[PATCH] arm64: zynqmp: Do not enable IPI by default
ZynqMP mini configurations are not using IPI driver and enabling this is adding additional ~1200 Bytes (depends on configuration). This ends up in situation that there is no enough space in OCM for relocation that's why disable this driver for all mini configurations.
Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/Kconfig | 4 ++-- configs/xilinx_zynqmp_mini_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc0_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc1_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_single_defconfig | 1 + configs/xilinx_zynqmp_mini_qspi_defconfig | 1 + 7 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f95ed71b2466..3f68d0988b7f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1302,7 +1302,7 @@ config ARCH_ZYNQMP select DM select DEBUG_UART_BOARD_INIT if SPL && DEBUG_UART select DM_ETH if NET - select DM_MAILBOX + imply DM_MAILBOX select DM_MMC if MMC select DM_SERIAL select DM_SPI if SPI @@ -1319,7 +1319,7 @@ config ARCH_ZYNQMP imply SPL_FIRMWARE if SPL select SPL_SEPARATE_BSS if SPL select SUPPORT_SPL - select ZYNQMP_IPI + imply ZYNQMP_IPI if DM_MAILBOX select SOC_DEVICE imply BOARD_LATE_INIT imply CMD_DM diff --git a/configs/xilinx_zynqmp_mini_defconfig b/configs/xilinx_zynqmp_mini_defconfig index 245b6a42b935..f29128bf55d9 100644 --- a/configs/xilinx_zynqmp_mini_defconfig +++ b/configs/xilinx_zynqmp_mini_defconfig @@ -59,6 +59,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_NET is not set # CONFIG_DM_WARN is not set # CONFIG_DM_DEVICE_REMOVE is not set +# CONFIG_DM_MAILBOX is not set # CONFIG_MMC is not set CONFIG_ARM_DCC=y CONFIG_PANIC_HANG=y diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index adf1dae66ede..611da78239db 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -71,6 +71,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_DM_WARN is not set # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_SPL_DM_SEQ_ALIAS=y +# CONFIG_DM_MAILBOX is not set CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index 9d799ad0e3d5..c8084e6ae050 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -71,6 +71,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_DM_WARN is not set # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_SPL_DM_SEQ_ALIAS=y +# CONFIG_DM_MAILBOX is not set CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index 29040a39e970..f5a467940266 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -55,6 +55,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_NET is not set # CONFIG_DM_WARN is not set # CONFIG_DM_DEVICE_REMOVE is not set +# CONFIG_DM_MAILBOX is not set # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_DM_MTD=y diff --git a/configs/xilinx_zynqmp_mini_nand_single_defconfig b/configs/xilinx_zynqmp_mini_nand_single_defconfig index 7c17c061d424..61c44e2a6a44 100644 --- a/configs/xilinx_zynqmp_mini_nand_single_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_single_defconfig @@ -55,6 +55,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_NET is not set # CONFIG_DM_WARN is not set # CONFIG_DM_DEVICE_REMOVE is not set +# CONFIG_DM_MAILBOX is not set # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_DM_MTD=y diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index 513b51998d25..a4b754e09ebb 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -76,6 +76,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y # CONFIG_GPIO is not set # CONFIG_I2C is not set # CONFIG_INPUT is not set +# CONFIG_DM_MAILBOX is not set # CONFIG_MMC is not set # CONFIG_SPI_FLASH_SMART_HWCAPS is not set # CONFIG_SPI_FLASH_UNLOCK_ALL is not set
- select DM_MAILBOX
- imply DM_MAILBOX select DM_MMC if MMC select DM_SERIAL select DM_SPI if SPI
- select ZYNQMP_IPI
- imply ZYNQMP_IPI if DM_MAILBOX select SOC_DEVICE imply BOARD_LATE_INIT imply CMD_DM
Applied. M
Michal Simek
