[U-Boot] [PATCH 1/2] ARM: bcm283x: don't always define CONFIG_BCM2835
Currently, CONFIG_BCM2835 is defined for all BCM283x builds and _BCM2836 is defined when building for that SoC. That means there isn't a single define that means "exactly BCM2835". This will complicate future patches where BCM2835-vs-anything-else needs to be determined simply.
Modify the code to define one or the other of CONFIG_BCM2835/BCM2836 so future patches are simpler.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- arch/arm/mach-bcm283x/include/mach/gpio.h | 2 +- arch/arm/mach-bcm283x/include/mach/mbox.h | 2 +- arch/arm/mach-bcm283x/include/mach/sdhci.h | 2 +- arch/arm/mach-bcm283x/include/mach/timer.h | 2 +- arch/arm/mach-bcm283x/include/mach/wdog.h | 2 +- arch/arm/mach-bcm283x/phys2bus.c | 2 +- board/raspberrypi/rpi/rpi.c | 2 +- include/configs/rpi-common.h | 5 ++--- include/configs/rpi.h | 1 + 9 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-bcm283x/include/mach/gpio.h b/arch/arm/mach-bcm283x/include/mach/gpio.h index c8ef8f528a21..e6e5d1605d0a 100644 --- a/arch/arm/mach-bcm283x/include/mach/gpio.h +++ b/arch/arm/mach-bcm283x/include/mach/gpio.h @@ -9,7 +9,7 @@ #ifndef _BCM2835_GPIO_H_ #define _BCM2835_GPIO_H_
-#ifdef CONFIG_BCM2836 +#ifndef CONFIG_BCM2835 #define BCM2835_GPIO_BASE 0x3f200000 #else #define BCM2835_GPIO_BASE 0x20200000 diff --git a/arch/arm/mach-bcm283x/include/mach/mbox.h b/arch/arm/mach-bcm283x/include/mach/mbox.h index 4a143917f0f8..627acb85dc8c 100644 --- a/arch/arm/mach-bcm283x/include/mach/mbox.h +++ b/arch/arm/mach-bcm283x/include/mach/mbox.h @@ -38,7 +38,7 @@
/* Raw mailbox HW */
-#ifdef CONFIG_BCM2836 +#ifndef CONFIG_BCM2835 #define BCM2835_MBOX_PHYSADDR 0x3f00b880 #else #define BCM2835_MBOX_PHYSADDR 0x2000b880 diff --git a/arch/arm/mach-bcm283x/include/mach/sdhci.h b/arch/arm/mach-bcm283x/include/mach/sdhci.h index 2a21ccbf66ba..64e582c114f5 100644 --- a/arch/arm/mach-bcm283x/include/mach/sdhci.h +++ b/arch/arm/mach-bcm283x/include/mach/sdhci.h @@ -7,7 +7,7 @@ #ifndef _BCM2835_SDHCI_H_ #define _BCM2835_SDHCI_H_
-#ifdef CONFIG_BCM2836 +#ifndef CONFIG_BCM2835 #define BCM2835_SDHCI_BASE 0x3f300000 #else #define BCM2835_SDHCI_BASE 0x20300000 diff --git a/arch/arm/mach-bcm283x/include/mach/timer.h b/arch/arm/mach-bcm283x/include/mach/timer.h index 004c24be365a..2a85f230e86d 100644 --- a/arch/arm/mach-bcm283x/include/mach/timer.h +++ b/arch/arm/mach-bcm283x/include/mach/timer.h @@ -7,7 +7,7 @@ #ifndef _BCM2835_TIMER_H #define _BCM2835_TIMER_H
-#ifdef CONFIG_BCM2836 +#ifndef CONFIG_BCM2835 #define BCM2835_TIMER_PHYSADDR 0x3f003000 #else #define BCM2835_TIMER_PHYSADDR 0x20003000 diff --git a/arch/arm/mach-bcm283x/include/mach/wdog.h b/arch/arm/mach-bcm283x/include/mach/wdog.h index cbc350e84b90..7741d7ba1558 100644 --- a/arch/arm/mach-bcm283x/include/mach/wdog.h +++ b/arch/arm/mach-bcm283x/include/mach/wdog.h @@ -7,7 +7,7 @@ #ifndef _BCM2835_WDOG_H #define _BCM2835_WDOG_H
-#ifdef CONFIG_BCM2836 +#ifndef CONFIG_BCM2835 #define BCM2835_WDOG_PHYSADDR 0x3f100000 #else #define BCM2835_WDOG_PHYSADDR 0x20100000 diff --git a/arch/arm/mach-bcm283x/phys2bus.c b/arch/arm/mach-bcm283x/phys2bus.c index fc1c29905de3..8e9f49240ff7 100644 --- a/arch/arm/mach-bcm283x/phys2bus.c +++ b/arch/arm/mach-bcm283x/phys2bus.c @@ -9,7 +9,7 @@
unsigned long phys_to_bus(unsigned long phys) { -#ifdef CONFIG_BCM2836 +#ifndef CONFIG_BCM2835 return 0xc0000000 | phys; #else return 0x40000000 | phys; diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index da4b6ff234d6..1fd7591f3325 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -31,7 +31,7 @@ U_BOOT_DEVICE(bcm2835_gpios) = { };
static const struct pl01x_serial_platdata serial_platdata = { -#ifdef CONFIG_BCM2836 +#ifndef CONFIG_BCM2835 .base = 0x3f201000, #else .base = 0x20201000, diff --git a/include/configs/rpi-common.h b/include/configs/rpi-common.h index 1c3642612e4b..12e1adde204c 100644 --- a/include/configs/rpi-common.h +++ b/include/configs/rpi-common.h @@ -11,7 +11,6 @@ #include <asm/arch/timer.h>
/* Architecture, CPU, etc.*/ -#define CONFIG_BCM2835 #define CONFIG_ARCH_CPU_INIT
#define CONFIG_SYS_TIMER_RATE 1000000 @@ -26,7 +25,7 @@ * chose to use someone else's previously registered machine ID (3139, MX51_GGC) * rather than obtaining a valid ID:-/ */ -#ifndef CONFIG_BCM2836 +#ifdef CONFIG_BCM2835 #define CONFIG_MACH_TYPE MACH_TYPE_BCM2708 #endif
@@ -80,7 +79,7 @@ #define CONFIG_CMD_USB #ifdef CONFIG_CMD_USB #define CONFIG_USB_DWC2 -#ifdef CONFIG_BCM2836 +#ifndef CONFIG_BCM2835 #define CONFIG_USB_DWC2_REG_ADDR 0x3f980000 #else #define CONFIG_USB_DWC2_REG_ADDR 0x20980000 diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 86422e390da2..a788ce42e44c 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -7,6 +7,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_BCM2835 #define CONFIG_SYS_CACHELINE_SIZE 32
#include "rpi-common.h"
Fixes: arch/arm/mach-bcm283x/mbox.c: In function ‘bcm2835_mbox_call_prop’: arch/arm/mach-bcm283x/mbox.c:118:48: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] arch/arm/mach-bcm283x/mbox.c:126:29: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- arch/arm/mach-bcm283x/mbox.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-bcm283x/mbox.c b/arch/arm/mach-bcm283x/mbox.c index 311bd8feaab0..ec3f417f40f4 100644 --- a/arch/arm/mach-bcm283x/mbox.c +++ b/arch/arm/mach-bcm283x/mbox.c @@ -115,7 +115,9 @@ int bcm2835_mbox_call_prop(u32 chan, struct bcm2835_mbox_hdr *buffer) (unsigned long)((void *)buffer + roundup(buffer->buf_size, ARCH_DMA_MINALIGN)));
- ret = bcm2835_mbox_call_raw(chan, phys_to_bus((u32)buffer), &rbuffer); + ret = bcm2835_mbox_call_raw(chan, + phys_to_bus((unsigned long)buffer), + &rbuffer); if (ret) return ret;
@@ -123,7 +125,7 @@ int bcm2835_mbox_call_prop(u32 chan, struct bcm2835_mbox_hdr *buffer) (unsigned long)((void *)buffer + roundup(buffer->buf_size, ARCH_DMA_MINALIGN)));
- if (rbuffer != phys_to_bus((u32)buffer)) { + if (rbuffer != phys_to_bus((unsigned long)buffer)) { printf("mbox: Response buffer mismatch\n"); return -1; }
Signed-off-by: Stephen Warren swarren@wwwdotorg.org Reviewed-by: Tom Rini trini@konsulko.com
[snip]
Shouldn't we take this as the time to move it to arch/arm/mach-bcm283x/Kconfig ?
[snip]
It is probably time yes, although I'd rather do that in a separate patch either way. I should be able to work that patch up before sending the actual RPi3 board file patches.
[snip]
OK:
Stephen Warren
