[U-Boot] [PATCH] ppc4xx: Fixed PPC4xx debug compilation error in uic.c
This patch fixes a debug compilation error for PPC4xx platforms, all other architectures are not affected by this change. The 'handler' pointer was undefined. The fix is exercised and has effect only if DEBUG is defined.
Signed-off-by: Alessio Centazzo acpatin@yahoo.com --- cpu/ppc4xx/uic.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/cpu/ppc4xx/uic.c b/cpu/ppc4xx/uic.c index a95d1cb..1a370b3 100644 --- a/cpu/ppc4xx/uic.c +++ b/cpu/ppc4xx/uic.c @@ -164,7 +164,7 @@ void pic_irq_enable(unsigned int vec) else if (vec >= 96) mtdcr(uic3er, mfdcr(uic3er) | UIC_MASK(vec));
- debug("Install interrupt for vector %d ==> %p\n", vec, handler); + debug("Enable interrupt vector %d\n", vec); }
void pic_irq_disable(unsigned int vec) -- 1.6.0.4
Unfortunately this still doesn't apply. Now I checked why this is the case (with such a "simple" patch). And it seems that you have a whitespace issue. Please see below.
Indentation done via spaces instead of tabs as done in the original file.
Again, indentation has to be done in tabs. Please fix and resubmit.
Thanks.
Best regards, Stefan
Alessio Centazzo
Stefan Roese
