[U-Boot] [PATCH v6 28/28] armv8/fsl-lsch3: Implement workaround for I2C erratum A009203
This erratum requires setting GLITCH_EN bit in debug register to enable digital filter to improve clock stability.
Signed-off-by: York Sun yorksun@freescale.com CC: Heiko Schocher hs@denx.de
Changes in v6: Add erratum number
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: Add comment to I2C workaround
arch/arm/cpu/armv8/fsl-lsch3/soc.c | 34 ++++++++++++++++++++++++++++++++++ 1 file changed, 34 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-lsch3/soc.c b/arch/arm/cpu/armv8/fsl-lsch3/soc.c index ca00108..2538001 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/soc.c +++ b/arch/arm/cpu/armv8/fsl-lsch3/soc.c @@ -37,11 +37,45 @@ static void erratum_rcw_src(void) #endif }
+#define I2C_DEBUG_REG 0x6 +#define I2C_GLITCH_EN 0x8 +/* + * This erratum requires setting glitch_en bit to enable + * digital glitch filter to improve clock stability. + */ +static void erratum_a009203(void) +{ + u8 __iomem *ptr; +#ifdef CONFIG_SYS_I2C +#ifdef I2C1_BASE_ADDR + ptr = (u8 __iomem *)(I2C1_BASE_ADDR + I2C_DEBUG_REG); + + writeb(I2C_GLITCH_EN, ptr); +#endif +#ifdef I2C2_BASE_ADDR + ptr = (u8 __iomem *)(I2C2_BASE_ADDR + I2C_DEBUG_REG); + + writeb(I2C_GLITCH_EN, ptr); +#endif +#ifdef I2C3_BASE_ADDR + ptr = (u8 __iomem *)(I2C3_BASE_ADDR + I2C_DEBUG_REG); + + writeb(I2C_GLITCH_EN, ptr); +#endif +#ifdef I2C4_BASE_ADDR + ptr = (u8 __iomem *)(I2C4_BASE_ADDR + I2C_DEBUG_REG); + + writeb(I2C_GLITCH_EN, ptr); +#endif +#endif +} + void fsl_lsch3_early_init_f(void) { erratum_a008751(); erratum_rcw_src(); init_early_memctl_regs(); /* tighten IFC timing */ + erratum_a009203(); }
#ifdef CONFIG_SPL_BUILD
York Sun
