[U-Boot] [PATCH 1/7] armv8: fsl-layerscape: ls1043a: move SCSI_AHCI and SCSI form arch/arm/cpu/armv8/fsl-layerscape/Kconfig to arch/arm/Kconfig
remove SCSI and SCSI_AHCI configs for ls1043ardb due to no sata interface support. this changed is to fixed the ls1043ardb compile warning as fallows: ===================== WARNING ====================== This board does not use CONFIG_DM_SCSI. Please update the storage controller to use CONFIG_DM_SCSI before the v2019.07 release. Failure to update by the deadline may result in board removal.See doc/driver-model/MIGRATION.txt for more info. ====================================================
Signed-off-by: Peng Ma peng.ma@nxp.com --- arch/arm/Kconfig | 2 +- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 2 -- 2 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d6b1629a00..afc8a85602 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1221,6 +1221,7 @@ config TARGET_LS1043AQDS select BOARD_LATE_INIT select SUPPORT_SPL imply SCSI + imply SCSI_AHCI help Support for Freescale LS1043AQDS platform.
@@ -1232,7 +1233,6 @@ config TARGET_LS1043ARDB select BOARD_EARLY_INIT_F select BOARD_LATE_INIT select SUPPORT_SPL - imply SCSI help Support for Freescale LS1043ARDB platform.
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 01c5068ab6..7d52ed20e2 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -49,8 +49,6 @@ config ARCH_LS1043A select SYS_I2C_MXC_I2C2 select SYS_I2C_MXC_I2C3 select SYS_I2C_MXC_I2C4 - imply SCSI - imply SCSI_AHCI imply CMD_PCI
config ARCH_LS1046A
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1043aqds defconfigs that missing one of them or more. Support sata for all ls1043aqds defconfigs
Signed-off-by: Peng Ma peng.ma@nxp.com --- configs/ls1043aqds_lpuart_defconfig | 3 +++ configs/ls1043aqds_nand_defconfig | 3 +++ configs/ls1043aqds_nor_ddr3_defconfig | 3 +++ configs/ls1043aqds_qspi_defconfig | 3 +++ configs/ls1043aqds_sdcard_ifc_defconfig | 3 +++ configs/ls1043aqds_sdcard_qspi_defconfig | 3 +++ configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 2 ++ configs/ls1043aqds_tfa_defconfig | 2 ++ 8 files changed, 22 insertions(+)
diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index 79448129bd..c8ddbc28ab 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1043AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -30,6 +31,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-lpuart" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -44,6 +46,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_SPI=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index ada225c3b6..c845b01831 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -7,6 +7,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -44,6 +45,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -58,6 +60,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index e86d4196b5..3cabc68729 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1043AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -29,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_DM_MMC=y @@ -44,6 +46,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index d948981080..434f69c289 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1043AQDS=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -29,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -39,6 +41,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index afa91e8b3a..bdbb12d302 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -44,6 +45,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -58,6 +60,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index 310cb2319a..3b16f3e84f 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -42,6 +43,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -52,6 +54,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index ce6f1ef86f..096f6fb984 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -5,6 +5,7 @@ CONFIG_SECURE_BOOT=y CONFIG_TFABOOT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -31,6 +32,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index dfd70b5312..f33c9bd9a9 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_TFABOOT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -34,6 +35,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1046ardb and ls1046aqds defconfigs that missing one of them or more. enable CONFIG_DM_MMC for some defconfigs to support CONFIG_BLK Support sata for all ls1046a defconfigs
Signed-off-by: Peng Ma peng.ma@nxp.com --- configs/ls1046aqds_SECURE_BOOT_defconfig | 3 +++ configs/ls1046aqds_lpuart_defconfig | 3 +++ configs/ls1046aqds_nand_defconfig | 3 +++ configs/ls1046aqds_qspi_defconfig | 3 +++ configs/ls1046aqds_sdcard_ifc_defconfig | 3 +++ configs/ls1046aqds_sdcard_qspi_defconfig | 3 +++ configs/ls1046ardb_emmc_defconfig | 3 +++ configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 3 +++ configs/ls1046ardb_qspi_spl_defconfig | 4 ++++ configs/ls1046ardb_sdcard_defconfig | 3 +++ configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 3 +++ 11 files changed, 34 insertions(+)
diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index ae05dd150b..2a811ae627 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1046AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_SECURE_BOOT=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT=y @@ -30,6 +31,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y @@ -43,6 +45,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index 0a8d51e43d..5b5800a9bf 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1046AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -31,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-lpuart" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -45,6 +47,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_SPI=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 9e11db7d7f..4b594d5a87 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_FSL_LS_PPA=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -37,6 +38,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -51,6 +53,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig index a6bbf106e1..16fc81a46d 100644 --- a/configs/ls1046aqds_qspi_defconfig +++ b/configs/ls1046aqds_qspi_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1046AQDS=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -29,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -40,6 +42,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index edf915fdd6..9da8fe0d4f 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -46,6 +47,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -60,6 +62,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index afb76d6900..de8a2c2e3f 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -44,6 +45,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -55,6 +57,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 181fa61422..f84b5ba4b3 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -41,6 +42,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -52,6 +54,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index d8eb7b7ede..cd40abb2fe 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -26,6 +27,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=1550000.quadspi:1m(rcw),15m(u-boot),48m(kernel CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y @@ -37,6 +39,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index 0a45653b98..184c137fe2 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -9,6 +9,7 @@ CONFIG_QSPI_AHB_INIT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -44,7 +45,9 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y CONFIG_PHYLIB=y @@ -54,6 +57,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index a1bd39b17c..daee64af02 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -40,6 +41,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -51,6 +53,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig index d570c6de05..ea70c01155 100644 --- a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_QSPI_AHB_INIT=y CONFIG_TFABOOT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT_VERBOSE=y @@ -27,6 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=1550000.quadspi:1m(rcw),15m(u-boot),48m(kernel CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y @@ -38,6 +40,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1088ardb and ls1088aqds defconfigs that missing one of them or more. Support sata for all ls1088a defconfigs
Signed-off-by: Peng Ma peng.ma@nxp.com --- configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 3 +++ configs/ls1088aqds_qspi_defconfig | 3 +++ configs/ls1088aqds_sdcard_ifc_defconfig | 3 +++ configs/ls1088aqds_sdcard_qspi_defconfig | 3 +++ configs/ls1088aqds_tfa_defconfig | 17 +++++++---------- configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 3 +++ configs/ls1088ardb_sdcard_qspi_defconfig | 3 +++ configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 14 +++++++------- configs/ls1088ardb_tfa_defconfig | 12 ++++++------ 9 files changed, 38 insertions(+), 23 deletions(-)
diff --git a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig index 731408c13e..0254a861d8 100644 --- a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set @@ -29,6 +30,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y @@ -41,6 +43,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 1a3e74600c..9160de255d 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1088AQDS=y CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set @@ -29,6 +30,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y @@ -41,6 +43,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index b34be2eaf9..868d6e7c87 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set CONFIG_OF_BOARD_SETUP=y @@ -38,6 +39,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y @@ -51,6 +53,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index d0319a5b63..6a9577aba2 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set @@ -39,6 +40,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y @@ -51,6 +53,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index 857362bb01..891810a583 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -1,10 +1,11 @@ CONFIG_ARM=y CONFIG_TARGET_LS1088AQDS=y CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_QSPI_AHB_INIT=y CONFIG_TFABOOT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y -CONFIG_QSPI_AHB_INIT=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set @@ -17,7 +18,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 # CONFIG_USE_BOOTCOMMAND is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_I2C=y @@ -25,18 +25,18 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" CONFIG_ENV_IS_IN_FLASH=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_NAND=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -45,7 +45,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y -CONFIG_FSL_SPI_ALIGNED_TXFIFO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_E1000=y CONFIG_MII=y @@ -53,6 +52,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y @@ -63,8 +63,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_BLK=y -CONFIG_DM_MMC=y diff --git a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig index 0cee141cf1..78aec38a12 100644 --- a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set @@ -30,6 +31,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y @@ -42,6 +44,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index 5b0f1d6d03..a7cdead46e 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set @@ -40,6 +41,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y @@ -52,6 +54,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig index ae177d3838..1163399c74 100644 --- a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig @@ -1,11 +1,12 @@ CONFIG_ARM=y CONFIG_TARGET_LS1088ARDB=y CONFIG_SYS_TEXT_BASE=0x82000000 -CONFIG_TFABOOT=y CONFIG_SECURE_BOOT=y +CONFIG_QSPI_AHB_INIT=y +CONFIG_TFABOOT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y -CONFIG_QSPI_AHB_INIT=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set @@ -29,10 +30,11 @@ CONFIG_CMD_USB=y CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" -CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y @@ -44,6 +46,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y @@ -54,11 +57,8 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y -CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_BLK=y -CONFIG_DM_MMC=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls1088ardb_tfa_defconfig b/configs/ls1088ardb_tfa_defconfig index 01fa13c7a8..7263471685 100644 --- a/configs/ls1088ardb_tfa_defconfig +++ b/configs/ls1088ardb_tfa_defconfig @@ -1,10 +1,11 @@ CONFIG_ARM=y CONFIG_TARGET_LS1088ARDB=y CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_QSPI_AHB_INIT=y CONFIG_TFABOOT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y -CONFIG_QSPI_AHB_INIT=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set @@ -28,16 +29,17 @@ CONFIG_CMD_USB=y CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" -CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y -CONFIG_FSL_SPI_ALIGNED_TXFIFO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_E1000=y CONFIG_MII=y @@ -45,6 +47,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y @@ -55,8 +58,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_BLK=y -CONFIG_DM_MMC=y
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls208xardb and ls208xaqds defconfigs that missing one of them or more. enable CONFIG_DM_MMC for some defconfigs to support CONFIG_BLK Support sata for all ls208xa defconfigs
Signed-off-by: Peng Ma peng.ma@nxp.com --- configs/ls2080aqds_SECURE_BOOT_defconfig | 3 +++ configs/ls2080aqds_nand_defconfig | 3 +++ configs/ls2080aqds_qspi_defconfig | 3 +++ configs/ls2080aqds_sdcard_defconfig | 3 +++ configs/ls2080ardb_SECURE_BOOT_defconfig | 3 +++ configs/ls2080ardb_nand_defconfig | 3 +++ configs/ls2081ardb_defconfig | 4 ++++ configs/ls2088aqds_tfa_defconfig | 9 +++++---- configs/ls2088ardb_qspi_SECURE_BOOT_defconfig | 3 +++ configs/ls2088ardb_qspi_defconfig | 3 +++ configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 18 +++++++----------- configs/ls2088ardb_tfa_defconfig | 14 ++++++-------- 12 files changed, 46 insertions(+), 23 deletions(-)
diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index d7c0db6343..5b85a94ed1 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2080AQDS=y CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -31,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y @@ -46,6 +48,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 30b506fafc..6340c19b08 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -41,6 +42,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -53,6 +55,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 44a718e855..5c509f60be 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080AQDS=y CONFIG_SYS_TEXT_BASE=0x20100000 +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -32,6 +33,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -44,6 +46,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index d6ca28979f..9c85b8e9c0 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -40,6 +41,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y @@ -51,6 +53,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 150693b387..647edeaed7 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -31,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y @@ -46,6 +48,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index e12c3d5a7e..9f9297c5fb 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -39,6 +40,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -54,6 +56,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index 39d431aec1..d7c8a5613c 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2081ARDB=y CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -30,7 +31,9 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y @@ -42,6 +45,7 @@ CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index b04796cbb7..85e6a01f5d 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_TFABOOT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -31,11 +32,13 @@ CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_ENV_IS_IN_FLASH=y -CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -50,6 +53,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y @@ -58,7 +62,4 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_BLK=y -CONFIG_DM_MMC=y diff --git a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig index d230e64307..3fedbc2038 100644 --- a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -26,6 +27,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y @@ -40,6 +42,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index 1c9a39d4b0..ff1f95f081 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -29,6 +30,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -44,6 +46,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index cb9490a867..058b3dd938 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -1,11 +1,12 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x82000000 -CONFIG_TFABOOT=y CONFIG_SECURE_BOOT=y -CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_QSPI_AHB_INIT=y +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -32,10 +33,10 @@ CONFIG_CMD_DATE=y CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" -CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -CONFIG_FSL_CAAM=y +CONFIG_SATA_CEVA=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -44,7 +45,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y - CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y @@ -53,22 +53,18 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y -CONFIG_FSL_SPI_ALIGNED_TXFIFO=y - CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y -CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_BLK=y -CONFIG_DM_MMC=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index 016d8bcdb6..e15156be3e 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -1,10 +1,11 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_QSPI_AHB_INIT=y CONFIG_TFABOOT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y -CONFIG_QSPI_AHB_INIT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -32,11 +33,13 @@ CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" CONFIG_ENV_IS_IN_FLASH=y -CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -46,7 +49,6 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set - CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y @@ -55,19 +57,15 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y -CONFIG_FSL_SPI_ALIGNED_TXFIFO=y - CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_BLK=y -CONFIG_DM_MMC=y
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1012afrwy and ls1012afrwy defconfigs that missing one of them or more. Support sata for all ls1012afrwy defconfigs
Signed-off-by: Peng Ma peng.ma@nxp.com --- configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig | 4 +++- configs/ls1012afrwy_qspi_defconfig | 4 +++- configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig | 4 +++- configs/ls1012afrwy_tfa_defconfig | 4 +++- 4 files changed, 12 insertions(+), 4 deletions(-)
diff --git a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig index c273dc937e..d5034b7b26 100644 --- a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1012AFRWY=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set @@ -28,7 +29,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frwy" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -# CONFIG_BLK is not set +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y @@ -40,6 +41,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1012afrwy_qspi_defconfig b/configs/ls1012afrwy_qspi_defconfig index 85523ba2d3..6fa13b205e 100644 --- a/configs/ls1012afrwy_qspi_defconfig +++ b/configs/ls1012afrwy_qspi_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012AFRWY=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set @@ -29,7 +30,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frwy" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -# CONFIG_BLK is not set +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y @@ -41,6 +42,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig index d9020c5281..02f5dedfa2 100644 --- a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig @@ -5,6 +5,7 @@ CONFIG_SECURE_BOOT=y CONFIG_TFABOOT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set @@ -28,7 +29,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frwy" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -# CONFIG_BLK is not set +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y @@ -40,6 +41,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1012afrwy_tfa_defconfig b/configs/ls1012afrwy_tfa_defconfig index 08b3692f97..1da166e43a 100644 --- a/configs/ls1012afrwy_tfa_defconfig +++ b/configs/ls1012afrwy_tfa_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_TFABOOT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set @@ -29,7 +30,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frwy" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -# CONFIG_BLK is not set +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y @@ -41,6 +42,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1021a defconfigs that missing one of them or more. enable CONFIG_DM_MMC for some defconfigs to support CONFIG_BLK Support sata for all ls1021a defconfigs
Signed-off-by: Peng Ma peng.ma@nxp.com --- configs/ls1021aiot_qspi_defconfig | 5 ++++- configs/ls1021aiot_sdcard_defconfig | 5 ++++- configs/ls1021aqds_ddr4_nor_defconfig | 4 ++++ configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 4 ++++ configs/ls1021aqds_nand_defconfig | 4 ++++ configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 4 ++++ configs/ls1021aqds_nor_defconfig | 4 ++++ configs/ls1021aqds_nor_lpuart_defconfig | 4 ++++ configs/ls1021aqds_qspi_defconfig | 4 ++++ configs/ls1021aqds_sdcard_ifc_defconfig | 4 ++++ configs/ls1021aqds_sdcard_qspi_defconfig | 4 ++++ configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 3 +++ configs/ls1021atwr_nor_lpuart_defconfig | 3 +++ configs/ls1021atwr_qspi_defconfig | 3 +++ configs/ls1021atwr_sdcard_ifc_defconfig | 3 +++ configs/ls1021atwr_sdcard_qspi_defconfig | 3 +++ 16 files changed, 59 insertions(+), 2 deletions(-)
diff --git a/configs/ls1021aiot_qspi_defconfig b/configs/ls1021aiot_qspi_defconfig index 0cafb5f294..c166abcdd4 100644 --- a/configs/ls1021aiot_qspi_defconfig +++ b/configs/ls1021aiot_qspi_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AIOT=y CONFIG_SYS_TEXT_BASE=0x40010000 +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_MISC_INIT_R=y @@ -15,7 +16,9 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-iot-duart" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y @@ -28,6 +31,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y @@ -36,4 +40,3 @@ CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index 0b15353bac..cbe1bf1186 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1021AIOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_MISC_INIT_R=y @@ -20,7 +21,9 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-iot-duart" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y @@ -33,6 +36,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y @@ -41,4 +45,3 @@ CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index d697a0302b..296cd094a3 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -33,7 +34,9 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -47,6 +50,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index f485b73a8b..187c534ffc 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -34,7 +35,9 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -48,6 +51,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_USB=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 045ef52a0f..81701fccf0 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -48,8 +49,10 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -63,6 +66,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 716cc63624..702d849a89 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_SECURE_BOOT=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y @@ -34,7 +35,9 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_SYS_FSL_DDR3=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -48,6 +51,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 9be4838c7e..2fd8d6e340 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -33,8 +34,10 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -48,6 +51,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index df922f59af..e00084cc04 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -34,8 +35,10 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -49,6 +52,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_USB=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index 70442c8f7f..80ea5138a9 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x40100000 +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -34,8 +35,10 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y @@ -47,6 +50,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index ec7f1bc15d..55793783d0 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -46,8 +47,10 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -61,6 +64,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index 133897b6ef..db308bc613 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -45,8 +46,10 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y @@ -58,6 +61,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index e3cd75563e..787c1fe93a 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_SECURE_BOOT=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_F is not set @@ -29,6 +30,7 @@ CONFIG_CMD_BMP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y @@ -43,6 +45,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 347c664e60..7c9c9d7062 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x60100000 +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y @@ -30,6 +31,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-lpuart" CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -45,6 +47,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_USB=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index edf74eef48..186cd1afd6 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x40100000 +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y @@ -31,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -45,6 +47,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index c69d1dd75a..f94e31fc26 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y @@ -41,6 +42,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -56,6 +58,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index c59e493490..9310d6ecc8 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y @@ -41,6 +42,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -55,6 +57,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y
-----Original Message----- From: Peng Ma Sent: Wednesday, January 30, 2019 4:32 PM To: albert.u.boot@aribaud.net; York Sun york.sun@nxp.com Cc: Bhaskar Upadhaya bhaskar.upadhaya@nxp.com; VINITHA V PILLAI vinitha.pillai@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; feng.li_2@nxp.com; Alison Wang alison.wang@nxp.com; sumit.garg@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; Udit Agarwal udit.agarwal@nxp.com; Ashish Kumar ashish.kumar@nxp.com; Priyanka Jain priyanka.jain@nxp.com; sriram.dash@nxp.com; Z.q. Hou zhiqiang.hou@nxp.com; Pankit Garg pankit.garg@nxp.com; aford173@gmail.com; mario.six@gdsys.cc; Yinbo Zhu yinbo.zhu@nxp.com; siva.durga.paladugu@xilinx.com; joe.hershberger@ni.com; jgebben@sweptlaser.com; Andy Tang andy.tang@nxp.com; u- boot@lists.denx.de; Peng Ma peng.ma@nxp.com Subject: [PATCH 1/7] armv8: fsl-layerscape: ls1043a: move SCSI_AHCI and SCSI form arch/arm/cpu/armv8/fsl-layerscape/Kconfig to arch/arm/Kconfig
This patch-set including 7 patches been applied to fsl-qoriq master, awaiting upstream.
--pk
Peng Ma
Prabhakar Kushwaha
