[PATCH V2] arm: dts: k3-binman: Make optee optional as requirement
Allow boards that use ti_spl_template to not use optee part in configuration. Vendor can have module with 256 Mb of memory and they try to optimize the available memory just using the essential components. This change allow to remove tee from configuration without binman fail.
configurations { default = "conf-0";
conf-0 { description = "k3-am62_ccm_m3"; firmware = "atf"; loadables = "dm", "spl"; fdt = "fdt-0"; }; };
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- V1->V2: Adjust commit message --- arch/arm/dts/k3-binman.dtsi | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/k3-binman.dtsi b/arch/arm/dts/k3-binman.dtsi index 758c8bf6ea..5ef5af315a 100644 --- a/arch/arm/dts/k3-binman.dtsi +++ b/arch/arm/dts/k3-binman.dtsi @@ -293,6 +293,7 @@ keyfile = "custMpk.pem"; }; tee: tee-os { + optional; }; };
@@ -360,6 +361,7 @@ entry = <0x9e800000>; tee-os { filename = "tee-raw.bin"; + optional; }; };
Michael Trimarchi
