[U-Boot] [PATCH 1/2] ppc4xx: Only define DDR2 registers for the correct PowerPC variants
Make sure that some SDRAM/DDR2 registers are only defined for the PPC variants really implementing those registers.
Signed-off-by: Stefan Roese sr@denx.de --- arch/powerpc/include/asm/ppc4xx-sdram.h | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/powerpc/include/asm/ppc4xx-sdram.h b/arch/powerpc/include/asm/ppc4xx-sdram.h index d9506e2..42eac45 100644 --- a/arch/powerpc/include/asm/ppc4xx-sdram.h +++ b/arch/powerpc/include/asm/ppc4xx-sdram.h @@ -363,6 +363,7 @@ /* * Memory controller registers */ +#ifdef CONFIG_405EX #define SDRAM_BESR 0x00 /* PLB bus error status (read/clear) */ #define SDRAM_BESRT 0x01 /* PLB bus error status (test/set) */ #define SDRAM_BEARL 0x02 /* PLB bus error address low */ @@ -371,11 +372,10 @@ #define SDRAM_WMIRQT 0x07 /* PLB write master interrupt (test/set) */ #define SDRAM_PLBOPT 0x08 /* PLB slave options */ #define SDRAM_PUABA 0x09 /* PLB upper address base */ -#ifndef CONFIG_405EX -#define SDRAM_MCSTAT 0x14 /* memory controller status */ -#else #define SDRAM_MCSTAT 0x1F /* memory controller status */ -#endif +#else /* CONFIG_405EX */ +#define SDRAM_MCSTAT 0x14 /* memory controller status */ +#endif /* CONFIG_405EX */ #define SDRAM_MCOPT1 0x20 /* memory controller options 1 */ #define SDRAM_MCOPT2 0x21 /* memory controller options 2 */ #define SDRAM_MODT0 0x22 /* on die termination for bank 0 */
Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
