[U-Boot] [PATCH v2 01/20] arch: powerpc: add eSDHC node to p1020 dts
Add eSDHC node to p1020 dts
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- Change in v2: remove the string "This patch is to" from commit information
arch/powerpc/dts/p1020-post.dtsi | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/powerpc/dts/p1020-post.dtsi b/arch/powerpc/dts/p1020-post.dtsi index 1e5e67804b..fb3b203a24 100644 --- a/arch/powerpc/dts/p1020-post.dtsi +++ b/arch/powerpc/dts/p1020-post.dtsi @@ -24,6 +24,13 @@ single-cpu-affinity; last-interrupt-source = <255>; }; + + esdhc: esdhc@2e000 { + compatible = "fsl,esdhc"; + reg = <0x2e000 0x1000>; + /* Filled in by U-Boot */ + clock-frequency = <0>; + }; };
/* PCIe controller base address 0x9000 */
Add eSDHC node to p2020 dts
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- arch/powerpc/dts/p2020-post.dtsi | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/powerpc/dts/p2020-post.dtsi b/arch/powerpc/dts/p2020-post.dtsi index f696f35960..c07ed66726 100644 --- a/arch/powerpc/dts/p2020-post.dtsi +++ b/arch/powerpc/dts/p2020-post.dtsi @@ -24,6 +24,13 @@ single-cpu-affinity; last-interrupt-source = <255>; }; + + esdhc: esdhc@2e000 { + compatible = "fsl,esdhc"; + reg = <0x2e000 0x1000>; + /* Filled in by U-Boot */ + clock-frequency = <0>; + }; };
/* PCIe controller base address 0x8000 */
Add eSDHC node to p2041 dts
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- arch/powerpc/dts/p2041.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/powerpc/dts/p2041.dtsi b/arch/powerpc/dts/p2041.dtsi index 55f7adc50e..cb83475d2a 100644 --- a/arch/powerpc/dts/p2041.dtsi +++ b/arch/powerpc/dts/p2041.dtsi @@ -59,6 +59,12 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + esdhc: esdhc@114000 { + compatible = "fsl,esdhc"; + reg = <0x114000 0x1000>; + clock-frequency = <0>; + }; };
pcie@ffe200000 {
Add eSDHC node to p3041 dts
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- arch/powerpc/dts/p3041.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/powerpc/dts/p3041.dtsi b/arch/powerpc/dts/p3041.dtsi index 197896d35a..6ab60a4ced 100644 --- a/arch/powerpc/dts/p3041.dtsi +++ b/arch/powerpc/dts/p3041.dtsi @@ -59,6 +59,12 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + esdhc: esdhc@114000 { + compatible = "fsl,esdhc"; + reg = <0x114000 0x1000>; + clock-frequency = <0>; + }; };
pcie@ffe200000 {
Add eSDHC node to p4080 dts
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- arch/powerpc/dts/p4080.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/powerpc/dts/p4080.dtsi b/arch/powerpc/dts/p4080.dtsi index ab766803a3..61ff5c2d67 100644 --- a/arch/powerpc/dts/p4080.dtsi +++ b/arch/powerpc/dts/p4080.dtsi @@ -79,6 +79,12 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + esdhc: esdhc@114000 { + compatible = "fsl,esdhc"; + reg = <0x114000 0x1000>; + clock-frequency = <0>; + } };
pcie@ffe200000 {
Add eSDHC node to p5040 dts
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- arch/powerpc/dts/p5040.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/powerpc/dts/p5040.dtsi b/arch/powerpc/dts/p5040.dtsi index 8ab123dca4..8128ac2376 100644 --- a/arch/powerpc/dts/p5040.dtsi +++ b/arch/powerpc/dts/p5040.dtsi @@ -58,6 +58,12 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + esdhc: esdhc@114000 { + compatible = "fsl,esdhc"; + reg = <0x114000 0x1000>; + clock-frequency = <0>; + }; };
pcie@ffe200000 {
Add eSDHC node to t102x dts
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- arch/powerpc/dts/t102x.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/powerpc/dts/t102x.dtsi b/arch/powerpc/dts/t102x.dtsi index c49fd21088..a0c97021dd 100644 --- a/arch/powerpc/dts/t102x.dtsi +++ b/arch/powerpc/dts/t102x.dtsi @@ -48,6 +48,12 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + esdhc: esdhc@114000 { + compatible = "fsl,esdhc"; + reg = <0x114000 0x1000>; + clock-frequency = <0>; + }; };
pcie@ffe240000 {
Add eSDHC node to t104x dts
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- arch/powerpc/dts/t104x.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/powerpc/dts/t104x.dtsi b/arch/powerpc/dts/t104x.dtsi index 59989677a2..c37a80f006 100644 --- a/arch/powerpc/dts/t104x.dtsi +++ b/arch/powerpc/dts/t104x.dtsi @@ -58,6 +58,12 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + esdhc: esdhc@114000 { + compatible = "fsl,esdhc"; + reg = <0x114000 0x1000>; + clock-frequency = <0>; + }; };
pcie@ffe240000 {
Add eSDHC node to t4240 dts
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- arch/powerpc/dts/t4240.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/powerpc/dts/t4240.dtsi b/arch/powerpc/dts/t4240.dtsi index fc34974c7f..b09b40d8c6 100644 --- a/arch/powerpc/dts/t4240.dtsi +++ b/arch/powerpc/dts/t4240.dtsi @@ -98,6 +98,12 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + esdhc: esdhc@114000 { + compatible = "fsl,esdhc"; + reg = <0x114000 0x1000>; + clock-frequency = <0>; + }; };
pcie@ffe240000 {
Use block layer to read from mmc
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- board/freescale/common/sdhc_boot.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/freescale/common/sdhc_boot.c b/board/freescale/common/sdhc_boot.c index 357aba9122..a1c7a94a90 100644 --- a/board/freescale/common/sdhc_boot.c +++ b/board/freescale/common/sdhc_boot.c @@ -28,7 +28,11 @@ int mmc_get_env_addr(struct mmc *mmc, int copy, u32 *env_addr) return 1;
/* read out the first block, get the config data information */ +#ifdef CONFIG_BLK + n = blk_dread(mmc_get_blk_desc(mmc), 0, 1, tmp_buf); +#else n = mmc->block_dev.block_read(&mmc->block_dev, 0, 1, tmp_buf); +#endif if (!n) { free(tmp_buf); return 1;
Enable eSDHC device module for P1020RDB board
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + 12 files changed, 12 insertions(+)
diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index c4e41f2010..286e18d5e4 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -69,3 +69,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index b21fc2159b..318a76c2f5 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -64,3 +64,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 2f69683379..e3aaa0e5df 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -65,3 +65,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 6145bf2cc6..a8c599242a 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -53,3 +53,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 832c96967e..27d878f8ed 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -68,3 +68,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 2b5537bc32..6d80c95414 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -63,3 +63,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index dc4f7d6a70..e8e9c57a35 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -64,3 +64,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index bd0bb1796c..27fafff8b7 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -52,3 +52,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index acbb9e0159..573d4eb4c2 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -72,3 +72,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index 208138f594..3880f96bb7 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -67,3 +67,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 960f2718a9..8a8780f3a4 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -68,3 +68,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 217ae7b1e6..b14a2226e9 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -56,3 +56,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y
Enable eSDHC device module for P2020RDB board
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + 8 files changed, 8 insertions(+)
diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index 5e279814a1..04d874dca2 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -74,3 +74,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 49a7c8052d..c09a8ea86d 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -69,3 +69,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 59fce53690..c7898e9b41 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -70,3 +70,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 401742463d..94450a0094 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -58,3 +58,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 3c65108d7d..eed499b091 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -73,3 +73,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 05f42aef8a..0ef15bef63 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -68,3 +68,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index bfb7026f2d..97eb775f4f 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -69,3 +69,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 6c7ac9d759..2e8b0aa876 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -57,3 +57,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y
Enable eSDHC device module for P2041RDB board
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- configs/P2041RDB_NAND_defconfig | 1 + configs/P2041RDB_SDCARD_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 1 + configs/P2041RDB_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 70b9190b53..78b407bd6a 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -53,3 +53,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index 2542526aee..2ddd83f512 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -52,3 +52,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index 4edb581f7c..ed8e07fb35 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -52,3 +52,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index 8a158f52b7..a736468716 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -51,3 +51,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y
Enable eSDHC device module for P3041DS board
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- configs/P3041DS_NAND_defconfig | 1 + configs/P3041DS_SDCARD_defconfig | 1 + configs/P3041DS_SPIFLASH_defconfig | 1 + configs/P3041DS_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index 7f8145fe4c..a2aef8fe80 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -53,3 +53,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index c6b2750cc2..c1abc95685 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -52,3 +52,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index 1b247cc931..fcbb7f4705 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -52,3 +52,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index f8e30efbd4..7b5dca10c3 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -51,3 +51,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y
Enable eSDHC device module for P4080DS board
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- configs/P4080DS_SDCARD_defconfig | 1 + configs/P4080DS_SPIFLASH_defconfig | 1 + configs/P4080DS_defconfig | 1 + 3 files changed, 3 insertions(+)
diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index 0c309f92ca..81d79e0c89 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -52,3 +52,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index 070ade5cfa..7c9ba8fc4f 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -52,3 +52,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index 0a35266cd5..38d866b32a 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -51,3 +51,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y
Enable eSDHC device module for P5040DS board
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- configs/P5040DS_NAND_defconfig | 1 + configs/P5040DS_SDCARD_defconfig | 1 + configs/P5040DS_SPIFLASH_defconfig | 1 + configs/P5040DS_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index 847250e0d9..f108a8964b 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -54,3 +54,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index a61d36d1ff..1dbdd33c7f 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -53,3 +53,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index 4eaa35448b..f446c7c9e8 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -53,3 +53,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index 2e67dce267..f22d95cd29 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -52,3 +52,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y
Enable eSDHC device module for T1024RDB board
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index c38912dc38..c809c25d3d 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -76,3 +76,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 5215953caf..a70159327b 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -73,3 +73,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 2e6b81b0c2..0515ece1cd 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -74,3 +74,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index ccd9112832..2b300673f0 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -60,3 +60,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y
Enable eSDHC device module for T1042D4RDB board
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 920af5b4c4..61532c13b4 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -76,3 +76,4 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_VIDEO=y CONFIG_CFB_CONSOLE_ANSI=y +CONFIG_DM_MMC=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index e532366218..f91108b447 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -73,3 +73,4 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_VIDEO=y CONFIG_CFB_CONSOLE_ANSI=y +CONFIG_DM_MMC=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 78e4582113..e5093a98eb 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -74,3 +74,4 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_VIDEO=y CONFIG_CFB_CONSOLE_ANSI=y +CONFIG_DM_MMC=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 3a4699b3ef..0a590b9446 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -60,3 +60,4 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_VIDEO=y CONFIG_CFB_CONSOLE_ANSI=y +CONFIG_DM_MMC=y
Enable eSDHC device module for T2080RDB board
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2080RDB_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index dcd57f7b3a..fc43fe5499 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -72,3 +72,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 235e8ee514..5061f7aa05 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -69,3 +69,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 7b64b7d490..b33c2de334 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -70,3 +70,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index 69ee626ee0..2da4ed2f44 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -56,3 +56,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y
Enable eSDHC device module for T4240RDB board
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- configs/T4240RDB_SDCARD_defconfig | 1 + configs/T4240RDB_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 7f97166860..61f786dc67 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -63,3 +63,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 81bd59566d..ee25f1fbaa 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -50,3 +50,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y
Hi Priyanka,
I worried other ppc ip uboot dm patch will rely on my patch. Please help merge my patch to upstream asap,
Regards, Yinbo -----Original Message----- From: Yinbo Zhu yinbo.zhu@nxp.com Sent: 2019年9月18日 10:52 To: Wolfgang Denk wd@denx.de; Priyanka Jain priyanka.jain@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; u-boot@lists.denx.de Cc: Yinbo Zhu yinbo.zhu@nxp.com; Xiaobo Xie xiaobo.xie@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Bin Meng bmeng.cn@gmail.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Adam Ford aford173@gmail.com; Patrick Delaunay patrick.delaunay@st.com; Jeremy Gebben jgebben@sweptlaser.com; Joe Hershberger joe.hershberger@ni.com; Y.b. Lu yangbo.lu@nxp.com Subject: [PATCH v2 20/20] configs: enable eSDHC device module for T4240RDB board
diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 7f97166860..61f786dc67 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -63,3 +63,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 81bd59566d..ee25f1fbaa 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -50,3 +50,4 @@ CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y -- 2.17.1
Yinbo Zhu
