[U-Boot] [PATCH] Kconfig: Add EEPROM options to Kconfig when I2C_EEPROM is set
Add the following options to drivers/misc/Kconfig: SYS_I2C_EEPROM_ADDR SYS_I2C_EEPROM_BUS SYS_EEPROM_SIZE SYS_EEPROM_PAGE_WRITE_BITS SYS_EEPROM_PAGE_WRITE_DELAY_MS SYS_I2C_EEPROM_ADDR_LEN SYS_I2C_EEPROM_ADDR_OVERFLOW
This does not migrate any boards, but provides a foundations for those who want/need these options
Signed-off-by: Adam Ford aford173@gmail.com --- common/Kconfig | 30 ------------------------------ drivers/misc/Kconfig | 45 +++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 45 insertions(+), 30 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index 0983891..aa50b03 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -204,40 +204,10 @@ config ENV_IS_IN_EEPROM These two #defines specify the offset and size of the environment area within the total memory of your EEPROM.
- - CONFIG_SYS_I2C_EEPROM_ADDR: - If defined, specified the chip address of the EEPROM device. - The default address is zero. - - - CONFIG_SYS_I2C_EEPROM_BUS: - If defined, specified the i2c bus of the EEPROM device. - - - CONFIG_SYS_EEPROM_PAGE_WRITE_BITS: - If defined, the number of bits used to address bytes in a - single page in the EEPROM device. A 64 byte page, for example - would require six bits. - - - CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS: - If defined, the number of milliseconds to delay between - page writes. The default is zero milliseconds. - - - CONFIG_SYS_I2C_EEPROM_ADDR_LEN: - The length in bytes of the EEPROM memory array address. Note - that this is NOT the chip address length! - - - CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW: - EEPROM chips that implement "address overflow" are ones - like Catalyst 24WC04/08/16 which has 9/10/11 bits of - address and the extra bits end up in the "chip address" bit - slots. This makes a 24WC08 (1Kbyte) chip look like four 256 - byte chips. - Note that we consider the length of the address field to still be one byte because the extra address bits are hidden in the chip address.
- - CONFIG_SYS_EEPROM_SIZE: - The size in bytes of the EEPROM device. - - CONFIG_ENV_EEPROM_IS_ON_I2C define this, if you have I2C and SPI activated, and your EEPROM, which holds the environment, is on the I2C bus. diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index d1ddbbe..3d282d5 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -196,4 +196,49 @@ config I2C_EEPROM depends on MISC help Enable a generic driver for EEPROMs attached via I2C. + +if I2C_EEPROM + +config SYS_I2C_EEPROM_ADDR + hex "Chip address of the EEPROM device" + default 0 + +config SYS_I2C_EEPROM_BUS + int "I2C bus of the EEPROM device." + default 0 + +config SYS_EEPROM_SIZE + int "Size in bytes of the EEPROM device" + default 256 + +config SYS_EEPROM_PAGE_WRITE_BITS + int "Number of bits used to address bytes in a single page" + default 0 + help + The EEPROM page size is 2^SYS_EEPROM_PAGE_WRITE_BITS. + A 64 byte page, for example would require six bits. + +config SYS_EEPROM_PAGE_WRITE_DELAY_MS + int "Number of milliseconds to delay between page writes" + default 0 + +config SYS_I2C_EEPROM_ADDR_LEN + int "Length in bytes of the EEPROM memory array address" + default 1 + help + Note: This is NOT the chip address length! + +config SYS_I2C_EEPROM_ADDR_OVERFLOW + hex "EEPROM Address Overflow" + default 0 + help + EEPROM chips that implement "address overflow" are ones + like Catalyst 24WC04/08/16 which has 9/10/11 bits of + address and the extra bits end up in the "chip address" bit + slots. This makes a 24WC08 (1Kbyte) chip look like four 256 + byte chips. + +endif + + endmenu
Hi Adam,
Perhaps Tom will migrate them when applying?
Most of these settings should go in device tree, not CONFIG.
Adam Ford
