[U-Boot] [PATCH RESEND v2 1/2] ARM: dts: dra7xx: Update spi-max-frequency for qspi slave node
Update the spi-max-frequency property of m25p80 flash slave to match that of TI QSPI controller node, so that QSPI operations happen at maximum supported frequency of 76.8MHz.
Signed-off-by: Vignesh R vigneshr@ti.com Reviewed-by: Jagan Teki jteki@openedev.com ---
v2: No changes
arch/arm/dts/dra7-evm.dts | 2 +- arch/arm/dts/dra72-evm-common.dtsi | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/dra7-evm.dts b/arch/arm/dts/dra7-evm.dts index fe755c05841d..be36d456206d 100644 --- a/arch/arm/dts/dra7-evm.dts +++ b/arch/arm/dts/dra7-evm.dts @@ -505,7 +505,7 @@ spi-max-frequency = <76800000>; m25p80@0 { compatible = "s25fl256s1","spi-flash"; - spi-max-frequency = <64000000>; + spi-max-frequency = <76800000>; reg = <0>; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; diff --git a/arch/arm/dts/dra72-evm-common.dtsi b/arch/arm/dts/dra72-evm-common.dtsi index b0993e5bf7e0..1e1ca725577f 100644 --- a/arch/arm/dts/dra72-evm-common.dtsi +++ b/arch/arm/dts/dra72-evm-common.dtsi @@ -441,7 +441,7 @@ spi-max-frequency = <76800000>; m25p80@0 { compatible = "s25fl256s1", "spi-flash"; - spi-max-frequency = <64000000>; + spi-max-frequency = <76800000>; reg = <0>; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>;
Fix the divider calculation logic to choose a value so that the resulting baudrate is either equal to or closest possible baudrate less than the requested value. While at that, cleanup ti_spi_set_speed().
Signed-off-by: Vignesh R vigneshr@ti.com ---
v2: cleanup ti_spi_set_speed() a bit.
drivers/spi/ti_qspi.c | 15 +++++++-------- 1 file changed, 7 insertions(+), 8 deletions(-)
diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index 52520dff6325..b5de70bf40e3 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -16,6 +16,7 @@ #include <asm/omap_gpio.h> #include <asm/omap_common.h> #include <asm/ti-common/ti-edma3.h> +#include <linux/kernel.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -118,21 +119,19 @@ static void ti_spi_set_speed(struct ti_qspi_priv *priv, uint hz) if (!hz) clk_div = 0; else - clk_div = (priv->fclk / hz) - 1; - - debug("ti_spi_set_speed: hz: %d, clock divider %d\n", hz, clk_div); + clk_div = DIV_ROUND_UP(priv->fclk, hz) - 1;
/* disable SCLK */ writel(readl(&priv->base->clk_ctrl) & ~QSPI_CLK_EN, &priv->base->clk_ctrl);
- /* assign clk_div values */ - if (clk_div < 0) - clk_div = 0; - else if (clk_div > QSPI_CLK_DIV_MAX) + /* truncate clk_div value to QSPI_CLK_DIV_MAX */ + if (clk_div > QSPI_CLK_DIV_MAX) clk_div = QSPI_CLK_DIV_MAX;
- /* enable SCLK */ + debug("ti_spi_set_speed: hz: %d, clock divider %d\n", hz, clk_div); + + /* enable SCLK and program the clk divider */ writel(QSPI_CLK_EN | clk_div, &priv->base->clk_ctrl); }
clk_div = DIV_ROUND_UP(priv->fclk, hz) - 1; /* disable SCLK */ writel(readl(&priv->base->clk_ctrl) & ~QSPI_CLK_EN, &priv->base->clk_ctrl);
Move this before enable SCLK.
if (clk_div < 0)
clk_div = 0;
/* enable SCLK */
thanks!
Do send the updated v3 or discusses further, I need to send the release PR?
thanks!
Ok...
Sorry for the delay.. Posted v3 with above change.
And this is also done in the kernel right? Thanks!
Yes, the kernel patch is merged.
Jagan Teki
R, Vignesh
Vignesh R
