[U-Boot] [PATCH 01/11] powerpc/85xx: Replace CONFIG_SYS_HAS_SERDES with a weak function
Instead of a #define use a null weak function for fsl_serdes_init
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cpu_init.c | 8 ++++++-- include/configs/MPC8536DS.h | 1 - include/configs/P1022DS.h | 1 - include/configs/corenet_ds.h | 1 - 4 files changed, 6 insertions(+), 5 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 4b8faa5..4a6cc65 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -232,6 +232,12 @@ void cpu_init_f (void) invalidate_cpc(); }
+/* Implement a dummy function for those platforms w/o SERDES */ +static void __fsl_serdes__init(void) +{ + return ; +} +__attribute__((weak, alias("__fsl_serdes__init"))) void fsl_serdes_init(void);
/* * Initialize L2 as cache. @@ -375,10 +381,8 @@ int cpu_init_r(void) qe_reset(); #endif
-#if defined(CONFIG_SYS_HAS_SERDES) /* needs to be in ram since code uses global static vars */ fsl_serdes_init(); -#endif
#if defined(CONFIG_MP) setup_mp(); diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 5c5be0c..7473834 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -78,7 +78,6 @@ #define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ #define CONFIG_FSL_PCIE_RESET 1 /* need PCIe reset errata */ #define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ -#define CONFIG_SYS_HAS_SERDES /* has SERDES */
#define CONFIG_FSL_LAW 1 /* Use common FSL init code */ #define CONFIG_E1000 1 /* Defind e1000 pci Ethernet card*/ diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index b411fc8..13f1125 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -34,7 +34,6 @@ #define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ #define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ -#define CONFIG_SYS_HAS_SERDES /* has SERDES */
#define CONFIG_PHYS_64BIT #define CONFIG_ENABLE_36BIT_PHYS diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 454a30a..e1cd1b0 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -50,7 +50,6 @@ #define CONFIG_PCIE3 /* PCIE controler 3 */ #define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ -#define CONFIG_SYS_HAS_SERDES /* has SERDES */
#define CONFIG_SRIO1 /* SRIO port 1 */ #define CONFIG_SRIO2 /* SRIO port 2 */
Created a section in the Makefile for SoC specific SERDES code. Also added P1013 SERDES (use P1022 SERDES code).
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/Makefile | 7 +++++-- 1 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 63d7923..e14ed01 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -66,8 +66,6 @@ COBJS-$(CONFIG_CPM2) += ether_fcc.o COBJS-$(CONFIG_OF_LIBFDT) += fdt.o COBJS-$(CONFIG_FSL_CORENET) += liodn.o COBJS-$(CONFIG_MP) += mp.o -COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o -COBJS-$(CONFIG_P1022) += p1022_serdes.o COBJS-$(CONFIG_PCI) += pci.o COBJS-$(CONFIG_FSL_CORENET) += portals.o
@@ -77,6 +75,11 @@ COBJS-$(CONFIG_PPC_P4080) += p4080_ids.o COBJS-$(CONFIG_QE) += qe_io.o COBJS-$(CONFIG_CPM2) += serial_scc.o COBJS-$(CONFIG_FSL_CORENET) += fsl_corenet_serdes.o + +# SoC specific SERDES support +COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o +COBJS-$(CONFIG_P1013) += p1013_serdes.o +COBJS-$(CONFIG_P1022) += p1022_serdes.o COBJS-$(CONFIG_PPC_P4080) += p4080_serdes.o
COBJS = $(COBJS-y)
Add the ability to determine if a given IP block connected on SERDES is configured. This is useful for things like PCIe and SRIO since they are only ever connected on SERDES. This mimics the code we have in place for the 85xx platforms.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc86xx/Makefile | 2 + arch/powerpc/cpu/mpc86xx/cpu_init.c | 6 ++- arch/powerpc/cpu/mpc86xx/mpc8610_serdes.c | 85 ++++++++++++++++++++++++++ arch/powerpc/cpu/mpc86xx/mpc8641_serdes.c | 94 +++++++++++++++++++++++++++++ 4 files changed, 186 insertions(+), 1 deletions(-) create mode 100644 arch/powerpc/cpu/mpc86xx/mpc8610_serdes.c create mode 100644 arch/powerpc/cpu/mpc86xx/mpc8641_serdes.c
diff --git a/arch/powerpc/cpu/mpc86xx/Makefile b/arch/powerpc/cpu/mpc86xx/Makefile index 5b7d80a..b4ef286 100644 --- a/arch/powerpc/cpu/mpc86xx/Makefile +++ b/arch/powerpc/cpu/mpc86xx/Makefile @@ -42,6 +42,8 @@ COBJS-$(CONFIG_MPC8641) += ddr-8641.o COBJS-$(CONFIG_OF_LIBFDT) += fdt.o COBJS-y += interrupts.o COBJS-$(CONFIG_MP) += mp.o +COBJS-$(CONFIG_MPC8610) += mpc8610_serdes.o +COBJS-$(CONFIG_MPC8641) += mpc8641_serdes.o COBJS-y += speed.o
SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) diff --git a/arch/powerpc/cpu/mpc86xx/cpu_init.c b/arch/powerpc/cpu/mpc86xx/cpu_init.c index 82c216b..1d35c0c 100644 --- a/arch/powerpc/cpu/mpc86xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc86xx/cpu_init.c @@ -1,5 +1,5 @@ /* - * Copyright 2004,2009 Freescale Semiconductor, Inc. + * Copyright 2004,2009-2010 Freescale Semiconductor, Inc. * Jeff Brown * Srikanth Srinivasan (srikanth.srinivasan@freescale.com) * @@ -31,6 +31,7 @@ #include <mpc86xx.h> #include <asm/mmu.h> #include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> #include <asm/mp.h>
void setup_bats(void); @@ -76,6 +77,9 @@ void cpu_init_f(void) */ int cpu_init_r(void) { + /* needs to be in ram since code uses global static vars */ + fsl_serdes_init(); + #if defined(CONFIG_MP) setup_mp(); #endif diff --git a/arch/powerpc/cpu/mpc86xx/mpc8610_serdes.c b/arch/powerpc/cpu/mpc86xx/mpc8610_serdes.c new file mode 100644 index 0000000..0dc1975 --- /dev/null +++ b/arch/powerpc/cpu/mpc86xx/mpc8610_serdes.c @@ -0,0 +1,85 @@ +/* + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/immap_86xx.h> +#include <asm/fsl_serdes.h> + +#define SRDS1_MAX_LANES 4 +#define SRDS2_MAX_LANES 4 + +static u32 serdes1_prtcl_map, serdes2_prtcl_map; + +static u8 serdes1_cfg_tbl[][SRDS1_MAX_LANES] = { + [0x1] = {PCIE1, PCIE1, PCIE1, PCIE1}, + [0x4] = {PCIE1, PCIE1, PCIE1, PCIE1}, + [0x7] = {NONE, NONE, NONE, NONE}, +}; + +static u8 serdes2_cfg_tbl[][SRDS2_MAX_LANES] = { + [0x0] = {PCIE2, PCIE2, PCIE2, PCIE2}, + [0x4] = {PCIE2, PCIE2, PCIE2, PCIE2}, + [0x7] = {NONE, NONE, NONE, NONE}, +}; + +int is_serdes_configured(enum srds_prtcl device) +{ + int ret = (1 << device) & serdes1_prtcl_map; + + if (ret) + return ret; + + return (1 << device) & serdes2_prtcl_map; +} + +void fsl_serdes_init(void) +{ + immap_t *immap = (immap_t *) CONFIG_SYS_CCSRBAR; + ccsr_gur_t *gur = &immap->im_gur; + u32 pordevsr = in_be32(&gur->pordevsr); + u32 srds_cfg = (pordevsr & MPC8610_PORDEVSR_IO_SEL) >> + MPC8610_PORDEVSR_IO_SEL_SHIFT; + int lane; + + debug("PORDEVSR[IO_SEL_SRDS] = %x\n", srds_cfg); + + if (srds_cfg > ARRAY_SIZE(serdes1_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; + } + for (lane = 0; lane < SRDS1_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes1_cfg_tbl[srds_cfg][lane]; + serdes1_prtcl_map |= (1 << lane_prtcl); + } + + if (srds_cfg > ARRAY_SIZE(serdes2_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; + } + + for (lane = 0; lane < SRDS2_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes2_cfg_tbl[srds_cfg][lane]; + serdes2_prtcl_map |= (1 << lane_prtcl); + } +} diff --git a/arch/powerpc/cpu/mpc86xx/mpc8641_serdes.c b/arch/powerpc/cpu/mpc86xx/mpc8641_serdes.c new file mode 100644 index 0000000..3ae9069 --- /dev/null +++ b/arch/powerpc/cpu/mpc86xx/mpc8641_serdes.c @@ -0,0 +1,94 @@ +/* + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/immap_86xx.h> +#include <asm/fsl_serdes.h> + +#define SRDS1_MAX_LANES 4 +#define SRDS2_MAX_LANES 4 + +static u32 serdes1_prtcl_map, serdes2_prtcl_map; + +static u8 serdes1_cfg_tbl[][SRDS1_MAX_LANES] = { + [0x2] = {PCIE1, PCIE1, PCIE1, PCIE1}, + [0x3] = {PCIE1, PCIE1, PCIE1, PCIE1}, + [0x5] = {PCIE1, PCIE1, PCIE1, PCIE1}, + [0x6] = {PCIE1, PCIE1, PCIE1, PCIE1}, + [0x7] = {PCIE1, PCIE1, PCIE1, PCIE1}, + [0xf] = {PCIE1, PCIE1, PCIE1, PCIE1}, +}; + +static u8 serdes2_cfg_tbl[][SRDS2_MAX_LANES] = { + [0x3] = {PCIE2, PCIE2, PCIE2, PCIE2}, + [0x5] = {SRIO1, SRIO1, SRIO1, SRIO1}, + [0x6] = {SRIO1, SRIO1, SRIO1, SRIO1}, + [0x7] = {SRIO1, SRIO1, SRIO1, SRIO1}, + [0x9] = {SRIO1, SRIO1, SRIO1, SRIO1}, + [0xa] = {SRIO1, SRIO1, SRIO1, SRIO1}, + [0xb] = {SRIO1, SRIO1, SRIO1, SRIO1}, + [0xe] = {PCIE2, PCIE2, PCIE2, PCIE2}, + [0xf] = {PCIE2, PCIE2, PCIE2, PCIE2}, +}; + +int is_serdes_configured(enum srds_prtcl device) +{ + int ret = (1 << device) & serdes1_prtcl_map; + + if (ret) + return ret; + + return (1 << device) & serdes2_prtcl_map; +} + +void fsl_serdes_init(void) +{ + immap_t *immap = (immap_t *) CONFIG_SYS_CCSRBAR; + ccsr_gur_t *gur = &immap->im_gur; + u32 pordevsr = in_be32(&gur->pordevsr); + u32 srds_cfg = (pordevsr & MPC8641_PORDEVSR_IO_SEL) >> + MPC8641_PORDEVSR_IO_SEL_SHIFT; + int lane; + + debug("PORDEVSR[IO_SEL_SRDS] = %x\n", srds_cfg); + + if (srds_cfg > ARRAY_SIZE(serdes1_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; + } + for (lane = 0; lane < SRDS1_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes1_cfg_tbl[srds_cfg][lane]; + serdes1_prtcl_map |= (1 << lane_prtcl); + } + + if (srds_cfg > ARRAY_SIZE(serdes2_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; + } + + for (lane = 0; lane < SRDS2_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes2_cfg_tbl[srds_cfg][lane]; + serdes2_prtcl_map |= (1 << lane_prtcl); + } +}
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/Makefile | 2 + arch/powerpc/cpu/mpc85xx/p2020_serdes.c | 73 +++++++++++++++++++++++++++++++ 2 files changed, 75 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/p2020_serdes.c
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index e14ed01..a2c844d 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -80,6 +80,8 @@ COBJS-$(CONFIG_FSL_CORENET) += fsl_corenet_serdes.o COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o COBJS-$(CONFIG_P1013) += p1013_serdes.o COBJS-$(CONFIG_P1022) += p1022_serdes.o +COBJS-$(CONFIG_P2010) += p2020_serdes.o +COBJS-$(CONFIG_P2020) += p2020_serdes.o COBJS-$(CONFIG_PPC_P4080) += p4080_serdes.o
COBJS = $(COBJS-y) diff --git a/arch/powerpc/cpu/mpc85xx/p2020_serdes.c b/arch/powerpc/cpu/mpc85xx/p2020_serdes.c new file mode 100644 index 0000000..389ff6b --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/p2020_serdes.c @@ -0,0 +1,73 @@ +/* + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_serdes.h> + +#define SRDS1_MAX_LANES 4 + +static u32 serdes1_prtcl_map; + +static u8 serdes1_cfg_tbl[][SRDS1_MAX_LANES] = { + [0x0] = {PCIE1, NONE, NONE, NONE}, + [0x2] = {PCIE1, PCIE2, PCIE3, PCIE3}, + [0x4] = {PCIE1, PCIE1, PCIE3, PCIE3}, + [0x6] = {PCIE1, PCIE1, PCIE1, PCIE1}, + [0x7] = {SRIO2, SRIO1, NONE, NONE}, + [0x8] = {SRIO2, SRIO2, SRIO2, SRIO2}, + [0x9] = {SRIO2, SRIO2, SRIO2, SRIO2}, + [0xa] = {SRIO2, SRIO2, SRIO2, SRIO2}, + [0xb] = {SRIO2, SRIO1, SGMII_TSEC2, SGMII_TSEC3}, + [0xc] = {SRIO2, SRIO1, SGMII_TSEC2, SGMII_TSEC3}, + [0xd] = {PCIE1, SRIO1, SGMII_TSEC2, SGMII_TSEC3}, + [0xe] = {PCIE1, PCIE2, SGMII_TSEC2, SGMII_TSEC3}, + [0xf] = {PCIE1, PCIE1, SGMII_TSEC2, SGMII_TSEC3}, +}; + +int is_serdes_configured(enum srds_prtcl prtcl) +{ + return (1 << prtcl) & serdes1_prtcl_map; +} + +void fsl_serdes_init(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 pordevsr = in_be32(&gur->pordevsr); + u32 srds_cfg = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> + MPC85xx_PORDEVSR_IO_SEL_SHIFT; + int lane; + + debug("PORDEVSR[IO_SEL_SRDS] = %x\n", srds_cfg); + + if (srds_cfg > ARRAY_SIZE(serdes1_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; + } + + for (lane = 0; lane < SRDS1_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes1_cfg_tbl[srds_cfg][lane]; + serdes1_prtcl_map |= (1 << lane_prtcl); + } +}
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/Makefile | 1 + arch/powerpc/cpu/mpc85xx/mpc8572_serdes.c | 81 +++++++++++++++++++++++++++++ 2 files changed, 82 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/mpc8572_serdes.c
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index a2c844d..9ec19bb 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -78,6 +78,7 @@ COBJS-$(CONFIG_FSL_CORENET) += fsl_corenet_serdes.o
# SoC specific SERDES support COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o +COBJS-$(CONFIG_MPC8572) += mpc8572_serdes.o COBJS-$(CONFIG_P1013) += p1013_serdes.o COBJS-$(CONFIG_P1022) += p1022_serdes.o COBJS-$(CONFIG_P2010) += p2020_serdes.o diff --git a/arch/powerpc/cpu/mpc85xx/mpc8572_serdes.c b/arch/powerpc/cpu/mpc85xx/mpc8572_serdes.c new file mode 100644 index 0000000..2ff5d9a --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/mpc8572_serdes.c @@ -0,0 +1,81 @@ +/* + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_serdes.h> + +#define SRDS1_MAX_LANES 8 + +static u32 serdes1_prtcl_map; + +static u8 serdes1_cfg_tbl[][SRDS1_MAX_LANES] = { + [0x2] = {PCIE1, PCIE1, PCIE1, PCIE1, NONE, NONE, NONE, NONE}, + [0x3] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2}, + [0x6] = {NONE, NONE, NONE, NONE, SRIO1, SRIO1, SRIO1, SRIO1}, + [0x7] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE3, PCIE3}, + [0xb] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO1, SRIO1, SRIO1, SRIO1}, + [0xc] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO1, SRIO1, SRIO1, SRIO1}, + [0xd] = {NONE, NONE, NONE, NONE, SRIO1, SRIO1, SRIO1, SRIO1}, + [0xe] = {NONE, NONE, NONE, NONE, SRIO1, SRIO1, SRIO1, SRIO1}, + [0xf] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1}, +}; + +int is_serdes_configured(enum srds_prtcl prtcl) +{ + return (1 << prtcl) & serdes1_prtcl_map; +} + +void fsl_serdes_init(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 pordevsr = in_be32(&gur->pordevsr); + u32 srds_cfg = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> + MPC85xx_PORDEVSR_IO_SEL_SHIFT; + int lane; + + debug("PORDEVSR[IO_SEL_SRDS] = %x\n", srds_cfg); + + if (srds_cfg > ARRAY_SIZE(serdes1_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; + } + + for (lane = 0; lane < SRDS1_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes1_cfg_tbl[srds_cfg][lane]; + serdes1_prtcl_map |= (1 << lane_prtcl); + } + + if (!(pordevsr & MPC85xx_PORDEVSR_SGMII1_DIS)) + serdes1_prtcl_map |= (1 << SGMII_TSEC1); + + if (!(pordevsr & MPC85xx_PORDEVSR_SGMII2_DIS)) + serdes1_prtcl_map |= (1 << SGMII_TSEC2); + + if (!(pordevsr & MPC85xx_PORDEVSR_SGMII3_DIS)) + serdes1_prtcl_map |= (1 << SGMII_TSEC3); + + if (!(pordevsr & MPC85xx_PORDEVSR_SGMII4_DIS)) + serdes1_prtcl_map |= (1 << SGMII_TSEC4); +}
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/Makefile | 1 + arch/powerpc/cpu/mpc85xx/mpc8548_serdes.c | 65 +++++++++++++++++++++++++++++ 2 files changed, 66 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/mpc8548_serdes.c
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 9ec19bb..e1320bf 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -78,6 +78,7 @@ COBJS-$(CONFIG_FSL_CORENET) += fsl_corenet_serdes.o
# SoC specific SERDES support COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o +COBJS-$(CONFIG_MPC8548) += mpc8548_serdes.o COBJS-$(CONFIG_MPC8572) += mpc8572_serdes.o COBJS-$(CONFIG_P1013) += p1013_serdes.o COBJS-$(CONFIG_P1022) += p1022_serdes.o diff --git a/arch/powerpc/cpu/mpc85xx/mpc8548_serdes.c b/arch/powerpc/cpu/mpc85xx/mpc8548_serdes.c new file mode 100644 index 0000000..76288cd --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/mpc8548_serdes.c @@ -0,0 +1,65 @@ +/* + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_serdes.h> + +#define SRDS1_MAX_LANES 8 + +static u32 serdes1_prtcl_map; + +static u8 serdes1_cfg_tbl[][SRDS1_MAX_LANES] = { + [0x3] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO1, SRIO1, SRIO1, SRIO1}, + [0x4] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO1, SRIO1, SRIO1, SRIO1}, + [0x5] = {NONE, NONE, NONE, NONE, SRIO1, SRIO1, SRIO1, SRIO1}, + [0x6] = {NONE, NONE, NONE, NONE, SRIO1, SRIO1, SRIO1, SRIO1}, + [0x7] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1}, +}; + +int is_serdes_configured(enum srds_prtcl prtcl) +{ + return (1 << prtcl) & serdes1_prtcl_map; +} + +void fsl_serdes_init(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 pordevsr = in_be32(&gur->pordevsr); + u32 srds1_cfg = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> + MPC85xx_PORDEVSR_IO_SEL_SHIFT; + int lane; + + debug("PORDEVSR[IO_SEL] = %x\n", srds1_cfg); + + if (srds1_cfg > ARRAY_SIZE(serdes1_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL] = %d\n", srds1_cfg); + return ; + } + + for (lane = 0; lane < SRDS1_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes1_cfg_tbl[srds1_cfg][lane]; + serdes1_prtcl_map |= (1 << lane_prtcl); + } +}
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/Makefile | 1 + arch/powerpc/cpu/mpc85xx/mpc8568_serdes.c | 65 +++++++++++++++++++++++++++++ 2 files changed, 66 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/mpc8568_serdes.c
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index e1320bf..3c75429 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -79,6 +79,7 @@ COBJS-$(CONFIG_FSL_CORENET) += fsl_corenet_serdes.o # SoC specific SERDES support COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o COBJS-$(CONFIG_MPC8548) += mpc8548_serdes.o +COBJS-$(CONFIG_MPC8568) += mpc8568_serdes.o COBJS-$(CONFIG_MPC8572) += mpc8572_serdes.o COBJS-$(CONFIG_P1013) += p1013_serdes.o COBJS-$(CONFIG_P1022) += p1022_serdes.o diff --git a/arch/powerpc/cpu/mpc85xx/mpc8568_serdes.c b/arch/powerpc/cpu/mpc85xx/mpc8568_serdes.c new file mode 100644 index 0000000..2582637 --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/mpc8568_serdes.c @@ -0,0 +1,65 @@ +/* + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_serdes.h> + +#define SRDS1_MAX_LANES 8 + +static u32 serdes1_prtcl_map; + +static u8 serdes1_cfg_tbl[][SRDS1_MAX_LANES] = { + [0x3] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO1, SRIO1, SRIO1, SRIO1}, + [0x4] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO1, SRIO1, SRIO1, SRIO1}, + [0x5] = {NONE, NONE, NONE, NONE, SRIO1, SRIO1, SRIO1, SRIO1}, + [0x6] = {NONE, NONE, NONE, NONE, SRIO1, SRIO1, SRIO1, SRIO1}, + [0x7] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1}, +}; + +int is_serdes_configured(enum srds_prtcl prtcl) +{ + return (1 << prtcl) & serdes1_prtcl_map; +} + +void fsl_serdes_init(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 pordevsr = in_be32(&gur->pordevsr); + u32 srds_cfg = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> + MPC85xx_PORDEVSR_IO_SEL_SHIFT; + int lane; + + debug("PORDEVSR[IO_SEL_SRDS] = %x\n", srds_cfg); + + if (srds_cfg > ARRAY_SIZE(serdes1_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; + } + + for (lane = 0; lane < SRDS1_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes1_cfg_tbl[srds_cfg][lane]; + serdes1_prtcl_map |= (1 << lane_prtcl); + } +}
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/Makefile | 1 + arch/powerpc/cpu/mpc85xx/mpc8569_serdes.c | 74 +++++++++++++++++++++++++++++ 2 files changed, 75 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/mpc8569_serdes.c
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 3c75429..78bc27a 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -80,6 +80,7 @@ COBJS-$(CONFIG_FSL_CORENET) += fsl_corenet_serdes.o COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o COBJS-$(CONFIG_MPC8548) += mpc8548_serdes.o COBJS-$(CONFIG_MPC8568) += mpc8568_serdes.o +COBJS-$(CONFIG_MPC8569) += mpc8569_serdes.o COBJS-$(CONFIG_MPC8572) += mpc8572_serdes.o COBJS-$(CONFIG_P1013) += p1013_serdes.o COBJS-$(CONFIG_P1022) += p1022_serdes.o diff --git a/arch/powerpc/cpu/mpc85xx/mpc8569_serdes.c b/arch/powerpc/cpu/mpc85xx/mpc8569_serdes.c new file mode 100644 index 0000000..f480c26 --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/mpc8569_serdes.c @@ -0,0 +1,74 @@ +/* + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_serdes.h> + +#define SRDS1_MAX_LANES 4 + +static u32 serdes1_prtcl_map; + +static u8 serdes1_cfg_tbl[][SRDS1_MAX_LANES] = { + [0x0] = {PCIE1, NONE, NONE, NONE}, + [0x1] = {SRIO1, SRIO2, SGMII_TSEC1, SGMII_TSEC2}, + [0x2] = {SRIO1, SRIO2, SGMII_TSEC1, SGMII_TSEC2}, + [0x3] = {SRIO1, SRIO2, NONE, NONE}, + [0x4] = {PCIE1, NONE, SGMII_TSEC1, SGMII_TSEC2}, + [0x5] = {PCIE1, PCIE1, SGMII_TSEC1, SGMII_TSEC2}, + [0x6] = {PCIE1, NONE, SRIO1, SRIO2}, + [0x7] = {PCIE1, PCIE1, SRIO1, SRIO2}, + [0x8] = {PCIE1, PCIE1, SRIO1, SRIO2}, + [0x9] = {SRIO1, SRIO1, SRIO1, SRIO1}, + [0xa] = {SRIO1, SRIO1, SRIO1, SRIO1}, + [0xb] = {SRIO1, SRIO1, SRIO1, SRIO1}, + [0xc] = {PCIE1, SRIO1, SGMII_TSEC1, SGMII_TSEC2}, + [0xf] = {PCIE1, PCIE1, PCIE1, PCIE1}, +}; + +int is_serdes_configured(enum srds_prtcl prtcl) +{ + return (1 << prtcl) & serdes1_prtcl_map; +} + +void fsl_serdes_init(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 pordevsr = in_be32(&gur->pordevsr); + u32 srds_cfg = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> + MPC85xx_PORDEVSR_IO_SEL_SHIFT; + int lane; + + debug("PORDEVSR[IO_SEL_SRDS] = %x\n", srds_cfg); + + if (srds_cfg > ARRAY_SIZE(serdes1_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; + } + + for (lane = 0; lane < SRDS1_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes1_cfg_tbl[srds_cfg][lane]; + serdes1_prtcl_map |= (1 << lane_prtcl); + } +}
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/Makefile | 1 + arch/powerpc/cpu/mpc85xx/mpc8544_serdes.c | 95 +++++++++++++++++++++++++++++ 2 files changed, 96 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/mpc8544_serdes.c
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 78bc27a..dbb53c8 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -78,6 +78,7 @@ COBJS-$(CONFIG_FSL_CORENET) += fsl_corenet_serdes.o
# SoC specific SERDES support COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o +COBJS-$(CONFIG_MPC8544) += mpc8544_serdes.o COBJS-$(CONFIG_MPC8548) += mpc8548_serdes.o COBJS-$(CONFIG_MPC8568) += mpc8568_serdes.o COBJS-$(CONFIG_MPC8569) += mpc8569_serdes.o diff --git a/arch/powerpc/cpu/mpc85xx/mpc8544_serdes.c b/arch/powerpc/cpu/mpc85xx/mpc8544_serdes.c new file mode 100644 index 0000000..7c49097 --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/mpc8544_serdes.c @@ -0,0 +1,95 @@ +/* + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_serdes.h> + +#define SRDS1_MAX_LANES 8 +#define SRDS2_MAX_LANES 4 + +static u32 serdes1_prtcl_map, serdes2_prtcl_map; + +static u8 serdes1_cfg_tbl[][SRDS1_MAX_LANES] = { + [0x2] = {PCIE1, PCIE1, PCIE1, PCIE1, NONE, NONE, NONE, NONE}, + [0x3] = {PCIE1, PCIE1, PCIE1, PCIE1, NONE, NONE, NONE, NONE}, + [0x4] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2}, + [0x5] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2}, + [0x6] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2}, + [0x7] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2}, +}; + +static u8 serdes2_cfg_tbl[][SRDS2_MAX_LANES] = { + [0x1] = {NONE, NONE, SGMII_TSEC1, SGMII_TSEC3}, + [0x3] = {NONE, NONE, SGMII_TSEC1, SGMII_TSEC3}, + [0x5] = {NONE, NONE, SGMII_TSEC1, SGMII_TSEC3}, + [0x6] = {PCIE3, NONE, NONE, NONE}, + [0x7] = {PCIE3, NONE, SGMII_TSEC1, SGMII_TSEC3}, +}; + +int is_serdes_configured(enum srds_prtcl device) +{ + int ret = (1 << device) & serdes1_prtcl_map; + + if (ret) + return ret; + + return (1 << device) & serdes2_prtcl_map; +} + +void fsl_serdes_init(void) +{ + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + u32 pordevsr = in_be32(&gur->pordevsr); + u32 srds_cfg = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> + MPC85xx_PORDEVSR_IO_SEL_SHIFT; + int lane; + + debug("PORDEVSR[IO_SEL_SRDS] = %x\n", srds_cfg); + + if (srds_cfg > ARRAY_SIZE(serdes1_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; + } + for (lane = 0; lane < SRDS1_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes1_cfg_tbl[srds_cfg][lane]; + serdes1_prtcl_map |= (1 << lane_prtcl); + } + + if (srds_cfg > ARRAY_SIZE(serdes2_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; + } + + for (lane = 0; lane < SRDS2_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes2_cfg_tbl[srds_cfg][lane]; + serdes2_prtcl_map |= (1 << lane_prtcl); + } + + if (pordevsr & MPC85xx_PORDEVSR_SGMII1_DIS) + serdes2_prtcl_map &= ~(1 << SGMII_TSEC1); + + if (pordevsr & MPC85xx_PORDEVSR_SGMII3_DIS) + serdes2_prtcl_map &= ~(1 << SGMII_TSEC3); +}
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/Makefile | 4 ++ arch/powerpc/cpu/mpc85xx/p1021_serdes.c | 64 +++++++++++++++++++++++++++++++ 2 files changed, 68 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/p1021_serdes.c
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index dbb53c8..af7bc09 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -83,7 +83,11 @@ COBJS-$(CONFIG_MPC8548) += mpc8548_serdes.o COBJS-$(CONFIG_MPC8568) += mpc8568_serdes.o COBJS-$(CONFIG_MPC8569) += mpc8569_serdes.o COBJS-$(CONFIG_MPC8572) += mpc8572_serdes.o +COBJS-$(CONFIG_P1011) += p1021_serdes.o +COBJS-$(CONFIG_P1012) += p1021_serdes.o COBJS-$(CONFIG_P1013) += p1013_serdes.o +COBJS-$(CONFIG_P1020) += p1021_serdes.o +COBJS-$(CONFIG_P1021) += p1021_serdes.o COBJS-$(CONFIG_P1022) += p1022_serdes.o COBJS-$(CONFIG_P2010) += p2020_serdes.o COBJS-$(CONFIG_P2020) += p2020_serdes.o diff --git a/arch/powerpc/cpu/mpc85xx/p1021_serdes.c b/arch/powerpc/cpu/mpc85xx/p1021_serdes.c new file mode 100644 index 0000000..457ab5d --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/p1021_serdes.c @@ -0,0 +1,64 @@ +/* + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_serdes.h> + +#define SRDS1_MAX_LANES 4 + +static u32 serdes1_prtcl_map; + +static u8 serdes1_cfg_tbl[][SRDS1_MAX_LANES] = { + [0x0] = {PCIE1, NONE, NONE, NONE}, + [0x6] = {PCIE1, PCIE1, PCIE1, PCIE1}, + [0xe] = {PCIE1, PCIE2, SGMII_TSEC2, SGMII_TSEC3}, + [0xf] = {PCIE1, PCIE1, SGMII_TSEC2, SGMII_TSEC3}, +}; + +int is_serdes_configured(enum srds_prtcl prtcl) +{ + return (1 << prtcl) & serdes1_prtcl_map; +} + +void fsl_serdes_init(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 pordevsr = in_be32(&gur->pordevsr); + u32 srds_cfg = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> + MPC85xx_PORDEVSR_IO_SEL_SHIFT; + int lane; + + debug("PORDEVSR[IO_SEL_SRDS] = %x\n", srds_cfg); + + if (srds_cfg > ARRAY_SIZE(serdes1_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; + } + + for (lane = 0; lane < SRDS1_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes1_cfg_tbl[srds_cfg][lane]; + serdes1_prtcl_map |= (1 << lane_prtcl); + } +}
Now that we have serdes support for all 85xx/86xx/Pxxx chips we can replace the is_fsl_pci_cfg() code with the is_serdes_configured().
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc8xxx/Makefile | 1 - arch/powerpc/cpu/mpc8xxx/pci_cfg.c | 204 ----------------------------- arch/powerpc/include/asm/fsl_pci.h | 2 - board/freescale/mpc8544ds/mpc8544ds.c | 7 +- board/freescale/mpc8548cds/mpc8548cds.c | 3 +- board/freescale/mpc8568mds/mpc8568mds.c | 3 +- board/freescale/mpc8569mds/mpc8569mds.c | 3 +- board/freescale/mpc8572ds/mpc8572ds.c | 7 +- board/freescale/mpc8610hpcd/mpc8610hpcd.c | 11 +- board/freescale/mpc8641hpcn/mpc8641hpcn.c | 5 +- board/freescale/p1_p2_rdb/pci.c | 10 +- board/freescale/p2020ds/p2020ds.c | 7 +- board/sbc8548/sbc8548.c | 3 +- board/sbc8641d/sbc8641d.c | 5 +- board/tqc/tqm85xx/tqm85xx.c | 5 +- board/xes/common/fsl_8xxx_pci.c | 11 +- 16 files changed, 39 insertions(+), 248 deletions(-) delete mode 100644 arch/powerpc/cpu/mpc8xxx/pci_cfg.c
diff --git a/arch/powerpc/cpu/mpc8xxx/Makefile b/arch/powerpc/cpu/mpc8xxx/Makefile index ab80dd7..95c73be 100644 --- a/arch/powerpc/cpu/mpc8xxx/Makefile +++ b/arch/powerpc/cpu/mpc8xxx/Makefile @@ -12,7 +12,6 @@ LIB = $(obj)lib8xxx.o
ifneq ($(CPU),mpc83xx) COBJS-y += cpu.o -COBJS-$(CONFIG_PCI) += pci_cfg.o endif
COBJS-$(CONFIG_OF_LIBFDT) += fdt.o diff --git a/arch/powerpc/cpu/mpc8xxx/pci_cfg.c b/arch/powerpc/cpu/mpc8xxx/pci_cfg.c deleted file mode 100644 index 53236a3..0000000 --- a/arch/powerpc/cpu/mpc8xxx/pci_cfg.c +++ /dev/null @@ -1,204 +0,0 @@ -/* - * Copyright 2009-2010 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fsl_law.h> -#include <pci.h> - -struct pci_info { - u32 cfg; -}; - -/* The cfg field is a bit mask in which each bit represents the value of - * cfg_IO_ports[] signal and the bit is set if the interface would be - * enabled based on the value of cfg_IO_ports[] signal - * - * On MPC86xx/PQ3 based systems: - * we extract cfg_IO_ports from GUTS register PORDEVSR - * - * cfg_IO_ports only exist on systems w/PCIe (we set cfg 0 for systems - * without PCIe) - */ - -#if defined(CONFIG_MPC8540) || defined(CONFIG_MPC8560) -static struct pci_info pci_config_info[] = -{ - [LAW_TRGT_IF_PCI] = { - .cfg = 0, - }, -}; -#elif defined(CONFIG_MPC8541) || defined(CONFIG_MPC8555) -static struct pci_info pci_config_info[] = -{ - [LAW_TRGT_IF_PCI] = { - .cfg = 0, - }, -}; -#elif defined(CONFIG_MPC8536) -static struct pci_info pci_config_info[] = -{ -}; -#elif defined(CONFIG_MPC8544) -static struct pci_info pci_config_info[] = -{ - [LAW_TRGT_IF_PCI] = { - .cfg = 0, - }, - [LAW_TRGT_IF_PCIE_1] = { - .cfg = (1 << 2) | (1 << 3) | (1 << 4) | (1 << 5) | - (1 << 6) | (1 << 7), - }, - [LAW_TRGT_IF_PCIE_2] = { - .cfg = (1 << 4) | (1 << 5) | (1 << 6) | (1 << 7), - }, - [LAW_TRGT_IF_PCIE_3] = { - .cfg = (1 << 6) | (1 << 7), - }, -}; -#elif defined(CONFIG_MPC8548) -static struct pci_info pci_config_info[] = -{ - [LAW_TRGT_IF_PCI_1] = { - .cfg = 0, - }, - [LAW_TRGT_IF_PCI_2] = { - .cfg = 0, - }, - /* PCI_2 is always host and we dont use iosel to determine enable/disable */ - [LAW_TRGT_IF_PCIE_1] = { - .cfg = (1 << 3) | (1 << 4) | (1 << 7), - }, -}; -#elif defined(CONFIG_MPC8568) -static struct pci_info pci_config_info[] = -{ - [LAW_TRGT_IF_PCI] = { - .cfg = 0, - }, - [LAW_TRGT_IF_PCIE_1] = { - .cfg = (1 << 3) | (1 << 4) | (1 << 7), - }, -}; -#elif defined(CONFIG_MPC8569) -static struct pci_info pci_config_info[] = -{ - [LAW_TRGT_IF_PCIE_1] = { - .cfg = (1 << 0) | (1 << 4) | (1 << 5) | (1 << 6) | (1 << 7) | - (1 << 8) | (1 << 0xc) | (1 << 0xf), - }, -}; -#elif defined(CONFIG_MPC8572) -static struct pci_info pci_config_info[] = -{ - [LAW_TRGT_IF_PCIE_1] = { - .cfg = (1 << 2) | (1 << 3) | (1 << 7) | - (1 << 0xb) | (1 << 0xc) | (1 << 0xf), - }, - [LAW_TRGT_IF_PCIE_2] = { - .cfg = (1 << 3) | (1 << 7), - }, - [LAW_TRGT_IF_PCIE_3] = { - .cfg = (1 << 7), - }, -}; -#elif defined(CONFIG_MPC8610) -static struct pci_info pci_config_info[] = -{ - [LAW_TRGT_IF_PCI_1] = { - .cfg = 0, - }, - [LAW_TRGT_IF_PCIE_1] = { - .cfg = (1 << 1) | (1 << 4), - }, - [LAW_TRGT_IF_PCIE_2] = { - .cfg = (1 << 0) | (1 << 4), - }, -}; -#elif defined(CONFIG_MPC8641) -static struct pci_info pci_config_info[] = -{ - [LAW_TRGT_IF_PCIE_1] = { - .cfg = (1 << 2) | (1 << 3) | (1 << 5) | (1 << 6) | - (1 << 7) | (1 << 0xf), - }, - [LAW_TRGT_IF_PCIE_2] = { - .cfg = (1 << 3) | (1 << 0xe) | (1 << 0xf), - }, -}; -#elif defined(CONFIG_P1011) || defined(CONFIG_P1020) || \ - defined(CONFIG_P1012) || defined(CONFIG_P1021) -static struct pci_info pci_config_info[] = -{ - [LAW_TRGT_IF_PCIE_1] = { - .cfg = (1 << 0) | (1 << 6) | (1 << 0xe) | (1 << 0xf), - }, - [LAW_TRGT_IF_PCIE_2] = { - .cfg = (1 << 0xe), - }, -}; -#elif defined(CONFIG_P1013) || defined(CONFIG_P1022) -static struct pci_info pci_config_info[] = -{ - [LAW_TRGT_IF_PCIE_1] = { - .cfg = (1 << 6) | (1 << 7) | (1 << 9) | (1 << 0xa) | - (1 << 0xb) | (1 << 0xd) | (1 << 0xe) | - (1 << 0xf) | (1 << 0x15) | (1 << 0x16) | - (1 << 0x17) | (1 << 0x18) | (1 << 0x19) | - (1 << 0x1a) | (1 << 0x1b) | (1 << 0x1c) | - (1 << 0x1d) | (1 << 0x1e) | (1 << 0x1f), - }, - [LAW_TRGT_IF_PCIE_2] = { - .cfg = (1 << 1) | (1 << 6) | (1 << 7) | (1 << 9) | - (1 << 0xd) | (1 << 0x15) | (1 << 0x16) | (1 << 0x17) | - (1 << 0x18) | (1 << 0x19) | (1 << 0x1a) | (1 << 0x1b), - }, - [LAW_TRGT_IF_PCIE_3] = { - .cfg = (1 << 0) | (1 << 1) | (1 << 6) | (1 << 7) | (1 << 9) | - (1 << 0xa) | (1 << 0xb) | (1 << 0xd) | (1 << 0x15) | - (1 << 0x16) | (1 << 0x17) | (1 << 0x18) | (1 << 0x1c), - }, -}; -#elif defined(CONFIG_P2010) || defined(CONFIG_P2020) -static struct pci_info pci_config_info[] = -{ - [LAW_TRGT_IF_PCIE_1] = { - .cfg = (1 << 0) | (1 << 2) | (1 << 4) | (1 << 6) | - (1 << 0xd) | (1 << 0xe) | (1 << 0xf), - }, - [LAW_TRGT_IF_PCIE_2] = { - .cfg = (1 << 2) | (1 << 0xe), - }, - [LAW_TRGT_IF_PCIE_3] = { - .cfg = (1 << 2) | (1 << 4), - }, -}; -#elif defined(CONFIG_FSL_CORENET) -#else -#error Need to define pci_config_info for processor -#endif - -#ifndef CONFIG_FSL_CORENET -int is_fsl_pci_cfg(enum law_trgt_if trgt, u32 io_sel) -{ - return ((1 << io_sel) & pci_config_info[trgt].cfg); -} -#endif diff --git a/arch/powerpc/include/asm/fsl_pci.h b/arch/powerpc/include/asm/fsl_pci.h index ab0f3ee..5cbe139 100644 --- a/arch/powerpc/include/asm/fsl_pci.h +++ b/arch/powerpc/include/asm/fsl_pci.h @@ -23,8 +23,6 @@
-int is_fsl_pci_cfg(enum law_trgt_if trgt, u32 io_sel); - int fsl_setup_hose(struct pci_controller *hose, unsigned long addr); int fsl_is_pci_agent(struct pci_controller *hose); void fsl_pci_init(struct pci_controller *hose, u32 cfg_addr, u32 cfg_data); diff --git a/board/freescale/mpc8544ds/mpc8544ds.c b/board/freescale/mpc8544ds/mpc8544ds.c index 31c3fad..3285cea 100644 --- a/board/freescale/mpc8544ds/mpc8544ds.c +++ b/board/freescale/mpc8544ds/mpc8544ds.c @@ -28,6 +28,7 @@ #include <asm/immap_85xx.h> #include <asm/fsl_pci.h> #include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_serdes.h> #include <asm/io.h> #include <miiphy.h> #include <libfdt.h> @@ -127,7 +128,7 @@ void pci_init_board(void) puts("\n");
#ifdef CONFIG_PCIE3 - pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_3, io_sel); + pcie_configured = is_serdes_configured(PCIE3);
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE3)){ SET_STD_PCIE_INFO(pci_info[num], 3); @@ -162,7 +163,7 @@ void pci_init_board(void) #endif
#ifdef CONFIG_PCIE1 - pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel); + pcie_configured = is_serdes_configured(PCIE1);
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ SET_STD_PCIE_INFO(pci_info[num], 1); @@ -193,7 +194,7 @@ void pci_init_board(void) #endif
#ifdef CONFIG_PCIE2 - pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_2, io_sel); + pcie_configured = is_serdes_configured(PCIE2);
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE2)){ SET_STD_PCIE_INFO(pci_info[num], 2); diff --git a/board/freescale/mpc8548cds/mpc8548cds.c b/board/freescale/mpc8548cds/mpc8548cds.c index 14c902c..ebeb897 100644 --- a/board/freescale/mpc8548cds/mpc8548cds.c +++ b/board/freescale/mpc8548cds/mpc8548cds.c @@ -29,6 +29,7 @@ #include <asm/immap_85xx.h> #include <asm/fsl_pci.h> #include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_serdes.h> #include <spd_sdram.h> #include <miiphy.h> #include <libfdt.h> @@ -332,7 +333,7 @@ void pci_init_board(void) #endif /* CONFIG_PCI2 */
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ SET_STD_PCIE_INFO(pci_info[num], 1); diff --git a/board/freescale/mpc8568mds/mpc8568mds.c b/board/freescale/mpc8568mds/mpc8568mds.c index d74fcac..71cfbf0 100644 --- a/board/freescale/mpc8568mds/mpc8568mds.c +++ b/board/freescale/mpc8568mds/mpc8568mds.c @@ -29,6 +29,7 @@ #include <asm/immap_85xx.h> #include <asm/fsl_pci.h> #include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_serdes.h> #include <spd_sdram.h> #include <i2c.h> #include <ioports.h> @@ -399,7 +400,7 @@ void pci_init_board(void) #endif
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ SET_STD_PCIE_INFO(pci_info[num], 1); diff --git a/board/freescale/mpc8569mds/mpc8569mds.c b/board/freescale/mpc8569mds/mpc8569mds.c index dc0884e..9700b8c 100644 --- a/board/freescale/mpc8569mds/mpc8569mds.c +++ b/board/freescale/mpc8569mds/mpc8569mds.c @@ -31,6 +31,7 @@ #include <asm/immap_85xx.h> #include <asm/fsl_pci.h> #include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_serdes.h> #include <asm/io.h> #include <spd_sdram.h> #include <i2c.h> @@ -579,7 +580,7 @@ void pci_init_board(void) #endif
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ SET_STD_PCIE_INFO(pci_info[num], 1); diff --git a/board/freescale/mpc8572ds/mpc8572ds.c b/board/freescale/mpc8572ds/mpc8572ds.c index 120f35c..15a4d31 100644 --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -30,6 +30,7 @@ #include <asm/fsl_pci.h> #include <asm/fsl_ddr_sdram.h> #include <asm/io.h> +#include <asm/fsl_serdes.h> #include <miiphy.h> #include <libfdt.h> #include <fdt_support.h> @@ -187,7 +188,7 @@ void pci_init_board(void)
puts("\n"); #ifdef CONFIG_PCIE3 - pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_3, io_sel); + pcie_configured = is_serdes_configured(PCIE3);
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE3)){ SET_STD_PCIE_INFO(pci_info[num], 3); @@ -219,7 +220,7 @@ void pci_init_board(void) #endif
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE2)){ SET_STD_PCIE_INFO(pci_info[num], 2); @@ -239,7 +240,7 @@ void pci_init_board(void) #endif
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ SET_STD_PCIE_INFO(pci_info[num], 1); diff --git a/board/freescale/mpc8610hpcd/mpc8610hpcd.c b/board/freescale/mpc8610hpcd/mpc8610hpcd.c index 61a635d..8abd917 100644 --- a/board/freescale/mpc8610hpcd/mpc8610hpcd.c +++ b/board/freescale/mpc8610hpcd/mpc8610hpcd.c @@ -27,6 +27,7 @@ #include <asm/immap_86xx.h> #include <asm/fsl_pci.h> #include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_serdes.h> #include <i2c.h> #include <asm/io.h> #include <libfdt.h> @@ -225,7 +226,7 @@ void pci_init_board(void) volatile immap_t *immap = (immap_t *) CONFIG_SYS_CCSRBAR; volatile ccsr_gur_t *gur = &immap->im_gur; struct fsl_pci_info pci_info[3]; - u32 devdisr, pordevsr, io_sel; + u32 devdisr, pordevsr; int first_free_busno = 0; int num = 0;
@@ -233,13 +234,9 @@ void pci_init_board(void)
devdisr = in_be32(&gur->devdisr); pordevsr = in_be32(&gur->pordevsr); - io_sel = (pordevsr & MPC8610_PORDEVSR_IO_SEL) - >> MPC8610_PORDEVSR_IO_SEL_SHIFT; - - debug (" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel);
if (pcie_configured && !(devdisr & MPC86xx_DEVDISR_PCIE1)){ SET_STD_PCIE_INFO(pci_info[num], 1); @@ -260,7 +257,7 @@ void pci_init_board(void) #endif
if (pcie_configured && !(devdisr & MPC86xx_DEVDISR_PCIE2)){ SET_STD_PCIE_INFO(pci_info[num], 2); diff --git a/board/freescale/mpc8641hpcn/mpc8641hpcn.c b/board/freescale/mpc8641hpcn/mpc8641hpcn.c index 882ff0b..e951021 100644 --- a/board/freescale/mpc8641hpcn/mpc8641hpcn.c +++ b/board/freescale/mpc8641hpcn/mpc8641hpcn.c @@ -26,6 +26,7 @@ #include <asm/immap_86xx.h> #include <asm/fsl_pci.h> #include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_serdes.h> #include <asm/io.h> #include <libfdt.h> #include <fdt_support.h> @@ -147,9 +148,7 @@ void pci_init_board(void) volatile immap_t *immap = (immap_t *) CONFIG_SYS_CCSRBAR; volatile ccsr_gur_t *gur = &immap->im_gur; uint devdisr = in_be32(&gur->devdisr); - uint io_sel = (gur->pordevsr & MPC8641_PORDEVSR_IO_SEL) - >> MPC8641_PORDEVSR_IO_SEL_SHIFT; - int pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel); + int pcie_configured = is_serdes_configured(PCIE1);
if (pcie_configured && !(devdisr & MPC86xx_DEVDISR_PCIEX1)) { SET_STD_PCIE_INFO(pci_info[num], 1); diff --git a/board/freescale/p1_p2_rdb/pci.c b/board/freescale/p1_p2_rdb/pci.c index 2a2d6b7..e95431b 100644 --- a/board/freescale/p1_p2_rdb/pci.c +++ b/board/freescale/p1_p2_rdb/pci.c @@ -24,6 +24,7 @@ #include <command.h> #include <pci.h> #include <asm/immap_85xx.h> +#include <asm/fsl_serdes.h> #include <asm/io.h> #include <asm/fsl_pci.h> #include <libfdt.h> @@ -43,7 +44,7 @@ void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); struct fsl_pci_info pci_info[2]; - u32 devdisr, pordevsr, io_sel; + u32 devdisr, pordevsr; int first_free_busno = 0; int num = 0;
@@ -51,16 +52,13 @@ void pci_init_board(void)
devdisr = in_be32(&gur->devdisr); pordevsr = in_be32(&gur->pordevsr); - io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - - debug (" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel);
if (!(pordevsr & MPC85xx_PORDEVSR_SGMII2_DIS)) printf("eTSEC2 is in sgmii mode.\n");
puts("\n"); #ifdef CONFIG_PCIE2 - pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_2, io_sel); + pcie_configured = is_serdes_configured(PCIE2);
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ SET_STD_PCIE_INFO(pci_info[num], 2); @@ -79,7 +77,7 @@ void pci_init_board(void) #endif
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ SET_STD_PCIE_INFO(pci_info[num], 1); diff --git a/board/freescale/p2020ds/p2020ds.c b/board/freescale/p2020ds/p2020ds.c index b05ef98..a40be13 100644 --- a/board/freescale/p2020ds/p2020ds.c +++ b/board/freescale/p2020ds/p2020ds.c @@ -30,6 +30,7 @@ #include <asm/fsl_pci.h> #include <asm/fsl_ddr_sdram.h> #include <asm/io.h> +#include <asm/fsl_serdes.h> #include <miiphy.h> #include <libfdt.h> #include <fdt_support.h> @@ -210,7 +211,7 @@ void pci_init_board(void)
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE2)) { SET_STD_PCIE_INFO(pci_info[num], 2); @@ -250,7 +251,7 @@ void pci_init_board(void) #endif
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE3)) { SET_STD_PCIE_INFO(pci_info[num], 3); @@ -269,7 +270,7 @@ void pci_init_board(void) #endif
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)) { SET_STD_PCIE_INFO(pci_info[num], 1); diff --git a/board/sbc8548/sbc8548.c b/board/sbc8548/sbc8548.c index 272428f..06c1eea 100644 --- a/board/sbc8548/sbc8548.c +++ b/board/sbc8548/sbc8548.c @@ -32,6 +32,7 @@ #include <asm/immap_85xx.h> #include <asm/fsl_pci.h> #include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_serdes.h> #include <spd_sdram.h> #include <netdev.h> #include <tsec.h> @@ -364,7 +365,7 @@ pci_init_board(void) setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI2); /* disable PCI2 */
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ SET_STD_PCIE_INFO(pci_info[num], 1); diff --git a/board/sbc8641d/sbc8641d.c b/board/sbc8641d/sbc8641d.c index 5bf2364..5ee8f73 100644 --- a/board/sbc8641d/sbc8641d.c +++ b/board/sbc8641d/sbc8641d.c @@ -35,6 +35,7 @@ #include <asm/immap_86xx.h> #include <asm/fsl_pci.h> #include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_serdes.h> #include <libfdt.h> #include <fdt_support.h>
@@ -210,13 +211,11 @@ void pci_init_board(void) volatile immap_t *immap = (immap_t *) CONFIG_SYS_CCSRBAR; volatile ccsr_gur_t *gur = &immap->im_gur; uint devdisr = in_be32(&gur->devdisr); - uint io_sel = (gur->pordevsr & MPC8641_PORDEVSR_IO_SEL) - >> MPC8641_PORDEVSR_IO_SEL_SHIFT; int pcie_ep; int num = 0;
#ifdef CONFIG_PCIE1 - int pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel); + int pcie_configured = is_serdes_configured(PCIE1);
if (pcie_configured && !(devdisr & MPC86xx_DEVDISR_PCIEX1)) { SET_STD_PCIE_INFO(pci_info[num], 1); diff --git a/board/tqc/tqm85xx/tqm85xx.c b/board/tqc/tqm85xx/tqm85xx.c index 527af6d..43c73e1 100644 --- a/board/tqc/tqm85xx/tqm85xx.c +++ b/board/tqc/tqm85xx/tqm85xx.c @@ -38,6 +38,7 @@ #include <asm/immap_85xx.h> #include <asm/fsl_pci.h> #include <asm/io.h> +#include <asm/fsl_serdes.h> #include <linux/compiler.h> #include <ioports.h> #include <flash.h> @@ -555,8 +556,6 @@ void pci_init_board (void) volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); u32 devdisr = in_be32(&gur->devdisr); u32 pordevsr = in_be32(&gur->pordevsr); - __maybe_unused uint io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> - MPC85xx_PORDEVSR_IO_SEL_SHIFT;
#ifdef CONFIG_PCI1 uint pci_32 = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_PCI32; @@ -598,7 +597,7 @@ void pci_init_board (void) #endif
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)) { SET_STD_PCIE_INFO(pci_info[num], 1); diff --git a/board/xes/common/fsl_8xxx_pci.c b/board/xes/common/fsl_8xxx_pci.c index 4a0965b..4135849 100644 --- a/board/xes/common/fsl_8xxx_pci.c +++ b/board/xes/common/fsl_8xxx_pci.c @@ -24,6 +24,7 @@ #include <common.h> #include <pci.h> #include <asm/fsl_pci.h> +#include <asm/fsl_serdes.h> #include <asm/io.h> #include <linux/compiler.h> #include <libfdt.h> @@ -81,11 +82,9 @@ void pci_init_board(void) volatile ccsr_gur_t *gur = &immap->im_gur; #endif u32 devdisr = in_be32(&gur->devdisr); - u32 pordevsr = in_be32(&gur->pordevsr); - __maybe_unused uint io_sel = (pordevsr & MPC8xxx_PORDEVSR_IO_SEL) >> - MPC8xxx_PORDEVSR_IO_SEL_SHIFT;
#ifdef CONFIG_PCI1 + u32 pordevsr = in_be32(&gur->pordevsr); uint pci_spd_norm = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_SPD; uint pci_32 = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_PCI32; uint pci_arb = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_ARB; @@ -114,7 +113,7 @@ void pci_init_board(void) #endif
if (pcie_configured && !(devdisr & MPC8xxx_DEVDISR_PCIE1)) { SET_STD_PCIE_INFO(pci_info[num], 1); @@ -131,7 +130,7 @@ void pci_init_board(void) #endif /* CONFIG_PCIE1 */
if (pcie_configured && !(devdisr & MPC8xxx_DEVDISR_PCIE2)) { SET_STD_PCIE_INFO(pci_info[num], 2); @@ -148,7 +147,7 @@ void pci_init_board(void) #endif /* CONFIG_PCIE2 */
if (pcie_configured && !(devdisr & MPC8xxx_DEVDISR_PCIE3)) { SET_STD_PCIE_INFO(pci_info[num], 3);
[Forgot to CC board maintainers, please review]
- Copyright 2009-2010 Freescale Semiconductor, Inc.
- project.
- MA 02111-1307 USA
-struct pci_info {
- u32 cfg;
- cfg_IO_ports[] signal and the bit is set if the interface would be
- enabled based on the value of cfg_IO_ports[] signal
- On MPC86xx/PQ3 based systems:
- we extract cfg_IO_ports from GUTS register PORDEVSR
- cfg_IO_ports only exist on systems w/PCIe (we set cfg 0 for systems
- without PCIe)
.cfg = 0,
.cfg = 0,
.cfg = 0,
.cfg = 0,
.cfg = 0,
.cfg = 0,
.cfg = (1 << 7),
.cfg = 0,
.cfg = (1 << 0xe),
#ifdef CONFIG_PCIE3
#ifdef CONFIG_PCIE1
#ifdef CONFIG_PCIE2
#ifdef CONFIG_PCIE1
#ifdef CONFIG_PCIE1
#ifdef CONFIG_PCIE1
#ifdef CONFIG_PCIE2
#ifdef CONFIG_PCIE1
- u32 devdisr, pordevsr; int first_free_busno = 0; int num = 0;
#ifdef CONFIG_PCIE1
#ifdef CONFIG_PCIE2
puts("\n");
#ifdef CONFIG_PCIE2
#ifdef CONFIG_PCIE1
#ifdef CONFIG_PCIE3
#ifdef CONFIG_PCIE1
#ifdef CONFIG_PCIE1
int pcie_ep; int num = 0;>> MPC8641_PORDEVSR_IO_SEL_SHIFT;
#ifdef CONFIG_PCIE1
#ifdef CONFIG_PCIE1
#ifdef CONFIG_PCI1
- u32 pordevsr = in_be32(&gur->pordevsr); uint pci_spd_norm = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_SPD; uint pci_32 = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_PCI32; uint pci_arb = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_ARB;
#ifdef CONFIG_PCIE1
#ifdef CONFIG_PCIE2
#ifdef CONFIG_PCIE3
-- 1.7.2.3
applied
- k
applied to 85xx
- k
applied to 85xx
- k
applied to 85xx
- k
applied to 85xx
- k
applied to 85xx
- k
[Added Chenhui Zhao signed off]
applied to 85xx
- k
[added Leo's Signed off]
applied to 85xx
- k
applied to 85xx
- k
applied to 85xx
- k
applied to 85xx
- k
Kumar Gala
