Re: [U-Boot-Users] No serial output from mips/au1550
Thank you all for the suggestions and help. I will double check all the settings.
Mitsy
On 7/19/06, Andrew Dyer amdyer@gmail.com wrote:
On 7/19/06, mitsy mitsy12@gmail.com wrote:
I'm using BDI2000 to debug my version of u-boot, which is still under development. I can step through the code via telnet with bdi, but I'm not seeing any output on serial port when it's supposed to be writing stuff out. The only time I see anything on the serial console is when I reset the target, before running anything. It spits put some garbage.
Our company does consulting work and having been through u-boot on the 1550 a few times could probably get you up and running pretty quickly. If you are interested you can take a look at our website (http://www.righthandtech.com) or e-mail me at adyer@righthandtech.com. I can get you in touch with the guys that handle the business end of things or you can use the contact info on the website.
-- Hardware, n.: The parts of a computer system that can be kicked.
mitsy
