Re: [U-Boot-Users] POST tests without OCM
Yes I am using the 440EP. I was referring to all the code in cpu/ppc4xx/commproc.c, like this section:
#if defined(CONFIG_POST) || defined(CONFIG_LOGBUFFER) void post_word_store (ulong a) { volatile void *save_addr = (volatile void *)(CFG_OCM_DATA_ADDR + CFG_POST_WORD_ADDR); *(volatile ulong *) save_addr = a; }
ulong post_word_load (void) { volatile void *save_addr = (volatile void *)(CFG_OCM_DATA_ADDR + CFG_POST_WORD_ADDR); return *(volatile ulong *) save_addr; }
There are a few more functions in there that refer to the OCM. What/where is the unused GPT that you are talking about?
Thanks Craig
-----Original Message----- From: Stefan Roese [mailto:sr@denx.de] Sent: Friday, December 14, 2007 4:04 PM To: u-boot-users@lists.sourceforge.net Cc: Craig Millen Subject: Re: [U-Boot-Users] POST tests without OCM
Hi Craig,
On Friday 14 December 2007, Craig Millen wrote:
I am trying to incorporate some of the POST tests into my u-boot, but I do not have any on-chip-memory (OCM). A lot of the code appears to use OCM for storage of data/testing. Has anyone achieved this by using the cache or any other means?
We are thinking about moving this POST_WORD from OCM to an unused GPT (General Purpose Timer) register. You *are* talking about the 440EP, right? This should be possible here too.
Patches are as always welcome. :)
Best regards, Stefan
Yes, I was referring to this code too.
GPT == General Purpose Timer. For example the GPT0_COMP6 register. But this is of course application/OS dependant. Could be that your application (Linux etc) is using this GPT register. But I doubt it.
BTW: We have an ACK from AMCC that the content of these registers is retained even during reset.
Craig Millen
Stefan Roese
