[U-Boot] [PATCH] input: simplify key_matrix_decode_fdt()
We know the exact property names that the code wants to process. Look these up directly with fdt_get_property(), rather than iterating over all properties within the node, and checking each property's name, in a convoluted fashion, against the expected name.
Signed-off-by: Stephen Warren swarren@nvidia.com --- Note: This depends on my previous patch "input: fix unaligned access in key_matrix_decode_fdt()". While to two patches could be squashed together, I'd prefer them to go in separately, since the former is a bug-fix that makes the original code work again on ARMv7 at least, and this patch is an unrelated refactoring. --- drivers/input/key_matrix.c | 66 +++++++++++++++++--------------------------- 1 file changed, 26 insertions(+), 40 deletions(-)
diff --git a/drivers/input/key_matrix.c b/drivers/input/key_matrix.c index c8b048e..ea05c77 100644 --- a/drivers/input/key_matrix.c +++ b/drivers/input/key_matrix.c @@ -154,54 +154,40 @@ static uchar *create_keymap(struct key_matrix *config, u32 *data, int len, return map; }
-int key_matrix_decode_fdt(struct key_matrix *config, const void *blob, - int node) +int key_matrix_decode_fdt(struct key_matrix *config, const void *blob, int node) { const struct fdt_property *prop; - static const char prefix[] = "linux,"; - int plen = sizeof(prefix) - 1; - int offset; - - /* Check each property name for ones that we understand */ - for (offset = fdt_first_property_offset(blob, node); - offset > 0; - offset = fdt_next_property_offset(blob, offset)) { - const char *name; - int len; - - prop = fdt_get_property_by_offset(blob, offset, NULL); - name = fdt_string(blob, fdt32_to_cpu(prop->nameoff)); - len = strlen(name); - - /* Name needs to match "1,<type>keymap" */ - debug("%s: property '%s'\n", __func__, name); - if (strncmp(name, prefix, plen) || - len < plen + 6 || - strcmp(name + len - 6, "keymap")) - continue; + int proplen; + uchar *plain_keycode;
- len -= plen + 6; - if (len == 0) { - config->plain_keycode = create_keymap(config, - (u32 *)prop->data, fdt32_to_cpu(prop->len), - KEY_FN, &config->fn_pos); - } else if (0 == strncmp(name + plen, "fn-", len)) { - config->fn_keycode = create_keymap(config, - (u32 *)prop->data, fdt32_to_cpu(prop->len), - -1, NULL); - } else { - debug("%s: unrecognised property '%s'\n", __func__, - name); - } - } - debug("%s: Decoded key maps %p, %p from fdt\n", __func__, - config->plain_keycode, config->fn_keycode); + prop = fdt_get_property(blob, node, "linux,keymap", &proplen); + /* Basic keymap is required */ + if (!prop) + return -1;
+ plain_keycode = create_keymap(config, (u32 *)prop->data, + proplen, KEY_FN, &config->fn_pos); + config->plain_keycode = plain_keycode; + /* Conversion error -> fail */ + if (!config->plain_keycode) + return -1; + + prop = fdt_get_property(blob, node, "linux,fn-keymap", &proplen); + /* fn keymap is optional */ + if (!prop) + goto done; + + config->fn_keycode = create_keymap(config, (u32 *)prop->data, + proplen, -1, NULL); + /* Conversion error -> fail */ if (!config->plain_keycode) { - debug("%s: cannot find keycode-plain map\n", __func__); + free(plain_keycode); return -1; }
+done: + debug("%s: Decoded key maps %p, %p from fdt\n", __func__, + config->plain_keycode, config->fn_keycode); return 0; }
Hi Stephen,
The original code dealt with ctrl and shift also - since removed. I think it is good to simplify it.
Yes.
int node)
int offset;
offset > 0;
const char *name;
int len;
len = strlen(name);
len < plen + 6 ||
continue;
int proplen;
len -= plen + 6;
if (len == 0) {
-1, NULL);
} else {
name);
if (!prop)
return -1;
Probably don't need plain_keycode variable at all.
return -1;
Missing debug() here from old code
if (!prop)
goto done;
proplen, -1, NULL);
Should check config->fn_keycode here.
+done:
-- 1.7.10.4
On 05/26/2013 01:31 PM, Simon Glass wrote:
Hi Stephen,
On Thu, May 23, 2013 at 3:09 PM, Stephen Warren <swarren@wwwdotorg.org mailto:swarren@wwwdotorg.org> wrote:
From: Stephen Warren <swarren@nvidia.com <mailto:swarren@nvidia.com>> We know the exact property names that the code wants to process. Look these up directly with fdt_get_property(), rather than iterating over all properties within the node, and checking each property's name, in a convoluted fashion, against the expected name. + plain_keycode = create_keymap(config, (u32 *)prop->data, + proplen, KEY_FN, &config->fn_pos);
This is required because the variable is passed to free() later, and config->plain_keycode is marked const, whereas free isn't prototyped to take a const. I figured that it was simplest to use a separate variable here rather than cast away the const when calling free(). Now, if C had const_cast<>, then I would have made a different decision:-)
Tom, is this likely to be applied for the upcoming release, or would it be deferred until the next? Thanks.
Stephen Warren
