[U-Boot] [PATCH] common: board_f: cosmetic use __weak for leds
First of all this looks a lot better, but it also prevents a gcc warning (W=1), that the weak function has no previous prototype.
cc: Simon Glass sjg@chromium.org Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl
--- This likely causes some merge issues, but is so uggly it deserves it. --- common/board_f.c | 29 ++++++++++------------------- include/status_led.h | 22 +++++++++++----------- 2 files changed, 21 insertions(+), 30 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 4ea4cb2..bdab38e 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -37,6 +37,7 @@ #include <os.h> #include <post.h> #include <spi.h> +#include <status_led.h> #include <trace.h> #include <watchdog.h> #include <asm/errno.h> @@ -78,25 +79,15 @@ DECLARE_GLOBAL_DATA_PTR; ************************************************************************ * May be supplied by boards if desired */ -inline void __coloured_LED_init(void) {} -void coloured_LED_init(void) - __attribute__((weak, alias("__coloured_LED_init"))); -inline void __red_led_on(void) {} -void red_led_on(void) __attribute__((weak, alias("__red_led_on"))); -inline void __red_led_off(void) {} -void red_led_off(void) __attribute__((weak, alias("__red_led_off"))); -inline void __green_led_on(void) {} -void green_led_on(void) __attribute__((weak, alias("__green_led_on"))); -inline void __green_led_off(void) {} -void green_led_off(void) __attribute__((weak, alias("__green_led_off"))); -inline void __yellow_led_on(void) {} -void yellow_led_on(void) __attribute__((weak, alias("__yellow_led_on"))); -inline void __yellow_led_off(void) {} -void yellow_led_off(void) __attribute__((weak, alias("__yellow_led_off"))); -inline void __blue_led_on(void) {} -void blue_led_on(void) __attribute__((weak, alias("__blue_led_on"))); -inline void __blue_led_off(void) {} -void blue_led_off(void) __attribute__((weak, alias("__blue_led_off"))); +__weak void coloured_LED_init(void) {} +__weak void red_led_on(void) {} +__weak void red_led_off(void) {} +__weak void green_led_on(void) {} +__weak void green_led_off(void) {} +__weak void yellow_led_on(void) {} +__weak void yellow_led_off(void) {} +__weak void blue_led_on(void) {} +__weak void blue_led_off(void) {}
/* * Why is gd allocated a register? Prior to reloc it might be better to diff --git a/include/status_led.h b/include/status_led.h index ecff60d..848708a 100644 --- a/include/status_led.h +++ b/include/status_led.h @@ -294,19 +294,21 @@ extern void __led_set (led_id_t mask, int state); # include <asm/status_led.h> #endif
+#endif /* CONFIG_STATUS_LED */ + /* * Coloured LEDs API */ #ifndef __ASSEMBLY__ -extern void coloured_LED_init (void); -extern void red_led_on(void); -extern void red_led_off(void); -extern void green_led_on(void); -extern void green_led_off(void); -extern void yellow_led_on(void); -extern void yellow_led_off(void); -extern void blue_led_on(void); -extern void blue_led_off(void); +void coloured_LED_init(void); +void red_led_on(void); +void red_led_off(void); +void green_led_on(void); +void green_led_off(void); +void yellow_led_on(void); +void yellow_led_off(void); +void blue_led_on(void); +void blue_led_off(void); #else .extern LED_init .extern red_led_on @@ -319,6 +321,4 @@ extern void blue_led_off(void); .extern blue_led_off #endif
-#endif /* CONFIG_STATUS_LED */ - #endif /* _STATUS_LED_H_ */
Build tested for sandbox and a few ARM boards.
cc: Simon Glass sjg@chromium.org Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl Acked-by: Simon Glass sjg@chromium.org
Jeroen Hofstee
