[U-Boot] [PATCH] arm64 :show_regs: show the real hardware register even after relocation
Not only show the calculated value after relocation, also show the real hardware register value.
Signed-off-by: Peng Fan peng.fan@nxp.com Reported-by: Karl Beldan karl.beldan@gmail.com --- arch/arm/lib/interrupts_64.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/arch/arm/lib/interrupts_64.c b/arch/arm/lib/interrupts_64.c index cbcfeec2b0..843d9fcd54 100644 --- a/arch/arm/lib/interrupts_64.c +++ b/arch/arm/lib/interrupts_64.c @@ -30,13 +30,14 @@ void show_regs(struct pt_regs *regs) { int i;
+ printf("ELR: %lx\n", regs->elr); + printf("LR: %lx\n", regs->regs[30]); if (gd->flags & GD_FLG_RELOC) { - printf("ELR: %lx\n", regs->elr - gd->reloc_off); - printf("LR: %lx\n", regs->regs[30] - gd->reloc_off); - } else { - printf("ELR: %lx\n", regs->elr); - printf("LR: %lx\n", regs->regs[30]); + printf("reloc ELR: %lx lr: %lx\n", + regs->elr - gd->reloc_off, + regs->regs[30] - gd->reloc_off); } + for (i = 0; i < 29; i += 2) printf("x%-2d: %016lx x%-2d: %016lx\n", i, regs->regs[i], i+1, regs->regs[i+1]);
- printf("LR: %lx\n", regs->regs[30]); if (gd->flags & GD_FLG_RELOC) {
- } else {
While formatting is often subjective, the other contributors took care of properly aligning all reg names and vals for other archs as much as possible in an homogeneous way, but it doesn't seem to be the case here.
With your change our stack traces would now look like: {
ELR: cff00ff LR: ab00 reloc ELR: fffc00000cff00ff lr: fffc00000000ab00 x0 : 000000000000000a x1 : 000000000000000a [...] x28: 0000000000000000 x29: 0000000000000000
} instead of e.g.: {
elr: 000000000cff00ff lr : 000000000000ab00 elr: fffc00000cff00ff lr : fffc00000000ab00 (reloc) x0 : 000000000000000a x1 : 000000000000000a [...] x28: 0000000000000000 x29: 0000000000000000
Regards, Karl
Karl Beldan
Peng Fan
