[U-Boot-Users] [PATCH ARM/AT91 0/20] AT91SAM/CAP patches for U-Boot 1.3.4
The following patches add support for the missing AT91SAM9 boards: - AT91SAM9261 - AT91SAM9263 - AT91SAM9RL
Additionnaly, they fix a few minor things in the existing AT91SAM9260 and AT91CAP9 ports: dataflash offsets, 8/16 bit NAND support, SPI timings, consistent Linux bootargs.
The second half of the patches (from 12 to 19) adds a driver for the LCD controller on the Atmel boards (except 9260). The driver could probably be adapted, with minimum efforts, to the AVR32 boards.
And finally, the last patch adds support for the revision 'C' of the AT91CAP9 silicon, which needs a special initialisation sequence to switch from the internal RC oscillator to the external 32k clock.
Thanks,
Stelian.
Signed-off-by: Stelian Pop stelian@popies.net --- board/atmel/at91cap9adk/at91cap9adk.c | 8 ++++++-- board/atmel/at91cap9adk/nand.c | 3 +++ include/configs/at91cap9adk.h | 1 + 3 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/board/atmel/at91cap9adk/at91cap9adk.c b/board/atmel/at91cap9adk/at91cap9adk.c index 24861ba..ab56f3a 100644 --- a/board/atmel/at91cap9adk/at91cap9adk.c +++ b/board/atmel/at91cap9adk/at91cap9adk.c @@ -116,7 +116,12 @@ static void at91cap9_nand_hw_init(void) at91_sys_write(AT91_SMC_MODE(3), AT91_SMC_READMODE | AT91_SMC_WRITEMODE | AT91_SMC_EXNWMODE_DISABLE | - AT91_SMC_DBW_8 | AT91_SMC_TDF_(1)); +#ifdef CFG_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CFG_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(1));
at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_PIOABCD);
@@ -252,7 +257,6 @@ int board_init(void) #ifdef CONFIG_USB_OHCI_NEW at91cap9_uhp_hw_init(); #endif - return 0; }
diff --git a/board/atmel/at91cap9adk/nand.c b/board/atmel/at91cap9adk/nand.c index c72b024..5d49aee 100644 --- a/board/atmel/at91cap9adk/nand.c +++ b/board/atmel/at91cap9adk/nand.c @@ -63,6 +63,9 @@ static void at91cap9adk_nand_hwcontrol(struct mtd_info *mtd, int cmd) int board_nand_init(struct nand_chip *nand) { nand->eccmode = NAND_ECC_SOFT; +#ifdef CFG_NAND_DBW_16 + nand->options = NAND_BUSWIDTH_16; +#endif nand->hwcontrol = at91cap9adk_nand_hwcontrol; nand->chip_delay = 20;
diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index dab21d0..88527a4 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -110,6 +110,7 @@ #define NAND_MAX_CHIPS 1 #define CFG_MAX_NAND_DEVICE 1 #define CFG_NAND_BASE 0x40000000 +#define CFG_NAND_DBW_8 1
/* Ethernet */ #define CONFIG_MACB 1
Already in the at91 tree
Best Regards, J.
Signed-off-by: Stelian Pop stelian@popies.net --- include/configs/at91cap9adk.h | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index 88527a4..a648ce0 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -94,9 +94,9 @@ #define CFG_SPI_WRITE_TOUT (5*CFG_HZ) #define CFG_MAX_DATAFLASH_BANKS 1 #define CFG_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ -#define AT91_SPI_CLK 20000000 -#define DATAFLASH_TCSS (0xFA << 16) -#define DATAFLASH_TCHS (0x8 << 24) +#define AT91_SPI_CLK 15000000 +#define DATAFLASH_TCSS (0x1a << 16) +#define DATAFLASH_TCHS (0x1 << 24)
/* NOR flash */ #define CFG_FLASH_CFI 1
Stelian Pop's patch:
What do you mean by "Normalize SPI timings"?
Why are you replacing 20000000 Hz with 15000000 Hz? Faster would be better as long as the SPI bus operates reliably, right?
Sincerely,
Ken Fuchs
I used here what the kernel people use. I tend to be more confident in the values used in the kernel (where the code is used by many) than in some random speed picked up from Atmel's example files.
As for TCSS/TCHS, the values comes from Atmel's bootstrap project.
Best Regards, J.
Signed-off-by: Stelian Pop stelian@popies.net --- include/configs/at91cap9adk.h | 10 ++++++++-- 1 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index a648ce0..78b2283 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -56,8 +56,6 @@ #define CONFIG_USART3 1 /* USART 3 is DBGU */
#define CONFIG_BOOTDELAY 3 -#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ - "root=/dev/mtdblock1 rw rootfstype=jffs2"
/* #define CONFIG_ENV_OVERWRITE 1 */
@@ -145,6 +143,10 @@ #define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS0 + CFG_ENV_OFFSET) #define CFG_ENV_SIZE 0x4200 #define CONFIG_BOOTCOMMAND "cp.b 0xC003DE00 0x72000000 0x200040; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock1 " \ + "mtdparts=physmap-flash.0:-(nor);at91_nand:-(root) "\ + "rw rootfstype=jffs2"
#else
@@ -155,6 +157,10 @@ #define CFG_ENV_ADDR (PHYS_FLASH_1 + CFG_ENV_OFFSET) #define CFG_ENV_SIZE 0x4000 #define CONFIG_BOOTCOMMAND "cp.b 0x10040000 0x72000000 0x200000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock4 " \ + "mtdparts=physmap-flash.0:16k(bootstrap)ro,16k(env),224k(uboot)ro,-(linux);at91_nand:-(root) "\ + "rw rootfstype=jffs2"
#endif
Please mind the maximum line length.
Please split this up.
In this particular case (there is only one kernel parameter here: mtdparts) I'm not sure splitting the line will have some added value.
But anyway, I'll split it up if you want to.
And no need to point to this line in all the config .h files, I know where are my copy and pastes :)
Stelian.
Stelian.
Already in the at91 tree Until you send your next patches I'll keep the currents
Best Regards, J.
Signed-off-by: Stelian Pop stelian@popies.net --- include/configs/at91cap9adk.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index 78b2283..ec70618 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -142,7 +142,7 @@ #define CFG_ENV_OFFSET 0x4200 #define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS0 + CFG_ENV_OFFSET) #define CFG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xC003DE00 0x72000000 0x200040; bootm" +#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x72000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock1 " \ "mtdparts=physmap-flash.0:-(nor);at91_nand:-(root) "\
Signed-off-by: Stelian Pop stelian@popies.net --- board/atmel/at91sam9260ek/at91sam9260ek.c | 7 ++++++- board/atmel/at91sam9260ek/nand.c | 3 +++ include/configs/at91sam9260ek.h | 1 + 3 files changed, 10 insertions(+), 1 deletions(-)
diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index a55468e..7d325e8 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -90,7 +90,12 @@ static void at91sam9260ek_nand_hw_init(void) at91_sys_write(AT91_SMC_MODE(3), AT91_SMC_READMODE | AT91_SMC_WRITEMODE | AT91_SMC_EXNWMODE_DISABLE | - AT91_SMC_DBW_8 | AT91_SMC_TDF_(2)); +#ifdef CFG_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CFG_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(2));
at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC);
diff --git a/board/atmel/at91sam9260ek/nand.c b/board/atmel/at91sam9260ek/nand.c index abb788a..a92b105 100644 --- a/board/atmel/at91sam9260ek/nand.c +++ b/board/atmel/at91sam9260ek/nand.c @@ -68,6 +68,9 @@ static int at91sam9260ek_nand_ready(struct mtd_info *mtd) int board_nand_init(struct nand_chip *nand) { nand->eccmode = NAND_ECC_SOFT; +#ifdef CFG_NAND_DBW_16 + nand->options = NAND_BUSWIDTH_16; +#endif nand->hwcontrol = at91sam9260ek_nand_hwcontrol; nand->dev_ready = at91sam9260ek_nand_ready; nand->chip_delay = 20; diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 96d1b8d..8d02416 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -104,6 +104,7 @@ #define NAND_MAX_CHIPS 1 #define CFG_MAX_NAND_DEVICE 1 #define CFG_NAND_BASE 0x40000000 +#define CFG_NAND_DBW_8 1
/* NOR flash - no real flash on this board */ #define CFG_NO_FLASH 1
Best Regards, J.
Signed-off-by: Stelian Pop stelian@popies.net --- include/configs/at91sam9260ek.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 8d02416..0aac0f5 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -96,7 +96,7 @@ #define CFG_MAX_DATAFLASH_BANKS 2 #define CFG_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ #define CFG_DATAFLASH_LOGIC_ADDR_CS1 0xD0000000 /* CS1 */ -#define AT91_SPI_CLK 33000000 +#define AT91_SPI_CLK 15000000 #define DATAFLASH_TCSS (0x1a << 16) #define DATAFLASH_TCHS (0x1 << 24)
Best Regards, J.
Signed-off-by: Stelian Pop stelian@popies.net --- include/configs/at91sam9260ek.h | 14 ++++++++++++-- 1 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 0aac0f5..e25985e 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -56,8 +56,6 @@ #define CONFIG_USART3 1 /* USART 3 is DBGU */
#define CONFIG_BOOTDELAY 3 -#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ - "root=/dev/mtdblock0 rw rootfstype=jffs2"
@@ -144,6 +142,10 @@ #define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS0 + CFG_ENV_OFFSET) #define CFG_ENV_SIZE 0x4200 #define CONFIG_BOOTCOMMAND "cp.b 0xC003DE00 0x22000000 0x200040; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock0 " \ + "mtdparts=at91_nand:-(root) "\ + "rw rootfstype=jffs2"
#elif CFG_USE_DATAFLASH_CS1
@@ -154,6 +156,10 @@ #define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS1 + CFG_ENV_OFFSET) #define CFG_ENV_SIZE 0x4200 #define CONFIG_BOOTCOMMAND "cp.b 0xD003DE00 0x22000000 0x200040; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock0 " \ + "mtdparts=at91_nand:-(root) "\ + "rw rootfstype=jffs2"
#else /* CFG_USE_NANDFLASH */
@@ -163,6 +169,10 @@ #define CFG_ENV_OFFSET_REDUND 0x80000 #define CFG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ #define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xA0000 0x200000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock5 " \ + "mtdparts=at91_nand:128k(bootstrap)ro,256k(uboot)ro,128k(env1)ro,128k(env2)ro,2M(linux),-(root) " \ + "rw rootfstype=jffs2"
#endif
Best Regards, J.
Signed-off-by: Stelian Pop stelian@popies.net --- include/configs/at91sam9260ek.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index e25985e..f334a53 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -141,7 +141,7 @@ #define CFG_ENV_OFFSET 0x4200 #define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS0 + CFG_ENV_OFFSET) #define CFG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xC003DE00 0x22000000 0x200040; bootm" +#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=at91_nand:-(root) "\ @@ -155,7 +155,7 @@ #define CFG_ENV_OFFSET 0x4200 #define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS1 + CFG_ENV_OFFSET) #define CFG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xD003DE00 0x22000000 0x200040; bootm" +#define CONFIG_BOOTCOMMAND "cp.b 0xD0042000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=at91_nand:-(root) "\
Signed-off-by: Stelian Pop stelian@popies.net --- MAINTAINERS | 1 + MAKEALL | 1 + Makefile | 3 + board/atmel/at91sam9261ek/Makefile | 53 ++++++ board/atmel/at91sam9261ek/at91sam9261ek.c | 194 ++++++++++++++++++++ board/atmel/at91sam9261ek/config.mk | 1 + board/atmel/at91sam9261ek/led.c | 78 ++++++++ board/atmel/at91sam9261ek/nand.c | 79 ++++++++ board/atmel/at91sam9261ek/partition.c | 38 ++++ board/atmel/at91sam9261ek/u-boot.lds | 57 ++++++ cpu/arm926ejs/at91sam9/usb.c | 8 + drivers/net/dm9000x.c | 2 + include/asm-arm/arch-at91sam9/at91sam9261.h | 105 +++++++++++ include/asm-arm/arch-at91sam9/at91sam9261_matrix.h | 62 +++++++ include/asm-arm/arch-at91sam9/hardware.h | 3 + include/configs/at91sam9261ek.h | 189 +++++++++++++++++++ 16 files changed, 874 insertions(+), 0 deletions(-) create mode 100644 board/atmel/at91sam9261ek/Makefile create mode 100644 board/atmel/at91sam9261ek/at91sam9261ek.c create mode 100644 board/atmel/at91sam9261ek/config.mk create mode 100644 board/atmel/at91sam9261ek/led.c create mode 100644 board/atmel/at91sam9261ek/nand.c create mode 100644 board/atmel/at91sam9261ek/partition.c create mode 100644 board/atmel/at91sam9261ek/u-boot.lds create mode 100644 include/asm-arm/arch-at91sam9/at91sam9261.h create mode 100644 include/asm-arm/arch-at91sam9/at91sam9261_matrix.h create mode 100644 include/configs/at91sam9261ek.h
diff --git a/MAINTAINERS b/MAINTAINERS index 58f833c..26f31fd 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -538,6 +538,7 @@ Stelian Pop stelian.pop@leadtechdesign.com
at91cap9adk ARM926EJS (AT91CAP9 SoC) at91sam9260ek ARM926EJS (AT91SAM9260 SoC) + at91sam9261ek ARM926EJS (AT91SAM9261 SoC)
Stefan Roese sr@denx.de
diff --git a/MAKEALL b/MAKEALL index 38911ed..251da90 100755 --- a/MAKEALL +++ b/MAKEALL @@ -458,6 +458,7 @@ LIST_ARM9=" \ at91cap9adk \ at91rm9200dk \ at91sam9260ek \ + at91sam9261ek \ cmc_pu2 \ ap920t \ ap922_XA10 \ diff --git a/Makefile b/Makefile index 167a717..5e06ff5 100644 --- a/Makefile +++ b/Makefile @@ -2326,6 +2326,9 @@ shannon_config : unconfig at91rm9200dk_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm920t at91rm9200dk atmel at91rm9200
+at91sam9261ek_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm926ejs at91sam9261ek atmel at91sam9 + cmc_pu2_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm920t cmc_pu2 NULL at91rm9200
diff --git a/board/atmel/at91sam9261ek/Makefile b/board/atmel/at91sam9261ek/Makefile new file mode 100644 index 0000000..5e4904c --- /dev/null +++ b/board/atmel/at91sam9261ek/Makefile @@ -0,0 +1,53 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd <at> denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += at91sam9261ek.o +COBJS-y += led.o +COBJS-y += partition.o +COBJS-$(CONFIG_CMD_NAND) += nand.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/atmel/at91sam9261ek/at91sam9261ek.c b/board/atmel/at91sam9261ek/at91sam9261ek.c new file mode 100644 index 0000000..55a178e --- /dev/null +++ b/board/atmel/at91sam9261ek/at91sam9261ek.c @@ -0,0 +1,194 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9261.h> +#include <asm/arch/at91sam9261_matrix.h> +#include <asm/arch/at91sam926x_mc.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_DRIVER_DM9000) +#include <net.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +static void at91sam9261ek_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PC8, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PC9, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_US0); +#endif + +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PC12, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PC13, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_US1); +#endif + +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PC14, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PC15, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_US2); +#endif + +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PA9, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PA10, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} + +#ifdef CONFIG_CMD_NAND +static void at91sam9261ek_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBICSA); + at91_sys_write(AT91_MATRIX_EBICSA, + csa | AT91_MATRIX_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(2) | AT91_SMC_NCS_WRPULSE_(5) | + AT91_SMC_NRDPULSE_(2) | AT91_SMC_NCS_RDPULSE_(5)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(7) | AT91_SMC_NRDCYCLE_(7)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | +#ifdef CFG_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CFG_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(1)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_PIOC); + + /* Configure RDY/BSY */ + at91_set_gpio_input(AT91_PIN_PC15, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(AT91_PIN_PC14, 1); + + at91_set_A_periph(AT91_PIN_PC0, 0); /* NANDOE */ + at91_set_A_periph(AT91_PIN_PC1, 0); /* NANDWE */ +} +#endif + +#ifdef CONFIG_HAS_DATAFLASH +static void at91sam9261ek_spi_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PA3, 0); /* SPI0_NPCS0 */ + + at91_set_A_periph(AT91_PIN_PA0, 0); /* SPI0_MISO */ + at91_set_A_periph(AT91_PIN_PA1, 0); /* SPI0_MOSI */ + at91_set_A_periph(AT91_PIN_PA2, 0); /* SPI0_SPCK */ + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_SPI0); +} +#endif + +#ifdef CONFIG_DRIVER_DM9000 +static void at91sam9261ek_dm9000_hw_init(void) +{ + /* Configure SMC CS2 for DM9000 */ + at91_sys_write(AT91_SMC_SETUP(2), + AT91_SMC_NWESETUP_(2) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(2) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(2), + AT91_SMC_NWEPULSE_(4) | AT91_SMC_NCS_WRPULSE_(8) | + AT91_SMC_NRDPULSE_(4) | AT91_SMC_NCS_RDPULSE_(8)); + at91_sys_write(AT91_SMC_CYCLE(2), + AT91_SMC_NWECYCLE_(16) | AT91_SMC_NRDCYCLE_(16)); + at91_sys_write(AT91_SMC_MODE(2), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | + AT91_SMC_BAT_WRITE | AT91_SMC_DBW_16 | + AT91_SMC_TDF_(1)); + + /* Configure Reset signal as output */ + at91_set_gpio_output(AT91_PIN_PC10, 0); + + /* Configure Interrupt pin as input, no pull-up */ + at91_set_gpio_input(AT91_PIN_PC11, 0); +} +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of AT91SAM9261EK-Board */ + gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9261EK; + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91sam9261ek_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + at91sam9261ek_nand_hw_init(); +#endif +#ifdef CONFIG_HAS_DATAFLASH + at91sam9261ek_spi_hw_init(); +#endif +#ifdef CONFIG_DRIVER_DM9000 + at91sam9261ek_dm9000_hw_init(); +#endif + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_DRIVER_DM9000 + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif diff --git a/board/atmel/at91sam9261ek/config.mk b/board/atmel/at91sam9261ek/config.mk new file mode 100644 index 0000000..ff2cfd1 --- /dev/null +++ b/board/atmel/at91sam9261ek/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x23f00000 diff --git a/board/atmel/at91sam9261ek/led.c b/board/atmel/at91sam9261ek/led.c new file mode 100644 index 0000000..49dd023 --- /dev/null +++ b/board/atmel/at91sam9261ek/led.c @@ -0,0 +1,78 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9261.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +#define RED_LED AT91_PIN_PA23 /* this is the power led */ +#define GREEN_LED AT91_PIN_PA13 /* this is the user1 led */ +#define YELLOW_LED AT91_PIN_PA14 /* this is the user2 led */ + +void red_LED_on(void) +{ + at91_set_gpio_value(RED_LED, 1); +} + +void red_LED_off(void) +{ + at91_set_gpio_value(RED_LED, 0); +} + +void green_LED_on(void) +{ + at91_set_gpio_value(GREEN_LED, 0); +} + +void green_LED_off(void) +{ + at91_set_gpio_value(GREEN_LED, 1); +} + +void yellow_LED_on(void) +{ + at91_set_gpio_value(YELLOW_LED, 0); +} + +void yellow_LED_off(void) +{ + at91_set_gpio_value(YELLOW_LED, 1); +} + + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_PIOA); + + at91_set_gpio_output(RED_LED, 1); + at91_set_gpio_output(GREEN_LED, 1); + at91_set_gpio_output(YELLOW_LED, 1); + + at91_set_gpio_value(RED_LED, 0); + at91_set_gpio_value(GREEN_LED, 1); + at91_set_gpio_value(YELLOW_LED, 1); +} diff --git a/board/atmel/at91sam9261ek/nand.c b/board/atmel/at91sam9261ek/nand.c new file mode 100644 index 0000000..666a846 --- /dev/null +++ b/board/atmel/at91sam9261ek/nand.c @@ -0,0 +1,79 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * (C) Copyright 2006 ATMEL Rousset, Lacressonniere Nicolas + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9261.h> +#include <asm/arch/gpio.h> +#include <asm/arch/at91_pio.h> + +#include <nand.h> + +/* + * hardware specific access to control-lines + */ +#define MASK_ALE (1 << 22) /* our ALE is AD22 */ +#define MASK_CLE (1 << 21) /* our CLE is AD21 */ + +static void at91sam9261ek_nand_hwcontrol(struct mtd_info *mtd, int cmd) +{ + struct nand_chip *this = mtd->priv; + ulong IO_ADDR_W = (ulong) this->IO_ADDR_W; + + IO_ADDR_W &= ~(MASK_ALE|MASK_CLE); + switch (cmd) { + case NAND_CTL_SETCLE: + IO_ADDR_W |= MASK_CLE; + break; + case NAND_CTL_SETALE: + IO_ADDR_W |= MASK_ALE; + break; + case NAND_CTL_CLRNCE: + at91_set_gpio_value(AT91_PIN_PC14, 1); + break; + case NAND_CTL_SETNCE: + at91_set_gpio_value(AT91_PIN_PC14, 0); + break; + } + this->IO_ADDR_W = (void *) IO_ADDR_W; +} + +static int at91sam9261ek_nand_ready(struct mtd_info *mtd) +{ + return at91_get_gpio_value(AT91_PIN_PC15); +} + +int board_nand_init(struct nand_chip *nand) +{ + nand->eccmode = NAND_ECC_SOFT; +#ifdef CFG_NAND_DBW_16 + nand->options = NAND_BUSWIDTH_16; +#endif + nand->hwcontrol = at91sam9261ek_nand_hwcontrol; + nand->dev_ready = at91sam9261ek_nand_ready; + nand->chip_delay = 20; + + return 0; +} diff --git a/board/atmel/at91sam9261ek/partition.c b/board/atmel/at91sam9261ek/partition.c new file mode 100644 index 0000000..a8a5fe6 --- /dev/null +++ b/board/atmel/at91sam9261ek/partition.c @@ -0,0 +1,38 @@ +/* + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <config.h> +#include <asm/hardware.h> +#include <dataflash.h> + +AT91S_DATAFLASH_INFO dataflash_info[CFG_MAX_DATAFLASH_BANKS]; + +struct dataflash_addr cs[CFG_MAX_DATAFLASH_BANKS] = { + {CFG_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ + {CFG_DATAFLASH_LOGIC_ADDR_CS3, 3} +}; + +/*define the area offsets*/ +dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { + {0x00000000, 0x000041FF, FLAG_PROTECT_SET, 0, "Bootstrap"}, + {0x00004200, 0x000083FF, FLAG_PROTECT_CLEAR, 0, "Environment"}, + {0x00008400, 0x00041FFF, FLAG_PROTECT_SET, 0, "U-Boot"}, + {0x00042000, 0x00251FFF, FLAG_PROTECT_CLEAR, 0, "Kernel"}, + {0x00252000, 0xFFFFFFFF, FLAG_PROTECT_CLEAR, 0, "FS"}, +}; diff --git a/board/atmel/at91sam9261ek/u-boot.lds b/board/atmel/at91sam9261ek/u-boot.lds new file mode 100644 index 0000000..05a6d83 --- /dev/null +++ b/board/atmel/at91sam9261ek/u-boot.lds @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, <gj <at> denx.de> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +/*OUTPUT_FORMAT("elf32-arm", "elf32-arm", "elf32-arm")*/ +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm926ejs/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/cpu/arm926ejs/at91sam9/usb.c b/cpu/arm926ejs/at91sam9/usb.c index d678897..92dcafb 100644 --- a/cpu/arm926ejs/at91sam9/usb.c +++ b/cpu/arm926ejs/at91sam9/usb.c @@ -33,7 +33,11 @@ int usb_cpu_init(void) { /* Enable USB host clock. */ at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_UHP); +#ifdef CONFIG_AT91SAM9261 + at91_sys_write(AT91_PMC_SCER, AT91_PMC_UHP | AT91_PMC_HCK0); +#else at91_sys_write(AT91_PMC_SCER, AT91_PMC_UHP); +#endif
return 0; } @@ -42,7 +46,11 @@ int usb_cpu_stop(void) { /* Disable USB host clock. */ at91_sys_write(AT91_PMC_PCDR, 1 << AT91_ID_UHP); +#ifdef CONFIG_AT91SAM9261 + at91_sys_write(AT91_PMC_SCDR, AT91_PMC_UHP | AT91_PMC_HCK0); +#else at91_sys_write(AT91_PMC_SCDR, AT91_PMC_UHP); +#endif return 0; }
diff --git a/drivers/net/dm9000x.c b/drivers/net/dm9000x.c index 6131b5c..db6d3bd 100644 --- a/drivers/net/dm9000x.c +++ b/drivers/net/dm9000x.c @@ -300,8 +300,10 @@ eth_init(bd_t * bd) DM9000_iow(DM9000_ISR, 0x0f); /* Clear interrupt status */
/* Set Node address */ +#ifndef CONFIG_AT91SAM9261EK for (i = 0; i < 6; i++) ((u16 *) bd->bi_enetaddr)[i] = read_srom_word(i); +#endif
if (is_zero_ether_addr(bd->bi_enetaddr) || is_multicast_ether_addr(bd->bi_enetaddr)) { diff --git a/include/asm-arm/arch-at91sam9/at91sam9261.h b/include/asm-arm/arch-at91sam9/at91sam9261.h new file mode 100644 index 0000000..c7c4778 --- /dev/null +++ b/include/asm-arm/arch-at91sam9/at91sam9261.h @@ -0,0 +1,105 @@ +/* + * include/asm-arm/arch-at91/at91sam9261.h + * + * Copyright (C) SAN People + * + * Common definitions. + * Based on AT91SAM9261 datasheet revision E. (Preliminary) + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef AT91SAM9261_H +#define AT91SAM9261_H + +/* + * Peripheral identifiers/interrupts. + */ +#define AT91_ID_FIQ 0 /* Advanced Interrupt Controller (FIQ) */ +#define AT91_ID_SYS 1 /* System Peripherals */ +#define AT91SAM9261_ID_PIOA 2 /* Parallel IO Controller A */ +#define AT91SAM9261_ID_PIOB 3 /* Parallel IO Controller B */ +#define AT91SAM9261_ID_PIOC 4 /* Parallel IO Controller C */ +#define AT91SAM9261_ID_US0 6 /* USART 0 */ +#define AT91SAM9261_ID_US1 7 /* USART 1 */ +#define AT91SAM9261_ID_US2 8 /* USART 2 */ +#define AT91SAM9261_ID_MCI 9 /* Multimedia Card Interface */ +#define AT91SAM9261_ID_UDP 10 /* USB Device Port */ +#define AT91SAM9261_ID_TWI 11 /* Two-Wire Interface */ +#define AT91SAM9261_ID_SPI0 12 /* Serial Peripheral Interface 0 */ +#define AT91SAM9261_ID_SPI1 13 /* Serial Peripheral Interface 1 */ +#define AT91SAM9261_ID_SSC0 14 /* Serial Synchronous Controller 0 */ +#define AT91SAM9261_ID_SSC1 15 /* Serial Synchronous Controller 1 */ +#define AT91SAM9261_ID_SSC2 16 /* Serial Synchronous Controller 2 */ +#define AT91SAM9261_ID_TC0 17 /* Timer Counter 0 */ +#define AT91SAM9261_ID_TC1 18 /* Timer Counter 1 */ +#define AT91SAM9261_ID_TC2 19 /* Timer Counter 2 */ +#define AT91SAM9261_ID_UHP 20 /* USB Host port */ +#define AT91SAM9261_ID_LCDC 21 /* LDC Controller */ +#define AT91SAM9261_ID_IRQ0 29 /* Advanced Interrupt Controller (IRQ0) */ +#define AT91SAM9261_ID_IRQ1 30 /* Advanced Interrupt Controller (IRQ1) */ +#define AT91SAM9261_ID_IRQ2 31 /* Advanced Interrupt Controller (IRQ2) */ + + +/* + * User Peripheral physical base addresses. + */ +#define AT91SAM9261_BASE_TCB0 0xfffa0000 +#define AT91SAM9261_BASE_TC0 0xfffa0000 +#define AT91SAM9261_BASE_TC1 0xfffa0040 +#define AT91SAM9261_BASE_TC2 0xfffa0080 +#define AT91SAM9261_BASE_UDP 0xfffa4000 +#define AT91SAM9261_BASE_MCI 0xfffa8000 +#define AT91SAM9261_BASE_TWI 0xfffac000 +#define AT91SAM9261_BASE_US0 0xfffb0000 +#define AT91SAM9261_BASE_US1 0xfffb4000 +#define AT91SAM9261_BASE_US2 0xfffb8000 +#define AT91SAM9261_BASE_SSC0 0xfffbc000 +#define AT91SAM9261_BASE_SSC1 0xfffc0000 +#define AT91SAM9261_BASE_SSC2 0xfffc4000 +#define AT91SAM9261_BASE_SPI0 0xfffc8000 +#define AT91SAM9261_BASE_SPI1 0xfffcc000 +#define AT91_BASE_SYS 0xffffea00 + + +/* + * System Peripherals (offset from AT91_BASE_SYS) + */ +#define AT91_SDRAMC (0xffffea00 - AT91_BASE_SYS) +#define AT91_SMC (0xffffec00 - AT91_BASE_SYS) +#define AT91_MATRIX (0xffffee00 - AT91_BASE_SYS) +#define AT91_AIC (0xfffff000 - AT91_BASE_SYS) +#define AT91_DBGU (0xfffff200 - AT91_BASE_SYS) +#define AT91_PIOA (0xfffff400 - AT91_BASE_SYS) +#define AT91_PIOB (0xfffff600 - AT91_BASE_SYS) +#define AT91_PIOC (0xfffff800 - AT91_BASE_SYS) +#define AT91_PMC (0xfffffc00 - AT91_BASE_SYS) +#define AT91_RSTC (0xfffffd00 - AT91_BASE_SYS) +#define AT91_SHDWC (0xfffffd10 - AT91_BASE_SYS) +#define AT91_RTT (0xfffffd20 - AT91_BASE_SYS) +#define AT91_PIT (0xfffffd30 - AT91_BASE_SYS) +#define AT91_WDT (0xfffffd40 - AT91_BASE_SYS) +#define AT91_GPBR (0xfffffd50 - AT91_BASE_SYS) + +#define AT91_USART0 AT91SAM9261_BASE_US0 +#define AT91_USART1 AT91SAM9261_BASE_US1 +#define AT91_USART2 AT91SAM9261_BASE_US2 + + +/* + * Internal Memory. + */ +#define AT91SAM9261_SRAM_BASE 0x00300000 /* Internal SRAM base address */ +#define AT91SAM9261_SRAM_SIZE 0x00028000 /* Internal SRAM size (160Kb) */ + +#define AT91SAM9261_ROM_BASE 0x00400000 /* Internal ROM base address */ +#define AT91SAM9261_ROM_SIZE SZ_32K /* Internal ROM size (32Kb) */ + +#define AT91SAM9261_UHP_BASE 0x00500000 /* USB Host controller */ +#define AT91SAM9261_LCDC_BASE 0x00600000 /* LDC controller */ + + +#endif diff --git a/include/asm-arm/arch-at91sam9/at91sam9261_matrix.h b/include/asm-arm/arch-at91sam9/at91sam9261_matrix.h new file mode 100644 index 0000000..6f07242 --- /dev/null +++ b/include/asm-arm/arch-at91sam9/at91sam9261_matrix.h @@ -0,0 +1,62 @@ +/* + * include/asm-arm/arch-at91/at91sam9261_matrix.h + * + * Memory Controllers (MATRIX, EBI) - System peripherals registers. + * Based on AT91SAM9261 datasheet revision D. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef AT91SAM9261_MATRIX_H +#define AT91SAM9261_MATRIX_H + +#define AT91_MATRIX_MCFG (AT91_MATRIX + 0x00) /* Master Configuration Register */ +#define AT91_MATRIX_RCB0 (1 << 0) /* Remap Command for AHB Master 0 (ARM926EJ-S Instruction Master) */ +#define AT91_MATRIX_RCB1 (1 << 1) /* Remap Command for AHB Master 1 (ARM926EJ-S Data Master) */ + +#define AT91_MATRIX_SCFG0 (AT91_MATRIX + 0x04) /* Slave Configuration Register 0 */ +#define AT91_MATRIX_SCFG1 (AT91_MATRIX + 0x08) /* Slave Configuration Register 1 */ +#define AT91_MATRIX_SCFG2 (AT91_MATRIX + 0x0C) /* Slave Configuration Register 2 */ +#define AT91_MATRIX_SCFG3 (AT91_MATRIX + 0x10) /* Slave Configuration Register 3 */ +#define AT91_MATRIX_SCFG4 (AT91_MATRIX + 0x14) /* Slave Configuration Register 4 */ +#define AT91_MATRIX_SLOT_CYCLE (0xff << 0) /* Maximum Number of Allowed Cycles for a Burst */ +#define AT91_MATRIX_DEFMSTR_TYPE (3 << 16) /* Default Master Type */ +#define AT91_MATRIX_DEFMSTR_TYPE_NONE (0 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_LAST (1 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_FIXED (2 << 16) +#define AT91_MATRIX_FIXED_DEFMSTR (7 << 18) /* Fixed Index of Default Master */ + +#define AT91_MATRIX_TCR (AT91_MATRIX + 0x24) /* TCM Configuration Register */ +#define AT91_MATRIX_ITCM_SIZE (0xf << 0) /* Size of ITCM enabled memory block */ +#define AT91_MATRIX_ITCM_0 (0 << 0) +#define AT91_MATRIX_ITCM_16 (5 << 0) +#define AT91_MATRIX_ITCM_32 (6 << 0) +#define AT91_MATRIX_ITCM_64 (7 << 0) +#define AT91_MATRIX_DTCM_SIZE (0xf << 4) /* Size of DTCM enabled memory block */ +#define AT91_MATRIX_DTCM_0 (0 << 4) +#define AT91_MATRIX_DTCM_16 (5 << 4) +#define AT91_MATRIX_DTCM_32 (6 << 4) +#define AT91_MATRIX_DTCM_64 (7 << 4) + +#define AT91_MATRIX_EBICSA (AT91_MATRIX + 0x30) /* EBI Chip Select Assignment Register */ +#define AT91_MATRIX_CS1A (1 << 1) /* Chip Select 1 Assignment */ +#define AT91_MATRIX_CS1A_SMC (0 << 1) +#define AT91_MATRIX_CS1A_SDRAMC (1 << 1) +#define AT91_MATRIX_CS3A (1 << 3) /* Chip Select 3 Assignment */ +#define AT91_MATRIX_CS3A_SMC (0 << 3) +#define AT91_MATRIX_CS3A_SMC_SMARTMEDIA (1 << 3) +#define AT91_MATRIX_CS4A (1 << 4) /* Chip Select 4 Assignment */ +#define AT91_MATRIX_CS4A_SMC (0 << 4) +#define AT91_MATRIX_CS4A_SMC_CF1 (1 << 4) +#define AT91_MATRIX_CS5A (1 << 5) /* Chip Select 5 Assignment */ +#define AT91_MATRIX_CS5A_SMC (0 << 5) +#define AT91_MATRIX_CS5A_SMC_CF2 (1 << 5) +#define AT91_MATRIX_DBPUC (1 << 8) /* Data Bus Pull-up Configuration */ + +#define AT91_MATRIX_USBPUCR (AT91_MATRIX + 0x34) /* USB Pad Pull-Up Control Register */ +#define AT91_MATRIX_USBPUCR_PUON (1 << 30) /* USB Device PAD Pull-up Enable */ + +#endif diff --git a/include/asm-arm/arch-at91sam9/hardware.h b/include/asm-arm/arch-at91sam9/hardware.h index 80b334f..d56f72d 100644 --- a/include/asm-arm/arch-at91sam9/hardware.h +++ b/include/asm-arm/arch-at91sam9/hardware.h @@ -26,6 +26,9 @@ #define AT91_PMC_UHP AT91SAM926x_PMC_UHP #elif defined(CONFIG_AT91SAM9261) #include <asm/arch/at91sam9261.h> +#define AT91_BASE_SPI AT91SAM9261_BASE_SPI0 +#define AT91_ID_UHP AT91SAM9261_ID_UHP +#define AT91_PMC_UHP AT91SAM926x_PMC_UHP #elif defined(CONFIG_AT91SAM9263) #include <asm/arch/at91sam9263.h> #elif defined(CONFIG_AT91SAM9RL) diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h new file mode 100644 index 0000000..cdafed3 --- /dev/null +++ b/include/configs/at91sam9261ek.h @@ -0,0 +1,189 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * Configuation settings for the AT91SAM9261EK board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* ARM asynchronous clock */ +#define AT91_MAIN_CLOCK 198656000 /* from 18.432 MHz crystal */ +#define AT91_MASTER_CLOCK 99328000 /* peripheral = main / 2 */ +#define CFG_HZ 1000000 /* 1us resolution */ + +#define AT91_SLOW_CLOCK 32768 /* slow clock */ + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#define CONFIG_AT91SAM9261 1 /* It's an Atmel AT91SAM9261 SoC*/ +#define CONFIG_AT91SAM9261EK 1 /* on an AT91SAM9261EK Board */ +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +#define CONFIG_BOOTDELAY 3 + +/* #define CONFIG_ENV_OVERWRITE 1 */ + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMLS + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x04000000 /* 64 megs */ + +/* DataFlash */ +#define CONFIG_HAS_DATAFLASH 1 +#define CFG_SPI_WRITE_TOUT (5*CFG_HZ) +#define CFG_MAX_DATAFLASH_BANKS 2 +#define CFG_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ +#define CFG_DATAFLASH_LOGIC_ADDR_CS3 0xD0000000 /* CS3 */ +#define AT91_SPI_CLK 15000000 +#define DATAFLASH_TCSS (0x1a << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +/* NAND flash */ +#define NAND_MAX_CHIPS 1 +#define CFG_MAX_NAND_DEVICE 1 +#define CFG_NAND_BASE 0x40000000 +#define CFG_NAND_DBW_8 1 + +/* NOR flash - no real flash on this board */ +#define CFG_NO_FLASH 1 + +/* Ethernet */ +#define CONFIG_DRIVER_DM9000 1 +#define CONFIG_DM9000_BASE 0x30000000 +#define DM9000_IO CONFIG_DM9000_BASE +#define DM9000_DATA (CONFIG_DM9000_BASE + 4) +#define CONFIG_DM9000_USE_16BIT 1 +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_RESET_PHY_R 1 + +/* USB */ +#define CONFIG_USB_OHCI_NEW 1 +#define LITTLEENDIAN 1 +#define CONFIG_DOS_PARTITION 1 +#define CFG_USB_OHCI_CPU_INIT 1 +#define CFG_USB_OHCI_REGS_BASE 0x00500000 /* AT91SAM9261_UHP_BASE */ +#define CFG_USB_OHCI_SLOT_NAME "at91sam9261" +#define CFG_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 + +#define CFG_LOAD_ADDR 0x22000000 /* load address */ + +#define CFG_MEMTEST_START PHYS_SDRAM +#define CFG_MEMTEST_END 0x23e00000 + +#define CFG_USE_DATAFLASH_CS0 1 +#undef CFG_USE_NANDFLASH + +#ifdef CFG_USE_DATAFLASH_CS0 + +/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +#define CFG_ENV_IS_IN_DATAFLASH 1 +#define CFG_MONITOR_BASE (CFG_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) +#define CFG_ENV_OFFSET 0x4200 +#define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS0 + CFG_ENV_OFFSET) +#define CFG_ENV_SIZE 0x4200 +#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock0 " \ + "mtdparts=at91_nand:-(root) "\ + "rw rootfstype=jffs2" + +#else /* CFG_USE_NANDFLASH */ + +/* bootstrap + u-boot + env + linux in nandflash */ +#define CFG_ENV_IS_IN_NAND 1 +#define CFG_ENV_OFFSET 0x60000 +#define CFG_ENV_OFFSET_REDUND 0x80000 +#define CFG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xA0000 0x200000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock5 " \ + "mtdparts=at91_nand:128k(bootstrap)ro,256k(uboot)ro,128k(env1)ro,128k(env2)ro,2M(linux),-(root) " \ + "rw rootfstype=jffs2" + +#endif + +#define CONFIG_BAUDRATE 115200 +#define CFG_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CFG_PROMPT "U-Boot> " +#define CFG_CBSIZE 256 +#define CFG_MAXARGS 16 +#define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) +#define CFG_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 + +#define ROUND(A, B) (((A) + (B)) & ~((B) - 1)) +/* + * Size of malloc() pool + */ +#define CFG_MALLOC_LEN ROUND(3 * CFG_ENV_SIZE + 128*1024, 0x1000) +#define CFG_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
Your (C) missing, mine is mangled again. Please fix.
(C) missing.
- (C) Copyright 2002
- Gary Jennejohn, DENX Software Engineering, <gj <at> denx.de>
Please add your own (C), and don't meddle with Gary's.
- include/asm-arm/arch-at91/at91sam9261.h
- Copyright (C) SAN People
Who exactly is "SAN People" ?
- include/asm-arm/arch-at91/at91sam9261_matrix.h
- Memory Controllers (MATRIX, EBI) - System peripherals registers.
- Based on AT91SAM9261 datasheet revision D.
(C) missing.
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
Line length!!!
Line length!!!
I did not modify this file, merely copied it verbatim from board/atmel/at91cap9adk, which in turn was copied from board/atmel/at91rm9200dk. So I see no reason to add my own copyright.
As for the mangle, see my other mail on the subject.
The at91sam9261.h and at91sam9261_matrix.h are verbatim copies of the header files of the Linux kernel.
For example: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=blob;f=in...
(C) missing.
ditto.
Line length!!!
No, I won't change this one. For maintenance reasons it is better to keep it identical to the kernel file.
Stelian.
If it's just copuied without changes, it's time to factor it out.
Understood, but needs to be fixed.
This explains where the file is coming from, but does not answer my question.
(C) missing.
ditto.
Maybe. It's still missing.
Isn't every board supposed to have a u-boot.lds file ? How could I factor these out ?
I'll submit a patch for this.
I think SAN is the former employer of Andrew Victor, the AT91 kernel maintainer.
(C) missing.
ditto.
And what am I supposed to do ?
Hello Stelian,
To be able to compile for at91sam9261-ek we need a logo called atmel.bmp. This bitmap is not available in the tree, so build fails. (There is, however, a denx.bmp)
The bitmap is also a binary file, so difficult to handle with patches. Have you any idea how to solve this?
Kind Regards,
Remy
2008/5/6 Stelian Pop stelian@popies.net:
(C) missing.
ditto.
-- Stelian Pop stelian@popies.net
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Don't miss this year's exciting event. There's still time to save $100. Use priority code J8TL2D2. http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javao... _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Le mercredi 07 mai 2008 à 10:25 +0200, Remy Bohmer a écrit :
Hello Stelian,
The patch "[PATCH 19/21] Use custom logo for Atmel boards" is a git patch containing the binary bitmap. If you use git-am to apply the patch it should handle this fine.
Otherwise, if you use plain 'patch' it will ignore the binary file.
For the time being, either use git to apply the patch or revert the whole patch 19/21 (so the standard u-boot bmp will be used).
Hello Stelian,
Kind Regards, Remy
==> Is this not for the custodians to sort out as a special case? Can't you just send a binary as an attachement and have this included in the mainstream?
An alternative would be to convert the bitmap to a non-binary file which can be used as data to a utility generating the binary during the build
Best Regards Ulf Samuelsson
Use git. Git handles binary blobs just fine.
It is not a special case. A binary image is just another file type which can be processed using git tools.
None of this is necessary.
Signed-off-by: Stelian Pop stelian@popies.net --- MAINTAINERS | 1 + MAKEALL | 1 + Makefile | 3 + board/atmel/at91sam9263ek/Makefile | 53 +++++ board/atmel/at91sam9263ek/at91sam9263ek.c | 240 ++++++++++++++++++++ board/atmel/at91sam9263ek/config.mk | 1 + board/atmel/at91sam9263ek/led.c | 78 +++++++ board/atmel/at91sam9263ek/nand.c | 79 +++++++ board/atmel/at91sam9263ek/partition.c | 37 +++ board/atmel/at91sam9263ek/u-boot.lds | 57 +++++ drivers/net/macb.c | 6 +- include/asm-arm/arch-at91sam9/at91sam9263.h | 127 +++++++++++ include/asm-arm/arch-at91sam9/at91sam9263_matrix.h | 129 +++++++++++ include/asm-arm/arch-at91sam9/hardware.h | 4 + include/configs/at91sam9263ek.h | 195 ++++++++++++++++ net/eth.c | 3 +- 16 files changed, 1011 insertions(+), 3 deletions(-) create mode 100644 board/atmel/at91sam9263ek/Makefile create mode 100644 board/atmel/at91sam9263ek/at91sam9263ek.c create mode 100644 board/atmel/at91sam9263ek/config.mk create mode 100644 board/atmel/at91sam9263ek/led.c create mode 100644 board/atmel/at91sam9263ek/nand.c create mode 100644 board/atmel/at91sam9263ek/partition.c create mode 100644 board/atmel/at91sam9263ek/u-boot.lds create mode 100644 include/asm-arm/arch-at91sam9/at91sam9263.h create mode 100644 include/asm-arm/arch-at91sam9/at91sam9263_matrix.h create mode 100644 include/configs/at91sam9263ek.h
diff --git a/MAINTAINERS b/MAINTAINERS index 26f31fd..84bf19f 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -539,6 +539,7 @@ Stelian Pop stelian.pop@leadtechdesign.com at91cap9adk ARM926EJS (AT91CAP9 SoC) at91sam9260ek ARM926EJS (AT91SAM9260 SoC) at91sam9261ek ARM926EJS (AT91SAM9261 SoC) + at91sam9263ek ARM926EJS (AT91SAM9263 SoC)
diff --git a/MAKEALL b/MAKEALL index 251da90..29aa7fc 100755 --- a/MAKEALL +++ b/MAKEALL @@ -459,6 +459,7 @@ LIST_ARM9=" \ at91rm9200dk \ at91sam9260ek \ at91sam9261ek \ + at91sam9263ek \ cmc_pu2 \ ap920t \ ap922_XA10 \ diff --git a/Makefile b/Makefile index 5e06ff5..65ef6c2 100644 --- a/Makefile +++ b/Makefile @@ -2329,6 +2329,9 @@ at91rm9200dk_config : unconfig at91sam9261ek_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs at91sam9261ek atmel at91sam9
+at91sam9263ek_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm926ejs at91sam9263ek atmel at91sam9 + cmc_pu2_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm920t cmc_pu2 NULL at91rm9200
diff --git a/board/atmel/at91sam9263ek/Makefile b/board/atmel/at91sam9263ek/Makefile new file mode 100644 index 0000000..3ded315 --- /dev/null +++ b/board/atmel/at91sam9263ek/Makefile @@ -0,0 +1,53 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd <at> denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += at91sam9263ek.o +COBJS-y += led.o +COBJS-y += partition.o +COBJS-$(CONFIG_CMD_NAND) += nand.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c new file mode 100644 index 0000000..ee6b69f --- /dev/null +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -0,0 +1,240 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91sam9263_matrix.h> +#include <asm/arch/at91sam926x_mc.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +static void at91sam9263ek_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PA26, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PA27, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_US0); +#endif + +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_US1); +#endif + +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_US2); +#endif + +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PC30, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PC31, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} + +#ifdef CONFIG_CMD_NAND +static void at91sam9263ek_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBI0CSA); + at91_sys_write(AT91_MATRIX_EBI0CSA, + csa | AT91_MATRIX_EBI0_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | +#ifdef CFG_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CFG_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(2)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOA | + 1 << AT91SAM9263_ID_PIOCDE); + + /* Configure RDY/BSY */ + at91_set_gpio_input(AT91_PIN_PA22, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(AT91_PIN_PD15, 1); +} +#endif + +#ifdef CONFIG_HAS_DATAFLASH +static void at91sam9263ek_spi_hw_init(void) +{ + at91_set_B_periph(AT91_PIN_PA5, 0); /* SPI0_NPCS0 */ + + at91_set_B_periph(AT91_PIN_PA0, 0); /* SPI0_MISO */ + at91_set_B_periph(AT91_PIN_PA1, 0); /* SPI0_MOSI */ + at91_set_B_periph(AT91_PIN_PA2, 0); /* SPI0_SPCK */ + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_SPI0); +} +#endif + +#ifdef CONFIG_MACB +static void at91sam9263ek_macb_hw_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_EMAC); + + /* + * Disable pull-up on: + * RXDV (PC25) => PHY normal mode (not Test mode) + * ERX0 (PE25) => PHY ADDR0 + * ERX1 (PE26) => PHY ADDR1 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PC25), + pin_to_controller(AT91_PIN_PC0) + PIO_PUDR); + writel(pin_to_mask(AT91_PIN_PE25) | + pin_to_mask(AT91_PIN_PE26), + pin_to_controller(AT91_PIN_PE0) + PIO_PUDR); + + /* Need to reset PHY -> 500ms reset */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + AT91_RSTC_ERSTL | (0x0D << 8) | + AT91_RSTC_URSTEN); + + at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + + /* Wait for end hardware reset */ + while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PC25), + pin_to_controller(AT91_PIN_PC0) + PIO_PUER); + writel(pin_to_mask(AT91_PIN_PE25) | + pin_to_mask(AT91_PIN_PE26), + pin_to_controller(AT91_PIN_PE0) + PIO_PUER); + + at91_set_A_periph(AT91_PIN_PE21, 0); /* ETXCK_EREFCK */ + at91_set_B_periph(AT91_PIN_PC25, 0); /* ERXDV */ + at91_set_A_periph(AT91_PIN_PE25, 0); /* ERX0 */ + at91_set_A_periph(AT91_PIN_PE26, 0); /* ERX1 */ + at91_set_A_periph(AT91_PIN_PE27, 0); /* ERXER */ + at91_set_A_periph(AT91_PIN_PE28, 0); /* ETXEN */ + at91_set_A_periph(AT91_PIN_PE23, 0); /* ETX0 */ + at91_set_A_periph(AT91_PIN_PE24, 0); /* ETX1 */ + at91_set_A_periph(AT91_PIN_PE30, 0); /* EMDIO */ + at91_set_A_periph(AT91_PIN_PE29, 0); /* EMDC */ + +#ifndef CONFIG_RMII + at91_set_A_periph(AT91_PIN_PE22, 0); /* ECRS */ + at91_set_B_periph(AT91_PIN_PC26, 0); /* ECOL */ + at91_set_B_periph(AT91_PIN_PC22, 0); /* ERX2 */ + at91_set_B_periph(AT91_PIN_PC23, 0); /* ERX3 */ + at91_set_B_periph(AT91_PIN_PC27, 0); /* ERXCK */ + at91_set_B_periph(AT91_PIN_PC20, 0); /* ETX2 */ + at91_set_B_periph(AT91_PIN_PC21, 0); /* ETX3 */ + at91_set_B_periph(AT91_PIN_PC24, 0); /* ETXER */ +#endif + +} +#endif + +#ifdef CONFIG_USB_OHCI_NEW +static void at91sam9263ek_uhp_hw_init(void) +{ + /* Enable VBus on UHP ports */ + at91_set_gpio_output(AT91_PIN_PA21, 0); + at91_set_gpio_output(AT91_PIN_PA24, 0); +} +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of AT91SAM9263EK-Board */ + gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9263EK; + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91sam9263ek_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + at91sam9263ek_nand_hw_init(); +#endif +#ifdef CONFIG_HAS_DATAFLASH + at91sam9263ek_spi_hw_init(); +#endif +#ifdef CONFIG_MACB + at91sam9263ek_macb_hw_init(); +#endif +#ifdef CONFIG_USB_OHCI_NEW + at91sam9263ek_uhp_hw_init(); +#endif + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_MACB + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif diff --git a/board/atmel/at91sam9263ek/config.mk b/board/atmel/at91sam9263ek/config.mk new file mode 100644 index 0000000..ff2cfd1 --- /dev/null +++ b/board/atmel/at91sam9263ek/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x23f00000 diff --git a/board/atmel/at91sam9263ek/led.c b/board/atmel/at91sam9263ek/led.c new file mode 100644 index 0000000..401311f --- /dev/null +++ b/board/atmel/at91sam9263ek/led.c @@ -0,0 +1,78 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +#define RED_LED AT91_PIN_PB7 /* this is the power led */ +#define GREEN_LED AT91_PIN_PB8 /* this is the user1 led */ +#define YELLOW_LED AT91_PIN_PC29 /* this is the user2 led */ + +void red_LED_on(void) +{ + at91_set_gpio_value(RED_LED, 1); +} + +void red_LED_off(void) +{ + at91_set_gpio_value(RED_LED, 0); +} + +void green_LED_on(void) +{ + at91_set_gpio_value(GREEN_LED, 0); +} + +void green_LED_off(void) +{ + at91_set_gpio_value(GREEN_LED, 1); +} + +void yellow_LED_on(void) +{ + at91_set_gpio_value(YELLOW_LED, 0); +} + +void yellow_LED_off(void) +{ + at91_set_gpio_value(YELLOW_LED, 1); +} + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOB | + 1 << AT91SAM9263_ID_PIOCDE); + + at91_set_gpio_output(RED_LED, 1); + at91_set_gpio_output(GREEN_LED, 1); + at91_set_gpio_output(YELLOW_LED, 1); + + at91_set_gpio_value(RED_LED, 0); + at91_set_gpio_value(GREEN_LED, 1); + at91_set_gpio_value(YELLOW_LED, 1); +} diff --git a/board/atmel/at91sam9263ek/nand.c b/board/atmel/at91sam9263ek/nand.c new file mode 100644 index 0000000..87d08a8 --- /dev/null +++ b/board/atmel/at91sam9263ek/nand.c @@ -0,0 +1,79 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * (C) Copyright 2006 ATMEL Rousset, Lacressonniere Nicolas + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/gpio.h> +#include <asm/arch/at91_pio.h> + +#include <nand.h> + +/* + * hardware specific access to control-lines + */ +#define MASK_ALE (1 << 21) /* our ALE is AD21 */ +#define MASK_CLE (1 << 22) /* our CLE is AD22 */ + +static void at91sam9263ek_nand_hwcontrol(struct mtd_info *mtd, int cmd) +{ + struct nand_chip *this = mtd->priv; + ulong IO_ADDR_W = (ulong) this->IO_ADDR_W; + + IO_ADDR_W &= ~(MASK_ALE|MASK_CLE); + switch (cmd) { + case NAND_CTL_SETCLE: + IO_ADDR_W |= MASK_CLE; + break; + case NAND_CTL_SETALE: + IO_ADDR_W |= MASK_ALE; + break; + case NAND_CTL_CLRNCE: + at91_set_gpio_value(AT91_PIN_PD15, 1); + break; + case NAND_CTL_SETNCE: + at91_set_gpio_value(AT91_PIN_PD15, 0); + break; + } + this->IO_ADDR_W = (void *) IO_ADDR_W; +} + +static int at91sam9263ek_nand_ready(struct mtd_info *mtd) +{ + return at91_get_gpio_value(AT91_PIN_PA22); +} + +int board_nand_init(struct nand_chip *nand) +{ + nand->eccmode = NAND_ECC_SOFT; +#ifdef CFG_NAND_DBW_16 + nand->options = NAND_BUSWIDTH_16; +#endif + nand->hwcontrol = at91sam9263ek_nand_hwcontrol; + nand->dev_ready = at91sam9263ek_nand_ready; + nand->chip_delay = 20; + + return 0; +} diff --git a/board/atmel/at91sam9263ek/partition.c b/board/atmel/at91sam9263ek/partition.c new file mode 100644 index 0000000..3bffd71 --- /dev/null +++ b/board/atmel/at91sam9263ek/partition.c @@ -0,0 +1,37 @@ +/* + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <config.h> +#include <asm/hardware.h> +#include <dataflash.h> + +AT91S_DATAFLASH_INFO dataflash_info[CFG_MAX_DATAFLASH_BANKS]; + +struct dataflash_addr cs[CFG_MAX_DATAFLASH_BANKS] = { + {CFG_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ +}; + +/*define the area offsets*/ +dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { + {0x00000000, 0x000041FF, FLAG_PROTECT_SET, 0, "Bootstrap"}, + {0x00004200, 0x000083FF, FLAG_PROTECT_CLEAR, 0, "Environment"}, + {0x00008400, 0x00041FFF, FLAG_PROTECT_SET, 0, "U-Boot"}, + {0x00042000, 0x00251FFF, FLAG_PROTECT_CLEAR, 0, "Kernel"}, + {0x00252000, 0xFFFFFFFF, FLAG_PROTECT_CLEAR, 0, "FS"}, +}; diff --git a/board/atmel/at91sam9263ek/u-boot.lds b/board/atmel/at91sam9263ek/u-boot.lds new file mode 100644 index 0000000..05a6d83 --- /dev/null +++ b/board/atmel/at91sam9263ek/u-boot.lds @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, <gj <at> denx.de> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +/*OUTPUT_FORMAT("elf32-arm", "elf32-arm", "elf32-arm")*/ +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm926ejs/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 703784e..e5733f6 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -417,13 +417,15 @@ static int macb_init(struct eth_device *netdev, bd_t *bd)
/* choose RMII or MII mode. This depends on the board */ #ifdef CONFIG_RMII -#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) +#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ + defined(CONFIG_AT91SAM9263) macb_writel(macb, USRIO, MACB_BIT(RMII) | MACB_BIT(CLKEN)); #else macb_writel(macb, USRIO, 0); #endif #else -#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) +#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ + defined(CONFIG_AT91SAM9263) macb_writel(macb, USRIO, MACB_BIT(CLKEN)); #else macb_writel(macb, USRIO, MACB_BIT(MII)); diff --git a/include/asm-arm/arch-at91sam9/at91sam9263.h b/include/asm-arm/arch-at91sam9/at91sam9263.h new file mode 100644 index 0000000..018a647 --- /dev/null +++ b/include/asm-arm/arch-at91sam9/at91sam9263.h @@ -0,0 +1,127 @@ +/* + * include/asm-arm/arch-at91/at91sam9263.h + * + * (C) 2007 Atmel Corporation. + * + * Common definitions. + * Based on AT91SAM9263 datasheet revision B (Preliminary). + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef AT91SAM9263_H +#define AT91SAM9263_H + +/* + * Peripheral identifiers/interrupts. + */ +#define AT91_ID_FIQ 0 /* Advanced Interrupt Controller (FIQ) */ +#define AT91_ID_SYS 1 /* System Peripherals */ +#define AT91SAM9263_ID_PIOA 2 /* Parallel IO Controller A */ +#define AT91SAM9263_ID_PIOB 3 /* Parallel IO Controller B */ +#define AT91SAM9263_ID_PIOCDE 4 /* Parallel IO Controller C, D and E */ +#define AT91SAM9263_ID_US0 7 /* USART 0 */ +#define AT91SAM9263_ID_US1 8 /* USART 1 */ +#define AT91SAM9263_ID_US2 9 /* USART 2 */ +#define AT91SAM9263_ID_MCI0 10 /* Multimedia Card Interface 0 */ +#define AT91SAM9263_ID_MCI1 11 /* Multimedia Card Interface 1 */ +#define AT91SAM9263_ID_CAN 12 /* CAN */ +#define AT91SAM9263_ID_TWI 13 /* Two-Wire Interface */ +#define AT91SAM9263_ID_SPI0 14 /* Serial Peripheral Interface 0 */ +#define AT91SAM9263_ID_SPI1 15 /* Serial Peripheral Interface 1 */ +#define AT91SAM9263_ID_SSC0 16 /* Serial Synchronous Controller 0 */ +#define AT91SAM9263_ID_SSC1 17 /* Serial Synchronous Controller 1 */ +#define AT91SAM9263_ID_AC97C 18 /* AC97 Controller */ +#define AT91SAM9263_ID_TCB 19 /* Timer Counter 0, 1 and 2 */ +#define AT91SAM9263_ID_PWMC 20 /* Pulse Width Modulation Controller */ +#define AT91SAM9263_ID_EMAC 21 /* Ethernet */ +#define AT91SAM9263_ID_2DGE 23 /* 2D Graphic Engine */ +#define AT91SAM9263_ID_UDP 24 /* USB Device Port */ +#define AT91SAM9263_ID_ISI 25 /* Image Sensor Interface */ +#define AT91SAM9263_ID_LCDC 26 /* LCD Controller */ +#define AT91SAM9263_ID_DMA 27 /* DMA Controller */ +#define AT91SAM9263_ID_UHP 29 /* USB Host port */ +#define AT91SAM9263_ID_IRQ0 30 /* Advanced Interrupt Controller (IRQ0) */ +#define AT91SAM9263_ID_IRQ1 31 /* Advanced Interrupt Controller (IRQ1) */ + + +/* + * User Peripheral physical base addresses. + */ +#define AT91SAM9263_BASE_UDP 0xfff78000 +#define AT91SAM9263_BASE_TCB0 0xfff7c000 +#define AT91SAM9263_BASE_TC0 0xfff7c000 +#define AT91SAM9263_BASE_TC1 0xfff7c040 +#define AT91SAM9263_BASE_TC2 0xfff7c080 +#define AT91SAM9263_BASE_MCI0 0xfff80000 +#define AT91SAM9263_BASE_MCI1 0xfff84000 +#define AT91SAM9263_BASE_TWI 0xfff88000 +#define AT91SAM9263_BASE_US0 0xfff8c000 +#define AT91SAM9263_BASE_US1 0xfff90000 +#define AT91SAM9263_BASE_US2 0xfff94000 +#define AT91SAM9263_BASE_SSC0 0xfff98000 +#define AT91SAM9263_BASE_SSC1 0xfff9c000 +#define AT91SAM9263_BASE_AC97C 0xfffa0000 +#define AT91SAM9263_BASE_SPI0 0xfffa4000 +#define AT91SAM9263_BASE_SPI1 0xfffa8000 +#define AT91SAM9263_BASE_CAN 0xfffac000 +#define AT91SAM9263_BASE_PWMC 0xfffb8000 +#define AT91SAM9263_BASE_EMAC 0xfffbc000 +#define AT91SAM9263_BASE_ISI 0xfffc4000 +#define AT91SAM9263_BASE_2DGE 0xfffc8000 +#define AT91_BASE_SYS 0xffffe000 + +/* + * System Peripherals (offset from AT91_BASE_SYS) + */ +#define AT91_ECC0 (0xffffe000 - AT91_BASE_SYS) +#define AT91_SDRAMC0 (0xffffe200 - AT91_BASE_SYS) +#define AT91_SMC0 (0xffffe400 - AT91_BASE_SYS) +#define AT91_ECC1 (0xffffe600 - AT91_BASE_SYS) +#define AT91_SDRAMC1 (0xffffe800 - AT91_BASE_SYS) +#define AT91_SMC1 (0xffffea00 - AT91_BASE_SYS) +#define AT91_MATRIX (0xffffec00 - AT91_BASE_SYS) +#define AT91_CCFG (0xffffed10 - AT91_BASE_SYS) +#define AT91_DBGU (0xffffee00 - AT91_BASE_SYS) +#define AT91_AIC (0xfffff000 - AT91_BASE_SYS) +#define AT91_PIOA (0xfffff200 - AT91_BASE_SYS) +#define AT91_PIOB (0xfffff400 - AT91_BASE_SYS) +#define AT91_PIOC (0xfffff600 - AT91_BASE_SYS) +#define AT91_PIOD (0xfffff800 - AT91_BASE_SYS) +#define AT91_PIOE (0xfffffa00 - AT91_BASE_SYS) +#define AT91_PMC (0xfffffc00 - AT91_BASE_SYS) +#define AT91_RSTC (0xfffffd00 - AT91_BASE_SYS) +#define AT91_SHDWC (0xfffffd10 - AT91_BASE_SYS) +#define AT91_RTT0 (0xfffffd20 - AT91_BASE_SYS) +#define AT91_PIT (0xfffffd30 - AT91_BASE_SYS) +#define AT91_WDT (0xfffffd40 - AT91_BASE_SYS) +#define AT91_RTT1 (0xfffffd50 - AT91_BASE_SYS) +#define AT91_GPBR (0xfffffd60 - AT91_BASE_SYS) + +#define AT91_USART0 AT91SAM9263_BASE_US0 +#define AT91_USART1 AT91SAM9263_BASE_US1 +#define AT91_USART2 AT91SAM9263_BASE_US2 + +#define AT91_SMC AT91_SMC0 + +/* + * Internal Memory. + */ +#define AT91SAM9263_SRAM0_BASE 0x00300000 /* Internal SRAM 0 base address */ +#define AT91SAM9263_SRAM0_SIZE (80 * SZ_1K) /* Internal SRAM 0 size (80Kb) */ + +#define AT91SAM9263_ROM_BASE 0x00400000 /* Internal ROM base address */ +#define AT91SAM9263_ROM_SIZE SZ_128K /* Internal ROM size (128Kb) */ + +#define AT91SAM9263_SRAM1_BASE 0x00500000 /* Internal SRAM 1 base address */ +#define AT91SAM9263_SRAM1_SIZE SZ_16K /* Internal SRAM 1 size (16Kb) */ + +#define AT91SAM9263_LCDC_BASE 0x00700000 /* LCD Controller */ +#define AT91SAM9263_DMAC_BASE 0x00800000 /* DMA Controller */ +#define AT91SAM9263_UHP_BASE 0x00a00000 /* USB Host controller */ + + +#endif diff --git a/include/asm-arm/arch-at91sam9/at91sam9263_matrix.h b/include/asm-arm/arch-at91sam9/at91sam9263_matrix.h new file mode 100644 index 0000000..72f6e66 --- /dev/null +++ b/include/asm-arm/arch-at91sam9/at91sam9263_matrix.h @@ -0,0 +1,129 @@ +/* + * include/asm-arm/arch-at91/at91sam9263_matrix.h + * + * Copyright (C) 2006 Atmel Corporation. + * + * Memory Controllers (MATRIX, EBI) - System peripherals registers. + * Based on AT91SAM9263 datasheet revision B (Preliminary). + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef AT91SAM9263_MATRIX_H +#define AT91SAM9263_MATRIX_H + +#define AT91_MATRIX_MCFG0 (AT91_MATRIX + 0x00) /* Master Configuration Register 0 */ +#define AT91_MATRIX_MCFG1 (AT91_MATRIX + 0x04) /* Master Configuration Register 1 */ +#define AT91_MATRIX_MCFG2 (AT91_MATRIX + 0x08) /* Master Configuration Register 2 */ +#define AT91_MATRIX_MCFG3 (AT91_MATRIX + 0x0C) /* Master Configuration Register 3 */ +#define AT91_MATRIX_MCFG4 (AT91_MATRIX + 0x10) /* Master Configuration Register 4 */ +#define AT91_MATRIX_MCFG5 (AT91_MATRIX + 0x14) /* Master Configuration Register 5 */ +#define AT91_MATRIX_MCFG6 (AT91_MATRIX + 0x18) /* Master Configuration Register 6 */ +#define AT91_MATRIX_MCFG7 (AT91_MATRIX + 0x1C) /* Master Configuration Register 7 */ +#define AT91_MATRIX_MCFG8 (AT91_MATRIX + 0x20) /* Master Configuration Register 8 */ +#define AT91_MATRIX_ULBT (7 << 0) /* Undefined Length Burst Type */ +#define AT91_MATRIX_ULBT_INFINITE (0 << 0) +#define AT91_MATRIX_ULBT_SINGLE (1 << 0) +#define AT91_MATRIX_ULBT_FOUR (2 << 0) +#define AT91_MATRIX_ULBT_EIGHT (3 << 0) +#define AT91_MATRIX_ULBT_SIXTEEN (4 << 0) + +#define AT91_MATRIX_SCFG0 (AT91_MATRIX + 0x40) /* Slave Configuration Register 0 */ +#define AT91_MATRIX_SCFG1 (AT91_MATRIX + 0x44) /* Slave Configuration Register 1 */ +#define AT91_MATRIX_SCFG2 (AT91_MATRIX + 0x48) /* Slave Configuration Register 2 */ +#define AT91_MATRIX_SCFG3 (AT91_MATRIX + 0x4C) /* Slave Configuration Register 3 */ +#define AT91_MATRIX_SCFG4 (AT91_MATRIX + 0x50) /* Slave Configuration Register 4 */ +#define AT91_MATRIX_SCFG5 (AT91_MATRIX + 0x54) /* Slave Configuration Register 5 */ +#define AT91_MATRIX_SCFG6 (AT91_MATRIX + 0x58) /* Slave Configuration Register 6 */ +#define AT91_MATRIX_SCFG7 (AT91_MATRIX + 0x5C) /* Slave Configuration Register 7 */ +#define AT91_MATRIX_SLOT_CYCLE (0xff << 0) /* Maximum Number of Allowed Cycles for a Burst */ +#define AT91_MATRIX_DEFMSTR_TYPE (3 << 16) /* Default Master Type */ +#define AT91_MATRIX_DEFMSTR_TYPE_NONE (0 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_LAST (1 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_FIXED (2 << 16) +#define AT91_MATRIX_FIXED_DEFMSTR (0xf << 18) /* Fixed Index of Default Master */ +#define AT91_MATRIX_ARBT (3 << 24) /* Arbitration Type */ +#define AT91_MATRIX_ARBT_ROUND_ROBIN (0 << 24) +#define AT91_MATRIX_ARBT_FIXED_PRIORITY (1 << 24) + +#define AT91_MATRIX_PRAS0 (AT91_MATRIX + 0x80) /* Priority Register A for Slave 0 */ +#define AT91_MATRIX_PRBS0 (AT91_MATRIX + 0x84) /* Priority Register B for Slave 0 */ +#define AT91_MATRIX_PRAS1 (AT91_MATRIX + 0x88) /* Priority Register A for Slave 1 */ +#define AT91_MATRIX_PRBS1 (AT91_MATRIX + 0x8C) /* Priority Register B for Slave 1 */ +#define AT91_MATRIX_PRAS2 (AT91_MATRIX + 0x90) /* Priority Register A for Slave 2 */ +#define AT91_MATRIX_PRBS2 (AT91_MATRIX + 0x94) /* Priority Register B for Slave 2 */ +#define AT91_MATRIX_PRAS3 (AT91_MATRIX + 0x98) /* Priority Register A for Slave 3 */ +#define AT91_MATRIX_PRBS3 (AT91_MATRIX + 0x9C) /* Priority Register B for Slave 3 */ +#define AT91_MATRIX_PRAS4 (AT91_MATRIX + 0xA0) /* Priority Register A for Slave 4 */ +#define AT91_MATRIX_PRBS4 (AT91_MATRIX + 0xA4) /* Priority Register B for Slave 4 */ +#define AT91_MATRIX_PRAS5 (AT91_MATRIX + 0xA8) /* Priority Register A for Slave 5 */ +#define AT91_MATRIX_PRBS5 (AT91_MATRIX + 0xAC) /* Priority Register B for Slave 5 */ +#define AT91_MATRIX_PRAS6 (AT91_MATRIX + 0xB0) /* Priority Register A for Slave 6 */ +#define AT91_MATRIX_PRBS6 (AT91_MATRIX + 0xB4) /* Priority Register B for Slave 6 */ +#define AT91_MATRIX_PRAS7 (AT91_MATRIX + 0xB8) /* Priority Register A for Slave 7 */ +#define AT91_MATRIX_PRBS7 (AT91_MATRIX + 0xBC) /* Priority Register B for Slave 7 */ +#define AT91_MATRIX_M0PR (3 << 0) /* Master 0 Priority */ +#define AT91_MATRIX_M1PR (3 << 4) /* Master 1 Priority */ +#define AT91_MATRIX_M2PR (3 << 8) /* Master 2 Priority */ +#define AT91_MATRIX_M3PR (3 << 12) /* Master 3 Priority */ +#define AT91_MATRIX_M4PR (3 << 16) /* Master 4 Priority */ +#define AT91_MATRIX_M5PR (3 << 20) /* Master 5 Priority */ +#define AT91_MATRIX_M6PR (3 << 24) /* Master 6 Priority */ +#define AT91_MATRIX_M7PR (3 << 28) /* Master 7 Priority */ +#define AT91_MATRIX_M8PR (3 << 0) /* Master 8 Priority (in Register B) */ + +#define AT91_MATRIX_MRCR (AT91_MATRIX + 0x100) /* Master Remap Control Register */ +#define AT91_MATRIX_RCB0 (1 << 0) /* Remap Command for AHB Master 0 (ARM926EJ-S Instruction Master) */ +#define AT91_MATRIX_RCB1 (1 << 1) /* Remap Command for AHB Master 1 (ARM926EJ-S Data Master) */ +#define AT91_MATRIX_RCB2 (1 << 2) +#define AT91_MATRIX_RCB3 (1 << 3) +#define AT91_MATRIX_RCB4 (1 << 4) +#define AT91_MATRIX_RCB5 (1 << 5) +#define AT91_MATRIX_RCB6 (1 << 6) +#define AT91_MATRIX_RCB7 (1 << 7) +#define AT91_MATRIX_RCB8 (1 << 8) + +#define AT91_MATRIX_TCMR (AT91_MATRIX + 0x114) /* TCM Configuration Register */ +#define AT91_MATRIX_ITCM_SIZE (0xf << 0) /* Size of ITCM enabled memory block */ +#define AT91_MATRIX_ITCM_0 (0 << 0) +#define AT91_MATRIX_ITCM_16 (5 << 0) +#define AT91_MATRIX_ITCM_32 (6 << 0) +#define AT91_MATRIX_DTCM_SIZE (0xf << 4) /* Size of DTCM enabled memory block */ +#define AT91_MATRIX_DTCM_0 (0 << 4) +#define AT91_MATRIX_DTCM_16 (5 << 4) +#define AT91_MATRIX_DTCM_32 (6 << 4) + +#define AT91_MATRIX_EBI0CSA (AT91_MATRIX + 0x120) /* EBI0 Chip Select Assignment Register */ +#define AT91_MATRIX_EBI0_CS1A (1 << 1) /* Chip Select 1 Assignment */ +#define AT91_MATRIX_EBI0_CS1A_SMC (0 << 1) +#define AT91_MATRIX_EBI0_CS1A_SDRAMC (1 << 1) +#define AT91_MATRIX_EBI0_CS3A (1 << 3) /* Chip Select 3 Assignment */ +#define AT91_MATRIX_EBI0_CS3A_SMC (0 << 3) +#define AT91_MATRIX_EBI0_CS3A_SMC_SMARTMEDIA (1 << 3) +#define AT91_MATRIX_EBI0_CS4A (1 << 4) /* Chip Select 4 Assignment */ +#define AT91_MATRIX_EBI0_CS4A_SMC (0 << 4) +#define AT91_MATRIX_EBI0_CS4A_SMC_CF1 (1 << 4) +#define AT91_MATRIX_EBI0_CS5A (1 << 5) /* Chip Select 5 Assignment */ +#define AT91_MATRIX_EBI0_CS5A_SMC (0 << 5) +#define AT91_MATRIX_EBI0_CS5A_SMC_CF2 (1 << 5) +#define AT91_MATRIX_EBI0_DBPUC (1 << 8) /* Data Bus Pull-up Configuration */ +#define AT91_MATRIX_EBI0_VDDIOMSEL (1 << 16) /* Memory voltage selection */ +#define AT91_MATRIX_EBI0_VDDIOMSEL_1_8V (0 << 16) +#define AT91_MATRIX_EBI0_VDDIOMSEL_3_3V (1 << 16) + +#define AT91_MATRIX_EBI1CSA (AT91_MATRIX + 0x124) /* EBI1 Chip Select Assignment Register */ +#define AT91_MATRIX_EBI1_CS1A (1 << 1) /* Chip Select 1 Assignment */ +#define AT91_MATRIX_EBI1_CS1A_SMC (0 << 1) +#define AT91_MATRIX_EBI1_CS1A_SDRAMC (1 << 1) +#define AT91_MATRIX_EBI1_CS2A (1 << 3) /* Chip Select 3 Assignment */ +#define AT91_MATRIX_EBI1_CS2A_SMC (0 << 3) +#define AT91_MATRIX_EBI1_CS2A_SMC_SMARTMEDIA (1 << 3) +#define AT91_MATRIX_EBI1_DBPUC (1 << 8) /* Data Bus Pull-up Configuration */ +#define AT91_MATRIX_EBI1_VDDIOMSEL (1 << 16) /* Memory voltage selection */ +#define AT91_MATRIX_EBI1_VDDIOMSEL_1_8V (0 << 16) +#define AT91_MATRIX_EBI1_VDDIOMSEL_3_3V (1 << 16) + +#endif diff --git a/include/asm-arm/arch-at91sam9/hardware.h b/include/asm-arm/arch-at91sam9/hardware.h index d56f72d..a5d8293 100644 --- a/include/asm-arm/arch-at91sam9/hardware.h +++ b/include/asm-arm/arch-at91sam9/hardware.h @@ -31,6 +31,10 @@ #define AT91_PMC_UHP AT91SAM926x_PMC_UHP #elif defined(CONFIG_AT91SAM9263) #include <asm/arch/at91sam9263.h> +#define AT91_BASE_EMAC AT91SAM9263_BASE_EMAC +#define AT91_BASE_SPI AT91SAM9263_BASE_SPI0 +#define AT91_ID_UHP AT91SAM9263_ID_UHP +#define AT91_PMC_UHP AT91SAM926x_PMC_UHP #elif defined(CONFIG_AT91SAM9RL) #include <asm/arch/at91sam9rl.h> #elif defined(CONFIG_AT91CAP9) diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h new file mode 100644 index 0000000..e2ffbbe --- /dev/null +++ b/include/configs/at91sam9263ek.h @@ -0,0 +1,195 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * Configuation settings for the AT91SAM9263EK board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* ARM asynchronous clock */ +#define AT91_MAIN_CLOCK 199919000 /* from 16.367 MHz crystal */ +#define AT91_MASTER_CLOCK 99959500 /* peripheral = main / 2 */ +#define CFG_HZ 1000000 /* 1us resolution */ + +#define AT91_SLOW_CLOCK 32768 /* slow clock */ + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#define CONFIG_AT91SAM9263 1 /* It's an Atmel AT91SAM9263 SoC*/ +#define CONFIG_AT91SAM9263EK 1 /* on an AT91SAM9263EK Board */ +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +#define CONFIG_BOOTDELAY 3 + +/* #define CONFIG_ENV_OVERWRITE 1 */ + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMLS + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x04000000 /* 64 megs */ + +/* DataFlash */ +#define CONFIG_HAS_DATAFLASH 1 +#define CFG_SPI_WRITE_TOUT (5*CFG_HZ) +#define CFG_MAX_DATAFLASH_BANKS 1 +#define CFG_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ +#define AT91_SPI_CLK 15000000 +#define DATAFLASH_TCSS (0x1a << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +/* NOR flash, if populated */ +#if 1 +#define CFG_NO_FLASH 1 +#else +#define CFG_FLASH_CFI 1 +#define CFG_FLASH_CFI_DRIVER 1 +#define PHYS_FLASH_1 0x10000000 +#define CFG_FLASH_BASE PHYS_FLASH_1 +#define CFG_MAX_FLASH_SECT 256 +#define CFG_MAX_FLASH_BANKS 1 +#endif + +/* NAND flash */ +#define NAND_MAX_CHIPS 1 +#define CFG_MAX_NAND_DEVICE 1 +#define CFG_NAND_BASE 0x40000000 +#define CFG_NAND_DBW_8 1 + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_RESET_PHY_R 1 + +/* USB */ +#define CONFIG_USB_OHCI_NEW 1 +#define LITTLEENDIAN 1 +#define CONFIG_DOS_PARTITION 1 +#define CFG_USB_OHCI_CPU_INIT 1 +#define CFG_USB_OHCI_REGS_BASE 0x00a00000 /* AT91SAM9263_UHP_BASE */ +#define CFG_USB_OHCI_SLOT_NAME "at91sam9263" +#define CFG_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 + +#define CFG_LOAD_ADDR 0x22000000 /* load address */ + +#define CFG_MEMTEST_START PHYS_SDRAM +#define CFG_MEMTEST_END 0x23e00000 + +#define CFG_USE_DATAFLASH 1 +#undef CFG_USE_NANDFLASH + +#ifdef CFG_USE_DATAFLASH + +/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +#define CFG_ENV_IS_IN_DATAFLASH 1 +#define CFG_MONITOR_BASE (CFG_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) +#define CFG_ENV_OFFSET 0x4200 +#define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS0 + CFG_ENV_OFFSET) +#define CFG_ENV_SIZE 0x4200 +#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock0 " \ + "mtdparts=at91_nand:-(root) "\ + "rw rootfstype=jffs2" + +#else /* CFG_USE_NANDFLASH */ + +/* bootstrap + u-boot + env + linux in nandflash */ +#define CFG_ENV_IS_IN_NAND 1 +#define CFG_ENV_OFFSET 0x60000 +#define CFG_ENV_OFFSET_REDUND 0x80000 +#define CFG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xA0000 0x200000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock5 " \ + "mtdparts=at91_nand:128k(bootstrap)ro,256k(uboot)ro,128k(env1)ro,128k(env2)ro,2M(linux),-(root) " \ + "rw rootfstype=jffs2" + +#endif + +#define CONFIG_BAUDRATE 115200 +#define CFG_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CFG_PROMPT "U-Boot> " +#define CFG_CBSIZE 256 +#define CFG_MAXARGS 16 +#define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) +#define CFG_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 + +#define ROUND(A, B) (((A) + (B)) & ~((B) - 1)) +/* + * Size of malloc() pool + */ +#define CFG_MALLOC_LEN ROUND(3 * CFG_ENV_SIZE + 128*1024, 0x1000) +#define CFG_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif diff --git a/net/eth.c b/net/eth.c index c4f24c6..21d1496 100644 --- a/net/eth.c +++ b/net/eth.c @@ -288,7 +288,8 @@ int eth_initialize(bd_t *bis) #if defined(CONFIG_FSLDMAFEC) mcdmafec_initialize(bis); #endif -#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) +#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ + defined(CONFIG_AT91SAM9263) at91sam9_eth_initialize(bis); #endif
Please add your own (C), and don't mess with mine.
(C) missing.
Please add your own (C), and don't mess with Gary's.
Line length!
Signed-off-by: Stelian Pop stelian@popies.net --- MAINTAINERS | 1 + MAKEALL | 1 + Makefile | 3 + board/atmel/at91sam9rlek/Makefile | 53 +++++++ board/atmel/at91sam9rlek/at91sam9rlek.c | 152 +++++++++++++++++++ board/atmel/at91sam9rlek/config.mk | 1 + board/atmel/at91sam9rlek/led.c | 77 ++++++++++ board/atmel/at91sam9rlek/nand.c | 79 ++++++++++ board/atmel/at91sam9rlek/partition.c | 37 +++++ board/atmel/at91sam9rlek/u-boot.lds | 57 +++++++ include/asm-arm/arch-at91sam9/at91sam9rl.h | 115 ++++++++++++++ include/asm-arm/arch-at91sam9/at91sam9rl_matrix.h | 96 ++++++++++++ include/asm-arm/arch-at91sam9/hardware.h | 2 + include/configs/at91sam9rlek.h | 164 +++++++++++++++++++++ 14 files changed, 838 insertions(+), 0 deletions(-) create mode 100644 board/atmel/at91sam9rlek/Makefile create mode 100644 board/atmel/at91sam9rlek/at91sam9rlek.c create mode 100644 board/atmel/at91sam9rlek/config.mk create mode 100644 board/atmel/at91sam9rlek/led.c create mode 100644 board/atmel/at91sam9rlek/nand.c create mode 100644 board/atmel/at91sam9rlek/partition.c create mode 100644 board/atmel/at91sam9rlek/u-boot.lds create mode 100644 include/asm-arm/arch-at91sam9/at91sam9rl.h create mode 100644 include/asm-arm/arch-at91sam9/at91sam9rl_matrix.h create mode 100644 include/configs/at91sam9rlek.h
diff --git a/MAINTAINERS b/MAINTAINERS index 84bf19f..2047af0 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -540,6 +540,7 @@ Stelian Pop stelian.pop@leadtechdesign.com at91sam9260ek ARM926EJS (AT91SAM9260 SoC) at91sam9261ek ARM926EJS (AT91SAM9261 SoC) at91sam9263ek ARM926EJS (AT91SAM9263 SoC) + at91sam9rlek ARM926EJS (AT91SAM9RL SoC)
Stefan Roese sr@denx.de
diff --git a/MAKEALL b/MAKEALL index 29aa7fc..62ff019 100755 --- a/MAKEALL +++ b/MAKEALL @@ -460,6 +460,7 @@ LIST_ARM9=" \ at91sam9260ek \ at91sam9261ek \ at91sam9263ek \ + at91sam9rlek \ cmc_pu2 \ ap920t \ ap922_XA10 \ diff --git a/Makefile b/Makefile index 65ef6c2..50f61c1 100644 --- a/Makefile +++ b/Makefile @@ -2332,6 +2332,9 @@ at91sam9261ek_config : unconfig at91sam9263ek_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs at91sam9263ek atmel at91sam9
+at91sam9rlek_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm926ejs at91sam9rlek atmel at91sam9 + cmc_pu2_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm920t cmc_pu2 NULL at91rm9200
diff --git a/board/atmel/at91sam9rlek/Makefile b/board/atmel/at91sam9rlek/Makefile new file mode 100644 index 0000000..f291d5e --- /dev/null +++ b/board/atmel/at91sam9rlek/Makefile @@ -0,0 +1,53 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd <at> denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += at91sam9rlek.o +COBJS-y += led.o +COBJS-y += partition.o +COBJS-$(CONFIG_CMD_NAND) += nand.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/atmel/at91sam9rlek/at91sam9rlek.c b/board/atmel/at91sam9rlek/at91sam9rlek.c new file mode 100644 index 0000000..488489c --- /dev/null +++ b/board/atmel/at91sam9rlek/at91sam9rlek.c @@ -0,0 +1,152 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9rl.h> +#include <asm/arch/at91sam9rl_matrix.h> +#include <asm/arch/at91sam926x_mc.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +static void at91sam9rlek_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PA6, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PA7, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_US0); +#endif + +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PA11, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PA12, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_US1); +#endif + +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PA13, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PA14, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_US2); +#endif + +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PA21, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PA22, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} + +#ifdef CONFIG_CMD_NAND +static void at91sam9rlek_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBICSA); + at91_sys_write(AT91_MATRIX_EBICSA, + csa | AT91_MATRIX_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(2) | AT91_SMC_NCS_WRPULSE_(5) | + AT91_SMC_NRDPULSE_(2) | AT91_SMC_NCS_RDPULSE_(5)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(7) | AT91_SMC_NRDCYCLE_(7)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | +#ifdef CFG_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CFG_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(1)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_PIOD); + + /* Configure RDY/BSY */ + at91_set_gpio_input(AT91_PIN_PD17, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(AT91_PIN_PB6, 1); + + at91_set_A_periph(AT91_PIN_PB4, 0); /* NANDOE */ + at91_set_A_periph(AT91_PIN_PB5, 0); /* NANDWE */ +} +#endif + +#ifdef CONFIG_HAS_DATAFLASH +static void at91sam9rlek_spi_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PA28, 0); /* SPI0_NPCS0 */ + + at91_set_A_periph(AT91_PIN_PA25, 0); /* SPI0_MISO */ + at91_set_A_periph(AT91_PIN_PA26, 0); /* SPI0_MOSI */ + at91_set_A_periph(AT91_PIN_PA27, 0); /* SPI0_SPCK */ + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_SPI); +} +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of AT91SAM9RLEK-Board */ + gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9RLEK; + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91sam9rlek_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + at91sam9rlek_nand_hw_init(); +#endif +#ifdef CONFIG_HAS_DATAFLASH + at91sam9rlek_spi_hw_init(); +#endif + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} diff --git a/board/atmel/at91sam9rlek/config.mk b/board/atmel/at91sam9rlek/config.mk new file mode 100644 index 0000000..ff2cfd1 --- /dev/null +++ b/board/atmel/at91sam9rlek/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x23f00000 diff --git a/board/atmel/at91sam9rlek/led.c b/board/atmel/at91sam9rlek/led.c new file mode 100644 index 0000000..fcf99b5 --- /dev/null +++ b/board/atmel/at91sam9rlek/led.c @@ -0,0 +1,77 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9rl.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +#define RED_LED AT91_PIN_PD14 /* this is the power led */ +#define GREEN_LED AT91_PIN_PD15 /* this is the user1 led */ +#define YELLOW_LED AT91_PIN_PD16 /* this is the user2 led */ + +void red_LED_on(void) +{ + at91_set_gpio_value(RED_LED, 1); +} + +void red_LED_off(void) +{ + at91_set_gpio_value(RED_LED, 0); +} + +void green_LED_on(void) +{ + at91_set_gpio_value(GREEN_LED, 0); +} + +void green_LED_off(void) +{ + at91_set_gpio_value(GREEN_LED, 1); +} + +void yellow_LED_on(void) +{ + at91_set_gpio_value(YELLOW_LED, 0); +} + +void yellow_LED_off(void) +{ + at91_set_gpio_value(YELLOW_LED, 1); +} + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_PIOD); + + at91_set_gpio_output(RED_LED, 1); + at91_set_gpio_output(GREEN_LED, 1); + at91_set_gpio_output(YELLOW_LED, 1); + + at91_set_gpio_value(RED_LED, 0); + at91_set_gpio_value(GREEN_LED, 1); + at91_set_gpio_value(YELLOW_LED, 1); +} diff --git a/board/atmel/at91sam9rlek/nand.c b/board/atmel/at91sam9rlek/nand.c new file mode 100644 index 0000000..8f8af93 --- /dev/null +++ b/board/atmel/at91sam9rlek/nand.c @@ -0,0 +1,79 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * (C) Copyright 2006 ATMEL Rousset, Lacressonniere Nicolas + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9rl.h> +#include <asm/arch/gpio.h> +#include <asm/arch/at91_pio.h> + +#include <nand.h> + +/* + * hardware specific access to control-lines + */ +#define MASK_ALE (1 << 21) /* our ALE is AD21 */ +#define MASK_CLE (1 << 22) /* our CLE is AD22 */ + +static void at91sam9rlek_nand_hwcontrol(struct mtd_info *mtd, int cmd) +{ + struct nand_chip *this = mtd->priv; + ulong IO_ADDR_W = (ulong) this->IO_ADDR_W; + + IO_ADDR_W &= ~(MASK_ALE|MASK_CLE); + switch (cmd) { + case NAND_CTL_SETCLE: + IO_ADDR_W |= MASK_CLE; + break; + case NAND_CTL_SETALE: + IO_ADDR_W |= MASK_ALE; + break; + case NAND_CTL_CLRNCE: + at91_set_gpio_value(AT91_PIN_PB6, 1); + break; + case NAND_CTL_SETNCE: + at91_set_gpio_value(AT91_PIN_PB6, 0); + break; + } + this->IO_ADDR_W = (void *) IO_ADDR_W; +} + +static int at91sam9rlek_nand_ready(struct mtd_info *mtd) +{ + return at91_get_gpio_value(AT91_PIN_PD17); +} + +int board_nand_init(struct nand_chip *nand) +{ + nand->eccmode = NAND_ECC_SOFT; +#ifdef CFG_NAND_DBW_16 + nand->options = NAND_BUSWIDTH_16; +#endif + nand->hwcontrol = at91sam9rlek_nand_hwcontrol; + nand->dev_ready = at91sam9rlek_nand_ready; + nand->chip_delay = 20; + + return 0; +} diff --git a/board/atmel/at91sam9rlek/partition.c b/board/atmel/at91sam9rlek/partition.c new file mode 100644 index 0000000..3bffd71 --- /dev/null +++ b/board/atmel/at91sam9rlek/partition.c @@ -0,0 +1,37 @@ +/* + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <config.h> +#include <asm/hardware.h> +#include <dataflash.h> + +AT91S_DATAFLASH_INFO dataflash_info[CFG_MAX_DATAFLASH_BANKS]; + +struct dataflash_addr cs[CFG_MAX_DATAFLASH_BANKS] = { + {CFG_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ +}; + +/*define the area offsets*/ +dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { + {0x00000000, 0x000041FF, FLAG_PROTECT_SET, 0, "Bootstrap"}, + {0x00004200, 0x000083FF, FLAG_PROTECT_CLEAR, 0, "Environment"}, + {0x00008400, 0x00041FFF, FLAG_PROTECT_SET, 0, "U-Boot"}, + {0x00042000, 0x00251FFF, FLAG_PROTECT_CLEAR, 0, "Kernel"}, + {0x00252000, 0xFFFFFFFF, FLAG_PROTECT_CLEAR, 0, "FS"}, +}; diff --git a/board/atmel/at91sam9rlek/u-boot.lds b/board/atmel/at91sam9rlek/u-boot.lds new file mode 100644 index 0000000..05a6d83 --- /dev/null +++ b/board/atmel/at91sam9rlek/u-boot.lds @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, <gj <at> denx.de> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +/*OUTPUT_FORMAT("elf32-arm", "elf32-arm", "elf32-arm")*/ +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm926ejs/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/include/asm-arm/arch-at91sam9/at91sam9rl.h b/include/asm-arm/arch-at91sam9/at91sam9rl.h new file mode 100644 index 0000000..16d2832 --- /dev/null +++ b/include/asm-arm/arch-at91sam9/at91sam9rl.h @@ -0,0 +1,115 @@ +/* + * include/asm-arm/arch-at91/at91sam9260.h + * + * Copyright (C) 2007 Atmel Corporation + * + * Common definitions. + * Based on AT91SAM9RL datasheet revision A. (Preliminary) + * + * This file is subject to the terms and conditions of the GNU General Public + * License. See the file COPYING in the main directory of this archive for + * more details. + */ + +#ifndef AT91SAM9RL_H +#define AT91SAM9RL_H + +/* + * Peripheral identifiers/interrupts. + */ +#define AT91_ID_FIQ 0 /* Advanced Interrupt Controller (FIQ) */ +#define AT91_ID_SYS 1 /* System Controller */ +#define AT91SAM9RL_ID_PIOA 2 /* Parallel IO Controller A */ +#define AT91SAM9RL_ID_PIOB 3 /* Parallel IO Controller B */ +#define AT91SAM9RL_ID_PIOC 4 /* Parallel IO Controller C */ +#define AT91SAM9RL_ID_PIOD 5 /* Parallel IO Controller D */ +#define AT91SAM9RL_ID_US0 6 /* USART 0 */ +#define AT91SAM9RL_ID_US1 7 /* USART 1 */ +#define AT91SAM9RL_ID_US2 8 /* USART 2 */ +#define AT91SAM9RL_ID_US3 9 /* USART 3 */ +#define AT91SAM9RL_ID_MCI 10 /* Multimedia Card Interface */ +#define AT91SAM9RL_ID_TWI0 11 /* TWI 0 */ +#define AT91SAM9RL_ID_TWI1 12 /* TWI 1 */ +#define AT91SAM9RL_ID_SPI 13 /* Serial Peripheral Interface */ +#define AT91SAM9RL_ID_SSC0 14 /* Serial Synchronous Controller 0 */ +#define AT91SAM9RL_ID_SSC1 15 /* Serial Synchronous Controller 1 */ +#define AT91SAM9RL_ID_TC0 16 /* Timer Counter 0 */ +#define AT91SAM9RL_ID_TC1 17 /* Timer Counter 1 */ +#define AT91SAM9RL_ID_TC2 18 /* Timer Counter 2 */ +#define AT91SAM9RL_ID_PWMC 19 /* Pulse Width Modulation Controller */ +#define AT91SAM9RL_ID_TSC 20 /* Touch Screen Controller */ +#define AT91SAM9RL_ID_DMA 21 /* DMA Controller */ +#define AT91SAM9RL_ID_UDPHS 22 /* USB Device HS */ +#define AT91SAM9RL_ID_LCDC 23 /* LCD Controller */ +#define AT91SAM9RL_ID_AC97C 24 /* AC97 Controller */ +#define AT91SAM9RL_ID_IRQ0 31 /* Advanced Interrupt Controller (IRQ0) */ + + +/* + * User Peripheral physical base addresses. + */ +#define AT91SAM9RL_BASE_TCB0 0xfffa0000 +#define AT91SAM9RL_BASE_TC0 0xfffa0000 +#define AT91SAM9RL_BASE_TC1 0xfffa0040 +#define AT91SAM9RL_BASE_TC2 0xfffa0080 +#define AT91SAM9RL_BASE_MCI 0xfffa4000 +#define AT91SAM9RL_BASE_TWI0 0xfffa8000 +#define AT91SAM9RL_BASE_TWI1 0xfffac000 +#define AT91SAM9RL_BASE_US0 0xfffb0000 +#define AT91SAM9RL_BASE_US1 0xfffb4000 +#define AT91SAM9RL_BASE_US2 0xfffb8000 +#define AT91SAM9RL_BASE_US3 0xfffbc000 +#define AT91SAM9RL_BASE_SSC0 0xfffc0000 +#define AT91SAM9RL_BASE_SSC1 0xfffc4000 +#define AT91SAM9RL_BASE_PWMC 0xfffc8000 +#define AT91SAM9RL_BASE_SPI 0xfffcc000 +#define AT91SAM9RL_BASE_TSC 0xfffd0000 +#define AT91SAM9RL_BASE_UDPHS 0xfffd4000 +#define AT91SAM9RL_BASE_AC97C 0xfffd8000 +#define AT91_BASE_SYS 0xffffc000 + + +/* + * System Peripherals (offset from AT91_BASE_SYS) + */ +#define AT91_DMA (0xffffe600 - AT91_BASE_SYS) +#define AT91_ECC (0xffffe800 - AT91_BASE_SYS) +#define AT91_SDRAMC (0xffffea00 - AT91_BASE_SYS) +#define AT91_SMC (0xffffec00 - AT91_BASE_SYS) +#define AT91_MATRIX (0xffffee00 - AT91_BASE_SYS) +#define AT91_CCFG (0xffffef10 - AT91_BASE_SYS) +#define AT91_AIC (0xfffff000 - AT91_BASE_SYS) +#define AT91_DBGU (0xfffff200 - AT91_BASE_SYS) +#define AT91_PIOA (0xfffff400 - AT91_BASE_SYS) +#define AT91_PIOB (0xfffff600 - AT91_BASE_SYS) +#define AT91_PIOC (0xfffff800 - AT91_BASE_SYS) +#define AT91_PIOD (0xfffffa00 - AT91_BASE_SYS) +#define AT91_PMC (0xfffffc00 - AT91_BASE_SYS) +#define AT91_RSTC (0xfffffd00 - AT91_BASE_SYS) +#define AT91_SHDWC (0xfffffd10 - AT91_BASE_SYS) +#define AT91_RTT (0xfffffd20 - AT91_BASE_SYS) +#define AT91_PIT (0xfffffd30 - AT91_BASE_SYS) +#define AT91_WDT (0xfffffd40 - AT91_BASE_SYS) +#define AT91_SCKCR (0xfffffd50 - AT91_BASE_SYS) +#define AT91_GPBR (0xfffffd60 - AT91_BASE_SYS) +#define AT91_RTC (0xfffffe00 - AT91_BASE_SYS) + +#define AT91_USART0 AT91SAM9RL_BASE_US0 +#define AT91_USART1 AT91SAM9RL_BASE_US1 +#define AT91_USART2 AT91SAM9RL_BASE_US2 +#define AT91_USART3 AT91SAM9RL_BASE_US3 + + +/* + * Internal Memory. + */ +#define AT91SAM9RL_SRAM_BASE 0x00300000 /* Internal SRAM base address */ +#define AT91SAM9RL_SRAM_SIZE SZ_16K /* Internal SRAM size (16Kb) */ + +#define AT91SAM9RL_ROM_BASE 0x00400000 /* Internal ROM base address */ +#define AT91SAM9RL_ROM_SIZE (2 * SZ_16K) /* Internal ROM size (32Kb) */ + +#define AT91SAM9RL_LCDC_BASE 0x00500000 /* LCD Controller */ +#define AT91SAM9RL_UDPHS_BASE 0x00600000 /* USB Device HS controller */ + +#endif diff --git a/include/asm-arm/arch-at91sam9/at91sam9rl_matrix.h b/include/asm-arm/arch-at91sam9/at91sam9rl_matrix.h new file mode 100644 index 0000000..8422417 --- /dev/null +++ b/include/asm-arm/arch-at91sam9/at91sam9rl_matrix.h @@ -0,0 +1,96 @@ +/* + * include/asm-arm/arch-at91/at91sam9rl_matrix.h + * + * Copyright (C) 2007 Atmel Corporation + * + * Memory Controllers (MATRIX, EBI) - System peripherals registers. + * Based on AT91SAM9RL datasheet revision A. (Preliminary) + * + * This file is subject to the terms and conditions of the GNU General Public + * License. See the file COPYING in the main directory of this archive for + * more details. + */ + +#ifndef AT91SAM9RL_MATRIX_H +#define AT91SAM9RL_MATRIX_H + +#define AT91_MATRIX_MCFG0 (AT91_MATRIX + 0x00) /* Master Configuration Register 0 */ +#define AT91_MATRIX_MCFG1 (AT91_MATRIX + 0x04) /* Master Configuration Register 1 */ +#define AT91_MATRIX_MCFG2 (AT91_MATRIX + 0x08) /* Master Configuration Register 2 */ +#define AT91_MATRIX_MCFG3 (AT91_MATRIX + 0x0C) /* Master Configuration Register 3 */ +#define AT91_MATRIX_MCFG4 (AT91_MATRIX + 0x10) /* Master Configuration Register 4 */ +#define AT91_MATRIX_MCFG5 (AT91_MATRIX + 0x14) /* Master Configuration Register 5 */ +#define AT91_MATRIX_ULBT (7 << 0) /* Undefined Length Burst Type */ +#define AT91_MATRIX_ULBT_INFINITE (0 << 0) +#define AT91_MATRIX_ULBT_SINGLE (1 << 0) +#define AT91_MATRIX_ULBT_FOUR (2 << 0) +#define AT91_MATRIX_ULBT_EIGHT (3 << 0) +#define AT91_MATRIX_ULBT_SIXTEEN (4 << 0) + +#define AT91_MATRIX_SCFG0 (AT91_MATRIX + 0x40) /* Slave Configuration Register 0 */ +#define AT91_MATRIX_SCFG1 (AT91_MATRIX + 0x44) /* Slave Configuration Register 1 */ +#define AT91_MATRIX_SCFG2 (AT91_MATRIX + 0x48) /* Slave Configuration Register 2 */ +#define AT91_MATRIX_SCFG3 (AT91_MATRIX + 0x4C) /* Slave Configuration Register 3 */ +#define AT91_MATRIX_SCFG4 (AT91_MATRIX + 0x50) /* Slave Configuration Register 4 */ +#define AT91_MATRIX_SCFG5 (AT91_MATRIX + 0x54) /* Slave Configuration Register 5 */ +#define AT91_MATRIX_SLOT_CYCLE (0xff << 0) /* Maximum Number of Allowed Cycles for a Burst */ +#define AT91_MATRIX_DEFMSTR_TYPE (3 << 16) /* Default Master Type */ +#define AT91_MATRIX_DEFMSTR_TYPE_NONE (0 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_LAST (1 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_FIXED (2 << 16) +#define AT91_MATRIX_FIXED_DEFMSTR (0xf << 18) /* Fixed Index of Default Master */ +#define AT91_MATRIX_ARBT (3 << 24) /* Arbitration Type */ +#define AT91_MATRIX_ARBT_ROUND_ROBIN (0 << 24) +#define AT91_MATRIX_ARBT_FIXED_PRIORITY (1 << 24) + +#define AT91_MATRIX_PRAS0 (AT91_MATRIX + 0x80) /* Priority Register A for Slave 0 */ +#define AT91_MATRIX_PRAS1 (AT91_MATRIX + 0x88) /* Priority Register A for Slave 1 */ +#define AT91_MATRIX_PRAS2 (AT91_MATRIX + 0x90) /* Priority Register A for Slave 2 */ +#define AT91_MATRIX_PRAS3 (AT91_MATRIX + 0x98) /* Priority Register A for Slave 3 */ +#define AT91_MATRIX_PRAS4 (AT91_MATRIX + 0xA0) /* Priority Register A for Slave 4 */ +#define AT91_MATRIX_PRAS5 (AT91_MATRIX + 0xA8) /* Priority Register A for Slave 5 */ +#define AT91_MATRIX_M0PR (3 << 0) /* Master 0 Priority */ +#define AT91_MATRIX_M1PR (3 << 4) /* Master 1 Priority */ +#define AT91_MATRIX_M2PR (3 << 8) /* Master 2 Priority */ +#define AT91_MATRIX_M3PR (3 << 12) /* Master 3 Priority */ +#define AT91_MATRIX_M4PR (3 << 16) /* Master 4 Priority */ +#define AT91_MATRIX_M5PR (3 << 20) /* Master 5 Priority */ + +#define AT91_MATRIX_MRCR (AT91_MATRIX + 0x100) /* Master Remap Control Register */ +#define AT91_MATRIX_RCB0 (1 << 0) /* Remap Command for AHB Master 0 (ARM926EJ-S Instruction Master) */ +#define AT91_MATRIX_RCB1 (1 << 1) /* Remap Command for AHB Master 1 (ARM926EJ-S Data Master) */ +#define AT91_MATRIX_RCB2 (1 << 2) +#define AT91_MATRIX_RCB3 (1 << 3) +#define AT91_MATRIX_RCB4 (1 << 4) +#define AT91_MATRIX_RCB5 (1 << 5) + +#define AT91_MATRIX_TCMR (AT91_MATRIX + 0x114) /* TCM Configuration Register */ +#define AT91_MATRIX_ITCM_SIZE (0xf << 0) /* Size of ITCM enabled memory block */ +#define AT91_MATRIX_ITCM_0 (0 << 0) +#define AT91_MATRIX_ITCM_16 (5 << 0) +#define AT91_MATRIX_ITCM_32 (6 << 0) +#define AT91_MATRIX_DTCM_SIZE (0xf << 4) /* Size of DTCM enabled memory block */ +#define AT91_MATRIX_DTCM_0 (0 << 4) +#define AT91_MATRIX_DTCM_16 (5 << 4) +#define AT91_MATRIX_DTCM_32 (6 << 4) + +#define AT91_MATRIX_EBICSA (AT91_MATRIX + 0x120) /* EBI0 Chip Select Assignment Register */ +#define AT91_MATRIX_CS1A (1 << 1) /* Chip Select 1 Assignment */ +#define AT91_MATRIX_CS1A_SMC (0 << 1) +#define AT91_MATRIX_CS1A_SDRAMC (1 << 1) +#define AT91_MATRIX_CS3A (1 << 3) /* Chip Select 3 Assignment */ +#define AT91_MATRIX_CS3A_SMC (0 << 3) +#define AT91_MATRIX_CS3A_SMC_SMARTMEDIA (1 << 3) +#define AT91_MATRIX_CS4A (1 << 4) /* Chip Select 4 Assignment */ +#define AT91_MATRIX_CS4A_SMC (0 << 4) +#define AT91_MATRIX_CS4A_SMC_CF1 (1 << 4) +#define AT91_MATRIX_CS5A (1 << 5) /* Chip Select 5 Assignment */ +#define AT91_MATRIX_CS5A_SMC (0 << 5) +#define AT91_MATRIX_CS5A_SMC_CF2 (1 << 5) +#define AT91_MATRIX_DBPUC (1 << 8) /* Data Bus Pull-up Configuration */ +#define AT91_MATRIX_VDDIOMSEL (1 << 16) /* Memory voltage selection */ +#define AT91_MATRIX_VDDIOMSEL_1_8V (0 << 16) +#define AT91_MATRIX_VDDIOMSEL_3_3V (1 << 16) + + +#endif diff --git a/include/asm-arm/arch-at91sam9/hardware.h b/include/asm-arm/arch-at91sam9/hardware.h index a5d8293..7e08602 100644 --- a/include/asm-arm/arch-at91sam9/hardware.h +++ b/include/asm-arm/arch-at91sam9/hardware.h @@ -37,6 +37,8 @@ #define AT91_PMC_UHP AT91SAM926x_PMC_UHP #elif defined(CONFIG_AT91SAM9RL) #include <asm/arch/at91sam9rl.h> +#define AT91_BASE_SPI AT91SAM9RL_BASE_SPI +#define AT91_ID_UHP AT91SAM9RL_ID_UHP #elif defined(CONFIG_AT91CAP9) #include <asm/arch/at91cap9.h> #define AT91_BASE_EMAC AT91CAP9_BASE_EMAC diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h new file mode 100644 index 0000000..acf5d81 --- /dev/null +++ b/include/configs/at91sam9rlek.h @@ -0,0 +1,164 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * Configuation settings for the AT91SAM9RLEK board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* ARM asynchronous clock */ +#define AT91_MAIN_CLOCK 200000000 /* from 12.000 MHz crystal */ +#define AT91_MASTER_CLOCK 100000000 /* peripheral = main / 2 */ +#define CFG_HZ 1000000 /* 1us resolution */ + +#define AT91_SLOW_CLOCK 32768 /* slow clock */ + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#define CONFIG_AT91SAM9RL 1 /* It's an Atmel AT91SAM9RL SoC*/ +#define CONFIG_AT91SAM9RLEK 1 /* on an AT91SAM9RLEK Board */ +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +#define CONFIG_BOOTDELAY 3 + +/* #define CONFIG_ENV_OVERWRITE 1 */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_USB + +#define CONFIG_CMD_NAND 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x04000000 /* 64 megs */ + +/* DataFlash */ +#define CONFIG_HAS_DATAFLASH 1 +#define CFG_SPI_WRITE_TOUT (5*CFG_HZ) +#define CFG_MAX_DATAFLASH_BANKS 1 +#define CFG_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ +#define AT91_SPI_CLK 15000000 +#define DATAFLASH_TCSS (0x1a << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +/* NOR flash - not present */ +#define CFG_NO_FLASH 1 + +/* NAND flash */ +#define NAND_MAX_CHIPS 1 +#define CFG_MAX_NAND_DEVICE 1 +#define CFG_NAND_BASE 0x40000000 +#define CFG_NAND_DBW_8 1 + +/* Ethernet - not present */ + +/* USB - not supported */ + +#define CFG_LOAD_ADDR 0x22000000 /* load address */ + +#define CFG_MEMTEST_START PHYS_SDRAM +#define CFG_MEMTEST_END 0x23e00000 + +#define CFG_USE_DATAFLASH 1 +#undef CFG_USE_NANDFLASH + +#ifdef CFG_USE_DATAFLASH + +/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +#define CFG_ENV_IS_IN_DATAFLASH 1 +#define CFG_MONITOR_BASE (CFG_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) +#define CFG_ENV_OFFSET 0x4200 +#define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS0 + CFG_ENV_OFFSET) +#define CFG_ENV_SIZE 0x4200 +#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock0 " \ + "mtdparts=at91_nand:-(root) "\ + "rw rootfstype=jffs2" + +#else /* CFG_USE_NANDFLASH */ + +/* bootstrap + u-boot + env + linux in nandflash */ +#define CFG_ENV_IS_IN_NAND 1 +#define CFG_ENV_OFFSET 0x60000 +#define CFG_ENV_OFFSET_REDUND 0x80000 +#define CFG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xA0000 0x200000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock5 " \ + "mtdparts=at91_nand:128k(bootstrap)ro,256k(uboot)ro,128k(env1)ro,128k(env2)ro,2M(linux),-(root) " \ + "rw rootfstype=jffs2" + +#endif + +#define CONFIG_BAUDRATE 115200 +#define CFG_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CFG_PROMPT "U-Boot> " +#define CFG_CBSIZE 256 +#define CFG_MAXARGS 16 +#define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) +#define CFG_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 + +#define ROUND(A, B) (((A) + (B)) & ~((B) - 1)) +/* + * Size of malloc() pool + */ +#define CFG_MALLOC_LEN ROUND(3 * CFG_ENV_SIZE + 128*1024, 0x1000) +#define CFG_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
You should add your own Copyright here. And please don't mutilate my entry - please leave this exactly as it was.
Copyright entry missing.
Ok.
I don't know what to say here. I suppose you're talking about the @ -> <at> replacement. This is a copy of board/atmel/at91cap9adk/Makefile, and I'm pretty sure that when I submitted the AT91CAP9 patches, the @ was there.
I think that somehow Peter Pearse converted it when applying the patches into his git tree.
Except that this is not mine. partition.c is a (pretty or complete, depending on the board) verbatim copy of board/atmel/at91cap9adk/partition.c, which was submitted by Ulf Samuelsson.
Signed-off-by: Stelian Pop stelian@popies.net --- drivers/mtd/nand/nand.c | 3 ++- include/nand.h | 2 +- 2 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/nand.c b/drivers/mtd/nand/nand.c index 27b5792..c5746fe 100644 --- a/drivers/mtd/nand/nand.c +++ b/drivers/mtd/nand/nand.c @@ -60,7 +60,7 @@ static void nand_init_chip(struct mtd_info *mtd, struct nand_chip *nand,
-void nand_init(void) +ulong nand_init(void) { int i; unsigned int size = 0; @@ -78,6 +78,7 @@ void nand_init(void) */ board_nand_select_device(nand_info[nand_curr_device].priv, nand_curr_device); #endif + return size; }
#endif diff --git a/include/nand.h b/include/nand.h index 247d346..8f388c4 100644 --- a/include/nand.h +++ b/include/nand.h @@ -32,7 +32,7 @@ typedef struct mtd_info nand_info_t;
extern int nand_curr_device; extern nand_info_t nand_info[]; -extern void nand_init(void); +extern ulong nand_init(void);
static inline int nand_read(nand_info_t *info, off_t ofs, size_t *len, u_char *buf) {
Signed-off-by: Stelian Pop stelian@popies.net --- include/asm-arm/u-boot.h | 4 ++++ lib_arm/board.c | 14 ++++++++------ 2 files changed, 12 insertions(+), 6 deletions(-)
diff --git a/include/asm-arm/u-boot.h b/include/asm-arm/u-boot.h index c120312..dbfe2cf 100644 --- a/include/asm-arm/u-boot.h +++ b/include/asm-arm/u-boot.h @@ -48,10 +48,14 @@ typedef struct bd_info { ulong start; ulong size; } bi_dram[CONFIG_NR_DRAM_BANKS]; + ulong bi_dram_size; #ifdef CONFIG_HAS_ETH1 /* second onboard ethernet port */ unsigned char bi_enet1addr[6]; #endif +#ifdef CONFIG_CMD_NAND + ulong bi_nand_size; +#endif } bd_t;
#define bi_env_data bi_env->data diff --git a/lib_arm/board.c b/lib_arm/board.c index 67506b3..0752877 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -56,7 +56,7 @@ DECLARE_GLOBAL_DATA_PTR;
#if defined(CONFIG_CMD_NAND) -void nand_init (void); +ulong nand_init (void); #endif
#if defined(CONFIG_CMD_ONENAND) @@ -187,21 +187,23 @@ static int display_dram_config (void) { int i;
+ gd->bd->bi_dram_size = 0; + #ifdef DEBUG puts ("RAM Configuration:\n");
for(i=0; i<CONFIG_NR_DRAM_BANKS; i++) { printf ("Bank #%d: %08lx ", i, gd->bd->bi_dram[i].start); print_size (gd->bd->bi_dram[i].size, "\n"); + gd->bd->bi_dram_size += gd->bd->bi_dram[i].size; } #else - ulong size = 0;
for (i=0; i<CONFIG_NR_DRAM_BANKS; i++) { - size += gd->bd->bi_dram[i].size; + gd->bd->bi_dram_size += gd->bd->bi_dram[i].size; } puts("DRAM: "); - print_size(size, "\n"); + print_size(gd->bd->bi_dram_size, "\n"); #endif
return (0); @@ -279,7 +281,7 @@ void start_armboot (void) { init_fnc_t **init_fnc_ptr; char *s; -#ifndef CFG_NO_FLASH +#if !defined(CFG_NO_FLASH) || defined (CONFIG_VFD) || defined(CONFIG_LCD) ulong size; #endif #if defined(CONFIG_VFD) || defined(CONFIG_LCD) @@ -340,7 +342,7 @@ void start_armboot (void)
#if defined(CONFIG_CMD_NAND) puts ("NAND: "); - nand_init(); /* go init the NAND */ + gd->bd->bi_nand_size = nand_init(); /* go init the NAND */ #endif
- ulong bi_dram_size;
Why would that be needed? Isn't adding the "size" entries above sufficient?
} puts("DRAM: ");gd->bd->bi_dram_size += gd->bd->bi_dram[i].size;
- print_size(gd->bd->bi_dram_size, "\n");
We really don't need an extra variable here, me thinks.
It is. But this addition is done once more in the LCD driver (see patch 14/21), so I thought it would be useful to remember the result.
But if you consider it's more costly to add 4 bytes in global data than to do the addition again, I can change it back.
Signed-off-by: Stelian Pop stelian@popies.net --- README | 4 + common/lcd.c | 66 +++++++++++++- drivers/video/Makefile | 1 + drivers/video/atmel_lcdfb.c | 160 +++++++++++++++++++++++++++++++ include/asm-arm/arch-at91sam9/clk.h | 6 + include/atmel_lcdc.h | 177 +++++++++++++++++++++++++++++++++++ include/lcd.h | 30 ++++++- lib_arm/board.c | 37 ++++++-- 8 files changed, 469 insertions(+), 12 deletions(-) create mode 100644 drivers/video/atmel_lcdfb.c create mode 100644 include/atmel_lcdc.h
diff --git a/README b/README index 5e2bca4..dca495d 100644 --- a/README +++ b/README @@ -962,6 +962,10 @@ The following options need to be configured: display); also select one of the supported displays by defining one of these:
+ CONFIG_ATMEL_LCD: + + HITACHI TX09D70VM1CCA, 3.5", 240x320. + CONFIG_NEC_NL6448AC33:
NEC NL6448AC33-18. Active, color, single scan. diff --git a/common/lcd.c b/common/lcd.c index 914dc2e..cf7f750 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -50,6 +50,10 @@ #include <lcdvideo.h> #endif
+#if defined(CONFIG_ATMEL_LCD) +#include <atmel_lcdc.h> +#endif + #ifdef CONFIG_LCD
/************************************************************************/ @@ -474,14 +478,22 @@ ulong lcd_setmem (ulong addr)
static void lcd_setfgcolor (int color) { +#ifdef CONFIG_ATMEL_LCD + lcd_color_fg = color; +#else lcd_color_fg = color & 0x0F; +#endif }
static void lcd_setbgcolor (int color) { +#ifdef CONFIG_ATMEL_LCD + lcd_color_bg = color; +#else lcd_color_bg = color & 0x0F; +#endif }
/*----------------------------------------------------------------------*/ @@ -508,7 +520,11 @@ static int lcd_getbgcolor (void) #ifdef CONFIG_LCD_LOGO void bitmap_plot (int x, int y) { +#ifdef CONFIG_ATMEL_LCD + uint *cmap; +#else ushort *cmap; +#endif ushort i, j; uchar *bmap; uchar *fb; @@ -533,6 +549,8 @@ void bitmap_plot (int x, int y) cmap = (ushort *)fbi->palette; #elif defined(CONFIG_MPC823) cmap = (ushort *)&(cp->lcd_cmap[BMP_LOGO_OFFSET*sizeof(ushort)]); +#elif defined(CONFIG_ATMEL_LCD) + cmap = (uint *) (panel_info.mmio + ATMEL_LCDC_LUT(0)); #endif
WATCHDOG_RESET(); @@ -540,11 +558,26 @@ void bitmap_plot (int x, int y) /* Set color map */ for (i=0; i<(sizeof(bmp_logo_palette)/(sizeof(ushort))); ++i) { ushort colreg = bmp_logo_palette[i]; +#ifdef CONFIG_ATMEL_LCD + uint lut_entry; +#ifdef CONFIG_ATMEL_LCD_BGR555 + lut_entry = ((colreg & 0x000F) << 11) | + ((colreg & 0x00F0) << 2) | + ((colreg & 0x0F00) >> 7); +#else /* CONFIG_ATMEL_LCD_RGB565 */ + lut_entry = ((colreg & 0x000F) << 1) | + ((colreg & 0x00F0) << 3) | + ((colreg & 0x0F00) << 4); +#endif + *(cmap + BMP_LOGO_OFFSET) = lut_entry; + cmap++; +#else /* !CONFIG_ATMEL_LCD */ #ifdef CFG_INVERT_COLORS *cmap++ = 0xffff - colreg; #else *cmap++ = colreg; #endif +#endif /* CONFIG_ATMEL_LCD */ }
WATCHDOG_RESET(); @@ -578,7 +611,9 @@ void bitmap_plot (int x, int y) */ int lcd_display_bitmap(ulong bmp_image, int x, int y) { -#if !defined(CONFIG_MCC200) +#ifdef CONFIG_ATMEL_LCD + uint *cmap; +#elif !defined(CONFIG_MCC200) ushort *cmap; #endif ushort i, j; @@ -633,6 +668,8 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) cmap = (ushort *)fbi->palette; #elif defined(CONFIG_MPC823) cmap = (ushort *)&(cp->lcd_cmap[255*sizeof(ushort)]); +#elif defined(CONFIG_ATMEL_LCD) + cmap = (uint *) (panel_info.mmio + ATMEL_LCDC_LUT(0)); #else # error "Don't know location of color map" #endif @@ -765,6 +802,33 @@ static void *lcd_logo (void) # endif /* CONFIG_LCD_INFO */ #endif /* CONFIG_MPC823 */
+#ifdef CONFIG_ATMEL_LCD +# ifdef CONFIG_LCD_INFO + sprintf (info, "%s", U_BOOT_VERSION); + lcd_drawchars (LCD_INFO_X, LCD_INFO_Y, (uchar *)info, strlen(info)); + + sprintf (info, "(C) 2008 ATMEL Corp"); + lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT, + (uchar *)info, strlen(info)); + + sprintf (info, "at91support@atmel.com"); + lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT * 2, + (uchar *)info, strlen(info)); + + sprintf (info, "%s CPU at %s MHz", + AT91_CPU_NAME, + strmhz(temp, AT91_MAIN_CLOCK)); + lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT * 3, + (uchar *)info, strlen(info)); + sprintf (info, " %ld MB SDRAM, %ld MB NAND", + gd->bd->bi_dram_size >> 20, + gd->bd->bi_nand_size >> 20 ); + lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT * 4, + (uchar *)info, strlen(info)); +# endif /* CONFIG_LCD_INFO */ +#endif /* CONFIG_ATMEL_LCD */ + + #if defined(CONFIG_LCD_LOGO) && !defined(CONFIG_LCD_INFO_BELOW_LOGO) return ((void *)((ulong)lcd_base + BMP_LOGO_HEIGHT * lcd_line_length)); #else diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 0e40f2a..a07ee0e 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -26,6 +26,7 @@ include $(TOPDIR)/config.mk LIB := $(obj)libvideo.a
COBJS-y += ati_radeon_fb.o +COBJS-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o COBJS-y += cfb_console.o COBJS-y += ct69000.o COBJS-y += mb862xx.o diff --git a/drivers/video/atmel_lcdfb.c b/drivers/video/atmel_lcdfb.c new file mode 100644 index 0000000..12157e4 --- /dev/null +++ b/drivers/video/atmel_lcdfb.c @@ -0,0 +1,160 @@ +/* + * Driver for AT91/AT32 LCD Controller + * + * Copyright (C) 2007 Atmel Corporation + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/gpio.h> +#include <asm/arch/clk.h> +#include <lcd.h> +#include <atmel_lcdc.h> + +int lcd_line_length; +int lcd_color_fg; +int lcd_color_bg; + +void *lcd_base; /* Start of framebuffer memory */ +void *lcd_console_address; /* Start of console buffer */ + +short console_col; +short console_row; + +/* configurable parameters */ +#define ATMEL_LCDC_CVAL_DEFAULT 0xc8 +#define ATMEL_LCDC_DMA_BURST_LEN 8 + +#if defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91CAP9) +#define ATMEL_LCDC_FIFO_SIZE 2048 +#else +#define ATMEL_LCDC_FIFO_SIZE 512 +#endif + +#define lcdc_readl(mmio, reg) __raw_readl((mmio)+(reg)) +#define lcdc_writel(mmio, reg, val) __raw_writel((val), (mmio)+(reg)) + +void lcd_setcolreg (ushort regno, ushort red, ushort green, ushort blue) +{ +#if defined(CONFIG_ATMEL_LCD_BGR555) + lcdc_writel(panel_info.mmio, ATMEL_LCDC_LUT(regno), + (red >> 3) | ((green & 0xf8) << 2) | ((blue & 0xf8) << 7)); +#else + lcdc_writel(panel_info.mmio, ATMEL_LCDC_LUT(regno), + (blue >> 3) | ((green & 0xfc) << 3) | ((red & 0xf8) << 8)); +#endif +} + +void lcd_ctrl_init(void *lcdbase) +{ + unsigned long value; + + /* Turn off the LCD controller and the DMA controller */ + lcdc_writel(panel_info.mmio, ATMEL_LCDC_PWRCON, + 1 << ATMEL_LCDC_GUARDT_OFFSET); + + /* Wait for the LCDC core to become idle */ + while (lcdc_readl(panel_info.mmio, ATMEL_LCDC_PWRCON) & ATMEL_LCDC_BUSY) + udelay(10); + + lcdc_writel(panel_info.mmio, ATMEL_LCDC_DMACON, 0); + + /* Reset LCDC DMA */ + lcdc_writel(panel_info.mmio, ATMEL_LCDC_DMACON, ATMEL_LCDC_DMARST); + + /* ...set frame size and burst length = 8 words (?) */ + value = (panel_info.vl_col * panel_info.vl_row * + NBITS(panel_info.vl_bpix)) / 32; + value |= ((ATMEL_LCDC_DMA_BURST_LEN - 1) << ATMEL_LCDC_BLENGTH_OFFSET); + lcdc_writel(panel_info.mmio, ATMEL_LCDC_DMAFRMCFG, value); + + /* Set pixel clock */ + value = get_lcdc_clk_rate(0) / panel_info.vl_clk; + if (get_lcdc_clk_rate(0) % panel_info.vl_clk) + value++; + value = (value / 2) - 1; + + if (!value) { + lcdc_writel(panel_info.mmio, ATMEL_LCDC_LCDCON1, ATMEL_LCDC_BYPASS); + } else + lcdc_writel(panel_info.mmio, ATMEL_LCDC_LCDCON1, + value << ATMEL_LCDC_CLKVAL_OFFSET); + + /* Initialize control register 2 */ + value = ATMEL_LCDC_MEMOR_LITTLE | ATMEL_LCDC_CLKMOD_ALWAYSACTIVE; + if (panel_info.vl_tft) + value |= ATMEL_LCDC_DISTYPE_TFT; + + if (!(panel_info.vl_sync & ATMEL_LCDC_INVLINE_INVERTED)) + value |= ATMEL_LCDC_INVLINE_INVERTED; + if (!(panel_info.vl_sync & ATMEL_LCDC_INVFRAME_INVERTED)) + value |= ATMEL_LCDC_INVFRAME_INVERTED; + value |= (panel_info.vl_bpix << 5); + lcdc_writel(panel_info.mmio, ATMEL_LCDC_LCDCON2, value); + + /* Vertical timing */ + value = (panel_info.vl_vsync_len - 1) << ATMEL_LCDC_VPW_OFFSET; + value |= panel_info.vl_upper_margin << ATMEL_LCDC_VBP_OFFSET; + value |= panel_info.vl_lower_margin; + lcdc_writel(panel_info.mmio, ATMEL_LCDC_TIM1, value); + + /* Horizontal timing */ + value = (panel_info.vl_right_margin - 1) << ATMEL_LCDC_HFP_OFFSET; + value |= (panel_info.vl_hsync_len - 1) << ATMEL_LCDC_HPW_OFFSET; + value |= (panel_info.vl_left_margin - 1); + lcdc_writel(panel_info.mmio, ATMEL_LCDC_TIM2, value); + + /* Display size */ + value = (panel_info.vl_col - 1) << ATMEL_LCDC_HOZVAL_OFFSET; + value |= panel_info.vl_row - 1; + lcdc_writel(panel_info.mmio, ATMEL_LCDC_LCDFRMCFG, value); + + /* FIFO Threshold: Use formula from data sheet */ + value = ATMEL_LCDC_FIFO_SIZE - (2 * ATMEL_LCDC_DMA_BURST_LEN + 3); + lcdc_writel(panel_info.mmio, ATMEL_LCDC_FIFO, value); + + /* Toggle LCD_MODE every frame */ + lcdc_writel(panel_info.mmio, ATMEL_LCDC_MVAL, 0); + + /* Disable all interrupts */ + lcdc_writel(panel_info.mmio, ATMEL_LCDC_IDR, ~0UL); + + /* Set contrast */ + value = ATMEL_LCDC_PS_DIV8 | + ATMEL_LCDC_POL_POSITIVE | + ATMEL_LCDC_ENA_PWMENABLE; + lcdc_writel(panel_info.mmio, ATMEL_LCDC_CONTRAST_CTR, value); + lcdc_writel(panel_info.mmio, ATMEL_LCDC_CONTRAST_VAL, ATMEL_LCDC_CVAL_DEFAULT); + + /* Set framebuffer DMA base address and pixel offset */ + lcdc_writel(panel_info.mmio, ATMEL_LCDC_DMABADDR1, (u_long)lcdbase); + + lcdc_writel(panel_info.mmio, ATMEL_LCDC_DMACON, ATMEL_LCDC_DMAEN); + lcdc_writel(panel_info.mmio, ATMEL_LCDC_PWRCON, + (1 << ATMEL_LCDC_GUARDT_OFFSET) | ATMEL_LCDC_PWR); +} + +ulong calc_fbsize (void) +{ + return ((panel_info.vl_col * panel_info.vl_row * + NBITS(panel_info.vl_bpix)) / 8) + PAGE_SIZE; +} diff --git a/include/asm-arm/arch-at91sam9/clk.h b/include/asm-arm/arch-at91sam9/clk.h index 86da9a6..7fd66c0 100644 --- a/include/asm-arm/arch-at91sam9/clk.h +++ b/include/asm-arm/arch-at91sam9/clk.h @@ -36,4 +36,10 @@ static inline unsigned long get_usart_clk_rate(unsigned int dev_id) return AT91_MASTER_CLOCK; }
+static inline unsigned long get_lcdc_clk_rate(unsigned int dev_id) +{ + return AT91_MASTER_CLOCK; +} + + #endif /* __ASM_ARM_ARCH_CLK_H__ */ diff --git a/include/atmel_lcdc.h b/include/atmel_lcdc.h new file mode 100644 index 0000000..73dd8f7 --- /dev/null +++ b/include/atmel_lcdc.h @@ -0,0 +1,177 @@ +/* + * Header file for AT91/AT32 LCD Controller + * + * Data structure and register user interface + * + * Copyright (C) 2007 Atmel Corporation + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ +#ifndef __ATMEL_LCDC_H__ +#define __ATMEL_LCDC_H__ + +#define ATMEL_LCDC_DMABADDR1 0x00 +#define ATMEL_LCDC_DMABADDR2 0x04 +#define ATMEL_LCDC_DMAFRMPT1 0x08 +#define ATMEL_LCDC_DMAFRMPT2 0x0c +#define ATMEL_LCDC_DMAFRMADD1 0x10 +#define ATMEL_LCDC_DMAFRMADD2 0x14 + +#define ATMEL_LCDC_DMAFRMCFG 0x18 +#define ATMEL_LCDC_FRSIZE (0x7fffff << 0) +#define ATMEL_LCDC_BLENGTH_OFFSET 24 +#define ATMEL_LCDC_BLENGTH (0x7f << ATMEL_LCDC_BLENGTH_OFFSET) + +#define ATMEL_LCDC_DMACON 0x1c +#define ATMEL_LCDC_DMAEN (0x1 << 0) +#define ATMEL_LCDC_DMARST (0x1 << 1) +#define ATMEL_LCDC_DMABUSY (0x1 << 2) +#define ATMEL_LCDC_DMAUPDT (0x1 << 3) +#define ATMEL_LCDC_DMA2DEN (0x1 << 4) + +#define ATMEL_LCDC_DMA2DCFG 0x20 +#define ATMEL_LCDC_ADDRINC_OFFSET 0 +#define ATMEL_LCDC_ADDRINC (0xffff) +#define ATMEL_LCDC_PIXELOFF_OFFSET 24 +#define ATMEL_LCDC_PIXELOFF (0x1f << 24) + +#define ATMEL_LCDC_LCDCON1 0x0800 +#define ATMEL_LCDC_BYPASS (1 << 0) +#define ATMEL_LCDC_CLKVAL_OFFSET 12 +#define ATMEL_LCDC_CLKVAL (0x1ff << ATMEL_LCDC_CLKVAL_OFFSET) +#define ATMEL_LCDC_LINCNT (0x7ff << 21) + +#define ATMEL_LCDC_LCDCON2 0x0804 +#define ATMEL_LCDC_DISTYPE (3 << 0) +#define ATMEL_LCDC_DISTYPE_STNMONO (0 << 0) +#define ATMEL_LCDC_DISTYPE_STNCOLOR (1 << 0) +#define ATMEL_LCDC_DISTYPE_TFT (2 << 0) +#define ATMEL_LCDC_SCANMOD (1 << 2) +#define ATMEL_LCDC_SCANMOD_SINGLE (0 << 2) +#define ATMEL_LCDC_SCANMOD_DUAL (1 << 2) +#define ATMEL_LCDC_IFWIDTH (3 << 3) +#define ATMEL_LCDC_IFWIDTH_4 (0 << 3) +#define ATMEL_LCDC_IFWIDTH_8 (1 << 3) +#define ATMEL_LCDC_IFWIDTH_16 (2 << 3) +#define ATMEL_LCDC_PIXELSIZE (7 << 5) +#define ATMEL_LCDC_PIXELSIZE_1 (0 << 5) +#define ATMEL_LCDC_PIXELSIZE_2 (1 << 5) +#define ATMEL_LCDC_PIXELSIZE_4 (2 << 5) +#define ATMEL_LCDC_PIXELSIZE_8 (3 << 5) +#define ATMEL_LCDC_PIXELSIZE_16 (4 << 5) +#define ATMEL_LCDC_PIXELSIZE_24 (5 << 5) +#define ATMEL_LCDC_PIXELSIZE_32 (6 << 5) +#define ATMEL_LCDC_INVVD (1 << 8) +#define ATMEL_LCDC_INVVD_NORMAL (0 << 8) +#define ATMEL_LCDC_INVVD_INVERTED (1 << 8) +#define ATMEL_LCDC_INVFRAME (1 << 9 ) +#define ATMEL_LCDC_INVFRAME_NORMAL (0 << 9) +#define ATMEL_LCDC_INVFRAME_INVERTED (1 << 9) +#define ATMEL_LCDC_INVLINE (1 << 10) +#define ATMEL_LCDC_INVLINE_NORMAL (0 << 10) +#define ATMEL_LCDC_INVLINE_INVERTED (1 << 10) +#define ATMEL_LCDC_INVCLK (1 << 11) +#define ATMEL_LCDC_INVCLK_NORMAL (0 << 11) +#define ATMEL_LCDC_INVCLK_INVERTED (1 << 11) +#define ATMEL_LCDC_INVDVAL (1 << 12) +#define ATMEL_LCDC_INVDVAL_NORMAL (0 << 12) +#define ATMEL_LCDC_INVDVAL_INVERTED (1 << 12) +#define ATMEL_LCDC_CLKMOD (1 << 15) +#define ATMEL_LCDC_CLKMOD_ACTIVEDISPLAY (0 << 15) +#define ATMEL_LCDC_CLKMOD_ALWAYSACTIVE (1 << 15) +#define ATMEL_LCDC_MEMOR (1 << 31) +#define ATMEL_LCDC_MEMOR_BIG (0 << 31) +#define ATMEL_LCDC_MEMOR_LITTLE (1 << 31) + +#define ATMEL_LCDC_TIM1 0x0808 +#define ATMEL_LCDC_VFP (0xffU << 0) +#define ATMEL_LCDC_VBP_OFFSET 8 +#define ATMEL_LCDC_VBP (0xffU << ATMEL_LCDC_VBP_OFFSET) +#define ATMEL_LCDC_VPW_OFFSET 16 +#define ATMEL_LCDC_VPW (0x3fU << ATMEL_LCDC_VPW_OFFSET) +#define ATMEL_LCDC_VHDLY_OFFSET 24 +#define ATMEL_LCDC_VHDLY (0xfU << ATMEL_LCDC_VHDLY_OFFSET) + +#define ATMEL_LCDC_TIM2 0x080c +#define ATMEL_LCDC_HBP (0xffU << 0) +#define ATMEL_LCDC_HPW_OFFSET 8 +#define ATMEL_LCDC_HPW (0x3fU << ATMEL_LCDC_HPW_OFFSET) +#define ATMEL_LCDC_HFP_OFFSET 21 +#define ATMEL_LCDC_HFP (0x7ffU << ATMEL_LCDC_HFP_OFFSET) + +#define ATMEL_LCDC_LCDFRMCFG 0x0810 +#define ATMEL_LCDC_LINEVAL (0x7ff << 0) +#define ATMEL_LCDC_HOZVAL_OFFSET 21 +#define ATMEL_LCDC_HOZVAL (0x7ff << ATMEL_LCDC_HOZVAL_OFFSET) + +#define ATMEL_LCDC_FIFO 0x0814 +#define ATMEL_LCDC_FIFOTH (0xffff) + +#define ATMEL_LCDC_MVAL 0x0818 + +#define ATMEL_LCDC_DP1_2 0x081c +#define ATMEL_LCDC_DP4_7 0x0820 +#define ATMEL_LCDC_DP3_5 0x0824 +#define ATMEL_LCDC_DP2_3 0x0828 +#define ATMEL_LCDC_DP5_7 0x082c +#define ATMEL_LCDC_DP3_4 0x0830 +#define ATMEL_LCDC_DP4_5 0x0834 +#define ATMEL_LCDC_DP6_7 0x0838 +#define ATMEL_LCDC_DP1_2_VAL (0xff) +#define ATMEL_LCDC_DP4_7_VAL (0xfffffff) +#define ATMEL_LCDC_DP3_5_VAL (0xfffff) +#define ATMEL_LCDC_DP2_3_VAL (0xfff) +#define ATMEL_LCDC_DP5_7_VAL (0xfffffff) +#define ATMEL_LCDC_DP3_4_VAL (0xffff) +#define ATMEL_LCDC_DP4_5_VAL (0xfffff) +#define ATMEL_LCDC_DP6_7_VAL (0xfffffff) + +#define ATMEL_LCDC_PWRCON 0x083c +#define ATMEL_LCDC_PWR (1 << 0) +#define ATMEL_LCDC_GUARDT_OFFSET 1 +#define ATMEL_LCDC_GUARDT (0x7f << ATMEL_LCDC_GUARDT_OFFSET) +#define ATMEL_LCDC_BUSY (1 << 31) + +#define ATMEL_LCDC_CONTRAST_CTR 0x0840 +#define ATMEL_LCDC_PS (3 << 0) +#define ATMEL_LCDC_PS_DIV1 (0 << 0) +#define ATMEL_LCDC_PS_DIV2 (1 << 0) +#define ATMEL_LCDC_PS_DIV4 (2 << 0) +#define ATMEL_LCDC_PS_DIV8 (3 << 0) +#define ATMEL_LCDC_POL (1 << 2) +#define ATMEL_LCDC_POL_NEGATIVE (0 << 2) +#define ATMEL_LCDC_POL_POSITIVE (1 << 2) +#define ATMEL_LCDC_ENA (1 << 3) +#define ATMEL_LCDC_ENA_PWMDISABLE (0 << 3) +#define ATMEL_LCDC_ENA_PWMENABLE (1 << 3) + +#define ATMEL_LCDC_CONTRAST_VAL 0x0844 +#define ATMEL_LCDC_CVAL (0xff) + +#define ATMEL_LCDC_IER 0x0848 +#define ATMEL_LCDC_IDR 0x084c +#define ATMEL_LCDC_IMR 0x0850 +#define ATMEL_LCDC_ISR 0x0854 +#define ATMEL_LCDC_ICR 0x0858 +#define ATMEL_LCDC_LNI (1 << 0) +#define ATMEL_LCDC_LSTLNI (1 << 1) +#define ATMEL_LCDC_EOFI (1 << 2) +#define ATMEL_LCDC_UFLWI (1 << 4) +#define ATMEL_LCDC_OWRI (1 << 5) +#define ATMEL_LCDC_MERI (1 << 6) + +#define ATMEL_LCDC_LUT(n) (0x0c00 + ((n)*4)) + +#endif /* __ATMEL_LCDC_H__ */ diff --git a/include/lcd.h b/include/lcd.h index 8a4273c..44ac8ef 100644 --- a/include/lcd.h +++ b/include/lcd.h @@ -155,7 +155,35 @@ typedef struct vidinfo {
u_char vl_bpix; /* Bits per pixel, 0 = 1 */ } vidinfo_t; -#endif /* CONFIG_MPC823, CONFIG_PXA250 or CONFIG_MCC200 */ + +#elif defined(CONFIG_ATMEL_LCD) + +typedef struct vidinfo { + u_long vl_col; /* Number of columns (i.e. 640) */ + u_long vl_row; /* Number of rows (i.e. 480) */ + u_long vl_clk; /* pixel clock in ps */ + + /* LCD configuration register */ + u_long vl_sync; /* Horizontal / vertical sync */ + u_long vl_bpix; /* Bits per pixel, 0 = 1, 1 = 2, 2 = 4, 3 = 8, 4 = 16 */ + u_long vl_tft; /* 0 = passive, 1 = TFT */ + + /* Horizontal control register. */ + u_long vl_hsync_len; /* Length of horizontal sync */ + u_long vl_left_margin; /* Time from sync to picture */ + u_long vl_right_margin; /* Time from picture to sync */ + + /* Vertical control register. */ + u_long vl_vsync_len; /* Length of vertical sync */ + u_long vl_upper_margin; /* Time from sync to picture */ + u_long vl_lower_margin; /* Time from picture to sync */ + + u_long mmio; /* Memory mapped registers */ +} vidinfo_t; + +extern vidinfo_t panel_info; + +#endif /* CONFIG_MPC823, CONFIG_PXA250 or CONFIG_MCC200 or CONFIG_ATMEL_LCD */
/* Video functions */
diff --git a/lib_arm/board.c b/lib_arm/board.c index 0752877..265591b 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -121,6 +121,20 @@ void *sbrk (ptrdiff_t increment) return ((void *) old); }
+char *strmhz (char *buf, long hz) +{ + long l, n; + long m; + + n = hz / 1000000L; + l = sprintf (buf, "%ld", n); + m = (hz % 1000000L) / 1000L; + if (m != 0) + sprintf (buf + l, ".%03ld", m); + return (buf); +} + + /************************************************************************ * Coloured LED functionality ************************************************************************ @@ -325,16 +339,19 @@ void start_armboot (void) #endif /* CONFIG_VFD */
#ifdef CONFIG_LCD -# ifndef PAGE_SIZE -# define PAGE_SIZE 4096 -# endif - /* - * reserve memory for LCD display (always full pages) - */ - /* bss_end is defined in the board-specific linker script */ - addr = (_bss_end + (PAGE_SIZE - 1)) & ~(PAGE_SIZE - 1); - size = lcd_setmem (addr); - gd->fb_base = addr; + /* board init may have inited fb_base */ + if (!gd->fb_base) { +# ifndef PAGE_SIZE +# define PAGE_SIZE 4096 +# endif + /* + * reserve memory for LCD display (always full pages) + */ + /* bss_end is defined in the board-specific linker script */ + addr = (_bss_end + (PAGE_SIZE - 1)) & ~(PAGE_SIZE - 1); + size = lcd_setmem (addr); + gd->fb_base = addr; + } #endif /* CONFIG_LCD */
/* armboot_start is defined in the board-specific linker script */
Signed-off-by: Stelian Pop stelian@popies.net --- board/atmel/at91cap9adk/at91cap9adk.c | 64 +++++++++++++++++++++++++++++++++ include/configs/at91cap9adk.h | 13 +++++++ 2 files changed, 77 insertions(+), 0 deletions(-)
diff --git a/board/atmel/at91cap9adk/at91cap9adk.c b/board/atmel/at91cap9adk/at91cap9adk.c index ab56f3a..ee4f26e 100644 --- a/board/atmel/at91cap9adk/at91cap9adk.c +++ b/board/atmel/at91cap9adk/at91cap9adk.c @@ -30,6 +30,8 @@ #include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <asm/arch/io.h> +#include <lcd.h> +#include <atmel_lcdc.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <net.h> #endif @@ -233,6 +235,65 @@ static void at91cap9_uhp_hw_init(void) } #endif
+#ifdef CONFIG_LCD +vidinfo_t panel_info = { + vl_col: 240, + vl_row: 320, + vl_clk: 4965000, + vl_sync: ATMEL_LCDC_INVLINE_INVERTED | + ATMEL_LCDC_INVFRAME_INVERTED, + vl_bpix: 3, + vl_tft: 1, + vl_hsync_len: 5, + vl_left_margin: 1, + vl_right_margin:33, + vl_vsync_len: 1, + vl_upper_margin:1, + vl_lower_margin:0, + mmio: AT91CAP9_LCDC_BASE, +}; + +void lcd_enable(void) +{ + at91_set_gpio_value(AT91_PIN_PC0, 0); /* power up */ +} + +void lcd_disable(void) +{ + at91_set_gpio_value(AT91_PIN_PC0, 1); /* power down */ +} + +static void at91cap9_lcd_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PC1, 0); /* LCDHSYNC */ + at91_set_A_periph(AT91_PIN_PC2, 0); /* LCDDOTCK */ + at91_set_A_periph(AT91_PIN_PC3, 0); /* LCDDEN */ + at91_set_B_periph(AT91_PIN_PB9, 0); /* LCDCC */ + at91_set_A_periph(AT91_PIN_PC6, 0); /* LCDD2 */ + at91_set_A_periph(AT91_PIN_PC7, 0); /* LCDD3 */ + at91_set_A_periph(AT91_PIN_PC8, 0); /* LCDD4 */ + at91_set_A_periph(AT91_PIN_PC9, 0); /* LCDD5 */ + at91_set_A_periph(AT91_PIN_PC10, 0); /* LCDD6 */ + at91_set_A_periph(AT91_PIN_PC11, 0); /* LCDD7 */ + at91_set_A_periph(AT91_PIN_PC14, 0); /* LCDD10 */ + at91_set_A_periph(AT91_PIN_PC15, 0); /* LCDD11 */ + at91_set_A_periph(AT91_PIN_PC16, 0); /* LCDD12 */ + at91_set_A_periph(AT91_PIN_PC17, 0); /* LCDD13 */ + at91_set_A_periph(AT91_PIN_PC18, 0); /* LCDD14 */ + at91_set_A_periph(AT91_PIN_PC19, 0); /* LCDD15 */ + at91_set_A_periph(AT91_PIN_PC22, 0); /* LCDD18 */ + at91_set_A_periph(AT91_PIN_PC23, 0); /* LCDD19 */ + at91_set_A_periph(AT91_PIN_PC24, 0); /* LCDD20 */ + at91_set_A_periph(AT91_PIN_PC25, 0); /* LCDD21 */ + at91_set_A_periph(AT91_PIN_PC26, 0); /* LCDD22 */ + at91_set_A_periph(AT91_PIN_PC27, 0); /* LCDD23 */ + + at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_LCDC); + + gd->fb_base = 0; +} +#endif + int board_init(void) { /* Enable Ctrlc */ @@ -257,6 +318,9 @@ int board_init(void) #ifdef CONFIG_USB_OHCI_NEW at91cap9_uhp_hw_init(); #endif +#ifdef CONFIG_LCD + at91cap9_lcd_hw_init(); +#endif return 0; }
diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index ec70618..82c2039 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -28,6 +28,7 @@ #define __CONFIG_H
/* ARM asynchronous clock */ +#define AT91_CPU_NAME "AT91CAP9" #define AT91_MAIN_CLOCK 200000000 /* from 12 MHz crystal */ #define AT91_MASTER_CLOCK 100000000 /* peripheral = main / 2 */ #define CFG_HZ 1000000 /* 1us resolution */ @@ -55,6 +56,18 @@ #undef CONFIG_USART2 #define CONFIG_USART3 1 /* USART 3 is DBGU */
+/* LCD */ +#define CONFIG_LCD 1 +#define LCD_BPP LCD_COLOR8 +#define CONFIG_LCD_LOGO 1 +#undef LCD_TEST_PATTERN +#define CONFIG_LCD_INFO 1 +#define CONFIG_LCD_INFO_BELOW_LOGO 1 +#define CFG_WHITE_ON_BLACK 1 +#define CONFIG_ATMEL_LCD 1 +#define CONFIG_ATMEL_LCD_BGR555 1 +#define CFG_CONSOLE_IS_IN_ENV 1 + #define CONFIG_BOOTDELAY 3
Signed-off-by: Stelian Pop stelian@popies.net --- board/atmel/at91sam9261ek/at91sam9261ek.c | 64 +++++++++++++++++++++++++++++ include/configs/at91sam9261ek.h | 13 ++++++ 2 files changed, 77 insertions(+), 0 deletions(-)
diff --git a/board/atmel/at91sam9261ek/at91sam9261ek.c b/board/atmel/at91sam9261ek/at91sam9261ek.c index 55a178e..d6ad15f 100644 --- a/board/atmel/at91sam9261ek/at91sam9261ek.c +++ b/board/atmel/at91sam9261ek/at91sam9261ek.c @@ -30,6 +30,8 @@ #include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <asm/arch/io.h> +#include <lcd.h> +#include <atmel_lcdc.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_DRIVER_DM9000) #include <net.h> #endif @@ -150,6 +152,65 @@ static void at91sam9261ek_dm9000_hw_init(void) } #endif
+#ifdef CONFIG_LCD +vidinfo_t panel_info = { + vl_col: 240, + vl_row: 320, + vl_clk: 4965000, + vl_sync: ATMEL_LCDC_INVLINE_INVERTED | + ATMEL_LCDC_INVFRAME_INVERTED, + vl_bpix: 3, + vl_tft: 1, + vl_hsync_len: 5, + vl_left_margin: 1, + vl_right_margin:33, + vl_vsync_len: 1, + vl_upper_margin:1, + vl_lower_margin:0, + mmio: AT91SAM9261_LCDC_BASE, +}; + +void lcd_enable(void) +{ + at91_set_gpio_value(AT91_PIN_PA12, 0); /* power up */ +} + +void lcd_disable(void) +{ + at91_set_gpio_value(AT91_PIN_PA12, 1); /* power down */ +} + +static void at91sam9261ek_lcd_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PB1, 0); /* LCDHSYNC */ + at91_set_A_periph(AT91_PIN_PB2, 0); /* LCDDOTCK */ + at91_set_A_periph(AT91_PIN_PB3, 0); /* LCDDEN */ + at91_set_A_periph(AT91_PIN_PB4, 0); /* LCDCC */ + at91_set_A_periph(AT91_PIN_PB7, 0); /* LCDD2 */ + at91_set_A_periph(AT91_PIN_PB8, 0); /* LCDD3 */ + at91_set_A_periph(AT91_PIN_PB9, 0); /* LCDD4 */ + at91_set_A_periph(AT91_PIN_PB10, 0); /* LCDD5 */ + at91_set_A_periph(AT91_PIN_PB11, 0); /* LCDD6 */ + at91_set_A_periph(AT91_PIN_PB12, 0); /* LCDD7 */ + at91_set_A_periph(AT91_PIN_PB15, 0); /* LCDD10 */ + at91_set_A_periph(AT91_PIN_PB16, 0); /* LCDD11 */ + at91_set_A_periph(AT91_PIN_PB17, 0); /* LCDD12 */ + at91_set_A_periph(AT91_PIN_PB18, 0); /* LCDD13 */ + at91_set_A_periph(AT91_PIN_PB19, 0); /* LCDD14 */ + at91_set_A_periph(AT91_PIN_PB20, 0); /* LCDD15 */ + at91_set_B_periph(AT91_PIN_PB23, 0); /* LCDD18 */ + at91_set_B_periph(AT91_PIN_PB24, 0); /* LCDD19 */ + at91_set_B_periph(AT91_PIN_PB25, 0); /* LCDD20 */ + at91_set_B_periph(AT91_PIN_PB26, 0); /* LCDD21 */ + at91_set_B_periph(AT91_PIN_PB27, 0); /* LCDD22 */ + at91_set_B_periph(AT91_PIN_PB28, 0); /* LCDD23 */ + + at91_sys_write(AT91_PMC_SCER, AT91_PMC_HCK1); + + gd->fb_base = AT91SAM9261_SRAM_BASE; +} +#endif + int board_init(void) { /* Enable Ctrlc */ @@ -170,6 +231,9 @@ int board_init(void) #ifdef CONFIG_DRIVER_DM9000 at91sam9261ek_dm9000_hw_init(); #endif +#ifdef CONFIG_LCD + at91sam9261ek_lcd_hw_init(); +#endif return 0; }
diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index cdafed3..6a40853 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -28,6 +28,7 @@ #define __CONFIG_H
/* ARM asynchronous clock */ +#define AT91_CPU_NAME "AT91SAM9261" #define AT91_MAIN_CLOCK 198656000 /* from 18.432 MHz crystal */ #define AT91_MASTER_CLOCK 99328000 /* peripheral = main / 2 */ #define CFG_HZ 1000000 /* 1us resolution */ @@ -55,6 +56,18 @@ #undef CONFIG_USART2 #define CONFIG_USART3 1 /* USART 3 is DBGU */
Signed-off-by: Stelian Pop stelian@popies.net --- board/atmel/at91sam9263ek/at91sam9263ek.c | 65 +++++++++++++++++++++++++++++ include/configs/at91sam9263ek.h | 13 ++++++ 2 files changed, 78 insertions(+), 0 deletions(-)
diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c index ee6b69f..ba152d2 100644 --- a/board/atmel/at91sam9263ek/at91sam9263ek.c +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -23,6 +23,7 @@ */
#include <common.h> +#include <asm/sizes.h> #include <asm/arch/at91sam9263.h> #include <asm/arch/at91sam9263_matrix.h> #include <asm/arch/at91sam926x_mc.h> @@ -30,6 +31,8 @@ #include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <asm/arch/io.h> +#include <lcd.h> +#include <atmel_lcdc.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <net.h> #endif @@ -193,6 +196,65 @@ static void at91sam9263ek_uhp_hw_init(void) } #endif
+#ifdef CONFIG_LCD +vidinfo_t panel_info = { + vl_col: 240, + vl_row: 320, + vl_clk: 4965000, + vl_sync: ATMEL_LCDC_INVLINE_INVERTED | + ATMEL_LCDC_INVFRAME_INVERTED, + vl_bpix: 3, + vl_tft: 1, + vl_hsync_len: 5, + vl_left_margin: 1, + vl_right_margin:33, + vl_vsync_len: 1, + vl_upper_margin:1, + vl_lower_margin:0, + mmio: AT91SAM9263_LCDC_BASE, +}; + +void lcd_enable(void) +{ + at91_set_gpio_value(AT91_PIN_PA30, 1); /* power up */ +} + +void lcd_disable(void) +{ + at91_set_gpio_value(AT91_PIN_PA30, 0); /* power down */ +} + +static void at91sam9263ek_lcd_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PC1, 0); /* LCDHSYNC */ + at91_set_A_periph(AT91_PIN_PC2, 0); /* LCDDOTCK */ + at91_set_A_periph(AT91_PIN_PC3, 0); /* LCDDEN */ + at91_set_B_periph(AT91_PIN_PB9, 0); /* LCDCC */ + at91_set_A_periph(AT91_PIN_PC6, 0); /* LCDD2 */ + at91_set_A_periph(AT91_PIN_PC7, 0); /* LCDD3 */ + at91_set_A_periph(AT91_PIN_PC8, 0); /* LCDD4 */ + at91_set_A_periph(AT91_PIN_PC9, 0); /* LCDD5 */ + at91_set_A_periph(AT91_PIN_PC10, 0); /* LCDD6 */ + at91_set_A_periph(AT91_PIN_PC11, 0); /* LCDD7 */ + at91_set_A_periph(AT91_PIN_PC14, 0); /* LCDD10 */ + at91_set_A_periph(AT91_PIN_PC15, 0); /* LCDD11 */ + at91_set_A_periph(AT91_PIN_PC16, 0); /* LCDD12 */ + at91_set_B_periph(AT91_PIN_PC12, 0); /* LCDD13 */ + at91_set_A_periph(AT91_PIN_PC18, 0); /* LCDD14 */ + at91_set_A_periph(AT91_PIN_PC19, 0); /* LCDD15 */ + at91_set_A_periph(AT91_PIN_PC22, 0); /* LCDD18 */ + at91_set_A_periph(AT91_PIN_PC23, 0); /* LCDD19 */ + at91_set_A_periph(AT91_PIN_PC24, 0); /* LCDD20 */ + at91_set_B_periph(AT91_PIN_PC17, 0); /* LCDD21 */ + at91_set_A_periph(AT91_PIN_PC26, 0); /* LCDD22 */ + at91_set_A_periph(AT91_PIN_PC27, 0); /* LCDD23 */ + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_LCDC); + + gd->fb_base = AT91SAM9263_SRAM0_BASE; +} +#endif + int board_init(void) { /* Enable Ctrlc */ @@ -216,6 +278,9 @@ int board_init(void) #ifdef CONFIG_USB_OHCI_NEW at91sam9263ek_uhp_hw_init(); #endif +#ifdef CONFIG_LCD + at91sam9263ek_lcd_hw_init(); +#endif return 0; }
diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index e2ffbbe..ae574d7 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -28,6 +28,7 @@ #define __CONFIG_H
/* ARM asynchronous clock */ +#define AT91_CPU_NAME "AT91SAM9263" #define AT91_MAIN_CLOCK 199919000 /* from 16.367 MHz crystal */ #define AT91_MASTER_CLOCK 99959500 /* peripheral = main / 2 */ #define CFG_HZ 1000000 /* 1us resolution */ @@ -55,6 +56,18 @@ #undef CONFIG_USART2 #define CONFIG_USART3 1 /* USART 3 is DBGU */
Signed-off-by: Stelian Pop stelian@popies.net --- board/atmel/at91sam9rlek/at91sam9rlek.c | 63 +++++++++++++++++++++++++++++++ include/configs/at91sam9rlek.h | 13 ++++++ 2 files changed, 76 insertions(+), 0 deletions(-)
diff --git a/board/atmel/at91sam9rlek/at91sam9rlek.c b/board/atmel/at91sam9rlek/at91sam9rlek.c index 488489c..1538bf1 100644 --- a/board/atmel/at91sam9rlek/at91sam9rlek.c +++ b/board/atmel/at91sam9rlek/at91sam9rlek.c @@ -30,6 +30,8 @@ #include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <asm/arch/io.h> +#include <lcd.h> +#include <atmel_lcdc.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <net.h> #endif @@ -124,6 +126,64 @@ static void at91sam9rlek_spi_hw_init(void) } #endif
+#ifdef CONFIG_LCD +vidinfo_t panel_info = { + vl_col: 240, + vl_row: 320, + vl_clk: 4965000, + vl_sync: ATMEL_LCDC_INVLINE_INVERTED | + ATMEL_LCDC_INVFRAME_INVERTED, + vl_bpix: 3, + vl_tft: 1, + vl_hsync_len: 5, + vl_left_margin: 1, + vl_right_margin:33, + vl_vsync_len: 1, + vl_upper_margin:1, + vl_lower_margin:0, + mmio: AT91SAM9RL_LCDC_BASE, +}; + +void lcd_enable(void) +{ + at91_set_gpio_value(AT91_PIN_PA30, 0); /* power up */ +} + +void lcd_disable(void) +{ + at91_set_gpio_value(AT91_PIN_PA30, 1); /* power down */ +} +static void at91sam9rlek_lcd_hw_init(void) +{ + at91_set_B_periph(AT91_PIN_PC1, 0); /* LCDPWR */ + at91_set_A_periph(AT91_PIN_PC5, 0); /* LCDHSYNC */ + at91_set_A_periph(AT91_PIN_PC6, 0); /* LCDDOTCK */ + at91_set_A_periph(AT91_PIN_PC7, 0); /* LCDDEN */ + at91_set_A_periph(AT91_PIN_PC3, 0); /* LCDCC */ + at91_set_B_periph(AT91_PIN_PC9, 0); /* LCDD3 */ + at91_set_B_periph(AT91_PIN_PC10, 0); /* LCDD4 */ + at91_set_B_periph(AT91_PIN_PC11, 0); /* LCDD5 */ + at91_set_B_periph(AT91_PIN_PC12, 0); /* LCDD6 */ + at91_set_B_periph(AT91_PIN_PC13, 0); /* LCDD7 */ + at91_set_B_periph(AT91_PIN_PC15, 0); /* LCDD11 */ + at91_set_B_periph(AT91_PIN_PC16, 0); /* LCDD12 */ + at91_set_B_periph(AT91_PIN_PC17, 0); /* LCDD13 */ + at91_set_B_periph(AT91_PIN_PC18, 0); /* LCDD14 */ + at91_set_B_periph(AT91_PIN_PC19, 0); /* LCDD15 */ + at91_set_B_periph(AT91_PIN_PC20, 0); /* LCDD18 */ + at91_set_B_periph(AT91_PIN_PC21, 0); /* LCDD19 */ + at91_set_B_periph(AT91_PIN_PC22, 0); /* LCDD20 */ + at91_set_B_periph(AT91_PIN_PC23, 0); /* LCDD21 */ + at91_set_B_periph(AT91_PIN_PC24, 0); /* LCDD22 */ + at91_set_B_periph(AT91_PIN_PC25, 0); /* LCDD23 */ + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_LCDC); + + gd->fb_base = 0; +} +#endif + + int board_init(void) { /* Enable Ctrlc */ @@ -141,6 +201,9 @@ int board_init(void) #ifdef CONFIG_HAS_DATAFLASH at91sam9rlek_spi_hw_init(); #endif +#ifdef CONFIG_LCD + at91sam9rlek_lcd_hw_init(); +#endif return 0; }
diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index acf5d81..fac26a9 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -28,6 +28,7 @@ #define __CONFIG_H
/* ARM asynchronous clock */ +#define AT91_CPU_NAME "AT91SAM9RL" #define AT91_MAIN_CLOCK 200000000 /* from 12.000 MHz crystal */ #define AT91_MASTER_CLOCK 100000000 /* peripheral = main / 2 */ #define CFG_HZ 1000000 /* 1us resolution */ @@ -55,6 +56,18 @@ #undef CONFIG_USART2 #define CONFIG_USART3 1 /* USART 3 is DBGU */
+/* LCD */ +#define CONFIG_LCD 1 +#define LCD_BPP LCD_COLOR8 +#define CONFIG_LCD_LOGO 1 +#undef LCD_TEST_PATTERN +#define CONFIG_LCD_INFO 1 +#define CONFIG_LCD_INFO_BELOW_LOGO 1 +#define CFG_WHITE_ON_BLACK 1 +#define CONFIG_ATMEL_LCD 1 +#define CONFIG_ATMEL_LCD_RGB565 1 +#define CFG_CONSOLE_IS_IN_ENV 1 + #define CONFIG_BOOTDELAY 3
Signed-off-by: Stelian Pop stelian@popies.net --- tools/Makefile | 4 ++++ tools/logos/atmel.bmp | Bin 0 -> 26334 bytes 2 files changed, 4 insertions(+), 0 deletions(-) create mode 100644 tools/logos/atmel.bmp
diff --git a/tools/Makefile b/tools/Makefile index b897923..dc210e8 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -44,6 +44,10 @@ LOGO_H = $(OBJTREE)/include/bmp_logo.h ifeq ($(LOGO_BMP),) LOGO_BMP= logos/denx.bmp endif +ifeq ($(VENDOR),atmel) +LOGO_BMP= logos/atmel.bmp +endif +
diff --git a/tools/logos/atmel.bmp b/tools/logos/atmel.bmp new file mode 100644 index 0000000000000000000000000000000000000000..3c445c9bc365aff31bf5f6c464ab2b1d7a99e99e GIT binary patch literal 26334 zcmd^{y^my9TE?%dt6b%2x9uH|y<;yXT%jdF1c(rkZ_IzN85^tsi3E`mZc2iL$dC{T z(gqfCzy>Qs0xN`&kQNdoKEy`?!Ae;Ce$R8xty|qao^D4T&FQJCbI*Ct^M1eQ+}qXj ztKa^~cb2q2<^AV){Wq^)=k>;N;(b|uf%zXk>FZ~?_VxMapD+LQk3U{M{q8q;eQWu@ z&wsl7l(8TE-nW;}xc-dsfBTzHmmmJluPmQ_@0-g%{rMj(KVa;C|MOp#&wle4m%snx z-(CLaUw^{f&o6)d``=mq<L~}r`R5<~$?}sw`~LE`fA|~AXW#qQ@>k#gwdJ$l`laRH z|KTr}AOF#JmmmK2FE7WdEB?`TJKx*qs+}W)ba(kVI=ee{2-?%h6%IL_<yWU59FGIj z)#);_8&iA)#N|60YiyEr74P8->e0DfudYOzat#uNnUXu}uohkpdtQfS*)K3q0lIrf z!-BUkMe;UblrV5~Ga8lX=E|8laa7G<WXgrL(rMKtfG$u$5zZh|BeSf9apDv`=+KTQ z#O)|c(cQ&bVnX^k#1GOZQMei}`>VsUNAUyJWnA^;q^-m16l2;Q*zG!thzbk4aDtNV zDe^NdQ{>Rqe)29v^$tyzX3-V|Wr|pER}6ot8t{dX=k$eAgn_g+#h3yp(+8-v$CZb} zet)Bmcoui>uZDliO1wl1dcY=8tjv|1z=~n31U7e=H}r=*Y<JSgewYBMw9$ZY!PI1e zWLYFVDQ7ju{^`fU_FPCSg>wLpp=1<dI7g1~37eyi#H*@FcZY|U1Iw4?W`9`1r0Z2J zmq8n#QAz=$o70;No;KI5&fA8mE1qLY!T6BH-UNxbTBin+tdiJ?F^yYR01^1;btVx! zp+6*dh7{U;h`RnP=(rqrXt{^WA=NYa5Fx@eX~boO4;MkF9PymOOo}-{21n0TS>@A8 zcQbef`%n#RMr4TSu~w{e+N7`<oai!p=;&XTj0|>8aVkDtNX%6Ii@t}eo#_h!`d^_q zjG`p;afB(BD0N{%1py+Je$kJE!x53_&J3>nGlQc;*MTRGu{4X$ASp*hEO=y>nzqT{ z@Qg~Gd0_@8(!QSJyr)?0Q4sCPwUgmZy?V{`jniscL!w!WIdraWt#j#)iiIyUek+z< zOf1y$+lnR8tXKo6L%y#d_PruZ62|fL%PZCpQ!z{e0@Br1EMt|vRoVFE{psl%IiSMl zJN;XJ@-$ezOn>Um_0V125D4krCTf|cjl3+*S<X-Z28?472izoz941J_HP~w~7nZs2 zF{XJ+ABeJN!u)kQ6tY&Dux>(PypK@MFeY{74e9kY1ME&*49Pt;2s~Ivcq9xP(88m@ za+0+AwF~ODVrg?tl8P0?5f?7Y?s)+MvC#6?KY_fcSd^@YnTlmu(HgB-$`Wmd;G(o* z?RV6y-4UfvH#>aG4$OXpT$58-SyB?EP8ll<2T?ibF*j9xSjCFsdcdXFMLTRk0xO4% zM|OR#2@pj0*^}q=g;24YQ#NKBR^7dKoYwK@(HBY|JVq{iFAWYZ%1S(eeP1)!smz<f z&gR+-)+@YX8}lg3Bu1+W41KIs2<es7_W{yi<tiCmL7+hDh|$$^jmDC2-JirEg~QLe zu^YPyzNNl9Yce4b$?<K@&y`OJXceY?t}@2dh)qcK3$iw6%HDM}!zjvX>L66SV4gEL zjy;3qD64T|udJI)%U6!WmVpmw1%oh7-efQ$-&nn_-z9ys;YPL_Zq)XNBULQ&R~m#U z@JQj2*g9H0qk?+vuFqE*YslmB7<pW;8H_UVY+V`{#4Jd36J+`xqv4(oZ!*|$s`<0u zH-n`e4pO4nxo;To?HoA>Vba%#j`D`L)?r>H`PX7$1{)QX6KkSKq~cS)$Wumyy|T&I z5WXf5={Um6PH=a}YgW0!w~@gG37z^$oXi$ED?wlZU4zLUuMq~2-0ZGmGH8>t%v$O| z7YzD1c)2>}*3dfTJwpby!2M0y(p=1EbK8vMo=ZBByffL%rF&<9(c5Iu#0`1pV00Vf z&b7kP#J-1kOcKF*@x;y2B$oc31>hVifP|L~^6k_<7s2pGY&(SoWOWa|V_jHm^|j}4 z-c;np4H|fbxH{iQ%6wE)A_WmLO!C3<cuG^)fp+%Lyz=zMGNJ@&%O#`Rf%L_{XQs?o z_H)_r!@PXq=U`sod*O4NUmXc0=%XlXyEOjB1}f<X7+S^2z(F6<IMBH)AM!{sj7K;0 zW2TGl6Pxu;o~O6~BLiY>QO-o|l`t+)5e2>56n%P(S!ft}{q#+)Y|OkG%CUs_I<j^c zwgl3wq||cDItLlHc*}1qqy?KxVZ1G~x?29z^Da%0ff6Ln5rWVJq2{O5rsjsug(C1q zmnxKpHMs+5ZD!xdItl3Sc5e=WtDRAB_yh!D3PvAZE^^Z~YS^)|!!Yj*Q`~*9a?jRd z>&}18dHnQTy`HltaYI5I=R3CnaI)EiQ&gTH0|nvP%&vFOkIxNG>Z$8Bmj-pe?56JS zq@*6IAc#80r@L#`JDvsh+#J>F8}Rm@dW@#Ma}Gmti8y?@`^pFT3HJyoTFn3oe&n3C zwjjII9VTS!lm;rF1VS;G1?oN!CAPL?$1UG`&m7r>#V|kFlTmkQ47R<~)lF^{KT#x{ z6USAMH&;Xy)+~xoD4lkv+C`&fs*dMyHyj3C8qVlWuNjeI?D&QXZKrp~IZg*K$V)TC z>xE#EN#IgJ8XByx&hb_b9YzxXIaM(VF2^Q4Mng}@UCYn&^p9^@qvGM!#ZR*yYy^Z5 z<@k34n#WCu<;vnY1wYrH{VO}n!*Q&`;FO$U^@Af-xY{e($lyy51x5}cOD`yEtP-f$ z*-WYdxjZ4WqtdEx$h3LxPmFXl0N}KHDh2FSI_<E0bYyM?W3_c7ZZ-;d2&ASRP&4?l znp?`*w0WDMi0Ri>H<gbzK%3AegD*i0NnH<k+zuT!WJs2E!8wCfJoj&b)}>J~<|qiO zj2DiaZ|ejjY-&uXsjjjixw0Zu9)NheNQ;P2$hjX8HNtUia|)}kqINXzJonAX0vZE> zR!<u|Jbc)oj9IHF!m4RGuleR$v{1flbu@oz_$TT*QapQR@bQ`sNvW>-&c?@kz@$Va zo)zADk@WBcpb5NGUh9t`$I)P#0cwpcC*T}Tboo}z&hea)P(odh4GKcEyb(KR<Ceg? z5rsk{2fS@?!%4l0xs@U|V7eKcKm+qV414x2${&_@k2l<HAgIb{Rb<i<4S~!!%9M)N ztov~2n~rm>Yaj}QZ?2)>CX`$*l6FZ3YwRsZp;Dg>saRG6i;^q4t7_g6b18<K*I;G_ zlX^_-PB+vOuWuw8zLh#Ul_v7&+dL0gPnBSRH!>I+BGmeBi5e|7cid3KR_CUv&+#m_ zV3A+{vbUd68ifHFp*%8JCA2f6iP>DLyZ&vyF>aBHHMQtyR^8qE5Rp4mXHT$Cgpi5z zSw_6MZE20U7&N*XFGhm+3~Y3@T*h?gCG^Uw@^(c$t+Ca21Cr=sbdQ+;k3>Ro5ZOJw z_J_PpWm8;;f`JuHKh#xYF<8lT8oo=Kg|crdUR~7LFlcGZCe0*|_G}SG5d<KARZ;x5 z2oR5HHYOTkssp@!k7|r+Cv?PUf<(Ltf|l;Tp0A|nKZVH>Q#RI7<2*p%fP+JPUNIZ8 ztHN0@R-E39>xO?xE_!di36W?(g2tz(CFVT8Wc5%&Nt)YXJ^3h~o*Wsu(U<dcZeO&0 z#dRU^gc;cDE>OfcTAy8?7Oxp}7y?g35?MLU%kaZE>kqyPmmKJ0R>+Q?DjQ_s`FiP# zHCsQ;m^dJ=!lq`2K~P)cSY68`5o$~%G@B&uW;W@GlkJfMC)BirjritT@?aD_eKSE! zB>kTIh4`9-0rB}%iQ-y($|piFay&jIRg7mNGEwO#&jAyvuCKVetB1xs@NzYV|(4 zHg1#$<!-#&vZ^JSvb+Gz-<aVd8ZB{d%W~Z|_08>tVro?y%o1YlZm0vYU@^v^w;*R( zZ4|ZLrHyT9BDs;CXO7Tj3t}y??72xwu1+8H%n^Ozn>2Vj<6TPS=ocP1Z;a)#XBe4T zhhmP`>dK2iCvhUDbn6eJSPfwyVX+gk3UmCq1z{@R=#ff2jfrbcNwUGULw(sfyYr#4 z{;dr&thL2g)eb;;)rZklSL1smcyEN3i!JsdHqwVg&PNYRjrCcQwIR9jyl3+dr?bBJ z7kwLbioz0J%@!5kfWRRjElgaLIND>|(B>i&Cuq?Z&zzaDd0`cA*lb~@(Tw1>SU;EV z`pDT<c>8X_2QOnTGdL{KYduKK<P%yyMwyEYh64?dk-51cs9y@qASZ2Bjb&ClL*{ z0#w}j9#1qaS6EoPm2&&viPGXtU3#bO-_DuRh=Um)CWTZe9&^SPQHR0xi%e(l9J`f3 zejalT)MQLn*Fl-qkK^fpj$2zmqNl_}1>e6=id)Sws-|kERw*nmVNiKXd|rL-b^Zx# z5;Wt<5ys`_f-gWI4tA#TVUX$doHrQ2Hfb73#S$JYIER>e4XGdk#Hk$6-G8;^3Swvh zV(k}!TO2vYJ*%+wtR@UDnbNo$a<IT#?ybi6_fgHVh<BqOoCv2YGFzZZgcy+{4%6p| zI@vhmHkGl2$kZ6QP`C%5X$`25La&b$88CpTucnpj$@<)QzNLY8c|$Af7?SqK4>!gK zH1GULrKtfRH~#X4^HsF;9pQ8bU<t*tXa*x<o^MDd#5sj6hS97Uj6})cY<AY?NIJ>@ zAZDAu{Clp-hE!S{(O|HidWMRx3oDV~Y+QRlcu-Rku~krH^s~|^Q^uWRCi)r*TvWS^ z$E>boY(rkop%9gS0b`gV0D1nc^aF%JitO%&YA=)StE|N14pg9gv&!dn8A%44!aR7m z+eR8}CK!32h3LsYOFSQjmm=n6W@rUNE`duw*Wr&~4D-dV$gfu8$9QhNQWnTM6%YZ# zs7h!;K_Y)p*<Y@%b%K7*GaO`dztI_e0MqpXwLyKMTzq}k;izDtP{>4?o6o#i0;o}i zJdngShPf6Qe3+SAiB^d7tFii0uavT$Xh=lgobNT_kadFKP^aS9-X>@(bqcuh_zTfg zGRCKABR-THFTS|z-R_4;jFmgTwH3KX2=o&VhKgDrl##;WDb80|%q0nknZf3-^_jIv zG2M&1l4A~P9DW30NkJ+B!g#|AHE)z92sOB#%^BGPoxkW{5-DXYF|qk#B{ws#o4)Rn z3%_2$jJmW=idPbEns+qlbR^-WP1lNrS-n4^5$nRV)ui)EaMrOOc{5T7P*(ag2;LH& zHdwQ449pQr9y?%oLPu5u&Z>vhXJg~Ayxm+<-h{6aBA29&^-4taY5}5;EJ<ytQCIE} zQw19Bqh3WQ-^6ALGh}ZUd4f1skTN&nwVP`4svKZs4a&uoS*;+$!hFoFxu$->JIRk4 zZ<==OyqJlFK^Z`;STHp`a1C5H6-%QiYBrEeIHJa_S6rE&$uI_U-pD47_=;L#2S~KV zaHvTeI%^~dJ%Wtr<Jk{h^1Q)7fA~Ox7if4fjJhm7yajt}5*ovb9wNvf((?{%{X2rJ zY}R^p-bz@m>E`p;8cncKTi~U>G?9c^>y^Je9Y(fJu|lls9dTl6ZDVVE&59-Qy(jJq zWyggn{1M;^pn`*`?r?}#+K6XJw7J4&CaLF`jc6F;#m?Y(6Rkc7C=mG<ZUKp%MNVq) zIZ#>Vr~-yfpzTk|sPBf5@%Pf^!vbI0Sxp5G`kf30Y7{1jMg~hO7i43-3sqRRjr`TI zG=r4c)+@huUaKO$p)^3~Fd_4q!Cv&AD-z-Oz4a=pN06uugN(maVYMJ3entr*l0bBU z3Qz+FzR@>wCQ+G>4$*hI)n$MTeSOl*RU$TeV+L>MLZJoVAP*L3G(K#b3=RuTpdCnI z6L!=qIbmc?8-BRw0jio!mNis_gz@k2_A8^4?}};#rEAp^Wg9M}@uH!D!5y!98!# zDK*o{wSYuJ-jp~T2S~P<&_fKOQL)Wnrd*Pe!%TPvRpva1x;Rk2O#2T%#OyBQHKhbz z29+66iRV!0#ZV&ANIe<aW(JpChSoRGvPU{l2v7`w3Bn~7h9z3Ic`^LJCysu~If_^y za^P3NLV+ZYQWuDikw*|jFya)0k6`L2DBOQFx<rY1MQA80swo_yGCJ=Uh9Ou6T#SZF zqWV%Fjdzac9XEvB7ciM!A^}i2aAj_dRo9JCIVy<6qi#F*kVgD{5Cqo7sL^L&Cb&Tv zTS-KbMI@S{#tt!q;#senzg%evYtWDhDYc6hP-ia&NDR%_3>bW_)fED#LV$%5e*AKm z4b%$R#{yVbEaT!KYOXXIEnn(Dyl8om!MZ#L6LcK*fCr3_I{E94FdMzoCVy3l1~Co- z#Jk5_@@7YIR}j&$gZ0v;`FyvO(o3>}LCe8tX0S#Xc32g9N#`}w*Wf!m!-Vk}#?l9R z0pt3~8wN9;o1=-dILC7rPlH`IQab@s^NO);66fh2gM}!+4G52t`Sr+gJUs51*a%L+ zM@o-_Tq2=DRZP&>#U6Biu3Q7gCmlwU;Tr{_hY<xZeE8N!hh<QPEti#Ajc3I&e|vjT z%)U3rz)qM(TI=x{L|}NIuJ{_;J<Z<&C4GI~4z0~_&qMTk=wCRLW7hIUoQZl05q+lp z(37<~a`KP_(frL=jtVF-{p<Q|z0!80VhOT7`&48V--6W8FyWbDT#9;ZH2mb0FtoK2 z%3gq47!$rwxqBvh-{6;66t-cqsaObXy~;KKAE{{3-TjvelpCzrf;VO(tB+XIGNING zkDKVRIzZWf2Z&Jou@upHw;9N?qglLYtyt8tIOM)HcTv_6;6B!Db!y*}!3fpoIi$^C zqJ6O`I;cT9neq+Z`F@>QcB?6Ea!*?Yf{)uEx7KJrU7-EFVIBD^cV<Qe0#XyN+I(?G zV)Xsc$kX&aNs`S<6HwOsSXxVFD@6?0@i>?XX)5^4U`EgR%Ur#YXKnu3rphX5rQL#L z^86+@G#dk;^t*UiIP5bHh*9*#3SQ2pKARj*atmx;Dvh9g+JtNVhB*_MR}1@uMxkuO z5R6{tZ>BtRh(VN_c+o^Np!o$zkk+@D6~{85h2Rv)<6A}n;MPoEKPrFC&D4SqqJ$QU zB+(5#RPm@_C^|JWST$YP{Ef%7O|8R(W*^N_V-AIZh#3POt6hT3CHeH|6sB4@7;a5+ zY<WxubHK^7lbGURZ~5jGrGPJ1Dvzz7<)&GqZ)Rkog$;HCH=WE(4<i&N?9k?&2-@>o zC9snx1L6+IW<|OP1U>o^c<21B42T)uAc(2;uy&^W1{ERjMik7<U_N`lz>Qz)#!xHy zi(V3@(P;*2oOS=rl%Z=ZI%*iM8LS!_X9WrQ`j)s)2CEjYXk`B8s&vTJ-zz;#-AN@| z4jtwtN`u%87Fsraus+I%@nxP5KWZM@^smA1F1cx1LXc+>R2%ZjFNye41k?;~sL$Qz z59AH(`Y~xBP)*0wqw`lElV0yU*O-Q!0w@zLw;wZ}wZxjiu)z%3f0J(^$2!C_$FXg5 zhWvfT7_pgbDL5CmK(@;uj-ug;6?{gL{56HeL^h4l`zCaFT;n?(Ms%GxGC1M^vkB0V z!O$hG`CJ<r;1@t?-FemtI)}rv{IbMb9mO>HSo_SwO#Hni-u5-VYxsyhxFXY5k)Y%N zn5oCTy=M9v&>v%SjFt@Ilc3QRxXXj1TTh}qC5N7#OkBm@$pyYk#As8pqj`sle?su7 zd#sE`XpagTkj)~xdbR)jEOF}<bAuE&KkEKy4FaTm+dmXgFwv}7$u$)4SJldQu2{@j znNq|v$1HN^(8Ax^jG_6_vzsES8!DtQ@<A=X1eq)PX|~5Y+U7*|_V)`+DyAjRM?kUg zs>cI6xp8=+s(>ijTCvF9bwf?<aB7rA*{;n#TJvWU>(J;ZTtGd&@gu&hp5^F!0dlc4 z6)Th)3NiQ{R4ZgFmIaNoOeB1uo|DX7^YE6XuTG3iBaCpQ5{}l2m0O;<qpnlw5UX=w z{k*{j_(PacvD8=Qp55Z9mG*XrMX^>y9U%sddnabg7Xzmj5C0@OQR^drzamsa2HARU zq=woy8EiZ!y0W0F;$SSlG0vFHGd6*BwARQUS3HyHEs(Kbe3-$FG?qn~nZNJ~4HAAy z|Ki~N8|$6FrnBbfe1(5w0%eWwhysrgJ{@IbHU#i*L=x|FY<}Y2Yh$Mxkm;w>GXN+J z0okC;75P*vvqUzKv;Q*EnQ7e=PK9|?tACf}>%#Dg*bxq)jJeU|=Vb1LI12J}PC4$_ zId@+Bf1KQE*U!6Z;O=(MDEdT*w-JJDQMOC12WT6vF^-3|5R42)M9&A0Zq_SbUwdk4 z@UW)ZG#~5x2XdPhXM5aP@~2zz>1O(cT@nItzNYbvC_cA<G%{Ya)URJrpIL)xR$1^f zeZQx)X<l6nZ00VzK4_z<_I5%1p!zm5I0nD&eK8h#oOL00TM4JKhnGW}kxQ{8W|AON zJ_2GR9kM}OxfNZiklu#4a~(QI#T6m^?KzV_%WT?=*z>^}<6Gu;Fz*=vY`Y}&N)Vac z->Ok0LYh@Ih*=zMBf7w%8H~p1{a~BXE)8E*OefRc0332R(r6>jIjMV6-WYlV^pdXP z4B-^mEP7e1T39#rd`n-bV4!O>jX}S_euG&IV(8M58fejT&BZxsR60o{x`qs$wtY}5 zyN!|s`9hSeQ5{-*JUB&4J-;@(NVFMPXKr`EX=3dUZ*iZ*-)d1dJ;wPZF!h@)PfepV zHSNS-SImhAeG(Vfz@HZZEy#J`E{qRtC>!2i(Lt(7g5m9-Yr8PK_*3SWw%1MHO~&qh z(vg3dt4H%3v{J8ntzDhW>9G6%n0?uYxD@$wD+r_Kq1!!<p&U;b<(+WbkkZHP{4H$6 z%0}+S_K<*HBj9j&<9Qz)v_6UAKDV~OdIIq225)Hn@Kyt|c(#IkG0IcaK~EQ{8HqGn z?$7F)jJU&dkXv<mV249i(N$++f8{^1M1K0{<$<bNn3s3BoAIW_Zyvu|jldya9;&N! z*;YTyeJma&R!xpqqbV*wkMnPK)pwqFtIFTuZW8S)AI}l+@&0A=IxHWcsCVIRZ?8^k z20zljIVOIMZ_ZNYbDQ+aW$>f&*K-?ZvS;I-@M5q0%BOKM_;LQ_Xq$+B-v@V=t5+wS zE9oQa^Qh(C_*=2gd;2S)w;B96|E_!2d#O~fR`N#L$L+tbt-kNP%Nd=A#$Wj&bs-=H z=gY<Op1)pUOL~>I-&tWEwI8kVygxj7!fnZ`rZC>luWDC49@t@1dW+w$c$@pGwJ+;m izA4NR>mof~feTIyc>?!9zh02N;qm(wYwW<Q4*w6N*nmL*
literal 0 HcmV?d00001
Signed-off-by: Stelian Pop stelian@popies.net --- board/atmel/at91cap9adk/at91cap9adk.c | 28 ++++++++++++++++++++++++++++ include/asm-arm/arch-at91sam9/at91_pmc.h | 5 +++++ include/asm-arm/arch-at91sam9/at91cap9.h | 14 +++++++++++++- 3 files changed, 46 insertions(+), 1 deletions(-)
diff --git a/board/atmel/at91cap9adk/at91cap9adk.c b/board/atmel/at91cap9adk/at91cap9adk.c index ee4f26e..b92dd82 100644 --- a/board/atmel/at91cap9adk/at91cap9adk.c +++ b/board/atmel/at91cap9adk/at91cap9adk.c @@ -72,6 +72,33 @@ static void at91cap9_serial_hw_init(void) #endif }
+static void at91cap9_slowclock_hw_init(void) +{ + /* + * On AT91CAP9 revC CPUs, the slow clock can be based on an + * internal impreciseRC oscillator or an external 32kHz oscillator. + * Switch to the latter. + */ +#define ARCH_ID_AT91CAP9_REVB 0x399 +#define ARCH_ID_AT91CAP9_REVC 0x601 + if (at91_sys_read(AT91_PMC_VER) == ARCH_ID_AT91CAP9_REVC) { + unsigned i, tmp = at91_sys_read(AT91_SCKCR); + if ((tmp & AT91CAP9_SCKCR_OSCSEL) == AT91CAP9_SCKCR_OSCSEL_RC) { + extern void timer_init(void); + timer_init(); + tmp |= AT91CAP9_SCKCR_OSC32EN; + at91_sys_write(AT91_SCKCR, tmp); + for (i = 0; i < 1200; i++) + udelay(1000); + tmp |= AT91CAP9_SCKCR_OSCSEL_32; + at91_sys_write(AT91_SCKCR, tmp); + udelay(200); + tmp &= ~AT91CAP9_SCKCR_RCEN; + at91_sys_write(AT91_SCKCR, tmp); + } + } +} + static void at91cap9_nor_hw_init(void) { unsigned long csa; @@ -305,6 +332,7 @@ int board_init(void) gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
at91cap9_serial_hw_init(); + at91cap9_slowclock_hw_init(); at91cap9_nor_hw_init(); #ifdef CONFIG_CMD_NAND at91cap9_nand_hw_init(); diff --git a/include/asm-arm/arch-at91sam9/at91_pmc.h b/include/asm-arm/arch-at91sam9/at91_pmc.h index 52cd8e5..9981c42 100644 --- a/include/asm-arm/arch-at91sam9/at91_pmc.h +++ b/include/asm-arm/arch-at91sam9/at91_pmc.h @@ -96,4 +96,9 @@ #define AT91_PMC_PCK3RDY (1 << 11) /* Programmable Clock 3 */ #define AT91_PMC_IMR (AT91_PMC + 0x6c) /* Interrupt Mask Register */
+#define AT91_PMC_PROT (AT91_PMC + 0xe4) /* Protect Register [AT91CAP9 revC only] */ +#define AT91_PMC_PROTKEY 0x504d4301 /* Activation Code */ + +#define AT91_PMC_VER (AT91_PMC + 0xfc) /* PMC Module Version [AT91CAP9 only] */ + #endif diff --git a/include/asm-arm/arch-at91sam9/at91cap9.h b/include/asm-arm/arch-at91sam9/at91cap9.h index e16909c..6bd78fa 100644 --- a/include/asm-arm/arch-at91sam9/at91cap9.h +++ b/include/asm-arm/arch-at91sam9/at91cap9.h @@ -101,13 +101,25 @@ #define AT91_RTT (0xfffffd20 - AT91_BASE_SYS) #define AT91_PIT (0xfffffd30 - AT91_BASE_SYS) #define AT91_WDT (0xfffffd40 - AT91_BASE_SYS) -#define AT91_GPBR (0xfffffd50 - AT91_BASE_SYS) +#define AT91_SCKCR (0xfffffd50 - AT91_BASE_SYS) +#define AT91_GPBR_REVB (0xfffffd50 - AT91_BASE_SYS) +#define AT91_GPBR_REVC (0xfffffd60 - AT91_BASE_SYS)
#define AT91_USART0 AT91CAP9_BASE_US0 #define AT91_USART1 AT91CAP9_BASE_US1 #define AT91_USART2 AT91CAP9_BASE_US2
/* + * SCKCR flags + */ +#define AT91CAP9_SCKCR_RCEN (1 << 0) /* RC Oscillator Enable */ +#define AT91CAP9_SCKCR_OSC32EN (1 << 1) /* 32kHz Oscillator Enable */ +#define AT91CAP9_SCKCR_OSC32BYP (1 << 2) /* 32kHz Oscillator Bypass */ +#define AT91CAP9_SCKCR_OSCSEL (1 << 3) /* Slow Clock Selector */ +#define AT91CAP9_SCKCR_OSCSEL_RC (0 << 3) +#define AT91CAP9_SCKCR_OSCSEL_32 (1 << 3) + +/* * Internal Memory. */ #define AT91CAP9_SRAM_BASE 0x00100000 /* Internal SRAM base address */
There is no patch 21/21, operator error. :)
- if (at91_sys_read(AT91_PMC_VER) == ARCH_ID_AT91CAP9_REVC) {
Please don't add #defines in the middle of a source file. Either right at the beginning, or in a header file.
Line lenght ?
participants (6)
Jean-Christophe PLAGNIOL-VILLARD
Ken.Fuchs@bench.com
Remy Bohmer
Stelian Pop
Ulf Samuelsson
