[U-Boot] [PATCH v2 03/16] [POWERPC] mgcoge: fix Codingstyle issues.
Signed-off-by: Heiko Schocher hs@denx.de --- board/keymile/mgcoge/mgcoge.c | 79 +++++++++++++++++++--------------------- 1 files changed, 38 insertions(+), 41 deletions(-)
diff --git a/board/keymile/mgcoge/mgcoge.c b/board/keymile/mgcoge/mgcoge.c index 51b6dc6..a6bf9bc 100644 --- a/board/keymile/mgcoge/mgcoge.c +++ b/board/keymile/mgcoge/mgcoge.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2007 + * (C) Copyright 2007 - 2008 * Heiko Schocher, DENX Software Engineering, hs@denx.de. * * See file CREDITS for list of people who contributed to this @@ -243,13 +243,13 @@ static long int try_init (volatile memctl8260_t * memctl, ulong sdmr, *sdmr_ptr = sdmr | PSDMR_OP_NORM | PSDMR_RFEN; *base = c;
- size = get_ram_size((long *)base, maxsize); + size = get_ram_size ((long *)base, maxsize); *orx_ptr = orx | ~(size - 1);
return (size); }
-phys_size_t initdram(int board_type) +phys_size_t initdram (int board_type) { volatile immap_t *immap = (immap_t *) CFG_IMMR; volatile memctl8260_t *memctl = &immap->im_memctl; @@ -273,7 +273,7 @@ phys_size_t initdram(int board_type)
int checkboard(void) { - puts("Board: mgcoge\n"); + puts ("Board: mgcoge\n");
return 0; } @@ -281,7 +281,7 @@ int checkboard(void) /* * Early board initalization. */ -int board_early_init_r(void) +int board_early_init_r (void) { /* setup the UPIOx */ *(char *)(CFG_PIGGY_BASE + 0x02) = 0xc0; @@ -293,68 +293,65 @@ int board_early_init_r(void) /* * update "memory" property in the blob */ -void ft_blob_update(void *blob, bd_t *bd) +void ft_blob_update (void *blob, bd_t *bd) { int ret, nodeoffset = 0; ulong memory_data[2] = {0}; ulong flash_data[8] = {0};
- memory_data[0] = cpu_to_be32(bd->bi_memstart); - memory_data[1] = cpu_to_be32(bd->bi_memsize); + memory_data[0] = cpu_to_be32 (bd->bi_memstart); + memory_data[1] = cpu_to_be32 (bd->bi_memsize);
nodeoffset = fdt_path_offset (blob, "/memory"); if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "reg", memory_data, - sizeof(memory_data)); + ret = fdt_setprop (blob, nodeoffset, "reg", memory_data, + sizeof (memory_data)); if (ret < 0) - printf("ft_blob_update(): cannot set /memory/reg " - "property err:%s\n", fdt_strerror(ret)); - } - else { + printf ("ft_blob_update(): cannot set /memory/reg " + "property err:%s\n", fdt_strerror (ret)); + } else { /* memory node is required in dts */ - printf("ft_blob_update(): cannot find /memory node " - "err:%s\n", fdt_strerror(nodeoffset)); + printf ("ft_blob_update(): cannot find /memory node " + "err:%s\n", fdt_strerror (nodeoffset)); } /* update Flash addr, size */ - flash_data[2] = cpu_to_be32(CFG_FLASH_BASE); - flash_data[3] = cpu_to_be32(CFG_FLASH_SIZE); - flash_data[4] = cpu_to_be32(1); - flash_data[5] = cpu_to_be32(0); - flash_data[6] = cpu_to_be32(CFG_FLASH_BASE_1); - flash_data[7] = cpu_to_be32(CFG_FLASH_SIZE_1); + flash_data[2] = cpu_to_be32 (CFG_FLASH_BASE); + flash_data[3] = cpu_to_be32 (CFG_FLASH_SIZE); + flash_data[4] = cpu_to_be32 (1); + flash_data[5] = cpu_to_be32 (0); + flash_data[6] = cpu_to_be32 (CFG_FLASH_BASE_1); + flash_data[7] = cpu_to_be32 (CFG_FLASH_SIZE_1); nodeoffset = fdt_path_offset (blob, "/localbus"); if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "ranges", flash_data, - sizeof(flash_data)); + ret = fdt_setprop (blob, nodeoffset, "ranges", flash_data, + sizeof (flash_data)); if (ret < 0) - printf("ft_blob_update(): cannot set /localbus/ranges " - "property err:%s\n", fdt_strerror(ret)); - } - else { + printf ("ft_blob_update(): cannot set /localbus/ranges " + "property err:%s\n", fdt_strerror (ret)); + } else { /* memory node is required in dts */ - printf("ft_blob_update(): cannot find /localbus node " - "err:%s\n", fdt_strerror(nodeoffset)); + printf ("ft_blob_update(): cannot find /localbus node " + "err:%s\n", fdt_strerror (nodeoffset)); } /* MAC Adresse */ nodeoffset = fdt_path_offset (blob, "/soc/cpm/ethernet"); if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "mac-address", bd->bi_enetaddr, - sizeof(uchar) * 6); + ret = fdt_setprop (blob, nodeoffset, "mac-address", bd->bi_enetaddr, + sizeof (uchar) * 6); if (ret < 0) - printf("ft_blob_update(): cannot set /soc/cpm/ethernet/mac-address " - "property err:%s\n", fdt_strerror(ret)); - } - else { + printf ("ft_blob_update(): cannot set /soc/cpm/ethernet/mac-address " + "property err:%s\n", fdt_strerror (ret)); + } else { /* memory node is required in dts */ - printf("ft_blob_update(): cannot find /soc/cpm/ethernet node " - "err:%s\n", fdt_strerror(nodeoffset)); + printf ("ft_blob_update(): cannot find /soc/cpm/ethernet node " + "err:%s\n", fdt_strerror (nodeoffset)); }
-void ft_board_setup(void *blob, bd_t *bd) +void ft_board_setup (void *blob, bd_t *bd) { - ft_cpu_setup( blob, bd); - ft_blob_update(blob, bd); + ft_cpu_setup (blob, bd); + ft_blob_update (blob, bd); } #endif /* defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) */
Heiko Schocher
