[U-Boot] Please pull u-boot-ppc4xx/master
The following changes since commit 984f10baac8ef6032df52f135943d6b0bc96f724: Wolfgang Denk (1): mpc5121ads: fix breakage introduced when reordering elpida_mddrc_config[]
git://www.denx.de/git/u-boot-ppc4xx.git master
Stefan Roese (3): ppc4xx: Convert PPC4xx UIC defines from lower case to upper case ppc4xx: Convert PPC4xx SDRAM defines from lower case to upper case ppc4xx: Remove mtsdram0() marcos and use common mtsdram() instead
board/amcc/acadia/acadia.c | 12 ++-- board/amcc/bamboo/bamboo.c | 28 +++++----- board/amcc/bubinga/bubinga.c | 12 ++-- board/amcc/canyonlands/canyonlands.c | 62 ++++++++++---------- board/amcc/ebony/ebony.c | 54 +++++++++--------- board/amcc/katmai/katmai.c | 72 ++++++++++++------------ board/amcc/kilauea/kilauea.c | 48 ++++++++-------- board/amcc/luan/luan.c | 32 +++++----- board/amcc/makalu/makalu.c | 48 ++++++++-------- board/amcc/ocotea/ocotea.c | 84 ++++++++++++++-------------- board/amcc/redwood/redwood.c | 60 ++++++++++---------- board/amcc/sequoia/sequoia.c | 42 +++++++------- board/amcc/taihu/taihu.c | 14 ++-- board/amcc/taishan/taishan.c | 60 ++++++++++---------- board/amcc/walnut/walnut.c | 14 ++-- board/amcc/yosemite/yosemite.c | 62 ++++++++++---------- board/amcc/yucca/yucca.c | 64 ++++++++++---------- board/cray/L1/L1.c | 32 +++++----- board/csb272/csb272.c | 22 ++++---- board/csb272/init.S | 18 +++--- board/csb472/csb472.c | 22 ++++---- board/csb472/init.S | 18 +++--- board/dave/PPChameleonEVB/PPChameleonEVB.c | 14 ++-- board/eric/eric.c | 14 ++-- board/eric/init.S | 14 ++-- board/esd/apc405/apc405.c | 14 ++-- board/esd/ar405/ar405.c | 14 ++-- board/esd/ash405/ash405.c | 14 ++-- board/esd/canbt/canbt.c | 14 ++-- board/esd/cms700/cms700.c | 14 ++-- board/esd/cpci2dp/cpci2dp.c | 16 +++--- board/esd/cpci405/cpci405.c | 18 +++--- board/esd/cpciiser4/cpciiser4.c | 16 +++--- board/esd/dp405/dp405.c | 14 ++-- board/esd/du405/du405.c | 14 ++-- board/esd/du440/du440.c | 42 +++++++------- board/esd/hh405/hh405.c | 14 ++-- board/esd/hub405/hub405.c | 14 ++-- board/esd/ocrtc/ocrtc.c | 14 ++-- board/esd/pci405/pci405.c | 16 +++--- board/esd/plu405/plu405.c | 14 ++-- board/esd/pmc405/pmc405.c | 14 ++-- board/esd/pmc405de/pmc405de.c | 14 ++-- board/esd/pmc440/pmc440.c | 46 +++++++------- board/esd/voh405/voh405.c | 14 ++-- board/esd/vom405/vom405.c | 14 ++-- board/esd/wuh405/wuh405.c | 14 ++-- board/exbitgen/exbitgen.c | 22 ++++---- board/exbitgen/init.S | 14 ++-- board/g2000/g2000.c | 41 +++++++------- board/gdsys/dlvision/dlvision.c | 14 ++-- board/gdsys/gdppc440etx/gdppc440etx.c | 28 +++++----- board/gdsys/intip/intip.c | 56 +++++++++--------- board/gdsys/neo/neo.c | 14 ++-- board/jse/jse.c | 12 ++-- board/jse/sdram.c | 36 ++++++------ board/korat/korat.c | 46 +++++++------- board/lwmon5/lwmon5.c | 42 +++++++------- board/mpl/mip405/mip405.c | 52 ++++++++-------- board/mpl/pip405/pip405.c | 50 ++++++++-------- board/netstal/common/fixed_sdram.c | 40 +++++++------- board/netstal/hcu4/hcu4.c | 12 ++-- board/netstal/hcu5/hcu5.c | 46 +++++++------- board/netstal/mcu25/mcu25.c | 12 ++-- board/pcs440ep/pcs440ep.c | 30 +++++----- board/prodrive/alpr/alpr.c | 60 ++++++++++---------- board/prodrive/p3p440/p3p440.c | 30 +++++----- board/quad100hd/quad100hd.c | 14 ++-- board/sandburst/common/sb_common.c | 24 ++++---- board/sandburst/karef/karef.c | 60 ++++++++++---------- board/sandburst/metrobox/metrobox.c | 60 ++++++++++---------- board/sbc405/sbc405.c | 14 ++-- board/sc3/sc3.c | 40 +++++++------- board/w7o/init.S | 10 ++-- board/w7o/w7o.c | 36 ++++++------ board/xes/xpedite1000/xpedite1000.c | 54 +++++++++--------- board/zeus/zeus.c | 14 ++-- common/cmd_reginfo.c | 78 +++++++++++++------------- cpu/ppc4xx/40x_spd_sdram.c | 27 ++++----- cpu/ppc4xx/44x_spd_ddr.c | 44 +++++++------- cpu/ppc4xx/sdram.c | 60 ++++++++++---------- cpu/ppc4xx/uic.c | 28 +++++----- include/asm-ppc/ppc4xx-sdram.h | 86 +++++++++++---------------- include/asm-ppc/ppc4xx-uic.h | 80 +++++++++++--------------- nand_spl/board/amcc/bamboo/sdram.c | 26 ++++---- 85 files changed, 1341 insertions(+), 1371 deletions(-)
Dear Stefan Roese,
Applied, thanks.
Stefan Roese
