[U-Boot] [PATCH] env: spi: Fix incorrect entry description
Fix the max frequency entry description, it's incorrect.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Chris Brandt chris.brandt@renesas.com Cc: Jagan Teki jagan@amarulasolutions.com Cc: Tom Rini trini@konsulko.com --- env/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/env/Kconfig b/env/Kconfig index 78300660c7..70858d3b40 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -351,14 +351,14 @@ config ENV_SPI_CS Value of the SPI chip select for environment.
config USE_ENV_SPI_MAX_HZ - bool "SPI flash bus for environment" + bool "SPI flash max frequency for environment" depends on ENV_IS_IN_SPI_FLASH help Force the SPI max work clock for environment. If not defined, use CONFIG_SF_DEFAULT_SPEED.
config ENV_SPI_MAX_HZ - int "Value of SPI flash max work for environment" + int "Value of SPI flash max frequency for environment" depends on USE_ENV_SPI_MAX_HZ help Value of the SPI max work clock for environment.
