[PATCH v3 00/17] Basic StarFive JH7110 RISC-V SoC support
This series of patches base on the latest branch/master, and add support for the StarFive JH7110 RISC-V SoC and VisionFive V2 board. In order for this to be achieved, the respective DT nodes have been added, and the required defconfigs have been added to the boards' defconfig. What is more, the basic required DM drivers have been added, such as reset, clock, pinctrl, uart, ram etc.
Note that the register base address of reset controller is same with the clock controller. Therefore, there is no device tree node alone for reset driver. It binds device node in the clock driver.
The u-boot-spl and u-boot has been tested on the StarFive VisionFive 2 boards which equip with JH7110 SoC and works normally.
For more information and support, you can visit RVspace wiki[1].
v3: - Added doc/board/starfive/visionfive2.rst file. - Added support booting from SD. - Added support pinctrl in SPL. - Reworded dts to consistent with linux. - Added CFG_EXTRA_ENV_SETTINGS configuration. - Reworded starfive_visionfive2_defconfig. - Reworded the clock driver. - Renamed 'starfive-jh7110.h' to 'starfive,jh7110-crg.h'. - Separated 'starfive_visionfive2.dts' to 'jh7110-starfive-visionfive-2-v1.3b.dts' and 'jh7110-starfive-visionfive-2-v1.2a.dts' to consistent with linux. - Added pinmux_property_set callback function implementation in 'pinctrl-starfive.c'.
v2: - Renamed file 'jh7110-regs.h' to 'regs.h'. - Reworded the clear L2 LIM memory code in C. - Removed flash init call in 'spl_soc_init' function. - Reworded the clock driver. - Rename the macro 'SET_DIV' to 'ASSIGNED_CLOCK_PARENTS' in 'spl.c'. - Moved the device tree node 'dmc@15700000' from 'jh7110-u-boot.dtsi' to 'starfive_visionfive2-u-boot.dtsi'
Previous versions: v1 - https://patchwork.ozlabs.org/project/uboot/cover/20221212025020.23778-1-yanh... v2 - https://patchwork.ozlabs.org/project/uboot/cover/20230118081132.31403-1-yanh...
Jianlong Huang (1): dt-bindings: pinctrl: Add StarFive JH7110 pinctrl definitions
Kuan Lim Lee (1): pinctrl: starfive: Add StarFive JH7110 driver
Yanhong Wang (15): riscv: cpu: jh7110: Add support for jh7110 SoC cache: starfive: Add StarFive JH7110 support dt-bindings: reset: Add StarFive JH7110 reset definitions reset: starfive: jh7110: Add reset driver for StarFive JH7110 SoC dt-bindings: clock: Add StarFive JH7110 clock definitions clk: starfive: Add StarFive JH7110 clock driver ram: starfive: add ddr driver board: starfive: add StarFive VisionFive v2 board support riscv: cpu: jh7110: Add Kconfig for StarFive JH7110 SoC board: starfive: Add Kconfig for StarFive VisionFive v2 Board board: starfive: Add TARGET_STARFIVE_VISIONFIVE2 to Kconfig riscv: dts: jh7110: Add initial StarFive JH7110 device tree riscv: dts: jh7110: Add initial u-boot device tree riscv: dts: jh7110: Add initial StarFive VisionFive v2 board device tree configs: starfive: add starfive_visionfive2_defconfig
arch/riscv/Kconfig | 5 + arch/riscv/cpu/jh7110/Kconfig | 28 + arch/riscv/cpu/jh7110/Makefile | 10 + arch/riscv/cpu/jh7110/cpu.c | 23 + arch/riscv/cpu/jh7110/dram.c | 38 + arch/riscv/cpu/jh7110/spl.c | 64 + arch/riscv/dts/Makefile | 3 +- ...10-starfive-visionfive-2-v1.2a-u-boot.dtsi | 85 + .../jh7110-starfive-visionfive-2-v1.2a.dts | 12 + ...10-starfive-visionfive-2-v1.3b-u-boot.dtsi | 85 + .../jh7110-starfive-visionfive-2-v1.3b.dts | 12 + .../dts/jh7110-starfive-visionfive-2.dtsi | 253 +++ arch/riscv/dts/jh7110-u-boot.dtsi | 95 + arch/riscv/dts/jh7110.dtsi | 582 +++++ arch/riscv/include/asm/arch-jh7110/regs.h | 19 + arch/riscv/include/asm/arch-jh7110/spl.h | 12 + board/starfive/visionfive2/Kconfig | 53 + board/starfive/visionfive2/MAINTAINERS | 7 + board/starfive/visionfive2/Makefile | 7 + board/starfive/visionfive2/spl.c | 87 + .../visionfive2/starfive_visionfive2.c | 38 + configs/starfive_visionfive2_defconfig | 79 + doc/board/starfive/index.rst | 9 + doc/board/starfive/visionfive2.rst | 492 +++++ drivers/cache/cache-sifive-ccache.c | 1 + drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/starfive/Kconfig | 17 + drivers/clk/starfive/Makefile | 4 + drivers/clk/starfive/clk-jh7110-pll.c | 321 +++ drivers/clk/starfive/clk-jh7110.c | 577 +++++ drivers/clk/starfive/clk.h | 57 + drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/starfive/Kconfig | 28 + drivers/pinctrl/starfive/Makefile | 6 + drivers/pinctrl/starfive/pinctrl-jh7110-aon.c | 113 + drivers/pinctrl/starfive/pinctrl-jh7110-sys.c | 399 ++++ drivers/pinctrl/starfive/pinctrl-starfive.c | 382 ++++ drivers/pinctrl/starfive/pinctrl-starfive.h | 55 + drivers/ram/Kconfig | 1 + drivers/ram/Makefile | 4 +- drivers/ram/starfive/Kconfig | 5 + drivers/ram/starfive/Makefile | 11 + drivers/ram/starfive/ddrcsr_boot.c | 339 +++ drivers/ram/starfive/ddrphy_start.c | 279 +++ drivers/ram/starfive/ddrphy_train.c | 383 ++++ drivers/ram/starfive/ddrphy_utils.c | 1955 +++++++++++++++++ drivers/ram/starfive/starfive_ddr.c | 161 ++ drivers/ram/starfive/starfive_ddr.h | 65 + drivers/reset/Kconfig | 16 + drivers/reset/Makefile | 1 + drivers/reset/reset-jh7110.c | 158 ++ include/configs/starfive-visionfive2.h | 49 + .../dt-bindings/clock/starfive,jh7110-crg.h | 257 +++ .../pinctrl/pinctrl-starfive-jh7110.h | 427 ++++ .../dt-bindings/reset/starfive,jh7110-crg.h | 183 ++ 57 files changed, 8354 insertions(+), 2 deletions(-) create mode 100644 arch/riscv/cpu/jh7110/Kconfig create mode 100644 arch/riscv/cpu/jh7110/Makefile create mode 100644 arch/riscv/cpu/jh7110/cpu.c create mode 100644 arch/riscv/cpu/jh7110/dram.c create mode 100644 arch/riscv/cpu/jh7110/spl.c create mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2-v1.2a-u-boot.dtsi create mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2-v1.2a.dts create mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2-v1.3b-u-boot.dtsi create mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2-v1.3b.dts create mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi create mode 100644 arch/riscv/dts/jh7110-u-boot.dtsi create mode 100644 arch/riscv/dts/jh7110.dtsi create mode 100644 arch/riscv/include/asm/arch-jh7110/regs.h create mode 100644 arch/riscv/include/asm/arch-jh7110/spl.h create mode 100644 board/starfive/visionfive2/Kconfig create mode 100644 board/starfive/visionfive2/MAINTAINERS create mode 100644 board/starfive/visionfive2/Makefile create mode 100644 board/starfive/visionfive2/spl.c create mode 100644 board/starfive/visionfive2/starfive_visionfive2.c create mode 100644 configs/starfive_visionfive2_defconfig create mode 100644 doc/board/starfive/index.rst create mode 100644 doc/board/starfive/visionfive2.rst create mode 100644 drivers/clk/starfive/Kconfig create mode 100644 drivers/clk/starfive/Makefile create mode 100644 drivers/clk/starfive/clk-jh7110-pll.c create mode 100644 drivers/clk/starfive/clk-jh7110.c create mode 100644 drivers/clk/starfive/clk.h create mode 100644 drivers/pinctrl/starfive/Kconfig create mode 100644 drivers/pinctrl/starfive/Makefile create mode 100644 drivers/pinctrl/starfive/pinctrl-jh7110-aon.c create mode 100644 drivers/pinctrl/starfive/pinctrl-jh7110-sys.c create mode 100644 drivers/pinctrl/starfive/pinctrl-starfive.c create mode 100644 drivers/pinctrl/starfive/pinctrl-starfive.h create mode 100644 drivers/ram/starfive/Kconfig create mode 100644 drivers/ram/starfive/Makefile create mode 100644 drivers/ram/starfive/ddrcsr_boot.c create mode 100644 drivers/ram/starfive/ddrphy_start.c create mode 100644 drivers/ram/starfive/ddrphy_train.c create mode 100644 drivers/ram/starfive/ddrphy_utils.c create mode 100644 drivers/ram/starfive/starfive_ddr.c create mode 100644 drivers/ram/starfive/starfive_ddr.h create mode 100644 drivers/reset/reset-jh7110.c create mode 100644 include/configs/starfive-visionfive2.h create mode 100644 include/dt-bindings/clock/starfive,jh7110-crg.h create mode 100644 include/dt-bindings/pinctrl/pinctrl-starfive-jh7110.h create mode 100644 include/dt-bindings/reset/starfive,jh7110-crg.h
base-commit: b0eda49bc9b00503366f2ec431be0178caf9e9b5
Add StarFive JH7110 SoC to support RISC-V arch.
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com Reviewed-by: Rick Chen rick@andestech.com --- arch/riscv/cpu/jh7110/Makefile | 10 ++++ arch/riscv/cpu/jh7110/cpu.c | 23 ++++++++ arch/riscv/cpu/jh7110/dram.c | 38 ++++++++++++++ arch/riscv/cpu/jh7110/spl.c | 64 +++++++++++++++++++++++ arch/riscv/include/asm/arch-jh7110/regs.h | 19 +++++++ arch/riscv/include/asm/arch-jh7110/spl.h | 12 +++++ 6 files changed, 166 insertions(+) create mode 100644 arch/riscv/cpu/jh7110/Makefile create mode 100644 arch/riscv/cpu/jh7110/cpu.c create mode 100644 arch/riscv/cpu/jh7110/dram.c create mode 100644 arch/riscv/cpu/jh7110/spl.c create mode 100644 arch/riscv/include/asm/arch-jh7110/regs.h create mode 100644 arch/riscv/include/asm/arch-jh7110/spl.h
diff --git a/arch/riscv/cpu/jh7110/Makefile b/arch/riscv/cpu/jh7110/Makefile new file mode 100644 index 0000000000..951c95631e --- /dev/null +++ b/arch/riscv/cpu/jh7110/Makefile @@ -0,0 +1,10 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2022 StarFive Technology Co., Ltd. + +ifeq ($(CONFIG_SPL_BUILD),y) +obj-y += spl.o +else +obj-y += cpu.o +obj-y += dram.o +endif diff --git a/arch/riscv/cpu/jh7110/cpu.c b/arch/riscv/cpu/jh7110/cpu.c new file mode 100644 index 0000000000..1d7c026584 --- /dev/null +++ b/arch/riscv/cpu/jh7110/cpu.c @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wang yanhong.wang@starfivetech.com + */ + +#include <asm/cache.h> +#include <irq_func.h> + +/* + * cleanup_before_linux() is called just before we call linux + * it prepares the processor for linux + * + * we disable interrupt and caches. + */ +int cleanup_before_linux(void) +{ + disable_interrupts(); + + cache_flush(); + + return 0; +} diff --git a/arch/riscv/cpu/jh7110/dram.c b/arch/riscv/cpu/jh7110/dram.c new file mode 100644 index 0000000000..2ad3f2044a --- /dev/null +++ b/arch/riscv/cpu/jh7110/dram.c @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wang yanhong.wang@starfivetech.com + */ + +#include <common.h> +#include <fdtdec.h> +#include <init.h> +#include <linux/sizes.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + return fdtdec_setup_mem_size_base(); +} + +int dram_init_banksize(void) +{ + return fdtdec_setup_memory_banksize(); +} + +phys_size_t board_get_usable_ram_top(phys_size_t total_size) +{ + /* + * Ensure that we run from first 4GB so that all + * addresses used by U-Boot are 32bit addresses. + * + * This in-turn ensures that 32bit DMA capable + * devices work fine because DMA mapping APIs will + * provide 32bit DMA addresses only. + */ + if (IS_ENABLED(CONFIG_64BIT) && gd->ram_top > SZ_4G) + return SZ_4G; + + return gd->ram_top; +} diff --git a/arch/riscv/cpu/jh7110/spl.c b/arch/riscv/cpu/jh7110/spl.c new file mode 100644 index 0000000000..104f0fe949 --- /dev/null +++ b/arch/riscv/cpu/jh7110/spl.c @@ -0,0 +1,64 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wangyanhong.wang@starfivetech.com + */ + +#include <asm/csr.h> +#include <asm/sections.h> +#include <dm.h> +#include <log.h> + +#define CSR_U74_FEATURE_DISABLE 0x7c1 +#define L2_LIM_MEM_END 0x81FFFFFUL + +int spl_soc_init(void) +{ + int ret; + struct udevice *dev; + + /* DDR init */ + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); + return ret; + } + + return 0; +} + +void harts_early_init(void) +{ + ulong *ptr; + u8 *tmp; + ulong len, remain; + /* + * Feature Disable CSR + * + * Clear feature disable CSR to '0' to turn on all features for + * each core. This operation must be in M-mode. + */ + if (CONFIG_IS_ENABLED(RISCV_MMODE)) + csr_write(CSR_U74_FEATURE_DISABLE, 0); + + /* clear L2 LIM memory + * set __bss_end to 0x81FFFFF region to zero + * The L2 Cache Controller supports ECC. ECC is applied to SRAM. + * If it is not cleared, the ECC part is invalid, and an ECC error + * will be reported when reading data. + */ + ptr = (ulong *)&__bss_end; + len = L2_LIM_MEM_END - (ulong)&__bss_end; + remain = len % sizeof(ulong); + len /= sizeof(ulong); + + while (len--) + *ptr++ = 0; + + /* clear the remain bytes */ + if (remain) { + tmp = (u8 *)ptr; + while (remain--) + *tmp++ = 0; + } +} diff --git a/arch/riscv/include/asm/arch-jh7110/regs.h b/arch/riscv/include/asm/arch-jh7110/regs.h new file mode 100644 index 0000000000..05026870a0 --- /dev/null +++ b/arch/riscv/include/asm/arch-jh7110/regs.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wang yanhong.wang@starfivetech.com + */ + +#ifndef __STARFIVE_JH7110_REGS_H +#define __STARFIVE_JH7110_REGS_H + +#define JH7110_SYS_CRG 0x13020000 +#define JH7110_SYS_SYSCON 0x13030000 +#define JH7110_SYS_IOMUX 0x13040000 +#define JH7110_AON_CRG 0x17000000 +#define JH7110_AON_SYSCON 0x17010000 + +#define JH7110_BOOT_MODE_SELECT_REG 0x1702002c +#define JH7110_BOOT_MODE_SELECT_MASK GENMASK(1, 0) + +#endif /* __STARFIVE_JH7110_REGS_H */ diff --git a/arch/riscv/include/asm/arch-jh7110/spl.h b/arch/riscv/include/asm/arch-jh7110/spl.h new file mode 100644 index 0000000000..23ce8871b3 --- /dev/null +++ b/arch/riscv/include/asm/arch-jh7110/spl.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wang yanhong.wang@starfivetech.com + */ + +#ifndef _SPL_STARFIVE_H +#define _SPL_STARFIVE_H + +int spl_soc_init(void); + +#endif /* _SPL_STARFIVE_H */
This adds support for the StarFive JH7110 SoC which also feature this SiFive cache controller.
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- drivers/cache/cache-sifive-ccache.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/cache/cache-sifive-ccache.c b/drivers/cache/cache-sifive-ccache.c index c8766f6242..c1bef0b4d3 100644 --- a/drivers/cache/cache-sifive-ccache.c +++ b/drivers/cache/cache-sifive-ccache.c @@ -62,6 +62,7 @@ static int sifive_ccache_probe(struct udevice *dev) static const struct udevice_id sifive_ccache_ids[] = { { .compatible = "sifive,fu540-c000-ccache" }, { .compatible = "sifive,fu740-c000-ccache" }, + { .compatible = "starfive,jh7110-ccache" }, {} };
- { .compatible = "starfive,jh7110-ccache" },
Perhaps there's a u-boot policy I am not aware of, but why not just add "sifive,ccache0" here instead, since the jh7110's ccache is compatible with that?
Thanks, Conor.
Thanks. I will add "sifive,ccache0" here instead.
Thanks, Conor.
Add a DM reset driver for StarFive JH7110 SoC.
Note that the register base address of reset controller is the same with the clock controller. Therefore, there is no device tree node alone for reset driver.It binds device node in the clock driver
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- drivers/reset/Kconfig | 16 ++++ drivers/reset/Makefile | 1 + drivers/reset/reset-jh7110.c | 158 +++++++++++++++++++++++++++++++++++ 3 files changed, 175 insertions(+) create mode 100644 drivers/reset/reset-jh7110.c
diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index e4039d7474..73bbd30692 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -172,6 +172,22 @@ config RESET_SIFIVE different hw blocks like DDR, gemgxl. With this driver we leverage U-Boot's reset framework to reset these hardware blocks.
+config RESET_JH7110 + bool "Reset driver for StarFive JH7110 SoC" + depends on DM_RESET && STARFIVE_JH7110 + default y + help + Support for reset controller on StarFive + JH7110 SoCs. + +config SPL_RESET_JH7110 + bool "SPL Reset driver for StarFive JH7110 SoC" + depends on SPL && STARFIVE_JH7110 + default y + help + Support for reset controller on StarFive + JH7110 SoCs in SPL. + config RESET_SYSCON bool "Enable generic syscon reset driver support" depends on DM_RESET diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index 6c8b45ecba..6801268180 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -32,3 +32,4 @@ obj-$(CONFIG_RESET_SCMI) += reset-scmi.o obj-$(CONFIG_RESET_ZYNQMP) += reset-zynqmp.o obj-$(CONFIG_RESET_DRA7) += reset-dra7.o obj-$(CONFIG_RESET_AT91) += reset-at91.o +obj-$(CONFIG_$(SPL_TPL_)RESET_JH7110) += reset-jh7110.o diff --git a/drivers/reset/reset-jh7110.c b/drivers/reset/reset-jh7110.c new file mode 100644 index 0000000000..d6bdf6bb00 --- /dev/null +++ b/drivers/reset/reset-jh7110.c @@ -0,0 +1,158 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wang yanhong.wang@starfivetech.com + * + */ + +#include <common.h> +#include <dm.h> +#include <dm/ofnode.h> +#include <dt-bindings/reset/starfive,jh7110-crg.h> +#include <errno.h> +#include <linux/iopoll.h> +#include <reset-uclass.h> + +struct jh7110_reset_priv { + void __iomem *reg; + u32 assert; + u32 status; + u32 resets; +}; + +struct reset_info { + const char *compat; + const u32 nr_resets; + const u32 assert_offset; + const u32 status_offset; +}; + +static const struct reset_info jh7110_rst_info[] = { + { + .compat = "starfive,jh7110-syscrg", + .nr_resets = JH7110_SYSRST_END, + .assert_offset = 0x2F8, + .status_offset = 0x308, + }, + { + .compat = "starfive,jh7110-aoncrg", + .nr_resets = JH7110_AONRST_END, + .assert_offset = 0x38, + .status_offset = 0x3C, + }, + { + .compat = "starfive,jh7110-stgcrg", + .nr_resets = JH7110_STGRST_END, + .assert_offset = 0x74, + .status_offset = 0x78, + } +}; + +static const struct reset_info *jh7110_reset_get_cfg(const char *compat) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(jh7110_rst_info); i++) + if (!strcmp(compat, jh7110_rst_info[i].compat)) + return &jh7110_rst_info[i]; + + return NULL; +} + +static int jh7110_reset_trigger(struct jh7110_reset_priv *priv, + unsigned long id, bool assert) +{ + ulong group; + u32 mask, value, done = 0; + ulong addr; + + group = id / 32; + mask = BIT(id % 32); + + if (!assert) + done ^= mask; + + addr = (ulong)priv->reg + priv->assert + group * sizeof(u32); + value = readl((ulong *)addr); + + if (assert) + value |= mask; + else + value &= ~mask; + + writel(value, (ulong *)addr); + addr = (ulong)priv->reg + priv->status + group * sizeof(u32); + + return readl_poll_timeout((ulong *)addr, value, + (value & mask) == done, 1000); +} + +static int jh7110_reset_assert(struct reset_ctl *rst) +{ + struct jh7110_reset_priv *priv = dev_get_priv(rst->dev); + + jh7110_reset_trigger(priv, rst->id, true); + + return 0; +} + +static int jh7110_reset_deassert(struct reset_ctl *rst) +{ + struct jh7110_reset_priv *priv = dev_get_priv(rst->dev); + + jh7110_reset_trigger(priv, rst->id, false); + + return 0; +} + +static int jh7110_reset_free(struct reset_ctl *rst) +{ + return 0; +} + +static int jh7110_reset_request(struct reset_ctl *rst) +{ + struct jh7110_reset_priv *priv = dev_get_priv(rst->dev); + + if (rst->id >= priv->resets) + return -EINVAL; + + return 0; +} + +static int jh7110_reset_probe(struct udevice *dev) +{ + struct jh7110_reset_priv *priv = dev_get_priv(dev); + const struct reset_info *cfg; + const char *compat; + + compat = ofnode_get_property(dev_ofnode(dev), "compatible", NULL); + if (!compat) + return -EINVAL; + + cfg = jh7110_reset_get_cfg(compat); + if (!cfg) + return -EINVAL; + + priv->assert = cfg->assert_offset; + priv->status = cfg->status_offset; + priv->resets = cfg->nr_resets; + priv->reg = (void __iomem *)dev_read_addr_index(dev, 0); + + return 0; +} + +const struct reset_ops jh7110_reset_reset_ops = { + .rfree = jh7110_reset_free, + .request = jh7110_reset_request, + .rst_assert = jh7110_reset_assert, + .rst_deassert = jh7110_reset_deassert, +}; + +U_BOOT_DRIVER(jh7110_reset) = { + .name = "jh7110_reset", + .id = UCLASS_RESET, + .ops = &jh7110_reset_reset_ops, + .probe = jh7110_reset_probe, + .priv_auto = sizeof(struct jh7110_reset_priv), +};
Add all clock outputs for the StarFive JH7110 clock generator.
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- .../dt-bindings/clock/starfive,jh7110-crg.h | 257 ++++++++++++++++++ 1 file changed, 257 insertions(+) create mode 100644 include/dt-bindings/clock/starfive,jh7110-crg.h
diff --git a/include/dt-bindings/clock/starfive,jh7110-crg.h b/include/dt-bindings/clock/starfive,jh7110-crg.h new file mode 100644 index 0000000000..77b70e7a83 --- /dev/null +++ b/include/dt-bindings/clock/starfive,jh7110-crg.h @@ -0,0 +1,257 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * + * Author: Yanhong Wang yanhong.wang@starfivetech.com + */ + +#ifndef __DT_BINDINGS_CLOCK_STARFIVE_JH7110_H__ +#define __DT_BINDINGS_CLOCK_STARFIVE_JH7110_H__ + +#define JH7110_SYSCLK_CPU_ROOT 0 +#define JH7110_SYSCLK_CPU_CORE 1 +#define JH7110_SYSCLK_CPU_BUS 2 +#define JH7110_SYSCLK_GPU_ROOT 3 +#define JH7110_SYSCLK_PERH_ROOT 4 +#define JH7110_SYSCLK_BUS_ROOT 5 +#define JH7110_SYSCLK_NOCSTG_BUS 6 +#define JH7110_SYSCLK_AXI_CFG0 7 +#define JH7110_SYSCLK_STG_AXIAHB 8 +#define JH7110_SYSCLK_AHB0 9 +#define JH7110_SYSCLK_AHB1 10 +#define JH7110_SYSCLK_APB_BUS 11 +#define JH7110_SYSCLK_APB0 12 +#define JH7110_SYSCLK_PLL0_DIV2 13 +#define JH7110_SYSCLK_PLL1_DIV2 14 +#define JH7110_SYSCLK_PLL2_DIV2 15 +#define JH7110_SYSCLK_AUDIO_ROOT 16 +#define JH7110_SYSCLK_MCLK_INNER 17 +#define JH7110_SYSCLK_MCLK 18 +#define JH7110_SYSCLK_MCLK_OUT 19 +#define JH7110_SYSCLK_ISP_2X 20 +#define JH7110_SYSCLK_ISP_AXI 21 +#define JH7110_SYSCLK_GCLK0 22 +#define JH7110_SYSCLK_GCLK1 23 +#define JH7110_SYSCLK_GCLK2 24 +#define JH7110_SYSCLK_CORE 25 +#define JH7110_SYSCLK_CORE1 26 +#define JH7110_SYSCLK_CORE2 27 +#define JH7110_SYSCLK_CORE3 28 +#define JH7110_SYSCLK_CORE4 29 +#define JH7110_SYSCLK_DEBUG 30 +#define JH7110_SYSCLK_RTC_TOGGLE 31 +#define JH7110_SYSCLK_TRACE0 32 +#define JH7110_SYSCLK_TRACE1 33 +#define JH7110_SYSCLK_TRACE2 34 +#define JH7110_SYSCLK_TRACE3 35 +#define JH7110_SYSCLK_TRACE4 36 +#define JH7110_SYSCLK_TRACE_COM 37 +#define JH7110_SYSCLK_NOC_BUS_CPU_AXI 38 +#define JH7110_SYSCLK_NOC_BUS_AXICFG0_AXI 39 +#define JH7110_SYSCLK_OSC_DIV2 40 +#define JH7110_SYSCLK_PLL1_DIV4 41 +#define JH7110_SYSCLK_PLL1_DIV8 42 +#define JH7110_SYSCLK_DDR_BUS 43 +#define JH7110_SYSCLK_DDR_AXI 44 +#define JH7110_SYSCLK_GPU_CORE 45 +#define JH7110_SYSCLK_GPU_CORE_CLK 46 +#define JH7110_SYSCLK_GPU_SYS_CLK 47 +#define JH7110_SYSCLK_GPU_APB 48 +#define JH7110_SYSCLK_GPU_RTC_TOGGLE 49 +#define JH7110_SYSCLK_NOC_BUS_GPU_AXI 50 +#define JH7110_SYSCLK_ISP_TOP_CLK_ISPCORE_2X 51 +#define JH7110_SYSCLK_ISP_TOP_CLK_ISP_AXI 52 +#define JH7110_SYSCLK_NOC_BUS_ISP_AXI 53 +#define JH7110_SYSCLK_HIFI4_CORE 54 +#define JH7110_SYSCLK_HIFI4_AXI 55 +#define JH7110_SYSCLK_AXI_CFG1_DEC_MAIN 56 +#define JH7110_SYSCLK_AXI_CFG1_DEC_AHB 57 +#define JH7110_SYSCLK_VOUT_SRC 58 +#define JH7110_SYSCLK_VOUT_AXI 59 +#define JH7110_SYSCLK_NOC_BUS_DISP_AXI 60 +#define JH7110_SYSCLK_VOUT_TOP_CLK_VOUT_AHB 61 +#define JH7110_SYSCLK_VOUT_TOP_CLK_VOUT_AXI 62 +#define JH7110_SYSCLK_VOUT_TOP_CLK_HDMITX0_MCLK 63 +#define JH7110_SYSCLK_VOUT_TOP_CLK_MIPIPHY_REF 64 +#define JH7110_SYSCLK_JPEGC_AXI 65 +#define JH7110_SYSCLK_CODAJ12_AXI 66 +#define JH7110_SYSCLK_CODAJ12_CORE 67 +#define JH7110_SYSCLK_CODAJ12_APB 68 +#define JH7110_SYSCLK_VDEC_AXI 69 +#define JH7110_SYSCLK_WAVE511_AXI 70 +#define JH7110_SYSCLK_WAVE511_BPU 71 +#define JH7110_SYSCLK_WAVE511_VCE 72 +#define JH7110_SYSCLK_WAVE511_APB 73 +#define JH7110_SYSCLK_VDEC_JPG_ARB_JPG 74 +#define JH7110_SYSCLK_VDEC_JPG_ARB_MAIN 75 +#define JH7110_SYSCLK_NOC_BUS_VDEC_AXI 76 +#define JH7110_SYSCLK_VENC_AXI 77 +#define JH7110_SYSCLK_WAVE420L_AXI 78 +#define JH7110_SYSCLK_WAVE420L_BPU 79 +#define JH7110_SYSCLK_WAVE420L_VCE 80 +#define JH7110_SYSCLK_WAVE420L_APB 81 +#define JH7110_SYSCLK_NOC_BUS_VENC_AXI 82 +#define JH7110_SYSCLK_AXI_CFG0_DEC_MAIN_DIV 83 +#define JH7110_SYSCLK_AXI_CFG0_DEC_MAIN 84 +#define JH7110_SYSCLK_AXI_CFG0_DEC_HIFI4 85 +#define JH7110_SYSCLK_AXIMEM2_AXI 86 +#define JH7110_SYSCLK_QSPI_AHB 87 +#define JH7110_SYSCLK_QSPI_APB 88 +#define JH7110_SYSCLK_QSPI_REF_SRC 89 +#define JH7110_SYSCLK_QSPI_REF 90 +#define JH7110_SYSCLK_SDIO0_AHB 91 +#define JH7110_SYSCLK_SDIO1_AHB 92 +#define JH7110_SYSCLK_SDIO0_SDCARD 93 +#define JH7110_SYSCLK_SDIO1_SDCARD 94 +#define JH7110_SYSCLK_USB_125M 95 +#define JH7110_SYSCLK_NOC_BUS_STG_AXI 96 +#define JH7110_SYSCLK_GMAC1_AHB 97 +#define JH7110_SYSCLK_GMAC1_AXI 98 +#define JH7110_SYSCLK_GMAC_SRC 99 +#define JH7110_SYSCLK_GMAC1_GTXCLK 100 +#define JH7110_SYSCLK_GMAC1_RMII_RTX 101 +#define JH7110_SYSCLK_GMAC1_PTP 102 +#define JH7110_SYSCLK_GMAC1_RX 103 +#define JH7110_SYSCLK_GMAC1_RX_INV 104 +#define JH7110_SYSCLK_GMAC1_TX 105 +#define JH7110_SYSCLK_GMAC1_TX_INV 106 +#define JH7110_SYSCLK_GMAC1_GTXC 107 +#define JH7110_SYSCLK_GMAC0_GTXCLK 108 +#define JH7110_SYSCLK_GMAC0_PTP 109 +#define JH7110_SYSCLK_GMAC_PHY 110 +#define JH7110_SYSCLK_GMAC0_GTXC 111 +#define JH7110_SYSCLK_IOMUX_APB 112 +#define JH7110_SYSCLK_MAILBOX 113 +#define JH7110_SYSCLK_INT_CTRL_APB 114 +#define JH7110_SYSCLK_CAN0_APB 115 +#define JH7110_SYSCLK_CAN0_TIMER 116 +#define JH7110_SYSCLK_CAN0_CAN 117 +#define JH7110_SYSCLK_CAN1_APB 118 +#define JH7110_SYSCLK_CAN1_TIMER 119 +#define JH7110_SYSCLK_CAN1_CAN 120 +#define JH7110_SYSCLK_PWM_APB 121 +#define JH7110_SYSCLK_WDT_APB 122 +#define JH7110_SYSCLK_WDT_CORE 123 +#define JH7110_SYSCLK_TIMER_APB 124 +#define JH7110_SYSCLK_TIMER0 125 +#define JH7110_SYSCLK_TIMER1 126 +#define JH7110_SYSCLK_TIMER2 127 +#define JH7110_SYSCLK_TIMER3 128 +#define JH7110_SYSCLK_TEMP_APB 129 +#define JH7110_SYSCLK_TEMP_CORE 130 +#define JH7110_SYSCLK_SPI0_APB 131 +#define JH7110_SYSCLK_SPI1_APB 132 +#define JH7110_SYSCLK_SPI2_APB 133 +#define JH7110_SYSCLK_SPI3_APB 134 +#define JH7110_SYSCLK_SPI4_APB 135 +#define JH7110_SYSCLK_SPI5_APB 136 +#define JH7110_SYSCLK_SPI6_APB 137 +#define JH7110_SYSCLK_I2C0_APB 138 +#define JH7110_SYSCLK_I2C1_APB 139 +#define JH7110_SYSCLK_I2C2_APB 140 +#define JH7110_SYSCLK_I2C3_APB 141 +#define JH7110_SYSCLK_I2C4_APB 142 +#define JH7110_SYSCLK_I2C5_APB 143 +#define JH7110_SYSCLK_I2C6_APB 144 +#define JH7110_SYSCLK_UART0_APB 145 +#define JH7110_SYSCLK_UART0_CORE 146 +#define JH7110_SYSCLK_UART1_APB 147 +#define JH7110_SYSCLK_UART1_CORE 148 +#define JH7110_SYSCLK_UART2_APB 149 +#define JH7110_SYSCLK_UART2_CORE 150 +#define JH7110_SYSCLK_UART3_APB 151 +#define JH7110_SYSCLK_UART3_CORE 152 +#define JH7110_SYSCLK_UART4_APB 153 +#define JH7110_SYSCLK_UART4_CORE 154 +#define JH7110_SYSCLK_UART5_APB 155 +#define JH7110_SYSCLK_UART5_CORE 156 +#define JH7110_SYSCLK_PWMDAC_APB 157 +#define JH7110_SYSCLK_PWMDAC_CORE 158 +#define JH7110_SYSCLK_SPDIF_APB 159 +#define JH7110_SYSCLK_SPDIF_CORE 160 +#define JH7110_SYSCLK_I2STX0_APB 161 +#define JH7110_SYSCLK_I2STX0_BCLK_MST 162 +#define JH7110_SYSCLK_I2STX0_BCLK_MST_INV 163 +#define JH7110_SYSCLK_I2STX0_LRCK_MST 164 +#define JH7110_SYSCLK_I2STX0_BCLK 165 +#define JH7110_SYSCLK_I2STX0_BCLK_INV 166 +#define JH7110_SYSCLK_I2STX0_LRCK 167 +#define JH7110_SYSCLK_I2STX1_APB 168 +#define JH7110_SYSCLK_I2STX1_BCLK_MST 169 +#define JH7110_SYSCLK_I2STX1_BCLK_MST_INV 170 +#define JH7110_SYSCLK_I2STX1_LRCK_MST 171 +#define JH7110_SYSCLK_I2STX1_BCLK 172 +#define JH7110_SYSCLK_I2STX1_BCLK_INV 173 +#define JH7110_SYSCLK_I2STX1_LRCK 174 +#define JH7110_SYSCLK_I2SRX_APB 175 +#define JH7110_SYSCLK_I2SRX_BCLK_MST 176 +#define JH7110_SYSCLK_I2SRX_BCLK_MST_INV 177 +#define JH7110_SYSCLK_I2SRX_LRCK_MST 178 +#define JH7110_SYSCLK_I2SRX_BCLK 179 +#define JH7110_SYSCLK_I2SRX_BCLK_INV 180 +#define JH7110_SYSCLK_I2SRX_LRCK 181 +#define JH7110_SYSCLK_PDM_DMIC 182 +#define JH7110_SYSCLK_PDM_APB 183 +#define JH7110_SYSCLK_TDM_AHB 184 +#define JH7110_SYSCLK_TDM_APB 185 +#define JH7110_SYSCLK_TDM_INTERNAL 186 +#define JH7110_SYSCLK_TDM_CLK_TDM 187 +#define JH7110_SYSCLK_TDM_CLK_TDM_N 188 +#define JH7110_SYSCLK_JTAG_CERTIFICATION_TRNG 189 + +#define JH7110_SYSCLK_PLL0_OUT 190 +#define JH7110_SYSCLK_PLL1_OUT 191 +#define JH7110_SYSCLK_PLL2_OUT 192 + +#define JH7110_SYSCLK_END 193 + +#define JH7110_AONCLK_OSC_DIV4 (JH7110_SYSCLK_END + 0) +#define JH7110_AONCLK_APB_FUNC (JH7110_SYSCLK_END + 1) +#define JH7110_AONCLK_GMAC0_AHB (JH7110_SYSCLK_END + 2) +#define JH7110_AONCLK_GMAC0_AXI (JH7110_SYSCLK_END + 3) +#define JH7110_AONCLK_GMAC0_RMII_RTX (JH7110_SYSCLK_END + 4) +#define JH7110_AONCLK_GMAC0_TX (JH7110_SYSCLK_END + 5) +#define JH7110_AONCLK_GMAC0_TX_INV (JH7110_SYSCLK_END + 6) +#define JH7110_AONCLK_GMAC0_RX (JH7110_SYSCLK_END + 7) +#define JH7110_AONCLK_GMAC0_RX_INV (JH7110_SYSCLK_END + 8) +#define JH7110_AONCLK_OTPC_APB (JH7110_SYSCLK_END + 9) +#define JH7110_AONCLK_RTC_APB (JH7110_SYSCLK_END + 10) +#define JH7110_AONCLK_RTC_INTERNAL (JH7110_SYSCLK_END + 11) +#define JH7110_AONCLK_RTC_32K (JH7110_SYSCLK_END + 12) +#define JH7110_AONCLK_RTC_CAL (JH7110_SYSCLK_END + 13) + +#define JH7110_AONCLK_END (JH7110_SYSCLK_END + 14) + +#define JH7110_STGCLK_HIFI4_CORE (JH7110_AONCLK_END + 0) +#define JH7110_STGCLK_USB_APB (JH7110_AONCLK_END + 1) +#define JH7110_STGCLK_USB_UTMI_APB (JH7110_AONCLK_END + 2) +#define JH7110_STGCLK_USB_AXI (JH7110_AONCLK_END + 3) +#define JH7110_STGCLK_USB_LPM (JH7110_AONCLK_END + 4) +#define JH7110_STGCLK_USB_STB (JH7110_AONCLK_END + 5) +#define JH7110_STGCLK_USB_APP_125 (JH7110_AONCLK_END + 6) +#define JH7110_STGCLK_USB_REFCLK (JH7110_AONCLK_END + 7) +#define JH7110_STGCLK_PCIE0_AXI (JH7110_AONCLK_END + 8) +#define JH7110_STGCLK_PCIE0_APB (JH7110_AONCLK_END + 9) +#define JH7110_STGCLK_PCIE0_TL (JH7110_AONCLK_END + 10) +#define JH7110_STGCLK_PCIE1_AXI (JH7110_AONCLK_END + 11) +#define JH7110_STGCLK_PCIE1_APB (JH7110_AONCLK_END + 12) +#define JH7110_STGCLK_PCIE1_TL (JH7110_AONCLK_END + 13) +#define JH7110_STGCLK_PCIE01_MAIN (JH7110_AONCLK_END + 14) +#define JH7110_STGCLK_SEC_HCLK (JH7110_AONCLK_END + 15) +#define JH7110_STGCLK_SEC_MISCAHB (JH7110_AONCLK_END + 16) +#define JH7110_STGCLK_MTRX_GRP0_MAIN (JH7110_AONCLK_END + 17) +#define JH7110_STGCLK_MTRX_GRP0_BUS (JH7110_AONCLK_END + 18) +#define JH7110_STGCLK_MTRX_GRP0_STG (JH7110_AONCLK_END + 19) +#define JH7110_STGCLK_MTRX_GRP1_MAIN (JH7110_AONCLK_END + 20) +#define JH7110_STGCLK_MTRX_GRP1_BUS (JH7110_AONCLK_END + 21) +#define JH7110_STGCLK_MTRX_GRP1_STG (JH7110_AONCLK_END + 22) +#define JH7110_STGCLK_MTRX_GRP1_HIFI (JH7110_AONCLK_END + 23) +#define JH7110_STGCLK_E2_RTC (JH7110_AONCLK_END + 24) +#define JH7110_STGCLK_E2_CORE (JH7110_AONCLK_END + 25) +#define JH7110_STGCLK_E2_DBG (JH7110_AONCLK_END + 26) +#define JH7110_STGCLK_DMA1P_AXI (JH7110_AONCLK_END + 27) +#define JH7110_STGCLK_DMA1P_AHB (JH7110_AONCLK_END + 28) + +#define JH7110_STGCLK_END (JH7110_AONCLK_END + 29) + +#endif /* __DT_BINDINGS_CLOCK_STARFIVE_JH7110_H__ */
Add a DM clock driver for StarFive JH7110 SoC.
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/starfive/Kconfig | 17 + drivers/clk/starfive/Makefile | 4 + drivers/clk/starfive/clk-jh7110-pll.c | 321 ++++++++++++++ drivers/clk/starfive/clk-jh7110.c | 577 ++++++++++++++++++++++++++ drivers/clk/starfive/clk.h | 57 +++ 7 files changed, 978 insertions(+) create mode 100644 drivers/clk/starfive/Kconfig create mode 100644 drivers/clk/starfive/Makefile create mode 100644 drivers/clk/starfive/clk-jh7110-pll.c create mode 100644 drivers/clk/starfive/clk-jh7110.c create mode 100644 drivers/clk/starfive/clk.h
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 09aa97ee8c..4d60c84aad 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -235,6 +235,7 @@ source "drivers/clk/owl/Kconfig" source "drivers/clk/renesas/Kconfig" source "drivers/clk/sunxi/Kconfig" source "drivers/clk/sifive/Kconfig" +source "drivers/clk/starfive/Kconfig" source "drivers/clk/stm32/Kconfig" source "drivers/clk/tegra/Kconfig" source "drivers/clk/ti/Kconfig" diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index c274cda77c..66f5860356 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -13,6 +13,7 @@ obj-$(CONFIG_$(SPL_TPL_)CLK_COMPOSITE_CCF) += clk-composite.o
obj-y += analogbits/ obj-y += imx/ +obj-$(CONFIG_CLK_JH7110) += starfive/ obj-y += tegra/ obj-y += ti/ obj-$(CONFIG_$(SPL_TPL_)CLK_INTEL) += intel/ diff --git a/drivers/clk/starfive/Kconfig b/drivers/clk/starfive/Kconfig new file mode 100644 index 0000000000..9399ef6d51 --- /dev/null +++ b/drivers/clk/starfive/Kconfig @@ -0,0 +1,17 @@ +# SPDX-License-Identifier: GPL-2.0+ + +config SPL_CLK_JH7110 + bool "SPL clock support for JH7110" + depends on STARFIVE_JH7110 && SPL + select SPL_CLK + select SPL_CLK_CCF + help + This enables SPL DM support for clock driver in JH7110. + +config CLK_JH7110 + bool "StarFive JH7110 clock support" + depends on STARFIVE_JH7110 + select CLK + select CLK_CCF + help + This enables support clock driver for StarFive JH7110 SoC platform. diff --git a/drivers/clk/starfive/Makefile b/drivers/clk/starfive/Makefile new file mode 100644 index 0000000000..ec0d157094 --- /dev/null +++ b/drivers/clk/starfive/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += clk-jh7110.o +obj-y += clk-jh7110-pll.o diff --git a/drivers/clk/starfive/clk-jh7110-pll.c b/drivers/clk/starfive/clk-jh7110-pll.c new file mode 100644 index 0000000000..02e6d9000e --- /dev/null +++ b/drivers/clk/starfive/clk-jh7110-pll.c @@ -0,0 +1,321 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022-23 StarFive Technology Co., Ltd. + * + * Author: Yanhong Wang yanhong.wang@starfivetech.com + */ + +#include <common.h> +#include <asm/io.h> +#include <malloc.h> +#include <clk-uclass.h> +#include <div64.h> +#include <dm/device.h> +#include <linux/bitops.h> +#include <linux/clk-provider.h> +#include <linux/delay.h> +#include <linux/err.h> + +#include "clk.h" + +#define UBOOT_DM_CLK_JH7110_PLLX "jh7110_clk_pllx" + +#define PLL_PD_OFF 1 +#define PLL_PD_ON 0 + +#define CLK_DDR_BUS_MASK GENMASK(29, 24) +#define CLK_DDR_BUS_OFFSET 0xAC +#define CLK_DDR_BUS_OSC_DIV2 0 +#define CLK_DDR_BUS_PLL1_DIV2 1 +#define CLK_DDR_BUS_PLL1_DIV4 2 +#define CLK_DDR_BUS_PLL1_DIV8 3 + +struct clk_jh7110_pllx { + struct clk clk; + void __iomem *base; + void __iomem *sysreg; + enum starfive_pll_type type; + const struct starfive_pllx_offset *offset; + const struct starfive_pllx_rate *rate_table; + int rate_count; +}; + +#define getbits_le32(addr, mask) ((in_le32(addr) & (mask)) >> __ffs((mask))) + +#define PLLX_SET(offset, mask, val) do {\ + reg = readl((ulong *)((ulong)pll->base + (offset))); \ + reg &= ~(mask); \ + reg |= (mask) & ((val) << __ffs(mask)); \ + writel(reg, (ulong *)((ulong)pll->base + (offset))); \ + } while (0) + +#define PLLX_RATE(_rate, _pd, _fd) \ + { \ + .rate = (_rate), \ + .prediv = (_pd), \ + .fbdiv = (_fd), \ + } + +#define to_clk_pllx(_clk) container_of(_clk, struct clk_jh7110_pllx, clk) + +static const struct starfive_pllx_rate jh7110_pll0_tbl[] = { + PLLX_RATE(375000000UL, 8, 125), + PLLX_RATE(500000000UL, 6, 125), + PLLX_RATE(625000000UL, 24, 625), + PLLX_RATE(750000000UL, 4, 125), + PLLX_RATE(875000000UL, 24, 875), + PLLX_RATE(1000000000UL, 3, 125), + PLLX_RATE(1250000000UL, 12, 625), + PLLX_RATE(1375000000UL, 24, 1375), + PLLX_RATE(1500000000UL, 2, 125), + PLLX_RATE(1625000000UL, 24, 1625), + PLLX_RATE(1750000000UL, 12, 875), + PLLX_RATE(1800000000UL, 3, 225), +}; + +static const struct starfive_pllx_rate jh7110_pll1_tbl[] = { + PLLX_RATE(1066000000UL, 12, 533), + PLLX_RATE(1200000000UL, 1, 50), + PLLX_RATE(1400000000UL, 6, 350), + PLLX_RATE(1600000000UL, 3, 200), +}; + +static const struct starfive_pllx_rate jh7110_pll2_tbl[] = { + PLLX_RATE(1228800000UL, 15, 768), + PLLX_RATE(1188000000UL, 2, 99), +}; + +static const struct starfive_pllx_offset jh7110_pll0_offset = { + .pd = 0x20, + .prediv = 0x24, + .fbdiv = 0x1c, + .frac = 0x20, + .postdiv1 = 0x20, + .dacpd = 0x18, + .dsmpd = 0x18, + .pd_mask = BIT(27), + .prediv_mask = GENMASK(5, 0), + .fbdiv_mask = GENMASK(11, 0), + .frac_mask = GENMASK(23, 0), + .postdiv1_mask = GENMASK(29, 28), + .dacpd_mask = BIT(24), + .dsmpd_mask = BIT(25) +}; + +static const struct starfive_pllx_offset jh7110_pll1_offset = { + .pd = 0x28, + .prediv = 0x2c, + .fbdiv = 0x24, + .frac = 0x28, + .postdiv1 = 0x28, + .dacpd = 0x24, + .dsmpd = 0x24, + .pd_mask = BIT(27), + .prediv_mask = GENMASK(5, 0), + .fbdiv_mask = GENMASK(28, 17), + .frac_mask = GENMASK(23, 0), + .postdiv1_mask = GENMASK(29, 28), + .dacpd_mask = BIT(15), + .dsmpd_mask = BIT(16) +}; + +static const struct starfive_pllx_offset jh7110_pll2_offset = { + .pd = 0x30, + .prediv = 0x34, + .fbdiv = 0x2c, + .frac = 0x30, + .postdiv1 = 0x30, + .dacpd = 0x2c, + .dsmpd = 0x2c, + .pd_mask = BIT(27), + .prediv_mask = GENMASK(5, 0), + .fbdiv_mask = GENMASK(28, 17), + .frac_mask = GENMASK(23, 0), + .postdiv1_mask = GENMASK(29, 28), + .dacpd_mask = BIT(15), + .dsmpd_mask = BIT(16) +}; + +struct starfive_pllx_clk starfive_jh7110_pll0 __initdata = { + .type = PLL0, + .offset = &jh7110_pll0_offset, + .rate_table = jh7110_pll0_tbl, + .rate_count = ARRAY_SIZE(jh7110_pll0_tbl), +}; + +struct starfive_pllx_clk starfive_jh7110_pll1 __initdata = { + .type = PLL1, + .offset = &jh7110_pll1_offset, + .rate_table = jh7110_pll1_tbl, + .rate_count = ARRAY_SIZE(jh7110_pll1_tbl), +}; + +struct starfive_pllx_clk starfive_jh7110_pll2 __initdata = { + .type = PLL2, + .offset = &jh7110_pll2_offset, + .rate_table = jh7110_pll2_tbl, + .rate_count = ARRAY_SIZE(jh7110_pll2_tbl), +}; + +static const struct starfive_pllx_rate * +jh7110_get_pll_settings(struct clk_jh7110_pllx *pll, unsigned long rate) +{ + for (int i = 0; i < pll->rate_count; i++) + if (rate == pll->rate_table[i].rate) + return &pll->rate_table[i]; + + return NULL; +} + +static void jh7110_pll_set_rate(struct clk_jh7110_pllx *pll, + const struct starfive_pllx_rate *rate) +{ + u32 reg; + bool set = (pll->type == PLL1) ? true : false; + + if (set) { + reg = readl((ulong *)((ulong)pll->sysreg + CLK_DDR_BUS_OFFSET)); + reg &= ~CLK_DDR_BUS_MASK; + reg |= CLK_DDR_BUS_OSC_DIV2 << __ffs(CLK_DDR_BUS_MASK); + writel(reg, (ulong *)((ulong)pll->sysreg + CLK_DDR_BUS_OFFSET)); + } + + PLLX_SET(pll->offset->pd, pll->offset->pd_mask, PLL_PD_OFF); + PLLX_SET(pll->offset->dacpd, pll->offset->dacpd_mask, 1); + PLLX_SET(pll->offset->dsmpd, pll->offset->dsmpd_mask, 1); + PLLX_SET(pll->offset->prediv, pll->offset->prediv_mask, rate->prediv); + PLLX_SET(pll->offset->fbdiv, pll->offset->fbdiv_mask, rate->fbdiv); + PLLX_SET(pll->offset->postdiv1, pll->offset->postdiv1, 0); + PLLX_SET(pll->offset->pd, pll->offset->pd_mask, PLL_PD_ON); + + if (set) { + udelay(100); + reg = readl((ulong *)((ulong)pll->sysreg + CLK_DDR_BUS_OFFSET)); + reg &= ~CLK_DDR_BUS_MASK; + reg |= CLK_DDR_BUS_PLL1_DIV2 << __ffs(CLK_DDR_BUS_MASK); + writel(reg, (ulong *)((ulong)pll->sysreg + CLK_DDR_BUS_OFFSET)); + } +} + +static ulong jh7110_pllx_recalc_rate(struct clk *clk) +{ + struct clk_jh7110_pllx *pll = to_clk_pllx(dev_get_clk_ptr(clk->dev)); + u64 refclk = clk_get_parent_rate(clk); + u32 dacpd, dsmpd; + u32 prediv, fbdiv, postdiv1; + u64 frac; + + dacpd = getbits_le32((ulong)pll->base + pll->offset->dacpd, + pll->offset->dacpd_mask); + dsmpd = getbits_le32((ulong)pll->base + pll->offset->dsmpd, + pll->offset->dsmpd_mask); + prediv = getbits_le32((ulong)pll->base + pll->offset->prediv, + pll->offset->prediv_mask); + fbdiv = getbits_le32((ulong)pll->base + pll->offset->fbdiv, + pll->offset->fbdiv_mask); + postdiv1 = 1 << getbits_le32((ulong)pll->base + pll->offset->postdiv1, + pll->offset->postdiv1_mask); + frac = (u64)getbits_le32((ulong)pll->base + pll->offset->frac, + pll->offset->frac_mask); + + /* Integer Multiple Mode + * Both dacpd and dsmpd should be set as 1 while integer multiple mode. + * + * The frequency of outputs can be figured out as below. + * + * Fvco = Fref*Nl/M + * NI is integer frequency dividing ratio of feedback divider, set by fbdiv1[11:0] , + * NI = 8, 9, 10, 12.13....4095 + * M is frequency dividing ratio of pre-divider, set by prediv[5:0],M = 1,2...63 + * + * Fclko1 = Fvco/Q1 + * Q1 is frequency dividing ratio of post divider, set by postdiv1[1:0],Q1= 1,2,4,8 + * + * Fraction Multiple Mode + * + * Both dacpd and dsmpd should be set as 0 while integer multiple mode. + * + * Fvco = Fref*(NI+NF)/M + * NI is integer frequency dividing ratio of feedback divider, set by fbdiv[11:0] , + * NI = 8, 9, 10, 12.13....4095 + * NF is fractional frequency dividing ratio, set by frac[23:0], NF =frac[23:0]/2^24= 0~0.99999994 + * M is frequency dividing ratio of pre-divider, set by prediv[5:0],M = 1,2...63 + * + * Fclko1 = Fvco/Q1 + * Q1 is frequency dividing ratio of post divider, set by postdivl[1:0],Q1= 1,2,4,8 + */ + if (dacpd == 1 && dsmpd == 1) + frac = 0; + else if (dacpd == 0 && dsmpd == 0) + do_div(frac, 1 << 24); + else + return -EINVAL; + + refclk *= (fbdiv + frac); + do_div(refclk, prediv * postdiv1); + + return refclk; +} + +static ulong jh7110_pllx_set_rate(struct clk *clk, ulong drate) +{ + struct clk_jh7110_pllx *pll = to_clk_pllx(dev_get_clk_ptr(clk->dev)); + const struct starfive_pllx_rate *rate; + + rate = jh7110_get_pll_settings(pll, drate); + if (!rate) + return -EINVAL; + + jh7110_pll_set_rate(pll, rate); + + return jh7110_pllx_recalc_rate(clk); +} + +static const struct clk_ops clk_jh7110_ops = { + .set_rate = jh7110_pllx_set_rate, + .get_rate = jh7110_pllx_recalc_rate, +}; + +struct clk *starfive_jh7110_pll(const char *name, const char *parent_name, + void __iomem *base, void __iomem *sysreg, + const struct starfive_pllx_clk *pll_clk) +{ + struct clk_jh7110_pllx *pll; + struct clk *clk; + int ret; + + if (!pll_clk || !base || !sysreg) + return ERR_PTR(-EINVAL); + + pll = kzalloc(sizeof(*pll), GFP_KERNEL); + if (!pll) + return ERR_PTR(-ENOMEM); + + pll->base = base; + pll->sysreg = sysreg; + pll->type = pll_clk->type; + pll->offset = pll_clk->offset; + pll->rate_table = pll_clk->rate_table; + pll->rate_count = pll_clk->rate_count; + + clk = &pll->clk; + ret = clk_register(clk, UBOOT_DM_CLK_JH7110_PLLX, name, parent_name); + if (ret) { + kfree(pll); + return ERR_PTR(ret); + } + + if (IS_ENABLED(CONFIG_SPL_BUILD) && pll->type == PLL0) + jh7110_pllx_set_rate(clk, 1000000000); + + if (IS_ENABLED(CONFIG_SPL_BUILD) && pll->type == PLL2) + jh7110_pllx_set_rate(clk, 1188000000); + + return clk; +} + +U_BOOT_DRIVER(jh7110_clk_pllx) = { + .name = UBOOT_DM_CLK_JH7110_PLLX, + .id = UCLASS_CLK, + .ops = &clk_jh7110_ops, +}; diff --git a/drivers/clk/starfive/clk-jh7110.c b/drivers/clk/starfive/clk-jh7110.c new file mode 100644 index 0000000000..3ca0220f9c --- /dev/null +++ b/drivers/clk/starfive/clk-jh7110.c @@ -0,0 +1,577 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022-23 StarFive Technology Co., Ltd. + * + * Author: Yanhong Wang yanhong.wang@starfivetech.com + */ + +#include <common.h> +#include <clk.h> +#include <clk-uclass.h> +#include <dm.h> +#include <dm/device.h> +#include <dm/devres.h> +#include <dm/lists.h> +#include <dt-bindings/clock/starfive,jh7110-crg.h> +#include <log.h> +#include <linux/clk-provider.h> + +#include "clk.h" + +#define STARFIVE_CLK_ENABLE_SHIFT 31 /* [31] */ +#define STARFIVE_CLK_INVERT_SHIFT 30 /* [30] */ +#define STARFIVE_CLK_MUX_SHIFT 24 /* [29:24] */ +#define STARFIVE_CLK_DIV_SHIFT 0 /* [23:0] */ + +#define OFFSET(id) ((id) * 4) +#define AONOFFSET(id) (((id) - JH7110_SYSCLK_END) * 4) +#define STGOFFSET(id) (((id) - JH7110_AONCLK_END) * 4) + +typedef int (*jh1710_init_fn)(struct udevice *dev); + +struct jh7110_clk_priv { + void __iomem *reg; + jh1710_init_fn init; +}; + +static const char *cpu_root_sels[2] = { + [0] = "oscillator", + [1] = "pll0_out", +}; + +static const char *perh_root_sels[2] = { + [0] = "pll0_out", + [1] = "pll2_out", +}; + +static const char *bus_root_sels[2] = { + [0] = "oscillator", + [1] = "pll2_out", +}; + +static const char *qspi_ref_sels[2] = { + [0] = "oscillator", + [1] = "qspi_ref_src", +}; + +static const char *gmac1_tx_sels[2] = { + [0] = "gmac1_gtxclk", + [1] = "gmac1_rmii_rtx", +}; + +static const char *gmac0_tx_sels[2] = { + [0] = "gmac0_gtxclk", + [1] = "gmac0_rmii_rtx", +}; + +static const char *apb_func_sels[2] = { + [0] = "osc_div4", + [1] = "oscillator", +}; + +static struct clk *starfive_clk_mux(void __iomem *reg, + const char *name, + unsigned int offset, + u8 width, + const char * const *parent_names, + u8 num_parents) +{ + return clk_register_mux(NULL, name, parent_names, num_parents, 0, + reg + offset, STARFIVE_CLK_MUX_SHIFT, + width, 0); +} + +static struct clk *starfive_clk_gate(void __iomem *reg, + const char *name, + const char *parent_name, + unsigned int offset) +{ + return clk_register_gate(NULL, name, parent_name, 0, reg + offset, + STARFIVE_CLK_ENABLE_SHIFT, 0, NULL); +} + +static struct clk *starfive_clk_divider(void __iomem *reg, + const char *name, + const char *parent_name, + unsigned int offset, + u8 width) +{ + return clk_register_divider(NULL, name, parent_name, 0, reg + offset, + 0, width, CLK_DIVIDER_ONE_BASED); +} + +static struct clk *starfive_clk_composite(void __iomem *reg, + const char *name, + const char * const *parent_names, + unsigned int num_parents, + unsigned int offset, + unsigned int mux_width, + unsigned int gate_width, + unsigned int div_width) +{ + struct clk *clk = ERR_PTR(-ENOMEM); + struct clk_divider *div = NULL; + struct clk_gate *gate = NULL; + struct clk_mux *mux = NULL; + int mask_arry[4] = {0x1, 0x3, 0x7, 0xF}; + int mask; + + if (mux_width) { + if (mux_width > 4) + goto fail; + else + mask = mask_arry[mux_width - 1]; + + mux = kzalloc(sizeof(*mux), GFP_KERNEL); + if (!mux) + goto fail; + + mux->reg = reg + offset; + mux->mask = mask; + mux->shift = STARFIVE_CLK_MUX_SHIFT; + mux->num_parents = num_parents; + mux->flags = 0; + mux->parent_names = parent_names; + } + + if (gate_width) { + gate = kzalloc(sizeof(*gate), GFP_KERNEL); + + if (!gate) + goto fail; + + gate->reg = reg + offset; + gate->bit_idx = STARFIVE_CLK_ENABLE_SHIFT; + gate->flags = 0; + } + + if (div_width) { + div = kzalloc(sizeof(*div), GFP_KERNEL); + if (!div) + goto fail; + + div->reg = reg + offset; + + if (offset == OFFSET(JH7110_SYSCLK_UART3_CORE) || + offset == OFFSET(JH7110_SYSCLK_UART4_CORE) || + offset == OFFSET(JH7110_SYSCLK_UART5_CORE)) { + div->shift = 8; + div->width = 8; + } else { + div->shift = STARFIVE_CLK_DIV_SHIFT; + div->width = div_width; + } + div->flags = CLK_DIVIDER_ONE_BASED; + div->table = NULL; + } + + clk = clk_register_composite(NULL, name, + parent_names, num_parents, + &mux->clk, &clk_mux_ops, + &div->clk, &clk_divider_ops, + &gate->clk, &clk_gate_ops, 0); + + if (IS_ERR(clk)) + goto fail; + + return clk; + +fail: + kfree(gate); + kfree(div); + kfree(mux); + return ERR_CAST(clk); +} + +static struct clk *starfive_clk_fix_parent_composite(void __iomem *reg, + const char *name, + const char *parent_names, + unsigned int offset, + unsigned int mux_width, + unsigned int gate_width, + unsigned int div_width) +{ + const char * const *parents; + + parents = &parent_names; + + return starfive_clk_composite(reg, name, parents, 1, offset, + mux_width, gate_width, div_width); +} + +static struct clk *starfive_clk_gate_divider(void __iomem *reg, + const char *name, + const char *parent, + unsigned int offset, + unsigned int width) +{ + const char * const *parent_names; + + parent_names = &parent; + + return starfive_clk_composite(reg, name, parent_names, 1, + offset, 0, 1, width); +} + +static int jh7110_syscrg_init(struct udevice *dev) +{ + struct jh7110_clk_priv *priv = dev_get_priv(dev); + struct ofnode_phandle_args args; + fdt_addr_t addr; + struct clk *pclk; + int ret; + + ret = ofnode_parse_phandle_with_args(dev->node_, "starfive,sys-syscon", NULL, 0, 0, &args); + if (ret) + return ret; + + addr = ofnode_get_addr(args.node); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + clk_dm(JH7110_SYSCLK_PLL0_OUT, + starfive_jh7110_pll("pll0_out", "oscillator", (void __iomem *)addr, + priv->reg, &starfive_jh7110_pll0)); + clk_dm(JH7110_SYSCLK_PLL1_OUT, + starfive_jh7110_pll("pll1_out", "oscillator", (void __iomem *)addr, + priv->reg, &starfive_jh7110_pll1)); + clk_dm(JH7110_SYSCLK_PLL2_OUT, + starfive_jh7110_pll("pll2_out", "oscillator", (void __iomem *)addr, + priv->reg, &starfive_jh7110_pll2)); + clk_dm(JH7110_SYSCLK_CPU_ROOT, + starfive_clk_mux(priv->reg, "cpu_root", + OFFSET(JH7110_SYSCLK_CPU_ROOT), 1, + cpu_root_sels, ARRAY_SIZE(cpu_root_sels))); + clk_dm(JH7110_SYSCLK_CPU_CORE, + starfive_clk_divider(priv->reg, + "cpu_core", "cpu_root", + OFFSET(JH7110_SYSCLK_CPU_CORE), 3)); + clk_dm(JH7110_SYSCLK_CPU_BUS, + starfive_clk_divider(priv->reg, + "cpu_bus", "cpu_core", + OFFSET(JH7110_SYSCLK_CPU_BUS), 2)); + clk_dm(JH7110_SYSCLK_PERH_ROOT, + starfive_clk_composite(priv->reg, + "perh_root", + perh_root_sels, ARRAY_SIZE(perh_root_sels), + OFFSET(JH7110_SYSCLK_PERH_ROOT), 1, 0, 2)); + clk_dm(JH7110_SYSCLK_BUS_ROOT, + starfive_clk_mux(priv->reg, "bus_root", + OFFSET(JH7110_SYSCLK_BUS_ROOT), 1, + bus_root_sels, ARRAY_SIZE(bus_root_sels))); + clk_dm(JH7110_SYSCLK_NOCSTG_BUS, + starfive_clk_divider(priv->reg, + "nocstg_bus", "bus_root", + OFFSET(JH7110_SYSCLK_NOCSTG_BUS), 3)); + clk_dm(JH7110_SYSCLK_AXI_CFG0, + starfive_clk_divider(priv->reg, + "axi_cfg0", "bus_root", + OFFSET(JH7110_SYSCLK_AXI_CFG0), 2)); + clk_dm(JH7110_SYSCLK_STG_AXIAHB, + starfive_clk_divider(priv->reg, + "stg_axiahb", "axi_cfg0", + OFFSET(JH7110_SYSCLK_STG_AXIAHB), 2)); + clk_dm(JH7110_SYSCLK_AHB0, + starfive_clk_gate(priv->reg, + "ahb0", "stg_axiahb", + OFFSET(JH7110_SYSCLK_AHB0))); + clk_dm(JH7110_SYSCLK_AHB1, + starfive_clk_gate(priv->reg, + "ahb1", "stg_axiahb", + OFFSET(JH7110_SYSCLK_AHB1))); + clk_dm(JH7110_SYSCLK_APB_BUS, + starfive_clk_divider(priv->reg, + "apb_bus", "stg_axiahb", + OFFSET(JH7110_SYSCLK_APB_BUS), 4)); + clk_dm(JH7110_SYSCLK_APB0, + starfive_clk_gate(priv->reg, + "apb0", "stg_axiahb", + OFFSET(JH7110_SYSCLK_APB0))); + clk_dm(JH7110_SYSCLK_QSPI_AHB, + starfive_clk_gate(priv->reg, + "qspi_ahb", "ahb1", + OFFSET(JH7110_SYSCLK_QSPI_AHB))); + clk_dm(JH7110_SYSCLK_QSPI_APB, + starfive_clk_gate(priv->reg, + "qspi_apb", "stg_axiahb", + OFFSET(JH7110_SYSCLK_QSPI_APB))); + clk_dm(JH7110_SYSCLK_QSPI_REF_SRC, + starfive_clk_divider(priv->reg, + "qspi_ref_src", "pll0_out", + OFFSET(JH7110_SYSCLK_QSPI_REF_SRC), 5)); + clk_dm(JH7110_SYSCLK_QSPI_REF, + starfive_clk_composite(priv->reg, + "qspi_ref", + qspi_ref_sels, ARRAY_SIZE(qspi_ref_sels), + OFFSET(JH7110_SYSCLK_QSPI_REF), 1, 1, 0)); + clk_dm(JH7110_SYSCLK_SDIO0_AHB, + starfive_clk_gate(priv->reg, + "sdio0_ahb", "ahb0", + OFFSET(JH7110_SYSCLK_SDIO0_AHB))); + clk_dm(JH7110_SYSCLK_SDIO1_AHB, + starfive_clk_gate(priv->reg, + "sdio1_ahb", "ahb0", + OFFSET(JH7110_SYSCLK_SDIO1_AHB))); + clk_dm(JH7110_SYSCLK_SDIO0_SDCARD, + starfive_clk_fix_parent_composite(priv->reg, + "sdio0_sdcard", "axi_cfg0", + OFFSET(JH7110_SYSCLK_SDIO0_SDCARD), 0, 1, 4)); + clk_dm(JH7110_SYSCLK_SDIO1_SDCARD, + starfive_clk_fix_parent_composite(priv->reg, + "sdio1_sdcard", "axi_cfg0", + OFFSET(JH7110_SYSCLK_SDIO1_SDCARD), 0, 1, 4)); + clk_dm(JH7110_SYSCLK_USB_125M, + starfive_clk_divider(priv->reg, + "usb_125m", "pll0_out", + OFFSET(JH7110_SYSCLK_USB_125M), 4)); + clk_dm(JH7110_SYSCLK_NOC_BUS_STG_AXI, + starfive_clk_gate(priv->reg, + "noc_bus_stg_axi", "nocstg_bus", + OFFSET(JH7110_SYSCLK_NOC_BUS_STG_AXI))); + clk_dm(JH7110_SYSCLK_GMAC1_AHB, + starfive_clk_gate(priv->reg, + "gmac1_ahb", "ahb0", + OFFSET(JH7110_SYSCLK_GMAC1_AHB))); + clk_dm(JH7110_SYSCLK_GMAC1_AXI, + starfive_clk_gate(priv->reg, + "gmac1_axi", "stg_axiahb", + OFFSET(JH7110_SYSCLK_GMAC1_AXI))); + clk_dm(JH7110_SYSCLK_GMAC_SRC, + starfive_clk_divider(priv->reg, + "gmac_src", "pll0_out", + OFFSET(JH7110_SYSCLK_GMAC_SRC), 3)); + clk_dm(JH7110_SYSCLK_GMAC1_GTXCLK, + starfive_clk_divider(priv->reg, + "gmac1_gtxclk", "pll0_out", + OFFSET(JH7110_SYSCLK_GMAC1_GTXCLK), 4)); + clk_dm(JH7110_SYSCLK_GMAC1_GTXC, + starfive_clk_gate(priv->reg, + "gmac1_gtxc", "gmac1_gtxclk", + OFFSET(JH7110_SYSCLK_GMAC1_GTXC))); + clk_dm(JH7110_SYSCLK_GMAC1_RMII_RTX, + starfive_clk_divider(priv->reg, + "gmac1_rmii_rtx", "gmac1-rmii-refin-clock", + OFFSET(JH7110_SYSCLK_GMAC1_RMII_RTX), 5)); + clk_dm(JH7110_SYSCLK_GMAC1_PTP, + starfive_clk_gate_divider(priv->reg, + "gmac1_ptp", "gmac_src", + OFFSET(JH7110_SYSCLK_GMAC1_PTP), 5)); + clk_dm(JH7110_SYSCLK_GMAC1_TX, + starfive_clk_composite(priv->reg, + "gmac1_tx", + gmac1_tx_sels, ARRAY_SIZE(gmac1_tx_sels), + OFFSET(JH7110_SYSCLK_GMAC1_TX), 1, 1, 0)); + clk_dm(JH7110_SYSCLK_GMAC0_GTXCLK, + starfive_clk_gate_divider(priv->reg, + "gmac0_gtxclk", "pll0_out", + OFFSET(JH7110_SYSCLK_GMAC0_GTXCLK), 4)); + clk_dm(JH7110_SYSCLK_GMAC0_PTP, + starfive_clk_gate_divider(priv->reg, + "gmac0_ptp", "gmac_src", + OFFSET(JH7110_SYSCLK_GMAC0_PTP), 5)); + clk_dm(JH7110_SYSCLK_GMAC0_GTXC, + starfive_clk_gate(priv->reg, + "gmac0_gtxc", "gmac0_gtxclk", + OFFSET(JH7110_SYSCLK_GMAC0_GTXC))); + clk_dm(JH7110_SYSCLK_UART0_APB, + starfive_clk_gate(priv->reg, + "uart0_apb", "apb0", + OFFSET(JH7110_SYSCLK_UART0_APB))); + clk_dm(JH7110_SYSCLK_UART0_CORE, + starfive_clk_gate(priv->reg, + "uart0_core", "oscillator", + OFFSET(JH7110_SYSCLK_UART0_CORE))); + clk_dm(JH7110_SYSCLK_UART1_APB, + starfive_clk_gate(priv->reg, + "uart1_apb", "apb0", + OFFSET(JH7110_SYSCLK_UART1_APB))); + clk_dm(JH7110_SYSCLK_UART1_CORE, + starfive_clk_gate(priv->reg, + "uart1_core", "oscillator", + OFFSET(JH7110_SYSCLK_UART1_CORE))); + clk_dm(JH7110_SYSCLK_UART2_APB, + starfive_clk_gate(priv->reg, + "uart2_apb", "apb0", + OFFSET(JH7110_SYSCLK_UART2_APB))); + clk_dm(JH7110_SYSCLK_UART2_CORE, + starfive_clk_gate(priv->reg, + "uart2_core", "oscillator", + OFFSET(JH7110_SYSCLK_UART2_CORE))); + clk_dm(JH7110_SYSCLK_UART3_APB, + starfive_clk_gate(priv->reg, + "uart3_apb", "apb0", + OFFSET(JH7110_SYSCLK_UART3_APB))); + clk_dm(JH7110_SYSCLK_UART3_CORE, + starfive_clk_gate_divider(priv->reg, + "uart3_core", "perh_root", + OFFSET(JH7110_SYSCLK_UART3_CORE), 8)); + clk_dm(JH7110_SYSCLK_UART4_APB, + starfive_clk_gate(priv->reg, + "uart4_apb", "apb0", + OFFSET(JH7110_SYSCLK_UART4_APB))); + clk_dm(JH7110_SYSCLK_UART4_CORE, + starfive_clk_gate_divider(priv->reg, + "uart4_core", "perh_root", + OFFSET(JH7110_SYSCLK_UART4_CORE), 8)); + clk_dm(JH7110_SYSCLK_UART5_APB, + starfive_clk_gate(priv->reg, + "uart5_apb", "apb0", + OFFSET(JH7110_SYSCLK_UART5_APB))); + clk_dm(JH7110_SYSCLK_UART5_CORE, + starfive_clk_gate_divider(priv->reg, + "uart5_core", "perh_root", + OFFSET(JH7110_SYSCLK_UART5_CORE), 8)); + clk_dm(JH7110_SYSCLK_I2C2_APB, + starfive_clk_gate(priv->reg, + "i2c2_apb", "stg_axiahb", + OFFSET(JH7110_SYSCLK_I2C2_APB))); + clk_dm(JH7110_SYSCLK_I2C5_APB, + starfive_clk_gate(priv->reg, + "i2c5_apb", "stg_axiahb", + OFFSET(JH7110_SYSCLK_I2C5_APB))); + + /* enable noc_bus_stg_axi clock */ + if (!clk_get_by_id(JH7110_SYSCLK_NOC_BUS_STG_AXI, &pclk)) + clk_enable(pclk); + + return 0; +} + +static int jh7110_aoncrg_init(struct udevice *dev) +{ + struct jh7110_clk_priv *priv = dev_get_priv(dev); + + clk_dm(JH7110_AONCLK_OSC_DIV4, + starfive_clk_divider(priv->reg, + "osc_div4", "oscillator", + AONOFFSET(JH7110_AONCLK_OSC_DIV4), 5)); + clk_dm(JH7110_AONCLK_APB_FUNC, + starfive_clk_mux(priv->reg, "apb_func", + AONOFFSET(JH7110_AONCLK_APB_FUNC), 1, + apb_func_sels, ARRAY_SIZE(apb_func_sels))); + clk_dm(JH7110_AONCLK_GMAC0_AHB, + starfive_clk_gate(priv->reg, + "gmac0_ahb", "stg_axiahb", + AONOFFSET(JH7110_AONCLK_GMAC0_AHB))); + clk_dm(JH7110_AONCLK_GMAC0_AXI, + starfive_clk_gate(priv->reg, + "gmac0_axi", "stg_axiahb", + AONOFFSET(JH7110_AONCLK_GMAC0_AXI))); + clk_dm(JH7110_AONCLK_GMAC0_RMII_RTX, + starfive_clk_divider(priv->reg, + "gmac0_rmii_rtx", "gmac0-rmii-refin-clock", + AONOFFSET(JH7110_AONCLK_GMAC0_RMII_RTX), 5)); + clk_dm(JH7110_AONCLK_GMAC0_TX, + starfive_clk_composite(priv->reg, + "gmac0_tx", gmac0_tx_sels, + ARRAY_SIZE(gmac0_tx_sels), + AONOFFSET(JH7110_AONCLK_GMAC0_TX), 1, 1, 0)); + clk_dm(JH7110_AONCLK_OTPC_APB, + starfive_clk_gate(priv->reg, + "otpc_apb", "stg_axiahb", + AONOFFSET(JH7110_AONCLK_OTPC_APB))); + + return 0; +} + +static int jh7110_stgcrg_init(struct udevice *dev) +{ + struct jh7110_clk_priv *priv = dev_get_priv(dev); + + clk_dm(JH7110_STGCLK_USB_APB, + starfive_clk_gate(priv->reg, + "usb_apb", "stg_axiahb", + STGOFFSET(JH7110_STGCLK_USB_APB))); + clk_dm(JH7110_STGCLK_USB_UTMI_APB, + starfive_clk_gate(priv->reg, + "usb_utmi_apb", "stg_axiahb", + STGOFFSET(JH7110_STGCLK_USB_UTMI_APB))); + clk_dm(JH7110_STGCLK_USB_AXI, + starfive_clk_gate(priv->reg, + "usb_axi", "stg_axiahb", + STGOFFSET(JH7110_STGCLK_USB_AXI))); + clk_dm(JH7110_STGCLK_USB_LPM, + starfive_clk_gate_divider(priv->reg, + "usb_lpm", "oscillator", + STGOFFSET(JH7110_STGCLK_USB_LPM), 2)); + clk_dm(JH7110_STGCLK_USB_STB, + starfive_clk_gate_divider(priv->reg, + "usb_stb", "oscillator", + STGOFFSET(JH7110_STGCLK_USB_STB), 3)); + clk_dm(JH7110_STGCLK_USB_APP_125, + starfive_clk_gate(priv->reg, + "usb_app_125", "usb_125m", + STGOFFSET(JH7110_STGCLK_USB_APP_125))); + clk_dm(JH7110_STGCLK_USB_REFCLK, + starfive_clk_divider(priv->reg, "usb_refclk", "oscillator", + STGOFFSET(JH7110_STGCLK_USB_REFCLK), 2)); + clk_dm(JH7110_STGCLK_PCIE0_AXI, + starfive_clk_gate(priv->reg, + "pcie0_axi", "stg_axiahb", + STGOFFSET(JH7110_STGCLK_PCIE0_AXI))); + clk_dm(JH7110_STGCLK_PCIE0_APB, + starfive_clk_gate(priv->reg, + "pcie0_apb", "stg_axiahb", + STGOFFSET(JH7110_STGCLK_PCIE0_APB))); + clk_dm(JH7110_STGCLK_PCIE0_TL, + starfive_clk_gate(priv->reg, + "pcie0_tl", "stg_axiahb", + STGOFFSET(JH7110_STGCLK_PCIE0_TL))); + clk_dm(JH7110_STGCLK_PCIE1_AXI, + starfive_clk_gate(priv->reg, + "pcie1_axi", "stg_axiahb", + STGOFFSET(JH7110_STGCLK_PCIE1_AXI))); + clk_dm(JH7110_STGCLK_PCIE1_APB, + starfive_clk_gate(priv->reg, + "pcie1_apb", "stg_axiahb", + STGOFFSET(JH7110_STGCLK_PCIE1_APB))); + clk_dm(JH7110_STGCLK_PCIE1_TL, + starfive_clk_gate(priv->reg, + "pcie1_tl", "stg_axiahb", + STGOFFSET(JH7110_STGCLK_PCIE1_TL))); + + return 0; +} + +static int jh7110_clk_probe(struct udevice *dev) +{ + struct jh7110_clk_priv *priv = dev_get_priv(dev); + + priv->init = (jh1710_init_fn)dev_get_driver_data(dev); + priv->reg = (void __iomem *)dev_read_addr_ptr(dev); + + if (priv->init) + return priv->init(dev); + + return 0; +} + +static int jh7110_clk_bind(struct udevice *dev) +{ + /* The reset driver does not have a device node, so bind it here */ + return device_bind_driver_to_node(dev, "jh7110_reset", dev->name, + dev_ofnode(dev), NULL); +} + +static const struct udevice_id jh7110_clk_of_match[] = { + { .compatible = "starfive,jh7110-syscrg", + .data = (ulong)&jh7110_syscrg_init + }, + { .compatible = "starfive,jh7110-stgcrg", + .data = (ulong)&jh7110_stgcrg_init + }, + { .compatible = "starfive,jh7110-aoncrg", + .data = (ulong)&jh7110_aoncrg_init + }, + { } +}; + +U_BOOT_DRIVER(jh7110_clk) = { + .name = "jh7110_clk", + .id = UCLASS_CLK, + .of_match = jh7110_clk_of_match, + .probe = jh7110_clk_probe, + .ops = &ccf_clk_ops, + .priv_auto = sizeof(struct jh7110_clk_priv), + .bind = jh7110_clk_bind, +}; diff --git a/drivers/clk/starfive/clk.h b/drivers/clk/starfive/clk.h new file mode 100644 index 0000000000..4dee12fe89 --- /dev/null +++ b/drivers/clk/starfive/clk.h @@ -0,0 +1,57 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2022 Starfive, Inc. + * Author: Yanhong Wang yanhong.wang@starfivetech.com + * + */ + +#ifndef __CLK_STARFIVE_H +#define __CLK_STARFIVE_H + +enum starfive_pll_type { + PLL0 = 0, + PLL1, + PLL2, + PLL_MAX = PLL2 +}; + +struct starfive_pllx_rate { + u64 rate; + u32 prediv; + u32 fbdiv; + u32 frac; +}; + +struct starfive_pllx_offset { + u32 pd; + u32 prediv; + u32 fbdiv; + u32 frac; + u32 postdiv1; + u32 dacpd; + u32 dsmpd; + u32 pd_mask; + u32 prediv_mask; + u32 fbdiv_mask; + u32 frac_mask; + u32 postdiv1_mask; + u32 dacpd_mask; + u32 dsmpd_mask; +}; + +struct starfive_pllx_clk { + enum starfive_pll_type type; + const struct starfive_pllx_offset *offset; + const struct starfive_pllx_rate *rate_table; + int rate_count; + int flags; +}; + +extern struct starfive_pllx_clk starfive_jh7110_pll0; +extern struct starfive_pllx_clk starfive_jh7110_pll1; +extern struct starfive_pllx_clk starfive_jh7110_pll2; + +struct clk *starfive_jh7110_pll(const char *name, const char *parent_name, + void __iomem *base, void __iomem *sysreg, + const struct starfive_pllx_clk *pll_clk); +#endif
From: Jianlong Huang jianlong.huang@starfivetech.com
Add pinctrl definitions for StarFive JH7110 SoC.
Signed-off-by: Kuan Lim Lee kuanlim.lee@linux.starfivetech.com Signed-off-by: Emil Renner Berthing kernel@esmil.dk Signed-off-by: Jianlong Huang jianlong.huang@starfivetech.com Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- .../pinctrl/pinctrl-starfive-jh7110.h | 427 ++++++++++++++++++ 1 file changed, 427 insertions(+) create mode 100644 include/dt-bindings/pinctrl/pinctrl-starfive-jh7110.h
diff --git a/include/dt-bindings/pinctrl/pinctrl-starfive-jh7110.h b/include/dt-bindings/pinctrl/pinctrl-starfive-jh7110.h new file mode 100644 index 0000000000..f273547e7b --- /dev/null +++ b/include/dt-bindings/pinctrl/pinctrl-starfive-jh7110.h @@ -0,0 +1,427 @@ +/* SPDX-License-Identifier: GPL-2.0 OR MIT */ +/* + * Copyright (C) 2022 Emil Renner Berthing kernel@esmil.dk + * Copyright (C) 2022 StarFive Technology Co., Ltd. + */ + +#ifndef __DT_BINDINGS_PINCTRL_STARFIVE_JH7110_H__ +#define __DT_BINDINGS_PINCTRL_STARFIVE_JH7110_H__ + +/* + * mux bits: + * | 31 - 24 | 23 - 16 | 15 - 10 | 9 - 8 | 7 - 0 | + * | din | dout | doen | function | gpio nr | + * + * dout: output signal + * doen: output enable signal + * din: optional input signal, 0xff = none + * function: + * gpio nr: gpio number, 0 - 63 + */ +#define GPIOMUX(n, dout, doen, din) ( \ + (((din) & 0xff) << 24) | \ + (((dout) & 0xff) << 16) | \ + (((doen) & 0x3f) << 10) | \ + ((n) & 0x3f)) + +#define PINMUX(n, func) ((1 << 10) | (((func) & 0x3) << 8) | ((n) & 0xff)) + +/* sys_iomux pin */ +#define PAD_GPIO0 0 +#define PAD_GPIO1 1 +#define PAD_GPIO2 2 +#define PAD_GPIO3 3 +#define PAD_GPIO4 4 +#define PAD_GPIO5 5 +#define PAD_GPIO6 6 +#define PAD_GPIO7 7 +#define PAD_GPIO8 8 +#define PAD_GPIO9 9 +#define PAD_GPIO10 10 +#define PAD_GPIO11 11 +#define PAD_GPIO12 12 +#define PAD_GPIO13 13 +#define PAD_GPIO14 14 +#define PAD_GPIO15 15 +#define PAD_GPIO16 16 +#define PAD_GPIO17 17 +#define PAD_GPIO18 18 +#define PAD_GPIO19 19 +#define PAD_GPIO20 20 +#define PAD_GPIO21 21 +#define PAD_GPIO22 22 +#define PAD_GPIO23 23 +#define PAD_GPIO24 24 +#define PAD_GPIO25 25 +#define PAD_GPIO26 26 +#define PAD_GPIO27 27 +#define PAD_GPIO28 28 +#define PAD_GPIO29 29 +#define PAD_GPIO30 30 +#define PAD_GPIO31 31 +#define PAD_GPIO32 32 +#define PAD_GPIO33 33 +#define PAD_GPIO34 34 +#define PAD_GPIO35 35 +#define PAD_GPIO36 36 +#define PAD_GPIO37 37 +#define PAD_GPIO38 38 +#define PAD_GPIO39 39 +#define PAD_GPIO40 40 +#define PAD_GPIO41 41 +#define PAD_GPIO42 42 +#define PAD_GPIO43 43 +#define PAD_GPIO44 44 +#define PAD_GPIO45 45 +#define PAD_GPIO46 46 +#define PAD_GPIO47 47 +#define PAD_GPIO48 48 +#define PAD_GPIO49 49 +#define PAD_GPIO50 50 +#define PAD_GPIO51 51 +#define PAD_GPIO52 52 +#define PAD_GPIO53 53 +#define PAD_GPIO54 54 +#define PAD_GPIO55 55 +#define PAD_GPIO56 56 +#define PAD_GPIO57 57 +#define PAD_GPIO58 58 +#define PAD_GPIO59 59 +#define PAD_GPIO60 60 +#define PAD_GPIO61 61 +#define PAD_GPIO62 62 +#define PAD_GPIO63 63 +#define PAD_SD0_CLK 64 +#define PAD_SD0_CMD 65 +#define PAD_SD0_DATA0 66 +#define PAD_SD0_DATA1 67 +#define PAD_SD0_DATA2 68 +#define PAD_SD0_DATA3 69 +#define PAD_SD0_DATA4 70 +#define PAD_SD0_DATA5 71 +#define PAD_SD0_DATA6 72 +#define PAD_SD0_DATA7 73 +#define PAD_SD0_STRB 74 +#define PAD_GMAC1_MDC 75 +#define PAD_GMAC1_MDIO 76 +#define PAD_GMAC1_RXD0 77 +#define PAD_GMAC1_RXD1 78 +#define PAD_GMAC1_RXD2 79 +#define PAD_GMAC1_RXD3 80 +#define PAD_GMAC1_RXDV 81 +#define PAD_GMAC1_RXC 82 +#define PAD_GMAC1_TXD0 83 +#define PAD_GMAC1_TXD1 84 +#define PAD_GMAC1_TXD2 85 +#define PAD_GMAC1_TXD3 86 +#define PAD_GMAC1_TXEN 87 +#define PAD_GMAC1_TXC 88 +#define PAD_QSPI_SCLK 89 +#define PAD_QSPI_CS0 90 +#define PAD_QSPI_DATA0 91 +#define PAD_QSPI_DATA1 92 +#define PAD_QSPI_DATA2 93 +#define PAD_QSPI_DATA3 94 + +/* aon_iomux pin */ +#define PAD_TESTEN 0 +#define PAD_RGPIO0 1 +#define PAD_RGPIO1 2 +#define PAD_RGPIO2 3 +#define PAD_RGPIO3 4 +#define PAD_RSTN 5 +#define PAD_GMAC0_MDC 6 +#define PAD_GMAC0_MDIO 7 +#define PAD_GMAC0_RXD0 8 +#define PAD_GMAC0_RXD1 9 +#define PAD_GMAC0_RXD2 10 +#define PAD_GMAC0_RXD3 11 +#define PAD_GMAC0_RXDV 12 +#define PAD_GMAC0_RXC 13 +#define PAD_GMAC0_TXD0 14 +#define PAD_GMAC0_TXD1 15 +#define PAD_GMAC0_TXD2 16 +#define PAD_GMAC0_TXD3 17 +#define PAD_GMAC0_TXEN 18 +#define PAD_GMAC0_TXC 19 + +/* sys_iomux dout */ +#define GPOUT_LOW 0 +#define GPOUT_HIGH 1 +#define GPOUT_SYS_WAVE511_UART_TX 2 +#define GPOUT_SYS_CAN0_STBY 3 +#define GPOUT_SYS_CAN0_TST_NEXT_BIT 4 +#define GPOUT_SYS_CAN0_TST_SAMPLE_POINT 5 +#define GPOUT_SYS_CAN0_TXD 6 +#define GPOUT_SYS_USB_DRIVE_VBUS 7 +#define GPOUT_SYS_QSPI_CS1 8 +#define GPOUT_SYS_SPDIF 9 +#define GPOUT_SYS_HDMI_CEC_SDA 10 +#define GPOUT_SYS_HDMI_DDC_SCL 11 +#define GPOUT_SYS_HDMI_DDC_SDA 12 +#define GPOUT_SYS_WATCHDOG 13 +#define GPOUT_SYS_I2C0_CLK 14 +#define GPOUT_SYS_I2C0_DATA 15 +#define GPOUT_SYS_SDIO0_BACK_END_POWER 16 +#define GPOUT_SYS_SDIO0_CARD_POWER_EN 17 +#define GPOUT_SYS_SDIO0_CCMD_OD_PULLUP_EN 18 +#define GPOUT_SYS_SDIO0_RST 19 +#define GPOUT_SYS_UART0_TX 20 +#define GPOUT_SYS_HIFI4_JTAG_TDO 21 +#define GPOUT_SYS_JTAG_TDO 22 +#define GPOUT_SYS_PDM_MCLK 23 +#define GPOUT_SYS_PWM_CHANNEL0 24 +#define GPOUT_SYS_PWM_CHANNEL1 25 +#define GPOUT_SYS_PWM_CHANNEL2 26 +#define GPOUT_SYS_PWM_CHANNEL3 27 +#define GPOUT_SYS_PWMDAC_LEFT 28 +#define GPOUT_SYS_PWMDAC_RIGHT 29 +#define GPOUT_SYS_SPI0_CLK 30 +#define GPOUT_SYS_SPI0_FSS 31 +#define GPOUT_SYS_SPI0_TXD 32 +#define GPOUT_SYS_GMAC_PHYCLK 33 +#define GPOUT_SYS_I2SRX_BCLK 34 +#define GPOUT_SYS_I2SRX_LRCK 35 +#define GPOUT_SYS_I2STX0_BCLK 36 +#define GPOUT_SYS_I2STX0_LRCK 37 +#define GPOUT_SYS_MCLK 38 +#define GPOUT_SYS_TDM_CLK 39 +#define GPOUT_SYS_TDM_SYNC 40 +#define GPOUT_SYS_TDM_TXD 41 +#define GPOUT_SYS_TRACE_DATA0 42 +#define GPOUT_SYS_TRACE_DATA1 43 +#define GPOUT_SYS_TRACE_DATA2 44 +#define GPOUT_SYS_TRACE_DATA3 45 +#define GPOUT_SYS_TRACE_REF 46 +#define GPOUT_SYS_CAN1_STBY 47 +#define GPOUT_SYS_CAN1_TST_NEXT_BIT 48 +#define GPOUT_SYS_CAN1_TST_SAMPLE_POINT 49 +#define GPOUT_SYS_CAN1_TXD 50 +#define GPOUT_SYS_I2C1_CLK 51 +#define GPOUT_SYS_I2C1_DATA 52 +#define GPOUT_SYS_SDIO1_BACK_END_POWER 53 +#define GPOUT_SYS_SDIO1_CARD_POWER_EN 54 +#define GPOUT_SYS_SDIO1_CLK 55 +#define GPOUT_SYS_SDIO1_CMD_OD_PULLUP_EN 56 +#define GPOUT_SYS_SDIO1_CMD 57 +#define GPOUT_SYS_SDIO1_DATA0 58 +#define GPOUT_SYS_SDIO1_DATA1 59 +#define GPOUT_SYS_SDIO1_DATA2 60 +#define GPOUT_SYS_SDIO1_DATA3 61 +#define GPOUT_SYS_SDIO1_DATA4 63 +#define GPOUT_SYS_SDIO1_DATA5 63 +#define GPOUT_SYS_SDIO1_DATA6 64 +#define GPOUT_SYS_SDIO1_DATA7 65 +#define GPOUT_SYS_SDIO1_RST 66 +#define GPOUT_SYS_UART1_RTS 67 +#define GPOUT_SYS_UART1_TX 68 +#define GPOUT_SYS_I2STX1_SDO0 69 +#define GPOUT_SYS_I2STX1_SDO1 70 +#define GPOUT_SYS_I2STX1_SDO2 71 +#define GPOUT_SYS_I2STX1_SDO3 72 +#define GPOUT_SYS_SPI1_CLK 73 +#define GPOUT_SYS_SPI1_FSS 74 +#define GPOUT_SYS_SPI1_TXD 75 +#define GPOUT_SYS_I2C2_CLK 76 +#define GPOUT_SYS_I2C2_DATA 77 +#define GPOUT_SYS_UART2_RTS 78 +#define GPOUT_SYS_UART2_TX 79 +#define GPOUT_SYS_SPI2_CLK 80 +#define GPOUT_SYS_SPI2_FSS 81 +#define GPOUT_SYS_SPI2_TXD 82 +#define GPOUT_SYS_I2C3_CLK 83 +#define GPOUT_SYS_I2C3_DATA 84 +#define GPOUT_SYS_UART3_TX 85 +#define GPOUT_SYS_SPI3_CLK 86 +#define GPOUT_SYS_SPI3_FSS 87 +#define GPOUT_SYS_SPI3_TXD 88 +#define GPOUT_SYS_I2C4_CLK 89 +#define GPOUT_SYS_I2C4_DATA 90 +#define GPOUT_SYS_UART4_RTS 91 +#define GPOUT_SYS_UART4_TX 92 +#define GPOUT_SYS_SPI4_CLK 93 +#define GPOUT_SYS_SPI4_FSS 94 +#define GPOUT_SYS_SPI4_TXD 95 +#define GPOUT_SYS_I2C5_CLK 96 +#define GPOUT_SYS_I2C5_DATA 97 +#define GPOUT_SYS_UART5_RTS 98 +#define GPOUT_SYS_UART5_TX 99 +#define GPOUT_SYS_SPI5_CLK 100 +#define GPOUT_SYS_SPI5_FSS 101 +#define GPOUT_SYS_SPI5_TXD 102 +#define GPOUT_SYS_I2C6_CLK 103 +#define GPOUT_SYS_I2C6_DATA 104 +#define GPOUT_SYS_SPI6_CLK 105 +#define GPOUT_SYS_SPI6_FSS 106 +#define GPOUT_SYS_SPI6_TXD 107 + +/* aon_iomux dout */ +#define GPOUT_AON_CLK_32K_OUT 2 +#define GPOUT_AON_PTC0_PWM4 3 +#define GPOUT_AON_PTC0_PWM5 4 +#define GPOUT_AON_PTC0_PWM6 5 +#define GPOUT_AON_PTC0_PWM7 6 +#define GPOUT_AON_CLK_GCLK0 7 +#define GPOUT_AON_CLK_GCLK1 8 +#define GPOUT_AON_CLK_GCLK2 9 + +/* sys_iomux doen */ +#define GPOEN_ENABLE 0 +#define GPOEN_DISABLE 1 +#define GPOEN_SYS_HDMI_CEC_SDA 2 +#define GPOEN_SYS_HDMI_DDC_SCL 3 +#define GPOEN_SYS_HDMI_DDC_SDA 4 +#define GPOEN_SYS_I2C0_CLK 5 +#define GPOEN_SYS_I2C0_DATA 6 +#define GPOEN_SYS_HIFI4_JTAG_TDO 7 +#define GPOEN_SYS_JTAG_TDO 8 +#define GPOEN_SYS_PWM0_CHANNEL0 9 +#define GPOEN_SYS_PWM0_CHANNEL1 10 +#define GPOEN_SYS_PWM0_CHANNEL2 11 +#define GPOEN_SYS_PWM0_CHANNEL3 12 +#define GPOEN_SYS_SPI0_NSSPCTL 13 +#define GPOEN_SYS_SPI0_NSSP 14 +#define GPOEN_SYS_TDM_SYNC 15 +#define GPOEN_SYS_TDM_TXD 16 +#define GPOEN_SYS_I2C1_CLK 17 +#define GPOEN_SYS_I2C1_DATA 18 +#define GPOEN_SYS_SDIO1_CMD 19 +#define GPOEN_SYS_SDIO1_DATA0 20 +#define GPOEN_SYS_SDIO1_DATA1 21 +#define GPOEN_SYS_SDIO1_DATA2 22 +#define GPOEN_SYS_SDIO1_DATA3 23 +#define GPOEN_SYS_SDIO1_DATA4 24 +#define GPOEN_SYS_SDIO1_DATA5 25 +#define GPOEN_SYS_SDIO1_DATA6 26 +#define GPOEN_SYS_SDIO1_DATA7 27 +#define GPOEN_SYS_SPI1_NSSPCTL 28 +#define GPOEN_SYS_SPI1_NSSP 29 +#define GPOEN_SYS_I2C2_CLK 30 +#define GPOEN_SYS_I2C2_DATA 31 +#define GPOEN_SYS_SPI2_NSSPCTL 32 +#define GPOEN_SYS_SPI2_NSSP 33 +#define GPOEN_SYS_I2C3_CLK 34 +#define GPOEN_SYS_I2C3_DATA 35 +#define GPOEN_SYS_SPI3_NSSPCTL 36 +#define GPOEN_SYS_SPI3_NSSP 37 +#define GPOEN_SYS_I2C4_CLK 38 +#define GPOEN_SYS_I2C4_DATA 39 +#define GPOEN_SYS_SPI4_NSSPCTL 40 +#define GPOEN_SYS_SPI4_NSSP 41 +#define GPOEN_SYS_I2C5_CLK 42 +#define GPOEN_SYS_I2C5_DATA 43 +#define GPOEN_SYS_SPI5_NSSPCTL 44 +#define GPOEN_SYS_SPI5_NSSP 45 +#define GPOEN_SYS_I2C6_CLK 46 +#define GPOEN_SYS_I2C6_DATA 47 +#define GPOEN_SYS_SPI6_NSSPCTL 48 +#define GPOEN_SYS_SPI6_NSSP 49 + +/* aon_iomux doen */ +#define GPOEN_AON_PTC0_OE_N_4 2 +#define GPOEN_AON_PTC0_OE_N_5 3 +#define GPOEN_AON_PTC0_OE_N_6 4 +#define GPOEN_AON_PTC0_OE_N_7 5 + +/* sys_iomux gin */ +#define GPI_NONE 255 + +#define GPI_SYS_WAVE511_UART_RX 0 +#define GPI_SYS_CAN0_RXD 1 +#define GPI_SYS_USB_OVERCURRENT 2 +#define GPI_SYS_SPDIF 3 +#define GPI_SYS_JTAG_RST 4 +#define GPI_SYS_HDMI_CEC_SDA 5 +#define GPI_SYS_HDMI_DDC_SCL 6 +#define GPI_SYS_HDMI_DDC_SDA 7 +#define GPI_SYS_HDMI_HPD 8 +#define GPI_SYS_I2C0_CLK 9 +#define GPI_SYS_I2C0_DATA 10 +#define GPI_SYS_SDIO0_CD 11 +#define GPI_SYS_SDIO0_INT 12 +#define GPI_SYS_SDIO0_WP 13 +#define GPI_SYS_UART0_RX 14 +#define GPI_SYS_HIFI4_JTAG_TCK 15 +#define GPI_SYS_HIFI4_JTAG_TDI 16 +#define GPI_SYS_HIFI4_JTAG_TMS 17 +#define GPI_SYS_HIFI4_JTAG_RST 18 +#define GPI_SYS_JTAG_TDI 19 +#define GPI_SYS_JTAG_TMS 20 +#define GPI_SYS_PDM_DMIC0 21 +#define GPI_SYS_PDM_DMIC1 22 +#define GPI_SYS_I2SRX_SDIN0 23 +#define GPI_SYS_I2SRX_SDIN1 24 +#define GPI_SYS_I2SRX_SDIN2 25 +#define GPI_SYS_SPI0_CLK 26 +#define GPI_SYS_SPI0_FSS 27 +#define GPI_SYS_SPI0_RXD 28 +#define GPI_SYS_JTAG_TCK 29 +#define GPI_SYS_MCLK_EXT 30 +#define GPI_SYS_I2SRX_BCLK 31 +#define GPI_SYS_I2SRX_LRCK 32 +#define GPI_SYS_I2STX0_BCLK 33 +#define GPI_SYS_I2STX0_LRCK 34 +#define GPI_SYS_TDM_CLK 35 +#define GPI_SYS_TDM_RXD 36 +#define GPI_SYS_TDM_SYNC 37 +#define GPI_SYS_CAN1_RXD 38 +#define GPI_SYS_I2C1_CLK 39 +#define GPI_SYS_I2C1_DATA 40 +#define GPI_SYS_SDIO1_CD 41 +#define GPI_SYS_SDIO1_INT 42 +#define GPI_SYS_SDIO1_WP 43 +#define GPI_SYS_SDIO1_CMD 44 +#define GPI_SYS_SDIO1_DATA0 45 +#define GPI_SYS_SDIO1_DATA1 46 +#define GPI_SYS_SDIO1_DATA2 47 +#define GPI_SYS_SDIO1_DATA3 48 +#define GPI_SYS_SDIO1_DATA4 49 +#define GPI_SYS_SDIO1_DATA5 50 +#define GPI_SYS_SDIO1_DATA6 51 +#define GPI_SYS_SDIO1_DATA7 52 +#define GPI_SYS_SDIO1_STRB 53 +#define GPI_SYS_UART1_CTS 54 +#define GPI_SYS_UART1_RX 55 +#define GPI_SYS_SPI1_CLK 56 +#define GPI_SYS_SPI1_FSS 57 +#define GPI_SYS_SPI1_RXD 58 +#define GPI_SYS_I2C2_CLK 59 +#define GPI_SYS_I2C2_DATA 60 +#define GPI_SYS_UART2_CTS 61 +#define GPI_SYS_UART2_RX 62 +#define GPI_SYS_SPI2_CLK 63 +#define GPI_SYS_SPI2_FSS 64 +#define GPI_SYS_SPI2_RXD 65 +#define GPI_SYS_I2C3_CLK 66 +#define GPI_SYS_I2C3_DATA 67 +#define GPI_SYS_UART3_RX 68 +#define GPI_SYS_SPI3_CLK 69 +#define GPI_SYS_SPI3_FSS 70 +#define GPI_SYS_SPI3_RXD 71 +#define GPI_SYS_I2C4_CLK 72 +#define GPI_SYS_I2C4_DATA 73 +#define GPI_SYS_UART4_CTS 74 +#define GPI_SYS_UART4_RX 75 +#define GPI_SYS_SPI4_CLK 76 +#define GPI_SYS_SPI4_FSS 77 +#define GPI_SYS_SPI4_RXD 78 +#define GPI_SYS_I2C5_CLK 79 +#define GPI_SYS_I2C5_DATA 80 +#define GPI_SYS_UART5_CTS 81 +#define GPI_SYS_UART5_RX 82 +#define GPI_SYS_SPI5_CLK 83 +#define GPI_SYS_SPI5_FSS 84 +#define GPI_SYS_SPI5_RXD 85 +#define GPI_SYS_I2C6_CLK 86 +#define GPI_SYS_I2C6_DATA 87 +#define GPI_SYS_SPI6_CLK 88 +#define GPI_SYS_SPI6_FSS 89 +#define GPI_SYS_SPI6_RXD 90 + +/* aon_iomux gin */ +#define GPI_AON_PMU_GPIO_WAKEUP_0 0 +#define GPI_AON_PMU_GPIO_WAKEUP_1 1 +#define GPI_AON_PMU_GPIO_WAKEUP_2 2 +#define GPI_AON_PMU_GPIO_WAKEUP_3 3 + +#endif
From: Kuan Lim Lee kuanlim.lee@linux.starfivetech.com
Add pinctrl driver for StarFive JH7110 SoC.
Signed-off-by: Kuan Lim Lee kuanlim.lee@linux.starfivetech.com Signed-off-by: Emil Renner Berthing kernel@esmil.dk Signed-off-by: Jianlong Huang jianlong.huang@starfivetech.com Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/starfive/Kconfig | 28 ++ drivers/pinctrl/starfive/Makefile | 6 + drivers/pinctrl/starfive/pinctrl-jh7110-aon.c | 113 +++++ drivers/pinctrl/starfive/pinctrl-jh7110-sys.c | 399 ++++++++++++++++++ drivers/pinctrl/starfive/pinctrl-starfive.c | 382 +++++++++++++++++ drivers/pinctrl/starfive/pinctrl-starfive.h | 55 +++ 8 files changed, 985 insertions(+) create mode 100644 drivers/pinctrl/starfive/Kconfig create mode 100644 drivers/pinctrl/starfive/Makefile create mode 100644 drivers/pinctrl/starfive/pinctrl-jh7110-aon.c create mode 100644 drivers/pinctrl/starfive/pinctrl-jh7110-sys.c create mode 100644 drivers/pinctrl/starfive/pinctrl-starfive.c create mode 100644 drivers/pinctrl/starfive/pinctrl-starfive.h
diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index b6ef2acced..75b3ff47a2 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -359,5 +359,6 @@ source "drivers/pinctrl/renesas/Kconfig" source "drivers/pinctrl/rockchip/Kconfig" source "drivers/pinctrl/sunxi/Kconfig" source "drivers/pinctrl/uniphier/Kconfig" +source "drivers/pinctrl/starfive/Kconfig"
endmenu diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index 3b167d099f..852adee4b4 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -32,3 +32,4 @@ obj-$(CONFIG_PINCTRL_STM32) += pinctrl_stm32.o obj-$(CONFIG_$(SPL_)PINCTRL_STMFX) += pinctrl-stmfx.o obj-y += broadcom/ obj-$(CONFIG_PINCTRL_ZYNQMP) += pinctrl-zynqmp.o +obj-$(CONFIG_PINCTRL_STARFIVE) += starfive/ diff --git a/drivers/pinctrl/starfive/Kconfig b/drivers/pinctrl/starfive/Kconfig new file mode 100644 index 0000000000..1b859c863e --- /dev/null +++ b/drivers/pinctrl/starfive/Kconfig @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0-only + +config SPL_PINCTRL_STARFIVE + bool "Support Pinctrl driver for StarFive SoC in SPL" + depends on SPL_PINCTRL_FULL && STARFIVE_JH7110 + help + Enable support pin control driver for StarFive SoC. + +config SPL_PINCTRL_STARFIVE_JH7110 + bool "Support Pinctrl and GPIO driver for StarFive JH7110 SoC in SPL" + depends on SPL_PINCTRL_STARFIVE + help + Enable support pinctrl and gpio driver for StarFive JH7110 in SPL. + +config PINCTRL_STARFIVE + bool "Pinctrl driver for StarFive SoC" + depends on PINCTRL_FULL && STARFIVE_JH7110 + help + Say yes here to support pin control on the StarFive RISC-V SoC. + This also provides an interface to the GPIO pins not used by other + peripherals supporting inputs, outputs, configuring pull-up/pull-down + and interrupts on input changes. + +config PINCTRL_STARFIVE_JH7110 + bool "Pinctrl and GPIO driver for StarFive JH7110 SoC" + depends on PINCTRL_STARFIVE + help + This selects the pinctrl driver for JH7110 starfive. diff --git a/drivers/pinctrl/starfive/Makefile b/drivers/pinctrl/starfive/Makefile new file mode 100644 index 0000000000..a4a12069b3 --- /dev/null +++ b/drivers/pinctrl/starfive/Makefile @@ -0,0 +1,6 @@ + +# SPDX-License-Identifier: GPL-2.0 +# Core +obj-$(CONFIG_$(SPL_TPL_)PINCTRL_STARFIVE) += pinctrl-starfive.o +# SoC Drivers +obj-$(CONFIG_$(SPL_TPL_)PINCTRL_STARFIVE_JH7110) += pinctrl-jh7110-sys.o pinctrl-jh7110-aon.o diff --git a/drivers/pinctrl/starfive/pinctrl-jh7110-aon.c b/drivers/pinctrl/starfive/pinctrl-jh7110-aon.c new file mode 100644 index 0000000000..2d739906e2 --- /dev/null +++ b/drivers/pinctrl/starfive/pinctrl-jh7110-aon.c @@ -0,0 +1,113 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Pinctrl / GPIO driver for StarFive JH7110 SoC + * + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Lee Kuan Lim kuanlim.lee@starfivetech.com + * Author: Jianlong Huang jianlong.huang@starfivetech.com + */ + +#include <dm/read.h> +#include <dm/device_compat.h> +#include <linux/io.h> + +#include <dt-bindings/pinctrl/pinctrl-starfive-jh7110.h> +#include "pinctrl-starfive.h" + +#define JH7110_AON_NGPIO 4 +#define JH7110_AON_GC_BASE 64 + +/* registers */ +#define JH7110_AON_DOEN 0x0 +#define JH7110_AON_DOUT 0x4 +#define JH7110_AON_GPI 0x8 +#define JH7110_AON_GPIOIN 0x2c + +#define JH7110_AON_GPIOEN 0xc +#define JH7110_AON_GPIOIS 0x10 +#define JH7110_AON_GPIOIC 0x14 +#define JH7110_AON_GPIOIBE 0x18 +#define JH7110_AON_GPIOIEV 0x1c +#define JH7110_AON_GPIOIE 0x20 +#define JH7110_AON_GPIORIS 0x28 +#define JH7110_AON_GPIOMIS 0x28 + +#define AON_GPO_PDA_0_5_CFG 0x30 + +static int jh7110_aon_set_one_pin_mux(struct udevice *dev, unsigned int pin, + unsigned int din, u32 dout, + u32 doen, u32 func) +{ + struct starfive_pinctrl_priv *priv = dev_get_priv(dev); + + if (pin < priv->info->ngpios && func == 0) + starfive_set_gpiomux(dev, pin, din, dout, doen); + + return 0; +} + +static int jh7110_aon_get_padcfg_base(struct udevice *dev, + unsigned int pin) +{ + if (pin < PAD_GMAC0_MDC) + return AON_GPO_PDA_0_5_CFG; + + return -1; +} + +static void jh7110_aon_init_hw(struct udevice *dev) +{ + struct starfive_pinctrl_priv *priv = dev_get_priv(dev); + + /* mask all GPIO interrupts */ + writel(0, priv->base + JH7110_AON_GPIOIE); + /* clear edge interrupt flags */ + writel(0, priv->base + JH7110_AON_GPIOIC); + writel(0x0f, priv->base + JH7110_AON_GPIOIC); + /* enable GPIO interrupts */ + writel(1, priv->base + JH7110_AON_GPIOEN); +} + +const struct starfive_pinctrl_soc_info jh7110_aon_pinctrl_info = { + /* pin conf */ + .set_one_pinmux = jh7110_aon_set_one_pin_mux, + .get_padcfg_base = jh7110_aon_get_padcfg_base, + + /* gpio dout/doen/din/gpioinput register */ + .dout_reg_base = JH7110_AON_DOUT, + .dout_mask = GENMASK(3, 0), + .doen_reg_base = JH7110_AON_DOEN, + .doen_mask = GENMASK(2, 0), + .gpi_reg_base = JH7110_AON_GPI, + .gpi_mask = GENMASK(3, 0), + .gpioin_reg_base = JH7110_AON_GPIOIN, + + /* gpio */ + .gpio_bank_name = "RGPIO", + .ngpios = JH7110_AON_NGPIO, + .gpio_init_hw = jh7110_aon_init_hw, +}; + +static int jh7110_aon_pinctrl_probe(struct udevice *dev) +{ + struct starfive_pinctrl_soc_info *info = + (struct starfive_pinctrl_soc_info *)dev_get_driver_data(dev); + + return starfive_pinctrl_probe(dev, info); +} + +static const struct udevice_id jh7110_aon_pinctrl_ids[] = { + /* JH7110 aon pinctrl */ + { .compatible = "starfive,jh7110-aon-pinctrl", + .data = (ulong)&jh7110_aon_pinctrl_info, }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(jh7110_aon_pinctrl) = { + .name = "jh7110-aon-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = jh7110_aon_pinctrl_ids, + .priv_auto = sizeof(struct starfive_pinctrl_priv), + .ops = &starfive_pinctrl_ops, + .probe = jh7110_aon_pinctrl_probe, +}; diff --git a/drivers/pinctrl/starfive/pinctrl-jh7110-sys.c b/drivers/pinctrl/starfive/pinctrl-jh7110-sys.c new file mode 100644 index 0000000000..dafba65eae --- /dev/null +++ b/drivers/pinctrl/starfive/pinctrl-jh7110-sys.c @@ -0,0 +1,399 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Pinctrl / GPIO driver for StarFive JH7110 SoC + * + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Lee Kuan Lim kuanlim.lee@starfivetech.com + * Author: Jianlong Huang jianlong.huang@starfivetech.com + */ + +#include <dm/read.h> +#include <dm/device_compat.h> +#include <linux/io.h> + +#include <dt-bindings/pinctrl/pinctrl-starfive-jh7110.h> +#include "pinctrl-starfive.h" + +#define JH7110_SYS_NGPIO 64 +#define JH7110_SYS_GC_BASE 0 + +/* registers */ +#define JH7110_SYS_DOEN 0x000 +#define JH7110_SYS_DOUT 0x040 +#define JH7110_SYS_GPI 0x080 +#define JH7110_SYS_GPIOIN 0x118 + +#define JH7110_SYS_GPIOEN 0x0dc +#define JH7110_SYS_GPIOIS0 0x0e0 +#define JH7110_SYS_GPIOIS1 0x0e4 +#define JH7110_SYS_GPIOIC0 0x0e8 +#define JH7110_SYS_GPIOIC1 0x0ec +#define JH7110_SYS_GPIOIBE0 0x0f0 +#define JH7110_SYS_GPIOIBE1 0x0f4 +#define JH7110_SYS_GPIOIEV0 0x0f8 +#define JH7110_SYS_GPIOIEV1 0x0fc +#define JH7110_SYS_GPIOIE0 0x100 +#define JH7110_SYS_GPIOIE1 0x104 +#define JH7110_SYS_GPIORIS0 0x108 +#define JH7110_SYS_GPIORIS1 0x10c +#define JH7110_SYS_GPIOMIS0 0x110 +#define JH7110_SYS_GPIOMIS1 0x114 + +#define SYS_GPO_PDA_0_74_CFG 0x120 +#define SYS_GPO_PDA_89_94_CFG 0x284 + +static const struct starfive_pinctrl_pin jh7110_sys_pins[] = { + STARFIVE_PINCTRL(PAD_GPIO0, "GPIO0"), + STARFIVE_PINCTRL(PAD_GPIO1, "GPIO1"), + STARFIVE_PINCTRL(PAD_GPIO2, "GPIO2"), + STARFIVE_PINCTRL(PAD_GPIO3, "GPIO3"), + STARFIVE_PINCTRL(PAD_GPIO4, "GPIO4"), + STARFIVE_PINCTRL(PAD_GPIO5, "GPIO5"), + STARFIVE_PINCTRL(PAD_GPIO6, "GPIO6"), + STARFIVE_PINCTRL(PAD_GPIO7, "GPIO7"), + STARFIVE_PINCTRL(PAD_GPIO8, "GPIO8"), + STARFIVE_PINCTRL(PAD_GPIO9, "GPIO9"), + STARFIVE_PINCTRL(PAD_GPIO10, "GPIO10"), + STARFIVE_PINCTRL(PAD_GPIO11, "GPIO11"), + STARFIVE_PINCTRL(PAD_GPIO12, "GPIO12"), + STARFIVE_PINCTRL(PAD_GPIO13, "GPIO13"), + STARFIVE_PINCTRL(PAD_GPIO14, "GPIO14"), + STARFIVE_PINCTRL(PAD_GPIO15, "GPIO15"), + STARFIVE_PINCTRL(PAD_GPIO16, "GPIO16"), + STARFIVE_PINCTRL(PAD_GPIO17, "GPIO17"), + STARFIVE_PINCTRL(PAD_GPIO18, "GPIO18"), + STARFIVE_PINCTRL(PAD_GPIO19, "GPIO19"), + STARFIVE_PINCTRL(PAD_GPIO20, "GPIO20"), + STARFIVE_PINCTRL(PAD_GPIO21, "GPIO21"), + STARFIVE_PINCTRL(PAD_GPIO22, "GPIO22"), + STARFIVE_PINCTRL(PAD_GPIO23, "GPIO23"), + STARFIVE_PINCTRL(PAD_GPIO24, "GPIO24"), + STARFIVE_PINCTRL(PAD_GPIO25, "GPIO25"), + STARFIVE_PINCTRL(PAD_GPIO26, "GPIO26"), + STARFIVE_PINCTRL(PAD_GPIO27, "GPIO27"), + STARFIVE_PINCTRL(PAD_GPIO28, "GPIO28"), + STARFIVE_PINCTRL(PAD_GPIO29, "GPIO29"), + STARFIVE_PINCTRL(PAD_GPIO30, "GPIO30"), + STARFIVE_PINCTRL(PAD_GPIO31, "GPIO31"), + STARFIVE_PINCTRL(PAD_GPIO32, "GPIO32"), + STARFIVE_PINCTRL(PAD_GPIO33, "GPIO33"), + STARFIVE_PINCTRL(PAD_GPIO34, "GPIO34"), + STARFIVE_PINCTRL(PAD_GPIO35, "GPIO35"), + STARFIVE_PINCTRL(PAD_GPIO36, "GPIO36"), + STARFIVE_PINCTRL(PAD_GPIO37, "GPIO37"), + STARFIVE_PINCTRL(PAD_GPIO38, "GPIO38"), + STARFIVE_PINCTRL(PAD_GPIO39, "GPIO39"), + STARFIVE_PINCTRL(PAD_GPIO40, "GPIO40"), + STARFIVE_PINCTRL(PAD_GPIO41, "GPIO41"), + STARFIVE_PINCTRL(PAD_GPIO42, "GPIO42"), + STARFIVE_PINCTRL(PAD_GPIO43, "GPIO43"), + STARFIVE_PINCTRL(PAD_GPIO44, "GPIO44"), + STARFIVE_PINCTRL(PAD_GPIO45, "GPIO45"), + STARFIVE_PINCTRL(PAD_GPIO46, "GPIO46"), + STARFIVE_PINCTRL(PAD_GPIO47, "GPIO47"), + STARFIVE_PINCTRL(PAD_GPIO48, "GPIO48"), + STARFIVE_PINCTRL(PAD_GPIO49, "GPIO49"), + STARFIVE_PINCTRL(PAD_GPIO50, "GPIO50"), + STARFIVE_PINCTRL(PAD_GPIO51, "GPIO51"), + STARFIVE_PINCTRL(PAD_GPIO52, "GPIO52"), + STARFIVE_PINCTRL(PAD_GPIO53, "GPIO53"), + STARFIVE_PINCTRL(PAD_GPIO54, "GPIO54"), + STARFIVE_PINCTRL(PAD_GPIO55, "GPIO55"), + STARFIVE_PINCTRL(PAD_GPIO56, "GPIO56"), + STARFIVE_PINCTRL(PAD_GPIO57, "GPIO57"), + STARFIVE_PINCTRL(PAD_GPIO58, "GPIO58"), + STARFIVE_PINCTRL(PAD_GPIO59, "GPIO59"), + STARFIVE_PINCTRL(PAD_GPIO60, "GPIO60"), + STARFIVE_PINCTRL(PAD_GPIO61, "GPIO61"), + STARFIVE_PINCTRL(PAD_GPIO62, "GPIO62"), + STARFIVE_PINCTRL(PAD_GPIO63, "GPIO63"), + STARFIVE_PINCTRL(PAD_SD0_CLK, "SD0_CLK"), + STARFIVE_PINCTRL(PAD_SD0_CMD, "SD0_CMD"), + STARFIVE_PINCTRL(PAD_SD0_DATA0, "SD0_DATA0"), + STARFIVE_PINCTRL(PAD_SD0_DATA1, "SD0_DATA1"), + STARFIVE_PINCTRL(PAD_SD0_DATA2, "SD0_DATA2"), + STARFIVE_PINCTRL(PAD_SD0_DATA3, "SD0_DATA3"), + STARFIVE_PINCTRL(PAD_SD0_DATA4, "SD0_DATA4"), + STARFIVE_PINCTRL(PAD_SD0_DATA5, "SD0_DATA5"), + STARFIVE_PINCTRL(PAD_SD0_DATA6, "SD0_DATA6"), + STARFIVE_PINCTRL(PAD_SD0_DATA7, "SD0_DATA7"), + STARFIVE_PINCTRL(PAD_SD0_STRB, "SD0_STRB"), + STARFIVE_PINCTRL(PAD_GMAC1_MDC, "GMAC1_MDC"), + STARFIVE_PINCTRL(PAD_GMAC1_MDIO, "GMAC1_MDIO"), + STARFIVE_PINCTRL(PAD_GMAC1_RXD0, "GMAC1_RXD0"), + STARFIVE_PINCTRL(PAD_GMAC1_RXD1, "GMAC1_RXD1"), + STARFIVE_PINCTRL(PAD_GMAC1_RXD2, "GMAC1_RXD2"), + STARFIVE_PINCTRL(PAD_GMAC1_RXD3, "GMAC1_RXD3"), + STARFIVE_PINCTRL(PAD_GMAC1_RXDV, "GMAC1_RXDV"), + STARFIVE_PINCTRL(PAD_GMAC1_RXC, "GMAC1_RXC"), + STARFIVE_PINCTRL(PAD_GMAC1_TXD0, "GMAC1_TXD0"), + STARFIVE_PINCTRL(PAD_GMAC1_TXD1, "GMAC1_TXD1"), + STARFIVE_PINCTRL(PAD_GMAC1_TXD2, "GMAC1_TXD2"), + STARFIVE_PINCTRL(PAD_GMAC1_TXD3, "GMAC1_TXD3"), + STARFIVE_PINCTRL(PAD_GMAC1_TXEN, "GMAC1_TXEN"), + STARFIVE_PINCTRL(PAD_GMAC1_TXC, "GMAC1_TXC"), + STARFIVE_PINCTRL(PAD_QSPI_SCLK, "QSPI_SCLK"), + STARFIVE_PINCTRL(PAD_QSPI_CS0, "QSPI_CS0"), + STARFIVE_PINCTRL(PAD_QSPI_DATA0, "QSPI_DATA0"), + STARFIVE_PINCTRL(PAD_QSPI_DATA1, "QSPI_DATA1"), + STARFIVE_PINCTRL(PAD_QSPI_DATA2, "QSPI_DATA2"), + STARFIVE_PINCTRL(PAD_QSPI_DATA3, "QSPI_DATA3"), +}; + +struct jh7110_func_sel { + u16 offset; + u8 shift; + u8 max; +}; + +static const struct jh7110_func_sel + jh7110_sys_func_sel[ARRAY_SIZE(jh7110_sys_pins)] = { + [PAD_GMAC1_RXC] = { 0x29c, 0, 1 }, + [PAD_GPIO10] = { 0x29c, 2, 3 }, + [PAD_GPIO11] = { 0x29c, 5, 3 }, + [PAD_GPIO12] = { 0x29c, 8, 3 }, + [PAD_GPIO13] = { 0x29c, 11, 3 }, + [PAD_GPIO14] = { 0x29c, 14, 3 }, + [PAD_GPIO15] = { 0x29c, 17, 3 }, + [PAD_GPIO16] = { 0x29c, 20, 3 }, + [PAD_GPIO17] = { 0x29c, 23, 3 }, + [PAD_GPIO18] = { 0x29c, 26, 3 }, + [PAD_GPIO19] = { 0x29c, 29, 3 }, + + [PAD_GPIO20] = { 0x2a0, 0, 3 }, + [PAD_GPIO21] = { 0x2a0, 3, 3 }, + [PAD_GPIO22] = { 0x2a0, 6, 3 }, + [PAD_GPIO23] = { 0x2a0, 9, 3 }, + [PAD_GPIO24] = { 0x2a0, 12, 3 }, + [PAD_GPIO25] = { 0x2a0, 15, 3 }, + [PAD_GPIO26] = { 0x2a0, 18, 3 }, + [PAD_GPIO27] = { 0x2a0, 21, 3 }, + [PAD_GPIO28] = { 0x2a0, 24, 3 }, + [PAD_GPIO29] = { 0x2a0, 27, 3 }, + + [PAD_GPIO30] = { 0x2a4, 0, 3 }, + [PAD_GPIO31] = { 0x2a4, 3, 3 }, + [PAD_GPIO32] = { 0x2a4, 6, 3 }, + [PAD_GPIO33] = { 0x2a4, 9, 3 }, + [PAD_GPIO34] = { 0x2a4, 12, 3 }, + [PAD_GPIO35] = { 0x2a4, 15, 3 }, + [PAD_GPIO36] = { 0x2a4, 17, 3 }, + [PAD_GPIO37] = { 0x2a4, 20, 3 }, + [PAD_GPIO38] = { 0x2a4, 23, 3 }, + [PAD_GPIO39] = { 0x2a4, 26, 3 }, + [PAD_GPIO40] = { 0x2a4, 29, 3 }, + + [PAD_GPIO41] = { 0x2a8, 0, 3 }, + [PAD_GPIO42] = { 0x2a8, 3, 3 }, + [PAD_GPIO43] = { 0x2a8, 6, 3 }, + [PAD_GPIO44] = { 0x2a8, 9, 3 }, + [PAD_GPIO45] = { 0x2a8, 12, 3 }, + [PAD_GPIO46] = { 0x2a8, 15, 3 }, + [PAD_GPIO47] = { 0x2a8, 18, 3 }, + [PAD_GPIO48] = { 0x2a8, 21, 3 }, + [PAD_GPIO49] = { 0x2a8, 24, 3 }, + [PAD_GPIO50] = { 0x2a8, 27, 3 }, + [PAD_GPIO51] = { 0x2a8, 30, 3 }, + + [PAD_GPIO52] = { 0x2ac, 0, 3 }, + [PAD_GPIO53] = { 0x2ac, 2, 3 }, + [PAD_GPIO54] = { 0x2ac, 4, 3 }, + [PAD_GPIO55] = { 0x2ac, 6, 3 }, + [PAD_GPIO56] = { 0x2ac, 9, 3 }, + [PAD_GPIO57] = { 0x2ac, 12, 3 }, + [PAD_GPIO58] = { 0x2ac, 15, 3 }, + [PAD_GPIO59] = { 0x2ac, 18, 3 }, + [PAD_GPIO60] = { 0x2ac, 21, 3 }, + [PAD_GPIO61] = { 0x2ac, 24, 3 }, + [PAD_GPIO62] = { 0x2ac, 27, 3 }, + [PAD_GPIO63] = { 0x2ac, 30, 3 }, + + [PAD_GPIO6] = { 0x2b0, 0, 3 }, + [PAD_GPIO7] = { 0x2b0, 2, 3 }, + [PAD_GPIO8] = { 0x2b0, 5, 3 }, + [PAD_GPIO9] = { 0x2b0, 8, 3 }, +}; + +struct jh7110_vin_group_sel { + u16 offset; + u8 shift; + u8 group; +}; + +static const struct jh7110_vin_group_sel + jh7110_sys_vin_group_sel[ARRAY_SIZE(jh7110_sys_pins)] = { + [PAD_GPIO6] = { 0x2b4, 21, 0 }, + [PAD_GPIO7] = { 0x2b4, 18, 0 }, + [PAD_GPIO8] = { 0x2b4, 15, 0 }, + [PAD_GPIO9] = { 0x2b0, 11, 0 }, + [PAD_GPIO10] = { 0x2b0, 20, 0 }, + [PAD_GPIO11] = { 0x2b0, 23, 0 }, + [PAD_GPIO12] = { 0x2b0, 26, 0 }, + [PAD_GPIO13] = { 0x2b0, 29, 0 }, + [PAD_GPIO14] = { 0x2b4, 0, 0 }, + [PAD_GPIO15] = { 0x2b4, 3, 0 }, + [PAD_GPIO16] = { 0x2b4, 6, 0 }, + [PAD_GPIO17] = { 0x2b4, 9, 0 }, + [PAD_GPIO18] = { 0x2b4, 12, 0 }, + [PAD_GPIO19] = { 0x2b0, 14, 0 }, + [PAD_GPIO20] = { 0x2b0, 17, 0 }, + + [PAD_GPIO21] = { 0x2b4, 21, 1 }, + [PAD_GPIO22] = { 0x2b4, 18, 1 }, + [PAD_GPIO23] = { 0x2b4, 15, 1 }, + [PAD_GPIO24] = { 0x2b0, 11, 1 }, + [PAD_GPIO25] = { 0x2b0, 20, 1 }, + [PAD_GPIO26] = { 0x2b0, 23, 1 }, + [PAD_GPIO27] = { 0x2b0, 26, 1 }, + [PAD_GPIO28] = { 0x2b0, 29, 1 }, + [PAD_GPIO29] = { 0x2b4, 0, 1 }, + [PAD_GPIO30] = { 0x2b4, 3, 1 }, + [PAD_GPIO31] = { 0x2b4, 6, 1 }, + [PAD_GPIO32] = { 0x2b4, 9, 1 }, + [PAD_GPIO33] = { 0x2b4, 12, 1 }, + [PAD_GPIO34] = { 0x2b0, 14, 1 }, + [PAD_GPIO35] = { 0x2b0, 17, 1 }, + + [PAD_GPIO36] = { 0x2b4, 21, 2 }, + [PAD_GPIO37] = { 0x2b4, 18, 2 }, + [PAD_GPIO38] = { 0x2b4, 15, 2 }, + [PAD_GPIO39] = { 0x2b0, 11, 2 }, + [PAD_GPIO40] = { 0x2b0, 20, 2 }, + [PAD_GPIO41] = { 0x2b0, 23, 2 }, + [PAD_GPIO42] = { 0x2b0, 26, 2 }, + [PAD_GPIO43] = { 0x2b0, 29, 2 }, + [PAD_GPIO44] = { 0x2b4, 0, 2 }, + [PAD_GPIO45] = { 0x2b4, 3, 2 }, + [PAD_GPIO46] = { 0x2b4, 6, 2 }, + [PAD_GPIO47] = { 0x2b4, 9, 2 }, + [PAD_GPIO48] = { 0x2b4, 12, 2 }, + [PAD_GPIO49] = { 0x2b0, 14, 2 }, + [PAD_GPIO50] = { 0x2b0, 17, 2 }, +}; + +static void jh7110_set_function(struct udevice *dev, + unsigned int pin, u32 func) +{ + const struct jh7110_func_sel *fs = &jh7110_sys_func_sel[pin]; + struct starfive_pinctrl_priv *priv = dev_get_priv(dev); + void __iomem *reg; + u32 mask; + + if (!fs->offset) + return; + + if (func > fs->max) + return; + + reg = priv->base + fs->offset; + func = func << fs->shift; + mask = 0x3U << fs->shift; + + func |= readl(reg) & ~mask; + writel(func, reg); +} + +static void jh7110_set_vin_group(struct udevice *dev, unsigned int pin) +{ + const struct jh7110_vin_group_sel *gs = + &jh7110_sys_vin_group_sel[pin]; + struct starfive_pinctrl_priv *priv = dev_get_priv(dev); + void __iomem *reg; + u32 mask; + u32 grp; + + if (!gs->offset) + return; + + reg = priv->base + gs->offset; + grp = gs->group << gs->shift; + mask = 0x3U << gs->shift; + + grp |= readl(reg) & ~mask; + writel(grp, reg); +} + +static int jh7110_sys_set_one_pin_mux(struct udevice *dev, unsigned int pin, + unsigned int din, u32 dout, u32 doen, u32 func) +{ + struct starfive_pinctrl_priv *priv = dev_get_priv(dev); + + if (pin < priv->info->ngpios && func == 0) + starfive_set_gpiomux(dev, pin, din, dout, doen); + + jh7110_set_function(dev, pin, func); + + if (pin < priv->info->ngpios && func == 2) + jh7110_set_vin_group(dev, pin); + + return 0; +} + +static int jh7110_sys_get_padcfg_base(struct udevice *dev, + unsigned int pin) +{ + if (pin < PAD_GMAC1_MDC) + return SYS_GPO_PDA_0_74_CFG; + else if (pin > PAD_GMAC1_TXC && pin <= PAD_QSPI_DATA3) + return SYS_GPO_PDA_89_94_CFG; + else + return -1; +} + +static void jh7110_sys_init_hw(struct udevice *dev) +{ + struct starfive_pinctrl_priv *priv = dev_get_priv(dev); + + /* mask all GPIO interrupts */ + writel(0U, priv->base + JH7110_SYS_GPIOIE0); + writel(0U, priv->base + JH7110_SYS_GPIOIE1); + /* clear edge interrupt flags */ + writel(~0U, priv->base + JH7110_SYS_GPIOIC0); + writel(~0U, priv->base + JH7110_SYS_GPIOIC1); + /* enable GPIO interrupts */ + writel(1U, priv->base + JH7110_SYS_GPIOEN); +} + +const struct starfive_pinctrl_soc_info jh7110_sys_pinctrl_info = { + /* pin conf */ + .set_one_pinmux = jh7110_sys_set_one_pin_mux, + .get_padcfg_base = jh7110_sys_get_padcfg_base, + + /* gpio dout/doen/din/gpioinput register */ + .dout_reg_base = JH7110_SYS_DOUT, + .dout_mask = GENMASK(6, 0), + .doen_reg_base = JH7110_SYS_DOEN, + .doen_mask = GENMASK(5, 0), + .gpi_reg_base = JH7110_SYS_GPI, + .gpi_mask = GENMASK(6, 0), + .gpioin_reg_base = JH7110_SYS_GPIOIN, + + /* gpio */ + .gpio_bank_name = "GPIO", + .ngpios = JH7110_SYS_NGPIO, + .gpio_init_hw = jh7110_sys_init_hw, +}; + +static int jh7110_sys_pinctrl_probe(struct udevice *dev) +{ + struct starfive_pinctrl_soc_info *info = + (struct starfive_pinctrl_soc_info *)dev_get_driver_data(dev); + + return starfive_pinctrl_probe(dev, info); +} + +static const struct udevice_id jh7110_sys_pinctrl_ids[] = { + /* JH7110 sys pinctrl */ + { .compatible = "starfive,jh7110-sys-pinctrl", + .data = (ulong)&jh7110_sys_pinctrl_info, }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(jh7110_sys_pinctrl) = { + .name = "jh7110-sys-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = jh7110_sys_pinctrl_ids, + .priv_auto = sizeof(struct starfive_pinctrl_priv), + .ops = &starfive_pinctrl_ops, + .probe = jh7110_sys_pinctrl_probe, +}; diff --git a/drivers/pinctrl/starfive/pinctrl-starfive.c b/drivers/pinctrl/starfive/pinctrl-starfive.c new file mode 100644 index 0000000000..1be9f36bb3 --- /dev/null +++ b/drivers/pinctrl/starfive/pinctrl-starfive.c @@ -0,0 +1,382 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Pinctrl / GPIO driver for StarFive JH7100 SoC + * + * Copyright (C) 2022 Shanghai StarFive Technology Co., Ltd. + * Author: Lee Kuan Lim kuanlim.lee@starfivetech.com + * Author: Jianlong Huang jianlong.huang@starfivetech.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <dm/pinctrl.h> +#include <asm-generic/gpio.h> +#include <linux/bitops.h> +#include <linux/io.h> +#include <linux/ioport.h> +#include <dm/device_compat.h> +#include <dt-bindings/pinctrl/pinctrl-starfive-jh7110.h> + +#include "pinctrl-starfive.h" + +/* pad control bits */ +#define STARFIVE_PADCFG_POS BIT(7) +#define STARFIVE_PADCFG_SMT BIT(6) +#define STARFIVE_PADCFG_SLEW BIT(5) +#define STARFIVE_PADCFG_PD BIT(4) +#define STARFIVE_PADCFG_PU BIT(3) +#define STARFIVE_PADCFG_BIAS (STARFIVE_PADCFG_PD | STARFIVE_PADCFG_PU) +#define STARFIVE_PADCFG_DS_MASK GENMASK(2, 1) +#define STARFIVE_PADCFG_DS_2MA (0U << 1) +#define STARFIVE_PADCFG_DS_4MA BIT(1) +#define STARFIVE_PADCFG_DS_8MA (2U << 1) +#define STARFIVE_PADCFG_DS_12MA (3U << 1) +#define STARFIVE_PADCFG_IE BIT(0) +#define GPIO_NUM_PER_WORD 32 + +/* + * The packed pinmux values from the device tree look like this: + * + * | 31 - 24 | 23 - 16 | 15 - 10 | 9 - 8 | 7 - 0 | + * | din | dout | doen | function | pin | + */ +static unsigned int starfive_pinmux_din(u32 v) +{ + return (v & GENMASK(31, 24)) >> 24; +} + +static u32 starfive_pinmux_dout(u32 v) +{ + return (v & GENMASK(23, 16)) >> 16; +} + +static u32 starfive_pinmux_doen(u32 v) +{ + return (v & GENMASK(15, 10)) >> 10; +} + +static u32 starfive_pinmux_function(u32 v) +{ + return (v & GENMASK(9, 8)) >> 8; +} + +static unsigned int starfive_pinmux_pin(u32 v) +{ + return v & GENMASK(7, 0); +} + +void starfive_set_gpiomux(struct udevice *dev, unsigned int pin, + unsigned int din, u32 dout, u32 doen) +{ + struct starfive_pinctrl_priv *priv = dev_get_priv(dev); + const struct starfive_pinctrl_soc_info *info = priv->info; + + unsigned int offset = 4 * (pin / 4); + unsigned int shift = 8 * (pin % 4); + u32 dout_mask = info->dout_mask << shift; + u32 done_mask = info->doen_mask << shift; + u32 ival, imask; + void __iomem *reg_dout; + void __iomem *reg_doen; + void __iomem *reg_din; + + reg_dout = priv->base + info->dout_reg_base + offset; + reg_doen = priv->base + info->doen_reg_base + offset; + dout <<= shift; + doen <<= shift; + if (din != GPI_NONE) { + unsigned int ioffset = 4 * (din / 4); + unsigned int ishift = 8 * (din % 4); + + reg_din = priv->base + info->gpi_reg_base + ioffset; + ival = (pin + 2) << ishift; + imask = info->gpi_mask << ishift; + } else { + reg_din = NULL; + } + + dout |= readl(reg_dout) & ~dout_mask; + writel(dout, reg_dout); + doen |= readl(reg_doen) & ~done_mask; + writel(doen, reg_doen); + if (reg_din) { + ival |= readl(reg_din) & ~imask; + writel(ival, reg_din); + } +} + +static const struct pinconf_param starfive_pinconf_params[] = { + { "bias-disable", PIN_CONFIG_BIAS_DISABLE, 0 }, + { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 1 }, + { "bias-pull-down", PIN_CONFIG_BIAS_PULL_DOWN, 1 }, + { "drive-strength", PIN_CONFIG_DRIVE_STRENGTH, 0 }, + { "input-schmitt-enable", PIN_CONFIG_INPUT_SCHMITT_ENABLE, 1 }, + { "input-schmitt-disable", PIN_CONFIG_INPUT_SCHMITT_ENABLE, 0 }, + { "input-enable", PIN_CONFIG_INPUT_ENABLE, 1 }, + { "input-disable", PIN_CONFIG_INPUT_ENABLE, 0 }, + { "slew-rate", PIN_CONFIG_SLEW_RATE, 0 }, +}; + +static const u8 starfive_drive_strength_mA[4] = { 2, 4, 8, 12 }; + +static u32 starfive_padcfg_ds_from_mA(u32 v) +{ + int i; + + for (i = 0; i < 3; i++) { + if (v <= starfive_drive_strength_mA[i]) + break; + } + return i << 1; +} + +static void starfive_padcfg_rmw(struct udevice *dev, + unsigned int pin, u32 mask, u32 value) +{ + struct starfive_pinctrl_priv *priv = dev_get_priv(dev); + struct starfive_pinctrl_soc_info *info = priv->info; + void __iomem *reg; + int padcfg_base; + + if (!info->get_padcfg_base) + return; + + padcfg_base = info->get_padcfg_base(dev, pin); + if (padcfg_base < 0) + return; + + reg = priv->base + padcfg_base + 4 * pin; + value &= mask; + + value |= readl(reg) & ~mask; + writel(value, reg); +} + +static int starfive_pinconf_set(struct udevice *dev, unsigned int pin, + unsigned int param, unsigned int arg) +{ + u16 mask = 0; + u16 value = 0; + + switch (param) { + case PIN_CONFIG_BIAS_DISABLE: + mask |= STARFIVE_PADCFG_BIAS; + value &= ~STARFIVE_PADCFG_BIAS; + break; + case PIN_CONFIG_BIAS_PULL_DOWN: + if (arg == 0) + return -EINVAL; + mask |= STARFIVE_PADCFG_BIAS; + value = (value & ~STARFIVE_PADCFG_BIAS) | STARFIVE_PADCFG_PD; + break; + case PIN_CONFIG_BIAS_PULL_UP: + if (arg == 0) + return -EINVAL; + mask |= STARFIVE_PADCFG_BIAS; + value = (value & ~STARFIVE_PADCFG_BIAS) | STARFIVE_PADCFG_PU; + break; + case PIN_CONFIG_DRIVE_STRENGTH: + mask |= STARFIVE_PADCFG_DS_MASK; + value = (value & ~STARFIVE_PADCFG_DS_MASK) | + starfive_padcfg_ds_from_mA(arg); + break; + case PIN_CONFIG_INPUT_ENABLE: + mask |= STARFIVE_PADCFG_IE; + if (arg) + value |= STARFIVE_PADCFG_IE; + else + value &= ~STARFIVE_PADCFG_IE; + break; + case PIN_CONFIG_INPUT_SCHMITT_ENABLE: + mask |= STARFIVE_PADCFG_SMT; + if (arg) + value |= STARFIVE_PADCFG_SMT; + else + value &= ~STARFIVE_PADCFG_SMT; + break; + case PIN_CONFIG_SLEW_RATE: + mask |= STARFIVE_PADCFG_SLEW; + if (arg) + value |= STARFIVE_PADCFG_SLEW; + else + value &= ~STARFIVE_PADCFG_SLEW; + break; + default: + return -EINVAL; + } + + starfive_padcfg_rmw(dev, pin, mask, value); + + return 0; +} + +static int starfive_property_set(struct udevice *dev, u32 pinmux_group) +{ + struct starfive_pinctrl_priv *priv = dev_get_priv(dev); + struct starfive_pinctrl_soc_info *info = priv->info; + + if (info->set_one_pinmux) + info->set_one_pinmux(dev, + starfive_pinmux_pin(pinmux_group), + starfive_pinmux_din(pinmux_group), + starfive_pinmux_dout(pinmux_group), + starfive_pinmux_doen(pinmux_group), + starfive_pinmux_function(pinmux_group)); + + return starfive_pinmux_pin(pinmux_group); +} + +const struct pinctrl_ops starfive_pinctrl_ops = { + .set_state = pinctrl_generic_set_state, + .pinconf_num_params = ARRAY_SIZE(starfive_pinconf_params), + .pinconf_params = starfive_pinconf_params, + .pinconf_set = starfive_pinconf_set, + .pinmux_property_set = starfive_property_set, +}; + +static int starfive_gpio_direction_input(struct udevice *dev, unsigned int off) +{ + struct udevice *pdev = dev->parent; + struct starfive_pinctrl_priv *priv = dev_get_priv(dev); + struct starfive_pinctrl_soc_info *info = priv->info; + + /* enable input and schmitt trigger */ + starfive_padcfg_rmw(pdev, off, + STARFIVE_PADCFG_IE | STARFIVE_PADCFG_SMT, + STARFIVE_PADCFG_IE | STARFIVE_PADCFG_SMT); + + if (info->set_one_pinmux) + info->set_one_pinmux(pdev, off, + GPI_NONE, GPOUT_LOW, GPOEN_DISABLE, 0); + + return 0; +} + +static int starfive_gpio_direction_output(struct udevice *dev, + unsigned int off, int val) +{ + struct udevice *pdev = dev->parent; + struct starfive_pinctrl_priv *priv = dev_get_priv(dev); + struct starfive_pinctrl_soc_info *info = priv->info; + + if (info->set_one_pinmux) + info->set_one_pinmux(pdev, off, + GPI_NONE, val ? GPOUT_HIGH : GPOUT_LOW, + GPOEN_ENABLE, 0); + + /* disable input, schmitt trigger and bias */ + starfive_padcfg_rmw(pdev, off, + STARFIVE_PADCFG_IE | STARFIVE_PADCFG_SMT + | STARFIVE_PADCFG_BIAS, + 0); + + return 0; +} + +static int starfive_gpio_get_value(struct udevice *dev, unsigned int off) +{ + struct udevice *pdev = dev->parent; + struct starfive_pinctrl_priv *priv = dev_get_priv(pdev); + struct starfive_pinctrl_soc_info *info = priv->info; + + void __iomem *reg = priv->base + info->gpioin_reg_base + + 4 * (off / GPIO_NUM_PER_WORD); + + return !!(readl(reg) & BIT(off % GPIO_NUM_PER_WORD)); +} + +static int starfive_gpio_set_value(struct udevice *dev, + unsigned int off, int val) +{ + struct udevice *pdev = dev->parent; + struct starfive_pinctrl_priv *priv = dev_get_priv(pdev); + struct starfive_pinctrl_soc_info *info = priv->info; + + unsigned int offset = 4 * (off / 4); + unsigned int shift = 8 * (off % 4); + void __iomem *reg_dout = priv->base + info->dout_reg_base + offset; + u32 dout = (val ? GPOUT_HIGH : GPOUT_LOW) << shift; + u32 mask = info->dout_mask << shift; + + dout |= readl(reg_dout) & ~mask; + writel(dout, reg_dout); + + return 0; +} + +static int starfive_gpio_probe(struct udevice *dev) +{ + struct gpio_dev_priv *uc_priv; + struct udevice *pdev = dev->parent; + struct starfive_pinctrl_priv *priv = dev_get_priv(pdev); + struct starfive_pinctrl_soc_info *info = priv->info; + + uc_priv = dev_get_uclass_priv(dev); + uc_priv->bank_name = info->gpio_bank_name; + uc_priv->gpio_count = info->ngpios; + + if (!info->gpio_init_hw) + return -ENXIO; + + info->gpio_init_hw(pdev); + + return 0; +} + +static const struct dm_gpio_ops starfive_gpio_ops = { + .direction_input = starfive_gpio_direction_input, + .direction_output = starfive_gpio_direction_output, + .get_value = starfive_gpio_get_value, + .set_value = starfive_gpio_set_value, +}; + +static struct driver starfive_gpio_driver = { + .name = "starfive_gpio", + .id = UCLASS_GPIO, + .probe = starfive_gpio_probe, + .ops = &starfive_gpio_ops, +}; + +static int starfive_gpiochip_register(struct udevice *parent) +{ + struct uclass_driver *drv; + struct udevice *dev; + int ret; + ofnode node; + + drv = lists_uclass_lookup(UCLASS_GPIO); + if (!drv) + return -ENOENT; + + node = dev_ofnode(parent); + ret = device_bind_with_driver_data(parent, &starfive_gpio_driver, + "starfive_gpio", 0, node, &dev); + + return (ret == 0) ? 0 : ret; +} + +int starfive_pinctrl_probe(struct udevice *dev, + const struct starfive_pinctrl_soc_info *info) +{ + struct starfive_pinctrl_priv *priv = dev_get_priv(dev); + int ret; + + /* Bind pinctrl_info from .data to priv */ + priv->info = + (struct starfive_pinctrl_soc_info *)dev_get_driver_data(dev); + + if (!priv->info) + return -EINVAL; + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -EINVAL; + + /* gpiochip register */ + ret = starfive_gpiochip_register(dev); + + return (ret == 0) ? 0 : ret; +} diff --git a/drivers/pinctrl/starfive/pinctrl-starfive.h b/drivers/pinctrl/starfive/pinctrl-starfive.h new file mode 100644 index 0000000000..5721c3c36e --- /dev/null +++ b/drivers/pinctrl/starfive/pinctrl-starfive.h @@ -0,0 +1,55 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Pinctrl / GPIO driver for StarFive SoC + * + * Copyright (C) 2022 Shanghai StarFive Technology Co., Ltd. + * Author: Lee Kuan Lim kuanlim.lee@starfivetech.com + * Author: Jianlong Huang jianlong.huang@starfivetech.com + */ + +#define STARFIVE_PINCTRL(a, b) { .number = a, .name = b } + +extern const struct pinctrl_ops starfive_pinctrl_ops; + +struct starfive_pinctrl_pin { + unsigned int number; + const char *name; +}; + +struct starfive_pinctrl_soc_info { + /* pinctrl */ + int (*set_one_pinmux)(struct udevice *dev, unsigned int pin, + unsigned int din, u32 dout, u32 doen, u32 func); + int (*get_padcfg_base)(struct udevice *dev, + unsigned int pin); + + /* gpio dout/doen/din/gpioinput register */ + unsigned int dout_reg_base; + unsigned int dout_mask; + unsigned int doen_reg_base; + unsigned int doen_mask; + unsigned int gpi_reg_base; + unsigned int gpi_mask; + unsigned int gpioin_reg_base; + + /* gpio */ + const char *gpio_bank_name; + int ngpios; + void (*gpio_init_hw)(struct udevice *dev); +}; + +/* + * struct starfive_pinctrl_priv - private data for Starfive pinctrl driver + * + * @padctl_base: base address of the pinctrl device + * @info: SoC specific data & function + */ +struct starfive_pinctrl_priv { + void __iomem *base; + struct starfive_pinctrl_soc_info *info; +}; + +void starfive_set_gpiomux(struct udevice *dev, unsigned int pin, + unsigned int din, u32 dout, u32 doen); +int starfive_pinctrl_probe(struct udevice *dev, + const struct starfive_pinctrl_soc_info *info);
Add driver for StarFive JH7110 to support ddr initialization in SPL.
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- drivers/ram/Kconfig | 1 + drivers/ram/Makefile | 4 +- drivers/ram/starfive/Kconfig | 5 + drivers/ram/starfive/Makefile | 11 + drivers/ram/starfive/ddrcsr_boot.c | 339 +++++ drivers/ram/starfive/ddrphy_start.c | 279 ++++ drivers/ram/starfive/ddrphy_train.c | 383 ++++++ drivers/ram/starfive/ddrphy_utils.c | 1955 +++++++++++++++++++++++++++ drivers/ram/starfive/starfive_ddr.c | 161 +++ drivers/ram/starfive/starfive_ddr.h | 65 + 10 files changed, 3202 insertions(+), 1 deletion(-) create mode 100644 drivers/ram/starfive/Kconfig create mode 100644 drivers/ram/starfive/Makefile create mode 100644 drivers/ram/starfive/ddrcsr_boot.c create mode 100644 drivers/ram/starfive/ddrphy_start.c create mode 100644 drivers/ram/starfive/ddrphy_train.c create mode 100644 drivers/ram/starfive/ddrphy_utils.c create mode 100644 drivers/ram/starfive/starfive_ddr.c create mode 100644 drivers/ram/starfive/starfive_ddr.h
diff --git a/drivers/ram/Kconfig b/drivers/ram/Kconfig index e085119963..1acf212f87 100644 --- a/drivers/ram/Kconfig +++ b/drivers/ram/Kconfig @@ -112,3 +112,4 @@ source "drivers/ram/rockchip/Kconfig" source "drivers/ram/sifive/Kconfig" source "drivers/ram/stm32mp1/Kconfig" source "drivers/ram/octeon/Kconfig" +source "drivers/ram/starfive/Kconfig" diff --git a/drivers/ram/Makefile b/drivers/ram/Makefile index 83948e2c43..2b9429cfee 100644 --- a/drivers/ram/Makefile +++ b/drivers/ram/Makefile @@ -20,5 +20,7 @@ obj-$(CONFIG_K3_DDRSS) += k3-ddrss/ obj-$(CONFIG_IMXRT_SDRAM) += imxrt_sdram.o
obj-$(CONFIG_RAM_SIFIVE) += sifive/ - +ifdef CONFIG_SPL_BUILD +obj-$(CONFIG_SPL_STARFIVE_DDR) += starfive/ +endif obj-$(CONFIG_ARCH_OCTEON) += octeon/ diff --git a/drivers/ram/starfive/Kconfig b/drivers/ram/starfive/Kconfig new file mode 100644 index 0000000000..80c790066f --- /dev/null +++ b/drivers/ram/starfive/Kconfig @@ -0,0 +1,5 @@ +config SPL_STARFIVE_DDR + bool "StarFive DDR driver in SPL" + depends on SPL_RAM && STARFIVE_JH7110 + help + This enables DDR support for the platforms based on StarFive JH7110 SoC. diff --git a/drivers/ram/starfive/Makefile b/drivers/ram/starfive/Makefile new file mode 100644 index 0000000000..1df42c377b --- /dev/null +++ b/drivers/ram/starfive/Makefile @@ -0,0 +1,11 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2022 StarFive, Inc +# +ifdef CONFIG_SPL_BUILD +obj-$(CONFIG_SPL_STARFIVE_DDR) += ddrphy_start.o +obj-$(CONFIG_SPL_STARFIVE_DDR) += ddrphy_train.o +obj-$(CONFIG_SPL_STARFIVE_DDR) += starfive_ddr.o +obj-$(CONFIG_SPL_STARFIVE_DDR) += ddrphy_utils.o +obj-$(CONFIG_SPL_STARFIVE_DDR) += ddrcsr_boot.o +endif \ No newline at end of file diff --git a/drivers/ram/starfive/ddrcsr_boot.c b/drivers/ram/starfive/ddrcsr_boot.c new file mode 100644 index 0000000000..f2dd55f74a --- /dev/null +++ b/drivers/ram/starfive/ddrcsr_boot.c @@ -0,0 +1,339 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wangyanhong.wang@starfivetech.com + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/regs.h> +#include <linux/delay.h> +#include <wait_bit.h> + +#include "starfive_ddr.h" + +#define REGOFFSET(offset) ((offset) / 4) + +static const struct ddr_reg_cfg ddr_csr_cfg[] = { + {0x0, 0x0, 0x00000001, REGSETALL}, + {0xf00, 0x0, 0x40001030, (OFFSET_SEL | F_SET | REG4G | REG8G)}, + {0xf00, 0x0, 0x40001030, (OFFSET_SEL | F_SET | REG2G)}, + {0xf04, 0x0, 0x00000001, (OFFSET_SEL | F_SET | REG4G | REG8G)}, + {0xf04, 0x0, 0x00800001, (OFFSET_SEL | F_SET | REG2G)}, + {0xf10, 0x0, 0x00400000, (OFFSET_SEL | REGSETALL)}, + {0xf14, 0x0, 0x043fffff, (OFFSET_SEL | REGSETALL)}, + {0xf18, 0x0, 0x00000000, (OFFSET_SEL | REGSETALL)}, + {0xf30, 0x0, 0x1f000041, (OFFSET_SEL | REGSETALL)}, + {0xf34, 0x0, 0x1f000041, (OFFSET_SEL | F_SET | REG4G | REG8G)}, + {0x110, 0x0, 0xc0000001, (OFFSET_SEL | REGSETALL)}, + {0x114, 0x0, 0xffffffff, (OFFSET_SEL | REGSETALL)}, + {0x10c, 0x0, 0x00000505, REGSETALL}, + {0x11c, 0x0, 0x00000000, REGSETALL}, + {0x500, 0x0, 0x00000201, REGSETALL}, + {0x514, 0x0, 0x00000100, REGSETALL}, + {0x6a8, 0x0, 0x00040000, REGSETALL}, + {0xea8, 0x0, 0x00040000, REGSETALL}, + {0x504, 0x0, 0x40000000, REGSETALL} +}; + +static const struct ddr_reg_cfg ddr_csr_cfg1[] = { + {0x310, 0x0, 0x00020000, REGSETALL}, + {0x310, 0x0, 0x00020001, REGSETALL}, + {0x600, 0x0, 0x002e0176, REGSETALL}, + {0x604, 0x0, 0x002e0176, REGSETALL}, + {0x608, 0x0, 0x001700bb, REGSETALL}, + {0x60c, 0x0, 0x000b005d, REGSETALL}, + {0x610, 0x0, 0x0005002e, REGSETALL}, + {0x614, 0x0, 0x00020017, REGSETALL}, + {0x618, 0x0, 0x00020017, REGSETALL}, + {0x61c, 0x0, 0x00020017, REGSETALL}, + {0x678, 0x0, 0x00000019, REGSETALL}, + {0x100, 0x0, 0x000000f8, REGSETALL}, + {0x620, 0x0, 0x03030404, REGSETALL}, + {0x624, 0x0, 0x04030505, REGSETALL}, + {0x628, 0x0, 0x07030884, REGSETALL}, + {0x62c, 0x0, 0x13150401, REGSETALL}, + {0x630, 0x0, 0x17150604, REGSETALL}, + {0x634, 0x0, 0x00110000, REGSETALL}, + {0x638, 0x0, 0x200a0a08, REGSETALL}, + {0x63c, 0x0, 0x1730f803, REGSETALL}, + {0x640, 0x0, 0x000a0c00, REGSETALL}, + {0x644, 0x0, 0xa005000a, REGSETALL}, + {0x648, 0x0, 0x00000000, REGSETALL}, + {0x64c, 0x0, 0x00081306, REGSETALL}, + {0x650, 0x0, 0x04070304, REGSETALL}, + {0x654, 0x0, 0x00000404, REGSETALL}, + {0x658, 0x0, 0x00000060, REGSETALL}, + {0x65c, 0x0, 0x00030008, REGSETALL}, + {0x660, 0x0, 0x00000000, REGSETALL}, + {0x680, 0x0, 0x00000603, REGSETALL}, + {0x684, 0x0, 0x01000202, REGSETALL}, + {0x688, 0x0, 0x0413040d, REGSETALL}, + {0x68c, 0x0, 0x20002420, REGSETALL}, + {0x690, 0x0, 0x00140000, REGSETALL}, + {0x69c, 0x0, 0x01240074, REGSETALL}, + {0x6a0, 0x0, 0x00000000, REGSETALL}, + {0x6a4, 0x0, 0x20240c00, REGSETALL}, + {0x6a8, 0x0, 0x00040000, REGSETALL}, + {0x4, 0x0, 0x30010006, (F_SET | REG4G | REG8G)}, + {0x4, 0x0, 0x10010006, (F_SET | REG2G)}, + {0xc, 0x0, 0x00000002, REGSETALL}, + {0x4, 0x0, 0x30020000, (F_SET | REG4G | REG8G)}, + {0x4, 0x0, 0x10020000, (F_SET | REG2G)}, + {0xc, 0x0, 0x00000002, REGSETALL}, + {0x4, 0x0, 0x30030031, (F_SET | REG4G | REG8G)}, + {0x4, 0x0, 0x10030031, (F_SET | REG2G)}, + {0xc, 0x0, 0x00000002, REGSETALL}, + {0x4, 0x0, 0x300b0033, (F_SET | REG4G | REG8G)}, + {0x4, 0x0, 0x100b0033, (F_SET | REG2G)}, + {0xc, 0x0, 0x00000002, REGSETALL}, + {0x4, 0x0, 0x30160016, (F_SET | REG4G | REG8G)}, + {0x4, 0x0, 0x10160016, (F_SET | REG2G)}, + {0xc, 0x0, 0x00000002, REGSETALL}, + {0x10, 0x0, 0x00000010, REGSETALL}, + {0x14, 0x0, 0x00000001, REGSETALL}, +}; + +static const struct ddr_reg_cfg ddr_csr_cfg2[] = { + {0xb8, 0xf0ffffff, 0x3000000, REGCLRSETALL}, + {0x84, 0xFEFFFFFF, 0x0, REGCLRSETALL}, + {0xb0, 0xFFFEFFFF, 0x0, REGCLRSETALL}, + {0xb0, 0xFEFFFFFF, 0x0, REGCLRSETALL}, + {0xb4, 0xffffffff, 0x1, REGCLRSETALL}, + {0x248, 0xffffffff, 0x3000000, REGCLRSETALL}, + {0x24c, 0xffffffff, 0x300, REGCLRSETALL}, + {0x24c, 0xffffffff, 0x3000000, REGCLRSETALL}, + {0xb0, 0xffffffff, 0x100, REGCLRSETALL}, + {0xb8, 0xFFF0FFFF, 0x30000, REGCLRSETALL}, + {0x84, 0xFFFEFFFF, 0x0, REGCLRSETALL}, + {0xac, 0xFFFEFFFF, 0x0, REGCLRSETALL}, + {0xac, 0xFEFFFFFF, 0x0, REGCLRSETALL}, + {0xb0, 0xffffffff, 0x1, REGCLRSETALL}, + {0x248, 0xffffffff, 0x30000, REGCLRSETALL}, + {0x24c, 0xffffffff, 0x3, REGCLRSETALL}, + {0x24c, 0xffffffff, 0x30000, REGCLRSETALL}, + {0x250, 0xffffffff, 0x3000000, REGCLRSETALL}, + {0x254, 0xffffffff, 0x3000000, REGCLRSETALL}, + {0x258, 0xffffffff, 0x3000000, REGCLRSETALL}, + {0xac, 0xffffffff, 0x100, REGCLRSETALL}, + {0x10c, 0xFFFFF0FF, 0x300, REGCLRSETALL}, + {0x110, 0xFFFFFEFF, 0x0, REGCLRSETALL}, + {0x11c, 0xFFFEFFFF, 0x0, REGCLRSETALL}, + {0x11c, 0xFEFFFFFF, 0x0, REGCLRSETALL}, + {0x120, 0xffffffff, 0x100, REGCLRSETALL}, + {0x2d0, 0xffffffff, 0x300, REGCLRSETALL}, + {0x2dc, 0xffffffff, 0x300, REGCLRSETALL}, + {0x2e8, 0xffffffff, 0x300, REGCLRSETALL}, +}; + +static const struct ddr_reg_cfg ddr_csr_cfg3[] = { + {0x100, 0x0, 0x000000e0, REGSETALL}, + {0x620, 0x0, 0x04041417, REGSETALL}, + {0x624, 0x0, 0x09110609, REGSETALL}, + {0x628, 0x0, 0x442d0994, REGSETALL}, + {0x62c, 0x0, 0x271e102b, REGSETALL}, + {0x630, 0x0, 0x291b140a, REGSETALL}, + {0x634, 0x0, 0x001c0000, REGSETALL}, + {0x638, 0x0, 0x200f0f08, REGSETALL}, + {0x63c, 0x0, 0x29420a06, REGSETALL}, + {0x640, 0x0, 0x019e1fc1, REGSETALL}, + {0x644, 0x0, 0x10cb0196, REGSETALL}, + {0x648, 0x0, 0x00000000, REGSETALL}, + {0x64c, 0x0, 0x00082714, REGSETALL}, + {0x650, 0x0, 0x16442f0d, REGSETALL}, + {0x654, 0x0, 0x00001916, REGSETALL}, + {0x658, 0x0, 0x00000060, REGSETALL}, + {0x65c, 0x0, 0x00600020, REGSETALL}, + {0x660, 0x0, 0x00000000, REGSETALL}, + {0x680, 0x0, 0x0c00040f, REGSETALL}, + {0x684, 0x0, 0x03000604, REGSETALL}, + {0x688, 0x0, 0x0515040d, REGSETALL}, + {0x68c, 0x0, 0x20002c20, REGSETALL}, + {0x690, 0x0, 0x00140000, REGSETALL}, + {0x69c, 0x0, 0x01240074, REGSETALL}, + {0x6a0, 0x0, 0x00000000, REGSETALL}, + {0x6a4, 0x0, 0x202c0c00, REGSETALL}, + {0x6a8, 0x0, 0x00040000, REGSETALL}, + {0x4, 0x0, 0x30010036, (F_SET | REG4G | REG8G)}, + {0x4, 0x0, 0x10010036, (F_SET | REG2G)}, + {0xc, 0x0, 0x00000002, REGSETALL}, + {0x4, 0x0, 0x3002001b, (F_SET | REG4G | REG8G)}, + {0x4, 0x0, 0x10010036, (F_SET | REG2G)}, + {0xc, 0x0, 0x00000002, REGSETALL}, + {0x4, 0x0, 0x30030031, (F_SET | REG4G | REG8G)}, + {0x4, 0x0, 0x10030031, (F_SET | REG2G)}, + {0xc, 0x0, 0x00000002, REGSETALL}, + {0x4, 0x0, 0x300b0066, (F_SET | REG4G)}, + {0x4, 0x0, 0x300b0036, (F_SET | REG8G)}, + {0x4, 0x0, 0x100b0066, (F_SET | REG2G)}, + {0xc, 0x0, 0x00000002, REGSETALL}, + {0x4, 0x0, 0x30160016, (F_SET | REG4G | REG8G)}, + {0x4, 0x0, 0x10160016, (F_SET | REG2G)}, + {0xc, 0x0, 0x00000002, REGSETALL}, + {0x410, 0x0, 0x00101010, REGSETALL}, + {0x420, 0x0, 0x0c181006, REGSETALL}, + {0x424, 0x0, 0x20200820, REGSETALL}, + {0x428, 0x0, 0x80000020, REGSETALL}, + {0x0, 0x0, 0x00000001, REGSETALL}, + {0x108, 0x0, 0x00003000, REGSETALL}, + {0x704, 0x0, 0x00000007, REGSETALL | OFFSET_SEL}, + {0x330, 0x0, 0x09313fff, (F_SET | REG4G | REG8G)}, + {0x330, 0x0, 0x09311fff, (F_SET | REG2G)}, + {0x508, 0x0, 0x00000033, (F_SET | REG4G | REG8G)}, + {0x508, 0x0, 0x00000013, (F_SET | REG2G)}, + {0x324, 0x0, 0x00002000, REGSETALL}, + {0x104, 0x0, 0x90000000, REGSETALL}, + {0x510, 0x0, 0x00000100, REGSETALL}, + {0x514, 0x0, 0x00000000, REGSETALL}, + {0x700, 0x0, 0x00000003, REGSETALL | OFFSET_SEL}, + {0x514, 0x0, 0x00000600, REGSETALL}, + {0x20, 0x0, 0x00000001, REGSETALL}, +}; + +static void ddr_csr_set(u32 *csrreg, u32 *secreg, const struct ddr_reg_cfg *data, + u32 len, u32 mask) +{ + u32 *addr; + u32 i; + + for (i = 0; i < len; i++) { + if (!(data[i].flag & mask)) + continue; + + if (data[i].flag & OFFSET_SEL) + addr = secreg + REGOFFSET(data[i].offset); + else + addr = csrreg + REGOFFSET(data[i].offset); + + if (data[i].flag & F_CLRSET) + DDR_REG_TRIGGER(addr, data[i].mask, data[i].val); + else + out_le32(addr, data[i].val); + } +} + +void ddrcsr_boot(u32 *csrreg, u32 *secreg, u32 *phyreg, enum ddr_size_t size) +{ + u32 len; + u32 val; + u32 mask; + int ret; + + switch (size) { + case DDR_SIZE_2G: + mask = REG2G; + break; + + case DDR_SIZE_4G: + mask = REG4G; + break; + + case DDR_SIZE_8G: + mask = REG8G; + break; + + case DDR_SIZE_16G: + default: + return; + }; + + len = ARRAY_SIZE(ddr_csr_cfg); + ddr_csr_set(csrreg, secreg, ddr_csr_cfg, len, mask); + + ret = wait_for_bit_le32(csrreg + REGOFFSET(0x504), BIT(31), + true, 1000, false); + if (ret) + return; + + out_le32(csrreg + REGOFFSET(0x504), 0x0); + out_le32(csrreg + REGOFFSET(0x50c), 0x0); + udelay(300); + out_le32(csrreg + REGOFFSET(0x50c), 0x1); + mdelay(3); + + switch (size) { + case DDR_SIZE_2G: + out_le32(csrreg + REGOFFSET(0x10), 0x1c); + break; + + case DDR_SIZE_8G: + case DDR_SIZE_4G: + out_le32(csrreg + REGOFFSET(0x10), 0x3c); + break; + + case DDR_SIZE_16G: + default: + break; + }; + + out_le32(csrreg + REGOFFSET(0x14), 0x1); + udelay(4); + + len = ARRAY_SIZE(ddr_csr_cfg1); + ddr_csr_set(csrreg, secreg, ddr_csr_cfg1, len, mask); + + udelay(4); + out_le32(csrreg + REGOFFSET(0x10), 0x11); + out_le32(csrreg + REGOFFSET(0x14), 0x1); + + switch (size) { + case DDR_SIZE_4G: + case DDR_SIZE_8G: + out_le32(csrreg + REGOFFSET(0x10), 0x20); + out_le32(csrreg + REGOFFSET(0x14), 0x1); + udelay(4); + out_le32(csrreg + REGOFFSET(0x10), 0x21); + out_le32(csrreg + REGOFFSET(0x14), 0x1); + break; + + case DDR_SIZE_2G: + case DDR_SIZE_16G: + default: + break; + }; + + out_le32(csrreg + REGOFFSET(0x514), 0x0); + ret = wait_for_bit_le32(csrreg + REGOFFSET(0x518), BIT(1), + true, 1000, false); + if (ret) + return; + + val = in_le32(csrreg + REGOFFSET(0x518)); + while ((val & 0x2) != 0x0) { + val = in_le32(phyreg + 1); + + if ((val & 0x20) == 0x20) { + switch (val & 0x1f) { + case 0: /* ddrc_clock=12M */ + DDR_REG_SET(BUS, DDR_BUS_OSC_DIV2); + break; + case 1: /* ddrc_clock=200M */ + DDR_REG_SET(BUS, DDR_BUS_PLL1_DIV8); + break; + case 2: /* ddrc_clock=800M */ + DDR_REG_SET(BUS, DDR_BUS_PLL1_DIV2); + break; + default: + break; + }; + + out_le32(phyreg + 2, 0x1); + ret = wait_for_bit_le32(phyreg + 2, BIT(0), false, 1000, false); + if (ret) + return; + } + + udelay(1); + val = in_le32(csrreg + REGOFFSET(0x518)); + }; + + val = in_le32(phyreg + 2048 + 83); + val = in_le32(phyreg + 2048 + 84); + out_le32(phyreg + 2048 + 84, val & 0xF8000000); + + len = ARRAY_SIZE(ddr_csr_cfg2); + ddr_csr_set(phyreg + PHY_BASE_ADDR, secreg, ddr_csr_cfg2, len, mask); + + len = ARRAY_SIZE(ddr_csr_cfg3); + ddr_csr_set(csrreg, secreg, ddr_csr_cfg3, len, mask); +} diff --git a/drivers/ram/starfive/ddrphy_start.c b/drivers/ram/starfive/ddrphy_start.c new file mode 100644 index 0000000000..479b6ef104 --- /dev/null +++ b/drivers/ram/starfive/ddrphy_start.c @@ -0,0 +1,279 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wangyanhong.wang@starfivetech.com + */ + +#include <common.h> +#include <asm/io.h> + +#include "starfive_ddr.h" + +static const struct ddr_reg_cfg ddr_start_cfg[] = { + {89, 0xffffff00, 0x00000051, (OFFSET_SEL | REGCLRSETALL)}, + {78, 0xfffffcff, 0x0, (OFFSET_SEL | REGCLRSETALL)}, + {345, 0xffffff00, 0x00000051, (OFFSET_SEL | REGCLRSETALL)}, + {334, 0xfffffcff, 0x0, (OFFSET_SEL | REGCLRSETALL)}, + {601, 0xffffff00, 0x00000051, (OFFSET_SEL | REGCLRSETALL)}, + {590, 0xfffffcff, 0x0, (OFFSET_SEL | REGCLRSETALL)}, + {857, 0xffffff00, 0x00000051, (OFFSET_SEL | REGCLRSETALL)}, + {846, 0xfffffcff, 0x0, (OFFSET_SEL | REGCLRSETALL)}, + {1793, 0xfffffeff, 0x0, (OFFSET_SEL | REGCLRSETALL)}, + {1793, 0xfffcffff, 0x0, (OFFSET_SEL | REGCLRSETALL)}, + {125, 0xfff0ffff, 0x00010000, (OFFSET_SEL | REGCLRSETALL)}, + {102, 0xfffffffc, 0x00000001, (OFFSET_SEL | REGCLRSETALL)}, + {105, 0xffffffe0, 0x00000001, (OFFSET_SEL | REGCLRSETALL)}, + {92, 0xfffffffe, 0x00000001, (OFFSET_SEL | REGCLRSETALL)}, + {94, 0xffffe0ff, 0x00000200, (OFFSET_SEL | REGCLRSETALL)}, + {96, 0xfffff0ff, 0x00000400, (OFFSET_SEL | REGCLRSETALL)}, + {89, 0xffffff00, 0x00000051, (OFFSET_SEL | REGCLRSETALL)}, + {381, 0xfff0ffff, 0x00010000, (OFFSET_SEL | REGCLRSETALL)}, + {358, 0xfffffffc, 0x00000001, (OFFSET_SEL | REGCLRSETALL)}, + {361, 0xffffffe0, 0x00000001, (OFFSET_SEL | REGCLRSETALL)}, + {348, 0xfffffffe, 0x00000001, (OFFSET_SEL | REGCLRSETALL)}, + {350, 0xffffe0ff, 0x00000200, (OFFSET_SEL | REGCLRSETALL)}, + {352, 0xfffff0ff, 0x00000400, (OFFSET_SEL | REGCLRSETALL)}, + {345, 0xffffff00, 0x00000051, (OFFSET_SEL | REGCLRSETALL)}, + {637, 0xfff0ffff, 0x00010000, (OFFSET_SEL | REGCLRSETALL)}, + {614, 0xfffffffc, 0x00000001, (OFFSET_SEL | REGCLRSETALL)}, + {617, 0xffffffe0, 0x00000001, (OFFSET_SEL | REGCLRSETALL)}, + {604, 0xfffffffe, 0x00000001, (OFFSET_SEL | REGCLRSETALL)}, + {606, 0xffffe0ff, 0x00000200, (OFFSET_SEL | REGCLRSETALL)}, + {608, 0xfffff0ff, 0x00000400, (OFFSET_SEL | REGCLRSETALL)}, + {601, 0xffffff00, 0x00000051, (OFFSET_SEL | REGCLRSETALL)}, + {893, 0xfff0ffff, 0x00010000, (OFFSET_SEL | REGCLRSETALL)}, + {870, 0xfffffffc, 0x00000001, (OFFSET_SEL | REGCLRSETALL)}, + {873, 0xffffffe0, 0x00000001, (OFFSET_SEL | REGCLRSETALL)}, + {860, 0xfffffffe, 0x00000001, (OFFSET_SEL | REGCLRSETALL)}, + {862, 0xffffe0ff, 0x00000200, (OFFSET_SEL | REGCLRSETALL)}, + {864, 0xfffff0ff, 0x00000400, (OFFSET_SEL | REGCLRSETALL)}, + {857, 0xffffff00, 0x00000051, (OFFSET_SEL | REGCLRSETALL)}, + {1895, 0xffffe000, 0x00001342, (OFFSET_SEL | REGCLRSETALL)}, + {1835, 0xfffff0ff, 0x00000200, (OFFSET_SEL | REGCLRSETALL)}, + {1793, 0xfffffeff, 0x00000100, (OFFSET_SEL | REGCLRSETALL)}, + {62, 0xfffffeff, 0x0, REGCLRSETALL}, + {66, 0xfffffeff, 0x0, REGCLRSETALL}, + {166, 0xffffff80, 0x00000001, REGCLRSETALL}, + {62, 0xfff0ffff, 0x00010000, REGCLRSETALL}, + {62, 0xf0ffffff, 0x01000000, REGCLRSETALL}, + {166, 0xffff80ff, 0x00000100, REGCLRSETALL}, + {179, 0xff80ffff, 0x00010000, REGCLRSETALL}, + {67, 0xffe0ffff, 0x00010000, REGCLRSETALL}, + {67, 0xe0ffffff, 0x01000000, REGCLRSETALL}, + {179, 0x80ffffff, 0x01000000, REGCLRSETALL}, + {166, 0xff80ffff, 0x00010000, REGCLRSETALL}, + {62, 0xfff0ffff, 0x00010000, REGCLRSETALL}, + {62, 0xf0ffffff, 0x01000000, REGCLRSETALL}, + {166, 0x80ffffff, 0x01000000, REGCLRSETALL}, + {182, 0xff80ffff, 0x00010000, REGCLRSETALL}, + {67, 0xffe0ffff, 0x00010000, REGCLRSETALL}, + {67, 0xe0ffffff, 0x01000000, REGCLRSETALL}, + {182, 0x80ffffff, 0x01000000, REGCLRSETALL}, + {167, 0xffffff80, 0x00000017, REGCLRSETALL}, + {62, 0xfff0ffff, 0x00010000, REGCLRSETALL}, + {62, 0xf0ffffff, 0x01000000, REGCLRSETALL}, + {167, 0xffff80ff, 0x00001700, REGCLRSETALL}, + {185, 0xff80ffff, 0x00200000, REGCLRSETALL}, + {67, 0xffe0ffff, 0x00010000, REGCLRSETALL}, + {67, 0xe0ffffff, 0x01000000, REGCLRSETALL}, + {185, 0x80ffffff, 0x20000000, REGCLRSETALL}, + {10, 0xffffffe0, 0x00000002, REGCLRSETALL}, + {0, 0xfffffffe, 0x00000001, REGCLRSETALL}, + {11, 0xfffffff0, 0x00000005, (F_CLRSET | REG2G)}, + {247, 0xffffffff, 0x00000008, REGCLRSETALL}, + {249, 0xffffffff, 0x00000800, REGCLRSETALL}, + {252, 0xffffffff, 0x00000008, REGCLRSETALL}, + {254, 0xffffffff, 0x00000800, REGCLRSETALL}, + {281, 0xffffffff, 0x33000000, REGCLRSETALL}, + {305, 0xffffffff, 0x33000000, REGCLRSETALL}, + {329, 0xffffffff, 0x33000000, REGCLRSETALL}, + {353, 0xffffffff, 0x33000000, REGCLRSETALL}, + {289, 0xffffffff, 0x36000000, (F_CLRSET | REG8G)}, + {313, 0xffffffff, 0x36000000, (F_CLRSET | REG8G)}, + {337, 0xffffffff, 0x36000000, (F_CLRSET | REG8G)}, + {361, 0xffffffff, 0x36000000, (F_CLRSET | REG8G)}, + {289, 0xffffffff, 0x66000000, (F_CLRSET | REG2G | REG4G)}, + {313, 0xffffffff, 0x66000000, (F_CLRSET | REG2G | REG4G)}, + {337, 0xffffffff, 0x66000000, (F_CLRSET | REG2G | REG4G)}, + {361, 0xffffffff, 0x66000000, (F_CLRSET | REG2G | REG4G)}, + {282, 0xffffffff, 0x00160000, REGCLRSETALL}, + {306, 0xffffffff, 0x00160000, REGCLRSETALL}, + {330, 0xffffffff, 0x00160000, REGCLRSETALL}, + {354, 0xffffffff, 0x00160000, REGCLRSETALL}, + {290, 0xffffffff, 0x00160000, REGCLRSETALL}, + {314, 0xffffffff, 0x00160000, REGCLRSETALL}, + {338, 0xffffffff, 0x00160000, REGCLRSETALL}, + {362, 0xffffffff, 0x00160000, REGCLRSETALL}, + {282, 0xffffff00, 0x17, REGCLRSETALL}, + {306, 0xffffff00, 0x17, REGCLRSETALL}, + {330, 0xffffff00, 0x17, REGCLRSETALL}, + {354, 0xffffff00, 0x17, REGCLRSETALL}, + {290, 0xffffff00, 0x17, REGCLRSETALL}, + {314, 0xffffff00, 0x17, REGCLRSETALL}, + {338, 0xffffff00, 0x17, REGCLRSETALL}, + {362, 0xffffff00, 0x17, REGCLRSETALL}, + {282, 0xffff00ff, 0x2000, REGCLRSETALL}, + {306, 0xffff00ff, 0x2000, REGCLRSETALL}, + {330, 0xffff00ff, 0x2000, REGCLRSETALL}, + {354, 0xffff00ff, 0x2000, REGCLRSETALL}, + {290, 0xffff00ff, 0x2000, REGCLRSETALL}, + {314, 0xffff00ff, 0x2000, REGCLRSETALL}, + {338, 0xffff00ff, 0x2000, REGCLRSETALL}, + {362, 0xffff00ff, 0x2000, REGCLRSETALL}, + {65, 0xffffffff, 0x00000100, (OFFSET_SEL | REGCLRSETALL)}, + {321, 0xffffffff, 0x00000100, (OFFSET_SEL | REGCLRSETALL)}, + {577, 0xffffffff, 0x00000100, (OFFSET_SEL | REGCLRSETALL)}, + {833, 0xffffffff, 0x00000100, (OFFSET_SEL | REGCLRSETALL)}, + {96, 0x0, 0x300, (OFFSET_SEL | REGADDSETALL)}, + {352, 0x0, 0x300, (OFFSET_SEL | REGADDSETALL)}, + {608, 0x0, 0x300, (OFFSET_SEL | REGADDSETALL)}, + {864, 0x0, 0x300, (OFFSET_SEL | REGADDSETALL)}, + {96, 0xff00ffff, 0x00120000, (OFFSET_SEL | REGCLRSETALL)}, + {352, 0xff00ffff, 0x00120000, (OFFSET_SEL | REGCLRSETALL)}, + {608, 0xff00ffff, 0x00120000, (OFFSET_SEL | REGCLRSETALL)}, + {864, 0xff00ffff, 0x00120000, (OFFSET_SEL | REGCLRSETALL)}, + {33, 0xffffff00, 0x0040, (OFFSET_SEL | REGCLRSETALL)}, + {289, 0xffffff00, 0x0040, (OFFSET_SEL | REGCLRSETALL)}, + {545, 0xffffff00, 0x0040, (OFFSET_SEL | REGCLRSETALL)}, + {801, 0xffffff00, 0x0040, (OFFSET_SEL | REGCLRSETALL)}, + {1038, 0xfcffffff, 0x03000000, (OFFSET_SEL | REGCLRSETALL)}, + {1294, 0xfcffffff, 0x03000000, (OFFSET_SEL | REGCLRSETALL)}, + {1550, 0xfcffffff, 0x03000000, (OFFSET_SEL | REGCLRSETALL)}, + {83, 0xffc0ffff, 0x70000, (OFFSET_SEL | REGCLRSETALL)}, + {339, 0xffc0ffff, 0x70000, (OFFSET_SEL | REGCLRSETALL)}, + {595, 0xffc0ffff, 0x70000, (OFFSET_SEL | REGCLRSETALL)}, + {851, 0xffc0ffff, 0x70000, (OFFSET_SEL | REGCLRSETALL)}, + {1062, 0xf800ffff, 0x70000, (OFFSET_SEL | REGCLRSETALL)}, + {1318, 0xf800ffff, 0x70000, (OFFSET_SEL | REGCLRSETALL)}, + {1574, 0xf800ffff, 0x70000, (OFFSET_SEL | REGCLRSETALL)}, + {1892, 0xfffc0000, 0x15547, (OFFSET_SEL | REGCLRSETALL)}, + {1893, 0xfffc0000, 0x7, (OFFSET_SEL | REGCLRSETALL)}, + {1852, 0xffffe000, 0x07a, (OFFSET_SEL | REGCLRSETALL)}, + {1853, 0xffffffff, 0x0100, (OFFSET_SEL | REGCLRSETALL)}, + {1822, 0xffffffff, 0xFF, (OFFSET_SEL | REGCLRSETALL)}, + {1896, 0xfffffc00, 0x03d5, (OFFSET_SEL | REGCLRSETALL)}, + {91, 0xfc00ffff, 0x03d50000, (OFFSET_SEL | REGCLRSETALL)}, + {347, 0xfc00ffff, 0x03d50000, (OFFSET_SEL | REGCLRSETALL)}, + {603, 0xfc00ffff, 0x03d50000, (OFFSET_SEL | REGCLRSETALL)}, + {859, 0xfc00ffff, 0x03d50000, (OFFSET_SEL | REGCLRSETALL)}, + {1912, 0x0, 0xcc3bfc7, (OFFSET_SEL | REGSETALL)}, + {1913, 0x0, 0xff8f, (OFFSET_SEL | REGSETALL)}, + {1914, 0x0, 0x33f07ff, (OFFSET_SEL | REGSETALL)}, + {1915, 0x0, 0xc3c37ff, (OFFSET_SEL | REGSETALL)}, + {1916, 0x0, 0x1fffff10, (OFFSET_SEL | REGSETALL)}, + {1917, 0x0, 0x230070, (OFFSET_SEL | REGSETALL)}, + {1918, 0x0, 0x3ff7ffff, (OFFSET_SEL | REG4G | REG2G | F_SET)}, + {1918, 0x0, 0x3ff7ffff, (OFFSET_SEL | REG8G | F_SET)}, + {1919, 0x0, 0xe10, (OFFSET_SEL | REGSETALL)}, + {1920, 0x0, 0x1fffffff, (OFFSET_SEL | REGSETALL)}, + {1921, 0x0, 0x188411, (OFFSET_SEL | REGSETALL)}, + {1922, 0x0, 0x1fffffff, (OFFSET_SEL | REGSETALL)}, + {1923, 0x0, 0x180400, (OFFSET_SEL | REGSETALL)}, + {1924, 0x0, 0x1fffffff, (OFFSET_SEL | REGSETALL)}, + {1925, 0x0, 0x180400, (OFFSET_SEL | REGSETALL)}, + {1926, 0x0, 0x1fffffcf, (OFFSET_SEL | REGSETALL)}, + {1927, 0x0, 0x188400, (OFFSET_SEL | REGSETALL)}, + {1928, 0x0, 0x1fffffff, (OFFSET_SEL | REGSETALL)}, + {1929, 0x0, 0x4188411, (OFFSET_SEL | REGSETALL)}, + {1837, 0x0, 0x24410, (OFFSET_SEL | REGSETALL)}, + {1840, 0x0, 0x24410, (OFFSET_SEL | REGSETALL)}, + {1842, 0x0, 0x2ffff, (OFFSET_SEL | REGSETALL)}, + {76, 0xff0000f8, 0x00ff8f07, (OFFSET_SEL | REGCLRSETALL)}, + {332, 0xff0000f8, 0x00ff8f07, (OFFSET_SEL | REGCLRSETALL)}, + {588, 0xff0000f8, 0x00ff8f07, (OFFSET_SEL | REGCLRSETALL)}, + {844, 0xff0000f8, 0x00ff8f07, (OFFSET_SEL | REGCLRSETALL)}, + {77, 0xffff0000, 0xff8f, (OFFSET_SEL | REGCLRSETALL)}, + {333, 0xffff0000, 0xff8f, (OFFSET_SEL | REGCLRSETALL)}, + {589, 0xffff0000, 0xff8f, (OFFSET_SEL | REGCLRSETALL)}, + {845, 0xffff0000, 0xff8f, (OFFSET_SEL | REGCLRSETALL)}, + {1062, 0xffffff00, 0xff, (OFFSET_SEL | REG4G | REG2G | F_CLRSET)}, + {1318, 0xffffff00, 0xff, (OFFSET_SEL | REG4G | REG2G | F_CLRSET)}, + {1574, 0xffffff00, 0xff, (OFFSET_SEL | REG4G | REG2G | F_CLRSET)}, + {1062, 0xffffff00, 0xfb, (OFFSET_SEL | REG8G | F_CLRSET)}, + {1318, 0xffffff00, 0xfb, (OFFSET_SEL | REG8G | F_CLRSET)}, + {1574, 0xffffff00, 0xfb, (OFFSET_SEL | REG8G | F_CLRSET)}, + {1028, 0xffffffff, 0x1000000, (OFFSET_SEL | REGCLRSETALL)}, + {1284, 0xffffffff, 0x1000000, (OFFSET_SEL | REGCLRSETALL)}, + {1540, 0xffffffff, 0x1000000, (OFFSET_SEL | REGCLRSETALL)}, + {1848, 0x0, 0x3cf07f8, (OFFSET_SEL | REGSETALL)}, + {1849, 0x0, 0x3f, (OFFSET_SEL | REGSETALL)}, + {1850, 0x0, 0x1fffff, (OFFSET_SEL | REGSETALL)}, + {1851, 0x0, 0x060000, (OFFSET_SEL | REGSETALL)}, + {130, 0x0000ffff, 0xffff0000, (OFFSET_SEL | REGCLRSETALL)}, + {386, 0x0000ffff, 0xffff0000, (OFFSET_SEL | REGCLRSETALL)}, + {642, 0x0000ffff, 0xffff0000, (OFFSET_SEL | REGCLRSETALL)}, + {898, 0x0000ffff, 0xffff0000, (OFFSET_SEL | REGCLRSETALL)}, + {131, 0xfffffff0, 0xf, (OFFSET_SEL | REGCLRSETALL)}, + {387, 0xfffffff0, 0xf, (OFFSET_SEL | REGCLRSETALL)}, + {643, 0xfffffff0, 0xf, (OFFSET_SEL | REGCLRSETALL)}, + {899, 0xfffffff0, 0xf, (OFFSET_SEL | REGCLRSETALL)}, + {29, 0xc0ffffff, 0x10000000, (OFFSET_SEL | REGCLRSETALL)}, + {285, 0xc0ffffff, 0x10000000, (OFFSET_SEL | REGCLRSETALL)}, + {541, 0xc0ffffff, 0x10000000, (OFFSET_SEL | REGCLRSETALL)}, + {797, 0xc0ffffff, 0x10000000, (OFFSET_SEL | REGCLRSETALL)}, + {30, 0xffffffff, 0x00080000, (OFFSET_SEL | REGCLRSETALL)}, + {286, 0xffffffff, 0x00080000, (OFFSET_SEL | REGCLRSETALL)}, + {542, 0xffffffff, 0x00080000, (OFFSET_SEL | REGCLRSETALL)}, + {798, 0xffffffff, 0x00080000, (OFFSET_SEL | REGCLRSETALL)}, + {31, 0xffffffc0, 0x00000010, (OFFSET_SEL | REGCLRSETALL)}, + {287, 0xffffffc0, 0x00000010, (OFFSET_SEL | REGCLRSETALL)}, + {543, 0xffffffc0, 0x00000010, (OFFSET_SEL | REGCLRSETALL)}, + {799, 0xffffffc0, 0x00000010, (OFFSET_SEL | REGCLRSETALL)}, + {1071, 0xfffffff0, 0x00000008, (OFFSET_SEL | REGCLRSETALL)}, + {1327, 0xfffffff0, 0x00000008, (OFFSET_SEL | REGCLRSETALL)}, + {1583, 0xfffffff0, 0x00000008, (OFFSET_SEL | REGCLRSETALL)}, + {1808, 0xfffffff0, 0x00000008, (OFFSET_SEL | REGCLRSETALL)}, + {1896, 0xfff0ffff, 0x00080000, (OFFSET_SEL | REGCLRSETALL)}, +}; + +void ddr_reg_set(u32 *reg, const struct ddr_reg_cfg *data, + u32 len, u32 mask) +{ + u32 *addr; + u32 i; + + for (i = 0; i < len; i++) { + if (!(data[i].flag & mask)) + continue; + + if (data[i].flag & OFFSET_SEL) + addr = reg + PHY_AC_BASE_ADDR + data[i].offset; + else + addr = reg + PHY_BASE_ADDR + data[i].offset; + + if (data[i].flag & F_CLRSET) + DDR_REG_TRIGGER(addr, data[i].mask, data[i].val); + else if (data[i].flag & F_SET) + out_le32(addr, data[i].val); + else + out_le32(addr, in_le32(addr) + data[i].val); + } +} + +void ddr_phy_start(u32 *phyreg, enum ddr_size_t size) +{ + u32 len; + u32 mask; + + switch (size) { + case DDR_SIZE_2G: + mask = REG2G; + break; + + case DDR_SIZE_4G: + mask = REG4G; + break; + + case DDR_SIZE_8G: + mask = REG8G; + break; + + case DDR_SIZE_16G: + default: + return; + }; + + len = ARRAY_SIZE(ddr_start_cfg); + ddr_reg_set(phyreg, ddr_start_cfg, len, mask); + out_le32(phyreg, 0x01); +} diff --git a/drivers/ram/starfive/ddrphy_train.c b/drivers/ram/starfive/ddrphy_train.c new file mode 100644 index 0000000000..0740f49be5 --- /dev/null +++ b/drivers/ram/starfive/ddrphy_train.c @@ -0,0 +1,383 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wangyanhong.wang@starfivetech.com + */ + +#include <common.h> +#include <asm/io.h> + +static const u32 ddr_train_data[] = { + 0xb00, + 0x101, + 0x640000, + 0x1, + 0x0, + 0x0, + 0x0, + 0x0, + 0x1, + 0x7, + 0x10002, + 0x300080f, + 0x1, + 0x5, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x1010000, + 0x280a0000, + 0x0, + 0x1, + 0x3200000f, + 0x0, + 0x0, + 0x10102, + 0x1, + 0x0, + 0x0, + 0x0, + 0xaa, + 0x55, + 0xb5, + 0x4a, + 0x56, + 0xa9, + 0xa9, + 0xb5, + 0x1000000, + 0x1000000, + 0x0, + 0xf0f0000, + 0x14, + 0x7d0, + 0x300, + 0x0, + 0x0, + 0x1000000, + 0x10101, + 0x0, + 0x30000, + 0x100, + 0x170f, + 0x0, + 0x0, + 0x0, + 0xa140a01, + 0x204010a, + 0x2080510, + 0x40400, + 0x1000101, + 0x10100, + 0x2040f00, + 0x34000000, + 0x0, + 0x0, + 0x1000000, + 0x0, + 0x0, + 0x0, + 0x0, + 0x10100, + 0x80101, + 0x2000200, + 0x1000100, + 0x1000000, + 0x2000200, + 0x200, + 0x0, + 0x0, + 0x0, + 0xe000004, + 0xc0d100f, + 0xa09080b, + 0x2010000, + 0x80103, + 0x200, + 0x0, + 0xf000000, + 0x4, + 0xa, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x30100, + 0x1010001, + 0x10200, + 0x4000103, + 0x1050001, + 0x10600, + 0x107, + 0x0, + 0x0, + 0x10001, + 0x0, + 0x0, + 0x0, + 0x0, + 0x10000, + 0x4, + 0x0, + 0x10000, + 0x0, + 0x3c0003, + 0x80100a0, + 0x16, + 0x2c, + 0x33, + 0x20043, + 0x2000200, + 0x4, + 0x60c, + 0xa1400, + 0x280000, + 0x6, + 0x46, + 0x70, + 0x610, + 0x12b, + 0x4001035, + 0x1010404, + 0x1e01, + 0x1e001e, + 0x1000100, + 0x100, + 0x0, + 0x5060403, + 0x1011108, + 0x1010101, + 0xf0a0a, + 0x0, + 0x0, + 0x4000000, + 0x4021008, + 0x4020206, + 0xc0034, + 0x100038, + 0x17003f, + 0x10001, + 0x10001, + 0x10005, + 0x20064, + 0x100010b, + 0x60006, + 0x650100, + 0x1000065, + 0x10c010c, + 0x1e1a1e1a, + 0x1011e1a, + 0xa070601, + 0xa07060d, + 0x100b080d, + 0xc00f, + 0xc01000, + 0xc01000, + 0x21000, + 0x120005, + 0x190064, + 0x10b, + 0x1100, + 0x1e1a0056, + 0x6000101, + 0x130204, + 0x1e1a0058, + 0x1000101, + 0x230408, + 0x1e1a005e, + 0x9000101, + 0x610, + 0x4040800, + 0x40100, + 0x3000277, + 0xa032001, + 0xa0a, + 0x80908, + 0x901, + 0x1100315c, + 0xa062002, + 0xa0a, + 0x141708, + 0x150d, + 0x2d00838e, + 0xf102004, + 0xf0b, + 0x8c, + 0x578, + 0xc20, + 0x7940, + 0x206a, + 0x14424, + 0x730006, + 0x3030133, + 0x4, + 0x0, + 0x4, + 0x1, + 0x5, + 0x2, + 0x6, + 0x50, + 0x1, + 0x5, + 0x28, + 0x73, + 0xd6, + 0x1, + 0x5, + 0x6b, + 0x1000133, + 0x140040, + 0x10001, + 0x1900040, + 0x1000c, + 0x42b0040, + 0x320, + 0x360014, + 0x1010101, + 0x2020101, + 0x8080404, + 0x67676767, + 0x67676767, + 0x67676767, + 0x67676767, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x5500, + 0x5a00, + 0x55003c, + 0x0, + 0x3c00005a, + 0x5500, + 0x5a00, + 0x55003c, + 0x0, + 0x3c00005a, + 0x18171615, + 0x14131211, + 0x7060504, + 0x3020100, + 0x0, + 0x0, + 0x0, + 0x1000000, + 0x4020201, + 0x80804, + 0x0, + 0x4, + 0x0, + 0x31, + 0x31, + 0x0, + 0x0, + 0x4d4d, + 0x0, + 0x14, + 0x9, + 0x31, + 0x31, + 0x0, + 0x0, + 0x4d4d, + 0x0, + 0x34, + 0x1b, + 0x31, + 0x31, + 0x0, + 0x0, + 0x4d4d, + 0x0, + 0x4, + 0x0, + 0x31, + 0x31, + 0x0, + 0x0, + 0x4d4d, + 0x0, + 0x14, + 0x9, + 0x31, + 0x31, + 0x0, + 0x0, + 0x4d4d, + 0x0, + 0x34, + 0x1b, + 0x31, + 0x31, + 0x0, + 0x0, + 0x4d4d, + 0x0, + 0x4, + 0x0, + 0x31, + 0x31, + 0x0, + 0x0, + 0x4d4d, + 0x0, + 0x14, + 0x9, + 0x31, + 0x31, + 0x0, + 0x0, + 0x4d4d, + 0x0, + 0x34, + 0x1b, + 0x31, + 0x31, + 0x0, + 0x0, + 0x4d4d, + 0x0, + 0x4, + 0x0, + 0x31, + 0x31, + 0x0, + 0x0, + 0x4d4d, + 0x0, + 0x14, + 0x9, + 0x31, + 0x31, + 0x0, + 0x0, + 0x4d4d, + 0x0, + 0x34, + 0x1b, + 0x31, + 0x31, + 0x0, + 0x0, + 0x4d4d, +}; + +void ddr_phy_train(u32 *phyreg) +{ + u32 i, len; + + len = ARRAY_SIZE(ddr_train_data); + for (i = 0; i < len; i++) + out_le32(phyreg + i, ddr_train_data[i]); +} diff --git a/drivers/ram/starfive/ddrphy_utils.c b/drivers/ram/starfive/ddrphy_utils.c new file mode 100644 index 0000000000..1c9fe0a784 --- /dev/null +++ b/drivers/ram/starfive/ddrphy_utils.c @@ -0,0 +1,1955 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wangyanhong.wang@starfivetech.com + */ + +#include <common.h> +#include <asm/io.h> + +static const u32 ddr_phy_data[] = { + 0x4f0, + 0x0, + 0x1030200, + 0x0, + 0x0, + 0x3000000, + 0x1000001, + 0x3000400, + 0x1000001, + 0x0, + 0x0, + 0x1000001, + 0x0, + 0xc00004, + 0xcc0008, + 0x660601, + 0x3, + 0x0, + 0x1, + 0xaaaa, + 0x5555, + 0xb5b5, + 0x4a4a, + 0x5656, + 0xa9a9, + 0xa9a9, + 0xb5b5, + 0x0, + 0x0, + 0x8000000, + 0x4000008, + 0x408, + 0xe4e400, + 0x71020, + 0xc0020, + 0x620, + 0x100, + 0x55555555, + 0xaaaaaaaa, + 0x55555555, + 0xaaaaaaaa, + 0x5555, + 0x1000100, + 0x800180, + 0x1, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x4, + 0x20, + 0x0, + 0x0, + 0x0, + 0x0, + 0x7ff0000, + 0x20008008, + 0x810, + 0x40100, + 0x0, + 0x1880c01, + 0x2003880c, + 0x20000125, + 0x7ff0200, + 0x101, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x20000, + 0x51515052, + 0x31c06000, + 0x11f0004, + 0xc0c001, + 0x3000000, + 0x30202, + 0x42100010, + 0x10c053e, + 0xf0c20, + 0x1000140, + 0xa30120, + 0xc00, + 0x210, + 0x200, + 0x2800000, + 0x80800101, + 0x3, + 0x76543210, + 0x8, + 0x2800280, + 0x2800280, + 0x2800280, + 0x2800280, + 0x280, + 0x8000, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x6e0080, + 0x1a00003, + 0x0, + 0x30000, + 0x80200, + 0x0, + 0x20202020, + 0x20202020, + 0x2020, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x4f0, + 0x0, + 0x1030200, + 0x0, + 0x0, + 0x3000000, + 0x1000001, + 0x3000400, + 0x1000001, + 0x0, + 0x0, + 0x1000001, + 0x0, + 0xc00004, + 0xcc0008, + 0x660601, + 0x3, + 0x0, + 0x1, + 0xaaaa, + 0x5555, + 0xb5b5, + 0x4a4a, + 0x5656, + 0xa9a9, + 0xa9a9, + 0xb5b5, + 0x0, + 0x0, + 0x8000000, + 0x4000008, + 0x408, + 0xe4e400, + 0x71020, + 0xc0020, + 0x620, + 0x100, + 0x55555555, + 0xaaaaaaaa, + 0x55555555, + 0xaaaaaaaa, + 0x5555, + 0x1000100, + 0x800180, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x4, + 0x20, + 0x0, + 0x0, + 0x0, + 0x0, + 0x7ff0000, + 0x20008008, + 0x810, + 0x40100, + 0x0, + 0x1880c01, + 0x2003880c, + 0x20000125, + 0x7ff0200, + 0x101, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x20000, + 0x51515052, + 0x31c06000, + 0x11f0004, + 0xc0c001, + 0x3000000, + 0x30202, + 0x42100010, + 0x10c053e, + 0xf0c20, + 0x1000140, + 0xa30120, + 0xc00, + 0x210, + 0x200, + 0x2800000, + 0x80800101, + 0x3, + 0x76543210, + 0x8, + 0x2800280, + 0x2800280, + 0x2800280, + 0x2800280, + 0x280, + 0x8000, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x6e0080, + 0x1a00003, + 0x0, + 0x30000, + 0x80200, + 0x0, + 0x20202020, + 0x20202020, + 0x2020, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x4f0, + 0x0, + 0x1030200, + 0x0, + 0x0, + 0x3000000, + 0x1000001, + 0x3000400, + 0x1000001, + 0x0, + 0x0, + 0x1000001, + 0x0, + 0xc00004, + 0xcc0008, + 0x660601, + 0x3, + 0x0, + 0x1, + 0xaaaa, + 0x5555, + 0xb5b5, + 0x4a4a, + 0x5656, + 0xa9a9, + 0xa9a9, + 0xb5b5, + 0x0, + 0x0, + 0x8000000, + 0x4000008, + 0x408, + 0xe4e400, + 0x71020, + 0xc0020, + 0x620, + 0x100, + 0x55555555, + 0xaaaaaaaa, + 0x55555555, + 0xaaaaaaaa, + 0x5555, + 0x1000100, + 0x800180, + 0x1, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x4, + 0x20, + 0x0, + 0x0, + 0x0, + 0x0, + 0x7ff0000, + 0x20008008, + 0x810, + 0x40100, + 0x0, + 0x1880c01, + 0x2003880c, + 0x20000125, + 0x7ff0200, + 0x101, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x20000, + 0x51515052, + 0x31c06000, + 0x11f0004, + 0xc0c001, + 0x3000000, + 0x30202, + 0x42100010, + 0x10c053e, + 0xf0c20, + 0x1000140, + 0xa30120, + 0xc00, + 0x210, + 0x200, + 0x2800000, + 0x80800101, + 0x3, + 0x76543210, + 0x8, + 0x2800280, + 0x2800280, + 0x2800280, + 0x2800280, + 0x280, + 0x8000, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x6e0080, + 0x1a00003, + 0x0, + 0x30000, + 0x80200, + 0x0, + 0x20202020, + 0x20202020, + 0x2020, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x4f0, + 0x0, + 0x1030200, + 0x0, + 0x0, + 0x3000000, + 0x1000001, + 0x3000400, + 0x1000001, + 0x0, + 0x0, + 0x1000001, + 0x0, + 0xc00004, + 0xcc0008, + 0x660601, + 0x3, + 0x0, + 0x1, + 0xaaaa, + 0x5555, + 0xb5b5, + 0x4a4a, + 0x5656, + 0xa9a9, + 0xa9a9, + 0xb5b5, + 0x0, + 0x0, + 0x8000000, + 0x4000008, + 0x408, + 0xe4e400, + 0x71020, + 0xc0020, + 0x620, + 0x100, + 0x55555555, + 0xaaaaaaaa, + 0x55555555, + 0xaaaaaaaa, + 0x5555, + 0x1000100, + 0x800180, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x4, + 0x20, + 0x0, + 0x0, + 0x0, + 0x0, + 0x7ff0000, + 0x20008008, + 0x810, + 0x40100, + 0x0, + 0x1880c01, + 0x2003880c, + 0x20000125, + 0x7ff0200, + 0x101, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x20000, + 0x51515052, + 0x31c06000, + 0x11f0004, + 0xc0c001, + 0x3000000, + 0x30202, + 0x42100010, + 0x10c053e, + 0xf0c20, + 0x1000140, + 0xa30120, + 0xc00, + 0x210, + 0x200, + 0x2800000, + 0x80800101, + 0x3, + 0x76543210, + 0x8, + 0x2800280, + 0x2800280, + 0x2800280, + 0x2800280, + 0x280, + 0x8000, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x800080, + 0x6e0080, + 0x1a00003, + 0x0, + 0x30000, + 0x80200, + 0x0, + 0x20202020, + 0x20202020, + 0x2020, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x100, + 0x200, + 0x0, + 0x0, + 0x0, + 0x0, + 0x400000, + 0x80, + 0xdcba98, + 0x3000000, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x2a, + 0x15, + 0x15, + 0x2a, + 0x33, + 0xc, + 0xc, + 0x33, + 0xa418820, + 0x3f0000, + 0x13f, + 0x20202000, + 0x202020, + 0x20008008, + 0x810, + 0x0, + 0x255, + 0x30000, + 0x300, + 0x300, + 0x300, + 0x300, + 0x300, + 0x42080010, + 0x33e, + 0x1010002, + 0x80, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x100, + 0x200, + 0x0, + 0x0, + 0x0, + 0x0, + 0x400000, + 0x80, + 0xdcba98, + 0x3000000, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x2a, + 0x15, + 0x15, + 0x2a, + 0x33, + 0xc, + 0xc, + 0x33, + 0x0, + 0x0, + 0x0, + 0x20202000, + 0x202020, + 0x20008008, + 0x810, + 0x0, + 0x255, + 0x30000, + 0x300, + 0x300, + 0x300, + 0x300, + 0x300, + 0x42080010, + 0x33e, + 0x1010002, + 0x80, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x100, + 0x200, + 0x0, + 0x0, + 0x0, + 0x0, + 0x400000, + 0x80, + 0xdcba98, + 0x3000000, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x2a, + 0x15, + 0x15, + 0x2a, + 0x33, + 0xc, + 0xc, + 0x33, + 0x0, + 0x10000000, + 0x0, + 0x20202000, + 0x202020, + 0x20008008, + 0x810, + 0x0, + 0x255, + 0x30000, + 0x300, + 0x300, + 0x300, + 0x300, + 0x300, + 0x42080010, + 0x33e, + 0x1010002, + 0x80, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x100, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x50000, + 0x4000000, + 0x55, + 0x0, + 0x0, + 0x0, + 0xf0001, + 0x280040, + 0x5002, + 0x10101, + 0x8008, + 0x81020, + 0x0, + 0x0, + 0x1000000, + 0x1, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x64, + 0x0, + 0x0, + 0x1010000, + 0x2020101, + 0x4040202, + 0x8080404, + 0xf0f0808, + 0xf0f0f0f, + 0x20200f0f, + 0x1b428000, + 0x4, + 0x1010000, + 0x1070501, + 0x54, + 0x4410, + 0x4410, + 0x4410, + 0x4410, + 0x4410, + 0x4410, + 0x4410, + 0x4410, + 0x4410, + 0x4410, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x64, + 0x0, + 0x108, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x3000000, + 0x0, + 0x0, + 0x0, + 0x4102035, + 0x41020, + 0x1c98c98, + 0x3f400000, + 0x3f3f1f3f, + 0x1f3f3f1f, + 0x1f3f3f, + 0x0, + 0x0, + 0x1, + 0x0, + 0x0, + 0x0, + 0x0, + 0x76543210, + 0x6010198, + 0x0, + 0x0, + 0x0, + 0x40700, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x2, + 0x0, + 0x0, + 0x0, + 0x0, + 0x0, + 0x1142, + 0x3020100, + 0x3000300, + 0x3000300, + 0x3000300, + 0x3000300, + 0x3000300, + 0x3000300, + 0x3000300, + 0x3000300, + 0x3000300, + 0x3000300, + 0x300, + 0x300, + 0x300, + 0x300, + 0x2, + 0x4011, + 0x4011, + 0x40, + 0x40, + 0x4011, + 0x1fff00, + 0x4011, + 0x4011, + 0x4011, + 0x4011, + 0x4011, + 0x4011, + 0x4011, + 0x4011, + 0x4011, + 0x4011, + 0x4011, + 0x1004011, + 0x200400, + +}; + +void ddr_phy_util(u32 *phyreg) +{ + u32 i, len; + + len = ARRAY_SIZE(ddr_phy_data); + for (i = 1792; i < len; i++) + out_le32(phyreg + i, ddr_phy_data[i]); + + for (i = 0; i < 1792; i++) + out_le32(phyreg + i, ddr_phy_data[i]); +} diff --git a/drivers/ram/starfive/starfive_ddr.c b/drivers/ram/starfive/starfive_ddr.c new file mode 100644 index 0000000000..553f2ce6f4 --- /dev/null +++ b/drivers/ram/starfive/starfive_ddr.c @@ -0,0 +1,161 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wangyanhong.wang@starfivetech.com + */ + +#include <common.h> +#include <asm/arch/regs.h> +#include <asm/io.h> +#include <clk.h> +#include <dm.h> +#include <fdtdec.h> +#include <init.h> +#include <linux/bitops.h> +#include <linux/sizes.h> +#include <linux/delay.h> +#include <ram.h> +#include <reset.h> + +#include "starfive_ddr.h" + +DECLARE_GLOBAL_DATA_PTR; + +struct starfive_ddr_priv { + struct udevice *dev; + struct ram_info info; + void __iomem *ctrlreg; + void __iomem *phyreg; + struct reset_ctl_bulk rst; + struct clk clk; + u32 fre; +}; + +static int starfive_ddr_setup(struct udevice *dev, struct starfive_ddr_priv *priv) +{ + enum ddr_size_t size; + + switch (priv->info.size) { + case SZ_2G: + size = DDR_SIZE_2G; + break; + + case SZ_4G: + size = DDR_SIZE_4G; + break; + + case 0x200000000: + size = DDR_SIZE_8G; + break; + + case 0x400000000: + default: + pr_err("unsupport size %lx\n", priv->info.size); + return -EINVAL; + } + + ddr_phy_train(priv->phyreg + (PHY_BASE_ADDR << 2)); + ddr_phy_util(priv->phyreg + (PHY_AC_BASE_ADDR << 2)); + ddr_phy_start(priv->phyreg, size); + + DDR_REG_SET(BUS, DDR_BUS_OSC_DIV2); + ddrcsr_boot(priv->ctrlreg, priv->ctrlreg + SEC_CTRL_ADDR, + priv->phyreg, size); + + return 0; +} + +static int starfive_ddr_probe(struct udevice *dev) +{ + struct starfive_ddr_priv *priv = dev_get_priv(dev); + fdt_addr_t addr; + u64 rate; + int ret; + + /* Read memory base and size from DT */ + fdtdec_setup_mem_size_base(); + priv->info.base = gd->ram_base; + priv->info.size = gd->ram_size; + + priv->dev = dev; + addr = dev_read_addr_index(dev, 0); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->ctrlreg = (void __iomem *)addr; + addr = dev_read_addr_index(dev, 1); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->phyreg = (void __iomem *)addr; + ret = dev_read_u32(dev, "clock-frequency", &priv->fre); + if (ret) + return ret; + + switch (priv->fre) { + case 2133: + rate = 1066000000; + break; + + case 2800: + rate = 1400000000; + break; + + default: + pr_err("Unknown DDR frequency %d\n", priv->fre); + return -EINVAL; + }; + + ret = reset_get_bulk(dev, &priv->rst); + if (ret) + return ret; + + ret = reset_deassert_bulk(&priv->rst); + if (ret < 0) + return ret; + + ret = clk_get_by_index(dev, 0, &priv->clk); + if (ret) + goto err_free_reset; + + ret = clk_set_rate(&priv->clk, rate); + if (ret < 0) + goto err_free_reset; + + ret = starfive_ddr_setup(dev, priv); + printf("DDR version: dc2e84f0.\n"); + + return ret; + +err_free_reset: + reset_release_bulk(&priv->rst); + + return ret; +} + +static int starfive_ddr_get_info(struct udevice *dev, struct ram_info *info) +{ + struct starfive_ddr_priv *priv = dev_get_priv(dev); + + *info = priv->info; + + return 0; +} + +static struct ram_ops starfive_ddr_ops = { + .get_info = starfive_ddr_get_info, +}; + +static const struct udevice_id starfive_ddr_ids[] = { + { .compatible = "starfive,jh7110-dmc" }, + { } +}; + +U_BOOT_DRIVER(starfive_ddr) = { + .name = "starfive_ddr", + .id = UCLASS_RAM, + .of_match = starfive_ddr_ids, + .ops = &starfive_ddr_ops, + .probe = starfive_ddr_probe, + .priv_auto = sizeof(struct starfive_ddr_priv), +}; diff --git a/drivers/ram/starfive/starfive_ddr.h b/drivers/ram/starfive/starfive_ddr.h new file mode 100644 index 0000000000..d0ec1c1da8 --- /dev/null +++ b/drivers/ram/starfive/starfive_ddr.h @@ -0,0 +1,65 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wangyanhong.wang@starfivetech.com + */ + +#ifndef __STARFIVE_DDR_H__ +#define __STARFIVE_DDR_H__ + +#define SEC_CTRL_ADDR 0x1000 +#define PHY_BASE_ADDR 0x800 +#define PHY_AC_BASE_ADDR 0x1000 + +#define DDR_BUS_MASK GENMASK(29, 24) +#define DDR_AXI_MASK BIT(31) +#define DDR_BUS_OFFSET 0xAC +#define DDR_AXI_OFFSET 0xB0 + +#define DDR_BUS_OSC_DIV2 0 +#define DDR_BUS_PLL1_DIV2 1 +#define DDR_BUS_PLL1_DIV4 2 +#define DDR_BUS_PLL1_DIV8 3 +#define DDR_AXI_DISABLE 0 +#define DDR_AXI_ENABLE 1 + +#define OFFSET_SEL BIT(31) +#define REG2G BIT(30) +#define REG4G BIT(29) +#define REG8G BIT(28) +#define F_ADDSET BIT(2) +#define F_SET BIT(1) +#define F_CLRSET BIT(0) +#define REGALL (REG2G | REG4G | REG8G) +#define REGSETALL (F_SET | REGALL) +#define REGCLRSETALL (F_CLRSET | REGALL) +#define REGADDSETALL (F_ADDSET | REGALL) + +struct ddr_reg_cfg { + u32 offset; + u32 mask; + u32 val; + u32 flag; +}; + +enum ddr_size_t { + DDR_SIZE_2G, + DDR_SIZE_4G, + DDR_SIZE_8G, + DDR_SIZE_16G, +}; + +void ddr_phy_train(u32 *phyreg); +void ddr_phy_util(u32 *phyreg); +void ddr_phy_start(u32 *phyreg, enum ddr_size_t size); +void ddrcsr_boot(u32 *csrreg, u32 *secreg, u32 *phyreg, enum ddr_size_t size); + +#define DDR_REG_TRIGGER(addr, mask, value) \ + out_le32((addr), (in_le32(addr) & (mask)) | (value)) + +#define DDR_REG_SET(type, val) \ + clrsetbits_le32(JH7110_SYS_CRG + DDR_##type##_OFFSET, \ + DDR_##type##_MASK, \ + ((val) << __ffs(DDR_##type##_MASK)) & DDR_##type##_MASK) + +#endif /*__STARFIVE_DDR_H__*/
Add board support for StarFive VisionFive v2.
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- board/starfive/visionfive2/MAINTAINERS | 7 + board/starfive/visionfive2/Makefile | 7 + board/starfive/visionfive2/spl.c | 87 ++++ .../visionfive2/starfive_visionfive2.c | 38 ++ doc/board/starfive/index.rst | 9 + doc/board/starfive/visionfive2.rst | 492 ++++++++++++++++++ include/configs/starfive-visionfive2.h | 49 ++ 7 files changed, 689 insertions(+) create mode 100644 board/starfive/visionfive2/MAINTAINERS create mode 100644 board/starfive/visionfive2/Makefile create mode 100644 board/starfive/visionfive2/spl.c create mode 100644 board/starfive/visionfive2/starfive_visionfive2.c create mode 100644 doc/board/starfive/index.rst create mode 100644 doc/board/starfive/visionfive2.rst create mode 100644 include/configs/starfive-visionfive2.h
diff --git a/board/starfive/visionfive2/MAINTAINERS b/board/starfive/visionfive2/MAINTAINERS new file mode 100644 index 0000000000..c5369086d8 --- /dev/null +++ b/board/starfive/visionfive2/MAINTAINERS @@ -0,0 +1,7 @@ +STARFIVE JH7110 VISIONFIVE2 BOARD +M: startfive +S: Maintained +F: arch/riscv/include/asm/arch-jh7110/ +F: board/starfive/visionfive2/ +F: include/configs/starfive-visionfive2.h +F: configs/starfive_visionfive2_defconfig diff --git a/board/starfive/visionfive2/Makefile b/board/starfive/visionfive2/Makefile new file mode 100644 index 0000000000..66c854df39 --- /dev/null +++ b/board/starfive/visionfive2/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2022 StarFive Technology Co., Ltd. +# + +obj-y := starfive_visionfive2.o +obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/board/starfive/visionfive2/spl.c b/board/starfive/visionfive2/spl.c new file mode 100644 index 0000000000..db0b4cb433 --- /dev/null +++ b/board/starfive/visionfive2/spl.c @@ -0,0 +1,87 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wangyanhong.wang@starfivetech.com + */ + +#include <common.h> +#include <asm/arch/regs.h> +#include <asm/arch/spl.h> +#include <asm/io.h> +#include <log.h> +#include <spl.h> + +#define JH7110_CLK_CPU_ROOT_OFFSET 0x0U +#define JH7110_CLK_CPU_ROOT_SHIFT 24 +#define JH7110_CLK_CPU_ROOT_MASK GENMASK(29, 24) + +int spl_board_init_f(void) +{ + int ret; + + ret = spl_soc_init(); + if (ret) { + debug("JH7110 SPL init failed: %d\n", ret); + return ret; + } + + return 0; +} + +u32 spl_boot_device(void) +{ + u32 mode; + + mode = in_le32(JH7110_BOOT_MODE_SELECT_REG) + & JH7110_BOOT_MODE_SELECT_MASK; + switch (mode) { + case 0: + return BOOT_DEVICE_SPI; + + case 1: + return BOOT_DEVICE_MMC2; + + case 2: + return BOOT_DEVICE_MMC1; + + case 3: + return BOOT_DEVICE_UART; + + default: + debug("Unsupported boot device 0x%x.\n", mode); + return BOOT_DEVICE_NONE; + } +} + +void board_init_f(ulong dummy) +{ + int ret; + + ret = spl_early_init(); + if (ret) + panic("spl_early_init() failed: %d\n", ret); + + riscv_cpu_setup(NULL, NULL); + preloader_console_init(); + + /* Set the parent clock of cpu_root clock to pll0, + * it must be initialized here + */ + clrsetbits_le32(JH7110_SYS_CRG + JH7110_CLK_CPU_ROOT_OFFSET, + JH7110_CLK_CPU_ROOT_MASK, + BIT(JH7110_CLK_CPU_ROOT_SHIFT)); + + ret = spl_board_init_f(); + if (ret) { + debug("spl_board_init_f init failed: %d\n", ret); + return; + } +} + +#if CONFIG_IS_ENABLED(SPL_LOAD_FIT) +int board_fit_config_name_match(const char *name) +{ + /* boot using first FIT config */ + return 0; +} +#endif diff --git a/board/starfive/visionfive2/starfive_visionfive2.c b/board/starfive/visionfive2/starfive_visionfive2.c new file mode 100644 index 0000000000..57f1b6ea5d --- /dev/null +++ b/board/starfive/visionfive2/starfive_visionfive2.c @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wangyanhong.wang@starfivetech.com + */ + +#include <common.h> +#include <asm/io.h> +#include <linux/bitops.h> + +#define JH7110_L2_PREFETCHER_BASE_ADDR 0x2030000 +#define JH7110_L2_PREFETCHER_HART_OFFSET 0x2000 + +/* enable U74-mc hart1~hart4 prefetcher */ +static void enable_prefetcher(void) +{ + u8 hart; + u32 *reg; + + /* JH7110 use U74MC CORE IP, it include five cores(one S7 and four U7), + * but only U7 cores support prefetcher configuration + */ + for (hart = 1; hart < 5; hart++) { + reg = (void *)(u64)(JH7110_L2_PREFETCHER_BASE_ADDR + + hart * JH7110_L2_PREFETCHER_HART_OFFSET); + + mb(); /* memory barrier */ + setbits_le32(reg, 0x1); + mb(); /* memory barrier */ + } +} + +int board_init(void) +{ + enable_prefetcher(); + + return 0; +} diff --git a/doc/board/starfive/index.rst b/doc/board/starfive/index.rst new file mode 100644 index 0000000000..420433ea30 --- /dev/null +++ b/doc/board/starfive/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +StarFive +====== + +.. toctree:: + :maxdepth: 1 + + visionfive2 diff --git a/doc/board/starfive/visionfive2.rst b/doc/board/starfive/visionfive2.rst new file mode 100644 index 0000000000..155358d29e --- /dev/null +++ b/doc/board/starfive/visionfive2.rst @@ -0,0 +1,492 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +StarFive VisionFive2 +================ + +JH7110 RISC-V SoC +--------------------- +The JH7110 is 4+1 64-bit RISC-V SoC from StarFive. + +The StarFive VisionFive2 development platform is based on JH7110 and capable +of running Linux. + +Mainline support +---------------- + +The support for following drivers are already enabled: + +1. ns16550 UART Driver. +2. StarFive JH7110 clock Driver. +3. StarFive JH7110 reset Driver. +4. Cadence QSPI controller Driver. +5. MMC SPI Driver for MMC/SD support. + +Booting from MMC using U-Boot SPL +--------------------------- + +The current U-Boot port is supported in S-mode only and loaded from DRAM. + +A prior stage M-mode firmware/bootloader (e.g OpenSBI) is required to +boot the u-boot.itb in S-mode and provide M-mode runtime services. + +Currently, the u-boot.itb is used as a dynamic of the OpenSBI FW_DYNAMIC +firmware with the latest. + +Building +~~~~~~~~ + +1. Add the RISC-V toolchain to your PATH. +2. Setup ARCH & cross compilation environment variable: + +.. code-block:: none + + export CROSS_COMPILE=<riscv64 toolchain prefix> + +Before building U-Boot SPL, OpenSBI must be built first. OpenSBI can be +cloned and built for JH7110 as below: + +.. code-block:: console + + git clone https://github.com/riscv/opensbi.git + cd opensbi + make PLATFORM=generic FW_TEXT_START=0x40000000 FW_OPTIONS=0 + +More detailed description of steps required to build FW_DYNAMIC firmware +is beyond the scope of this document. Please refer OpenSBI documenation. +(Note: OpenSBI git repo is at https://github.com/riscv/opensbi.git) + +Now build the U-Boot SPL and U-Boot proper + +.. code-block:: console + + cd <U-Boot-dir> + make starfive_visionfive2_defconfig + make OPENSBI=$(opensbi_dir)/opensbi/build/platform/generic/firmware/fw_dynamic.bin + +This will generate spl/u-boot-spl.bin and FIT image (u-boot.itb) + +u-boot-spl.bin cannot be used directly on StarFive VisionFive2,we need +to convert the u-boot-spl.bin to u-boot-spl.bin.normal.out with +the below command: + + ./spl_tool -c -f $(Uboot_PATH)/spl/u-boot-spl.bin + +More detailed description of spl_tool,please refer spl_tool documenation. +(Note: spl_tool git repo is at https://github.com/starfive-tech/Tools/tree/master/spl_tool) + +This will generate u-boot-spl.bin.normal.out file. + +Flashing +~~~~~~~~ + +SPL loads the U-Boot SPL (u-boot-spl.bin.normal.out) from a partition with GUID type +2E54B353-1271-4842-806F-E436D6AF6985 + +U-Boot SPL expects a U-Boot FIT image (u-boot.itb) from a partition with GUID +type BC13C2FF-59E6-4262-A352-B275FD6F7172 + +FIT image (u-boot.itb) is a combination of fw_dynamic.bin, u-boot-nodtb.bin and +device tree blob (jh7110-starfive-visionfive-2-v1.3b.dtb/jh7110-starfive-visionfive-2-v1.2a.dtb) + +Format the SD card (make sure the disk has GPT, otherwise use gdisk to switch) + +.. code-block:: bash + + sudo sgdisk --clear \ + --set-alignment=2 \ + --new=1:4096:8191 --change-name=1:spl --typecode=1:2E54B353-1271-4842-806F-E436D6AF6985\ + --new=2:8192:16383 --change-name=2:uboot --typecode=2:BC13C2FF-59E6-4262-A352-B275FD6F7172 \ + --new=3:16384:1654784 --change-name=3:system --typecode=3:EBD0A0A2-B9E5-4433-87C0-68B6B72699C7 \ + /dev/sdb + +Program the SD card + +.. code-block:: bash + + sudo dd if=u-boot-spl.bin.normal.out of=/dev/sdb1 + sudo dd if=u-boot.itb of=/dev/sdb2 + + sudo mount /dev/sdb3 /mnt/ + sudo cp u-boot-spl.bin.normal.out /mnt/ + sudo cp u-boot.itb /mnt/ + sudo cp Image.gz /mnt/ + sudo cp initramfs.cpio.gz /mnt/ + sudo cp jh7110-starfive-visionfive-2-v1.3b.dtb /mnt/ + sudo umount /mnt + +Booting +~~~~~~~ + +Change DIP switches MSEL[1:0] are set to 10, select the boot mode to SD. +Once you plugin the sdcard and power up, you should see the U-Boot prompt. + +Sample boot log from StarFive VisionFive2 board +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + +.. code-block:: none + + + U-Boot SPL 2023.04-rc2-00055-gfc43b9c51a-dirty (Mar 02 2023 - 10:51:39 +0800) + DDR version: dc2e84f0. + Trying to boot from MMC2 + + OpenSBI v1.2-80-g4b28afc + ____ _____ ____ _____ + / __ \ / ____| _ _ _| + | | | |_ __ ___ _ __ | (___ | |_) || | + | | | | '_ \ / _ \ '_ \ ___ | _ < | | + | |__| | |_) | __/ | | |____) | |_) || |_ + ____/| .__/ ___|_| |_|_____/|___/_____| + | | + |_| + + Platform Name : StarFive VisionFive 2 v1.3B + Platform Features : medeleg + Platform HART Count : 5 + Platform IPI Device : aclint-mswi + Platform Timer Device : aclint-mtimer @ 4000000Hz + Platform Console Device : uart8250 + Platform HSM Device : --- + Platform PMU Device : --- + Platform Reboot Device : --- + Platform Shutdown Device : --- + Platform Suspend Device : --- + Firmware Base : 0x40000000 + Firmware Size : 264 KB + Firmware RW Offset : 0x20000 + Runtime SBI Version : 1.0 + + Domain0 Name : root + Domain0 Boot HART : 2 + Domain0 HARTs : 0*,1*,2*,3*,4* + Domain0 Region00 : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: () + Domain0 Region01 : 0x0000000040000000-0x000000004001ffff M: (R,X) S/U: () + Domain0 Region02 : 0x0000000040000000-0x000000004007ffff M: (R,W) S/U: () + Domain0 Region03 : 0x0000000000000000-0xffffffffffffffff M: (R,W,X) S/U: (R,W,X) + Domain0 Next Address : 0x0000000040200000 + Domain0 Next Arg1 : 0x0000000040287970 + Domain0 Next Mode : S-mode + Domain0 SysReset : yes + Domain0 SysSuspend : yes + + Boot HART ID : 2 + Boot HART Domain : root + Boot HART Priv Version : v1.11 + Boot HART Base ISA : rv64imafdcbx + Boot HART ISA Extensions : none + Boot HART PMP Count : 8 + Boot HART PMP Granularity : 4096 + Boot HART PMP Address Bits: 34 + Boot HART MHPM Count : 2 + Boot HART MIDELEG : 0x0000000000000222 + Boot HART MEDELEG : 0x000000000000b109 + + + U-Boot 2023.04-rc2-00055-gfc43b9c51a-dirty (Mar 02 2023 - 10:51:39 +0800) + + CPU: rv64imac_zba_zbb + Model: StarFive VisionFive 2 v1.3B + DRAM: 8 GiB + Core: 107 devices, 18 uclasses, devicetree: separate + MMC: mmc@16010000: 0, mmc@16020000: 1 + Loading Environment from nowhere... OK + In: serial@10000000 + Out: serial@10000000 + Err: serial@10000000 + Net: No ethernet found. + Working FDT set to ff74a340 + Hit any key to stop autoboot: 0 + StarFive # + StarFive #version + U-Boot 2023.04-rc2-00055-gfc43b9c51a-dirty (Mar 02 2023 - 10:51:39 +0800) + + riscv64-buildroot-linux-gnu-gcc.br_real (Buildroot VF2_515_v1.0.0_rc4) 10.3.0 + GNU ld (GNU Binutils) 2.36.1 + StarFive # + StarFive #mmc dev 1 + switch to partitions #0, OK + mmc1 is current device + StarFive #mmc info + Device: mmc@16020000 + Manufacturer ID: 9f + OEM: 5449 + Name: SD64G + Bus Speed: 50000000 + Mode: SD High Speed (50MHz) + Rd Block Len: 512 + SD version 3.0 + High Capacity: Yes + Capacity: 58.3 GiB + Bus Width: 4-bit + Erase Group Size: 512 Bytes + StarFive # + StarFive #mmc part + + Partition Map for MMC device 1 -- Partition Type: EFI + + Part Start LBA End LBA Name + Attributes + Type GUID + Partition GUID + 1 0x00001000 0x00001fff "spl" + attrs: 0x0000000000000000 + type: 2e54b353-1271-4842-806f-e436d6af6985 + (2e54b353-1271-4842-806f-e436d6af6985) + guid: d5ee2056-3020-475b-9a33-25b4257c9f12 + 2 0x00002000 0x00003fff "uboot" + attrs: 0x0000000000000000 + type: bc13c2ff-59e6-4262-a352-b275fd6f7172 + (bc13c2ff-59e6-4262-a352-b275fd6f7172) + guid: 379ab7fe-fd0c-4149-b758-960c1cbfc0cc + 3 0x00004000 0x00194000 "system" + attrs: 0x0000000000000000 + type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 + (data) + guid: 539a6df9-4655-4953-8541-733ca36eb1db + StarFive # + StarFive #fatls mmc 1:3 + 6429424 Image.gz + 717705 u-boot.itb + 125437 u-boot-spl.bin.normal.out + 152848495 initramfs.cpio.gz + 11285 jh7110-starfive-visionfive-2-v1.3b.dtb + + 5 file(s), 0 dir(s) + + StarFive #fatload mmc 1:3 ${kernel_addr_r} Image.gz + 6429424 bytes read in 394 ms (15.6 MiB/s) + StarFive #fatload mmc 1:3 ${fdt_addr_r} jh7110-starfive-visionfive-2-v1.3b.dtb + 11285 bytes read in 5 ms (2.2 MiB/s) + StarFive #fatload mmc 1:3 ${ramdisk_addr_r} initramfs.cpio.gz + 152848495 bytes read in 9271 ms (15.7 MiB/s) + StarFive #booti ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r} + Uncompressing Kernel Image + ## Flattened Device Tree blob at 46000000 + Booting using the fdt blob at 0x46000000 + Working FDT set to 46000000 + Loading Ramdisk to f5579000, end fe73d86f ... OK + Loading Device Tree to 00000000f5573000, end 00000000f5578c14 ... OK + Working FDT set to f5573000 + + Starting kernel ... + + + ] Linux version 6.2.0-starfive-00026-g11934a315b67 (wyh@wyh-VirtualBox) (riscv64-linux-gnu-gcc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0, GNU ld (GNU Binutils for Ubuntu) 2.30) #1 SMP Thu Mar 2 14:51:36 CST 2023 + [ 0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000 + [ 0.000000] Machine model: StarFive VisionFive 2 v1.3B + [ 0.000000] efi: UEFI not found. + [ 0.000000] Zone ranges: + [ 0.000000] DMA32 [mem 0x0000000040200000-0x00000000ffffffff] + [ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff] + [ 0.000000] Movable zone start for each node + [ 0.000000] Early memory node ranges + [ 0.000000] node 0: [mem 0x0000000040200000-0x000000013fffffff] + [ 0.000000] Initmem setup node 0 [mem 0x0000000040200000-0x000000013fffffff] + [ 0.000000] On node 0, zone DMA32: 512 pages in unavailable ranges + [ 0.000000] SBI specification v1.0 detected + [ 0.000000] SBI implementation ID=0x1 Version=0x10002 + [ 0.000000] SBI TIME extension detected + [ 0.000000] SBI IPI extension detected + [ 0.000000] SBI RFENCE extension detected + [ 0.000000] SBI HSM extension detected + [ 0.000000] CPU with hartid=0 is not available + [ 0.000000] CPU with hartid=0 is not available + [ 0.000000] CPU with hartid=0 is not available + [ 0.000000] riscv: base ISA extensions acdfim + [ 0.000000] riscv: ELF capabilities acdfim + [ 0.000000] percpu: Embedded 18 pages/cpu s35960 r8192 d29576 u73728 + [ 0.000000] pcpu-alloc: s35960 r8192 d29576 u73728 alloc=18*4096 + [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 + [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1031688 + [ 0.000000] Kernel command line: console=ttyS0,115200 debug rootwait earlycon=sbi + [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) + [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) + [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off + [ 0.000000] software IO TLB: area num 4. + [ 0.000000] software IO TLB: mapped [mem 0x00000000f1573000-0x00000000f5573000] (64MB) + [ 0.000000] Virtual kernel memory layout: + [ 0.000000] fixmap : 0xffffffc6fee00000 - 0xffffffc6ff000000 (2048 kB) + [ 0.000000] pci io : 0xffffffc6ff000000 - 0xffffffc700000000 ( 16 MB) + [ 0.000000] vmemmap : 0xffffffc700000000 - 0xffffffc800000000 (4096 MB) + [ 0.000000] vmalloc : 0xffffffc800000000 - 0xffffffd800000000 ( 64 GB) + [ 0.000000] modules : 0xffffffff0136a000 - 0xffffffff80000000 (2028 MB) + [ 0.000000] lowmem : 0xffffffd800000000 - 0xffffffd8ffe00000 (4094 MB) + [ 0.000000] kernel : 0xffffffff80000000 - 0xffffffffffffffff (2047 MB) + [ 0.000000] Memory: 3867604K/4192256K available (8012K kernel code, 4919K rwdata, 4096K rodata, 2190K init, 476K bss, 324652K reserved, 0K cma-reserved) + [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 + [ 0.000000] rcu: Hierarchical RCU implementation. + [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4. + [ 0.000000] rcu: RCU debug extended QS entry/exit. + [ 0.000000] Tracing variant of Tasks RCU enabled. + [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. + [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 + [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 + [ 0.000000] CPU with hartid=0 is not available + [ 0.000000] riscv-intc: unable to find hart id for /cpus/cpu@0/interrupt-controller + [ 0.000000] riscv-intc: 64 local interrupts mapped + [ 0.000000] plic: interrupt-controller@c000000: mapped 136 interrupts with 4 handlers for 9 contexts. + [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. + [ 0.000000] riscv-timer: riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [4] + [ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 881590404240 ns + [ 0.000003] sched_clock: 64 bits at 4MHz, resolution 250ns, wraps every 2199023255500ns + [ 0.000437] Console: colour dummy device 80x25 + [ 0.000568] Calibrating delay loop (skipped), value calculated using timer frequency.. 8.00 BogoMIPS (lpj=16000) + [ 0.000602] pid_max: default: 32768 minimum: 301 + [ 0.000752] LSM: initializing lsm=capability,integrity + [ 0.001071] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) + [ 0.001189] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) + [ 0.004201] CPU node for /cpus/cpu@0 exist but the possible cpu range is :0-3 + [ 0.007426] cblist_init_generic: Setting adjustable number of callback queues. + [ 0.007457] cblist_init_generic: Setting shift to 2 and lim to 1. + [ 0.007875] riscv: ELF compat mode unsupported + [ 0.007902] ASID allocator disabled (0 bits) + [ 0.008405] rcu: Hierarchical SRCU implementation. + [ 0.008426] rcu: Max phase no-delay instances is 1000. + [ 0.009247] EFI services will not be available. + [ 0.010738] smp: Bringing up secondary CPUs ... + [ 0.018358] smp: Brought up 1 node, 4 CPUs + [ 0.021776] devtmpfs: initialized + [ 0.027337] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns + [ 0.027389] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) + [ 0.027888] pinctrl core: initialized pinctrl subsystem + [ 0.029881] NET: Registered PF_NETLINK/PF_ROUTE protocol family + [ 0.030401] audit: initializing netlink subsys (disabled) + [ 0.031041] audit: type=2000 audit(0.028:1): state=initialized audit_enabled=0 res=1 + [ 0.031943] cpuidle: using governor menu + [ 0.043011] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages + [ 0.043033] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page + [ 0.044943] iommu: Default domain type: Translated + [ 0.044965] iommu: DMA domain TLB invalidation policy: strict mode + [ 0.046089] SCSI subsystem initialized + [ 0.046733] libata version 3.00 loaded. + [ 0.047231] usbcore: registered new interface driver usbfs + [ 0.047315] usbcore: registered new interface driver hub + [ 0.047420] usbcore: registered new device driver usb + [ 0.049770] vgaarb: loaded + [ 0.050277] clocksource: Switched to clocksource riscv_clocksource + [ 0.084690] NET: Registered PF_INET protocol family + [ 0.085561] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) + [ 0.093010] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 65536 bytes, linear) + [ 0.093152] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) + [ 0.093224] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) + [ 0.093821] TCP bind hash table entries: 32768 (order: 9, 2097152 bytes, linear) + [ 0.117880] TCP: Hash tables configured (established 32768 bind 32768) + [ 0.118500] UDP hash table entries: 2048 (order: 5, 196608 bytes, linear) + [ 0.118881] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes, linear) + [ 0.119675] NET: Registered PF_UNIX/PF_LOCAL protocol family + [ 0.121749] RPC: Registered named UNIX socket transport module. + [ 0.121776] RPC: Registered udp transport module. + [ 0.121784] RPC: Registered tcp transport module. + [ 0.121791] RPC: Registered tcp NFSv4.1 backchannel transport module. + [ 0.121816] PCI: CLS 0 bytes, default 64 + [ 0.124101] Unpacking initramfs... + [ 0.125468] workingset: timestamp_bits=46 max_order=20 bucket_order=0 + [ 0.128372] NFS: Registering the id_resolver key type + [ 0.128498] Key type id_resolver registered + [ 0.128525] Key type id_legacy registered + [ 0.128625] nfs4filelayout_init: NFSv4 File Layout Driver Registering... + [ 0.128649] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... + [ 0.129358] 9p: Installing v9fs 9p2000 file system support + [ 0.130179] NET: Registered PF_ALG protocol family + [ 0.130499] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) + [ 0.130544] io scheduler mq-deadline registered + [ 0.130556] io scheduler kyber registered + [ 0.416754] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled + [ 0.420857] SuperH (H)SCI(F) driver initialized + [ 0.443735] loop: module loaded + [ 0.448605] e1000e: Intel(R) PRO/1000 Network Driver + [ 0.448627] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. + [ 0.450716] usbcore: registered new interface driver uas + [ 0.450832] usbcore: registered new interface driver usb-storage + [ 0.451638] mousedev: PS/2 mouse device common for all mice + [ 0.453465] sdhci: Secure Digital Host Controller Interface driver + [ 0.453487] sdhci: Copyright(c) Pierre Ossman + [ 0.453584] sdhci-pltfm: SDHCI platform and OF driver helper + [ 0.454140] usbcore: registered new interface driver usbhid + [ 0.454174] usbhid: USB HID core driver + [ 0.454833] riscv-pmu-sbi: SBI PMU extension is available + [ 0.454920] riscv-pmu-sbi: 16 firmware and 4 hardware counters + [ 0.454942] riscv-pmu-sbi: Perf sampling/filtering is not supported as sscof extension is not available + [ 0.457071] NET: Registered PF_INET6 protocol family + [ 0.460627] Segment Routing with IPv6 + [ 0.460821] In-situ OAM (IOAM) with IPv6 + [ 0.461005] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver + [ 0.462712] NET: Registered PF_PACKET protocol family + [ 0.462933] 9pnet: Installing 9P2000 support + [ 0.463141] Key type dns_resolver registered + [ 0.463168] start plist test + [ 0.469261] end plist test + [ 0.506774] debug_vm_pgtable: [debug_vm_pgtable ]: Validating architecture page table helpers + [ 0.553683] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. + [ 0.554741] starfive-jh7110-sys-pinctrl 13040000.pinctrl: StarFive GPIO chip registered 64 GPIOs + [ 0.555900] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. + [ 0.556772] starfive-jh7110-aon-pinctrl 17020000.pinctrl: StarFive GPIO chip registered 4 GPIOs + [ 0.559454] printk: console [ttyS0] disabled + [ 0.579948] 10000000.serial: ttyS0 at MMIO 0x10000000 (irq = 3, base_baud = 1500000) is a 16550A + [ 0.580082] printk: console [ttyS0] enabled + [ 13.642680] Freeing initrd memory: 149264K + [ 13.651051] Freeing unused kernel image (initmem) memory: 2188K + [ 13.666431] Run /init as init process + [ 13.670116] with arguments: + [ 13.673168] /init + [ 13.675488] with environment: + [ 13.678668] HOME=/ + [ 13.681038] TERM=linux + Starting syslogd: OK + Starting klogd: OK + Running sysctl: OK + Populating /dev using udev: [ 14.145944] udevd[93]: starting version 3.2.10 + [ 15.214287] random: crng init done + [ 15.240816] udevd[94]: starting eudev-3.2.10 + done + Saving random seed: OK + Starting system message bus: dbus[122]: Unknown username "pulse" in message bus configuration file + done + Starting rpcbind: OK + Starting iptables: OK + Starting bluetoothd: OK + Starting network: Waiting for interface eth0 to appear............... timeout! + run-parts: /etc/network/if-pre-up.d/wait_iface: exit status 1 + FAIL + Starting dropbear sshd: OK + Starting NFS statd: OK + Starting NFS services: OK + Starting NFS daemon: rpc.nfsd: Unable to access /proc/fs/nfsd errno 2 (No such file or directory). + Please try, as root, 'mount -t nfsd nfsd /proc/fs/nfsd' and then restart rpc.nfsd to correct the problem + FAIL + Starting NFS mountd: OK + Starting DHCP server: FAIL + + Welcome to Buildroot + buildroot login: + +Booting from SPI +---------------- + +Use Building steps from "Booting from MMC using U-Boot SPL" section. + +Partition the SPI in Linux via mtdblock. (Require to boot the board in +SD boot mode by enabling MTD block in Linux) + +Use prebuilt image from here [1], which support to partition the SPI flash. + + +Program the SPI (Require to boot the board in SD boot mode) + +Execute below steps on U-Boot proper, + +.. code-block:: none + + sf probe + fatload mmc 1:3 $kernel_addr_r u-boot.itb + sf update $kernel_addr_r 0x100000 $filesize + + fatload mmc 1:3 $kernel_addr_r u-boot-spl.bin.normal.out + sf update $kernel_addr_r 0x0 $filesize + + +Power off the board + +Change DIP switches MSEL[1:0] are set to 00, select the boot mode to flash + +Power up the board. diff --git a/include/configs/starfive-visionfive2.h b/include/configs/starfive-visionfive2.h new file mode 100644 index 0000000000..93dcc22d36 --- /dev/null +++ b/include/configs/starfive-visionfive2.h @@ -0,0 +1,49 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + * Author: Yanhong Wangyanhong.wang@starfivetech.com + * + */ + +#ifndef _STARFIVE_VISIONFIVE2_H +#define _STARFIVE_VISIONFIVE2_H + +#define RISCV_MMODE_TIMERBASE 0x2000000 +#define RISCV_MMODE_TIMER_FREQ 4000000 +#define RISCV_SMODE_TIMER_FREQ 4000000 + +#define __io + +/* Environment options */ + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 1) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> + +#define TYPE_GUID_SPL "2E54B353-1271-4842-806F-E436D6AF6985" +#define TYPE_GUID_UBOOT "BC13C2FF-59E6-4262-A352-B275FD6F7172" +#define TYPE_GUID_SYSTEM "EBD0A0A2-B9E5-4433-87C0-68B6B72699C7" + +#define PARTS_DEFAULT \ + "name=spl,start=2M,size=2M,type=${type_guid_gpt_loader1};" \ + "name=uboot,size=4MB,type=${type_guid_gpt_loader2};" \ + "name=system,size=-,bootable,type=${type_guid_gpt_system};" + +#define CFG_EXTRA_ENV_SETTINGS \ + "kernel_addr_r=0x40200000\0" \ + "kernel_comp_addr_r=0x88000000\0" \ + "kernel_comp_size=0x4000000\0" \ + "fdt_addr_r=0x46000000\0" \ + "scriptaddr=0x43900000\0" \ + "pxefile_addr_r=0x45900000\0" \ + "ramdisk_addr_r=0x46100000\0" \ + "type_guid_gpt_loader1=" TYPE_GUID_SPL "\0" \ + "type_guid_gpt_loader2=" TYPE_GUID_UBOOT "\0" \ + "type_guid_gpt_system=" TYPE_GUID_SYSTEM "\0" \ + "partitions=" PARTS_DEFAULT "\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + BOOTENV + +#endif /* _STARFIVE_VISIONFIVE2_H */
Add Kconfig to select the basic functions for StarFive JH7110 SoC.
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- arch/riscv/cpu/jh7110/Kconfig | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+) create mode 100644 arch/riscv/cpu/jh7110/Kconfig
diff --git a/arch/riscv/cpu/jh7110/Kconfig b/arch/riscv/cpu/jh7110/Kconfig new file mode 100644 index 0000000000..3f145415eb --- /dev/null +++ b/arch/riscv/cpu/jh7110/Kconfig @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2022 StarFive Technology Co., Ltd. + +config STARFIVE_JH7110 + bool + select ARCH_EARLY_INIT_R + select CLK_JH7110 + select CPU + select CPU_RISCV + select RAM + select RESET_JH7110 + select SUPPORT_SPL + select SPL_RAM if SPL + select SPL_STARFIVE_DDR + select PINCTRL_STARFIVE_JH7110 + imply MMC + imply MMC_BROKEN_CD + imply MMC_SPI + imply RISCV_TIMER if (RISCV_SMODE || SPL_RISCV_SMODE) + imply SIFIVE_CACHE + imply SIFIVE_CCACHE + imply SMP + imply SPI + imply SPL_CPU + imply SPL_LOAD_FIT + imply SPL_OPENSBI + imply SPL_SIFIVE_CLINT
Add Kconfig to select the basic functions for StarFive VisionFive v2 Board.
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- board/starfive/visionfive2/Kconfig | 53 ++++++++++++++++++++++++++++++ 1 file changed, 53 insertions(+) create mode 100644 board/starfive/visionfive2/Kconfig
diff --git a/board/starfive/visionfive2/Kconfig b/board/starfive/visionfive2/Kconfig new file mode 100644 index 0000000000..2186a93964 --- /dev/null +++ b/board/starfive/visionfive2/Kconfig @@ -0,0 +1,53 @@ +if TARGET_STARFIVE_VISIONFIVE2 + +config SYS_CPU + default "jh7110" + +config SYS_BOARD + default "visionfive2" + +config SYS_VENDOR + default "starfive" + +config SYS_CONFIG_NAME + default "starfive-visionfive2" + +config TEXT_BASE + default 0x40200000 if SPL + default 0x40000000 if !RISCV_SMODE + default 0x40200000 if RISCV_SMODE + +config SPL_TEXT_BASE + default 0x08000000 + +config SPL_OPENSBI_LOAD_ADDR + default 0x80000000 + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select STARFIVE_JH7110 + select SUPPORT_SPL + select BINMAN + imply CMD_CPU + imply CMD_DHCP + imply CMD_EXT2 + imply CMD_EXT4 + imply CMD_FAT + imply CMD_FS_GENERIC + imply CMD_GPIO + imply CMD_GPT + imply CMD_MMC + imply CMD_NET + imply CMD_PING + imply CMD_SF + imply DM_GPIO + imply DOS_PARTITION + imply EFI_PARTITION + imply MII + imply IP_DYN + imply ISO_PARTITION + imply PARTITION_TYPE_GUID + imply PHY_LIB + imply PHY_MSCC + +endif
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- arch/riscv/Kconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 48ca4ff4c4..f6ed05906a 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -24,6 +24,9 @@ config TARGET_SIFIVE_UNMATCHED bool "Support SiFive Unmatched Board" select SYS_CACHE_SHIFT_6
+config TARGET_STARFIVE_VISIONFIVE2 + bool "Support StarFive VisionFive2 Board" + config TARGET_SIPEED_MAIX bool "Support Sipeed Maix Board" select SYS_CACHE_SHIFT_6 @@ -65,12 +68,14 @@ source "board/sifive/unleashed/Kconfig" source "board/sifive/unmatched/Kconfig" source "board/openpiton/riscv64/Kconfig" source "board/sipeed/maix/Kconfig" +source "board/starfive/visionfive2/Kconfig"
# platform-specific options below source "arch/riscv/cpu/andesv5/Kconfig" source "arch/riscv/cpu/fu540/Kconfig" source "arch/riscv/cpu/fu740/Kconfig" source "arch/riscv/cpu/generic/Kconfig" +source "arch/riscv/cpu/jh7110/Kconfig"
# architecture-specific options below
Add initial device tree for the JH7110 RISC-V SoC.
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- arch/riscv/dts/jh7110.dtsi | 582 +++++++++++++++++++++++++++++++++++++ 1 file changed, 582 insertions(+) create mode 100644 arch/riscv/dts/jh7110.dtsi
diff --git a/arch/riscv/dts/jh7110.dtsi b/arch/riscv/dts/jh7110.dtsi new file mode 100644 index 0000000000..d3e9f92987 --- /dev/null +++ b/arch/riscv/dts/jh7110.dtsi @@ -0,0 +1,582 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + */ + +/dts-v1/; +#include <dt-bindings/clock/starfive,jh7110-crg.h> +#include <dt-bindings/reset/starfive,jh7110-crg.h> + +/ { + compatible = "starfive,jh7110"; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + S7_0: cpu@0 { + compatible = "sifive,s7", "riscv"; + reg = <0>; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <8192>; + d-tlb-sets = <1>; + d-tlb-size = <40>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <64>; + i-cache-size = <16384>; + i-tlb-sets = <1>; + i-tlb-size = <40>; + mmu-type = "riscv,sv39"; + next-level-cache = <&ccache>; + riscv,isa = "rv64imac_zba_zbb"; + tlb-split; + status = "disabled"; + + cpu0_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + U74_1: cpu@1 { + compatible = "sifive,u74-mc", "riscv"; + reg = <1>; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <40>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <64>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <40>; + mmu-type = "riscv,sv39"; + next-level-cache = <&ccache>; + riscv,isa = "rv64imafdc_zba_zbb"; + tlb-split; + + cpu1_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + U74_2: cpu@2 { + compatible = "sifive,u74-mc", "riscv"; + reg = <2>; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <40>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <64>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <40>; + mmu-type = "riscv,sv39"; + next-level-cache = <&ccache>; + riscv,isa = "rv64imafdc_zba_zbb"; + tlb-split; + + cpu2_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + U74_3: cpu@3 { + compatible = "sifive,u74-mc", "riscv"; + reg = <3>; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <40>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <64>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <40>; + mmu-type = "riscv,sv39"; + next-level-cache = <&ccache>; + riscv,isa = "rv64imafdc_zba_zbb"; + tlb-split; + + cpu3_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + U74_4: cpu@4 { + compatible = "sifive,u74-mc", "riscv"; + reg = <4>; + d-cache-block-size = <64>; + d-cache-sets = <64>; + d-cache-size = <32768>; + d-tlb-sets = <1>; + d-tlb-size = <40>; + device_type = "cpu"; + i-cache-block-size = <64>; + i-cache-sets = <64>; + i-cache-size = <32768>; + i-tlb-sets = <1>; + i-tlb-size = <40>; + mmu-type = "riscv,sv39"; + next-level-cache = <&ccache>; + riscv,isa = "rv64imafdc_zba_zbb"; + tlb-split; + + cpu4_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu-map { + cluster0 { + core0 { + cpu = <&S7_0>; + }; + + core1 { + cpu = <&U74_1>; + }; + + core2 { + cpu = <&U74_2>; + }; + + core3 { + cpu = <&U74_3>; + }; + + core4 { + cpu = <&U74_4>; + }; + }; + }; + }; + + osc: oscillator { + compatible = "fixed-clock"; + clock-output-names = "osc"; + #clock-cells = <0>; + }; + + rtc_osc: rtc-oscillator { + compatible = "fixed-clock"; + clock-output-names = "rtc_osc"; + #clock-cells = <0>; + }; + + gmac0_rmii_refin: gmac0-rmii-refin-clock { + compatible = "fixed-clock"; + clock-output-names = "gmac0_rmii_refin"; + #clock-cells = <0>; + }; + + gmac0_rgmii_rxin: gmac0-rgmii-rxin-clock { + compatible = "fixed-clock"; + clock-output-names = "gmac0_rgmii_rxin"; + #clock-cells = <0>; + }; + + gmac1_rmii_refin: gmac1-rmii-refin-clock { + compatible = "fixed-clock"; + clock-output-names = "gmac1_rmii_refin"; + #clock-cells = <0>; + }; + + gmac1_rgmii_rxin: gmac1-rgmii-rxin-clock { + compatible = "fixed-clock"; + clock-output-names = "gmac1_rgmii_rxin"; + #clock-cells = <0>; + }; + + i2stx_bclk_ext: i2stx-bclk-ext-clock { + compatible = "fixed-clock"; + clock-output-names = "i2stx_bclk_ext"; + #clock-cells = <0>; + }; + + i2stx_lrck_ext: i2stx-lrck-ext-clock { + compatible = "fixed-clock"; + clock-output-names = "i2stx_lrck_ext"; + #clock-cells = <0>; + }; + + i2srx_bclk_ext: i2srx-bclk-ext-clock { + compatible = "fixed-clock"; + clock-output-names = "i2srx_bclk_ext"; + #clock-cells = <0>; + }; + + i2srx_lrck_ext: i2srx-lrck-ext-clock { + compatible = "fixed-clock"; + clock-output-names = "i2srx_lrck_ext"; + #clock-cells = <0>; + }; + + tdm_ext: tdm-ext-clock { + compatible = "fixed-clock"; + clock-output-names = "tdm_ext"; + #clock-cells = <0>; + }; + + mclk_ext: mclk-ext-clock { + compatible = "fixed-clock"; + clock-output-names = "mclk_ext"; + #clock-cells = <0>; + }; + + soc { + compatible = "simple-bus"; + interrupt-parent = <&plic>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + clint: timer@2000000 { + compatible = "starfive,jh7110-clint", "sifive,clint0"; + reg = <0x0 0x2000000 0x0 0x10000>; + interrupts-extended = <&cpu0_intc 3>, <&cpu0_intc 7>, + <&cpu1_intc 3>, <&cpu1_intc 7>, + <&cpu2_intc 3>, <&cpu2_intc 7>, + <&cpu3_intc 3>, <&cpu3_intc 7>, + <&cpu4_intc 3>, <&cpu4_intc 7>; + }; + + plic: interrupt-controller@c000000 { + compatible = "starfive,jh7110-plic", "sifive,plic-1.0.0"; + reg = <0x0 0xc000000 0x0 0x4000000>; + interrupts-extended = <&cpu0_intc 11>, + <&cpu1_intc 11>, <&cpu1_intc 9>, + <&cpu2_intc 11>, <&cpu2_intc 9>, + <&cpu3_intc 11>, <&cpu3_intc 9>, + <&cpu4_intc 11>, <&cpu4_intc 9>; + interrupt-controller; + #interrupt-cells = <1>; + #address-cells = <0>; + riscv,ndev = <136>; + }; + + ccache: cache-controller@2010000 { + compatible = "starfive,jh7110-ccache", "sifive,ccache0", "cache"; + reg = <0x0 0x2010000 0x0 0x4000>; + interrupts = <1>, <3>, <4>, <2>; + cache-block-size = <64>; + cache-level = <2>; + cache-sets = <2048>; + cache-size = <2097152>; + cache-unified; + }; + + uart0: serial@10000000 { + compatible = "snps,dw-apb-uart"; + reg = <0x0 0x10000000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_UART0_CORE>, + <&syscrg JH7110_SYSCLK_UART0_APB>; + clock-names = "baudclk", "apb_pclk"; + resets = <&syscrg JH7110_SYSRST_UART0_APB>, + <&syscrg JH7110_SYSRST_UART0_CORE>; + interrupts = <32>; + reg-io-width = <4>; + reg-shift = <2>; + status = "disabled"; + }; + + uart1: serial@10010000 { + compatible = "snps,dw-apb-uart"; + reg = <0x0 0x10010000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_UART1_CORE>, + <&syscrg JH7110_SYSCLK_UART1_APB>; + clock-names = "baudclk", "apb_pclk"; + resets = <&syscrg JH7110_SYSRST_UART1_APB>, + <&syscrg JH7110_SYSRST_UART1_CORE>; + interrupts = <33>; + reg-io-width = <4>; + reg-shift = <2>; + status = "disabled"; + }; + + uart2: serial@10020000 { + compatible = "snps,dw-apb-uart"; + reg = <0x0 0x10020000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_UART2_CORE>, + <&syscrg JH7110_SYSCLK_UART2_APB>; + clock-names = "baudclk", "apb_pclk"; + resets = <&syscrg JH7110_SYSRST_UART2_APB>, + <&syscrg JH7110_SYSRST_UART2_CORE>; + interrupts = <34>; + reg-io-width = <4>; + reg-shift = <2>; + status = "disabled"; + }; + + i2c0: i2c@10030000 { + compatible = "snps,designware-i2c"; + reg = <0x0 0x10030000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_I2C0_APB>; + clock-names = "ref"; + resets = <&syscrg JH7110_SYSRST_I2C0_APB>; + interrupts = <35>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c1: i2c@10040000 { + compatible = "snps,designware-i2c"; + reg = <0x0 0x10040000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_I2C1_APB>; + clock-names = "ref"; + resets = <&syscrg JH7110_SYSRST_I2C1_APB>; + interrupts = <36>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c2: i2c@10050000 { + compatible = "snps,designware-i2c"; + reg = <0x0 0x10050000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_I2C2_APB>; + clock-names = "ref"; + resets = <&syscrg JH7110_SYSRST_I2C2_APB>; + interrupts = <37>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + stgcrg: clock-controller@10230000 { + compatible = "starfive,jh7110-stgcrg"; + reg = <0x0 0x10230000 0x0 0x10000>; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + stg_syscon: stg_syscon@10240000 { + compatible = "starfive,jh7110-stg-syscon","syscon"; + reg = <0x0 0x10240000 0x0 0x1000>; + }; + + uart3: serial@12000000 { + compatible = "snps,dw-apb-uart"; + reg = <0x0 0x12000000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_UART3_CORE>, + <&syscrg JH7110_SYSCLK_UART3_APB>; + clock-names = "baudclk", "apb_pclk"; + resets = <&syscrg JH7110_SYSRST_UART3_APB>, + <&syscrg JH7110_SYSRST_UART3_CORE>; + interrupts = <45>; + reg-io-width = <4>; + reg-shift = <2>; + status = "disabled"; + }; + + uart4: serial@12010000 { + compatible = "snps,dw-apb-uart"; + reg = <0x0 0x12010000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_UART4_CORE>, + <&syscrg JH7110_SYSCLK_UART4_APB>; + clock-names = "baudclk", "apb_pclk"; + resets = <&syscrg JH7110_SYSRST_UART4_APB>, + <&syscrg JH7110_SYSRST_UART4_CORE>; + interrupts = <46>; + reg-io-width = <4>; + reg-shift = <2>; + status = "disabled"; + }; + + uart5: serial@12020000 { + compatible = "snps,dw-apb-uart"; + reg = <0x0 0x12020000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_UART5_CORE>, + <&syscrg JH7110_SYSCLK_UART5_APB>; + clock-names = "baudclk", "apb_pclk"; + resets = <&syscrg JH7110_SYSRST_UART5_APB>, + <&syscrg JH7110_SYSRST_UART5_CORE>; + interrupts = <47>; + reg-io-width = <4>; + reg-shift = <2>; + status = "disabled"; + }; + + i2c3: i2c@12030000 { + compatible = "snps,designware-i2c"; + reg = <0x0 0x12030000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_I2C3_APB>; + clock-names = "ref"; + resets = <&syscrg JH7110_SYSRST_I2C3_APB>; + interrupts = <48>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c4: i2c@12040000 { + compatible = "snps,designware-i2c"; + reg = <0x0 0x12040000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_I2C4_APB>; + clock-names = "ref"; + resets = <&syscrg JH7110_SYSRST_I2C4_APB>; + interrupts = <49>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c5: i2c@12050000 { + compatible = "snps,designware-i2c"; + reg = <0x0 0x12050000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_I2C5_APB>; + clock-names = "ref"; + resets = <&syscrg JH7110_SYSRST_I2C5_APB>; + interrupts = <50>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c6: i2c@12060000 { + compatible = "snps,designware-i2c"; + reg = <0x0 0x12060000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_I2C6_APB>; + clock-names = "ref"; + resets = <&syscrg JH7110_SYSRST_I2C6_APB>; + interrupts = <51>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + qspi: spi@13010000 { + compatible = "cdns,qspi-nor"; + reg = <0x0 0x13010000 0x0 0x10000 + 0x0 0x21000000 0x0 0x400000>; + clocks = <&syscrg JH7110_SYSCLK_QSPI_REF>; + clock-names = "clk_ref"; + resets = <&syscrg JH7110_SYSRST_QSPI_APB>, + <&syscrg JH7110_SYSRST_QSPI_AHB>, + <&syscrg JH7110_SYSRST_QSPI_REF>; + reset-names = "rst_apb", "rst_ahb", "rst_ref"; + cdns,fifo-depth = <256>; + cdns,fifo-width = <4>; + #address-cells = <1>; + #size-cells = <0>; + }; + + syscrg: clock-controller@13020000 { + compatible = "starfive,jh7110-syscrg"; + reg = <0x0 0x13020000 0x0 0x10000>; + clocks = <&osc>, <&gmac1_rmii_refin>, + <&gmac1_rgmii_rxin>, + <&i2stx_bclk_ext>, <&i2stx_lrck_ext>, + <&i2srx_bclk_ext>, <&i2srx_lrck_ext>, + <&tdm_ext>, <&mclk_ext>; + clock-names = "osc", "gmac1_rmii_refin", + "gmac1_rgmii_rxin", + "i2stx_bclk_ext", "i2stx_lrck_ext", + "i2srx_bclk_ext", "i2srx_lrck_ext", + "tdm_ext", "mclk_ext"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + sys_syscon: sys_syscon@13030000 { + compatible = "starfive,jh7110-sys-syscon","syscon"; + reg = <0x0 0x13030000 0x0 0x1000>; + }; + + sysgpio: pinctrl@13040000 { + compatible = "starfive,jh7110-sys-pinctrl"; + reg = <0x0 0x13040000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_IOMUX_APB>; + resets = <&syscrg JH7110_SYSRST_IOMUX_APB>; + interrupts = <86>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-controller; + #gpio-cells = <2>; + }; + + mmc0: mmc@16010000 { + compatible = "starfive,jh7110-mmc"; + reg = <0x0 0x16010000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_SDIO0_AHB>, + <&syscrg JH7110_SYSCLK_SDIO0_SDCARD>; + clock-names = "biu", "ciu"; + resets = <&syscrg JH7110_SYSRST_SDIO0_AHB>; + reset-names = "reset"; + interrupts = <74>; + fifo-depth = <32>; + fifo-watermark-aligned; + data-addr = <0>; + starfive,sysreg = <&sys_syscon 0x14 0x1a 0x7c000000>; + status = "disabled"; + }; + + mmc1: mmc@16020000 { + compatible = "starfive,jh7110-mmc"; + reg = <0x0 0x16020000 0x0 0x10000>; + clocks = <&syscrg JH7110_SYSCLK_SDIO1_AHB>, + <&syscrg JH7110_SYSCLK_SDIO1_SDCARD>; + clock-names = "biu", "ciu"; + resets = <&syscrg JH7110_SYSRST_SDIO1_AHB>; + reset-names = "reset"; + interrupts = <75>; + fifo-depth = <32>; + fifo-watermark-aligned; + data-addr = <0>; + starfive,sysreg = <&sys_syscon 0x9c 0x1 0x3e>; + status = "disabled"; + }; + + aoncrg: clock-controller@17000000 { + compatible = "starfive,jh7110-aoncrg"; + reg = <0x0 0x17000000 0x0 0x10000>; + clocks = <&osc>, <&rtc_osc>, + <&gmac0_rmii_refin>, <&gmac0_rgmii_rxin>, + <&syscrg JH7110_SYSCLK_STG_AXIAHB>, + <&syscrg JH7110_SYSCLK_APB_BUS>, + <&syscrg JH7110_SYSCLK_GMAC0_GTXCLK>; + clock-names = "osc", "rtc_osc", "gmac0_rmii_refin", + "gmac0_rgmii_rxin", "stg_axiahb", + "apb_bus", "gmac0_gtxclk"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + aon_syscon: aon_syscon@17010000 { + compatible = "starfive,jh7110-aon-syscon","syscon"; + reg = <0x0 0x17010000 0x0 0x1000>; + }; + + aongpio: pinctrl@17020000 { + compatible = "starfive,jh7110-aon-pinctrl"; + reg = <0x0 0x17020000 0x0 0x10000>; + resets = <&aoncrg JH7110_AONRST_IOMUX>; + interrupts = <85>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-controller; + #gpio-cells = <2>; + }; + }; +};
- Copyright (C) 2022 StarFive Technology Co., Ltd.
- compatible = "starfive,jh7110";
- #address-cells = <2>;
- #size-cells = <2>;
- cpus {
#size-cells = <0>;
S7_0: cpu@0 {
reg = <0>;
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
Hmm, based on what Sean said on the previous version, "We use strchr on it; so something like Zicsr is parsed as 5 extensions", are you sure that adding this here behaves correctly?
https://lore.kernel.org/u-boot/22e805d4-f823-975c-a970-a4a19bb13ece@gmail.co...
I know that having zba/zbb is *correct*, but if U-Boot doesn't parse it correctly...
Cheers, Conor.
- cpus {
#size-cells = <0>;
S7_0: cpu@0 {
reg = <0>;
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
As you said, u-boot does not parse the content after '_', zba/zbb has no practical meaning in u-boot. The definitions of 'riscv,isa' refer to linux and is consistent with this.
https://patchwork.kernel.org/project/linux-riscv/patch/20230221024645.127922...
Do you have any better suggestion? Referring to the definition of Sifive fu740, remove '_zba_zbb'?
Cheers, Conor.
On 7 March 2023 01:59:31 GMT, yanhong wang yanhong.wang@starfivetech.com wrote:
- cpus {
#size-cells = <0>;
S7_0: cpu@0 {
reg = <0>;
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
That's not what Sean's comment on the previous version said. If it is actually ignored, this is fine, but Sean's comment read like it would be misinterpreted by U-Boot. I'll have to go read the code.
The fu740 doesn't have those extensions.
Cheers, Conor.
- cpus {
#size-cells = <0>;
S7_0: cpu@0 {
reg = <0>;
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
Having gone and found the code in question, it does indeed look like it stops at an _, supports_extension() in arch/riscv/cpu/cpu.c, so having Zba and Zbb in the riscv,isa string is fine. Apologies for the noise here, I must've misunderstood the comments on the previous version.
Cheers, Conor.
Add initial u-boot device tree for the JH7110 RISC-V SoC.
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- arch/riscv/dts/jh7110-u-boot.dtsi | 95 +++++++++++++++++++++++++++++++ 1 file changed, 95 insertions(+) create mode 100644 arch/riscv/dts/jh7110-u-boot.dtsi
diff --git a/arch/riscv/dts/jh7110-u-boot.dtsi b/arch/riscv/dts/jh7110-u-boot.dtsi new file mode 100644 index 0000000000..6972e40327 --- /dev/null +++ b/arch/riscv/dts/jh7110-u-boot.dtsi @@ -0,0 +1,95 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + */ + +#include <dt-bindings/reset/starfive,jh7110-crg.h> + +/ { + cpus: cpus { + u-boot,dm-spl; + + S7_0: cpu@0 { + u-boot,dm-spl; + status = "okay"; + cpu0_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + + U74_1: cpu@1 { + u-boot,dm-spl; + cpu1_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + + U74_2: cpu@2 { + u-boot,dm-spl; + cpu2_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + + U74_3: cpu@3 { + u-boot,dm-spl; + cpu3_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + + U74_4: cpu@4 { + u-boot,dm-spl; + cpu4_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + }; + + soc { + u-boot,dm-spl; + + clint: timer@2000000 { + u-boot,dm-spl; + }; + + dmc: dmc@15700000 { + u-boot,dm-spl; + compatible = "starfive,jh7110-dmc"; + reg = <0x0 0x15700000 0x0 0x10000>, + <0x0 0x13000000 0x0 0x10000>; + resets = <&syscrg JH7110_SYSRST_DDR_AXI>, + <&syscrg JH7110_SYSRST_DDR_OSC>, + <&syscrg JH7110_SYSRST_DDR_APB>; + reset-names = "axi", "osc", "apb"; + clocks = <&syscrg JH7110_SYSCLK_PLL1_OUT>; + clock-names = "pll1"; + clock-frequency = <2133>; + }; + }; +}; + +&osc { + u-boot,dm-spl; +}; + +&gmac0_rmii_refin { + u-boot,dm-spl; +}; + +&aoncrg { + u-boot,dm-spl; +}; + +&syscrg { + u-boot,dm-spl; + starfive,sys-syscon = <&sys_syscon>; +}; + +&stgcrg { + u-boot,dm-spl; +}; + +&sys_syscon { + u-boot,dm-spl; +};
Add initial device tree for StarFive VisionFive v2 board.
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- arch/riscv/dts/Makefile | 3 +- ...10-starfive-visionfive-2-v1.2a-u-boot.dtsi | 85 ++++++ .../jh7110-starfive-visionfive-2-v1.2a.dts | 12 + ...10-starfive-visionfive-2-v1.3b-u-boot.dtsi | 85 ++++++ .../jh7110-starfive-visionfive-2-v1.3b.dts | 12 + .../dts/jh7110-starfive-visionfive-2.dtsi | 253 ++++++++++++++++++ 6 files changed, 449 insertions(+), 1 deletion(-) create mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2-v1.2a-u-boot.dtsi create mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2-v1.2a.dts create mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2-v1.3b-u-boot.dtsi create mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2-v1.3b.dts create mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi
diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index c576c55767..79a58694f5 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -7,7 +7,8 @@ dtb-$(CONFIG_TARGET_OPENPITON_RISCV64) += openpiton-riscv64.dtb dtb-$(CONFIG_TARGET_SIFIVE_UNLEASHED) += hifive-unleashed-a00.dtb dtb-$(CONFIG_TARGET_SIFIVE_UNMATCHED) += hifive-unmatched-a00.dtb dtb-$(CONFIG_TARGET_SIPEED_MAIX) += k210-maix-bit.dtb - +dtb-$(CONFIG_TARGET_STARFIVE_VISIONFIVE2) += jh7110-starfive-visionfive-2-v1.3b.dtb +dtb-$(CONFIG_TARGET_STARFIVE_VISIONFIVE2) += jh7110-starfive-visionfive-2-v1.2a.dtb include $(srctree)/scripts/Makefile.dts
targets += $(dtb-y) diff --git a/arch/riscv/dts/jh7110-starfive-visionfive-2-v1.2a-u-boot.dtsi b/arch/riscv/dts/jh7110-starfive-visionfive-2-v1.2a-u-boot.dtsi new file mode 100644 index 0000000000..161468f3e9 --- /dev/null +++ b/arch/riscv/dts/jh7110-starfive-visionfive-2-v1.2a-u-boot.dtsi @@ -0,0 +1,85 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + */ + +#include "binman.dtsi" +#include "jh7110-u-boot.dtsi" +/ { + chosen { + u-boot,dm-spl; + }; + + firmware { + spi0 = &qspi; + u-boot,dm-spl; + }; + + config { + u-boot,dm-spl; + u-boot,spl-payload-offset = <0x100000>; + }; + + memory@40000000 { + u-boot,dm-spl; + }; +}; + +&uart0 { + u-boot,dm-spl; +}; + +&mmc0 { + u-boot,dm-spl; +}; + +&mmc1 { + u-boot,dm-spl; +}; + +&qspi { + u-boot,dm-spl; + + nor-flash@0 { + u-boot,dm-spl; + }; +}; + +&sysgpio { + u-boot,dm-spl; +}; + +&mmc0_pins { + u-boot,dm-spl; + mmc0-pins-rest { + u-boot,dm-spl; + }; +}; + +&sdcard1_pins { + u-boot,dm-spl; + sdcard1-pins0 { + u-boot,dm-spl; + }; + + sdcard1-pins1 { + u-boot,dm-spl; + }; + + sdcard1-pins2 { + u-boot,dm-spl; + }; + + sdcard1-pins3 { + u-boot,dm-spl; + }; + + sdcard1-pins4 { + u-boot,dm-spl; + }; + + sdcard1-pins5 { + u-boot,dm-spl; + }; +}; + diff --git a/arch/riscv/dts/jh7110-starfive-visionfive-2-v1.2a.dts b/arch/riscv/dts/jh7110-starfive-visionfive-2-v1.2a.dts new file mode 100644 index 0000000000..b9d26d7af7 --- /dev/null +++ b/arch/riscv/dts/jh7110-starfive-visionfive-2-v1.2a.dts @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + */ + +/dts-v1/; +#include "jh7110-starfive-visionfive-2.dtsi" + +/ { + model = "StarFive VisionFive 2 v1.2A"; + compatible = "starfive,visionfive-2-v1.2a", "starfive,jh7110"; +}; diff --git a/arch/riscv/dts/jh7110-starfive-visionfive-2-v1.3b-u-boot.dtsi b/arch/riscv/dts/jh7110-starfive-visionfive-2-v1.3b-u-boot.dtsi new file mode 100644 index 0000000000..161468f3e9 --- /dev/null +++ b/arch/riscv/dts/jh7110-starfive-visionfive-2-v1.3b-u-boot.dtsi @@ -0,0 +1,85 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + */ + +#include "binman.dtsi" +#include "jh7110-u-boot.dtsi" +/ { + chosen { + u-boot,dm-spl; + }; + + firmware { + spi0 = &qspi; + u-boot,dm-spl; + }; + + config { + u-boot,dm-spl; + u-boot,spl-payload-offset = <0x100000>; + }; + + memory@40000000 { + u-boot,dm-spl; + }; +}; + +&uart0 { + u-boot,dm-spl; +}; + +&mmc0 { + u-boot,dm-spl; +}; + +&mmc1 { + u-boot,dm-spl; +}; + +&qspi { + u-boot,dm-spl; + + nor-flash@0 { + u-boot,dm-spl; + }; +}; + +&sysgpio { + u-boot,dm-spl; +}; + +&mmc0_pins { + u-boot,dm-spl; + mmc0-pins-rest { + u-boot,dm-spl; + }; +}; + +&sdcard1_pins { + u-boot,dm-spl; + sdcard1-pins0 { + u-boot,dm-spl; + }; + + sdcard1-pins1 { + u-boot,dm-spl; + }; + + sdcard1-pins2 { + u-boot,dm-spl; + }; + + sdcard1-pins3 { + u-boot,dm-spl; + }; + + sdcard1-pins4 { + u-boot,dm-spl; + }; + + sdcard1-pins5 { + u-boot,dm-spl; + }; +}; + diff --git a/arch/riscv/dts/jh7110-starfive-visionfive-2-v1.3b.dts b/arch/riscv/dts/jh7110-starfive-visionfive-2-v1.3b.dts new file mode 100644 index 0000000000..3b3b3453a1 --- /dev/null +++ b/arch/riscv/dts/jh7110-starfive-visionfive-2-v1.3b.dts @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + */ + +/dts-v1/; +#include "jh7110-starfive-visionfive-2.dtsi" + +/ { + model = "StarFive VisionFive 2 v1.3B"; + compatible = "starfive,visionfive-2-v1.3b", "starfive,jh7110"; +}; diff --git a/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi b/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi new file mode 100644 index 0000000000..e669c2a26a --- /dev/null +++ b/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi @@ -0,0 +1,253 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT +/* + * Copyright (C) 2022 StarFive Technology Co., Ltd. + */ + +/dts-v1/; + +#include "jh7110.dtsi" +#include <dt-bindings/pinctrl/pinctrl-starfive-jh7110.h> +/ { + aliases { + serial0 = &uart0; + spi0 = &qspi; + mmc0 = &mmc0; + mmc1 = &mmc1; + }; + + chosen { + stdout-path = "serial0:115200"; + }; + + cpus { + timebase-frequency = <4000000>; + }; + + memory@40000000 { + device_type = "memory"; + reg = <0x0 0x40000000 0x2 0x0>; + }; +}; + +&S7_0 { + status = "okay"; +}; + +&osc { + clock-frequency = <24000000>; +}; + +&rtc_osc { + clock-frequency = <32768>; +}; + +&gmac0_rmii_refin { + clock-frequency = <50000000>; +}; + +&gmac0_rgmii_rxin { + clock-frequency = <125000000>; +}; + +&gmac1_rmii_refin { + clock-frequency = <50000000>; +}; + +&gmac1_rgmii_rxin { + clock-frequency = <125000000>; +}; + +&i2stx_bclk_ext { + clock-frequency = <12288000>; +}; + +&i2stx_lrck_ext { + clock-frequency = <192000>; +}; + +&i2srx_bclk_ext { + clock-frequency = <12288000>; +}; + +&i2srx_lrck_ext { + clock-frequency = <192000>; +}; + +&tdm_ext { + clock-frequency = <49152000>; +}; + +&mclk_ext { + clock-frequency = <12288000>; +}; + +&sysgpio { + status = "okay"; + uart0_pins: uart0-0 { + tx-pins { + pinmux = <GPIOMUX(5, GPOUT_SYS_UART0_TX, + GPOEN_ENABLE, GPI_NONE)>; + bias-disable; + drive-strength = <12>; + input-disable; + input-schmitt-disable; + slew-rate = <0>; + }; + + rx-pins { + pinmux = <GPIOMUX(6, GPOUT_LOW, + GPOEN_DISABLE, GPI_SYS_UART0_RX)>; + bias-pull-up; + drive-strength = <2>; + input-enable; + input-schmitt-enable; + slew-rate = <0>; + }; + }; + + mmc0_pins: mmc0-pins { + mmc0-pins-rest { + pinmux = <GPIOMUX(62, GPOUT_SYS_SDIO0_RST, + GPOEN_ENABLE, GPI_NONE)>; + bias-pull-up; + drive-strength = <12>; + input-disable; + input-schmitt-disable; + slew-rate = <0>; + }; + }; + + sdcard1_pins: sdcard1-pins { + sdcard1-pins0 { + pinmux = <GPIOMUX(10, GPOUT_SYS_SDIO1_CLK, + GPOEN_ENABLE, GPI_NONE)>; + bias-pull-up; + drive-strength = <12>; + input-disable; + input-schmitt-disable; + slew-rate = <0>; + }; + + sdcard1-pins1 { + pinmux = <GPIOMUX(9, GPOUT_SYS_SDIO1_CMD, + GPOEN_SYS_SDIO1_CMD, GPI_SYS_SDIO1_CMD)>; + bias-pull-up; + drive-strength = <12>; + input-enable; + input-schmitt-enable; + slew-rate = <0>; + }; + + sdcard1-pins2 { + pinmux = <GPIOMUX(11, GPOUT_SYS_SDIO1_DATA0, + GPOEN_SYS_SDIO1_DATA0, GPI_SYS_SDIO1_DATA0)>; + bias-pull-up; + drive-strength = <12>; + input-enable; + input-schmitt-enable; + slew-rate = <0>; + }; + + sdcard1-pins3 { + pinmux = <GPIOMUX(12, GPOUT_SYS_SDIO1_DATA1, + GPOEN_SYS_SDIO1_DATA1, GPI_SYS_SDIO1_DATA1)>; + bias-pull-up; + drive-strength = <12>; + input-enable; + input-schmitt-enable; + slew-rate = <0>; + }; + + sdcard1-pins4 { + pinmux = <GPIOMUX(7, GPOUT_SYS_SDIO1_DATA2, + GPOEN_SYS_SDIO1_DATA2, GPI_SYS_SDIO1_DATA2)>; + bias-pull-up; + drive-strength = <12>; + input-enable; + input-schmitt-enable; + slew-rate = <0>; + }; + + sdcard1-pins5 { + pinmux = <GPIOMUX(8, GPOUT_SYS_SDIO1_DATA3, + GPOEN_SYS_SDIO1_DATA3, GPI_SYS_SDIO1_DATA3)>; + bias-pull-up; + drive-strength = <12>; + input-enable; + input-schmitt-enable; + slew-rate = <0>; + }; + }; +}; + +&mmc0 { + compatible = "snps,dw-mshc"; + max-frequency = <100000000>; + bus-width = <8>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + non-removable; + cap-mmc-hw-reset; + post-power-on-delay-ms = <200>; + status = "okay"; + +}; + +&mmc1 { + compatible = "snps,dw-mshc"; + max-frequency = <100000000>; + bus-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&sdcard1_pins>; + no-sdio; + no-mmc; + broken-cd; + cap-sd-highspeed; + post-power-on-delay-ms = <200>; + status = "okay"; +}; + +&uart0 { + reg-offset = <0>; + current-speed = <115200>; + clock-frequency = <24000000>; + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins>; + status = "okay"; +}; + +&qspi { + spi-max-frequency = <250000000>; + status = "okay"; + + nor-flash@0 { + compatible = "jedec,spi-nor"; + reg=<0>; + spi-max-frequency = <100000000>; + cdns,tshsl-ns = <1>; + cdns,tsd2d-ns = <1>; + cdns,tchsh-ns = <1>; + cdns,tslch-ns = <1>; + }; +}; + +&syscrg { + assigned-clocks = <&syscrg JH7110_SYSCLK_CPU_ROOT>, + <&syscrg JH7110_SYSCLK_BUS_ROOT>, + <&syscrg JH7110_SYSCLK_PERH_ROOT>, + <&syscrg JH7110_SYSCLK_QSPI_REF>; + assigned-clock-parents = <&syscrg JH7110_SYSCLK_PLL0_OUT>, + <&syscrg JH7110_SYSCLK_PLL2_OUT>, + <&syscrg JH7110_SYSCLK_PLL2_OUT>, + <&syscrg JH7110_SYSCLK_QSPI_REF_SRC>; + assigned-clock-rates = <0>, <0>, <0>, <0>; +}; + +&aoncrg { + assigned-clocks = <&aoncrg JH7110_AONCLK_APB_FUNC>; + assigned-clock-parents = <&osc>; + assigned-clock-rates = <0>; +};
+/dts-v1/;
- aliases {
serial0 = &uart0;
spi0 = &qspi;
mmc0 = &mmc0;
mmc1 = &mmc1;
- chosen {
- cpus {
- memory@40000000 {
+&S7_0 {
- status = "okay";
Please forgive me if I am missing something obvious, but should this be be in -u-boot.dtsi instead?
Cheers, Conor.
+/dts-v1/;
- aliases {
serial0 = &uart0;
spi0 = &qspi;
mmc0 = &mmc0;
mmc1 = &mmc1;
- chosen {
- cpus {
- memory@40000000 {
+&S7_0 {
- status = "okay";
Thanks. I will move this node to -u-boot.dtsi.
Cheers, Conor.
This is the initial basic config for StarFive VisionFive v2 board. It includes consol, Norflash, sdio, ddr etc.
Signed-off-by: Yanhong Wang yanhong.wang@starfivetech.com --- configs/starfive_visionfive2_defconfig | 79 ++++++++++++++++++++++++++ 1 file changed, 79 insertions(+) create mode 100644 configs/starfive_visionfive2_defconfig
diff --git a/configs/starfive_visionfive2_defconfig b/configs/starfive_visionfive2_defconfig new file mode 100644 index 0000000000..550d0ff3ab --- /dev/null +++ b/configs/starfive_visionfive2_defconfig @@ -0,0 +1,79 @@ +CONFIG_RISCV=y +CONFIG_SYS_MALLOC_LEN=0x800000 +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_SPL_GPIO=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80000000 +CONFIG_SPL_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="jh7110-starfive-visionfive-2-v1.3b" +CONFIG_SPL_TEXT_BASE=0x8000000 +CONFIG_SYS_PROMPT="StarFive #" +CONFIG_DM_RESET=y +CONFIG_SPL_MMC=y +CONFIG_SPL_STACK=0x8180000 +CONFIG_SPL=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_TARGET_STARFIVE_VISIONFIVE2=y +CONFIG_SPL_OPENSBI_LOAD_ADDR=0x40000000 +CONFIG_ARCH_RV64I=y +CONFIG_CMODEL_MEDANY=y +CONFIG_RISCV_SMODE=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_QSPI_BOOT=y +CONFIG_SD_BOOT=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 debug rootwait earlycon=sbi" +CONFIG_USE_PREBOOT=y +CONFIG_PREBOOT="setenv fdt_addr ${fdtcontroladdr};fdt addr ${fdtcontroladdr};" +CONFIG_DEFAULT_FDT_FILE="starfive/jh7110-starfive-visionfive-2-v1.3b.dtb" +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x0 +CONFIG_SPL_BSS_START_ADDR=0x8040000 +CONFIG_SPL_BSS_MAX_SIZE=0x10000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x80000000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x400000 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=0x2 +CONFIG_SPL_DM_SPI_FLASH=y +CONFIG_SPL_DM_RESET=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_CBSIZE=256 +CONFIG_SYS_PBSIZE=276 +CONFIG_SYS_BOOTM_LEN=0x4000000 +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_TFTPPUT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_JH7110=y +# CONFIG_I2C is not set +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_SPL_MMC_HS400_SUPPORT=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_SNPS=y +CONFIG_SF_DEFAULT_SPEED=100000000 +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_PINCTRL=y +CONFIG_PINCONF=y +CONFIG_SPL_PINCTRL=y +CONFIG_SPL_PINCONF=y +CONFIG_SPL_PINCTRL_STARFIVE=y +CONFIG_SPL_PINCTRL_STARFIVE_JH7110=y +CONFIG_PINCTRL_STARFIVE=y +# CONFIG_RAM_SIFIVE is not set +CONFIG_SYS_NS16550=y +CONFIG_CADENCE_QSPI=y +CONFIG_TIMER_EARLY=y +CONFIG_OF_LIBFDT_OVERLAY=y
Hey Yanhong,
On Fri, Mar 03, 2023 at 11:24:15AM +0800, Yanhong Wang wrote:
This series of patches base on the latest branch/master, and add support for the StarFive JH7110 RISC-V SoC and VisionFive V2 board. In order for this to be achieved, the respective DT nodes have been added, and the required defconfigs have been added to the boards' defconfig. What is more, the basic required DM drivers have been added, such as reset, clock, pinctrl, uart, ram etc.
Note that the register base address of reset controller is same with the clock controller. Therefore, there is no device tree node alone for reset driver. It binds device node in the clock driver.
The u-boot-spl and u-boot has been tested on the StarFive VisionFive 2 boards which equip with JH7110 SoC and works normally.
For more information and support, you can visit RVspace wiki[1].
I gave you some tested-bys for the series on the previous version, did you omit those here intentionally?
Cheers, Conor.
On 2023/3/4 5:08, Conor Dooley wrote:
Hey Yanhong,
Sorry, I forgot to add the information of tested-bys, it was not intentionally omitted.
Cheers, Conor.
Conor Dooley
Yanhong Wang
yanhong wang
