[U-Boot] [PATCH 0/3] MIPS: fixes for 2012.04-rc1
Hi Marek,
this series collects the bugfix patches from the open patches at patchwork delegated to you. Only these patches should be merged for the release. The other patches are superseeded for now.
The series is rebased against v2012.04-rc1 and needs your patch http://patchwork.ozlabs.org/patch/149924/ to run MAKEALL -a mips.
Daniel Schwierzeck (3): MIPS: board.c: fix init of flash data in bd_info MIPS: fix inconsistency in config option for cache operation mode MIPS: fix endianess handling
README | 6 ++++++ arch/mips/cpu/mips32/cache.S | 6 +++++- arch/mips/cpu/mips32/config.mk | 21 +++++++++++++++------ arch/mips/lib/board.c | 8 ++++++-- boards.cfg | 2 +- include/configs/pb1x00.h | 2 ++ 6 files changed, 35 insertions(+), 10 deletions(-)
-- 1.7.9.4
Boards with CONFIG_SYS_NO_FLASH should not forced to define CONFIG_SYS_FLASH_BASE. In this case the flash data in bd_info should be initialized with 0 like the other archs do.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- arch/mips/lib/board.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/mips/lib/board.c b/arch/mips/lib/board.c index d998f0e..38e6e77 100644 --- a/arch/mips/lib/board.c +++ b/arch/mips/lib/board.c @@ -294,15 +294,19 @@ void board_init_r(gd_t *id, ulong dest_addr) /* configure available FLASH banks */ size = flash_init(); display_flash_config(size); + bd->bi_flashstart = CONFIG_SYS_FLASH_BASE; bd->bi_flashsize = size; -#endif
- bd->bi_flashstart = CONFIG_SYS_FLASH_BASE; #if CONFIG_SYS_MONITOR_BASE == CONFIG_SYS_FLASH_BASE bd->bi_flashoffset = monitor_flash_len; /* reserved area for U-Boot */ #else bd->bi_flashoffset = 0; #endif +#else + bd->bi_flashstart = 0; + bd->bi_flashsize = 0; + bd->bi_flashoffset = 0; +#endif
#ifdef CONFIG_CMD_NAND puts("NAND: ");
Commit ab2a98b11716364bc5a8c43cdfa7fee176cda1d8 missed to use the new config option in dcache_enable().
Fix this to avoid inconsistencies if someone wants to disable and enable D-caches.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- arch/mips/cpu/mips32/cache.S | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/mips/cpu/mips32/cache.S b/arch/mips/cpu/mips32/cache.S index 5ce0ec4..e683e8b 100644 --- a/arch/mips/cpu/mips32/cache.S +++ b/arch/mips/cpu/mips32/cache.S @@ -30,6 +30,10 @@ #include <asm/addrspace.h> #include <asm/cacheops.h>
+#ifndef CONFIG_SYS_MIPS_CACHE_MODE +#define CONFIG_SYS_MIPS_CACHE_MODE CONF_CM_CACHABLE_NONCOHERENT +#endif + #define RA t8
/* @@ -224,7 +228,7 @@ LEAF(dcache_enable) mfc0 t0, CP0_CONFIG ori t0, CONF_CM_CMASK xori t0, CONF_CM_CMASK - ori t0, CONF_CM_CACHABLE_NONCOHERENT + ori t0, CONFIG_SYS_MIPS_CACHE_MODE mtc0 t0, CP0_CONFIG jr ra END(dcache_enable)
Mike, there was some issue with this patch?
#define RA t8
- ori t0, CONFIG_SYS_MIPS_CACHE_MODE mtc0 t0, CP0_CONFIG jr ra END(dcache_enable)
Best regards, Marek Vasut
this commit refers to a patch that I sent a while ago as preparation for supporting Lantiq SoCs. Some Lantiq SoCs wants CONF_CM_CACHABLE_NO_WA instead of the hard-coded CONF_CM_CACHABLE_NONCOHERENT. So I created a config option for the required cache mode.
#define RA t8
I only changed start.S and forgot to change this code part too. That is why I created this patch to fix this inconsistency.
Dear Daniel Schwierzeck,
#define RA t8
I see ... so this fixes some other commit. What was Shinya-san's concern, that you only changed this file?
i had feedback on the endian flags last time Daniel posted it, but i don't think i ever gave feedback on this ... i certainly don't know mips asm beyond the extreme basics ;).
was there a patchwork URL or mailing list archive for me to check ? -mike
Apologies for confusing, I intended to refer to PATCH 3/3, not 2/3. If everybody is Ok with 3/3 as-is, I'm fine.
Shinya
Make endianess of target CPU configurable. Use the new config option for dbau1550_el and pb1000 boards.
Adapt linking of standalone applications to pass through endianess options to LD.
Build tested with: - ELDK 4 mips_4KC- and mips4KCle - Sourcery CodeBench Lite 2011.03-93
With this patch all 26 MIPS boards can be compiled now in one step by running "MAKEALL -a mips".
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- README | 6 ++++++ arch/mips/cpu/mips32/config.mk | 21 +++++++++++++++------ boards.cfg | 2 +- include/configs/pb1x00.h | 2 ++ 4 files changed, 24 insertions(+), 7 deletions(-)
diff --git a/README b/README index c98afa7..9702067 100644 --- a/README +++ b/README @@ -374,6 +374,12 @@ The following options need to be configured: Defines the string to utilize when trying to match PCIe device tree nodes for the given platform.
+- Generic CPU options: + CONFIG_SYS_BIG_ENDIAN, CONFIG_SYS_LITTLE_ENDIAN + + Defines the endianess of the CPU. Implementation of those + values is arch specific. + - Intel Monahans options: CONFIG_SYS_MONAHANS_RUN_MODE_OSC_RATIO
diff --git a/arch/mips/cpu/mips32/config.mk b/arch/mips/cpu/mips32/config.mk index 4d1b273..a1cd590 100644 --- a/arch/mips/cpu/mips32/config.mk +++ b/arch/mips/cpu/mips32/config.mk @@ -27,14 +27,23 @@ # Note: Toolchains with binutils prior to v2.16 # are no longer supported by U-Boot MIPS tree! # -MIPSFLAGS = -march=mips32r2 +MIPSFLAGS := -march=mips32r2
+# Handle special prefix in ELDK 4.0 toolchain ifneq (,$(findstring 4KCle,$(CROSS_COMPILE))) -ENDIANNESS = -EL -else -ENDIANNESS = -EB +ENDIANNESS := -EL endif
-MIPSFLAGS += $(ENDIANNESS) +ifdef CONFIG_SYS_LITTLE_ENDIAN +ENDIANNESS := -EL +endif + +ifdef CONFIG_SYS_BIG_ENDIAN +ENDIANNESS := -EB +endif + +# Default to EB if no endianess is configured +ENDIANNESS ?= -EB
-PLATFORM_CPPFLAGS += $(MIPSFLAGS) +PLATFORM_CPPFLAGS += $(MIPSFLAGS) $(ENDIANNESS) +PLATFORM_LDFLAGS += $(ENDIANNESS) diff --git a/boards.cfg b/boards.cfg index c6090ba..3cf75c3 100644 --- a/boards.cfg +++ b/boards.cfg @@ -360,7 +360,7 @@ dbau1000 mips mips32 dbau1x00 - dbau1100 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1100 dbau1500 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1500 dbau1550 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1550 -dbau1550_el mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1550 +dbau1550_el mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1550,SYS_LITTLE_ENDIAN gth2 mips mips32 - - au1x00 pb1000 mips mips32 pb1x00 - au1x00 pb1x00:PB1000 incaip mips mips32 incaip - incaip diff --git a/include/configs/pb1x00.h b/include/configs/pb1x00.h index eea8ed3..d056884 100644 --- a/include/configs/pb1x00.h +++ b/include/configs/pb1x00.h @@ -46,6 +46,8 @@ #endif #endif
+#define CONFIG_SYS_LITTLE_ENDIAN + #define CONFIG_ETHADDR DE:AD:BE:EF:01:01 /* Ethernet address */
#define CONFIG_BOOTDELAY 2 /* autoboot after 2 seconds */
Acked-by: Mike Frysinger vapier@gentoo.org
note: we could unify the -EL/-EB handling in the top level as those options are the same for linkers. it's only the CFLAGS that differ :(. -mike
Dear Mike Frysinger,
Agreed ... so I'll be pushing those for .04 release as fixes?
-mike
Hi Marek,
Shinya-san, you ok with these patches hitting .04?
I'll roll then through my -staging if it's fine.
-- 1.7.9.4
Suggestions/comments from Mike to the last submission are not reflected in [PATCH 2/3] (MIPS: fix inconsistency in config option for cache operation mode), but other than that these three patches are Ok with me.
Thanks in advance, I don't have enough bandwidth to catch up with the latest tree/discussion, nor doing build tests and/or boot tests.
Daniel Schwierzeck
Mike Frysinger
Shinya Kuribayashi
