[PATCH] dtoc: Correct the intarray-widening test case
This case was intended to check that widening an int array with an int does nothing. Fix it.
Reported-by: Walter Lozano walter.lozano@collabora.com Signed-off-by: Simon Glass sjg@chromium.org ---
tools/dtoc/test_fdt.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/dtoc/test_fdt.py b/tools/dtoc/test_fdt.py index 1119e6b7847..d104f3c7745 100755 --- a/tools/dtoc/test_fdt.py +++ b/tools/dtoc/test_fdt.py @@ -425,7 +425,7 @@ class TestProp(unittest.TestCase):
# Widen an array of ints with an int (should do nothing) prop = self.node.props['intarray'] - prop2 = node2.props['intarray'] + prop2 = node2.props['intval'] self.assertEqual(Type.INT, prop.type) self.assertEqual(3, len(prop.value)) prop.Widen(prop2)
Hi Simon,
Thanks for the fix!
Reviewed-by: Walter Lozano walter.lozano@collabora.com
Regards,
Walter
Hi Simon,
Applied to u-boot-dm, thanks!
Walter Lozano
