[U-Boot] [PATCH 00/11] mtd/SMI: Add support for ST SMI controller
In the current u-boot, a driver exists for ST's SMI controller. However, the driver is SPEAr specific. This patchset makes the driver more generic so that it can be used across multiple platforms.
In the first commit, the driver is renamed to st_smi. In subsequent patches, changes are introduced so as to make the driver generic.
Amit Virdi (4): st_smi: Remove compilation warning st_smi: Return error in case TFF is not set st_smi: Change SMI timeout values st_smi: Enhance the error handling
Armando Visconti (3): st_smi: Removed no needed dependency on ST_M25Pxx_ID st_smi: Change the flash probing method st_smi: Fix bug in flash_print_info()
Shiraz Hashim (1): st_smi: Move status register read before modifying ctrl register
Vipin KUMAR (2): st_smi: Add support for SPEAr SMI driver st_smi: Read status until timeout happens
Vipin Kumar (1): st_smi: Fix smi read status
drivers/mtd/Makefile | 2 +- drivers/mtd/{spr_smi.c => st_smi.c} | 223 ++++++++++++-------- include/configs/spear-common.h | 6 +- .../spr_smi.h => include/linux/mtd/st_smi.h | 10 +- 4 files changed, 140 insertions(+), 101 deletions(-) rename drivers/mtd/{spr_smi.c => st_smi.c} (66%) rename arch/arm/include/asm/arch-spear/spr_smi.h => include/linux/mtd/st_smi.h (95%)
SMI is the serial memory interface controller provided by ST.
Earlier, a driver exists in the u-boot source code for the SMI IP. However, it was specific to spear platforms. This commit converts the same driver to a more generic driver. As a result, the driver files are renamed to st_smi.c and st_smi.h and moved into drivers/mtd folder for reusability by other platforms using smi controller peripheral.
Signed-off-by: Vipin Kumar vipin.kumar@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/mtd/Makefile | 2 +- drivers/mtd/{spr_smi.c => st_smi.c} | 5 +++-- include/configs/spear-common.h | 6 +++--- .../spr_smi.h => include/linux/mtd/st_smi.h | 6 ++++-- 4 files changed, 11 insertions(+), 8 deletions(-) rename drivers/mtd/{spr_smi.c => st_smi.c} (99%) rename arch/arm/include/asm/arch-spear/spr_smi.h => include/linux/mtd/st_smi.h (98%)
diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index 5a5ecdf..543c845 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -35,7 +35,7 @@ COBJS-$(CONFIG_HAS_DATAFLASH) += dataflash.o COBJS-$(CONFIG_FTSMC020) += ftsmc020.o COBJS-$(CONFIG_FLASH_CFI_LEGACY) += jedec_flash.o COBJS-$(CONFIG_MW_EEPROM) += mw_eeprom.o -COBJS-$(CONFIG_SPEARSMI) += spr_smi.o +COBJS-$(CONFIG_ST_SMI) += st_smi.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/mtd/spr_smi.c b/drivers/mtd/st_smi.c similarity index 99% rename from drivers/mtd/spr_smi.c rename to drivers/mtd/st_smi.c index 9a70a19..b514046 100644 --- a/drivers/mtd/spr_smi.c +++ b/drivers/mtd/st_smi.c @@ -24,10 +24,10 @@ #include <common.h> #include <flash.h> #include <linux/err.h> +#include <linux/mtd/st_smi.h>
#include <asm/io.h> #include <asm/arch/hardware.h> -#include <asm/arch/spr_smi.h>
#if !defined(CONFIG_SYS_NO_FLASH)
@@ -82,6 +82,7 @@ static unsigned int smi_read_id(flash_info_t *info, int banknum) writel(READ_ID, &smicntl->smi_tr); writel((banknum << BANKSEL_SHIFT) | SEND | TX_LEN_1 | RX_LEN_3, &smicntl->smi_cr2); + smi_wait_xfer_finish(XFER_FINISH_TOUT);
value = (readl(&smicntl->smi_rr) & 0x00FFFFFF); @@ -232,7 +233,7 @@ static int smi_write_enable(int bank) * * SMI initialization routine. Sets SMI control register1. */ -static void smi_init(void) +void smi_init(void) { /* Setting the fast mode values. SMI working at 166/4 = 41.5 MHz */ writel(HOLD1 | FAST_MODE | BANK_EN | DSEL_TIME | PRESCAL4, diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index 3947fd5..5a582e8 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -55,10 +55,10 @@ #if defined(CONFIG_FLASH_PNOR) #define CONFIG_SPEAR_EMI #else -#define CONFIG_SPEARSMI +#define CONFIG_ST_SMI #endif
-#if defined(CONFIG_SPEARSMI) +#if defined(CONFIG_ST_SMI)
#define CONFIG_SYS_MAX_FLASH_BANKS 2 #define CONFIG_SYS_FLASH_BASE 0xF8000000 @@ -124,7 +124,7 @@ * U-Boot Environment placing definitions. */ #if defined(CONFIG_ENV_IS_IN_FLASH) -#ifdef CONFIG_SPEARSMI +#ifdef CONFIG_ST_SMI /* * Environment is in serial NOR flash */ diff --git a/arch/arm/include/asm/arch-spear/spr_smi.h b/include/linux/mtd/st_smi.h similarity index 98% rename from arch/arm/include/asm/arch-spear/spr_smi.h rename to include/linux/mtd/st_smi.h index 06df745..b7a78ac 100644 --- a/arch/arm/include/asm/arch-spear/spr_smi.h +++ b/include/linux/mtd/st_smi.h @@ -21,8 +21,8 @@ * MA 02111-1307 USA */
-#ifndef SPR_SMI_H -#define SPR_SMI_H +#ifndef ST_SMI_H +#define ST_SMI_H
/* 0xF800.0000 . 0xFBFF.FFFF 64MB SMI (Serial Flash Mem) */ /* 0xFC00.0000 . 0xFC1F.FFFF 2MB SMI (Serial Flash Reg.) */ @@ -112,4 +112,6 @@ struct flash_dev { #define XFER_FINISH_TOUT 2 /* xfer finish timeout */ #define WMODE_TOUT 2 /* write enable timeout */
+extern void smi_init(void); + #endif
Hi Amit,
Since u-boot/next is now available, I wanted to apply some SPEAr patches. Mainly the "st_smi" patch series:
[PATCH 01/11] st_smi: Add support for SPEAr SMI driver ...
and the SPEAr platform rework:
[PATCH V2 00/24] SPEAr: Update platform support for SPEAr3xx/6xx ...
Unfortunately the first patch series doesn't apply any more to "next":
[stefan@kubuntu u-boot-staging (sr@denx.de)]$ git am -s bundle-2819.mbox Applying: st_smi: Add support for SPEAr SMI driver error: patch failed: include/configs/spear-common.h:55 error: include/configs/spear-common.h: patch does not apply Patch failed at 0001 st_smi: Add support for SPEAr SMI driver
Could you please rebase your patch series on "next"? And make sure that all SPEAr based boards still compile clean?
Thanks, Stefan
Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/mtd/st_smi.c | 5 ----- 1 files changed, 0 insertions(+), 5 deletions(-)
diff --git a/drivers/mtd/st_smi.c b/drivers/mtd/st_smi.c index b514046..82f1fe1 100644 --- a/drivers/mtd/st_smi.c +++ b/drivers/mtd/st_smi.c @@ -323,24 +323,19 @@ static int smi_write(unsigned int *src_addr, unsigned int *dst_addr, unsigned int length, ulong bank_addr) { int banknum; - unsigned int WM;
switch (bank_addr) { case SMIBANK0_BASE: banknum = BANK0; - WM = WM0; break; case SMIBANK1_BASE: banknum = BANK1; - WM = WM1; break; case SMIBANK2_BASE: banknum = BANK2; - WM = WM2; break; case SMIBANK3_BASE: banknum = BANK3; - WM = WM3; break; default: return -1;
Curently the code makes wrong assumption that the Transfer finished flag shall be set within the stipulated time. However, there may occur a scenario in which the TFF flag is not set. Return error in that case.
Signed-off-by: Vipin Kumar vipin.kumar@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/mtd/st_smi.c | 22 ++++++++++++++-------- 1 files changed, 14 insertions(+), 8 deletions(-)
diff --git a/drivers/mtd/st_smi.c b/drivers/mtd/st_smi.c index 82f1fe1..ec19b0d 100644 --- a/drivers/mtd/st_smi.c +++ b/drivers/mtd/st_smi.c @@ -58,13 +58,15 @@ static struct flash_dev flash_ids[] = { * * Wait until TFF is set in status register */ -static void smi_wait_xfer_finish(int timeout) +static int smi_wait_xfer_finish(int timeout) { - while (timeout--) { + do { if (readl(&smicntl->smi_sr) & TFF) - break; + return 0; udelay(1000); - } + } while (timeout--); + + return -1; }
/* @@ -83,7 +85,8 @@ static unsigned int smi_read_id(flash_info_t *info, int banknum) writel((banknum << BANKSEL_SHIFT) | SEND | TX_LEN_1 | RX_LEN_3, &smicntl->smi_cr2);
- smi_wait_xfer_finish(XFER_FINISH_TOUT); + if (smi_wait_xfer_finish(XFER_FINISH_TOUT)) + return -EIO;
@@ -151,7 +154,8 @@ static unsigned int smi_read_sr(int bank) /* Performing a RSR instruction in HW mode */ writel((bank << BANKSEL_SHIFT) | RD_STATUS_REG, &smicntl->smi_cr2);
- smi_wait_xfer_finish(XFER_FINISH_TOUT); + if (smi_wait_xfer_finish(XFER_FINISH_TOUT)) + return -1;
/* Restore the CTRL REG1 state */ writel(ctrlreg1, &smicntl->smi_cr1); @@ -211,7 +215,8 @@ static int smi_write_enable(int bank) /* Give the Flash, Write Enable command */ writel((bank << BANKSEL_SHIFT) | WE, &smicntl->smi_cr2);
/* Restore the CTRL REG1 state */ writel(ctrlreg1, &smicntl->smi_cr1); @@ -292,7 +297,8 @@ static int smi_sector_erase(flash_info_t *info, unsigned int sector) writel(instruction, &smicntl->smi_tr); writel((bank << BANKSEL_SHIFT) | SEND | TX_LEN_4, &smicntl->smi_cr2); - smi_wait_xfer_finish(XFER_FINISH_TOUT); + if (smi_wait_xfer_finish(XFER_FINISH_TOUT)) + return -EIO;
if (smi_wait_till_ready(bank, CONFIG_SYS_FLASH_ERASE_TOUT)) return -EBUSY;
- Wait until TFF is set in status register
- do { if (readl(&smicntl->smi_sr) & TFF)
break;
udelay(1000);return 0;
- } while (timeout--);
- return -1;
Somewhat unrelated to the patch topic, but I don't really like this kind of timeout loops. Since it always adds at least 1ms delay after initial failing test. Better use something like this:
static int smi_wait_xfer_finish(int timeout) { ulong start = get_timer(0);
while (get_timer(start) < timeout) { if (readl(&smicntl->smi_sr) & TFF) return 0;
/* Try again after 100usec */ udelay(100); }
return -1; }
You could tune this udelay(100) down more or even remove it completely.
But such a change could be done in a addon cleanup patch, changing all timeout loops this way. I suggest you take a look at my version, here these loops are changes. In the designware networking driver as well, iirc.
Thanks, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Hello Stefan,
Signed-off-by: Vipin Kumarvipin.kumar@st.com Signed-off-by: Amit Virdiamit.virdi@st.com
- do { if (readl(&smicntl->smi_sr)& TFF)
break;
- return -1;
while (get_timer(start)< timeout) { if (readl(&smicntl->smi_sr)& TFF) return 0;
return -1; }
Thanks for pointing out. In a separate cleanup patch, I shall be changing all the timeout loops for smi driver. I'll check other ST drivers too and change the timer implementation there too.
Regards Amit Virdi
Hi Amit,
Good.
Thanks, Stefan
Signed-off-by: Amit Virdi amit.virdi@st.com --- include/linux/mtd/st_smi.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/linux/mtd/st_smi.h b/include/linux/mtd/st_smi.h index b7a78ac..04f81ea 100644 --- a/include/linux/mtd/st_smi.h +++ b/include/linux/mtd/st_smi.h @@ -109,8 +109,8 @@ struct flash_dev { };
#define SFLASH_PAGE_SIZE 0x100 /* flash page size */ -#define XFER_FINISH_TOUT 2 /* xfer finish timeout */ -#define WMODE_TOUT 2 /* write enable timeout */ +#define XFER_FINISH_TOUT 15 /* xfer finish timeout(in ms) */ +#define WMODE_TOUT 15 /* write enable timeout(in ms) */
This commit does the following: - Reports error if SNOR flash is not found on the board - Changes smi_read_sr to return error using which a retry mechanism is implemented for reading flash status
Signed-off-by: Vipin Kumar vipin.kumar@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/mtd/st_smi.c | 34 +++++++++++++++++++++------------- 1 files changed, 21 insertions(+), 13 deletions(-)
diff --git a/drivers/mtd/st_smi.c b/drivers/mtd/st_smi.c index ec19b0d..ce50fc1 100644 --- a/drivers/mtd/st_smi.c +++ b/drivers/mtd/st_smi.c @@ -108,11 +108,17 @@ static ulong flash_get_size(ulong base, int banknum) { flash_info_t *info = &flash_info[banknum]; struct flash_dev *dev; - unsigned int value; + int value; unsigned int density; int i;
value = smi_read_id(info, banknum); + + if (value < 0) { + printf("Flash id could not be read\n"); + return 0; + } + density = (value >> 16) & 0xff;
for (i = 0, dev = &flash_ids[0]; dev->density != 0x0; @@ -140,7 +146,7 @@ static ulong flash_get_size(ulong base, int banknum) * This routine will get the status register of the flash chip present at the * given bank */ -static unsigned int smi_read_sr(int bank) +static int smi_read_sr(int bank) { u32 ctrlreg1;
@@ -174,13 +180,11 @@ static unsigned int smi_read_sr(int bank) */ static int smi_wait_till_ready(int bank, int timeout) { - int count; - unsigned int sr; + int sr;
/* One chip guarantees max 5 msec wait here after page writes, but potentially three seconds (!) after page erase. */ - for (count = 0; count < timeout; count++) { - + do { sr = smi_read_sr(bank); if (sr < 0) break; @@ -189,7 +193,8 @@ static int smi_wait_till_ready(int bank, int timeout)
/* Try again after 1m-sec */ udelay(1000); - } + } while (timeout--); + printf("SMI controller is still in wait, timeout=%d\n", timeout); return -EIO; } @@ -205,6 +210,7 @@ static int smi_write_enable(int bank) { u32 ctrlreg1; int timeout = WMODE_TOUT; + int sr;
/* Store the CTRL REG1 state */ ctrlreg1 = readl(&smicntl->smi_cr1); @@ -221,14 +227,16 @@ static int smi_write_enable(int bank) /* Restore the CTRL REG1 state */ writel(ctrlreg1, &smicntl->smi_cr1);
- while (timeout--) { - if (smi_read_sr(bank) & (1 << (bank + WM_SHIFT))) + do { + sr = smi_read_sr(bank); + if (sr < 0) break; - udelay(1000); - } + else if (sr & (1 << (bank + WM_SHIFT))) + return 0;
- if (timeout) - return 0; + /* Try again after 1m-sec */ + udelay(1000); + } while (timeout--);
return -1; }
SMI driver read status fails because the control register could not be overwritten. Instead, the read status should be tried until timeout.
Signed-off-by: Vipin Kumar vipin.kumar@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/mtd/st_smi.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/mtd/st_smi.c b/drivers/mtd/st_smi.c index ce50fc1..7b4c6f3 100644 --- a/drivers/mtd/st_smi.c +++ b/drivers/mtd/st_smi.c @@ -187,7 +187,7 @@ static int smi_wait_till_ready(int bank, int timeout) do { sr = smi_read_sr(bank); if (sr < 0) - break; + continue; /* try until timeout */ else if (!(sr & WIP_BIT)) return 0;
Signed-off-by: Shiraz Hashim shiraz.hashim@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/mtd/st_smi.c | 6 ++++-- 1 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/st_smi.c b/drivers/mtd/st_smi.c index 7b4c6f3..eb902b2 100644 --- a/drivers/mtd/st_smi.c +++ b/drivers/mtd/st_smi.c @@ -148,7 +148,7 @@ static ulong flash_get_size(ulong base, int banknum) */ static int smi_read_sr(int bank) { - u32 ctrlreg1; + u32 ctrlreg1, val;
/* store the CTRL REG1 state */ ctrlreg1 = readl(&smicntl->smi_cr1); @@ -163,10 +163,12 @@ static int smi_read_sr(int bank) if (smi_wait_xfer_finish(XFER_FINISH_TOUT)) return -1;
+ val = readl(&smicntl->smi_sr); + /* Restore the CTRL REG1 state */ writel(ctrlreg1, &smicntl->smi_cr1);
- return readl(&smicntl->smi_sr); + return val; }
smi_read_sr fails sometimes because of TFF not getting set within assumed time. This condition may arise because of, for example, smi memory being in a erase mode.
This fix is to enable reading the status register until timeout.
Signed-off-by: Vipin Kumar vipin.kumar@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/mtd/st_smi.c | 8 ++------ 1 files changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/st_smi.c b/drivers/mtd/st_smi.c index eb902b2..e5c803b 100644 --- a/drivers/mtd/st_smi.c +++ b/drivers/mtd/st_smi.c @@ -188,9 +188,7 @@ static int smi_wait_till_ready(int bank, int timeout) but potentially three seconds (!) after page erase. */ do { sr = smi_read_sr(bank); - if (sr < 0) - continue; /* try until timeout */ - else if (!(sr & WIP_BIT)) + if ((sr >= 0) && (!(sr & WIP_BIT))) return 0;
/* Try again after 1m-sec */ @@ -231,9 +229,7 @@ static int smi_write_enable(int bank)
do { sr = smi_read_sr(bank); - if (sr < 0) - break; - else if (sr & (1 << (bank + WM_SHIFT))) + if ((sr >= 0) && (sr & (1 << (bank + WM_SHIFT)))) return 0;
Since the smi erase code is very generic and works for any kind of flash, there is no need to test for ST_M25Pxx_ID flash types like m25p40 flashes).
Signed-off-by: Armando Visconti armando.visconti@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/mtd/st_smi.c | 50 ++++++++++++++++++-------------------------------- 1 files changed, 18 insertions(+), 32 deletions(-)
diff --git a/drivers/mtd/st_smi.c b/drivers/mtd/st_smi.c index e5c803b..43eb2ab 100644 --- a/drivers/mtd/st_smi.c +++ b/drivers/mtd/st_smi.c @@ -37,8 +37,6 @@ static ulong bank_base[CONFIG_SYS_MAX_FLASH_BANKS] = CONFIG_SYS_FLASH_ADDR_BASE; flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS];
-#define ST_M25Pxx_ID 0x00002020 - static struct flash_dev flash_ids[] = { {0x10, 0x10000, 2}, /* 64K Byte */ {0x11, 0x20000, 4}, /* 128K Byte */ @@ -287,39 +285,32 @@ static int smi_sector_erase(flash_info_t *info, unsigned int sector)
writel(readl(&smicntl->smi_sr) & ~(ERF1 | ERF2), &smicntl->smi_sr);
- if (info->flash_id == ST_M25Pxx_ID) { - /* Wait until finished previous write command. */ - if (smi_wait_till_ready(bank, CONFIG_SYS_FLASH_ERASE_TOUT)) - return -EBUSY; + /* Wait until finished previous write command. */ + if (smi_wait_till_ready(bank, CONFIG_SYS_FLASH_ERASE_TOUT)) + return -EBUSY;
- /* Send write enable, before erase commands. */ - if (smi_write_enable(bank)) - return -EIO; + /* Send write enable, before erase commands. */ + if (smi_write_enable(bank)) + return -EIO;
- /* Put SMI in SW mode */ - writel(readl(&smicntl->smi_cr1) | SW_MODE, &smicntl->smi_cr1); + /* Put SMI in SW mode */ + writel(readl(&smicntl->smi_cr1) | SW_MODE, &smicntl->smi_cr1);
- /* Send Sector Erase command in SW Mode */ - writel(instruction, &smicntl->smi_tr); - writel((bank << BANKSEL_SHIFT) | SEND | TX_LEN_4, + /* Send Sector Erase command in SW Mode */ + writel(instruction, &smicntl->smi_tr); + writel((bank << BANKSEL_SHIFT) | SEND | TX_LEN_4, &smicntl->smi_cr2); - if (smi_wait_xfer_finish(XFER_FINISH_TOUT)) - return -EIO; + if (smi_wait_xfer_finish(XFER_FINISH_TOUT)) + return -EIO;
- if (smi_wait_till_ready(bank, CONFIG_SYS_FLASH_ERASE_TOUT)) - return -EBUSY; + if (smi_wait_till_ready(bank, CONFIG_SYS_FLASH_ERASE_TOUT)) + return -EBUSY;
- /* Put SMI in HW mode */ - writel(readl(&smicntl->smi_cr1) & ~SW_MODE, + /* Put SMI in HW mode */ + writel(readl(&smicntl->smi_cr1) & ~SW_MODE, &smicntl->smi_cr1);
- return 0; - } else { - /* Put SMI in HW mode */ - writel(readl(&smicntl->smi_cr1) & ~SW_MODE, - &smicntl->smi_cr1); - return -EINVAL; - } + return 0; }
/* @@ -496,11 +487,6 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) int prot = 0; flash_sect_t sect;
- if (info->flash_id != ST_M25Pxx_ID) { - puts("Can't erase unknown flash type - aborted\n"); - return 1; - } - if ((s_first < 0) || (s_first > s_last)) { puts("- no sectors to erase\n"); return 1;
THis patch introduces a new methodology for flash probing in which flash_devices[] table, looked-up thru the dev_id, is used to locate the flash geometry and information.
Signed-off-by: Armando Visconti armando.visconti@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/mtd/st_smi.c | 92 +++++++++++++++++++++++++++++++++++--------------- 1 files changed, 65 insertions(+), 27 deletions(-)
diff --git a/drivers/mtd/st_smi.c b/drivers/mtd/st_smi.c index 43eb2ab..a308399 100644 --- a/drivers/mtd/st_smi.c +++ b/drivers/mtd/st_smi.c @@ -37,17 +37,61 @@ static ulong bank_base[CONFIG_SYS_MAX_FLASH_BANKS] = CONFIG_SYS_FLASH_ADDR_BASE; flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS];
-static struct flash_dev flash_ids[] = { - {0x10, 0x10000, 2}, /* 64K Byte */ - {0x11, 0x20000, 4}, /* 128K Byte */ - {0x12, 0x40000, 4}, /* 256K Byte */ - {0x13, 0x80000, 8}, /* 512K Byte */ - {0x14, 0x100000, 16}, /* 1M Byte */ - {0x15, 0x200000, 32}, /* 2M Byte */ - {0x16, 0x400000, 64}, /* 4M Byte */ - {0x17, 0x800000, 128}, /* 8M Byte */ - {0x18, 0x1000000, 64}, /* 16M Byte */ - {0x00,} +/* data structure to maintain flash ids from different vendors */ +struct flash_device { + char *name; + u8 erase_cmd; + u32 device_id; + u32 pagesize; + unsigned long sectorsize; + unsigned long size_in_bytes; +}; + +#define FLASH_ID(n, es, id, psize, ssize, size) \ +{ \ + .name = n, \ + .erase_cmd = es, \ + .device_id = id, \ + .pagesize = psize, \ + .sectorsize = ssize, \ + .size_in_bytes = size \ +} + +/* + * List of supported flash devices. + * Currently the erase_cmd field is not used in this driver. + */ +static struct flash_device flash_devices[] = { + FLASH_ID("st m25p16" , 0xd8, 0x00152020, 0x100, 0x10000, 0x200000), + FLASH_ID("st m25p32" , 0xd8, 0x00162020, 0x100, 0x10000, 0x400000), + FLASH_ID("st m25p64" , 0xd8, 0x00172020, 0x100, 0x10000, 0x800000), + FLASH_ID("st m25p128" , 0xd8, 0x00182020, 0x100, 0x40000, 0x1000000), + FLASH_ID("st m25p05" , 0xd8, 0x00102020, 0x80 , 0x8000 , 0x10000), + FLASH_ID("st m25p10" , 0xd8, 0x00112020, 0x80 , 0x8000 , 0x20000), + FLASH_ID("st m25p20" , 0xd8, 0x00122020, 0x100, 0x10000, 0x40000), + FLASH_ID("st m25p40" , 0xd8, 0x00132020, 0x100, 0x10000, 0x80000), + FLASH_ID("st m25p80" , 0xd8, 0x00142020, 0x100, 0x10000, 0x100000), + FLASH_ID("st m45pe10" , 0xd8, 0x00114020, 0x100, 0x10000, 0x20000), + FLASH_ID("st m45pe20" , 0xd8, 0x00124020, 0x100, 0x10000, 0x40000), + FLASH_ID("st m45pe40" , 0xd8, 0x00134020, 0x100, 0x10000, 0x80000), + FLASH_ID("st m45pe80" , 0xd8, 0x00144020, 0x100, 0x10000, 0x100000), + FLASH_ID("sp s25fl004" , 0xd8, 0x00120201, 0x100, 0x10000, 0x80000), + FLASH_ID("sp s25fl008" , 0xd8, 0x00130201, 0x100, 0x10000, 0x100000), + FLASH_ID("sp s25fl016" , 0xd8, 0x00140201, 0x100, 0x10000, 0x200000), + FLASH_ID("sp s25fl032" , 0xd8, 0x00150201, 0x100, 0x10000, 0x400000), + FLASH_ID("sp s25fl064" , 0xd8, 0x00160201, 0x100, 0x10000, 0x800000), + FLASH_ID("mac 25l512" , 0xd8, 0x001020C2, 0x010, 0x10000, 0x10000), + FLASH_ID("mac 25l1005" , 0xd8, 0x001120C2, 0x010, 0x10000, 0x20000), + FLASH_ID("mac 25l2005" , 0xd8, 0x001220C2, 0x010, 0x10000, 0x40000), + FLASH_ID("mac 25l4005" , 0xd8, 0x001320C2, 0x010, 0x10000, 0x80000), + FLASH_ID("mac 25l4005a" , 0xd8, 0x001320C2, 0x010, 0x10000, 0x80000), + FLASH_ID("mac 25l8005" , 0xd8, 0x001420C2, 0x010, 0x10000, 0x100000), + FLASH_ID("mac 25l1605" , 0xd8, 0x001520C2, 0x100, 0x10000, 0x200000), + FLASH_ID("mac 25l1605a" , 0xd8, 0x001520C2, 0x010, 0x10000, 0x200000), + FLASH_ID("mac 25l3205" , 0xd8, 0x001620C2, 0x100, 0x10000, 0x400000), + FLASH_ID("mac 25l3205a" , 0xd8, 0x001620C2, 0x100, 0x10000, 0x400000), + FLASH_ID("mac 25l6405" , 0xd8, 0x001720C2, 0x100, 0x10000, 0x800000), + FLASH_ID("wbd w25q128" , 0xd8, 0x001840EF, 0x1000, 0x10000, 0x1000000), };
/* @@ -105,9 +149,7 @@ static unsigned int smi_read_id(flash_info_t *info, int banknum) static ulong flash_get_size(ulong base, int banknum) { flash_info_t *info = &flash_info[banknum]; - struct flash_dev *dev; int value; - unsigned int density; int i;
value = smi_read_id(info, banknum); @@ -117,24 +159,20 @@ static ulong flash_get_size(ulong base, int banknum) return 0; }
- density = (value >> 16) & 0xff; + /* Matches chip-id to entire list of 'serial-nor flash' ids */ + for (i = 0; i < ARRAY_SIZE(flash_devices); i++) { + if (flash_devices[i].device_id == value) { + info->size = flash_devices[i].size_in_bytes; + info->flash_id = value; + info->start[0] = base; + info->sector_count = + info->size/flash_devices[i].sectorsize;
- for (i = 0, dev = &flash_ids[0]; dev->density != 0x0; - i++, dev = &flash_ids[i]) { - if (dev->density == density) { - info->size = dev->size; - info->sector_count = dev->sector_count; - break; + return info->size; } }
- if (dev->density == 0x0) - return 0; - - info->flash_id = value & 0xffff; - info->start[0] = base; - - return info->size; + return 0; }
If the flash size was smaller than 1MB then flash_print_info() was erroneously reporting 0 MB.
Signed-off-by: Armando Visconti armando.visconti@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/mtd/st_smi.c | 9 +++++++-- 1 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/st_smi.c b/drivers/mtd/st_smi.c index a308399..6d4edba 100644 --- a/drivers/mtd/st_smi.c +++ b/drivers/mtd/st_smi.c @@ -471,8 +471,13 @@ void flash_print_info(flash_info_t *info) puts("missing or unknown FLASH type\n"); return; } - printf(" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); + + if (info->size >= 0x100000) + printf(" Size: %ld MB in %d Sectors\n", + info->size >> 20, info->sector_count); + else + printf(" Size: %ld KB in %d Sectors\n", + info->size >> 10, info->sector_count);
puts(" Sector Start Addresses:"); for (i = 0; i < info->sector_count; ++i) {
Hello Stefan,
I'm not sure about the status of this patchset. Can you please tell me who's the custodian for SNOR flash devices?
Thanks Amit Virdi
Hi Amit,
Usually I handle those kind of patches, as I'm the CFI flash custodian. I have assigned those patches to me. Since its not really bug fixes, I'll add them to the next branch, once it opens. So they will get pushed after the upcoming release.
Thanks, Stefan
Dear Stefan,
Thanks for the information. I have added another patch as a cleanup for the timeout loops. Will you prefer V2 for this patchset with that commit added or you're fine with that as a separate commit?
Thanks Amit Virdi
Hi Amit,
Separate patch is fine with me.
Thanks, Stefan
Signed-off-by: Armando Visconti armando.visconti@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/mtd/st_smi.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/mtd/st_smi.c b/drivers/mtd/st_smi.c index bd5602b..3f689e7 100644 --- a/drivers/mtd/st_smi.c +++ b/drivers/mtd/st_smi.c @@ -91,7 +91,7 @@ static struct flash_device flash_devices[] = { FLASH_ID("mac 25l3205" , 0xd8, 0x001620C2, 0x100, 0x10000, 0x400000), FLASH_ID("mac 25l3205a" , 0xd8, 0x001620C2, 0x100, 0x10000, 0x400000), FLASH_ID("mac 25l6405" , 0xd8, 0x001720C2, 0x100, 0x10000, 0x800000), - FLASH_ID("wbd w25q128" , 0xd8, 0x001840EF, 0x1000, 0x10000, 0x1000000), + FLASH_ID("wbd w25q128" , 0xd8, 0x001840EF, 0x100, 0x10000, 0x1000000), };
Amit Virdi
Stefan Roese
