[U-Boot] [PATCH v2]ppc4xx/Canyonlands added USB board callbacks
Functions added to support board callbacks for USB init. This isolates USB manipulations such that it is only touched if USB is used by U-Boot.
Signed-off-by: Dave Mitchell dmitchell@appliedmicro.com Signed-off-by: Rupjyoti Sarmah rsarmah@appliedmicro.com --- This patch incorporates the changes advised. The description of the Macros changed in the header file.
board/amcc/canyonlands/canyonlands.c | 64 +++++++++++++++++++++++++++++----- include/configs/canyonlands.h | 13 +++++++ 2 files changed, 68 insertions(+), 9 deletions(-)
diff --git a/board/amcc/canyonlands/canyonlands.c b/board/amcc/canyonlands/canyonlands.c index 23874d2..c3c1348 100644 --- a/board/amcc/canyonlands/canyonlands.c +++ b/board/amcc/canyonlands/canyonlands.c @@ -34,7 +34,17 @@ extern flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH ch
DECLARE_GLOBAL_DATA_PTR;
-#define CONFIG_SYS_BCSR3_PCIE 0x10 + struct ep460c_bcsr { + u8 board_id; + u8 cpld_rev; + u8 led_user; + u8 board_status; + u8 reset_ctrl; + u8 flash_ctrl; + u8 eth_ctrl; + u8 usb_ctrl; + u8 irq_ctrl; +};
#define BOARD_CANYONLANDS_PCIE 1 #define BOARD_CANYONLANDS_SATA 2 @@ -112,6 +122,9 @@ int board_early_init_f(void) { #if !defined(CONFIG_ARCHES) u32 sdr0_cust0; + struct ep460c_bcsr *bcsr_data = + (struct ep460c_bcsr *)CONFIG_SYS_BCSR_BASE; + #endif
/* @@ -172,14 +185,10 @@ int board_early_init_f(void)
#if !defined(CONFIG_ARCHES) /* Enable ethernet and take out of reset */ - out_8((void *)CONFIG_SYS_BCSR_BASE + 6, 0); + out_8(&bcsr_data->eth_ctrl, 0) ;
/* Remove NOR-FLASH, NAND-FLASH & EEPROM hardware write protection */ - out_8((void *)CONFIG_SYS_BCSR_BASE + 5, 0); - - /* Enable USB host & USB-OTG */ - out_8((void *)CONFIG_SYS_BCSR_BASE + 7, 0); - + out_8(&bcsr_data->flash_ctrl, 0) ; mtsdr(SDR0_SRST1, 0); /* Pull AHB out of reset default=1 */
/* Setup PLB4-AHB bridge based on the system address map */ @@ -201,6 +210,41 @@ int board_early_init_f(void) return 0; }
+#if defined(CONFIG_USB_OHCI_NEW) && defined(CONFIG_SYS_USB_OHCI_BOARD_INIT) +int usb_board_init(void) +{ + struct ep460c_bcsr *bcsr_data = + (struct ep460c_bcsr *)CONFIG_SYS_BCSR_BASE; + u8 val; + + /* Enable USB host & USB-OTG */ + val = in_8(&bcsr_data->usb_ctrl); + val &= ~(BCSR_USBCTRL_OTG_RST | BCSR_USBCTRL_HOST_RST); + out_8(&bcsr_data->usb_ctrl, val); + + return 0; +} + +int usb_board_stop(void) +{ + struct ep460c_bcsr *bcsr_data = + (struct ep460c_bcsr *)CONFIG_SYS_BCSR_BASE; + u8 val; + + /* Disable USB host & USB-OTG */ + val = in_8(&bcsr_data->usb_ctrl); + val |= (BCSR_USBCTRL_OTG_RST | BCSR_USBCTRL_HOST_RST); + out_8(&bcsr_data->usb_ctrl, val); + + return 0; +} + +int usb_board_init_fail(void) +{ + return usb_board_stop(); +} +#endif /* CONFIG_USB_OHCI_NEW && CONFIG_SYS_USB_OHCI_BOARD_INIT */ + #if !defined(CONFIG_ARCHES) static void canyonlands_sata_init(int board_type) { @@ -244,11 +288,13 @@ int get_cpu_num(void) #if !defined(CONFIG_ARCHES) int checkboard(void) { + struct ep460c_bcsr *bcsr_data = + (struct ep460c_bcsr *)CONFIG_SYS_BCSR_BASE; char *s = getenv("serial#");
if (pvr_460ex()) { printf("Board: Canyonlands - AMCC PPC460EX Evaluation Board"); - if (in_8((void *)(CONFIG_SYS_BCSR_BASE + 3)) & CONFIG_SYS_BCSR3_PCIE) + if (in_8(&bcsr_data->board_status) & CONFIG_SYS_BCSR3_PCIE) gd->board_type = BOARD_CANYONLANDS_PCIE; else gd->board_type = BOARD_CANYONLANDS_SATA; @@ -268,7 +314,7 @@ int checkboard(void) break; }
- printf(", Rev. %X", in_8((void *)(CONFIG_SYS_BCSR_BASE + 0))); + printf(", Rev. %X", in_8(&bcsr_data->cpld_rev));
if (s != NULL) { puts(", serial# "); diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index ac9b3c5..0eee522 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -77,6 +77,18 @@ #define CONFIG_SYS_PCIE0_XCFGBASE 0xc3000000 #define CONFIG_SYS_PCIE1_XCFGBASE 0xc3001000
+/* + * BCSR bits as defined in the Canyonlands board user manual. + */ +#define BCSR_CPLDREV 0x00 +#define BCSR_BRDSTS 0x03 +#define BCSR_FLASHCTRL 0x05 +#define BCSR_ETHCTRL 0x06 +#define BCSR_USBCTRL 0x07 +#define BCSR_USBCTRL_OTG_RST 0x32 +#define BCSR_USBCTRL_HOST_RST 0x01 +#define CONFIG_SYS_BCSR3_PCIE 0x10 + #define CONFIG_SYS_PCIE0_UTLBASE 0xc08010000ULL /* 36bit physical addr */
/* base address of inbound PCIe window */ @@ -417,6 +429,7 @@ #define CONFIG_SYS_USB_OHCI_REGS_BASE (CONFIG_SYS_AHB_BASE | 0xd0000) #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ppc440" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 +#define CONFIG_SYS_USB_OHCI_BOARD_INIT #endif
Hi Rup,
Thanks. Looks quite good now. Please find a small comment below.
<snip>
- BCSR bits as defined in the Canyonlands board user manual.
Hmmm. Which of these defines are really bits and which are offsets for registers? You can remove the register offsets defines, since you're using the struct now. And please use consistent naming, and don't name one bit "CONFIG_SYS_BCSRxxx".
Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Hi Stefan and Felix,
Thanks for your inputs. I am releasing v3 with the updates.
Regards, Rup
-----Original Message----- From: Stefan Roese [mailto:sr@denx.de]
<snip>
index ac9b3c5..0eee522 100644 --- a/include/configs/canyonlands.h +#define CONFIG_SYS_BCSR3_PCIE 0x10
Hi Rupjyoti,
- struct ep460c_bcsr {
u8 board_id;
u8 cpld_rev;
u8 led_user;
u8 board_status;
u8 reset_ctrl;
u8 flash_ctrl;
u8 eth_ctrl;
u8 usb_ctrl;
u8 irq_ctrl;
Can you name this structure canyonlands_bcsr or just board_bcsr. As Wolfgang said, ep460c is not not used anywhere in the code.
Thanks.
Felix.
Felix Radensky
Rupjyoti Sarmah
Rupjyoti Sarmah
Stefan Roese
