[PATCH 2/2] doc: rockchip: Update and complete info about RK3308
Update documentation about build steps for RK3308, using an external TPL. Add RK3308 case to rST document. Add ROCK Pi S in the list of supported boards.
Signed-off-by: Massimo Pegorer massimo.pegorer+oss@gmail.com --- doc/README.rockchip | 4 ++-- doc/board/rockchip/rockchip.rst | 10 ++++++++++ 2 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/doc/README.rockchip b/doc/README.rockchip index 52b5140eca..cfbd858c3b 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -38,16 +38,16 @@ Building (or you can use another cross compiler if you prefer)
2. To build RK3308 board: + - Get the rkbin => git clone https://github.com/rockchip-linux/rkbin.git
- Compile U-Boot => cd /path/to/u-boot => export BL31=/path/to/rkbin/bin/rk33/rk3308_bl31_v2.22.elf + => export ROCKCHIP_TPL=/path/to/rkbin/bin/rk33/rk3308_ddr_589MHz_uart2_m0_v1.26.bin => make roc-cc-rk3308_defconfig => make CROSS_COMPILE=aarch64-linux-gnu- all - => ./tools/mkimage -n rk3308 -T rksd -d /path/to/rkbin/bin/rk33/rk3308_ddr_589MHz_uart2_m0_v1.26.bin idbloader.img - => cat spl/u-boot-spl.bin >> idbloader.img
3. To build RK3399 board:
diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index de9fe8e642..b38c3d3136 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -53,6 +53,7 @@ List of mainline supported Rockchip boards: - Google Speedy (chromebook_speedy) - Amarula Vyasa-RK3288 (vyasa-rk3288) * rk3308 + - Radxa ROCK Pi S (rock-pi-s-rk3308) - Rockchip Evb-RK3308 (evb-rk3308) - Roc-cc-RK3308 (roc-cc-rk3308) * rk3326 @@ -172,6 +173,15 @@ To build rk3288 boards: make evb-rk3288_defconfig make CROSS_COMPILE=arm-linux-gnueabihf-
+To build rk3308 boards: + +.. code-block:: bash + + export BL31=../rkbin/bin/rk33/rk3308_bl31_vX.YZ.elf + export ROCKCHIP_TPL=../rkbin/bin/rk33/rk3308_ddr_589MHz_uart0_m0_vX.YZ.bin + make evb-rk3308_defconfig + make CROSS_COMPILE=aarch64-linux-gnu- + To build rk3328 boards:
- To build RK3308 board:
Hi Massimo,
The text in this document should moved to doc/board/rockchip. This paragraph above is therefor redundant, so it can be removed I think.
Johan
- To build RK3399 board:
- rk3308
- rk3326
Hi Johan,
Il giorno dom 3 set 2023 alle ore 10:36 Johan Jonker jbx6244@gmail.com ha scritto:
Hi Massimo,
Johan
OK, thanks, I agree on redundant. But I do not know if everything here - other than RK3308 info - has already been moved to doc/board/rockchip.rst, so to remove it. On the other hand, leaving as it is (i.e. not updated) would be misleading.
If everybody agree I can remove it in a V2, or otherwise just delete the RK3308 section.
Massimo
- rk3308
- rk3326
Johan Jonker
Massimo Pegorer
