[U-Boot] [PATCH] mtd: nand: omap_gpmc: fix error handling
"err" was an unsigned variable, causing negative error codes to turn into positive values, which are interpreted as an amount of succesfully corrected bitflips (and thus not an error).
In particular, this resulted in that if the elm reports uncorrectable errors (-EBADMSG), the MTD layer (and UBI) falsely succeeded.
Signed-off-by: Guido Martínez guido@vanguardiasur.com.ar --- drivers/mtd/nand/omap_gpmc.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/omap_gpmc.c b/drivers/mtd/nand/omap_gpmc.c index 93829a4..459904d 100644 --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -368,8 +368,9 @@ static int omap_correct_data_bch(struct mtd_info *mtd, uint8_t *dat, uint32_t error_loc[ELM_MAX_ERROR_COUNT]; enum bch_level bch_type; uint32_t i, ecc_flag = 0; - uint8_t count, err = 0; + uint8_t count; uint32_t byte_pos, bit_pos; + int err = 0;
/* check calculated ecc */ for (i = 0; i < ecc->bytes && !ecc_flag; i++) {
Thanks, Stefan
Signed-off-by: Guido Martínez guido@vanguardiasur.com.ar Reviewed-by: Stefan Roese sr@denx.de
Guido Martínez
Stefan Roese
