[U-Boot] [PATCH] mkimage: Allow including a ramdisk in FIT auto mode
Adds -i option that allows specifying a ramdisk file to be added to the FIT image when we are using the automatic FIT mode (no ITS file).
This makes adding Depthcharge support to LAVA much more convenient, as no additional configuration files need to be kept around in the machine that dispatches jobs to the boards.
Signed-off-by: Tomeu Vizoso tomeu.vizoso@collabora.com Cc: Simon Glass sjg@chromium.org Cc: Matt Hart matthew.hart@linaro.org Cc: Neil Williams codehelp@debian.org --- doc/mkimage.1 | 4 ++++ tools/fit_image.c | 33 ++++++++++++++++++++++++++++++++- tools/imagetool.h | 1 + tools/mkimage.c | 10 +++++++--- 4 files changed, 44 insertions(+), 4 deletions(-)
diff --git a/doc/mkimage.1 b/doc/mkimage.1 index e883f07849a6..3dcdcedcefaf 100644 --- a/doc/mkimage.1 +++ b/doc/mkimage.1 @@ -138,6 +138,10 @@ This can be used to sign images with additional keys after initial image creation.
.TP +.BI "-i [" "ramdisk_file" "]" +Appends the ramdisk file to the FIT. + +.TP .BI "-k [" "key_directory" "]" Specifies the directory containing keys to use for signing. This directory should contain a private key file <name>.key for use with signing and a diff --git a/tools/fit_image.c b/tools/fit_image.c index 10fd6d492937..efd8a97a0b92 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -85,8 +85,15 @@ static int fit_calc_size(struct image_tool_params *params) size = imagetool_get_filesize(params, params->datafile); if (size < 0) return -1; - total_size = size; + + if (params->fit_ramdisk) { + size = imagetool_get_filesize(params, params->fit_ramdisk); + if (size < 0) + return -1; + total_size += size; + } + for (cont = params->content_head; cont; cont = cont->next) { size = imagetool_get_filesize(params, cont->fname); if (size < 0) @@ -233,6 +240,20 @@ static int fit_write_images(struct image_tool_params *params, char *fdt) fdt_end_node(fdt); }
+ /* And a ramdisk file if available */ + if (params->fit_ramdisk) { + fdt_begin_node(fdt, FIT_RAMDISK_PROP "@1"); + + fdt_property_string(fdt, "type", FIT_RAMDISK_PROP); + fdt_property_string(fdt, "os", genimg_get_os_short_name(params->os)); + + ret = fdt_property_file(params, fdt, "data", params->fit_ramdisk); + if (ret) + return ret; + + fdt_end_node(fdt); + } + fdt_end_node(fdt);
return 0; @@ -272,15 +293,25 @@ static void fit_write_configs(struct image_tool_params *params, char *fdt) snprintf(str, sizeof(str), "%s@1", typename); fdt_property_string(fdt, typename, str);
+ if (params->fit_ramdisk) + fdt_property_string(fdt, FIT_RAMDISK_PROP, + FIT_RAMDISK_PROP "@1"); + snprintf(str, sizeof(str), FIT_FDT_PROP "@%d", upto); fdt_property_string(fdt, FIT_FDT_PROP, str); fdt_end_node(fdt); } + if (!upto) { fdt_begin_node(fdt, "conf@1"); typename = genimg_get_type_short_name(params->fit_image_type); snprintf(str, sizeof(str), "%s@1", typename); fdt_property_string(fdt, typename, str); + + if (params->fit_ramdisk) + fdt_property_string(fdt, FIT_RAMDISK_PROP, + FIT_RAMDISK_PROP "@1"); + fdt_end_node(fdt); }
diff --git a/tools/imagetool.h b/tools/imagetool.h index 6c1a9d376058..15c2a0c0e1c1 100644 --- a/tools/imagetool.h +++ b/tools/imagetool.h @@ -70,6 +70,7 @@ struct image_tool_params { int orig_file_size; /* Original size for file before padding */ bool auto_its; /* Automatically create the .its file */ int fit_image_type; /* Image type to put into the FIT */ + char *fit_ramdisk; /* Ramdisk file to include */ struct content_info *content_head; /* List of files to include */ struct content_info *content_tail; bool external_data; /* Store data outside the FIT */ diff --git a/tools/mkimage.c b/tools/mkimage.c index 0c6dba89a099..49d5d1ed70a7 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -88,12 +88,13 @@ static void usage(const char *msg) " -x ==> set XIP (execute in place)\n", params.cmdname); fprintf(stderr, - " %s [-D dtc_options] [-f fit-image.its|-f auto|-F] [-b <dtb> [-b <dtb>]] fit-image\n" + " %s [-D dtc_options] [-f fit-image.its|-f auto|-F] [-b <dtb> [-b <dtb>]] [-i <ramdisk.cpio.gz>] fit-image\n" " <dtb> file is used with -f auto, it may occur multiple times.\n", params.cmdname); fprintf(stderr, " -D => set all options for device tree compiler\n" - " -f => input filename for FIT source\n"); + " -f => input filename for FIT source\n" + " -i => input filename for ramdisk file\n"); #ifdef CONFIG_FIT_SIGNATURE fprintf(stderr, "Signing / verified boot options: [-E] [-k keydir] [-K dtb] [ -c <comment>] [-p addr] [-r]\n" @@ -141,7 +142,7 @@ static void process_args(int argc, char **argv) int opt;
while ((opt = getopt(argc, argv, - "a:A:b:c:C:d:D:e:Ef:Fk:K:ln:p:O:rR:qsT:vVx")) != -1) { + "a:A:b:c:C:d:D:e:Ef:Fk:i:K:ln:p:O:rR:qsT:vVx")) != -1) { switch (opt) { case 'a': params.addr = strtoull(optarg, &ptr, 16); @@ -207,6 +208,9 @@ static void process_args(int argc, char **argv) params.type = IH_TYPE_FLATDT; params.fflag = 1; break; + case 'i': + params.fit_ramdisk = optarg; + break; case 'k': params.keydir = optarg; break;
Signed-off-by: Tomeu Vizoso tomeu.vizoso@collabora.com Cc: Simon Glass sjg@chromium.org Cc: Matt Hart matthew.hart@linaro.org Cc: Neil Williams codehelp@debian.org Reviewed-by: Simon Glass sjg@chromium.org
Tomeu Vizoso
