Pull request: u-boot-rockchip-next-20240615
Hi Tom,
Please pull the updates for next on rockchip platform: - New board: Theobroma Systems SOM-RK3588-Q7 Tiger, ArmSoM Sige7 Rk3588; - PX30 dts migrate to OF_UPSTREAM; - Some other update on board or config;
CI: https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/pipelines/21113
Thanks, - Kever
The following changes since commit 3db3a6ba7b0cb09757fc631ccc9d4445eb101dc7:
Merge patch series "Enable OSPI boot for j721s2" (2024-06-13 08:20:30 -0600)
https://source.denx.de/u-boot/custodians/u-boot-rockchip.git tags/u-boot-rockchip-next-20240615
for you to fetch changes up to ae4aaa44977cbe522e9f38f2ac2ac07a784bf867:
rockchip: puma-rk3399: get closer to other Theobroma defconfigs (2024-06-14 17:35:45 +0800)
---------------------------------------------------------------- Boris Brezillon (1): arm64: dts: rockchip: Add rk3588 GPU node
Diederik de Haas (1): arm64: dts: rockchip: Fix ordering of nodes on rk3588s
Heiko Stuebner (6): arm64: dts: rockchip: enable gpu on rk3588-tiger arm64: dts: rockchip: move uart2 pinmux to dtsi on rk3588-tiger arm64: dts: rockchip: fix pcie-refclk frequency on rk3588 tiger arm64: dts: rockchip: fix comment for upper usb3 port arm64: dts: rockchip: add usb-id extcon on rk3588 tiger arm64: dts: rockchip: add dual-role usb3 hosts to rk3588 Tiger-Haikou
Jianfeng Liu (3): arm64: dts: rockchip: Add ArmSom Sige7 board rockchip: rk3588: Remove USB3 DRD nodes in u-boot.dtsi board: rockchip: add ArmSoM Sige7 Rk3588 board
Jing Luo (1): arm64: dts: rockchip: correct gpio_pwrctrl1 typos on rk3588(s) boards
Niklas Cassel (1): arm64: dts: rockchip: add rk3588 pcie and php IOMMUs
Quentin Schulz (17): rockchip: evb-px30: Use common bss and stack addresses rockchip: firefly-px30: Use common bss and stack addresses rockchip: odroid-go2: Use common bss and stack addresses rockchip: px30-core-*: Use common bss and stack addresses rockchip: px30: make UART pinmux accessible to TPL/SPL DTB rockchip: evb-px30: do not remove pinctrl nodes from SPL DTB rockchip: evb-px30: make UART5 the debug UART rockchip: px30/rk3326: migrate to OF_UPSTREAM rockchip: jaguar-rk3588: use default env size for Rockchip on MMC rockchip: rk3399-puma: remove default value from defconfig rockchip: rk3399-puma: remove unnecessary simple-bin:fit:offset override rockchip: px30-ringneck: Update SPL_PAD_TO Kconfig option power: rk8xx: properly print all supported PMICs name rockchip: ringneck-px30: fix TPL_MAX_SIZE rockchip: add support for Theobroma Systems SOM-RK3588-Q7 Tiger module rockchip: ringneck-px30: get closer to other Theobroma defconfigs rockchip: puma-rk3399: get closer to other Theobroma defconfigs
Sebastian Reichel (4): arm64: dts: rockchip: fix usb2phy nodename for rk3588 arm64: dts: rockchip: reorder usb2phy properties for rk3588 arm64: dts: rockchip: add USBDP phys on rk3588 arm64: dts: rockchip: add USB3 DRD controllers on rk3588
MAINTAINERS | 1 + arch/arm/dts/Makefile | 8 - arch/arm/dts/px30-engicam-common.dtsi | 129 ---- arch/arm/dts/px30-engicam-ctouch2.dtsi | 30 - arch/arm/dts/px30-engicam-edimm2.2.dtsi | 66 -- .../dts/px30-engicam-px30-core-ctouch2-of10.dts | 77 --- arch/arm/dts/px30-engicam-px30-core-ctouch2.dts | 22 - arch/arm/dts/px30-engicam-px30-core-edimm2.2.dts | 43 -- arch/arm/dts/px30-engicam-px30-core.dtsi | 241 ------- arch/arm/dts/px30-evb.dts | 634 ------------------ arch/arm/dts/px30-ringneck-haikou-u-boot.dtsi | 8 - arch/arm/dts/px30-ringneck-haikou.dts | 232 ------- arch/arm/dts/px30-ringneck.dtsi | 382 ----------- arch/arm/dts/px30-u-boot.dtsi | 16 + arch/arm/dts/rk3326-odroid-go2-u-boot.dtsi | 15 + arch/arm/dts/rk3326-odroid-go2.dts | 642 ------------------ arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi | 6 - arch/arm/dts/rk3588-armsom-sige7-u-boot.dtsi | 6 + arch/arm/dts/rk3588-tiger-haikou-u-boot.dtsi | 37 ++ arch/arm/dts/rk3588-u-boot.dtsi | 74 --- arch/arm/dts/rk3588s-u-boot.dtsi | 85 --- arch/arm/mach-rockchip/Kconfig | 1 + arch/arm/mach-rockchip/rk3588/Kconfig | 57 ++ board/armsom/sige7-rk3588/Kconfig | 12 + board/armsom/sige7-rk3588/MAINTAINERS | 7 + board/theobroma-systems/tiger_rk3588/Kconfig | 16 + board/theobroma-systems/tiger_rk3588/MAINTAINERS | 13 + board/theobroma-systems/tiger_rk3588/Makefile | 10 + .../theobroma-systems/tiger_rk3588/tiger_rk3588.c | 53 ++ configs/evb-px30_defconfig | 24 +- configs/firefly-px30_defconfig | 19 +- configs/jaguar-rk3588_defconfig | 1 - configs/odroid-go2_defconfig | 20 +- configs/puma-rk3399_defconfig | 10 +- configs/px30-core-ctouch2-of10-px30_defconfig | 20 +- configs/px30-core-ctouch2-px30_defconfig | 20 +- configs/px30-core-edimm2.2-px30_defconfig | 20 +- configs/ringneck-px30_defconfig | 21 +- configs/sige7-rk3588_defconfig | 93 +++ configs/tiger-rk3588_defconfig | 113 ++++ doc/board/rockchip/rockchip.rst | 2 + doc/board/theobroma-systems/index.rst | 1 + doc/board/theobroma-systems/tiger_rk3588.rst | 102 +++ drivers/power/pmic/rk8xx.c | 6 +- .../src/arm64/rockchip/rk3588-armsom-sige7.dts | 721 +++++++++++++++++++++ .../src/arm64/rockchip/rk3588-coolpi-cm5.dtsi | 2 +- .../rockchip/rk3588-edgeble-neu6a-common.dtsi | 2 +- dts/upstream/src/arm64/rockchip/rk3588-jaguar.dts | 2 +- .../src/arm64/rockchip/rk3588-tiger-haikou.dts | 65 +- dts/upstream/src/arm64/rockchip/rk3588-tiger.dtsi | 29 +- .../src/arm64/rockchip/rk3588-turing-rk1.dtsi | 2 +- dts/upstream/src/arm64/rockchip/rk3588.dtsi | 72 ++ .../src/arm64/rockchip/rk3588s-coolpi-4b.dts | 2 +- .../src/arm64/rockchip/rk3588s-indiedroid-nova.dts | 2 +- .../src/arm64/rockchip/rk3588s-orangepi-5.dts | 2 +- .../src/arm64/rockchip/rk3588s-rock-5a.dts | 2 +- dts/upstream/src/arm64/rockchip/rk3588s.dtsi | 377 ++++++++--- include/configs/sige7-rk3588.h | 15 + include/configs/tiger_rk3588.h | 15 + 59 files changed, 1795 insertions(+), 2910 deletions(-) delete mode 100644 arch/arm/dts/px30-engicam-common.dtsi delete mode 100644 arch/arm/dts/px30-engicam-ctouch2.dtsi delete mode 100644 arch/arm/dts/px30-engicam-edimm2.2.dtsi delete mode 100644 arch/arm/dts/px30-engicam-px30-core-ctouch2-of10.dts delete mode 100644 arch/arm/dts/px30-engicam-px30-core-ctouch2.dts delete mode 100644 arch/arm/dts/px30-engicam-px30-core-edimm2.2.dts delete mode 100644 arch/arm/dts/px30-engicam-px30-core.dtsi delete mode 100644 arch/arm/dts/px30-evb.dts delete mode 100644 arch/arm/dts/px30-ringneck-haikou.dts delete mode 100644 arch/arm/dts/px30-ringneck.dtsi delete mode 100644 arch/arm/dts/rk3326-odroid-go2.dts create mode 100644 arch/arm/dts/rk3588-armsom-sige7-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-tiger-haikou-u-boot.dtsi create mode 100644 board/armsom/sige7-rk3588/Kconfig create mode 100644 board/armsom/sige7-rk3588/MAINTAINERS create mode 100644 board/theobroma-systems/tiger_rk3588/Kconfig create mode 100644 board/theobroma-systems/tiger_rk3588/MAINTAINERS create mode 100644 board/theobroma-systems/tiger_rk3588/Makefile create mode 100644 board/theobroma-systems/tiger_rk3588/tiger_rk3588.c create mode 100644 configs/sige7-rk3588_defconfig create mode 100644 configs/tiger-rk3588_defconfig create mode 100644 doc/board/theobroma-systems/tiger_rk3588.rst create mode 100644 dts/upstream/src/arm64/rockchip/rk3588-armsom-sige7.dts create mode 100644 include/configs/sige7-rk3588.h create mode 100644 include/configs/tiger_rk3588.h
On Sat, Jun 15, 2024 at 08:22:13PM +0800, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
