[PATCH 1/1] mtd: spi_flash_free()
dfu_free_entities() invoking dfu_free_entity_sf() has let to segementation faults due to double freeing the same device.
spi_flash_free() is not relevant for the driver model but exists only for compatibility with old drivers.
We must not remove any device here:
* The device may still be referenced. * We don't want to have to probe again.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/mtd/spi/sf-uclass.c | 5 ----- include/spi_flash.h | 4 +++- 2 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/spi/sf-uclass.c b/drivers/mtd/spi/sf-uclass.c index 12d132152d..fd1bec80d6 100644 --- a/drivers/mtd/spi/sf-uclass.c +++ b/drivers/mtd/spi/sf-uclass.c @@ -46,11 +46,6 @@ struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, return dev_get_uclass_priv(dev); }
-void spi_flash_free(struct spi_flash *flash) -{ - device_remove(flash->spi->dev, DM_REMOVE_NORMAL); -} - int spi_flash_probe_bus_cs(unsigned int busnum, unsigned int cs, unsigned int max_hz, unsigned int spi_mode, struct udevice **devp) diff --git a/include/spi_flash.h b/include/spi_flash.h index 85cae32cc7..478c543b06 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -97,7 +97,9 @@ struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int spi_mode);
/* Compatibility function - this is the old U-Boot API */ -void spi_flash_free(struct spi_flash *flash); +static inline void spi_flash_free(struct spi_flash *flash) +{ +}
static inline int spi_flash_read(struct spi_flash *flash, u32 offset, size_t len, void *buf) -- 2.30.1
Applied to u-boot-dm/next, thanks!
