[PATCH v1] arm: imx: imx8m: soc: Fix VPU fdt disable fixup
With the introduction of downstream Linux 6.6, the iMX8MP VPU block control node in DTS was renamed "blk-ctl@38330000" and will not match the ones found in `node_path_imx8mp` resulting in the node not being disabled on the VPU-less variants.
Add an extra node_path entry for imx8mp VPU block control that match with downstream Linux.
Signed-off-by: Vitor Soares vitor.soares@toradex.com --- arch/arm/mach-imx/imx8m/soc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index be38ca528850..4c224382021e 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -955,6 +955,7 @@ int disable_vpu_nodes(void *blob) "/soc@0/video-codec@38300000", "/soc@0/video-codec@38310000", "/soc@0/blk-ctrl@38330000", + "/soc@0/blk-ctl@38330000", };
if (is_imx8mq())
Subject: [PATCH v1] arm: imx: imx8m: soc: Fix VPU fdt disable fixup
Reviewed-by: Peng Fan peng.fan@nxp.com
I am thinking to make ocotp as access controller, then we no need such code in uboot in future.
Thanks, Peng.
Applied to u-boot-imx/next, thanks.
Fabio Estevam
Peng Fan
Vitor Soares
