[PATCH] spi: xilinx_spi: Trivial fixes in axi qspi driver
Use __func__ instead for function name in debug. Use Linux style u32 instead of uint32_t.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Acked-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
drivers/spi/xilinx_spi.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index 0274afdc6e0d..b892cdae9bab 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -314,8 +314,7 @@ static int xilinx_spi_set_speed(struct udevice *bus, uint speed)
priv->freq = speed;
- debug("xilinx_spi_set_speed: regs=%p, speed=%d\n", priv->regs, - priv->freq); + debug("%s: regs=%p, speed=%d\n", __func__, priv->regs, priv->freq);
return 0; } @@ -324,7 +323,7 @@ static int xilinx_spi_set_mode(struct udevice *bus, uint mode) { struct xilinx_spi_priv *priv = dev_get_priv(bus); struct xilinx_spi_regs *regs = priv->regs; - uint32_t spicr; + u32 spicr;
spicr = readl(®s->spicr); if (mode & SPI_LSB_FIRST) @@ -339,8 +338,7 @@ static int xilinx_spi_set_mode(struct udevice *bus, uint mode) writel(spicr, ®s->spicr); priv->mode = mode;
- debug("xilinx_spi_set_mode: regs=%p, mode=%d\n", priv->regs, - priv->mode); + debug("%s: regs=%p, mode=%d\n", __func__, priv->regs, priv->mode);
return 0; }
st 17. 3. 2021 v 9:17 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
priv->freq = speed;
priv->freq);
debug("%s: regs=%p, speed=%d\n", __func__, priv->regs, priv->freq); return 0;
uint32_t spicr;
u32 spicr; spicr = readl(®s->spicr); if (mode & SPI_LSB_FIRST)
priv->mode);
debug("%s: regs=%p, mode=%d\n", __func__, priv->regs, priv->mode); return 0;
2.30.1
Applied. M
Michal Simek
Michal Simek
