[U-Boot] [PATCH] cosmetic: FIT: fix typos in comments
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- common/image-fit.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 199b4ed..1c2ef31 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -58,7 +58,7 @@ static int fit_parse_spec(const char *spec, char sepc, ulong addr_curr, * @conf_name double pointer to a char, will hold pointer to a configuration * unit name * - * fit_parse_conf() expects configuration spec in the for of [<addr>]#<conf>, + * fit_parse_conf() expects configuration spec in the form of [<addr>]#<conf>, * where <addr> is a FIT image address that contains configuration * with a <conf> unit name. * @@ -84,7 +84,7 @@ int fit_parse_conf(const char *spec, ulong addr_curr, * subimage * @image_name: double pointer to a char, will hold pointer to a subimage name * - * fit_parse_subimage() expects subimage spec in the for of + * fit_parse_subimage() expects subimage spec in the form of * [<addr>]:<subimage>, where <addr> is a FIT image address that contains * subimage with a <subimg> unit name. *
On Tue, Sep 17, 2013 at 6:36 PM, Masahiro Yamada yamada.m@jp.panasonic.comwrote:
On Wed, Sep 18, 2013 at 09:36:38AM +0900, Masahiro Yamada wrote:
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Acked-by: Simon Glass sjg@chromium.org
Masahiro Yamada
