[U-Boot] [PATCH ARM v2] Add a unified s3c24x0 header file
This patch adds a unified s3c24x0 cpu header file that selects the header file for the specific s3c24x0 cpu from the SOC and CPU configs defined in board config file. This removes the current chain of s3c24-type #ifdef's from the s3c24x0 code.
Signed-off-by: Kevin Morfitt kevin.morfitt@fearnside-systems.co.uk --- v2 changes: re-based to current u-boot-samsung.
board/mpl/vcma9/vcma9.c | 2 +- board/mpl/vcma9/vcma9.h | 2 +- board/samsung/smdk2400/smdk2400.c | 2 +- board/samsung/smdk2410/smdk2410.c | 2 +- board/sbc2410x/sbc2410x.c | 2 +- board/trab/cmd_trab.c | 2 +- board/trab/rs485.c | 2 +- board/trab/rs485.h | 2 +- board/trab/trab.c | 2 +- board/trab/trab_fkt.c | 2 +- board/trab/tsc2000.c | 2 +- board/trab/vfd.c | 2 +- cpu/arm920t/s3c24x0/interrupts.c | 6 +----- cpu/arm920t/s3c24x0/speed.c | 13 +++---------- cpu/arm920t/s3c24x0/timer.c | 15 +++------------ cpu/arm920t/s3c24x0/usb.c | 17 +++++++---------- cpu/arm920t/s3c24x0/usb_ohci.c | 11 +++-------- cpu/arm920t/start.S | 4 ++-- drivers/i2c/s3c24x0_i2c.c | 6 +----- drivers/mtd/nand/s3c2410_nand.c | 2 +- drivers/rtc/s3c24x0_rtc.c | 6 +----- drivers/serial/serial_s3c24x0.c | 6 +----- drivers/usb/host/ohci-hcd.c | 3 +-- include/asm-arm/arch-s3c24x0/s3c24x0_cpu.h | 27 +++++++++++++++++++++++++++ include/common.h | 5 +++-- include/configs/VCMA9.h | 7 ++++--- include/configs/sbc2410x.h | 7 ++++--- include/configs/smdk2400.h | 7 ++++--- include/configs/smdk2410.h | 7 ++++--- include/configs/trab.h | 9 +++++---- 30 files changed, 87 insertions(+), 95 deletions(-) create mode 100644 include/asm-arm/arch-s3c24x0/s3c24x0_cpu.h
diff --git a/board/mpl/vcma9/vcma9.c b/board/mpl/vcma9/vcma9.c index f3bd288..1835677 100644 --- a/board/mpl/vcma9/vcma9.c +++ b/board/mpl/vcma9/vcma9.c @@ -27,7 +27,7 @@
#include <common.h> #include <netdev.h> -#include <asm/arch/s3c2410.h> +#include <asm/arch/s3c24x0_cpu.h> #include <stdio_dev.h> #include <i2c.h>
diff --git a/board/mpl/vcma9/vcma9.h b/board/mpl/vcma9/vcma9.h index 2c4305c..94fd2fa 100644 --- a/board/mpl/vcma9/vcma9.h +++ b/board/mpl/vcma9/vcma9.h @@ -25,7 +25,7 @@ * Global routines used for VCMA9 *****************************************************************************/
extern int mem_test(unsigned long start, unsigned long ramsize,int mode);
diff --git a/board/samsung/smdk2400/smdk2400.c b/board/samsung/smdk2400/smdk2400.c index be0c70a..1294d3f 100644 --- a/board/samsung/smdk2400/smdk2400.c +++ b/board/samsung/smdk2400/smdk2400.c @@ -27,7 +27,7 @@
#include <common.h> #include <netdev.h> -#include <asm/arch/s3c2400.h> +#include <asm/arch/s3c24x0_cpu.h>
DECLARE_GLOBAL_DATA_PTR;
diff --git a/board/samsung/smdk2410/smdk2410.c b/board/samsung/smdk2410/smdk2410.c index a8cf287..5d1a8bb 100644 --- a/board/samsung/smdk2410/smdk2410.c +++ b/board/samsung/smdk2410/smdk2410.c @@ -27,7 +27,7 @@
diff --git a/board/sbc2410x/sbc2410x.c b/board/sbc2410x/sbc2410x.c index 6768c02..3a93677 100644 --- a/board/sbc2410x/sbc2410x.c +++ b/board/sbc2410x/sbc2410x.c @@ -30,7 +30,7 @@
#if defined(CONFIG_CMD_NAND) #include <linux/mtd/nand.h> diff --git a/board/trab/cmd_trab.c b/board/trab/cmd_trab.c index a01ffcc..472d7d8 100644 --- a/board/trab/cmd_trab.c +++ b/board/trab/cmd_trab.c @@ -25,7 +25,7 @@
#include <common.h> #include <command.h> -#include <asm/arch/s3c2400.h> +#include <asm/arch/s3c24x0_cpu.h> #include <rtc.h>
/* diff --git a/board/trab/rs485.c b/board/trab/rs485.c index f402c59..ad0c136 100644 --- a/board/trab/rs485.c +++ b/board/trab/rs485.c @@ -22,7 +22,7 @@ */
#include <common.h> -#include <asm/arch/s3c2400.h> +#include <asm/arch/s3c24x0_cpu.h> #include "rs485.h"
static void rs485_setbrg (void); diff --git a/board/trab/rs485.h b/board/trab/rs485.h index 4a2d83f..16d69bb 100644 --- a/board/trab/rs485.h +++ b/board/trab/rs485.h @@ -24,7 +24,7 @@ #ifndef _RS485_H_ #define _RS485_H_
int rs485_init (void); int rs485_getc (void); diff --git a/board/trab/trab.c b/board/trab/trab.c index f8836ff..71fd22c 100644 --- a/board/trab/trab.c +++ b/board/trab/trab.c @@ -26,7 +26,7 @@ #include <common.h> #include <netdev.h> #include <malloc.h> -#include <asm/arch/s3c2400.h> +#include <asm/arch/s3c24x0_cpu.h> #include <command.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/trab/trab_fkt.c b/board/trab/trab_fkt.c index 940e12f..2df9a04 100644 --- a/board/trab/trab_fkt.c +++ b/board/trab/trab_fkt.c @@ -26,7 +26,7 @@ #include <common.h> #include <exports.h> #include <timestamp.h> -#include <asm/arch/s3c2400.h> +#include <asm/arch/s3c24x0_cpu.h> #include "tsc2000.h" #include "rs485.h"
diff --git a/board/trab/tsc2000.c b/board/trab/tsc2000.c index f757202..5890624 100644 --- a/board/trab/tsc2000.c +++ b/board/trab/tsc2000.c @@ -26,7 +26,7 @@ */
#include <common.h> -#include <asm/arch/s3c2400.h> +#include <asm/arch/s3c24x0_cpu.h> #include <asm/io.h> #include <div64.h> #include "tsc2000.h" diff --git a/board/trab/vfd.c b/board/trab/vfd.c index 8d9a057..b7eb8cc 100644 --- a/board/trab/vfd.c +++ b/board/trab/vfd.c @@ -37,7 +37,7 @@ #include <stdarg.h> #include <linux/types.h> #include <stdio_dev.h> -#include <asm/arch/s3c2400.h> +#include <asm/arch/s3c24x0_cpu.h>
diff --git a/cpu/arm920t/s3c24x0/interrupts.c b/cpu/arm920t/s3c24x0/interrupts.c index 3e8422e..879fda6 100644 --- a/cpu/arm920t/s3c24x0/interrupts.c +++ b/cpu/arm920t/s3c24x0/interrupts.c @@ -31,11 +31,7 @@
#include <common.h>
-#if defined(CONFIG_S3C2400) -#include <asm/arch/s3c2400.h> -#elif defined(CONFIG_S3C2410) -#include <asm/arch/s3c2410.h> -#endif +#include <asm/arch/s3c24x0_cpu.h> #include <asm/proc-armv/ptrace.h>
void do_irq (struct pt_regs *pt_regs) diff --git a/cpu/arm920t/s3c24x0/speed.c b/cpu/arm920t/s3c24x0/speed.c index 85c73a3..b13283a 100644 --- a/cpu/arm920t/s3c24x0/speed.c +++ b/cpu/arm920t/s3c24x0/speed.c @@ -30,15 +30,10 @@ */
#include <common.h> -#if defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_TRAB) +#ifdef CONFIG_S3C24X0
#include <asm/io.h> - -#if defined(CONFIG_S3C2400) -#include <asm/arch/s3c2400.h> -#elif defined(CONFIG_S3C2410) -#include <asm/arch/s3c2410.h> -#endif +#include <asm/arch/s3c24x0_cpu.h>
#define MPLL 0 #define UPLL 1 @@ -100,6 +95,4 @@ ulong get_UCLK(void) return get_PLLCLK(UPLL); }
-#endif /* defined(CONFIG_S3C2400) || - defined (CONFIG_S3C2410) || - defined (CONFIG_TRAB) */ +#endif /* CONFIG_S3C24X0 */ diff --git a/cpu/arm920t/s3c24x0/timer.c b/cpu/arm920t/s3c24x0/timer.c index 2667da6..cd06f6b 100644 --- a/cpu/arm920t/s3c24x0/timer.c +++ b/cpu/arm920t/s3c24x0/timer.c @@ -30,17 +30,10 @@ */
#include <common.h> -#if defined(CONFIG_S3C2400) || \ - defined(CONFIG_S3C2410) || \ - defined(CONFIG_TRAB) +#ifdef CONFIG_S3C24X0
int timer_load_val = 0; static ulong timer_clk; @@ -225,6 +218,4 @@ void reset_cpu(ulong ignored) /*NOTREACHED*/ }
-#endif /* defined(CONFIG_S3C2400) || - defined (CONFIG_S3C2410) || - defined (CONFIG_TRAB) */ +#endif /* CONFIG_S3C24X0 */ diff --git a/cpu/arm920t/s3c24x0/usb.c b/cpu/arm920t/s3c24x0/usb.c index 5e19cda..e468ed0 100644 --- a/cpu/arm920t/s3c24x0/usb.c +++ b/cpu/arm920t/s3c24x0/usb.c @@ -23,15 +23,11 @@
#include <common.h>
-#if defined(CONFIG_USB_OHCI_NEW) && defined(CONFIG_SYS_USB_OHCI_CPU_INIT) -# if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) - -#if defined(CONFIG_S3C2400) -# include <asm/arch/s3c2400.h> -#elif defined(CONFIG_S3C2410) -# include <asm/arch/s3c2410.h> -#endif +#if defined(CONFIG_USB_OHCI_NEW) && \ + defined(CONFIG_SYS_USB_OHCI_CPU_INIT) && \ + defined(CONFIG_S3C24X0)
int usb_cpu_init(void) @@ -70,5 +66,6 @@ int usb_cpu_init_fail(void) return 0; }
-# endif /* defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) */ -#endif /* defined(CONFIG_USB_OHCI_NEW) && defined(CONFIG_SYS_USB_OHCI_CPU_INIT) */ +#endif /* defined(CONFIG_USB_OHCI_NEW) && \ + defined(CONFIG_SYS_USB_OHCI_CPU_INIT) && \ + defined(CONFIG_S3C24X0) */ diff --git a/cpu/arm920t/s3c24x0/usb_ohci.c b/cpu/arm920t/s3c24x0/usb_ohci.c index 4111992..5aa8d64 100644 --- a/cpu/arm920t/s3c24x0/usb_ohci.c +++ b/cpu/arm920t/s3c24x0/usb_ohci.c @@ -36,14 +36,9 @@ #include <common.h> /* #include <pci.h> no PCI on the S3C24X0 */
-#ifdef CONFIG_USB_OHCI - -#if defined(CONFIG_S3C2400) -#include <asm/arch/s3c2400.h> -#elif defined(CONFIG_S3C2410) -#include <asm/arch/s3c2410.h> -#endif +#if defined(CONFIG_USB_OHCI) && defined(CONFIG_S3C24X0)
+#include <asm/arch/s3c24x0_cpu.h> #include <asm/io.h> #include <malloc.h> #include <usb.h> @@ -1757,4 +1752,4 @@ int usb_lowlevel_stop(void) return 0; }
-#endif /* CONFIG_USB_OHCI */ +#endif /* defined(CONFIG_USB_OHCI) && defined(CONFIG_S3C24X0) */ diff --git a/cpu/arm920t/start.S b/cpu/arm920t/start.S index 114427a..779f192 100644 --- a/cpu/arm920t/start.S +++ b/cpu/arm920t/start.S @@ -131,7 +131,7 @@ copyex: bne copyex #endif
-#if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) +#ifdef CONFIG_S3C24X0 /* turn off the watchdog */
# if defined(CONFIG_S3C2400) @@ -166,7 +166,7 @@ copyex: ldr r0, =CLKDIVN mov r1, #3 str r1, [r0] -#endif /* CONFIG_S3C2400 || CONFIG_S3C2410 */ +#endif /* CONFIG_S3C24X0 */
/* * we do sys-critical inits only at reboot, diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index 8fecc6e..c8371cf 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -27,11 +27,7 @@ */
#include <common.h> -#if defined(CONFIG_S3C2400) -#include <asm/arch/s3c2400.h> -#elif defined(CONFIG_S3C2410) -#include <asm/arch/s3c2410.h> -#endif +#include <asm/arch/s3c24x0_cpu.h>
#include <asm/io.h> #include <i2c.h> diff --git a/drivers/mtd/nand/s3c2410_nand.c b/drivers/mtd/nand/s3c2410_nand.c index 9f02dd8..3f15d2d 100644 --- a/drivers/mtd/nand/s3c2410_nand.c +++ b/drivers/mtd/nand/s3c2410_nand.c @@ -21,7 +21,7 @@ #include <common.h>
#include <nand.h> -#include <asm/arch/s3c2410.h> +#include <asm/arch/s3c24x0_cpu.h> #include <asm/io.h>
#define S3C2410_NFCONF_EN (1<<15) diff --git a/drivers/rtc/s3c24x0_rtc.c b/drivers/rtc/s3c24x0_rtc.c index 2d78f93..04de5ca 100644 --- a/drivers/rtc/s3c24x0_rtc.c +++ b/drivers/rtc/s3c24x0_rtc.c @@ -30,11 +30,7 @@
#if (defined(CONFIG_CMD_DATE))
#include <rtc.h> #include <asm/io.h> diff --git a/drivers/serial/serial_s3c24x0.c b/drivers/serial/serial_s3c24x0.c index 914d07c..5dd4dd8 100644 --- a/drivers/serial/serial_s3c24x0.c +++ b/drivers/serial/serial_s3c24x0.c @@ -19,11 +19,7 @@ */
#include <common.h> -#if defined(CONFIG_S3C2400) || defined(CONFIG_TRAB) -#include <asm/arch/s3c2400.h> -#elif defined(CONFIG_S3C2410) -#include <asm/arch/s3c2410.h> -#endif +#include <asm/arch/s3c24x0_cpu.h>
diff --git a/drivers/usb/host/ohci-hcd.c b/drivers/usb/host/ohci-hcd.c index 67d478f..b03a600 100644 --- a/drivers/usb/host/ohci-hcd.c +++ b/drivers/usb/host/ohci-hcd.c @@ -65,8 +65,7 @@ #endif
#if defined(CONFIG_ARM920T) || \ - defined(CONFIG_S3C2400) || \ - defined(CONFIG_S3C2410) || \ + defined(CONFIG_S3C24X0) || \ defined(CONFIG_S3C6400) || \ defined(CONFIG_440EP) || \ defined(CONFIG_PCI_OHCI) || \ diff --git a/include/asm-arm/arch-s3c24x0/s3c24x0_cpu.h b/include/asm-arm/arch-s3c24x0/s3c24x0_cpu.h new file mode 100644 index 0000000..c37d4a1 --- /dev/null +++ b/include/asm-arm/arch-s3c24x0/s3c24x0_cpu.h @@ -0,0 +1,27 @@ +/* + * (C) Copyright 2009 + * Kevin Morfitt, Fearnside Systems Ltd, kevin.morfitt@fearnside-systems.co.uk + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifdef CONFIG_S3C2400 + #include <asm/arch/s3c2400.h> +#elif defined CONFIG_S3C2410 + #include <asm/arch/s3c2410.h> +#else + #error Please define the s3c24x0 cpu type +#endif diff --git a/include/common.h b/include/common.h index f7c93bf..8ee80c1 100644 --- a/include/common.h +++ b/include/common.h @@ -495,8 +495,9 @@ int prt_mpc8220_clks (void); ulong get_OPB_freq (void); ulong get_PCI_freq (void); #endif -#if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) || \ - defined(CONFIG_LH7A40X) || defined(CONFIG_S3C6400) +#if defined(CONFIG_S3C24X0) || \ + defined(CONFIG_LH7A40X) || \ + defined(CONFIG_S3C6400) ulong get_FCLK (void); ulong get_HCLK (void); ulong get_PCLK (void); diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index 618b7f0..ebc81c4 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -33,9 +33,10 @@ * High Level Configuration Options * (easy to change) */ -#define CONFIG_ARM920T 1 /* This is an ARM920T Core */ -#define CONFIG_S3C2410 1 /* in a SAMSUNG S3C2410 SoC */ -#define CONFIG_VCMA9 1 /* on a MPL VCMA9 Board */ +#define CONFIG_ARM920T 1 /* This is an ARM920T Core */ +#define CONFIG_S3C24X0 1 /* in a SAMSUNG S3C24x0-type SoC */ +#define CONFIG_S3C2410 1 /* specifically a SAMSUNG S3C2410 SoC */ +#define CONFIG_VCMA9 1 /* on a MPL VCMA9 Board */
/* input clock of PLL */ #define CONFIG_SYS_CLK_FREQ 12000000/* VCMA9 has 12MHz input clock */ diff --git a/include/configs/sbc2410x.h b/include/configs/sbc2410x.h index e6886cf..025ad09 100644 --- a/include/configs/sbc2410x.h +++ b/include/configs/sbc2410x.h @@ -43,9 +43,10 @@ * High Level Configuration Options * (easy to change) */ -#define CONFIG_ARM920T 1 /* This is an ARM920T Core */ -#define CONFIG_S3C2410 1 /* in a SAMSUNG S3C2410 SoC */ -#define CONFIG_SBC2410X 1 /* on a friendly-arm SBC-2410X Board */ +#define CONFIG_ARM920T 1 /* This is an ARM920T Core */ +#define CONFIG_S3C24X0 1 /* in a SAMSUNG S3C24x0-type SoC */ +#define CONFIG_S3C2410 1 /* specifically a SAMSUNG S3C2410 SoC */ +#define CONFIG_SBC2410X 1 /* on a friendly-arm SBC-2410X Board */
/* input clock of PLL */ #define CONFIG_SYS_CLK_FREQ 12000000/* the SBC2410X has 12MHz input clock */ diff --git a/include/configs/smdk2400.h b/include/configs/smdk2400.h index a1beb65..fd51219 100644 --- a/include/configs/smdk2400.h +++ b/include/configs/smdk2400.h @@ -34,9 +34,10 @@ * High Level Configuration Options * (easy to change) */ -#define CONFIG_ARM920T 1 /* This is an ARM920T core */ -#define CONFIG_S3C2400 1 /* in a SAMSUNG S3C2400 SoC */ -#define CONFIG_SMDK2400 1 /* on an SAMSUNG SMDK2400 Board */ +#define CONFIG_ARM920T 1 /* This is an ARM920T core */ +#define CONFIG_S3C24X0 1 /* in a SAMSUNG S3C24x0-type SoC */ +#define CONFIG_S3C2400 1 /* specifically a SAMSUNG S3C2400 SoC */ +#define CONFIG_SMDK2400 1 /* on an SAMSUNG SMDK2400 Board */
/* input clock of PLL */ #define CONFIG_SYS_CLK_FREQ 12000000 /* SMDK2400 has 12 MHz input clock */ diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index c57751b..f9d1e55 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -33,9 +33,10 @@ * High Level Configuration Options * (easy to change) */ -#define CONFIG_ARM920T 1 /* This is an ARM920T Core */ -#define CONFIG_S3C2410 1 /* in a SAMSUNG S3C2410 SoC */ -#define CONFIG_SMDK2410 1 /* on a SAMSUNG SMDK2410 Board */ +#define CONFIG_ARM920T 1 /* This is an ARM920T Core */ +#define CONFIG_S3C24X0 1 /* in a SAMSUNG S3C24x0-type SoC */ +#define CONFIG_S3C2410 1 /* specifically a SAMSUNG S3C2410 SoC */ +#define CONFIG_SMDK2410 1 /* on a SAMSUNG SMDK2410 Board */
/* input clock of PLL */ #define CONFIG_SYS_CLK_FREQ 12000000/* the SMDK2410 has 12MHz input clock */ diff --git a/include/configs/trab.h b/include/configs/trab.h index 97f30ce..9827195 100644 --- a/include/configs/trab.h +++ b/include/configs/trab.h @@ -40,10 +40,11 @@ * High Level Configuration Options * (easy to change) */ -#define CONFIG_ARM920T 1 /* This is an arm920t CPU */ -#define CONFIG_S3C2400 1 /* in a SAMSUNG S3C2400 SoC */ -#define CONFIG_TRAB 1 /* on a TRAB Board */ -#undef CONFIG_TRAB_50MHZ /* run the CPU at 50 MHz */ +#define CONFIG_ARM920T 1 /* This is an arm920t CPU */ +#define CONFIG_S3C24X0 1 /* in a SAMSUNG S3C24x0-type SoC */ +#define CONFIG_S3C2400 1 /* specifically a SAMSUNG S3C2400 SoC */ +#define CONFIG_TRAB 1 /* on a TRAB Board */ +#undef CONFIG_TRAB_50MHZ /* run the CPU at 50 MHz */
/* automatic software updates (see board/trab/auto_update.c) */ #define CONFIG_AUTO_UPDATE 1
Dear Kevin Morfitt,
2009/11/17 kevin.morfitt@fearnside-systems.co.uk kevin.morfitt@fearnside-systems.co.uk:
applied to u-boot-samsung
Thanks Minkyu Kang
Minkyu Kang
