[U-Boot] [PATCH v2 1/2] serial: xuartlite: Staticize local functions
Staticize local functions in xuartlite driver.
Signed-off-by: Axel Lin axel.lin@ingics.com --- v2: Also staticize userial##port##_* functions
drivers/serial/serial_xuartlite.c | 20 ++++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/drivers/serial/serial_xuartlite.c b/drivers/serial/serial_xuartlite.c index 9c1d025..e613994 100644 --- a/drivers/serial/serial_xuartlite.c +++ b/drivers/serial/serial_xuartlite.c @@ -39,7 +39,7 @@ static struct uartlite *userial_ports[4] = { #endif };
-void uartlite_serial_putc(const char c, const int port) +static void uartlite_serial_putc(const char c, const int port) { struct uartlite *regs = userial_ports[port];
@@ -51,13 +51,13 @@ void uartlite_serial_putc(const char c, const int port) out_be32(®s->tx_fifo, c & 0xff); }
-void uartlite_serial_puts(const char *s, const int port) +static void uartlite_serial_puts(const char *s, const int port) { while (*s) uartlite_serial_putc(*s++, port); }
-int uartlite_serial_getc(const int port) +static int uartlite_serial_getc(const int port) { struct uartlite *regs = userial_ports[port];
@@ -66,7 +66,7 @@ int uartlite_serial_getc(const int port) return in_be32(®s->rx_fifo) & 0xff; }
-int uartlite_serial_tstc(const int port) +static int uartlite_serial_tstc(const int port) { struct uartlite *regs = userial_ports[port];
@@ -82,16 +82,16 @@ static int uartlite_serial_init(const int port)
/* Multi serial device functions */ #define DECLARE_ESERIAL_FUNCTIONS(port) \ - int userial##port##_init(void) \ + static int userial##port##_init(void) \ { return uartlite_serial_init(port); } \ - void userial##port##_setbrg(void) {} \ - int userial##port##_getc(void) \ + static void userial##port##_setbrg(void) {} \ + static int userial##port##_getc(void) \ { return uartlite_serial_getc(port); } \ - int userial##port##_tstc(void) \ + static int userial##port##_tstc(void) \ { return uartlite_serial_tstc(port); } \ - void userial##port##_putc(const char c) \ + static void userial##port##_putc(const char c) \ { uartlite_serial_putc(c, port); } \ - void userial##port##_puts(const char *s) \ + static void userial##port##_puts(const char *s) \ { uartlite_serial_puts(s, port); }
/* Serial device descriptor */
Staticize local functions in s5p serial driver.
Signed-off-by: Axel Lin axel.lin@ingics.com --- v2: Also staticize s5p_serial##port##_* functions
drivers/serial/serial_s5p.c | 24 ++++++++++++------------ 1 file changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/serial/serial_s5p.c b/drivers/serial/serial_s5p.c index f98b422..cc20d2d 100644 --- a/drivers/serial/serial_s5p.c +++ b/drivers/serial/serial_s5p.c @@ -65,7 +65,7 @@ static const int udivslot[] = { 0xffdf, };
-void serial_setbrg_dev(const int dev_index) +static void serial_setbrg_dev(const int dev_index) { struct s5p_uart *const uart = s5p_get_base_uart(dev_index); u32 uclk = get_uart_clk(dev_index); @@ -96,7 +96,7 @@ void serial_setbrg_dev(const int dev_index) * Initialise the serial port with the given baudrate. The settings * are always 8 data bits, no parity, 1 stop bit, no start bits. */ -int serial_init_dev(const int dev_index) +static int serial_init_dev(const int dev_index) { struct s5p_uart *const uart = s5p_get_base_uart(dev_index);
@@ -138,7 +138,7 @@ static int serial_err_check(const int dev_index, int op) * otherwise. When the function is succesfull, the character read is * written into its argument c. */ -int serial_getc_dev(const int dev_index) +static int serial_getc_dev(const int dev_index) { struct s5p_uart *const uart = s5p_get_base_uart(dev_index);
@@ -158,7 +158,7 @@ int serial_getc_dev(const int dev_index) /* * Output a single byte to the serial port. */ -void serial_putc_dev(const char c, const int dev_index) +static void serial_putc_dev(const char c, const int dev_index) { struct s5p_uart *const uart = s5p_get_base_uart(dev_index);
@@ -181,7 +181,7 @@ void serial_putc_dev(const char c, const int dev_index) /* * Test whether a character is in the RX buffer */ -int serial_tstc_dev(const int dev_index) +static int serial_tstc_dev(const int dev_index) { struct s5p_uart *const uart = s5p_get_base_uart(dev_index);
@@ -191,7 +191,7 @@ int serial_tstc_dev(const int dev_index) return (int)(readl(&uart->utrstat) & 0x1); }
-void serial_puts_dev(const char *s, const int dev_index) +static void serial_puts_dev(const char *s, const int dev_index) { while (*s) serial_putc_dev(*s++, dev_index); @@ -199,12 +199,12 @@ void serial_puts_dev(const char *s, const int dev_index)
/* Multi serial device functions */ #define DECLARE_S5P_SERIAL_FUNCTIONS(port) \ -int s5p_serial##port##_init(void) { return serial_init_dev(port); } \ -void s5p_serial##port##_setbrg(void) { serial_setbrg_dev(port); } \ -int s5p_serial##port##_getc(void) { return serial_getc_dev(port); } \ -int s5p_serial##port##_tstc(void) { return serial_tstc_dev(port); } \ -void s5p_serial##port##_putc(const char c) { serial_putc_dev(c, port); } \ -void s5p_serial##port##_puts(const char *s) { serial_puts_dev(s, port); } +static int s5p_serial##port##_init(void) { return serial_init_dev(port); } \ +static void s5p_serial##port##_setbrg(void) { serial_setbrg_dev(port); } \ +static int s5p_serial##port##_getc(void) { return serial_getc_dev(port); } \ +static int s5p_serial##port##_tstc(void) { return serial_tstc_dev(port); } \ +static void s5p_serial##port##_putc(const char c) { serial_putc_dev(c, port); } \ +static void s5p_serial##port##_puts(const char *s) { serial_puts_dev(s, port); }
#define INIT_S5P_SERIAL_STRUCTURE(port, __name) { \ .name = __name, \
Acked-by: Minkyu Kang mk7.kang@samsung.com
Thanks, Minkyu Kang.
Signed-off-by: Axel Lin axel.lin@ingics.com Acked-by: Minkyu Kang mk7.kang@samsung.com
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
Tested-by: Michal Simek monstr@monstr.eu
Thanks, Michal
Signed-off-by: Axel Lin axel.lin@ingics.com Acked-by: Stefan Roese sr@denx.de Tested-by: Michal Simek monstr@monstr.eu
participants (5)
Axel Lin
Michal Simek
Minkyu Kang
Stefan Roese
