[U-Boot] [PATCH 2/6] dm: pci: Correct primary/secondary/subordinate bus number assignment
In driver model, each pci bridge device has its own hose structure. hose->first_busno points to the bridge device's device number, so we should not substract hose->first_busno before programming the bridge device's primary/secondary/subordinate bus number registers.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/pci/pci_auto.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index e034ed1..ef6dc4f 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -224,10 +224,15 @@ void pciauto_prescan_setup_bridge(struct pci_controller *hose, prefechable_64 &= PCI_PREF_RANGE_TYPE_MASK;
/* Configure bus number registers */ +#ifdef CONFIG_DM_PCI + pci_hose_write_config_byte(hose, dev, PCI_PRIMARY_BUS, PCI_BUS(dev)); + pci_hose_write_config_byte(hose, dev, PCI_SECONDARY_BUS, sub_bus); +#else pci_hose_write_config_byte(hose, dev, PCI_PRIMARY_BUS, PCI_BUS(dev) - hose->first_busno); pci_hose_write_config_byte(hose, dev, PCI_SECONDARY_BUS, sub_bus - hose->first_busno); +#endif pci_hose_write_config_byte(hose, dev, PCI_SUBORDINATE_BUS, 0xff);
if (pci_mem) { @@ -295,8 +300,12 @@ void pciauto_postscan_setup_bridge(struct pci_controller *hose, struct pci_region *pci_io = hose->pci_io;
/* Configure bus number registers */ +#ifdef CONFIG_DM_PCI + pci_hose_write_config_byte(hose, dev, PCI_SUBORDINATE_BUS, sub_bus); +#else pci_hose_write_config_byte(hose, dev, PCI_SUBORDINATE_BUS, sub_bus - hose->first_busno); +#endif
if (pci_mem) { /* Round memory allocator to 1MB boundary */
Hi Bin,
Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org
I'm not happy with how each PCI bridge has its own hose structure. I think that was a mistake. It just creates problems.
I'm thinking we should instead have a UCLASS_PCI which is strictly for the PCI controller, and a new UCLASS_PCI_BRIDGE for bridges.
What do you think?
Hi Simon,
On Mon, Jul 20, 2015 at 9:59 AM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
What do you think?
I guess that may help. During the debug, I feel the dm pci codes are really not that intuitive than the previous non-dm version. It took me sometime to figure out where is the problem.
Regards, Bin
Hi Bin,
On 19 July 2015 at 20:38, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
What do you think?
Agreed. Part of the problem I think is that it is still compatible with the old code.
We should be able to do things like pci_read_config16(struct udevice *dev, ...)
I guess we could move to separate things more.
On 19 July 2015 at 19:59, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Applied to u-boot-x86, thanks!
[snip]
Bin Meng
