[U-Boot] [PATCH 0/2] Add support for GCC 5.x for MicroBlaze
This patch series fixes some issues with some MicroBlaze functions and declarations that are not compatible with newer C standards (e.g. C99) this includes the default C standard set by the GCC 5.x compiler (which is gnu11 by default).
This series is split into two patches, the first patch being some code style clean up, followed by the patch that fixes the compatiblity.
Nathan Rossi (2): microblaze: Fix style issues in header files microblaze: Fix C99/gnu99 compatiblity for inline functions
arch/microblaze/include/asm/bitops.h | 63 ++++++++++++------------------------ arch/microblaze/include/asm/system.h | 2 +- 2 files changed, 22 insertions(+), 43 deletions(-)
Fix various style issues in MicroBlaze header files. Specifically fixing style voilations including '__inline__', 'foo * bar' and 'void foo ('.
Signed-off-by: Nathan Rossi nathan@nathanrossi.com Cc: Michal Simek monstr@monstr.eu Cc: Tom Rini trini@konsulko.com --- arch/microblaze/include/asm/bitops.h | 66 ++++++++++++++++++------------------ arch/microblaze/include/asm/system.h | 2 +- 2 files changed, 34 insertions(+), 34 deletions(-)
diff --git a/arch/microblaze/include/asm/bitops.h b/arch/microblaze/include/asm/bitops.h index 0ac78d7..d42ee61 100644 --- a/arch/microblaze/include/asm/bitops.h +++ b/arch/microblaze/include/asm/bitops.h @@ -17,31 +17,31 @@ * The __ functions are not atomic */
-extern void set_bit(int nr, volatile void * addr); -extern void __set_bit(int nr, volatile void * addr); +extern void set_bit(int nr, volatile void *addr); +extern void __set_bit(int nr, volatile void *addr);
-extern void clear_bit(int nr, volatile void * addr); +extern void clear_bit(int nr, volatile void *addr); #define __clear_bit(nr, addr) clear_bit(nr, addr) #define PLATFORM__CLEAR_BIT
-extern void change_bit(int nr, volatile void * addr); -extern void __change_bit(int nr, volatile void * addr); -extern int test_and_set_bit(int nr, volatile void * addr); -extern int __test_and_set_bit(int nr, volatile void * addr); -extern int test_and_clear_bit(int nr, volatile void * addr); -extern int __test_and_clear_bit(int nr, volatile void * addr); -extern int test_and_change_bit(int nr, volatile void * addr); -extern int __test_and_change_bit(int nr, volatile void * addr); -extern int __constant_test_bit(int nr, const volatile void * addr); -extern int __test_bit(int nr, volatile void * addr); -extern int find_first_zero_bit(void * addr, unsigned size); -extern int find_next_zero_bit (void * addr, int size, int offset); +extern void change_bit(int nr, volatile void *addr); +extern void __change_bit(int nr, volatile void *addr); +extern int test_and_set_bit(int nr, volatile void *addr); +extern int __test_and_set_bit(int nr, volatile void *addr); +extern int test_and_clear_bit(int nr, volatile void *addr); +extern int __test_and_clear_bit(int nr, volatile void *addr); +extern int test_and_change_bit(int nr, volatile void *addr); +extern int __test_and_change_bit(int nr, volatile void *addr); +extern int __constant_test_bit(int nr, const volatile void *addr); +extern int __test_bit(int nr, volatile void *addr); +extern int find_first_zero_bit(void *addr, unsigned size); +extern int find_next_zero_bit(void *addr, int size, int offset);
/* * ffz = Find First Zero in word. Undefined if no zero exists, * so code should check against ~0UL first.. */ -extern __inline__ unsigned long ffz(unsigned long word) +extern inline unsigned long ffz(unsigned long word) { unsigned long result = 0;
@@ -53,7 +53,7 @@ extern __inline__ unsigned long ffz(unsigned long word) }
-extern __inline__ void set_bit(int nr, volatile void * addr) +extern inline void set_bit(int nr, volatile void *addr) { int * a = (int *) addr; int mask; @@ -66,7 +66,7 @@ extern __inline__ void set_bit(int nr, volatile void * addr) restore_flags(flags); }
-extern __inline__ void __set_bit(int nr, volatile void * addr) +extern inline void __set_bit(int nr, volatile void *addr) { int * a = (int *) addr; int mask; @@ -83,7 +83,7 @@ extern __inline__ void __set_bit(int nr, volatile void * addr) #define smp_mb__before_clear_bit() barrier() #define smp_mb__after_clear_bit() barrier()
-extern __inline__ void clear_bit(int nr, volatile void * addr) +extern inline void clear_bit(int nr, volatile void *addr) { int * a = (int *) addr; int mask; @@ -96,7 +96,7 @@ extern __inline__ void clear_bit(int nr, volatile void * addr) restore_flags(flags); }
-extern __inline__ void change_bit(int nr, volatile void * addr) +extern inline void change_bit(int nr, volatile void *addr) { int mask; unsigned long flags; @@ -109,7 +109,7 @@ extern __inline__ void change_bit(int nr, volatile void * addr) restore_flags(flags); }
-extern __inline__ void __change_bit(int nr, volatile void * addr) +extern inline void __change_bit(int nr, volatile void *addr) { int mask; unsigned long *ADDR = (unsigned long *) addr; @@ -119,7 +119,7 @@ extern __inline__ void __change_bit(int nr, volatile void * addr) *ADDR ^= mask; }
-extern __inline__ int test_and_set_bit(int nr, volatile void * addr) +extern inline int test_and_set_bit(int nr, volatile void *addr) { int mask, retval; volatile unsigned int *a = (volatile unsigned int *) addr; @@ -135,7 +135,7 @@ extern __inline__ int test_and_set_bit(int nr, volatile void * addr) return retval; }
-extern __inline__ int __test_and_set_bit(int nr, volatile void * addr) +extern inline int __test_and_set_bit(int nr, volatile void *addr) { int mask, retval; volatile unsigned int *a = (volatile unsigned int *) addr; @@ -147,7 +147,7 @@ extern __inline__ int __test_and_set_bit(int nr, volatile void * addr) return retval; }
-extern __inline__ int test_and_clear_bit(int nr, volatile void * addr) +extern inline int test_and_clear_bit(int nr, volatile void *addr) { int mask, retval; volatile unsigned int *a = (volatile unsigned int *) addr; @@ -163,7 +163,7 @@ extern __inline__ int test_and_clear_bit(int nr, volatile void * addr) return retval; }
-extern __inline__ int __test_and_clear_bit(int nr, volatile void * addr) +extern inline int __test_and_clear_bit(int nr, volatile void *addr) { int mask, retval; volatile unsigned int *a = (volatile unsigned int *) addr; @@ -175,7 +175,7 @@ extern __inline__ int __test_and_clear_bit(int nr, volatile void * addr) return retval; }
-extern __inline__ int test_and_change_bit(int nr, volatile void * addr) +extern inline int test_and_change_bit(int nr, volatile void *addr) { int mask, retval; volatile unsigned int *a = (volatile unsigned int *) addr; @@ -191,7 +191,7 @@ extern __inline__ int test_and_change_bit(int nr, volatile void * addr) return retval; }
-extern __inline__ int __test_and_change_bit(int nr, volatile void * addr) +extern inline int __test_and_change_bit(int nr, volatile void *addr) { int mask, retval; volatile unsigned int *a = (volatile unsigned int *) addr; @@ -206,12 +206,12 @@ extern __inline__ int __test_and_change_bit(int nr, volatile void * addr) /* * This routine doesn't need to be atomic. */ -extern __inline__ int __constant_test_bit(int nr, const volatile void * addr) +extern inline int __constant_test_bit(int nr, const volatile void *addr) { return ((1UL << (nr & 31)) & (((const volatile unsigned int *) addr)[nr >> 5])) != 0; }
-extern __inline__ int __test_bit(int nr, volatile void * addr) +extern inline int __test_bit(int nr, volatile void *addr) { int * a = (int *) addr; int mask; @@ -229,7 +229,7 @@ extern __inline__ int __test_bit(int nr, volatile void * addr) #define find_first_zero_bit(addr, size) \ find_next_zero_bit((addr), (size), 0)
-extern __inline__ int find_next_zero_bit (void * addr, int size, int offset) +extern inline int find_next_zero_bit(void *addr, int size, int offset) { unsigned long *p = ((unsigned long *) addr) + (offset >> 5); unsigned long result = offset & ~31UL; @@ -275,7 +275,7 @@ found_middle: #define hweight8(x) generic_hweight8(x)
-extern __inline__ int ext2_set_bit(int nr, volatile void * addr) +extern inline int ext2_set_bit(int nr, volatile void *addr) { int mask, retval; unsigned long flags; @@ -290,7 +290,7 @@ extern __inline__ int ext2_set_bit(int nr, volatile void * addr) return retval; }
-extern __inline__ int ext2_clear_bit(int nr, volatile void * addr) +extern inline int ext2_clear_bit(int nr, volatile void *addr) { int mask, retval; unsigned long flags; @@ -305,7 +305,7 @@ extern __inline__ int ext2_clear_bit(int nr, volatile void * addr) return retval; }
-extern __inline__ int ext2_test_bit(int nr, const volatile void * addr) +extern inline int ext2_test_bit(int nr, const volatile void *addr) { int mask; const volatile unsigned char *ADDR = (const unsigned char *) addr; diff --git a/arch/microblaze/include/asm/system.h b/arch/microblaze/include/asm/system.h index 0297a11..3090835 100644 --- a/arch/microblaze/include/asm/system.h +++ b/arch/microblaze/include/asm/system.h @@ -131,7 +131,7 @@ extern void *switch_thread (struct thread_struct *last, ((__typeof__ (*(ptr)))__xchg ((unsigned long)(with), (ptr), sizeof (*(ptr)))) #define tas(ptr) (xchg ((ptr), 1))
-extern inline unsigned long __xchg (unsigned long with, +extern inline unsigned long __xchg(unsigned long with, __volatile__ void *ptr, int size) { unsigned long tmp, flags;
'extern inline' is not portable across various C standards. To ensure compatiblity with various standards/compilers change the functions to static inline. This is a portable construct and serves as a comparable definition to 'extern inline' from the gnu90 standard.
Additionally remove the function prototypes as they are not required due to the functions being declared static and functions are correctly ordered based on dependence.
Signed-off-by: Nathan Rossi nathan@nathanrossi.com Cc: Michal Simek monstr@monstr.eu Cc: Tom Rini trini@konsulko.com --- arch/microblaze/include/asm/bitops.h | 63 ++++++++++++------------------------ arch/microblaze/include/asm/system.h | 2 +- 2 files changed, 22 insertions(+), 43 deletions(-)
diff --git a/arch/microblaze/include/asm/bitops.h b/arch/microblaze/include/asm/bitops.h index d42ee61..2c11d1a 100644 --- a/arch/microblaze/include/asm/bitops.h +++ b/arch/microblaze/include/asm/bitops.h @@ -10,38 +10,14 @@
#ifdef __KERNEL__ /* - * Function prototypes to keep gcc -Wall happy - */ - -/* * The __ functions are not atomic */
-extern void set_bit(int nr, volatile void *addr); -extern void __set_bit(int nr, volatile void *addr); - -extern void clear_bit(int nr, volatile void *addr); -#define __clear_bit(nr, addr) clear_bit(nr, addr) -#define PLATFORM__CLEAR_BIT - -extern void change_bit(int nr, volatile void *addr); -extern void __change_bit(int nr, volatile void *addr); -extern int test_and_set_bit(int nr, volatile void *addr); -extern int __test_and_set_bit(int nr, volatile void *addr); -extern int test_and_clear_bit(int nr, volatile void *addr); -extern int __test_and_clear_bit(int nr, volatile void *addr); -extern int test_and_change_bit(int nr, volatile void *addr); -extern int __test_and_change_bit(int nr, volatile void *addr); -extern int __constant_test_bit(int nr, const volatile void *addr); -extern int __test_bit(int nr, volatile void *addr); -extern int find_first_zero_bit(void *addr, unsigned size); -extern int find_next_zero_bit(void *addr, int size, int offset); - /* * ffz = Find First Zero in word. Undefined if no zero exists, * so code should check against ~0UL first.. */ -extern inline unsigned long ffz(unsigned long word) +static inline unsigned long ffz(unsigned long word) { unsigned long result = 0;
@@ -53,7 +29,7 @@ extern inline unsigned long ffz(unsigned long word) }
-extern inline void set_bit(int nr, volatile void *addr) +static inline void set_bit(int nr, volatile void *addr) { int * a = (int *) addr; int mask; @@ -66,7 +42,7 @@ extern inline void set_bit(int nr, volatile void *addr) restore_flags(flags); }
-extern inline void __set_bit(int nr, volatile void *addr) +static inline void __set_bit(int nr, volatile void *addr) { int * a = (int *) addr; int mask; @@ -83,7 +59,7 @@ extern inline void __set_bit(int nr, volatile void *addr) #define smp_mb__before_clear_bit() barrier() #define smp_mb__after_clear_bit() barrier()
-extern inline void clear_bit(int nr, volatile void *addr) +static inline void clear_bit(int nr, volatile void *addr) { int * a = (int *) addr; int mask; @@ -96,7 +72,10 @@ extern inline void clear_bit(int nr, volatile void *addr) restore_flags(flags); }
-extern inline void change_bit(int nr, volatile void *addr) +#define __clear_bit(nr, addr) clear_bit(nr, addr) +#define PLATFORM__CLEAR_BIT + +static inline void change_bit(int nr, volatile void *addr) { int mask; unsigned long flags; @@ -109,7 +88,7 @@ extern inline void change_bit(int nr, volatile void *addr) restore_flags(flags); }
-extern inline void __change_bit(int nr, volatile void *addr) +static inline void __change_bit(int nr, volatile void *addr) { int mask; unsigned long *ADDR = (unsigned long *) addr; @@ -119,7 +98,7 @@ extern inline void __change_bit(int nr, volatile void *addr) *ADDR ^= mask; }
-extern inline int test_and_set_bit(int nr, volatile void *addr) +static inline int test_and_set_bit(int nr, volatile void *addr) { int mask, retval; volatile unsigned int *a = (volatile unsigned int *) addr; @@ -135,7 +114,7 @@ extern inline int test_and_set_bit(int nr, volatile void *addr) return retval; }
-extern inline int __test_and_set_bit(int nr, volatile void *addr) +static inline int __test_and_set_bit(int nr, volatile void *addr) { int mask, retval; volatile unsigned int *a = (volatile unsigned int *) addr; @@ -147,7 +126,7 @@ extern inline int __test_and_set_bit(int nr, volatile void *addr) return retval; }
-extern inline int test_and_clear_bit(int nr, volatile void *addr) +static inline int test_and_clear_bit(int nr, volatile void *addr) { int mask, retval; volatile unsigned int *a = (volatile unsigned int *) addr; @@ -163,7 +142,7 @@ extern inline int test_and_clear_bit(int nr, volatile void *addr) return retval; }
-extern inline int __test_and_clear_bit(int nr, volatile void *addr) +static inline int __test_and_clear_bit(int nr, volatile void *addr) { int mask, retval; volatile unsigned int *a = (volatile unsigned int *) addr; @@ -175,7 +154,7 @@ extern inline int __test_and_clear_bit(int nr, volatile void *addr) return retval; }
-extern inline int test_and_change_bit(int nr, volatile void *addr) +static inline int test_and_change_bit(int nr, volatile void *addr) { int mask, retval; volatile unsigned int *a = (volatile unsigned int *) addr; @@ -191,7 +170,7 @@ extern inline int test_and_change_bit(int nr, volatile void *addr) return retval; }
-extern inline int __test_and_change_bit(int nr, volatile void *addr) +static inline int __test_and_change_bit(int nr, volatile void *addr) { int mask, retval; volatile unsigned int *a = (volatile unsigned int *) addr; @@ -206,12 +185,12 @@ extern inline int __test_and_change_bit(int nr, volatile void *addr) /* * This routine doesn't need to be atomic. */ -extern inline int __constant_test_bit(int nr, const volatile void *addr) +static inline int __constant_test_bit(int nr, const volatile void *addr) { return ((1UL << (nr & 31)) & (((const volatile unsigned int *) addr)[nr >> 5])) != 0; }
-extern inline int __test_bit(int nr, volatile void *addr) +static inline int __test_bit(int nr, volatile void *addr) { int * a = (int *) addr; int mask; @@ -229,7 +208,7 @@ extern inline int __test_bit(int nr, volatile void *addr) #define find_first_zero_bit(addr, size) \ find_next_zero_bit((addr), (size), 0)
-extern inline int find_next_zero_bit(void *addr, int size, int offset) +static inline int find_next_zero_bit(void *addr, int size, int offset) { unsigned long *p = ((unsigned long *) addr) + (offset >> 5); unsigned long result = offset & ~31UL; @@ -275,7 +254,7 @@ found_middle: #define hweight8(x) generic_hweight8(x)
-extern inline int ext2_set_bit(int nr, volatile void *addr) +static inline int ext2_set_bit(int nr, volatile void *addr) { int mask, retval; unsigned long flags; @@ -290,7 +269,7 @@ extern inline int ext2_set_bit(int nr, volatile void *addr) return retval; }
-extern inline int ext2_clear_bit(int nr, volatile void *addr) +static inline int ext2_clear_bit(int nr, volatile void *addr) { int mask, retval; unsigned long flags; @@ -305,7 +284,7 @@ extern inline int ext2_clear_bit(int nr, volatile void *addr) return retval; }
-extern inline int ext2_test_bit(int nr, const volatile void *addr) +static inline int ext2_test_bit(int nr, const volatile void *addr) { int mask; const volatile unsigned char *ADDR = (const unsigned char *) addr; diff --git a/arch/microblaze/include/asm/system.h b/arch/microblaze/include/asm/system.h index 3090835..3107748 100644 --- a/arch/microblaze/include/asm/system.h +++ b/arch/microblaze/include/asm/system.h @@ -131,7 +131,7 @@ extern void *switch_thread (struct thread_struct *last, ((__typeof__ (*(ptr)))__xchg ((unsigned long)(with), (ptr), sizeof (*(ptr)))) #define tas(ptr) (xchg ((ptr), 1))
-extern inline unsigned long __xchg(unsigned long with, +static inline unsigned long __xchg(unsigned long with, __volatile__ void *ptr, int size) { unsigned long tmp, flags;
Nathan Rossi nathan@nathanrossi.com writes:
Acked-by: Mans Rullgard mans@mansr.com
- Function prototypes to keep gcc -Wall happy
- The __ functions are not atomic
- ffz = Find First Zero in word. Undefined if no zero exists,
- so code should check against ~0UL first..
- This routine doesn't need to be atomic.
-extern inline unsigned long __xchg(unsigned long with, +static inline unsigned long __xchg(unsigned long with, __volatile__ void *ptr, int size) { unsigned long tmp, flags; -- 2.6.2
Applied both.
Thanks, Michal
Michal Simek
Måns Rullgård
Nathan Rossi
