[PATCH 0/2] efi_loader: use short-form DP for load options
The GUID of partitions is sufficient for identification and will stay constant in the lifetime of a boot option. The preceding path of the device-path may change due to changes in the enumeration of devices.
Create short-form device-paths in the 'efidebug boot add' command.
Fix the support of short form device-paths in the implementation of LoadImage().
Heinrich Schuchardt (2): efi_loader: support booting via short-form device-path efi_loader: use short-form DP for load options
cmd/efidebug.c | 15 +++++++++++---- include/efi_loader.h | 3 ++- lib/efi_loader/efi_boottime.c | 12 ++++++------ lib/efi_loader/efi_device_path.c | 21 +++++++++++++-------- 4 files changed, 32 insertions(+), 19 deletions(-)
-- 2.34.1
The boot manager must support loading from boot options using a short-form device-path, e.g. one where the first element is a hard drive media path.
See '3.1.2 Load Options Processing' in UEFI specification version 2.9.
Fixes: 0e074d12393b ("efi_loader: carve out efi_load_image_from_file()") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_boottime.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 82128ac1d5..173e636d60 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1940,7 +1940,7 @@ efi_status_t efi_load_image_from_path(bool boot_policy, { efi_handle_t device; efi_status_t ret; - struct efi_device_path *dp; + struct efi_device_path *dp, *rem; struct efi_load_file_protocol *load_file_protocol = NULL; efi_uintn_t buffer_size; uint64_t addr, pages; @@ -1951,18 +1951,18 @@ efi_status_t efi_load_image_from_path(bool boot_policy, *size = 0;
dp = file_path; - ret = EFI_CALL(efi_locate_device_path( - &efi_simple_file_system_protocol_guid, &dp, &device)); + device = efi_dp_find_obj(dp, &rem); + ret = efi_search_protocol(device, &efi_simple_file_system_protocol_guid, + NULL); if (ret == EFI_SUCCESS) return efi_load_image_from_file(file_path, buffer, size);
- ret = EFI_CALL(efi_locate_device_path( - &efi_guid_load_file_protocol, &dp, &device)); + ret = efi_search_protocol(device, &efi_guid_load_file_protocol, NULL); if (ret == EFI_SUCCESS) { guid = &efi_guid_load_file_protocol; } else if (!boot_policy) { guid = &efi_guid_load_file2_protocol; - ret = EFI_CALL(efi_locate_device_path(guid, &dp, &device)); + ret = efi_search_protocol(device, guid, NULL); } if (ret != EFI_SUCCESS) return EFI_NOT_FOUND; -- 2.34.1
The GUID of partitions is sufficient for identification and will stay constant in the lifetime of a boot option. The preceding path of the device-path may change due to changes in the enumeration of devices. Therefore it is preferable to use the short-form of device-paths in load options. Adjust the 'efidebug boot add' command accordingly.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/efidebug.c | 15 +++++++++++---- include/efi_loader.h | 3 ++- lib/efi_loader/efi_device_path.c | 21 +++++++++++++-------- 3 files changed, 26 insertions(+), 13 deletions(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index 401d13cc4c..f62a4345fd 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -747,7 +747,7 @@ struct efi_device_path *create_initrd_dp(const char *dev, const char *part, const char *file)
{ - struct efi_device_path *tmp_dp = NULL, *tmp_fp = NULL; + struct efi_device_path *tmp_dp = NULL, *tmp_fp = NULL, *short_fp; struct efi_device_path *initrd_dp = NULL; efi_status_t ret; const struct efi_initrd_dp id_dp = { @@ -771,9 +771,12 @@ struct efi_device_path *create_initrd_dp(const char *dev, const char *part, printf("Cannot create device path for "%s %s"\n", part, file); goto out; } + short_fp = efi_dp_shorten(tmp_fp); + if (!short_fp) + short_fp = tmp_fp;
initrd_dp = efi_dp_append((const struct efi_device_path *)&id_dp, - tmp_fp); + short_fp);
out: efi_free_pool(tmp_dp); @@ -807,6 +810,7 @@ static int do_efi_boot_add(struct cmd_tbl *cmdtp, int flag, size_t label_len, label_len16; u16 *label; struct efi_device_path *device_path = NULL, *file_path = NULL; + struct efi_device_path *fp_free = NULL; struct efi_device_path *final_fp = NULL; struct efi_device_path *initrd_dp = NULL; struct efi_load_option lo; @@ -849,13 +853,16 @@ static int do_efi_boot_add(struct cmd_tbl *cmdtp, int flag,
/* file path */ ret = efi_dp_from_name(argv[3], argv[4], argv[5], - &device_path, &file_path); + &device_path, &fp_free); if (ret != EFI_SUCCESS) { printf("Cannot create device path for "%s %s"\n", argv[3], argv[4]); r = CMD_RET_FAILURE; goto out; } + file_path = efi_dp_shorten(fp_free); + if (!file_path) + file_path = fp_free; fp_size += efi_dp_size(file_path) + sizeof(struct efi_device_path); argc -= 5; @@ -927,7 +934,7 @@ out: efi_free_pool(final_fp); efi_free_pool(initrd_dp); efi_free_pool(device_path); - efi_free_pool(file_path); + efi_free_pool(fp_free); free(lo.label);
return r; diff --git a/include/efi_loader.h b/include/efi_loader.h index e390d323a9..c7d6b7c7f3 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -725,7 +725,8 @@ extern void *efi_bounce_buffer; #define EFI_LOADER_BOUNCE_BUFFER_SIZE (64 * 1024 * 1024) #endif
- +/* shorten device path */ +struct efi_device_path *efi_dp_shorten(struct efi_device_path *dp); struct efi_device_path *efi_dp_next(const struct efi_device_path *dp); int efi_dp_match(const struct efi_device_path *a, const struct efi_device_path *b); diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index dc787b4d3d..ddd5f132ec 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -122,20 +122,25 @@ int efi_dp_match(const struct efi_device_path *a, } }
-/* +/** + * efi_dp_shorten() - shorten device-path + * * We can have device paths that start with a USB WWID or a USB Class node, * and a few other cases which don't encode the full device path with bus * hierarchy: * - * - MESSAGING:USB_WWID - * - MESSAGING:USB_CLASS - * - MEDIA:FILE_PATH - * - MEDIA:HARD_DRIVE - * - MESSAGING:URI + * * MESSAGING:USB_WWID + * * MESSAGING:USB_CLASS + * * MEDIA:FILE_PATH + * * MEDIA:HARD_DRIVE + * * MESSAGING:URI * * See UEFI spec (section 3.1.2, about short-form device-paths) + * + * @dp: original devie-path + * @Return: shortened device-path or NULL */ -static struct efi_device_path *shorten_path(struct efi_device_path *dp) +struct efi_device_path *efi_dp_shorten(struct efi_device_path *dp) { while (dp) { /* @@ -189,7 +194,7 @@ static struct efi_object *find_obj(struct efi_device_path *dp, bool short_path, } }
- obj_dp = shorten_path(efi_dp_next(obj_dp)); + obj_dp = efi_dp_shorten(efi_dp_next(obj_dp)); } while (short_path && obj_dp); }
-- 2.34.1
Since a "long" device path is still valid, I think that a user should be allowed to use a long device path especially if he or she wants to limit an interface for loading any image. Please add an option to efidebug to select a short or long path.
Furthermore, I would like to ask you to add a test, as you always require me to do so, for loading from a short path. Otherwise, the feature will never be exercised in CI loop.
-Takahiro Akashi
- struct efi_device_path *tmp_dp = NULL, *tmp_fp = NULL, *short_fp; struct efi_device_path *initrd_dp = NULL; efi_status_t ret; const struct efi_initrd_dp id_dp = {
if (!short_fp)
short_fp = tmp_fp;
tmp_fp);
short_fp);
- struct efi_device_path *fp_free = NULL; struct efi_device_path *final_fp = NULL; struct efi_device_path *initrd_dp = NULL; struct efi_load_option lo;
&device_path, &fp_free); if (ret != EFI_SUCCESS) { printf("Cannot create device path for \"%s %s\"\n", argv[3], argv[4]); r = CMD_RET_FAILURE; goto out; }
if (!file_path)
return r;
- efi_dp_shorten() - shorten device-path
- We can have device paths that start with a USB WWID or a USB Class node,
- and a few other cases which don't encode the full device path with bus
- hierarchy:
- MEDIA:FILE_PATH
- MEDIA:HARD_DRIVE
- MESSAGING:URI
- MEDIA:FILE_PATH
- MEDIA:HARD_DRIVE
- MESSAGING:URI
- See UEFI spec (section 3.1.2, about short-form device-paths)
- @dp: original devie-path
- @Return: shortened device-path or NULL
} while (short_path && obj_dp); }obj_dp = efi_dp_shorten(efi_dp_next(obj_dp));
-- 2.34.1
-Takahiro Akashi
Dear Takahiro,
thanks for reviewing. In the next round I will alternative options -b/-B, -i/-I to choose between long and short device path.
I will create a Python test exposes a initrd via LoadFile2 protocol and then use initrddump.efi as binary payload and to check the content of the initrd.
Best regards
Heinrich
if (!short_fp)
short_fp = tmp_fp;
tmp_fp);
short_fp);
if (!file_path)
return r;
- hierarchy:
- MEDIA:FILE_PATH
- MEDIA:HARD_DRIVE
- MESSAGING:URI
- MEDIA:FILE_PATH
- MEDIA:HARD_DRIVE
- MESSAGING:URI
-- 2.34.1
AKASHI Takahiro
