[U-Boot] [PATCH v1 1/4] ARM: DRA7XX: Add config file for Android with fastboot support
Signed-off-by: Angela Stegmaier angelabaker@ti.com Signed-off-by: Dileep Katta dileep.katta@linaro.org --- arch/arm/cpu/armv7/omap5/Kconfig | 5 + board/ti/dra7xx/Kconfig | 13 ++ board/ti/dra7xx/MAINTAINERS | 2 + configs/dra7xx_evm_android_defconfig | 5 + include/configs/dra7xx_evm_android.h | 313 +++++++++++++++++++++++++++++++++++ 5 files changed, 338 insertions(+) create mode 100644 configs/dra7xx_evm_android_defconfig create mode 100644 include/configs/dra7xx_evm_android.h
diff --git a/arch/arm/cpu/armv7/omap5/Kconfig b/arch/arm/cpu/armv7/omap5/Kconfig index aca862d..d8e9b2d 100644 --- a/arch/arm/cpu/armv7/omap5/Kconfig +++ b/arch/arm/cpu/armv7/omap5/Kconfig @@ -12,6 +12,11 @@ config TARGET_OMAP5_UEVM config TARGET_DRA7XX_EVM bool "TI DRA7XX"
+config TARGET_DRA7XX_EVM_ANDROID + bool "TI DRA7XX ANDROID" + ---help--- + TI DRA7XX build for Android. Enables Fastboot. + config TARGET_BEAGLE_X15 bool "BeagleBoard X15"
diff --git a/board/ti/dra7xx/Kconfig b/board/ti/dra7xx/Kconfig index 3bbd866..6837998 100644 --- a/board/ti/dra7xx/Kconfig +++ b/board/ti/dra7xx/Kconfig @@ -10,3 +10,16 @@ config SYS_CONFIG_NAME default "dra7xx_evm"
endif + +if TARGET_DRA7XX_EVM_ANDROID + +config SYS_BOARD + default "dra7xx" + +config SYS_VENDOR + default "ti" + +config SYS_CONFIG_NAME + default "dra7xx_evm_android" + +endif diff --git a/board/ti/dra7xx/MAINTAINERS b/board/ti/dra7xx/MAINTAINERS index 5ec6769..efd4f81 100644 --- a/board/ti/dra7xx/MAINTAINERS +++ b/board/ti/dra7xx/MAINTAINERS @@ -6,3 +6,5 @@ F: include/configs/dra7xx_evm.h F: configs/dra7xx_evm_defconfig F: configs/dra7xx_evm_qspiboot_defconfig F: configs/dra7xx_evm_uart3_defconfig +F: include/configs/dra7xx_evm_android.h +F: configs/dra7xx_evm_android_defconfig diff --git a/configs/dra7xx_evm_android_defconfig b/configs/dra7xx_evm_android_defconfig new file mode 100644 index 0000000..64ae4b3 --- /dev/null +++ b/configs/dra7xx_evm_android_defconfig @@ -0,0 +1,5 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" ++S:CONFIG_ARM=y ++S:CONFIG_OMAP54XX=y ++S:CONFIG_TARGET_DRA7XX_EVM_ANDROID=y diff --git a/include/configs/dra7xx_evm_android.h b/include/configs/dra7xx_evm_android.h new file mode 100644 index 0000000..68e7eec --- /dev/null +++ b/include/configs/dra7xx_evm_android.h @@ -0,0 +1,313 @@ +/* + * (C) Copyright 2013 + * Texas Instruments Incorporated. + * Lokesh Vutla lokeshvutla@ti.com + * + * Configuration settings for the TI DRA7XX board. + * See ti_omap5_common.h for omap5 common settings. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_DRA7XX_EVM_ANDROID_H +#define __CONFIG_DRA7XX_EVM_ANDROID_H + +#define CONFIG_DRA7XX +#define CONFIG_BOARD_EARLY_INIT_F + +#ifndef CONFIG_QSPI_BOOT +/* MMC ENV related defines */ +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ +#define CONFIG_ENV_SIZE (128 << 10) +#define CONFIG_ENV_OFFSET 0xE0000 +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#endif +#define CONFIG_CMD_SAVEENV + +#if (CONFIG_CONS_INDEX == 1) +#define CONSOLEDEV "ttyO0" +#elif (CONFIG_CONS_INDEX == 3) +#define CONSOLEDEV "ttyO2" +#endif +#define CONFIG_SYS_NS16550_COM1 UART1_BASE /* Base EVM has UART0 */ +#define CONFIG_SYS_NS16550_COM2 UART2_BASE /* UART2 */ +#define CONFIG_SYS_NS16550_COM3 UART3_BASE /* UART3 */ +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_SYS_OMAP_ABE_SYSCK + +/* Define the default GPT table for eMMC */ +#define PARTS_DEFAULT \ + "uuid_disk=${uuid_gpt_disk};" \ + "name=rootfs,start=2MiB,size=-,uuid=${uuid_gpt_rootfs}" + +#ifdef CONFIG_NAND +/* Define NAND information. */ +#define NANDARGS \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "nandargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "nandroot=ubi0:rootfs rw ubi.mtd=NAND.file-system,2048\0" \ + "nandrootfstype=ubifs rootwait=1\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${fdtaddr} NAND.u-boot-spl-os; " \ + "nand read ${loadaddr} NAND.kernel; " \ + "bootz ${loadaddr} - ${fdtaddr}\0" +#define NANDBOOT "run nandboot; " +#endif + +#define DFU_ALT_INFO_MMC \ + "dfu_alt_info_mmc=" \ + "boot part 0 1;" \ + "rootfs part 0 2;" \ + "MLO fat 0 1;" \ + "spl-os-args fat 0 1;" \ + "spl-os-image fat 0 1;" \ + "u-boot.img fat 0 1;" \ + "uEnv.txt fat 0 1\0" + +#define DFU_ALT_INFO_EMMC \ + "dfu_alt_info_emmc=" \ + "MLO raw 0x100 0x100 mmcpart 0;" \ + "u-boot.img raw 0x300 0x1000 mmcpart 0\0" + +#define DFU_ALT_INFO_RAM \ + "dfu_alt_info_ram=" \ + "kernel ram 0x80200000 0x4000000;" \ + "fdt ram 0x80f80000 0x80000;" \ + "ramdisk ram 0x81000000 0x4000000\0" + +#define DFUARGS \ + "dfu_bufsiz=0x10000\0" \ + DFU_ALT_INFO_MMC \ + DFU_ALT_INFO_EMMC \ + DFU_ALT_INFO_RAM + +/* Fastboot */ +#define CONFIG_CMD_FASTBOOT +#define CONFIG_ANDROID_BOOT_IMAGE +#define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR +#define CONFIG_USB_FASTBOOT_BUF_SIZE 0x2F000000 +#define CONFIG_FASTBOOT_FLASH +#define CONFIG_FASTBOOT_FLASH_MMC_DEV 1 + +#include <configs/ti_omap5_common.h> + +/* Enhance our eMMC support / experience. */ +#define CONFIG_CMD_GPT +#define CONFIG_EFI_PARTITION +#define CONFIG_PARTITION_UUIDS +#define CONFIG_CMD_PART + +/* CPSW Ethernet */ +#define CONFIG_CMD_NET /* 'bootp' and 'tftp' */ +#define CONFIG_CMD_DHCP +#define CONFIG_BOOTP_DNS /* Configurable parts of CMD_DHCP */ +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_SUBNETMASK +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_CMD_PING +#define CONFIG_CMD_MII +#define CONFIG_DRIVER_TI_CPSW /* Driver for IP block */ +#define CONFIG_MII /* Required in net/eth.c */ +#define CONFIG_PHY_GIGE /* per-board part of CPSW */ +#define CONFIG_PHYLIB + +/* SPI */ +#undef CONFIG_OMAP3_SPI +#define CONFIG_TI_QSPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SPANSION +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_SPI_FLASH_BAR +#define CONFIG_TI_SPI_MMAP +#define CONFIG_SF_DEFAULT_SPEED 48000000 +#define CONFIG_DEFAULT_SPI_MODE SPI_MODE_3 + +/* + * Default to using SPI for environment, etc. + * 0x000000 - 0x010000 : QSPI.SPL (64KiB) + * 0x010000 - 0x020000 : QSPI.SPL.backup1 (64KiB) + * 0x020000 - 0x030000 : QSPI.SPL.backup2 (64KiB) + * 0x030000 - 0x040000 : QSPI.SPL.backup3 (64KiB) + * 0x040000 - 0x140000 : QSPI.u-boot (1MiB) + * 0x140000 - 0x1C0000 : QSPI.u-boot-spl-os (512KiB) + * 0x1C0000 - 0x1D0000 : QSPI.u-boot-env (64KiB) + * 0x1D0000 - 0x1E0000 : QSPI.u-boot-env.backup1 (64KiB) + * 0x1E0000 - 0x9E0000 : QSPI.kernel (8MiB) + * 0x9E0000 - 0x2000000 : USERLAND + */ +#define CONFIG_SYS_SPI_KERNEL_OFFS 0x1E0000 +#define CONFIG_SYS_SPI_ARGS_OFFS 0x140000 +#define CONFIG_SYS_SPI_ARGS_SIZE 0x80000 +#if defined(CONFIG_QSPI_BOOT) +/* In SPL, use the environment and discard MMC support for space. */ +#ifdef CONFIG_SPL_BUILD +#undef CONFIG_SPL_MMC_SUPPORT +#undef CONFIG_SPL_MAX_SIZE +#define CONFIG_SPL_MAX_SIZE (64 << 10) /* 64 KiB */ +#endif +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#define CONFIG_ENV_SIZE (64 << 10) +#define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64 KB sectors */ +#define CONFIG_ENV_OFFSET 0x1C0000 +#define CONFIG_ENV_OFFSET_REDUND 0x1D0000 +#endif + +/* SPI SPL */ +#define CONFIG_SPL_SPI_SUPPORT +#define CONFIG_SPL_DMA_SUPPORT +#ifdef CONFIG_SPL_BUILD +#define CONFIG_TI_EDMA +#endif +#define CONFIG_SPL_SPI_LOAD +#define CONFIG_SPL_SPI_FLASH_SUPPORT +#define CONFIG_SPL_SPI_BUS 0 +#define CONFIG_SPL_SPI_CS 0 +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x80000 + +#define CONFIG_SUPPORT_EMMC_BOOT + +/* USB xHCI HOST */ +#define CONFIG_CMD_USB +#define CONFIG_USB_HOST +#define CONFIG_USB_XHCI +#define CONFIG_USB_XHCI_OMAP +#define CONFIG_USB_STORAGE +#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 + +#define CONFIG_OMAP_USB_PHY +#define CONFIG_OMAP_USB2PHY2_HOST + +/* USB GADGET */ +#define CONFIG_USB_DWC3_PHY_OMAP +#define CONFIG_USB_DWC3_OMAP +#define CONFIG_USB_DWC3 +#define CONFIG_USB_DWC3_GADGET + +#define CONFIG_USB_GADGET +#define CONFIG_MUSB_GADGET +#define CONFIG_MUSB_PIO_ONLY +#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_VBUS_DRAW 2 +#define CONFIG_G_DNL_MANUFACTURER "Texas Instruments" +#define CONFIG_G_DNL_VENDOR_NUM 0x0451 +#define CONFIG_G_DNL_PRODUCT_NUM 0xd022 +#define CONFIG_USB_GADGET_DUALSPEED + +/* USB Device Firmware Update support */ +#define CONFIG_DFU_FUNCTION +#define CONFIG_DFU_RAM +#define CONFIG_CMD_DFU + +#define CONFIG_DFU_MMC +#define CONFIG_DFU_RAM + +/* SATA */ +#define CONFIG_BOARD_LATE_INIT +#define CONFIG_CMD_SCSI +#define CONFIG_LIBATA +#define CONFIG_SCSI_AHCI +#define CONFIG_SCSI_AHCI_PLAT +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) + +/* NAND support */ +#ifdef CONFIG_NAND +/* NAND: device related configs */ +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_BUSWIDTH_16BIT +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +/* NAND: driver related configs */ +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_NAND_OMAP_ELM +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13, 14, 15, 16, 17, \ + 18, 19, 20, 21, 22, 23, 24, 25, \ + 26, 27, 28, 29, 30, 31, 32, 33, \ + 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 43, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56, 57, } +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 14 +#define MTDIDS_DEFAULT "nand0=nand.0" +#define MTDPARTS_DEFAULT "mtdparts=nand.0:" \ + "128k(NAND.SPL)," \ + "128k(NAND.SPL.backup1)," \ + "128k(NAND.SPL.backup2)," \ + "128k(NAND.SPL.backup3)," \ + "256k(NAND.u-boot-spl-os)," \ + "1m(NAND.u-boot)," \ + "128k(NAND.u-boot-env)," \ + "128k(NAND.u-boot-env.backup1)," \ + "8m(NAND.kernel)," \ + "-(NAND.file-system)" +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 +/* NAND: SPL related configs */ +#ifdef CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_AM33XX_BCH +#endif +/* NAND: SPL falcon mode configs */ +#ifdef CONFIG_SPL_OS_BOOT +#define CONFIG_CMD_SPL_NAND_OFS 0x00080000 /* os-boot params*/ +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ +#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 +#endif +#endif /* !CONFIG_NAND */ + +/* Parallel NOR Support */ +#if defined(CONFIG_NOR) +/* NOR: device related configs */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_FLASH_SIZE (64 * 1024 * 1024) /* 64 MB */ +/* #define CONFIG_INIT_IGNORE_ERROR */ +#undef CONFIG_SYS_NO_FLASH +#define CONFIG_CMD_FLASH +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#define CONFIG_SYS_FLASH_PROTECTION +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_FLASH_CFI_MTD +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_FLASH_BASE (0x08000000) +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE +/* Reduce SPL size by removing unlikey targets */ +#ifdef CONFIG_NOR_BOOT +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_SECT_SIZE (128 * 1024) /* 128 KiB */ +#define MTDIDS_DEFAULT "nor0=physmap-flash.0" +#define MTDPARTS_DEFAULT "mtdparts=physmap-flash.0:" \ + "1m(NOR.u-boot)," \ + "128k(NOR.u-boot-env)," \ + "128k(NOR.u-boot-env.backup1)," \ + "256k(NOR.u-boot-spl-os)," \ + "8m(NOR.kernel)," \ + "-(NOR.rootfs)" +#define CONFIG_ENV_OFFSET 0x00100000 +#define CONFIG_ENV_OFFSET_REDUND 0x00120000 +#endif +#endif /* NOR support */ + +#endif /* __CONFIG_DRA7XX_EVM_ANDROID_H */
g_dnl_gadget_register() fails for dra7xx dwc3 gadget when running cmd_fastboot. Calling board_usb_init() fixes this.
Signed-off-by: Angela Stegmaier angelabaker@ti.com Signed-off-by: Dileep Katta dileep.katta@linaro.org --- common/cmd_fastboot.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/common/cmd_fastboot.c b/common/cmd_fastboot.c index 346ab80..d7b8f6d 100644 --- a/common/cmd_fastboot.c +++ b/common/cmd_fastboot.c @@ -10,11 +10,13 @@ #include <common.h> #include <command.h> #include <g_dnl.h> +#include <usb.h>
static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { int ret;
+ board_usb_init(0, USB_INIT_DEVICE); g_dnl_clear_detach(); ret = g_dnl_register("usb_dnl_fastboot"); if (ret)
Hi Dileep,
- board_usb_init(0, USB_INIT_DEVICE); g_dnl_clear_detach(); ret = g_dnl_register("usb_dnl_fastboot"); if (ret)
Acked-by: Lukasz Majewski l.majewski@samsung.com
Hi Dileep,
-----Original Message----- From: Dileep Katta [mailto:dileep.katta@linaro.org] Sent: Tuesday, March 03, 2015 5:11 AM To: u-boot@lists.denx.de; robherring2@gmail.com; Rini, Tom; rob.herring@linaro.org; srae@broadcom.com; l.majewski@samsung.com; Stegmaier, Angela Cc: Dileep Katta Subject: [U-Boot][PATCH v2 2/4] fastboot: call board_usb_init() to enable usb
The controller index should be configurable. Also, should board_usb_cleanup be called at the end?
Thanks, Angela
g_dnl_clear_detach(); ret = g_dnl_register("usb_dnl_fastboot"); if (ret) -- 1.8.3.2
On Wed, Mar 04, 2015 at 05:05:11PM +0000, Stegmaier, Angela wrote:
Hi Dileep,
I _really_ _really_ want to see if we can modify things so that we don't have to sprinkle ever gadget driver with a cleanup() and every gadget too if we don't have to. Thanks!
Hi Dileep,
enable
usb
*const
argv[]) { int ret;
Most of the boards have board_usb_cleanup() as just a stub. For some, the function is not present, and adding board_usb_cleanup() here breaks the build for others with fastboot enabled.
-- Tom
Regards, Dileep
Hi Dileep,
enable
usb
*const
argv[]) { int ret;
That's a problem that needs fixing since those boards without a functional board_usb_cleanup() are likely causing breakage in Linux.
Hi Dileep,
enable
usb
*const
argv[]) { int ret;
We are not getting controller Index as an argument for fastboot function. Might have to add extra logic to get the same. But do we need configurable index here for fastboot? Experts, please advise.
Also, should
don't
Will add the board_usb_cleanup() function at the end.
-- Tom
Hi Dileep, Marek
Hi Dileep,
enable
usb
*const
argv[]) { int ret;
Some time ago we have changed syntax of all gadget related commands (from e.g. dfu mmc 0 -> dfu 0 mmc 0) to support different controllers. Rationale was to prepare ourself for future changes.
IMHO it would be feasible to do the same with fastboot command. However, lets wait for Marek's opinion.
Also, should
don't
+1
-- Tom
On Thursday, March 12, 2015 at 09:55:57 AM, Lukasz Majewski wrote:
Hi!
I'm all for that.
Best regards, Marek Vasut
g_dnl_gadget_register() fails for dra7xx dwc3 gadget when running cmd_fastboot. Calling board_usb_init() to fix this. fastboot command is now added with an optional controller index argument with default value as 0, to facilitate configurable controller index.
Signed-off-by: Angela Stegmaier angelabaker@ti.com Signed-off-by: Dileep Katta dileep.katta@linaro.org --- Changes in v2: - Changed fastboot command to facilitate passing controller index - Added board_usb_cleanup() This patch considers the following change by Inha Song, without which the build will be broken on BeagleBone Black platform https://patchwork.ozlabs.org/patch/430303/ common/cmd_fastboot.c | 15 ++++++++++++--- 1 file changed, 12 insertions(+), 3 deletions(-)
diff --git a/common/cmd_fastboot.c b/common/cmd_fastboot.c index 346ab80..9ca4a2f 100644 --- a/common/cmd_fastboot.c +++ b/common/cmd_fastboot.c @@ -10,11 +10,19 @@ #include <common.h> #include <command.h> #include <g_dnl.h> +#include <usb.h>
static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { int ret; + int controller_index = 0;
+ if (argc == 2) { + char *usb_controller = argv[1]; + controller_index = simple_strtoul(usb_controller, NULL, 0); + } + + board_usb_init(controller_index, USB_INIT_DEVICE); g_dnl_clear_detach(); ret = g_dnl_register("usb_dnl_fastboot"); if (ret) @@ -36,12 +44,13 @@ static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[])
g_dnl_unregister(); g_dnl_clear_detach(); + board_usb_cleanup(controller_index, USB_INIT_DEVICE); return CMD_RET_SUCCESS; }
U_BOOT_CMD( - fastboot, 1, 0, do_fastboot, + fastboot, 2, 0, do_fastboot, "use USB Fastboot protocol", - "\n" - " - run as a fastboot usb device" + "[<USB_controller>]\n" + " - run as a fastboot usb device via <USB_controller>" );
Hi Dileep,
Changes in v2:
index
if (argc == 2) {
NULL, 0);
- board_usb_init(controller_index, USB_INIT_DEVICE); g_dnl_clear_detach(); ret = g_dnl_register("usb_dnl_fastboot"); if (ret)
@@ -36,12 +44,13 @@ static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) g_dnl_unregister(); g_dnl_clear_detach();
- board_usb_cleanup(controller_index, USB_INIT_DEVICE); return CMD_RET_SUCCESS;
U_BOOT_CMD(
- fastboot, 2, 0, do_fastboot, "use USB Fastboot protocol",
- "\nLukasz Majewski l.majewski@samsung.com"
- "[<USB_controller>]\n"
- " - run as a fastboot usb device via <USB_controller>"
Since I'm not CC'ed to all patches, I assume that this work would go via other tree?
Hi Lukasz,
On 13 March 2015 at 13:23, Lukasz Majewski l.majewski@samsung.com wrote:
Hi Dileep,
if (argc == 2) {
NULL, 0);
U_BOOT_CMD(
"\nLukasz Majewski <l.majewski@samsung.com>"
Other patches are TI board specific and I am working on next version of the patches as per the review comments. I felt that this is generic functionality and hence sent it separately. Do you want me send all patches?
Regards, Dileep
-- Best regards,
Lukasz Majewski
Samsung R&D Institute Poland (SRPOL) | Linux Platform Group
On Sat, 14 Mar 2015 00:58:51 +0530 Dileep Katta dileep.katta@linaro.org wrote:
Hi Lukasz,
Hi Dileep,
if (argc == 2) {
NULL, 0);
U_BOOT_CMD(
No, it is not necessary. Regarding above, I assume that Tom will probably fetch those patches.
I was just concern about tree to which this patch should belong.
Regards, Lukasz
Regards, Dileep
-- Best regards,
Lukasz Majewski
Experts, Please send your valuable comments if this patch needs any change.
Regards, Dileep
Hi Lukasz,
Hi Dileep,
if (argc == 2) {
NULL, 0);
U_BOOT_CMD(
Regards, Lukasz
Regards, Dileep
-- Best regards,
Lukasz Majewski
Assuming everything has acks I'll pick it up for the next release, thanks.
Regards, Dileep
Hi Lukasz,
Hi Dileep,
if (argc == 2) {
NULL, 0);
U_BOOT_CMD(
Regards, Lukasz
Regards, Dileep
-- Best regards,
Lukasz Majewski
Lukasz can pick it through the correct tree for next release just fine I think.
Hi Marek,
And adding Lukasz to CC would really speed up the process :-)
Adds the registers to get the serial number of dra7xx boards. Serial# environment variable will be set if not done already. This will be useful to show correct information in "fastboot devices" commands.
Signed-off-by: Angela Stegmaier angelabaker@ti.com Signed-off-by: Dileep Katta dileep.katta@linaro.org --- arch/arm/cpu/armv7/omap5/prcm-regs.c | 2 ++ arch/arm/include/asm/omap_common.h | 2 ++ board/ti/dra7xx/evm.c | 11 +++++++++++ 3 files changed, 15 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap5/prcm-regs.c b/arch/arm/cpu/armv7/omap5/prcm-regs.c index 0745d42..020a964 100644 --- a/arch/arm/cpu/armv7/omap5/prcm-regs.c +++ b/arch/arm/cpu/armv7/omap5/prcm-regs.c @@ -440,6 +440,8 @@ struct omap_sys_ctrl_regs const dra7xx_ctrl = { .control_emif1_sdram_config_ext = 0x4AE0C144, .control_emif2_sdram_config_ext = 0x4AE0C148, .control_wkup_ldovbb_mpu_voltage_ctrl = 0x4AE0C158, + .control_std_fuse_die_id_3 = 0x4AE0C210, + .control_std_fuse_prod_id_0 = 0x4AE0C214, .control_padconf_mode = 0x4AE0C5A0, .control_xtal_oscillator = 0x4AE0C5A4, .control_i2c_2 = 0x4AE0C5A8, diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 323952f..b329803 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -362,6 +362,8 @@ struct omap_sys_ctrl_regs { u32 control_core_control_io1; u32 control_core_control_io2; u32 control_id_code; + u32 control_std_fuse_die_id_3; + u32 control_std_fuse_prod_id_0; u32 control_std_fuse_opp_bgap; u32 control_ldosram_iva_voltage_ctrl; u32 control_ldosram_mpu_voltage_ctrl; diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 6522241..e20d950 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -88,10 +88,21 @@ int board_init(void) int board_late_init(void) { #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + char serialno[72]; + uint32_t serialno_lo, serialno_hi; + if (omap_revision() == DRA722_ES1_0) setenv("board_name", "dra72x"); else setenv("board_name", "dra7xx"); + + if (!getenv("serial#")) { + printf("serial# not set, setting...\n"); + serialno_lo = readl((*ctrl)->control_std_fuse_die_id_3); + serialno_hi = readl((*ctrl)->control_std_fuse_prod_id_0); + sprintf(serialno, "%08x%08x", serialno_hi, serialno_lo); + setenv("serial#", serialno); + } #endif return 0; }
Hi Dileep,
- .control_std_fuse_die_id_3 = 0x4AE0C210,
- .control_std_fuse_prod_id_0 = 0x4AE0C214, .control_padconf_mode = 0x4AE0C5A0, .control_xtal_oscillator = 0x4AE0C5A4, .control_i2c_2 = 0x4AE0C5A8,
- u32 control_std_fuse_die_id_3;
- u32 control_std_fuse_prod_id_0; u32 control_std_fuse_opp_bgap; u32 control_ldosram_iva_voltage_ctrl; u32 control_ldosram_mpu_voltage_ctrl;
- char serialno[72];
- uint32_t serialno_lo, serialno_hi;
- if (omap_revision() == DRA722_ES1_0) setenv("board_name", "dra72x"); else setenv("board_name", "dra7xx");
- if (!getenv("serial#")) {
serialno_lo =
serialno_hi =
serialno_lo);
#endif return 0; }
Reviewed-by: Lukasz Majewski l.majewski@samsung.com
I wish we could do this a bit more generically but...
Are these serial numbers of dra7 "boards"? they dont match up with commit message.
http://www.ti.com/lit/ug/spruhz6/spruhz6.pdf See section "AM572x Device Identification" on page 357 you would rather want to use CTRL_WKUP_STD_FUSE_DIE_ID_0,1,2,3
Is'nt better to unify with existing requirements such as arch/arm/cpu/armv7/omap3/sys_info.c dieid_num_r() such that every omap3,4,5,dra7 SoCs can use the same function in different ways (example: usb_fake_mac_from_die_id in omap5_uevm and panda) ?
here we do fastboot_serial_from_die_id? Standardizing such information allows us to just hook up the missing information for various SoCs and reuse the common code.
#endif return 0; }
Signed-off-by: Angela Stegmaier angelabaker@ti.com Signed-off-by: Dileep Katta dileep.katta@linaro.org --- board/ti/dra7xx/Makefile | 1 + board/ti/dra7xx/fastboot.c | 45 ++++++++++++++++++++++++++++++++++++ common/cmd_bootm.c | 5 ++++ drivers/usb/gadget/f_fastboot.c | 5 ++++ include/configs/dra7xx_evm_android.h | 14 +++++++++++ 5 files changed, 70 insertions(+) create mode 100644 board/ti/dra7xx/fastboot.c
diff --git a/board/ti/dra7xx/Makefile b/board/ti/dra7xx/Makefile index 434e8d1..ae730ae 100644 --- a/board/ti/dra7xx/Makefile +++ b/board/ti/dra7xx/Makefile @@ -6,3 +6,4 @@ #
obj-y := evm.o +obj-$(CONFIG_CMD_FASTBOOT) += fastboot.o diff --git a/board/ti/dra7xx/fastboot.c b/board/ti/dra7xx/fastboot.c new file mode 100644 index 0000000..e05010d --- /dev/null +++ b/board/ti/dra7xx/fastboot.c @@ -0,0 +1,45 @@ +/* + * (C) Copyright 2013 + * Texas Instruments Incorporated, <www.ti.com> + * + * Lokesh Vutla lokeshvutla@ti.com + * + * Based on previous work by: + * Aneesh V aneesh@ti.com + * Steve Sakoman steve@sakoman.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <config.h> + + +int fb_set_reboot_flag(void) +{ + /* clear all reset events */ + __raw_writel(DRA7XX_PRM_RSTST_CLR, PRM_RSTST); + strncpy((char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE, "bootloader", + DRA7XX_REBOOT_REASON_SIZE - 1); + *(((char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE) + + DRA7XX_REBOOT_REASON_SIZE - 1) = '\0'; + /* trigger warm reset */ + __raw_writel(DRA7XX_PRM_RSTCTRL_RESET_WARM_BIT, DRA7XX_PRM_RSTCTRL); + + return 0; +} + +int fb_check_reboot_flag(void) +{ + /* Check if we are coming from a warm reset */ + if (__raw_readl(DRA7XX_PRM_RSTST) & DRA7XX_PRM_RSTST_RESET_WARM_BIT) + if (!strncmp((const char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE, + "bootloader", DRA7XX_REBOOT_REASON_SIZE)) { + strncpy((char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE, "", + DRA7XX_REBOOT_REASON_SIZE); + return 0; + } + + return 1; +} diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 48199bf..00791be 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -729,6 +729,11 @@ int do_booti(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int ret;
+#if defined(CONFIG_CMD_FASTBOOT) + if (!fb_check_reboot_flag()) + do_fastboot(cmdtp, flag, argc, argv); +#endif + /* Consume 'booti' */ argc--; argv++;
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 206b6d1..a450357 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -332,6 +332,11 @@ int __weak fb_set_reboot_flag(void) return -ENOSYS; }
+int __weak fb_check_reboot_flag(void) +{ + return -ENOSYS; +} + static void cb_reboot(struct usb_ep *ep, struct usb_request *req) { char *cmd = req->buf; diff --git a/include/configs/dra7xx_evm_android.h b/include/configs/dra7xx_evm_android.h index 68e7eec..2038e00 100644 --- a/include/configs/dra7xx_evm_android.h +++ b/include/configs/dra7xx_evm_android.h @@ -310,4 +310,18 @@ #endif #endif /* NOR support */
+#define DRA7XX_PUBLIC_SAR_RAM_1_FREE (0x4AE26000 + 0xFE0) +#define DRA7XX_PRM_RSTCTRL_RESET_WARM_BIT (1<<0) +#define DRA7XX_PRM_RSTST_RESET_WARM_BIT (1<<1) +#define DRA7XX_PRM_RSTST 0x4AE07D04 +#define DRA7XX_PRM_RSTCTRL 0x4AE07D00 +#define DRA7XX_PRM_RSTST_CLR 0xfff +#define DRA7XX_REBOOT_REASON_SIZE 0xf + +#define CONFIG_BOARD_MACH_TYPE 4070 +#define MEMORY_BASE 0x80000000 +#define CONFIG_ADDR_ATAGS (MEMORY_BASE + 0x100) +#define CONFIG_ADDR_DOWNLOAD (MEMORY_BASE + 0x02000000) +#define DEVICE_TREE 0x82f80000 + #endif /* __CONFIG_DRA7XX_EVM_ANDROID_H */
- (C) Copyright 2013
- Texas Instruments Incorporated, <www.ti.com>
- Lokesh Vutla lokeshvutla@ti.com
- Based on previous work by:
- Aneesh V aneesh@ti.com
- Steve Sakoman steve@sakoman.com
Does this reset immediately? If so, then you will fail to send a response to the client.
return 1;
Part of the booti command? First, booti is for arm64 Image files. How does this work for you?
More importantly, this should not be tied into any bootX command. It should probably be done in a boot script. If the flag is set, the board code can set some environment variable. Then the boot script can run the fastboot command if the env var is set.
return -ENOSYS;
You shouldn't need this anymore, right?
Or this?
Use fdt_addr_r env var instead?
Rob
You need a full commit message as I don't really understand what this is supposed to be doing or why it's needed.
return 1;
return -ENOSYS;
These defines, if really needed, need to end up somewhere under arch/arm/include/asm/arch-omap5/ and the code using them somewhere under arch/arm/cpu/armv7/omap-common/
Or this?
Yeah, this doesn't look right, nor genericially done for something I imagine "everyone" doing fastboot would want to get at.
Rob _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Dileep,
- /* clear all reset events */
- __raw_writel(DRA7XX_PRM_RSTST_CLR, PRM_RSTST);
- strncpy((char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE, "bootloader",
- *(((char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE) +
'\0';
- /* trigger warm reset */
- __raw_writel(DRA7XX_PRM_RSTCTRL_RESET_WARM_BIT,
- /* Check if we are coming from a warm reset */
- if (__raw_readl(DRA7XX_PRM_RSTST) &
"bootloader",
strncpy((char
- return 1;
- if (!fb_check_reboot_flag())
- /* Consume 'booti' */ argc--; argv++;
- return -ENOSYS;
Corrected Tom Rini's mail id.
Regards, Dileep
---help---
endif
+config SYS_BOARD
default "dra7xx"
+config SYS_VENDOR
default "ti"
- Texas Instruments Incorporated.
- Configuration settings for the TI DRA7XX board.
- See ti_omap5_common.h for omap5 common settings.
"${optargs} " \
"run nandargs; " \
"boot part 0 1;" \
"MLO fat 0 1;" \
+#define DFUARGS \
DFU_ALT_INFO_MMC \
DFU_ALT_INFO_EMMC \
DFU_ALT_INFO_RAM
- Default to using SPI for environment, etc.
- 0x000000 - 0x010000 : QSPI.SPL (64KiB)
- 0x010000 - 0x020000 : QSPI.SPL.backup1 (64KiB)
- 0x020000 - 0x030000 : QSPI.SPL.backup2 (64KiB)
- 0x030000 - 0x040000 : QSPI.SPL.backup3 (64KiB)
- 0x040000 - 0x140000 : QSPI.u-boot (1MiB)
- 0x140000 - 0x1C0000 : QSPI.u-boot-spl-os (512KiB)
- 0x1C0000 - 0x1D0000 : QSPI.u-boot-env (64KiB)
- 0x1D0000 - 0x1E0000 : QSPI.u-boot-env.backup1 (64KiB)
- 0x1E0000 - 0x9E0000 : QSPI.kernel (8MiB)
- 0x9E0000 - 0x2000000 : USERLAND
"128k(NAND.SPL)," \
"1m(NOR.u-boot)," \
"8m(NOR.kernel)," \
"-(NOR.rootfs)"
1.8.3.2
Hi Dileep,
- bool "TI DRA7XX ANDROID"
- ---help---
- TI DRA7XX build for Android. Enables Fastboot.
endif
No needed blank line
+config SYS_BOARD
- default "dra7xx"
+config SYS_VENDOR
- default "ti"
- default "dra7xx_evm_android"
ditto
Please use SZ_1K instead of << 10
- "uuid_disk=${uuid_gpt_disk};" \
- "name=rootfs,start=2MiB,size=-,uuid=${uuid_gpt_rootfs}"
- "mtdids=" MTDIDS_DEFAULT "\0" \
- "mtdparts=" MTDPARTS_DEFAULT "\0" \
- "nandargs=setenv bootargs console=${console} " \
"${optargs} " \
- "nandroot=ubi0:rootfs rw ubi.mtd=NAND.file-system,2048\0" \
- "nandrootfstype=ubifs rootwait=1\0" \
- "nandboot=echo Booting from nand ...; " \
"run nandargs; " \
- "dfu_alt_info_mmc=" \
- "boot part 0 1;" \
- "rootfs part 0 2;" \
- "MLO fat 0 1;" \
- "spl-os-args fat 0 1;" \
- "spl-os-image fat 0 1;" \
- "u-boot.img fat 0 1;" \
- "uEnv.txt fat 0 1\0"
- "dfu_alt_info_emmc=" \
- "MLO raw 0x100 0x100 mmcpart 0;" \
- "u-boot.img raw 0x300 0x1000 mmcpart 0\0"
- "dfu_alt_info_ram=" \
- "kernel ram 0x80200000 0x4000000;" \
- "fdt ram 0x80f80000 0x80000;" \
- "ramdisk ram 0x81000000 0x4000000\0"
+#define DFUARGS \
- "dfu_bufsiz=0x10000\0" \
- DFU_ALT_INFO_MMC \
- DFU_ALT_INFO_EMMC \
- DFU_ALT_INFO_RAM
SZ_1K Please use globally.
17, \
25, \
33, \
41, \
49, \
"128k(NAND.SPL)," \
"1m(NOR.u-boot)," \
"8m(NOR.kernel)," \
"-(NOR.rootfs)"
Despite some minor comments,
I _really_ don't like how we're duplicating large hunks of dra7xx_evm.h. The first question is, what parts of this are not appropriate to just do in dra7xx_evm.h directly? And the second question would be, which of those cannot simply be done via Kconfig choices.
Hi Tom and Lukasz,
-- Tom
Discussed this with Angela from TI, and arrived at a common header file so that the duplication could be avoided. Will send a follow-up patch with the update. Thanks for the comments.
Regards, Dileep
On Thu, Mar 12, 2015 at 12:01:15PM +0530, Dileep Katta wrote:
Hi Tom and Lukasz,
Note that I'm still skeptical that there's things that can't just be Kconfig choices and the rest just be in dra7xx_evm.h. Sort out and come up with a common flash/etc layout and so forth. Thanks!
- Added new configuration for Android fastboot - This is based on following patch modified accordingly http://git.omapzoom.org/?p=repo/u-boot.git;a=commit;h=b2e04f92b5d91c708b6fd6...
Signed-off-by: Angela Stegmaier angelabaker@ti.com Signed-off-by: Dileep Katta dileep.katta@linaro.org --- Changes in v2: - Merged the header file content to existing dra7xx_evm.h to avoid duplication - Removed unnecessary definitions as per comments
board/ti/dra7xx/MAINTAINERS | 1 + configs/dra7xx_evm_android_defconfig | 5 +++++ include/configs/dra7xx_evm.h | 30 ++++++++++++++++++++++++++++++ 3 files changed, 36 insertions(+) create mode 100644 configs/dra7xx_evm_android_defconfig
diff --git a/board/ti/dra7xx/MAINTAINERS b/board/ti/dra7xx/MAINTAINERS index 5ec6769..1b5ae71 100644 --- a/board/ti/dra7xx/MAINTAINERS +++ b/board/ti/dra7xx/MAINTAINERS @@ -6,3 +6,4 @@ F: include/configs/dra7xx_evm.h F: configs/dra7xx_evm_defconfig F: configs/dra7xx_evm_qspiboot_defconfig F: configs/dra7xx_evm_uart3_defconfig +F: configs/dra7xx_evm_android_defconfig diff --git a/configs/dra7xx_evm_android_defconfig b/configs/dra7xx_evm_android_defconfig new file mode 100644 index 0000000..5fdce85 --- /dev/null +++ b/configs/dra7xx_evm_android_defconfig @@ -0,0 +1,5 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1,DRA7XX_ANDROID" ++S:CONFIG_ARM=y ++S:CONFIG_OMAP54XX=y ++S:CONFIG_TARGET_DRA7XX_EVM=y diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index dee2b11..dd20e08 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -43,6 +43,16 @@ "uuid_disk=${uuid_gpt_disk};" \ "name=rootfs,start=2MiB,size=-,uuid=${uuid_gpt_rootfs}"
+#ifdef CONFIG_DRA7XX_ANDROID +/* Fastboot */ +#define CONFIG_CMD_FASTBOOT +#define CONFIG_ANDROID_BOOT_IMAGE +#define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR +#define CONFIG_USB_FASTBOOT_BUF_SIZE 0x2F000000 +#define CONFIG_FASTBOOT_FLASH +#define CONFIG_FASTBOOT_FLASH_MMC_DEV 1 +#endif + #include <configs/ti_omap5_common.h>
/* Enhance our eMMC support / experience. */ @@ -115,7 +125,11 @@ #define CONFIG_SPL_SPI_SUPPORT #define CONFIG_SPL_SPI_LOAD #define CONFIG_SPL_SPI_FLASH_SUPPORT +#ifdef CONFIG_DRA7XX_ANDROID +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x80000 +#else #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x40000 +#endif
@@ -130,6 +144,22 @@ #define CONFIG_OMAP_USB_PHY #define CONFIG_OMAP_USB2PHY2_HOST
+/* USB GADGET */ +#define CONFIG_USB_GADGET +#define CONFIG_MUSB_GADGET +#define CONFIG_MUSB_PIO_ONLY +#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_VBUS_DRAW 2 +#define CONFIG_G_DNL_MANUFACTURER "Texas Instruments" +#ifdef CONFIG_CMD_FASTBOOT +#define CONFIG_G_DNL_VENDOR_NUM 0x0451 +#define CONFIG_G_DNL_PRODUCT_NUM 0xd022 +#else +#define CONFIG_G_DNL_VENDOR_NUM 0x0403 +#define CONFIG_G_DNL_PRODUCT_NUM 0xBD00 +#endif +#define CONFIG_USB_GADGET_DUALSPEED + /* SATA */ #define CONFIG_BOARD_LATE_INIT #define CONFIG_CMD_SCSI
[snip]
No, just enable fastboot. There's a growing population of people whose workflow is "use fastboot to shove a new test kernel at my device" that aren't strictly using Android, lets enable them.
Why are you moving U-Boot so much higher in SPI flash?
This board doesn't have MUSB, DWC3 only.
Why can't we always use one vid/pid?
Hi Tom,
[snip]
OK, will enable fastboot unconditional. Now there is no much difference for android_defconfig, but will still keep separate config for future changes.
This is done to accommodate larger size MLO.
Thanks. DWC3 is enabled in dwc3_gadget developer branch of DFU custodian tree. Will submit the updated patch on top of the same
As we are restricted to use the vid which fastboot host application knows, the other/original vid/pid kept intact for the dependent functionality, if any. Will check if 0x0403/0xBD00 could be removed.
-- Tom
Regards, Dileep
On Thu, Mar 19, 2015 at 02:42:16AM +0530, Dileep Katta wrote:
Hi Tom,
[snip]
I remain unconvinced that we need a separate config upstream still.
Oh that's right. Some parts can be made with a larger SRAM and thus we could use a larger MLO. But are we? What functionality would we be shoving into a larger MLO that would make sense to do this really? Frankly I had been thinking that in these parts it makes more sense to jump to full U-Boot and skip SPL rather than make SPL be very complicated.
I think we can just always use the VID/PID that fastboot knows, DFU isn't nearly so picky and other gadget use cases don't care I believe.
Hi Tom,
Hi Tom,
[snip]
keep
Will remove separate config.
Strictly speaking, its not required now, and can be changed when required.
knows,
Will use fastboot aware VID/PID pair, always.
-- Tom
Regards, Dileep
- Fastboot is enable by default for DRA7XX - This is based on following patch modified accordingly http://git.omapzoom.org/?p=repo/u-boot.git;a=commit;h=b2e04f92b5d91c708b6fd6...
Signed-off-by: Angela Stegmaier angelabaker@ti.com Signed-off-by: Dileep Katta dileep.katta@linaro.org --- Changes in v2: - Merged the header file content to existing dra7xx_evm.h to avoid duplication - Removed unnecessary definitions as per comments Changes in v3: - Added the changes on dwc3_gadget developer branch of DFU tree - Added the changes as part of existing dra7xx_evm_defconfig - Enabled fastboot by default - Kept fastboot aware VID/PID only - reverted change made for U-Boot offset
include/configs/dra7xx_evm.h | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index e94b618..7acd907 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -84,6 +84,14 @@ DFU_ALT_INFO_EMMC \ DFU_ALT_INFO_RAM
+/* Fastboot */ +#define CONFIG_CMD_FASTBOOT +#define CONFIG_ANDROID_BOOT_IMAGE +#define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR +#define CONFIG_USB_FASTBOOT_BUF_SIZE 0x2F000000 +#define CONFIG_FASTBOOT_FLASH +#define CONFIG_FASTBOOT_FLASH_MMC_DEV 1 + #include <configs/ti_omap5_common.h>
/* Enhance our eMMC support / experience. */ @@ -181,8 +189,8 @@ #define CONFIG_USBDOWNLOAD_GADGET #define CONFIG_USB_GADGET_VBUS_DRAW 2 #define CONFIG_G_DNL_MANUFACTURER "Texas Instruments" -#define CONFIG_G_DNL_VENDOR_NUM 0x0403 -#define CONFIG_G_DNL_PRODUCT_NUM 0xBD00 +#define CONFIG_G_DNL_VENDOR_NUM 0x0451 +#define CONFIG_G_DNL_PRODUCT_NUM 0xd022 #define CONFIG_USB_GADGET_DUALSPEED
This patch populates serial number environment variable from die_id_0 and die_id_1 register values for DRA7xx boards.
The function is added in omap common code so that this can be re-used.
Serial# environment variable will be useful to show correct information in "fastboot devices" commands.
Ref: http://git.omapzoom.org/?p=repo/u-boot.git;a=commit;h=a6bcaaf67f6e4bcd97808f...
Signed-off-by: Angela Stegmaier angelabaker@ti.com Signed-off-by: Dileep Katta dileep.katta@linaro.org --- Changes in v2: - None Changes in v3: - corrected the error in the computation of serial# variable - Made it more generic and reusable as per the comments
arch/arm/cpu/armv7/omap-common/utils.c | 13 +++++++++++++ arch/arm/cpu/armv7/omap5/prcm-regs.c | 4 ++++ arch/arm/include/asm/omap_common.h | 5 +++++ board/ti/dra7xx/evm.c | 6 ++++++ 4 files changed, 28 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap-common/utils.c b/arch/arm/cpu/armv7/omap-common/utils.c index 1696c2d..df5f817 100644 --- a/arch/arm/cpu/armv7/omap-common/utils.c +++ b/arch/arm/cpu/armv7/omap-common/utils.c @@ -60,3 +60,16 @@ void __weak usb_fake_mac_from_die_id(u32 *id) eth_setenv_enetaddr("usbethaddr", device_mac); } } + +void __weak usb_set_serial_num_from_die_id(u32 *id) +{ + char serialno[72]; + uint32_t serialno_lo, serialno_hi; + + if (!getenv("serial#")) { + serialno_hi = id[0]; + serialno_lo = id[1]; + sprintf(serialno, "%08x%08x", serialno_hi, serialno_lo); + setenv("serial#", serialno); + } +} diff --git a/arch/arm/cpu/armv7/omap5/prcm-regs.c b/arch/arm/cpu/armv7/omap5/prcm-regs.c index 440bb40..f80d36d 100644 --- a/arch/arm/cpu/armv7/omap5/prcm-regs.c +++ b/arch/arm/cpu/armv7/omap5/prcm-regs.c @@ -440,6 +440,10 @@ struct omap_sys_ctrl_regs const dra7xx_ctrl = { .control_emif1_sdram_config_ext = 0x4AE0C144, .control_emif2_sdram_config_ext = 0x4AE0C148, .control_wkup_ldovbb_mpu_voltage_ctrl = 0x4AE0C158, + .control_std_fuse_die_id_0 = 0x4AE0C200, + .control_std_fuse_die_id_1 = 0x4AE0C208, + .control_std_fuse_die_id_2 = 0x4AE0C20C, + .control_std_fuse_die_id_3 = 0x4AE0C210, .control_padconf_mode = 0x4AE0C5A0, .control_xtal_oscillator = 0x4AE0C5A4, .control_i2c_2 = 0x4AE0C5A8, diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index bd43099..13a57ab 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -362,6 +362,10 @@ struct omap_sys_ctrl_regs { u32 control_core_control_io1; u32 control_core_control_io2; u32 control_id_code; + u32 control_std_fuse_die_id_0; + u32 control_std_fuse_die_id_1; + u32 control_std_fuse_die_id_2; + u32 control_std_fuse_die_id_3; u32 control_std_fuse_opp_bgap; u32 control_ldosram_iva_voltage_ctrl; u32 control_ldosram_mpu_voltage_ctrl; @@ -578,6 +582,7 @@ void abb_setup(u32 fuse, u32 ldovbb, u32 setup, u32 control, s8 abb_setup_ldovbb(u32 fuse, u32 ldovbb);
void usb_fake_mac_from_die_id(u32 *id); +void usb_set_serial_num_from_die_id(u32 *id);
/* ABB */ #define OMAP_ABB_NOMINAL_OPP 0 diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 3089fa2..cadff5a 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -93,10 +93,16 @@ int board_init(void) int board_late_init(void) { #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + u32 id[4]; + if (omap_revision() == DRA722_ES1_0) setenv("board_name", "dra72x"); else setenv("board_name", "dra7xx"); + + id[0] = readl((*ctrl)->control_std_fuse_die_id_0); + id[1] = readl((*ctrl)->control_std_fuse_die_id_1); + usb_set_serial_num_from_die_id(id); #endif return 0; }
Signed-off-by: Angela Stegmaier angelabaker@ti.com Signed-off-by: Dileep Katta dileep.katta@linaro.org Reviewed-by: Tom Rini trini@konsulko.com
Implemented fb_set_reboot_flag() for OMAP5 to set an environment variable 'dofastboot' when reboot-bootloader called.
This environment variable will be checked in boot command and fastboot will be called if the variable is set. If the bootcmd env variable of OMAP5 common is overwritten with board-specific command, then these changes will not apply.
This was originally intended for DRA7 platform, but now applies to all OMAP5.
Ref: http://git.omapzoom.org/?p=repo/u-boot.git;a=commit;h=19da2e436e9806259cf1f4...
Signed-off-by: Angela Stegmaier angelabaker@ti.com Signed-off-by: Dileep Katta dileep.katta@linaro.org --- Changes in v2: - None Changes in v3: - Changed the implementation to be more abstract - Used environment variable instead of board-specific registers - Moved the code to OMAP5
arch/arm/cpu/armv7/omap-common/boot-common.c | 11 +++++++++++ include/configs/ti_omap5_common.h | 7 +++++++ 2 files changed, 18 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap-common/boot-common.c b/arch/arm/cpu/armv7/omap-common/boot-common.c index 17500f2..1aff7c8 100644 --- a/arch/arm/cpu/armv7/omap-common/boot-common.c +++ b/arch/arm/cpu/armv7/omap-common/boot-common.c @@ -162,3 +162,14 @@ void arch_preboot_os(void) ahci_reset(DWC_AHSATA_BASE); } #endif + +#ifdef CONFIG_CMD_FASTBOOT +int fb_set_reboot_flag(void) +{ + printf("Setting reboot to fastboot flag ...\n"); + setenv("dofastboot", "1"); + saveenv(); + udelay(60); + return 0; +} +#endif diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index cd92454..c5d97ea 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -141,13 +141,20 @@ "loadfdt=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile};\0" \ DFUARGS \
+ #define CONFIG_BOOTCOMMAND \ + "if test ${dofastboot} -eq 1; then " \ + "echo Boot fastboot requested, resetting dofastboot ...;" \ + "setenv dofastboot 0; saveenv; sleep 1;" \ + "echo Booting into fastboot ...; fastboot;" \ + "fi;" \ "run findfdt; " \ "run mmcboot;" \ "setenv mmcdev 1; " \ "setenv bootpart 1:2; " \ "setenv mmcroot /dev/mmcblk0p2 rw; " \ "run mmcboot;" \ + ""
[snip]
- printf("Setting reboot to fastboot flag ...\n");
- setenv("dofastboot", "1");
- saveenv();
- udelay(60);
[snip]
- "if test ${dofastboot} -eq 1; then " \
No. When saveenv returns environment is saved. If it doesn't there's a bug that must be addressed.
[snip]
- saveenv();
- udelay(60);
[snip]
sleep/udelay not required. Will remove and send an updated patch.
-- Tom
Thanks for the comment. Regards, Dileep
Signed-off-by: Angela Stegmaier angelabaker@ti.com Signed-off-by: Dileep Katta dileep.katta@linaro.org --- Changes in v2: - None Changes in v3: - Changed the implementation to be more abstract - Used environment variable instead of board-specific registers - Moved the code to OMAP5 Changes in v4: - Removed udelay and sleep after saveenv
arch/arm/cpu/armv7/omap-common/boot-common.c | 10 ++++++++++ include/configs/ti_omap5_common.h | 7 +++++++ 2 files changed, 17 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap-common/boot-common.c b/arch/arm/cpu/armv7/omap-common/boot-common.c index 17500f2..55ca94d 100644 --- a/arch/arm/cpu/armv7/omap-common/boot-common.c +++ b/arch/arm/cpu/armv7/omap-common/boot-common.c @@ -162,3 +162,13 @@ void arch_preboot_os(void) ahci_reset(DWC_AHSATA_BASE); } #endif + +#ifdef CONFIG_CMD_FASTBOOT +int fb_set_reboot_flag(void) +{ + printf("Setting reboot to fastboot flag ...\n"); + setenv("dofastboot", "1"); + saveenv(); + return 0; +} +#endif diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index cd92454..24f8021 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -141,13 +141,20 @@ "loadfdt=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile};\0" \ DFUARGS \
+ #define CONFIG_BOOTCOMMAND \ + "if test ${dofastboot} -eq 1; then " \ + "echo Boot fastboot requested, resetting dofastboot ...;" \ + "setenv dofastboot 0; saveenv;" \ + "echo Booting into fastboot ...; fastboot;" \ + "fi;" \ "run findfdt; " \ "run mmcboot;" \ "setenv mmcdev 1; " \ "setenv bootpart 1:2; " \ "setenv mmcroot /dev/mmcblk0p2 rw; " \ "run mmcboot;" \ + ""
Hi Dileep,
Changes in v2:
avoid duplication
participants (8)
Dileep Katta
Lukasz Majewski
Lukasz Majewski
Nishanth Menon
Rob Herring
Stegmaier, Angela
