[U-Boot] [PATCH] spl: mmc: Add option to set eMMC HW boot partition
This change allows setting pre-defined eMMC boot partition for SPL eMMC booting. It is necessary in the case when one wants to boot (through falcon boot) from eMMC after loading SPL from other memory (like SPI-NOR).
Signed-off-by: Mans Rullgard mans@mansr.com [lukma: Edit the commit message] Signed-off-by: Lukasz Majewski lukma@denx.de Acked-by: Andreas Dannenberg dannenberg@ti.com
common/spl/Kconfig | 6 ++++++ common/spl/spl_mmc.c | 4 ++++ 2 files changed, 10 insertions(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index f467eca2be..5b7667ea16 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -314,6 +314,12 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR Address on the MMC to load U-Boot from, when the MMC is being used in raw mode. Units: MMC sectors (1 sector = 512 bytes).
+config SYS_MMCSD_RAW_MODE_EMMC_BOOT_PARTITION + int "Number of the eMMC boot partition to use" + default 1 + help + eMMC boot partition number to use when the eMMC in raw mode. + config SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION bool "MMC Raw mode: by partition" help diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 2caceb5186..a4d2e63b82 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -334,6 +334,9 @@ int spl_mmc_load(struct spl_image_info *spl_image, err = -EINVAL; switch (boot_mode) { case MMCSD_MODE_EMMCBOOT: +#ifdef CONFIG_SYS_MMCSD_RAW_MODE_EMMC_BOOT_PARTITION + part = CONFIG_SYS_MMCSD_RAW_MODE_EMMC_BOOT_PARTITION; +#else /* * We need to check what the partition is configured to. * 1 and 2 match up to boot0 / boot1 and 7 is user data @@ -343,6 +346,7 @@ int spl_mmc_load(struct spl_image_info *spl_image,
if (part == 7) part = 0; +#endif
if (CONFIG_IS_ENABLED(MMC_TINY)) err = mmc_switch_part(mmc, part);
Would it be better if this came from /chosen node in DT ?
Marek Vasut marex@denx.de writes:
This patch was made for an imx28 based board. Fitting DT support into SPL on that chip won't be easy.
Hi Måns, Marek,
Unfortunately, on purpose the DT support for SPL on this board is disabled.
This is the case where the only eligible option is to use OF_PLATDATA, to benefit from DM drivers, but also to keep the size as small as possible.
(Please refer to xea board support patches for more details).
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On 9/3/19 5:49 PM, Lukasz Majewski wrote:
Hi Måns, Marek,
Hm, then shall we use platdata ? I don't think that fits common code like this either.
Hi Marek,
Hi Måns, Marek,
Yes, correct. The OF_PLATDATA allows you to use DM/DTS converted driver with platform data encoded in the C structures.
For example such patch adds support for OF_PLATDATA to DM/DTS driver: https://patchwork.ozlabs.org/patch/1148906/
Please see above link.
Lukasz Majewski
Dear Tom,
Tom, are there any issues preventing this patch from being applied to -master?
- int "Number of the eMMC boot partition to use"
- default 1
- help
+#else /* * We need to check what the partition is configured to. * 1 and 2 match up to boot0 / boot1 and 7 is user data @@ -343,6 +346,7 @@ int spl_mmc_load(struct spl_image_info *spl_image, if (part == 7) part = 0; +#endif
Lukasz Majewski
On Wed, Oct 09, 2019 at 11:07:18AM +0200, Lukasz Majewski wrote:
Dear Tom,
Keeping in mind that we do need to allow for SPL to do reasonable things to retain a smaller footprint, this is fine. If Peng doesn't pick it up as an MMC change I'll get it soon.
Hi Tom,
Subject: Re: [PATCH] spl: mmc: Add option to set eMMC HW boot partition
Dear Tom,
It not in my patchwork list, so I not pick it. Please directly pick it up since it is ok to you.
Thanks, Peng.
-- Tom
participants (5)
Lukasz Majewski
Måns Rullgård
Peng Fan
