[U-Boot] [PATCH V2 1/2] pci: Support parsing PCI controller DT subnodes
The PCI controller can have DT subnodes describing extra properties of particular PCI devices, ie. a PHY attached to an EHCI controller on a PCI bus. This patch parses those DT subnodes and assigns a node to the PCI device instance, so that the driver can extract details from that node and ie. configure the PHY using the PHY subsystem.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- V2: Move the whole machinery to pci_bind_bus_devices(), right after the driver instance platform data are updated. This reduces the number of times the DT is traversed and works for both DT nodes with and without compat string. --- drivers/pci/pci-uclass.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index e9671d9b76..cf3e38a6f2 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -733,6 +733,7 @@ int pci_bind_bus_devices(struct udevice *bus) ulong vendor, device; ulong header_type; pci_dev_t bdf, end; + ofnode node; bool found_multi; int ret;
@@ -803,6 +804,20 @@ int pci_bind_bus_devices(struct udevice *bus) pplat->vendor = vendor; pplat->device = device; pplat->class = class; + + /* Associate potention OF node */ + dev_for_each_subnode(node, bus) { + phys_addr_t df, size; + df = ofnode_get_addr_size(node, "reg", &size); + if (df == FDT_ADDR_T_NONE) + continue; + + if (PCI_FUNC(df) == PCI_FUNC(bdf) && + PCI_DEV(df) == PCI_DEV(bdf)) { + dev->node = node; + break; + } + } }
Reword the documentation to make it clear the compatible string is now optional, yet still matching on it takes precedence over PCI IDs and PCI classes.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- V2: New patch --- doc/driver-model/pci-info.txt | 14 +++++++++----- 1 file changed, 9 insertions(+), 5 deletions(-)
diff --git a/doc/driver-model/pci-info.txt b/doc/driver-model/pci-info.txt index e1701d1fbc..14364c5c75 100644 --- a/doc/driver-model/pci-info.txt +++ b/doc/driver-model/pci-info.txt @@ -34,11 +34,15 @@ under that bus. Note that this is all done on a lazy basis, as needed, so until something is touched on PCI (eg: a call to pci_find_devices()) it will not be probed.
-PCI devices can appear in the flattened device tree. If they do this serves to -specify the driver to use for the device. In this case they will be bound at -first. Each PCI device node must have a compatible string list as well as a -<reg> property, as defined by the IEEE Std 1275-1994 PCI bus binding document -v2.1. Note we must describe PCI devices with the same bus hierarchy as the +PCI devices can appear in the flattened device tree. If they do, their node +often contains extra information which cannot be derived from the PCI IDs or +PCI class of the device. Each PCI device node must have a <reg> property, as +defined by the IEEE Std 1275-1994 PCI bus binding document v2.1. Compatible +string list is optional and generally not needed, since PCI is discoverable +bus, albeit there are justified exceptions. If the compatible string is +present, matching on it takes precedence over PCI IDs and PCI classes. + +Note we must describe PCI devices with the same bus hierarchy as the hardware, otherwise driver model cannot detect the correct parent/children relationship during PCI bus enumeration thus PCI devices won't be bound to their drivers accordingly. A working example like below:
Hi Marek,
V2: New patch
+Note we must describe PCI devices with the same bus hierarchy as the hardware, otherwise driver model cannot detect the correct parent/children relationship during PCI bus enumeration thus PCI devices won't be bound to their drivers accordingly. A working example like below: -- 2.16.2
Are we really saying that compatible strings are 'generally not needed'?
device tree pci supplement 2.1 talks about some new formats for the compatible string, but doesn't say it is not needed. I much prefer a compatible string since it is easy to find the driver in the source code.
Can way say that a compatible string is preferred, but in extremis you can avoid it by...
On 08/30/2018 02:29 AM, Simon Glass wrote:
Hi Marek,
V2: New patch
Yes, PCI is a discoverable bus.
But it duplicates (badly) what the PCI IDs and classes are used for since PCI's inception.
No, see above, PCI is discoverable by design.
Hi Marek,
Hi Marek,
V2: New patch
I feel that these two things are orthogonal.
You can probe the bus and find a device. That is the 'discoverable' part.
But it is not automatically configurable. If it it were, there would be no DT node and no settings in the DT for the device. But from your patch, in some cases we need more information, and the DT node provides that.
So to get the settings to pass to the driver, you have to find the device-tree node to use for the device. The only way U-Boot supports is to use the 'reg' property, which specifies the PCI address. (We don't support a compatible string starting with "pci...". We could support that, but it is more code for essentially the same purpose.)
So we are not talking about the discoverability, which is already supported by U-Boot. We are talking about the configuration of the device, via settings passed to the driver.
In fact the only issue here is whether to require a compatible string for PCI nodes or allow matching solely based on the 'reg' property. Is the latter widely used in Linux? Presumably not on x86, which doesn't even use DT.
On 09/01/2018 11:45 PM, Simon Glass wrote:
Hi Marek,
Hi Marek,
V2: New patch
Pretty much, you can have stuff on the PCI card which needs extra info.
Yes
Yes
I only see the compatible string used for bridges, the rest of the subdevices match on reg property.
Hi Marek,
Hi Marek,
V2: New patch
Yes
Yes
Where are you looking?
Hi Marek,
Hi Marek,
V2: New patch
Yes
Yes
Roughly 'git grep -A 10 pci arch/arm*/boot/dts' in Linux
Hi Marek,
Hi Marek,
Hi Marek,
On 24 August 2018 at 12:27, Marek Vasut marek.vasut@gmail.com wrote: > Reword the documentation to make it clear the compatible string is now > optional, yet still matching on it takes precedence over PCI IDs and > PCI classes. > > Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com > Cc: Simon Glass sjg@chromium.org > Cc: Tom Rini trini@konsulko.com > --- > V2: New patch > --- > doc/driver-model/pci-info.txt | 14 +++++++++----- > 1 file changed, 9 insertions(+), 5 deletions(-) > > diff --git a/doc/driver-model/pci-info.txt b/doc/driver-model/pci-info.txt > index e1701d1fbc..14364c5c75 100644 > --- a/doc/driver-model/pci-info.txt > +++ b/doc/driver-model/pci-info.txt > @@ -34,11 +34,15 @@ under that bus. > Note that this is all done on a lazy basis, as needed, so until something is > touched on PCI (eg: a call to pci_find_devices()) it will not be probed. > > -PCI devices can appear in the flattened device tree. If they do this serves to > -specify the driver to use for the device. In this case they will be bound at > -first. Each PCI device node must have a compatible string list as well as a > -<reg> property, as defined by the IEEE Std 1275-1994 PCI bus binding document > -v2.1. Note we must describe PCI devices with the same bus hierarchy as the > +PCI devices can appear in the flattened device tree. If they do, their node > +often contains extra information which cannot be derived from the PCI IDs or > +PCI class of the device. Each PCI device node must have a <reg> property, as > +defined by the IEEE Std 1275-1994 PCI bus binding document v2.1. Compatible > +string list is optional and generally not needed, since PCI is discoverable > +bus, albeit there are justified exceptions. If the compatible string is > +present, matching on it takes precedence over PCI IDs and PCI classes. > + > +Note we must describe PCI devices with the same bus hierarchy as the > hardware, otherwise driver model cannot detect the correct parent/children > relationship during PCI bus enumeration thus PCI devices won't be bound to > their drivers accordingly. A working example like below: > -- > 2.16.2 >
Yes
Yes
I don't really understand why we need 'status = "okay"' on a bridge, since it should be enumerated anyway.
But I did find some bridges (I think( with settings like reset-gpios and no compatible strings.
I'm OK with supporting this if you want to.
Tom do you have any thoughts on this?
Well, bump ?
This is the only missing patch to get my hardware working properly.
- ofnode node; bool found_multi; int ret;
continue;
dev->node = node;
break;
+Simon
Hi Marek,
Well, bump ?
I don't think we ever had an agreement on the v1 patch. Simon had a long email that pointed out what Linux does seems like a 'fallback' to find a node with no compatible string.
Back to this, if we have to go with this way, please create a test case to cover this scenario.
Regards, Bin
On 08/29/2018 05:15 PM, Bin Meng wrote:
+Simon
Hi Marek,
Well, bump ?
The fact that it works on a particular board is not tested enough? Do we need a custom, special, synthetic test ?
Anyway, any feedback on the patch ? Did you test it ? I again only see "do this random stuff and that random stuff" , but zero actual feedback.
+Simon
Hi Marek,
Well, bump ?
I agree that we should include test coverage for this case in some automated fashion, so that nobody breaks support for it by accident.
What's the easiest way to get us there?
I think "potention" is a typo in your patch. Apart from that the logic feels very sound to me though. It's perfectly valid in DT to refer to subdevices by reg only.
Alex
Hi Marek,
+Simon
Hi Marek,
Well, bump ?
I believe that's always been the requirement against the DM code changes. I was requested in the past when I changed something in the DM and I see other people were asked to do so. Like Alex said, it does not mean this patch was not tested enough, but to ensure future commits won't break this.
If "this and that random stuff" means test case I asked for, please check my proposal on the v1 patch thread which indicated that a proper test case should be created. You seems to have missed that.
Regards, Bin
On 08/30/2018 03:32 PM, Bin Meng wrote:
Hi Marek,
+Simon
Hi Marek,
Well, bump ?
So, do you have any suggestion how to implement this test ? It seems Alex posed the same question. It doesn't seem to be trivial in the context of sandbox.
So, any feedback on this actual patch ?
Hi Marek,
Hi Marek,
+Simon
Hi Marek,
Well, bump ?
I suppose you need a PCI_DEVICE() declaration for sandbox, with an associated DT node and no compatible string. Then check that you can locate the device and that it read a DT property correctly.
What is 'potention'?
Is there any check needed that it does not attach the same DT node to two different devices? Or perhaps that cannot happen, since we shouldn't expect two nodes to share a BDF?
I think it looks OK, assuming this is the way we want to go.
On 09/01/2018 11:50 PM, Simon Glass wrote:
Hi Marek,
Hi Marek,
+Simon
Hi Marek,
On 08/24/2018 08:27 PM, Marek Vasut wrote: > The PCI controller can have DT subnodes describing extra properties > of particular PCI devices, ie. a PHY attached to an EHCI controller > on a PCI bus. This patch parses those DT subnodes and assigns a node > to the PCI device instance, so that the driver can extract details > from that node and ie. configure the PHY using the PHY subsystem. > > Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com > Cc: Simon Glass sjg@chromium.org > Cc: Tom Rini trini@konsulko.com
Well, bump ?
Is there any example of this stuff already ?
potential typo .
I guess it could happen and I didn't find a good solution to this even in Linux. The current take on this possibility seems to be "let's live with it".
Hi Marek,
Hi Marek,
Hi Marek,
+Simon
Hi Marek,
On Wed, Aug 29, 2018 at 10:22 PM Marek Vasut marek.vasut@gmail.com wrote: > > On 08/24/2018 08:27 PM, Marek Vasut wrote: >> The PCI controller can have DT subnodes describing extra properties >> of particular PCI devices, ie. a PHY attached to an EHCI controller >> on a PCI bus. This patch parses those DT subnodes and assigns a node >> to the PCI device instance, so that the driver can extract details >> from that node and ie. configure the PHY using the PHY subsystem. >> >> Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com >> Cc: Simon Glass sjg@chromium.org >> Cc: Tom Rini trini@konsulko.com > > Well, bump ? > > This is the only missing patch to get my hardware working properly.
See the bottom of swap_case.c. You might be able to add a new one of those,
If you look at pci-controller2 in test.dts it has a device with a compatible string. You could try adding a second device with no compatible string.
potential typo .
OK.
-- Best regards, Marek Vasut
Hi Marek,
Hi Marek,
Hi Marek,
On 08/29/2018 05:15 PM, Bin Meng wrote: > +Simon > > Hi Marek, > > On Wed, Aug 29, 2018 at 10:22 PM Marek Vasut marek.vasut@gmail.com wrote: >> >> On 08/24/2018 08:27 PM, Marek Vasut wrote: >>> The PCI controller can have DT subnodes describing extra properties >>> of particular PCI devices, ie. a PHY attached to an EHCI controller >>> on a PCI bus. This patch parses those DT subnodes and assigns a node >>> to the PCI device instance, so that the driver can extract details >>> from that node and ie. configure the PHY using the PHY subsystem. >>> >>> Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com >>> Cc: Simon Glass sjg@chromium.org >>> Cc: Tom Rini trini@konsulko.com >> >> Well, bump ? >> >> This is the only missing patch to get my hardware working properly. > > I don't think we ever had an agreement on the v1 patch. Simon had a > long email that pointed out what Linux does seems like a 'fallback' to > find a node with no compatible string. > > Back to this, if we have to go with this way, please create a test > case to cover this scenario.
And how does that test anything ?
Hi Marek,
Hi Marek,
Hi Marek,
Hi Marek,
On Thu, Aug 30, 2018 at 1:07 AM Marek Vasut marek.vasut@gmail.com wrote: > > On 08/29/2018 05:15 PM, Bin Meng wrote: >> +Simon >> >> Hi Marek, >> >> On Wed, Aug 29, 2018 at 10:22 PM Marek Vasut marek.vasut@gmail.com wrote: >>> >>> On 08/24/2018 08:27 PM, Marek Vasut wrote: >>>> The PCI controller can have DT subnodes describing extra properties >>>> of particular PCI devices, ie. a PHY attached to an EHCI controller >>>> on a PCI bus. This patch parses those DT subnodes and assigns a node >>>> to the PCI device instance, so that the driver can extract details >>>> from that node and ie. configure the PHY using the PHY subsystem. >>>> >>>> Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com >>>> Cc: Simon Glass sjg@chromium.org >>>> Cc: Tom Rini trini@konsulko.com >>> >>> Well, bump ? >>> >>> This is the only missing patch to get my hardware working properly. >> >> I don't think we ever had an agreement on the v1 patch. Simon had a >> long email that pointed out what Linux does seems like a 'fallback' to >> find a node with no compatible string. >> >> Back to this, if we have to go with this way, please create a test >> case to cover this scenario. > > The fact that it works on a particular board is not tested enough? > Do we need a custom, special, synthetic test ? >
You can test that your code actually attaches the DT node to the probed device. Without you code the test would fail. Wit it, it would pass.
On 09/14/2018 06:41 AM, Simon Glass wrote:
Hi Marek,
Hi Marek,
Hi Marek,
On 08/30/2018 03:32 PM, Bin Meng wrote: > Hi Marek, > > On Thu, Aug 30, 2018 at 1:07 AM Marek Vasut marek.vasut@gmail.com wrote: >> >> On 08/29/2018 05:15 PM, Bin Meng wrote: >>> +Simon >>> >>> Hi Marek, >>> >>> On Wed, Aug 29, 2018 at 10:22 PM Marek Vasut marek.vasut@gmail.com wrote: >>>> >>>> On 08/24/2018 08:27 PM, Marek Vasut wrote: >>>>> The PCI controller can have DT subnodes describing extra properties >>>>> of particular PCI devices, ie. a PHY attached to an EHCI controller >>>>> on a PCI bus. This patch parses those DT subnodes and assigns a node >>>>> to the PCI device instance, so that the driver can extract details >>>>> from that node and ie. configure the PHY using the PHY subsystem. >>>>> >>>>> Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com >>>>> Cc: Simon Glass sjg@chromium.org >>>>> Cc: Tom Rini trini@konsulko.com >>>> >>>> Well, bump ? >>>> >>>> This is the only missing patch to get my hardware working properly. >>> >>> I don't think we ever had an agreement on the v1 patch. Simon had a >>> long email that pointed out what Linux does seems like a 'fallback' to >>> find a node with no compatible string. >>> >>> Back to this, if we have to go with this way, please create a test >>> case to cover this scenario. >> >> The fact that it works on a particular board is not tested enough? >> Do we need a custom, special, synthetic test ? >> > > I believe that's always been the requirement against the DM code > changes. I was requested in the past when I changed something in the > DM and I see other people were asked to do so. Like Alex said, it does > not mean this patch was not tested enough, but to ensure future > commits won't break this.
Well it won't, because the sandbox swap_case.c requires the compatible. This all seems like a big hack to support virtual PCI devices.
The driver binds with a compatible and then pins the read/write config reg accessors to emulate their return values. Those include PCI IDs. So you cannot instantiate virtual PCI device without this compatible string and thus also cannot write such a test easily.
Now I also understand where this whole discussion about compatible strings came from though.
Hi Marek,
Hi Marek,
Hi Marek,
Hi Marek,
On 30 August 2018 at 07:42, Marek Vasut marek.vasut@gmail.com wrote: > On 08/30/2018 03:32 PM, Bin Meng wrote: >> Hi Marek, >> >> On Thu, Aug 30, 2018 at 1:07 AM Marek Vasut marek.vasut@gmail.com wrote: >>> >>> On 08/29/2018 05:15 PM, Bin Meng wrote: >>>> +Simon >>>> >>>> Hi Marek, >>>> >>>> On Wed, Aug 29, 2018 at 10:22 PM Marek Vasut marek.vasut@gmail.com wrote: >>>>> >>>>> On 08/24/2018 08:27 PM, Marek Vasut wrote: >>>>>> The PCI controller can have DT subnodes describing extra properties >>>>>> of particular PCI devices, ie. a PHY attached to an EHCI controller >>>>>> on a PCI bus. This patch parses those DT subnodes and assigns a node >>>>>> to the PCI device instance, so that the driver can extract details >>>>>> from that node and ie. configure the PHY using the PHY subsystem. >>>>>> >>>>>> Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com >>>>>> Cc: Simon Glass sjg@chromium.org >>>>>> Cc: Tom Rini trini@konsulko.com >>>>> >>>>> Well, bump ? >>>>> >>>>> This is the only missing patch to get my hardware working properly. >>>> >>>> I don't think we ever had an agreement on the v1 patch. Simon had a >>>> long email that pointed out what Linux does seems like a 'fallback' to >>>> find a node with no compatible string. >>>> >>>> Back to this, if we have to go with this way, please create a test >>>> case to cover this scenario. >>> >>> The fact that it works on a particular board is not tested enough? >>> Do we need a custom, special, synthetic test ? >>> >> >> I believe that's always been the requirement against the DM code >> changes. I was requested in the past when I changed something in the >> DM and I see other people were asked to do so. Like Alex said, it does >> not mean this patch was not tested enough, but to ensure future >> commits won't break this. > > So, do you have any suggestion how to implement this test ? It seems > Alex posed the same question. It doesn't seem to be trivial in the > context of sandbox.
The sandbox swap_case.c indeed supports dynamic driver binding, just like real PCI devices. Please check doc/driver-model/pci-info.txt (since you were modifying the same doc, I guess you missed that part ..)
Regards, Bin
On 09/18/2018 03:52 PM, Bin Meng wrote:
Hi Marek,
Hi Marek,
Hi Marek,
On 09/01/2018 11:50 PM, Simon Glass wrote: > Hi Marek, > > On 30 August 2018 at 07:42, Marek Vasut marek.vasut@gmail.com wrote: >> On 08/30/2018 03:32 PM, Bin Meng wrote: >>> Hi Marek, >>> >>> On Thu, Aug 30, 2018 at 1:07 AM Marek Vasut marek.vasut@gmail.com wrote: >>>> >>>> On 08/29/2018 05:15 PM, Bin Meng wrote: >>>>> +Simon >>>>> >>>>> Hi Marek, >>>>> >>>>> On Wed, Aug 29, 2018 at 10:22 PM Marek Vasut marek.vasut@gmail.com wrote: >>>>>> >>>>>> On 08/24/2018 08:27 PM, Marek Vasut wrote: >>>>>>> The PCI controller can have DT subnodes describing extra properties >>>>>>> of particular PCI devices, ie. a PHY attached to an EHCI controller >>>>>>> on a PCI bus. This patch parses those DT subnodes and assigns a node >>>>>>> to the PCI device instance, so that the driver can extract details >>>>>>> from that node and ie. configure the PHY using the PHY subsystem. >>>>>>> >>>>>>> Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com >>>>>>> Cc: Simon Glass sjg@chromium.org >>>>>>> Cc: Tom Rini trini@konsulko.com >>>>>> >>>>>> Well, bump ? >>>>>> >>>>>> This is the only missing patch to get my hardware working properly. >>>>> >>>>> I don't think we ever had an agreement on the v1 patch. Simon had a >>>>> long email that pointed out what Linux does seems like a 'fallback' to >>>>> find a node with no compatible string. >>>>> >>>>> Back to this, if we have to go with this way, please create a test >>>>> case to cover this scenario. >>>> >>>> The fact that it works on a particular board is not tested enough? >>>> Do we need a custom, special, synthetic test ? >>>> >>> >>> I believe that's always been the requirement against the DM code >>> changes. I was requested in the past when I changed something in the >>> DM and I see other people were asked to do so. Like Alex said, it does >>> not mean this patch was not tested enough, but to ensure future >>> commits won't break this. >> >> So, do you have any suggestion how to implement this test ? It seems >> Alex posed the same question. It doesn't seem to be trivial in the >> context of sandbox. > > I suppose you need a PCI_DEVICE() declaration for sandbox, with an > associated DT node and no compatible string. Then check that you can > locate the device and that it read a DT property correctly.
Any specific part I am looking for ?
Hi Marek,
Hi Marek,
Hi Marek,
Hi Marek,
On 1 September 2018 at 16:45, Marek Vasut marek.vasut@gmail.com wrote: > > On 09/01/2018 11:50 PM, Simon Glass wrote: >> Hi Marek, >> >> On 30 August 2018 at 07:42, Marek Vasut marek.vasut@gmail.com wrote: >>> On 08/30/2018 03:32 PM, Bin Meng wrote: >>>> Hi Marek, >>>> >>>> On Thu, Aug 30, 2018 at 1:07 AM Marek Vasut marek.vasut@gmail.com wrote: >>>>> >>>>> On 08/29/2018 05:15 PM, Bin Meng wrote: >>>>>> +Simon >>>>>> >>>>>> Hi Marek, >>>>>> >>>>>> On Wed, Aug 29, 2018 at 10:22 PM Marek Vasut marek.vasut@gmail.com wrote: >>>>>>> >>>>>>> On 08/24/2018 08:27 PM, Marek Vasut wrote: >>>>>>>> The PCI controller can have DT subnodes describing extra properties >>>>>>>> of particular PCI devices, ie. a PHY attached to an EHCI controller >>>>>>>> on a PCI bus. This patch parses those DT subnodes and assigns a node >>>>>>>> to the PCI device instance, so that the driver can extract details >>>>>>>> from that node and ie. configure the PHY using the PHY subsystem. >>>>>>>> >>>>>>>> Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com >>>>>>>> Cc: Simon Glass sjg@chromium.org >>>>>>>> Cc: Tom Rini trini@konsulko.com >>>>>>> >>>>>>> Well, bump ? >>>>>>> >>>>>>> This is the only missing patch to get my hardware working properly. >>>>>> >>>>>> I don't think we ever had an agreement on the v1 patch. Simon had a >>>>>> long email that pointed out what Linux does seems like a 'fallback' to >>>>>> find a node with no compatible string. >>>>>> >>>>>> Back to this, if we have to go with this way, please create a test >>>>>> case to cover this scenario. >>>>> >>>>> The fact that it works on a particular board is not tested enough? >>>>> Do we need a custom, special, synthetic test ? >>>>> >>>> >>>> I believe that's always been the requirement against the DM code >>>> changes. I was requested in the past when I changed something in the >>>> DM and I see other people were asked to do so. Like Alex said, it does >>>> not mean this patch was not tested enough, but to ensure future >>>> commits won't break this. >>> >>> So, do you have any suggestion how to implement this test ? It seems >>> Alex posed the same question. It doesn't seem to be trivial in the >>> context of sandbox. >> >> I suppose you need a PCI_DEVICE() declaration for sandbox, with an >> associated DT node and no compatible string. Then check that you can >> locate the device and that it read a DT property correctly. > > Is there any example of this stuff already ?
In the pci-info.txt, search for "The sandbox PCI drivers also support dynamic driver binding". The arch/sandbox/dts/test.dts already has one PCI controller and two swap_case devices setup for this testing. You can start from there.
Regards, Bin
Hi Marek,
Hi Marek,
Hi Marek,
Hi Marek,
The compatible string is needed for the emulation driver but not for the thing that connects to it. However as things stand you can't attach an emulator to a bus without nesting it under the device which it attaches to.
I suspect the best answer is to move the emulator so it is a direct child of the bus. You would need to update sandbox_pci_get_emul() to call device_find_first_child() on 'bus' instead of 'dev'.
On 09/18/2018 03:52 PM, Simon Glass wrote:
Hi Marek,
Hi Marek,
Hi Marek,
Sounds to me _way_ out of scope for this patchset.
Hi Marek,
Hi Marek,
Hi Marek,
Hi Marek,
Dynamic binding is already supported on Sandbox. I guess Simon may have missed the part.
Regards, Bin
On 09/19/2018 11:26 AM, Bin Meng wrote:
Hi Marek,
Hi Marek,
Hi Marek,
On 09/02/2018 03:07 AM, Simon Glass wrote: > Hi Marek,
> On 1 September 2018 at 16:45, Marek Vasut marek.vasut@gmail.com wrote: >> >> On 09/01/2018 11:50 PM, Simon Glass wrote: >>> Hi Marek, >>> >>> On 30 August 2018 at 07:42, Marek Vasut marek.vasut@gmail.com wrote: >>>> On 08/30/2018 03:32 PM, Bin Meng wrote: >>>>> Hi Marek, >>>>> >>>>> On Thu, Aug 30, 2018 at 1:07 AM Marek Vasut marek.vasut@gmail.com wrote: >>>>>> >>>>>> On 08/29/2018 05:15 PM, Bin Meng wrote: >>>>>>> +Simon >>>>>>> >>>>>>> Hi Marek, >>>>>>> >>>>>>> On Wed, Aug 29, 2018 at 10:22 PM Marek Vasut marek.vasut@gmail.com wrote: >>>>>>>> >>>>>>>> On 08/24/2018 08:27 PM, Marek Vasut wrote: >>>>>>>>> The PCI controller can have DT subnodes describing extra properties >>>>>>>>> of particular PCI devices, ie. a PHY attached to an EHCI controller >>>>>>>>> on a PCI bus. This patch parses those DT subnodes and assigns a node >>>>>>>>> to the PCI device instance, so that the driver can extract details >>>>>>>>> from that node and ie. configure the PHY using the PHY subsystem. >>>>>>>>> >>>>>>>>> Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com >>>>>>>>> Cc: Simon Glass sjg@chromium.org >>>>>>>>> Cc: Tom Rini trini@konsulko.com >>>>>>>> >>>>>>>> Well, bump ? >>>>>>>> >>>>>>>> This is the only missing patch to get my hardware working properly. >>>>>>> >>>>>>> I don't think we ever had an agreement on the v1 patch. Simon had a >>>>>>> long email that pointed out what Linux does seems like a 'fallback' to >>>>>>> find a node with no compatible string. >>>>>>> >>>>>>> Back to this, if we have to go with this way, please create a test >>>>>>> case to cover this scenario. >>>>>> >>>>>> The fact that it works on a particular board is not tested enough? >>>>>> Do we need a custom, special, synthetic test ? >>>>>> >>>>> >>>>> I believe that's always been the requirement against the DM code >>>>> changes. I was requested in the past when I changed something in the >>>>> DM and I see other people were asked to do so. Like Alex said, it does >>>>> not mean this patch was not tested enough, but to ensure future >>>>> commits won't break this. >>>> >>>> So, do you have any suggestion how to implement this test ? It seems >>>> Alex posed the same question. It doesn't seem to be trivial in the >>>> context of sandbox. >>> >>> I suppose you need a PCI_DEVICE() declaration for sandbox, with an >>> associated DT node and no compatible string. Then check that you can >>> locate the device and that it read a DT property correctly. >> >> Is there any example of this stuff already ? > > See the bottom of swap_case.c. You might be able to add a new one of those, > > If you look at pci-controller2 in test.dts it has a device with a > compatible string. You could try adding a second device with no > compatible string.
Well, where is an example of that ? Because I am not seeing one.
Hi Marek,
Hi Marek,
Hi Marek,
Hi Marek,
On 10 September 2018 at 01:38, Marek Vasut marek.vasut@gmail.com wrote: > > On 09/02/2018 03:07 AM, Simon Glass wrote: >> Hi Marek, > > Hi, > >> On 1 September 2018 at 16:45, Marek Vasut marek.vasut@gmail.com wrote: >>> >>> On 09/01/2018 11:50 PM, Simon Glass wrote: >>>> Hi Marek, >>>> >>>> On 30 August 2018 at 07:42, Marek Vasut marek.vasut@gmail.com wrote: >>>>> On 08/30/2018 03:32 PM, Bin Meng wrote: >>>>>> Hi Marek, >>>>>> >>>>>> On Thu, Aug 30, 2018 at 1:07 AM Marek Vasut marek.vasut@gmail.com wrote: >>>>>>> >>>>>>> On 08/29/2018 05:15 PM, Bin Meng wrote: >>>>>>>> +Simon >>>>>>>> >>>>>>>> Hi Marek, >>>>>>>> >>>>>>>> On Wed, Aug 29, 2018 at 10:22 PM Marek Vasut marek.vasut@gmail.com wrote: >>>>>>>>> >>>>>>>>> On 08/24/2018 08:27 PM, Marek Vasut wrote: >>>>>>>>>> The PCI controller can have DT subnodes describing extra properties >>>>>>>>>> of particular PCI devices, ie. a PHY attached to an EHCI controller >>>>>>>>>> on a PCI bus. This patch parses those DT subnodes and assigns a node >>>>>>>>>> to the PCI device instance, so that the driver can extract details >>>>>>>>>> from that node and ie. configure the PHY using the PHY subsystem. >>>>>>>>>> >>>>>>>>>> Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com >>>>>>>>>> Cc: Simon Glass sjg@chromium.org >>>>>>>>>> Cc: Tom Rini trini@konsulko.com >>>>>>>>> >>>>>>>>> Well, bump ? >>>>>>>>> >>>>>>>>> This is the only missing patch to get my hardware working properly. >>>>>>>> >>>>>>>> I don't think we ever had an agreement on the v1 patch. Simon had a >>>>>>>> long email that pointed out what Linux does seems like a 'fallback' to >>>>>>>> find a node with no compatible string. >>>>>>>> >>>>>>>> Back to this, if we have to go with this way, please create a test >>>>>>>> case to cover this scenario. >>>>>>> >>>>>>> The fact that it works on a particular board is not tested enough? >>>>>>> Do we need a custom, special, synthetic test ? >>>>>>> >>>>>> >>>>>> I believe that's always been the requirement against the DM code >>>>>> changes. I was requested in the past when I changed something in the >>>>>> DM and I see other people were asked to do so. Like Alex said, it does >>>>>> not mean this patch was not tested enough, but to ensure future >>>>>> commits won't break this. >>>>> >>>>> So, do you have any suggestion how to implement this test ? It seems >>>>> Alex posed the same question. It doesn't seem to be trivial in the >>>>> context of sandbox. >>>> >>>> I suppose you need a PCI_DEVICE() declaration for sandbox, with an >>>> associated DT node and no compatible string. Then check that you can >>>> locate the device and that it read a DT property correctly. >>> >>> Is there any example of this stuff already ? >> >> See the bottom of swap_case.c. You might be able to add a new one of those, >> >> If you look at pci-controller2 in test.dts it has a device with a >> compatible string. You could try adding a second device with no >> compatible string. > > And how does that test anything ?
I already pointed out in the previous email. In arch/sandbox/dts/test.dts, the 2nd PCI controller has two swap_case devices and the 3rd controller has one. In swap_case.c, U_BOOT_PCI_DEVICE() is there which is also a clear sign that the driver supports dynamic binding. Of course, the driver supports "compatible" too as you noticed.
Regards, Bin
On 09/19/2018 11:41 AM, Bin Meng wrote:
Hi Marek,
Hi Marek,
Hi Marek,
On 09/14/2018 06:41 AM, Simon Glass wrote: > Hi Marek, > > On 10 September 2018 at 01:38, Marek Vasut marek.vasut@gmail.com wrote: >> >> On 09/02/2018 03:07 AM, Simon Glass wrote: >>> Hi Marek, >> >> Hi, >> >>> On 1 September 2018 at 16:45, Marek Vasut marek.vasut@gmail.com wrote: >>>> >>>> On 09/01/2018 11:50 PM, Simon Glass wrote: >>>>> Hi Marek, >>>>> >>>>> On 30 August 2018 at 07:42, Marek Vasut marek.vasut@gmail.com wrote: >>>>>> On 08/30/2018 03:32 PM, Bin Meng wrote: >>>>>>> Hi Marek, >>>>>>> >>>>>>> On Thu, Aug 30, 2018 at 1:07 AM Marek Vasut marek.vasut@gmail.com wrote: >>>>>>>> >>>>>>>> On 08/29/2018 05:15 PM, Bin Meng wrote: >>>>>>>>> +Simon >>>>>>>>> >>>>>>>>> Hi Marek, >>>>>>>>> >>>>>>>>> On Wed, Aug 29, 2018 at 10:22 PM Marek Vasut marek.vasut@gmail.com wrote: >>>>>>>>>> >>>>>>>>>> On 08/24/2018 08:27 PM, Marek Vasut wrote: >>>>>>>>>>> The PCI controller can have DT subnodes describing extra properties >>>>>>>>>>> of particular PCI devices, ie. a PHY attached to an EHCI controller >>>>>>>>>>> on a PCI bus. This patch parses those DT subnodes and assigns a node >>>>>>>>>>> to the PCI device instance, so that the driver can extract details >>>>>>>>>>> from that node and ie. configure the PHY using the PHY subsystem. >>>>>>>>>>> >>>>>>>>>>> Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com >>>>>>>>>>> Cc: Simon Glass sjg@chromium.org >>>>>>>>>>> Cc: Tom Rini trini@konsulko.com >>>>>>>>>> >>>>>>>>>> Well, bump ? >>>>>>>>>> >>>>>>>>>> This is the only missing patch to get my hardware working properly. >>>>>>>>> >>>>>>>>> I don't think we ever had an agreement on the v1 patch. Simon had a >>>>>>>>> long email that pointed out what Linux does seems like a 'fallback' to >>>>>>>>> find a node with no compatible string. >>>>>>>>> >>>>>>>>> Back to this, if we have to go with this way, please create a test >>>>>>>>> case to cover this scenario. >>>>>>>> >>>>>>>> The fact that it works on a particular board is not tested enough? >>>>>>>> Do we need a custom, special, synthetic test ? >>>>>>>> >>>>>>> >>>>>>> I believe that's always been the requirement against the DM code >>>>>>> changes. I was requested in the past when I changed something in the >>>>>>> DM and I see other people were asked to do so. Like Alex said, it does >>>>>>> not mean this patch was not tested enough, but to ensure future >>>>>>> commits won't break this. >>>>>> >>>>>> So, do you have any suggestion how to implement this test ? It seems >>>>>> Alex posed the same question. It doesn't seem to be trivial in the >>>>>> context of sandbox. >>>>> >>>>> I suppose you need a PCI_DEVICE() declaration for sandbox, with an >>>>> associated DT node and no compatible string. Then check that you can >>>>> locate the device and that it read a DT property correctly. >>>> >>>> Is there any example of this stuff already ? >>> >>> See the bottom of swap_case.c. You might be able to add a new one of those, >>> >>> If you look at pci-controller2 in test.dts it has a device with a >>> compatible string. You could try adding a second device with no >>> compatible string. >> >> And how does that test anything ? > > You can test that your code actually attaches the DT node to the > probed device. Without you code the test would fail. Wit it, it would > pass.
By "second" you mean pci1: or pci2: ? Because pci1: is second , after pci0 . It'd really help if you were clearer in what you refer to.
Are you talking about sandbox,dev-info DT property here ?
Hi Marek,
Hi Marek,
Hi Marek,
Hi Marek,
On 18 September 2018 at 13:36, Marek Vasut marek.vasut@gmail.com wrote: > > On 09/14/2018 06:41 AM, Simon Glass wrote: >> Hi Marek, >> >> On 10 September 2018 at 01:38, Marek Vasut marek.vasut@gmail.com wrote: >>> >>> On 09/02/2018 03:07 AM, Simon Glass wrote: >>>> Hi Marek, >>> >>> Hi, >>> >>>> On 1 September 2018 at 16:45, Marek Vasut marek.vasut@gmail.com wrote: >>>>> >>>>> On 09/01/2018 11:50 PM, Simon Glass wrote: >>>>>> Hi Marek, >>>>>> >>>>>> On 30 August 2018 at 07:42, Marek Vasut marek.vasut@gmail.com wrote: >>>>>>> On 08/30/2018 03:32 PM, Bin Meng wrote: >>>>>>>> Hi Marek, >>>>>>>> >>>>>>>> On Thu, Aug 30, 2018 at 1:07 AM Marek Vasut marek.vasut@gmail.com wrote: >>>>>>>>> >>>>>>>>> On 08/29/2018 05:15 PM, Bin Meng wrote: >>>>>>>>>> +Simon >>>>>>>>>> >>>>>>>>>> Hi Marek, >>>>>>>>>> >>>>>>>>>> On Wed, Aug 29, 2018 at 10:22 PM Marek Vasut marek.vasut@gmail.com wrote: >>>>>>>>>>> >>>>>>>>>>> On 08/24/2018 08:27 PM, Marek Vasut wrote: >>>>>>>>>>>> The PCI controller can have DT subnodes describing extra properties >>>>>>>>>>>> of particular PCI devices, ie. a PHY attached to an EHCI controller >>>>>>>>>>>> on a PCI bus. This patch parses those DT subnodes and assigns a node >>>>>>>>>>>> to the PCI device instance, so that the driver can extract details >>>>>>>>>>>> from that node and ie. configure the PHY using the PHY subsystem. >>>>>>>>>>>> >>>>>>>>>>>> Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com >>>>>>>>>>>> Cc: Simon Glass sjg@chromium.org >>>>>>>>>>>> Cc: Tom Rini trini@konsulko.com >>>>>>>>>>> >>>>>>>>>>> Well, bump ? >>>>>>>>>>> >>>>>>>>>>> This is the only missing patch to get my hardware working properly. >>>>>>>>>> >>>>>>>>>> I don't think we ever had an agreement on the v1 patch. Simon had a >>>>>>>>>> long email that pointed out what Linux does seems like a 'fallback' to >>>>>>>>>> find a node with no compatible string. >>>>>>>>>> >>>>>>>>>> Back to this, if we have to go with this way, please create a test >>>>>>>>>> case to cover this scenario. >>>>>>>>> >>>>>>>>> The fact that it works on a particular board is not tested enough? >>>>>>>>> Do we need a custom, special, synthetic test ? >>>>>>>>> >>>>>>>> >>>>>>>> I believe that's always been the requirement against the DM code >>>>>>>> changes. I was requested in the past when I changed something in the >>>>>>>> DM and I see other people were asked to do so. Like Alex said, it does >>>>>>>> not mean this patch was not tested enough, but to ensure future >>>>>>>> commits won't break this. >>>>>>> >>>>>>> So, do you have any suggestion how to implement this test ? It seems >>>>>>> Alex posed the same question. It doesn't seem to be trivial in the >>>>>>> context of sandbox. >>>>>> >>>>>> I suppose you need a PCI_DEVICE() declaration for sandbox, with an >>>>>> associated DT node and no compatible string. Then check that you can >>>>>> locate the device and that it read a DT property correctly. >>>>> >>>>> Is there any example of this stuff already ? >>>> >>>> See the bottom of swap_case.c. You might be able to add a new one of those, >>>> >>>> If you look at pci-controller2 in test.dts it has a device with a >>>> compatible string. You could try adding a second device with no >>>> compatible string. >>> >>> And how does that test anything ? >> >> You can test that your code actually attaches the DT node to the >> probed device. Without you code the test would fail. Wit it, it would >> pass. > > Well it won't, because the sandbox swap_case.c requires the compatible. > This all seems like a big hack to support virtual PCI devices. > > The driver binds with a compatible and then pins the read/write config > reg accessors to emulate their return values. Those include PCI IDs. So > you cannot instantiate virtual PCI device without this compatible string > and thus also cannot write such a test easily. > > Now I also understand where this whole discussion about compatible > strings came from though.
It's pci1. You can see there is no subnode under pci1 there yet if you type 'pci 1' from the U-Boot shell you see two PCI devices.
This is the property Sandbox uses to make the dynamic binding work. You can bypass this. The key here is that swap_case driver supports both "compatible" and dynamic binding, so you can write test cases to cover this newly added ofnode scenario.
Regards, Bin
On 09/20/2018 03:47 AM, Bin Meng wrote: [...]
> I suspect the best answer is to move the emulator so it is a direct > child of the bus. You would need to update sandbox_pci_get_emul() to > call device_find_first_child() on 'bus' instead of 'dev'.
I'd really appreciate it if you could be more precise when referring to things.
Why would I want to bypass this ?
That's great, and after spending even more time on this (probably days by now), I just keep finding more and more limitations of the virtual PCI subsystem which makes writing this testcase really hard. And none of that really helps fixing the real problem on my real hardware, which really stays broken.
Hi Marek,
>> I suspect the best answer is to move the emulator so it is a direct >> child of the bus. You would need to update sandbox_pci_get_emul() to >> call device_find_first_child() on 'bus' instead of 'dev'. > > Sounds to me _way_ out of scope for this patchset.
You could fix that with a 5-minute patch to add a compatible string :-)
The problem is that you want to do it a certain way. Yes the test system has limitations but it is better than what we had before (no tests). We should expand its capability as we add new functionality.
On 09/26/2018 07:42 AM, Simon Glass wrote:
Hi Marek,
>>> I suspect the best answer is to move the emulator so it is a direct >>> child of the bus. You would need to update sandbox_pci_get_emul() to >>> call device_find_first_child() on 'bus' instead of 'dev'. >> >> Sounds to me _way_ out of scope for this patchset. > > Dynamic binding is already supported on Sandbox. I guess Simon may > have missed the part.
No, that's a hack.
Alexander Graf
Bin Meng
