[U-Boot] [PATCH] arm: atmel: cpux9k2: board update and enhancement
From: "Jens Scharsig (BuS Elektronik)" esw@bus-elektronik.de
- remove jffs2 support, board doesn't use this anymore - add ubifs support - change sizes and start for partitions
Signed-off-by: Jens Scharsig (BuS Elektronik) esw@bus-elektronik.de --- include/configs/eb_cpux9k2.h | 61 ++++++++++++++++++++++---------------------- localversion-eb_cpux9k2 | 2 +- 2 files changed, 32 insertions(+), 31 deletions(-)
diff --git a/include/configs/eb_cpux9k2.h b/include/configs/eb_cpux9k2.h index 0d07ac4..b35f2c7 100644 --- a/include/configs/eb_cpux9k2.h +++ b/include/configs/eb_cpux9k2.h @@ -140,41 +140,40 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_DHCP #define CONFIG_CMD_I2C -#define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII #define CONFIG_CMD_NAND #define CONFIG_CMD_PING -#define CONFIG_I2C_CMD_NO_FLAT #define CONFIG_I2C_CMD_TREE #define CONFIG_CMD_USB #define CONFIG_CMD_FAT - +#define CONFIG_CMD_UBI +#define CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_UBIFS #define CONFIG_SYS_LONGHELP
/* - * Filesystems + * MTD defines */
-#define CONFIG_JFFS2_NAND 1 +#define CONFIG_FLASH_CFI_MTD +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_RBTREE +#define CONFIG_LZO
-#ifndef CONFIG_JFFS2_CMDLINE -#define CONFIG_JFFS2_DEV "nand0" -#define CONFIG_JFFS2_PART_OFFSET 0 -#define CONFIG_JFFS2_PART_SIZE 0xFFFFFFFF -#else -#define MTDIDS_DEFAULT "nor0=0,nand0=1" +#define MTDIDS_DEFAULT "nor0=physmap-flash.0,nand0=atmel_nand" #define MTDPARTS_DEFAULT "mtdparts=" \ - "0:" \ - "384k(U-Boot)," \ - "128k(Env)," \ - "128k(Splash)," \ - "4M(Kernel)," \ - "-(FS)" \ + "physmap-flash.0:" \ + "512k(U-Boot)," \ + "128k(Env)," \ + "128k(Splash)," \ + "4M(Kernel)," \ + "384k(MiniFS)," \ + "-(FS)" \ ";" \ - "1:" \ - "-(jffs2)" -#endif /* CONFIG_JFFS2_CMDLINE */ - + "atmel_nand:" \ + "1M(emergency)," \ + "-(data)" /* * Hardware drivers */ @@ -348,7 +347,7 @@ #define CONFIG_BOOTDELAY 5
#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR (PHYS_FLASH_1 + 0x60000) +#define CONFIG_ENV_ADDR (PHYS_FLASH_1 + 0x80000) #define CONFIG_ENV_SIZE 0x20000 /* sectors are 128K here */
#define CONFIG_BAUDRATE 115200 @@ -367,12 +366,14 @@ "displayheight=512\0" \ "displaybsteps=1023\0" \ "ubootaddr=10000000\0" \ - "splashimage=10080000\0" \ - "kerneladdr=100A0000\0" \ + "splashimage=100A0000\0" \ + "kerneladdr=100C0000\0" \ "kernelsize=00400000\0" \ - "rootfsaddr=10500000\0" \ + "rootfsaddr=10520000\0" \ "copy_addr=21200000\0" \ - "rootfssize=00B00000\0" \ + "rootfssize=00AE0000\0" \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ "bootargsdefaults=set bootargs " \ "console=ttyS0,115200 " \ "video=vcxk_fb:xres:${displaywidth}," \ @@ -393,15 +394,15 @@ "erase $(rootfsaddr) +$(rootfssize);" \ "cp.b $(fileaddr) $(rootfsaddr) $(filesize);" \ "\0" \ - "update_uboot=protect off 10000000 1005FFFF;" \ + "update_uboot=protect off 10000000 1007FFFF;" \ "dhcp $(copy_addr) u-boot_eb_cpux9k2;" \ - "erase 10000000 1005FFFF;" \ + "erase 10000000 1007FFFF;" \ "cp.b $(fileaddr) $(ubootaddr) $(filesize);" \ - "protect on 10000000 1005FFFF;reset\0" \ + "protect on 10000000 1007FFFF;reset\0" \ "update_splash=protect off $(splashimage) +20000;" \ "dhcp $(copy_addr) splash_eb_cpux9k2.bmp;" \ "erase $(splashimage) +20000;" \ - "cp.b $(fileaddr) 10080000 $(filesize);" \ + "cp.b $(fileaddr) $(splashimage) $(filesize);" \ "protect on $(splashimage) +20000;reset\0" \ "emergency=run bootargsdefaults;" \ "set bootargs $(bootargs) root=initramfs boot=emergency " \ diff --git a/localversion-eb_cpux9k2 b/localversion-eb_cpux9k2 index 8b13789..b7e2d62 100644 --- a/localversion-eb_cpux9k2 +++ b/localversion-eb_cpux9k2 @@ -1 +1 @@ - +.1
