[U-Boot] [PATCH 2/2][v2] powerpc: make espi can read more than 0xFFFA bytes
espi flash read returns invalid data if the read length is more than 0xFFFA bytes, it supports maximum transaction of 2^16 bytes at a time, resister spcom[TRANLEN] is 16 bits. If the transaction length is greater than 0xFFFF, it need to be split into multiple transactions.
Signed-off-by: Shaohui Xie b21989@freescale.com Cc: Mike Frysinger vapier@gentoo.org --- changes for v2: fix some compile warnings. remove ifdef and use if else instead.
drivers/mtd/spi/spi_flash.c | 39 +++++++++++++++++++++++++++++++++++---- drivers/spi/fsl_espi.c | 6 ++++++ include/spi.h | 2 ++ 3 files changed, 43 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index c75b716..f90ef25 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1,6 +1,7 @@ /* * SPI flash interface * + * Copyright 2009-2011 Freescale Semiconductor, Inc. * Copyright (C) 2008 Atmel Corporation * Copyright (C) 2010 Reinhard Meyer, EMK Elektronik * @@ -82,11 +83,41 @@ int spi_flash_cmd_read_fast(struct spi_flash *flash, u32 offset, { u8 cmd[5];
- cmd[0] = CMD_READ_ARRAY_FAST; - spi_flash_addr(offset, cmd); - cmd[4] = 0x00; + if (len <= flash->spi->max_transfer_length) { + cmd[0] = CMD_READ_ARRAY_FAST; + spi_flash_addr(offset, cmd); + cmd[4] = 0x00; + + return spi_flash_read_common(flash, cmd, sizeof(cmd), data, len); + } else { + int max_tran_len, num_chunks, tran_len, ret = 0; + + max_tran_len = flash->spi->max_transfer_length; + num_chunks = len / max_tran_len + (len % max_tran_len ? 1 : 0); + + while (num_chunks--) { + tran_len = min(len , max_tran_len); + + cmd[0] = CMD_READ_ARRAY_FAST; + spi_flash_addr(offset, cmd); + cmd[4] = 0x00; + + debug("READ: 0x%x => cmd = " + "{ 0x%02x 0x%02x%02x%02x%02x } tran_len = 0x%x\n", + offset, cmd[0], cmd[1], cmd[2], cmd[3], cmd[4], tran_len);
- return spi_flash_read_common(flash, cmd, sizeof(cmd), data, len); + ret = spi_flash_read_common( + flash, cmd, sizeof(cmd), data, tran_len); + if (ret < 0) + return ret; + + offset += max_tran_len; + data += max_tran_len; + len -= max_tran_len; + } + + return ret; + } }
int spi_flash_cmd_poll_bit(struct spi_flash *flash, unsigned long timeout, diff --git a/drivers/spi/fsl_espi.c b/drivers/spi/fsl_espi.c index 9b8ae9a..7630fb3 100644 --- a/drivers/spi/fsl_espi.c +++ b/drivers/spi/fsl_espi.c @@ -53,6 +53,8 @@ ESPI_CSMODE_CSBEF(0) | ESPI_CSMODE_CSAFT(0) | \ ESPI_CSMODE_CSCG(1))
+#define ESPI_MAX_DATA_TRANSFER_LEN 0xFFF0 + struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int mode) { @@ -72,6 +74,7 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs,
slave->bus = bus; slave->cs = cs; + slave->max_transfer_length = ESPI_MAX_DATA_TRANSFER_LEN;
/* Enable eSPI interface */ out_be32(&espi->mode, ESPI_MODE_RXTHR(3) @@ -165,6 +168,9 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, unsigned char *buffer; size_t buf_len;
+ if (slave->max_transfer_length > ESPI_MAX_DATA_TRANSFER_LEN) + return -1; + switch (flags) { case SPI_XFER_BEGIN: cmd_len = bitlen / 8; diff --git a/include/spi.h b/include/spi.h index c5da3ca..866b920 100644 --- a/include/spi.h +++ b/include/spi.h @@ -58,10 +58,12 @@ * * bus: ID of the bus that the slave is attached to. * cs: ID of the chip select connected to the slave. + * max_transfer_length: maximum data transfer length supported by the slave. */ struct spi_slave { unsigned int bus; unsigned int cs; + unsigned int max_transfer_length; };
hrm, so how does this work under Linux ? or does it just not ? -mike
From: vapierfilter@gmail.com [mailto:vapierfilter@gmail.com] On Behalf Of Mike Frysinger Sent: Friday, April 22, 2011 1:17 AM To: Xie Shaohui-B21989 Cc: u-boot@lists.denx.de; Gala Kumar-B11780; Zang Roy-R61911 Subject: Re: [PATCH 2/2][v2] powerpc: make espi can read more than 0xFFFA bytes
[Xie Shaohui] This does work under Linux, being solved in similar way.
Best Regards, Shaohui Xie
so it doesnt work under Linux atm, but you're trying to get similar changes made to the Linux code upstream ? -mike
Mike Frysinger
Shaohui Xie
Xie Shaohui-B21989
