[U-Boot] [PATCH] MTD: nand: mxs_nand_spl: Fix empty function pointer for BBT
The initialization function calls a nand_chip.scan_bbt(mtd) but scan_bbt is never initialized resulting in an undefined function pointer. This will direct the function pointer to nand_default_bbt defined in the same file.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/drivers/mtd/nand/raw/mxs_nand_spl.c b/drivers/mtd/nand/raw/mxs_nand_spl.c index 2d7bbe83cc..c628f3adec 100644 --- a/drivers/mtd/nand/raw/mxs_nand_spl.c +++ b/drivers/mtd/nand/raw/mxs_nand_spl.c @@ -185,6 +185,7 @@ static int mxs_nand_init(void) mtd = nand_to_mtd(&nand_chip); /* set mtd functions */ nand_chip.cmdfunc = mxs_nand_command; + nand_chip.scan_bbt = nand_default_bbt; nand_chip.numchips = 1;
/* identify flash device */
Seems sensible
Acked-by: Stefan Agner stefan.agner@toradex.com
Seems sensible
Fixes crashing NAND SPL loader on my i.MX6ULL board, which was introduced in commit 5346c31e305a37d39f535cc0d5ae87d8b7e81230 and is present in U-Boot since version 2018.07.
Tested on a custom i.MX6ULL board with a Micron NAND flash.
Tested-by: Jörg Krause joerg.krause@embedded.rocks
The initialization function calls a nand_chip.scan_bbt(mtd) but scan_bbt is never initialized resulting in an undefined function pointer. This will direct the function pointer to nand_default_bbt defined in the same file. Signed-off-by: Adam Ford aford173@gmail.com Acked-by: Stefan Agner stefan.agner@toradex.com diff --git a/drivers/mtd/nand/raw/mxs_nand_spl.c b/drivers/mtd/nand/raw/mxs_nand_spl.c index 2d7bbe83cc..c628f3adec 100644 --- a/drivers/mtd/nand/raw/mxs_nand_spl.c +++ b/drivers/mtd/nand/raw/mxs_nand_spl.c @@ -185,6 +185,7 @@ static int mxs_nand_init(void) mtd = nand_to_mtd(&nand_chip); /* set mtd functions */ nand_chip.cmdfunc = mxs_nand_command;
Best regards, Stefano Babic
Adam Ford
Jörg Krause
sbabic@denx.de
Stefan Agner
