Re: [U-Boot] [PATCH v3 0/7] Addition of new board Peach-Pi
Hi Simon,
Hi Akshay,
On 31 October 2014 02:55, Akshay Saraswat akshay.s@samsung.com wrote:
Now we are adding a new Peach-Pi board which is a variant of Peach-Pit and is based on Exynos5800. Exynos5800 itself is a variant of Exynos5420, hence, most of the hardware config and settings are reused for this board.
Changes since v1: - Rebased all the patches
Changes since v2: - Rebased all the patches - Added new patch "Enable update mode for DREX controller"
This last patch fixed USB for me, pleased you found the problem!
The display doesn't work yet - will that be the next series?
Thanks for testing. Ajay will send the patch for display.
Also I had to drop the clock to 900MHz as with Pit. It must be something odd I am doing, but I'm not sure what.
For my board it works fine. I am trying to reproduce it. I'll post the fix as soon as I see the problem.
Regards, Akshay Saraswat
Hi Akshay,
On 13 November 2014 10:16, Akshay Saraswat akshay.s@samsung.com wrote:
Hi Simon,
Hi Akshay,
Let's not worry about it. I'll see if I can dig into it one day, but if the problem doesn't happen for you then I'm not bothered about it. There could be various strange things about my setup.
Akshay Saraswat
