[PATCH v7 0/2] dm: uclass: don't assign aliased seq numbers
If there are aliases for an uclass, set the base for the "dynamically" allocated numbers next to the highest alias.
The actual patch is 3, the first two patches will fix some breakage which would be introduced with patch 3.
changes since v6: - added new patch to fix dev_read_alias_highest_id()
changes since v5: - added test cases for usb dt node patch
changes since v4: - new patch to fix the ethernet0 alias on Raspberry Pis. This has never been working, but wasn't a problem until recently. Patch 3 changes the allocation of the numbers and reserves possible aliases.
changes since v3: - dev_read_alias_highest_id() is only available if CONFIG_OF_CONTROL is set. Thus added an additional condition "CONFIG_IS_ENABLED(OF_CONTROL)", thanks Simon.
changes since v2: - adapt/new test cases, thanks Simon
changes since v1: - move notice about superfluous commits from commit message to this section. - fix the comment style
Michael Walle (3): usb: provide a device tree node to USB devices dm: core: fix dev_read_alias_highest_id() without libfdt dm: uclass: don't assign aliased seq numbers
arch/sandbox/dts/test.dts | 13 +++++++++-- drivers/core/uclass.c | 21 +++++++++++++----- drivers/usb/host/usb-uclass.c | 41 ++++++++++++++++++++++++++++++----- include/configs/sandbox.h | 6 ++--- include/dm/read.h | 2 ++ test/dm/eth.c | 14 ++++++------ test/dm/test-fdt.c | 22 ++++++++++++++----- test/dm/usb.c | 22 +++++++++++++++++++ 8 files changed, 113 insertions(+), 28 deletions(-)
It is possible to specify a device tree node for an USB device. This is useful if you have a static USB setup and want to use aliases which point to these nodes, like on the Raspberry Pi. The nodes are matched against their hub port number, the compatible strings are not matched for now.
Signed-off-by: Michael Walle michael@walle.cc Reviewed-by: Marek Vasut marex@denx.de Reviewed-by: Simon Glass sjg@chromium.org --- arch/sandbox/dts/test.dts | 9 ++++++++ drivers/usb/host/usb-uclass.c | 41 ++++++++++++++++++++++++++++++----- test/dm/usb.c | 22 +++++++++++++++++++ 3 files changed, 67 insertions(+), 5 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 5ce5e28476..b9255e4593 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -810,6 +810,8 @@ hub { compatible = "usb-hub"; usb,device-class = <9>; + #address-cells = <1>; + #size-cells = <0>; hub-emul { compatible = "sandbox,usb-hub"; #address-cells = <1>; @@ -838,6 +840,13 @@ };
}; + + usbstor@1 { + reg = <1>; + }; + usbstor@3 { + reg = <3>; + }; }; };
diff --git a/drivers/usb/host/usb-uclass.c b/drivers/usb/host/usb-uclass.c index cb79dfbbd5..f42c0625cb 100644 --- a/drivers/usb/host/usb-uclass.c +++ b/drivers/usb/host/usb-uclass.c @@ -494,6 +494,35 @@ static int usb_match_one_id(struct usb_device_descriptor *desc, return usb_match_one_id_intf(desc, int_desc, id); }
+static ofnode usb_get_ofnode(struct udevice *hub, int port) +{ + ofnode node; + u32 reg; + + if (!dev_has_of_node(hub)) + return ofnode_null(); + + /* + * The USB controller and its USB hub are two different udevices, + * but the device tree has only one node for both. Thus we are + * assigning this node to both udevices. + * If port is zero, the controller scans its root hub, thus we + * are using the same ofnode as the controller here. + */ + if (!port) + return dev_ofnode(hub); + + ofnode_for_each_subnode(node, dev_ofnode(hub)) { + if (ofnode_read_u32(node, "reg", ®)) + continue; + + if (reg == port) + return node; + } + + return ofnode_null(); +} + /** * usb_find_and_bind_driver() - Find and bind the right USB driver * @@ -502,13 +531,14 @@ static int usb_match_one_id(struct usb_device_descriptor *desc, static int usb_find_and_bind_driver(struct udevice *parent, struct usb_device_descriptor *desc, struct usb_interface_descriptor *iface, - int bus_seq, int devnum, + int bus_seq, int devnum, int port, struct udevice **devp) { struct usb_driver_entry *start, *entry; int n_ents; int ret; char name[30], *str; + ofnode node = usb_get_ofnode(parent, port);
*devp = NULL; debug("%s: Searching for driver\n", __func__); @@ -533,8 +563,8 @@ static int usb_find_and_bind_driver(struct udevice *parent, * find another driver. For now this doesn't seem * necesssary, so just bind the first match. */ - ret = device_bind(parent, drv, drv->name, NULL, -1, - &dev); + ret = device_bind_ofnode(parent, drv, drv->name, NULL, + node, &dev); if (ret) goto error; debug("%s: Match found: %s\n", __func__, drv->name); @@ -651,9 +681,10 @@ int usb_scan_device(struct udevice *parent, int port, if (ret) { if (ret != -ENOENT) return ret; - ret = usb_find_and_bind_driver(parent, &udev->descriptor, iface, + ret = usb_find_and_bind_driver(parent, &udev->descriptor, + iface, udev->controller_dev->seq, - udev->devnum, &dev); + udev->devnum, port, &dev); if (ret) return ret; created = true; diff --git a/test/dm/usb.c b/test/dm/usb.c index a25c2c1482..b273a515ef 100644 --- a/test/dm/usb.c +++ b/test/dm/usb.c @@ -78,6 +78,28 @@ static int dm_test_usb_multi(struct unit_test_state *uts) } DM_TEST(dm_test_usb_multi, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
+/* test that we have an associated ofnode with the usb device */ +static int dm_test_usb_fdt_node(struct unit_test_state *uts) +{ + struct udevice *dev; + ofnode node; + + state_set_skip_delays(true); + ut_assertok(usb_init()); + ut_assertok(uclass_get_device(UCLASS_MASS_STORAGE, 0, &dev)); + node = ofnode_path("/usb@1/hub/usbstor@1"); + ut_asserteq(1, ofnode_equal(node, dev_ofnode(dev))); + ut_assertok(uclass_get_device(UCLASS_MASS_STORAGE, 1, &dev)); + ut_asserteq(1, ofnode_equal(ofnode_null(), dev_ofnode(dev))); + ut_assertok(uclass_get_device(UCLASS_MASS_STORAGE, 2, &dev)); + node = ofnode_path("/usb@1/hub/usbstor@3"); + ut_asserteq(1, ofnode_equal(node, dev_ofnode(dev))); + ut_assertok(usb_stop()); + + return 0; +} +DM_TEST(dm_test_usb_fdt_node, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + static int count_usb_devices(void) { struct udevice *hub;
Applied to u-boot-dm, thanks!
If CONFIG_DM_DEV_READ_INLINE is set, dev_read_alias_highest_id() calls libfdt_get_highest_id(). But this function is only available if we have libfdt compiled in. If its not available return -1, which matches the return code for no alias found.
This fixes the following error on omapl138_lcdk: arm-linux-gnueabi-ld.bfd: drivers/built-in.o: in function `dev_read_alias_highest_id': /home/mw/repo/u-boot/include/dm/read.h:986: undefined reference to `fdtdec_get_alias_highest_id'
Signed-off-by: Michael Walle michael@walle.cc --- include/dm/read.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/dm/read.h b/include/dm/read.h index b952551d55..1c1bc3702f 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -983,6 +983,8 @@ static inline u64 dev_translate_dma_address(const struct udevice *dev,
static inline int dev_read_alias_highest_id(const char *stem) { + if (!CONFIG_IS_ENABLED(OF_LIBFDT)) + return -1; return fdtdec_get_alias_highest_id(gd->fdt_blob, stem); }
Please note, that this might lead to holes in the sequences, depending on the device tree. For example if there is only an alias "ethernet1", the next device seq number would be 2.
In particular this fixes a problem with boards which are using ethernet aliases but also might have network add-in cards like the E1000. If the board is started with the add-in card and depending on the order of the drivers, the E1000 might occupy the first ethernet device and mess up all the hardware addresses, because the devices are now shifted by one.
Also adapt the test cases to the new handling and add test cases checking the holes in the seq numbers.
Signed-off-by: Michael Walle michael@walle.cc Reviewed-by: Alex Marginean alexandru.marginean@nxp.com Tested-by: Alex Marginean alexandru.marginean@nxp.com Acked-by: Vladimir Oltean olteanv@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Michal Simek michal.simek@xilinx.com [on zcu102-revA] --- arch/sandbox/dts/test.dts | 4 ++-- drivers/core/uclass.c | 21 +++++++++++++++------ include/configs/sandbox.h | 6 +++--- test/dm/eth.c | 14 +++++++------- test/dm/test-fdt.c | 22 +++++++++++++++++----- 5 files changed, 44 insertions(+), 23 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index b9255e4593..a6e2bfd082 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -23,8 +23,8 @@ pci0 = &pci0; pci1 = &pci1; pci2 = &pci2; - remoteproc1 = &rproc_1; - remoteproc2 = &rproc_2; + remoteproc0 = &rproc_1; + remoteproc1 = &rproc_2; rtc0 = &rtc_0; rtc1 = &rtc_1; spi0 = "/spi@0"; diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index 2ab419cfe4..c3f1b73cd6 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -689,13 +689,14 @@ int uclass_unbind_device(struct udevice *dev)
int uclass_resolve_seq(struct udevice *dev) { + struct uclass *uc = dev->uclass; + struct uclass_driver *uc_drv = uc->uc_drv; struct udevice *dup; - int seq; + int seq = 0; int ret;
assert(dev->seq == -1); - ret = uclass_find_device_by_seq(dev->uclass->uc_drv->id, dev->req_seq, - false, &dup); + ret = uclass_find_device_by_seq(uc_drv->id, dev->req_seq, false, &dup); if (!ret) { dm_warn("Device '%s': seq %d is in use by '%s'\n", dev->name, dev->req_seq, dup->name); @@ -707,9 +708,17 @@ int uclass_resolve_seq(struct udevice *dev) return ret; }
- for (seq = 0; seq < DM_MAX_SEQ; seq++) { - ret = uclass_find_device_by_seq(dev->uclass->uc_drv->id, seq, - false, &dup); + if (CONFIG_IS_ENABLED(OF_CONTROL) && CONFIG_IS_ENABLED(DM_SEQ_ALIAS) && + (uc_drv->flags & DM_UC_FLAG_SEQ_ALIAS)) { + /* + * dev_read_alias_highest_id() will return -1 if there no + * alias. Thus we can always add one. + */ + seq = dev_read_alias_highest_id(uc_drv->name) + 1; + } + + for (; seq < DM_MAX_SEQ; seq++) { + ret = uclass_find_device_by_seq(uc_drv->id, seq, false, &dup); if (ret == -ENODEV) break; if (ret) diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 484a15df79..a2c9811eca 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -95,9 +95,9 @@ #endif
#define SANDBOX_ETH_SETTINGS "ethaddr=00:00:11:22:33:44\0" \ - "eth1addr=00:00:11:22:33:45\0" \ - "eth3addr=00:00:11:22:33:46\0" \ - "eth5addr=00:00:11:22:33:47\0" \ + "eth3addr=00:00:11:22:33:45\0" \ + "eth5addr=00:00:11:22:33:46\0" \ + "eth6addr=00:00:11:22:33:47\0" \ "ipaddr=1.2.3.4\0"
#define MEM_LAYOUT_ENV_SETTINGS \ diff --git a/test/dm/eth.c b/test/dm/eth.c index 1fddcaabb0..b58c9640a2 100644 --- a/test/dm/eth.c +++ b/test/dm/eth.c @@ -48,7 +48,7 @@ static int dm_test_eth_alias(struct unit_test_state *uts) ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10002000", env_get("ethact"));
- env_set("ethact", "eth1"); + env_set("ethact", "eth6"); ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10004000", env_get("ethact"));
@@ -105,7 +105,7 @@ static int dm_test_eth_act(struct unit_test_state *uts) const char *ethname[DM_TEST_ETH_NUM] = {"eth@10002000", "eth@10003000", "sbe5", "eth@10004000"}; const char *addrname[DM_TEST_ETH_NUM] = {"ethaddr", "eth5addr", - "eth3addr", "eth1addr"}; + "eth3addr", "eth6addr"}; char ethaddr[DM_TEST_ETH_NUM][18]; int i;
@@ -188,15 +188,15 @@ static int dm_test_eth_rotate(struct unit_test_state *uts)
/* Invalidate eth1's MAC address */ memset(ethaddr, '\0', sizeof(ethaddr)); - strncpy(ethaddr, env_get("eth1addr"), 17); - /* Must disable access protection for eth1addr before clearing */ - env_set(".flags", "eth1addr"); - env_set("eth1addr", NULL); + strncpy(ethaddr, env_get("eth6addr"), 17); + /* Must disable access protection for eth6addr before clearing */ + env_set(".flags", "eth6addr"); + env_set("eth6addr", NULL);
retval = _dm_test_eth_rotate1(uts);
/* Restore the env */ - env_set("eth1addr", ethaddr); + env_set("eth6addr", ethaddr); env_set("ethrotate", NULL);
if (!retval) { diff --git a/test/dm/test-fdt.c b/test/dm/test-fdt.c index 4fcae03dc5..51f2547409 100644 --- a/test/dm/test-fdt.c +++ b/test/dm/test-fdt.c @@ -361,20 +361,32 @@ static int dm_test_fdt_uclass_seq(struct unit_test_state *uts) ut_assertok(uclass_get_device(UCLASS_TEST_FDT, 2, &dev)); ut_asserteq_str("d-test", dev->name);
- /* d-test actually gets 0 */ - ut_assertok(uclass_get_device_by_seq(UCLASS_TEST_FDT, 0, &dev)); + /* + * d-test actually gets 9, because thats the next free one after the + * aliases. + */ + ut_assertok(uclass_get_device_by_seq(UCLASS_TEST_FDT, 9, &dev)); ut_asserteq_str("d-test", dev->name);
- /* initially no one wants seq 1 */ - ut_asserteq(-ENODEV, uclass_get_device_by_seq(UCLASS_TEST_FDT, 1, + /* initially no one wants seq 10 */ + ut_asserteq(-ENODEV, uclass_get_device_by_seq(UCLASS_TEST_FDT, 10, &dev)); ut_assertok(uclass_get_device(UCLASS_TEST_FDT, 0, &dev)); ut_assertok(uclass_get_device(UCLASS_TEST_FDT, 4, &dev));
/* But now that it is probed, we can find it */ - ut_assertok(uclass_get_device_by_seq(UCLASS_TEST_FDT, 1, &dev)); + ut_assertok(uclass_get_device_by_seq(UCLASS_TEST_FDT, 10, &dev)); ut_asserteq_str("f-test", dev->name);
+ /* + * And we should still have holes in our sequence numbers, that is 2 + * and 4 should not be used. + */ + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 2, + true, &dev)); + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 4, + true, &dev)); + return 0; } DM_TEST(dm_test_fdt_uclass_seq, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Michael Walle
sjg@google.com
