[U-Boot] [PATCH 0/3] ARM: meson-g12a: Add missing support from Linux 5.2-rc1
This patchset : - Syncs the G12A DT from v5.2-rc1 - Add support for the G12A PCIE PLL, introduced in v5.2-rc1 - Add missing DT to fill the gaps, that will be synced in Linux 5.3-rc1
Neil Armstrong (3): ARM: dts: sync Amlogic G12A DT with Linux 5.2-rc1 clk: meson-g12a: Add PCIE PLL support ARM: dts: Add missing DT for Meson G12A support
arch/arm/dts/meson-g12a-u-boot.dtsi | 216 ++++++++ arch/arm/dts/meson-g12a-u200-u-boot.dtsi | 63 +++ arch/arm/dts/meson-g12a-u200.dts | 147 ++++++ arch/arm/dts/meson-g12a.dtsi | 465 ++++++++++++++++++ drivers/clk/meson/g12a.c | 103 ++++ include/dt-bindings/clock/g12a-aoclkc.h | 2 + include/dt-bindings/clock/g12a-clkc.h | 5 + .../reset/amlogic,meson-g12a-reset.h | 5 +- 8 files changed, 1005 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/meson-g12a-u-boot.dtsi create mode 100644 arch/arm/dts/meson-g12a-u200-u-boot.dtsi
Sync from Linux commit a188339ca5a3 ("Linux 5.2-rc1")
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/dts/meson-g12a-u200.dts | 147 ++++++ arch/arm/dts/meson-g12a.dtsi | 465 ++++++++++++++++++ include/dt-bindings/clock/g12a-aoclkc.h | 2 + include/dt-bindings/clock/g12a-clkc.h | 5 + .../reset/amlogic,meson-g12a-reset.h | 5 +- 5 files changed, 623 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/meson-g12a-u200.dts b/arch/arm/dts/meson-g12a-u200.dts index c44dbdddf2..0e8045b8a9 100644 --- a/arch/arm/dts/meson-g12a-u200.dts +++ b/arch/arm/dts/meson-g12a-u200.dts @@ -6,6 +6,8 @@ /dts-v1/;
#include "meson-g12a.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/gpio/meson-g12a-gpio.h>
/ { compatible = "amlogic,u200", "amlogic,g12a"; @@ -21,9 +23,154 @@ device_type = "memory"; reg = <0x0 0x0 0x0 0x40000000>; }; + + cvbs-connector { + compatible = "composite-video-connector"; + + port { + cvbs_connector_in: endpoint { + remote-endpoint = <&cvbs_vdac_out>; + }; + }; + }; + + flash_1v8: regulator-flash_1v8 { + compatible = "regulator-fixed"; + regulator-name = "FLASH_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + regulator-always-on; + }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&hdmi_tx_tmds_out>; + }; + }; + }; + + main_12v: regulator-main_12v { + compatible = "regulator-fixed"; + regulator-name = "12V"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + }; + + vcc_1v8: regulator-vcc_1v8 { + compatible = "regulator-fixed"; + regulator-name = "VCC_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + regulator-always-on; + }; + + vcc_3v3: regulator-vcc_3v3 { + compatible = "regulator-fixed"; + regulator-name = "VCC_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vddao_3v3>; + regulator-always-on; + /* FIXME: actually controlled by VDDCPU_B_EN */ + }; + + vcc_5v: regulator-vcc_5v { + compatible = "regulator-fixed"; + regulator-name = "VCC_5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&main_12v>; + + gpio = <&gpio GPIOH_8 GPIO_OPEN_DRAIN>; + enable-active-high; + }; + + usb_pwr_en: regulator-usb_pwr_en { + compatible = "regulator-fixed"; + regulator-name = "USB_PWR_EN"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc_5v>; + + gpio = <&gpio GPIOH_6 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vddao_1v8: regulator-vddao_1v8 { + compatible = "regulator-fixed"; + regulator-name = "VDDAO_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vddao_3v3>; + regulator-always-on; + }; + + vddao_3v3: regulator-vddao_3v3 { + compatible = "regulator-fixed"; + regulator-name = "VDDAO_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&main_12v>; + regulator-always-on; + }; + +}; + +&cec_AO { + pinctrl-0 = <&cec_ao_a_h_pins>; + pinctrl-names = "default"; + status = "disabled"; + hdmi-phandle = <&hdmi_tx>; +}; + +&cecb_AO { + pinctrl-0 = <&cec_ao_b_h_pins>; + pinctrl-names = "default"; + status = "okay"; + hdmi-phandle = <&hdmi_tx>; +}; + +&cvbs_vdac_port { + cvbs_vdac_out: endpoint { + remote-endpoint = <&cvbs_connector_in>; + }; +}; + +&hdmi_tx { + status = "okay"; + pinctrl-0 = <&hdmitx_hpd_pins>, <&hdmitx_ddc_pins>; + pinctrl-names = "default"; + hdmi-supply = <&vcc_5v>; +}; + +&hdmi_tx_tmds_port { + hdmi_tx_tmds_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; };
&uart_AO { status = "okay"; + pinctrl-0 = <&uart_ao_a_pins>; + pinctrl-names = "default"; };
+&usb { + status = "okay"; + vbus-supply = <&usb_pwr_en>; +}; + +&usb2_phy0 { + phy-supply = <&vcc_5v>; +}; + +&usb2_phy1 { + phy-supply = <&vcc_5v>; +}; diff --git a/arch/arm/dts/meson-g12a.dtsi b/arch/arm/dts/meson-g12a.dtsi index 17c6217f8a..9f72396ba7 100644 --- a/arch/arm/dts/meson-g12a.dtsi +++ b/arch/arm/dts/meson-g12a.dtsi @@ -3,9 +3,13 @@ * Copyright (c) 2018 Amlogic, Inc. All rights reserved. */
+#include <dt-bindings/phy/phy.h> #include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clock/g12a-clkc.h> +#include <dt-bindings/clock/g12a-aoclkc.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/reset/amlogic,meson-g12a-reset.h>
/ { compatible = "amlogic,g12a"; @@ -55,6 +59,14 @@ }; };
+ efuse: efuse { + compatible = "amlogic,meson-gxbb-efuse"; + clocks = <&clkc CLKID_EFUSE>; + #address-cells = <1>; + #size-cells = <1>; + read-only; + }; + psci { compatible = "arm,psci-1.0"; method = "smc"; @@ -70,6 +82,18 @@ reg = <0x0 0x05000000 0x0 0x300000>; no-map; }; + + linux,cma { + compatible = "shared-dma-pool"; + reusable; + size = <0x0 0x10000000>; + alignment = <0x0 0x400000>; + linux,cma-default; + }; + }; + + sm: secure-monitor { + compatible = "amlogic,meson-gxbb-sm"; };
soc { @@ -85,12 +109,177 @@ #size-cells = <2>; ranges = <0x0 0x0 0x0 0xff600000 0x0 0x200000>;
+ hdmi_tx: hdmi-tx@0 { + compatible = "amlogic,meson-g12a-dw-hdmi"; + reg = <0x0 0x0 0x0 0x10000>; + interrupts = <GIC_SPI 57 IRQ_TYPE_EDGE_RISING>; + resets = <&reset RESET_HDMITX_CAPB3>, + <&reset RESET_HDMITX_PHY>, + <&reset RESET_HDMITX>; + reset-names = "hdmitx_apb", "hdmitx", "hdmitx_phy"; + clocks = <&clkc CLKID_HDMI>, + <&clkc CLKID_HTX_PCLK>, + <&clkc CLKID_VPU_INTR>; + clock-names = "isfr", "iahb", "venci"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + + /* VPU VENC Input */ + hdmi_tx_venc_port: port@0 { + reg = <0>; + + hdmi_tx_in: endpoint { + remote-endpoint = <&hdmi_tx_out>; + }; + }; + + /* TMDS Output */ + hdmi_tx_tmds_port: port@1 { + reg = <1>; + }; + }; + periphs: bus@34400 { compatible = "simple-bus"; reg = <0x0 0x34400 0x0 0x400>; #address-cells = <2>; #size-cells = <2>; ranges = <0x0 0x0 0x0 0x34400 0x0 0x400>; + + periphs_pinctrl: pinctrl@40 { + compatible = "amlogic,meson-g12a-periphs-pinctrl"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + gpio: bank@40 { + reg = <0x0 0x40 0x0 0x4c>, + <0x0 0xe8 0x0 0x18>, + <0x0 0x120 0x0 0x18>, + <0x0 0x2c0 0x0 0x40>, + <0x0 0x340 0x0 0x1c>; + reg-names = "gpio", + "pull", + "pull-enable", + "mux", + "ds"; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&periphs_pinctrl 0 0 86>; + }; + + cec_ao_a_h_pins: cec_ao_a_h { + mux { + groups = "cec_ao_a_h"; + function = "cec_ao_a_h"; + bias-disable; + }; + }; + + cec_ao_b_h_pins: cec_ao_b_h { + mux { + groups = "cec_ao_b_h"; + function = "cec_ao_b_h"; + bias-disable; + }; + }; + + hdmitx_ddc_pins: hdmitx_ddc { + mux { + groups = "hdmitx_sda", + "hdmitx_sck"; + function = "hdmitx"; + bias-disable; + }; + }; + + hdmitx_hpd_pins: hdmitx_hpd { + mux { + groups = "hdmitx_hpd_in"; + function = "hdmitx"; + bias-disable; + }; + }; + + uart_a_pins: uart-a { + mux { + groups = "uart_a_tx", + "uart_a_rx"; + function = "uart_a"; + bias-disable; + }; + }; + + uart_a_cts_rts_pins: uart-a-cts-rts { + mux { + groups = "uart_a_cts", + "uart_a_rts"; + function = "uart_a"; + bias-disable; + }; + }; + + uart_b_pins: uart-b { + mux { + groups = "uart_b_tx", + "uart_b_rx"; + function = "uart_b"; + bias-disable; + }; + }; + + uart_c_pins: uart-c { + mux { + groups = "uart_c_tx", + "uart_c_rx"; + function = "uart_c"; + bias-disable; + }; + }; + + uart_c_cts_rts_pins: uart-c-cts-rts { + mux { + groups = "uart_c_cts", + "uart_c_rts"; + function = "uart_c"; + bias-disable; + }; + }; + }; + }; + + usb2_phy0: phy@36000 { + compatible = "amlogic,g12a-usb2-phy"; + reg = <0x0 0x36000 0x0 0x2000>; + clocks = <&xtal>; + clock-names = "xtal"; + resets = <&reset RESET_USB_PHY20>; + reset-names = "phy"; + #phy-cells = <0>; + }; + + dmc: bus@38000 { + compatible = "simple-bus"; + reg = <0x0 0x38000 0x0 0x400>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x38000 0x0 0x400>; + + canvas: video-lut@48 { + compatible = "amlogic,canvas"; + reg = <0x0 0x48 0x0 0x14>; + }; + }; + + usb2_phy1: phy@3a000 { + compatible = "amlogic,g12a-usb2-phy"; + reg = <0x0 0x3a000 0x0 0x2000>; + clocks = <&xtal>; + clock-names = "xtal"; + resets = <&reset RESET_USB_PHY21>; + reset-names = "phy"; + #phy-cells = <0>; };
hiu: bus@3c000 { @@ -113,6 +302,18 @@ }; }; }; + + usb3_pcie_phy: phy@46000 { + compatible = "amlogic,g12a-usb3-pcie-phy"; + reg = <0x0 0x46000 0x0 0x2000>; + clocks = <&clkc CLKID_PCIE_PLL>; + clock-names = "ref_clk"; + resets = <&reset RESET_PCIE_PHY>; + reset-names = "phy"; + assigned-clocks = <&clkc CLKID_PCIE_PLL>; + assigned-clock-rates = <100000000>; + #phy-cells = <1>; + }; };
aobus: bus@ff800000 { @@ -122,6 +323,128 @@ #size-cells = <2>; ranges = <0x0 0x0 0x0 0xff800000 0x0 0x100000>;
+ rti: sys-ctrl@0 { + compatible = "amlogic,meson-gx-ao-sysctrl", + "simple-mfd", "syscon"; + reg = <0x0 0x0 0x0 0x100>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x0 0x0 0x100>; + + clkc_AO: clock-controller { + compatible = "amlogic,meson-g12a-aoclkc"; + #clock-cells = <1>; + #reset-cells = <1>; + clocks = <&xtal>, <&clkc CLKID_CLK81>; + clock-names = "xtal", "mpeg-clk"; + }; + + pwrc_vpu: power-controller-vpu { + compatible = "amlogic,meson-g12a-pwrc-vpu"; + #power-domain-cells = <0>; + amlogic,hhi-sysctrl = <&hhi>; + resets = <&reset RESET_VIU>, + <&reset RESET_VENC>, + <&reset RESET_VCBUS>, + <&reset RESET_BT656>, + <&reset RESET_RDMA>, + <&reset RESET_VENCI>, + <&reset RESET_VENCP>, + <&reset RESET_VDAC>, + <&reset RESET_VDI6>, + <&reset RESET_VENCL>, + <&reset RESET_VID_LOCK>; + clocks = <&clkc CLKID_VPU>, + <&clkc CLKID_VAPB>; + clock-names = "vpu", "vapb"; + /* + * VPU clocking is provided by two identical clock paths + * VPU_0 and VPU_1 muxed to a single clock by a glitch + * free mux to safely change frequency while running. + * Same for VAPB but with a final gate after the glitch free mux. + */ + assigned-clocks = <&clkc CLKID_VPU_0_SEL>, + <&clkc CLKID_VPU_0>, + <&clkc CLKID_VPU>, /* Glitch free mux */ + <&clkc CLKID_VAPB_0_SEL>, + <&clkc CLKID_VAPB_0>, + <&clkc CLKID_VAPB_SEL>; /* Glitch free mux */ + assigned-clock-parents = <&clkc CLKID_FCLK_DIV3>, + <0>, /* Do Nothing */ + <&clkc CLKID_VPU_0>, + <&clkc CLKID_FCLK_DIV4>, + <0>, /* Do Nothing */ + <&clkc CLKID_VAPB_0>; + assigned-clock-rates = <0>, /* Do Nothing */ + <666666666>, + <0>, /* Do Nothing */ + <0>, /* Do Nothing */ + <250000000>, + <0>; /* Do Nothing */ + }; + + ao_pinctrl: pinctrl@14 { + compatible = "amlogic,meson-g12a-aobus-pinctrl"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + gpio_ao: bank@14 { + reg = <0x0 0x14 0x0 0x8>, + <0x0 0x1c 0x0 0x8>, + <0x0 0x24 0x0 0x14>; + reg-names = "mux", + "ds", + "gpio"; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&ao_pinctrl 0 0 15>; + }; + + uart_ao_a_pins: uart-a-ao { + mux { + groups = "uart_ao_a_tx", + "uart_ao_a_rx"; + function = "uart_ao_a"; + bias-disable; + }; + }; + + uart_ao_a_cts_rts_pins: uart-ao-a-cts-rts { + mux { + groups = "uart_ao_a_cts", + "uart_ao_a_rts"; + function = "uart_ao_a"; + bias-disable; + }; + }; + }; + }; + + cec_AO: cec@100 { + compatible = "amlogic,meson-gx-ao-cec"; + reg = <0x0 0x00100 0x0 0x14>; + interrupts = <GIC_SPI 199 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_AO CLKID_AO_CEC>; + clock-names = "core"; + status = "disabled"; + }; + + sec_AO: ao-secure@140 { + compatible = "amlogic,meson-gx-ao-secure", "syscon"; + reg = <0x0 0x140 0x0 0x140>; + amlogic,has-chip-id; + }; + + cecb_AO: cec@280 { + compatible = "amlogic,meson-g12a-ao-cec"; + reg = <0x0 0x00280 0x0 0x1c>; + interrupts = <GIC_SPI 203 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_AO CLKID_AO_CTS_OSCIN>; + clock-names = "oscin"; + status = "disabled"; + }; + uart_AO: serial@3000 { compatible = "amlogic,meson-gx-uart", "amlogic,meson-ao-uart"; @@ -141,6 +464,46 @@ clock-names = "xtal", "pclk", "baud"; status = "disabled"; }; + + saradc: adc@9000 { + compatible = "amlogic,meson-g12a-saradc", + "amlogic,meson-saradc"; + reg = <0x0 0x9000 0x0 0x48>; + #io-channel-cells = <1>; + interrupts = <GIC_SPI 200 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, + <&clkc_AO CLKID_AO_SAR_ADC>, + <&clkc_AO CLKID_AO_SAR_ADC_CLK>, + <&clkc_AO CLKID_AO_SAR_ADC_SEL>; + clock-names = "clkin", "core", "adc_clk", "adc_sel"; + status = "disabled"; + }; + }; + + vpu: vpu@ff900000 { + compatible = "amlogic,meson-g12a-vpu"; + reg = <0x0 0xff900000 0x0 0x100000>, + <0x0 0xff63c000 0x0 0x1000>; + reg-names = "vpu", "hhi"; + interrupts = <GIC_SPI 3 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + amlogic,canvas = <&canvas>; + power-domains = <&pwrc_vpu>; + + /* CVBS VDAC output port */ + cvbs_vdac_port: port@0 { + reg = <0>; + }; + + /* HDMI-TX output port */ + hdmi_tx_port: port@1 { + reg = <1>; + + hdmi_tx_out: endpoint { + remote-endpoint = <&hdmi_tx_in>; + }; + }; };
gic: interrupt-controller@ffc01000 { @@ -163,10 +526,112 @@ #size-cells = <2>; ranges = <0x0 0x0 0x0 0xffd00000 0x0 0x100000>;
+ reset: reset-controller@1004 { + compatible = "amlogic,meson-g12a-reset", + "amlogic,meson-axg-reset"; + reg = <0x0 0x1004 0x0 0x9c>; + #reset-cells = <1>; + }; + clk_msr: clock-measure@18000 { compatible = "amlogic,meson-g12a-clk-measure"; reg = <0x0 0x18000 0x0 0x10>; }; + + uart_C: serial@22000 { + compatible = "amlogic,meson-gx-uart"; + reg = <0x0 0x22000 0x0 0x18>; + interrupts = <GIC_SPI 93 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&clkc CLKID_UART2>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + + uart_B: serial@23000 { + compatible = "amlogic,meson-gx-uart"; + reg = <0x0 0x23000 0x0 0x18>; + interrupts = <GIC_SPI 75 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&clkc CLKID_UART1>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + + uart_A: serial@24000 { + compatible = "amlogic,meson-gx-uart"; + reg = <0x0 0x24000 0x0 0x18>; + interrupts = <GIC_SPI 26 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&clkc CLKID_UART0>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + }; + + usb: usb@ffe09000 { + status = "disabled"; + compatible = "amlogic,meson-g12a-usb-ctrl"; + reg = <0x0 0xffe09000 0x0 0xa0>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + clocks = <&clkc CLKID_USB>; + resets = <&reset RESET_USB>; + + dr_mode = "otg"; + + phys = <&usb2_phy0>, <&usb2_phy1>, + <&usb3_pcie_phy PHY_TYPE_USB3>; + phy-names = "usb2-phy0", "usb2-phy1", "usb3-phy0"; + + dwc2: usb@ff400000 { + compatible = "amlogic,meson-g12a-usb", "snps,dwc2"; + reg = <0x0 0xff400000 0x0 0x40000>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clkc CLKID_USB1_DDR_BRIDGE>; + clock-names = "ddr"; + phys = <&usb2_phy1>; + dr_mode = "peripheral"; + g-rx-fifo-size = <192>; + g-np-tx-fifo-size = <128>; + g-tx-fifo-size = <128 128 16 16 16>; + }; + + dwc3: usb@ff500000 { + compatible = "snps,dwc3"; + reg = <0x0 0xff500000 0x0 0x100000>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + dr_mode = "host"; + snps,dis_u2_susphy_quirk; + snps,quirk-frame-length-adjustment; + }; + }; + + mali: gpu@ffe40000 { + compatible = "amlogic,meson-g12a-mali", "arm,mali-bifrost"; + reg = <0x0 0xffe40000 0x0 0x40000>; + interrupt-parent = <&gic>; + interrupts = <GIC_SPI 160 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "gpu", "mmu", "job"; + clocks = <&clkc CLKID_MALI>; + resets = <&reset RESET_DVALIN_CAPB3>, <&reset RESET_DVALIN>; + + /* + * Mali clocking is provided by two identical clock paths + * MALI_0 and MALI_1 muxed to a single clock by a glitch + * free mux to safely change frequency while running. + */ + assigned-clocks = <&clkc CLKID_MALI_0_SEL>, + <&clkc CLKID_MALI_0>, + <&clkc CLKID_MALI>; /* Glitch free mux */ + assigned-clock-parents = <&clkc CLKID_FCLK_DIV2P5>, + <0>, /* Do Nothing */ + <&clkc CLKID_MALI_0>; + assigned-clock-rates = <0>, /* Do Nothing */ + <800000000>, + <0>; /* Do Nothing */ }; };
diff --git a/include/dt-bindings/clock/g12a-aoclkc.h b/include/dt-bindings/clock/g12a-aoclkc.h index 8db01ffbeb..e916e49ff2 100644 --- a/include/dt-bindings/clock/g12a-aoclkc.h +++ b/include/dt-bindings/clock/g12a-aoclkc.h @@ -26,7 +26,9 @@ #define CLKID_AO_M4_FCLK 13 #define CLKID_AO_M4_HCLK 14 #define CLKID_AO_CLK81 15 +#define CLKID_AO_SAR_ADC_SEL 16 #define CLKID_AO_SAR_ADC_CLK 18 +#define CLKID_AO_CTS_OSCIN 19 #define CLKID_AO_32K 23 #define CLKID_AO_CEC 27 #define CLKID_AO_CTS_RTC_OSCIN 28 diff --git a/include/dt-bindings/clock/g12a-clkc.h b/include/dt-bindings/clock/g12a-clkc.h index 83b657038d..82c9e0c020 100644 --- a/include/dt-bindings/clock/g12a-clkc.h +++ b/include/dt-bindings/clock/g12a-clkc.h @@ -131,5 +131,10 @@ #define CLKID_MALI_1 174 #define CLKID_MALI 175 #define CLKID_MPLL_5OM 177 +#define CLKID_CPU_CLK 187 +#define CLKID_PCIE_PLL 201 +#define CLKID_VDEC_1 204 +#define CLKID_VDEC_HEVC 207 +#define CLKID_VDEC_HEVCF 210
#endif /* __G12A_CLKC_H */ diff --git a/include/dt-bindings/reset/amlogic,meson-g12a-reset.h b/include/dt-bindings/reset/amlogic,meson-g12a-reset.h index 8063e8314e..6d487c5eba 100644 --- a/include/dt-bindings/reset/amlogic,meson-g12a-reset.h +++ b/include/dt-bindings/reset/amlogic,meson-g12a-reset.h @@ -51,7 +51,10 @@ #define RESET_SD_EMMC_A 44 #define RESET_SD_EMMC_B 45 #define RESET_SD_EMMC_C 46 -/* 47-60 */ +/* 47 */ +#define RESET_USB_PHY20 48 +#define RESET_USB_PHY21 49 +/* 50-60 */ #define RESET_AUDIO_CODEC 61 /* 62-63 */ /* RESET2 */
The G12A PCIE PLL clock was introduced in Linux 5.2-rc1, and is needed for USB to operate, add basic support for it and associated gates.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/clk/meson/g12a.c | 103 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 103 insertions(+)
diff --git a/drivers/clk/meson/g12a.c b/drivers/clk/meson/g12a.c index fedc9eb7dd..112326e553 100644 --- a/drivers/clk/meson/g12a.c +++ b/drivers/clk/meson/g12a.c @@ -22,6 +22,8 @@ struct meson_clk { struct regmap *map; };
+static ulong meson_clk_set_rate_by_id(struct clk *clk, unsigned long id, + ulong rate, ulong current_rate); static ulong meson_clk_get_rate_by_id(struct clk *clk, unsigned long id);
#define NUM_CLKS 178 @@ -36,6 +38,8 @@ static struct meson_gate gates[NUM_CLKS] = { MESON_GATE(CLKID_SD_EMMC_C, HHI_GCLK_MPEG0, 26), MESON_GATE(CLKID_ETH, HHI_GCLK_MPEG1, 3), MESON_GATE(CLKID_UART1, HHI_GCLK_MPEG1, 16), + MESON_GATE(CLKID_USB, HHI_GCLK_MPEG1, 25), + MESON_GATE(CLKID_USB1_DDR_BRIDGE, HHI_GCLK_MPEG2, 8),
/* Peripheral Gates */ MESON_GATE(CLKID_SD_EMMC_B_CLK0, HHI_SD_EMMC_CLK_CNTL, 23), @@ -231,6 +235,36 @@ static ulong meson_pll_get_rate(struct clk *clk, unsigned long id) return ((parent_rate_mhz * m / n) >> od) * 1000000; }
+static struct parm meson_pcie_pll_parm[3] = { + {HHI_PCIE_PLL_CNTL0, 0, 8}, /* pm */ + {HHI_PCIE_PLL_CNTL0, 10, 5}, /* pn */ + {HHI_PCIE_PLL_CNTL0, 16, 5}, /* pod */ +}; + +static ulong meson_pcie_pll_get_rate(struct clk *clk) +{ + struct meson_clk *priv = dev_get_priv(clk->dev); + struct parm *pm, *pn, *pod; + unsigned long parent_rate_mhz = XTAL_RATE / 1000000; + u16 n, m, od; + uint reg; + + pm = &meson_pcie_pll_parm[0]; + pn = &meson_pcie_pll_parm[1]; + pod = &meson_pcie_pll_parm[2]; + + regmap_read(priv->map, pn->reg_off, ®); + n = PARM_GET(pn->width, pn->shift, reg); + + regmap_read(priv->map, pm->reg_off, ®); + m = PARM_GET(pm->width, pm->shift, reg); + + regmap_read(priv->map, pod->reg_off, ®); + od = PARM_GET(pod->width, pod->shift, reg); + + return ((parent_rate_mhz * m / n) / 2 / od / 2) * 1000000; +} + static ulong meson_clk_get_rate_by_id(struct clk *clk, unsigned long id) { ulong rate; @@ -263,6 +297,9 @@ static ulong meson_clk_get_rate_by_id(struct clk *clk, unsigned long id) case CLKID_CLK81: rate = meson_clk81_get_rate(clk); break; + case CLKID_PCIE_PLL: + rate = meson_pcie_pll_get_rate(clk); + break; default: if (gates[id].reg != 0) { /* a clock gate */ @@ -281,6 +318,71 @@ static ulong meson_clk_get_rate(struct clk *clk) return meson_clk_get_rate_by_id(clk, clk->id); }
+static ulong meson_pcie_pll_set_rate(struct clk *clk, ulong rate) +{ + struct meson_clk *priv = dev_get_priv(clk->dev); + + regmap_write(priv->map, HHI_PCIE_PLL_CNTL0, 0x20090496); + regmap_write(priv->map, HHI_PCIE_PLL_CNTL0, 0x30090496); + regmap_write(priv->map, HHI_PCIE_PLL_CNTL1, 0x00000000); + regmap_write(priv->map, HHI_PCIE_PLL_CNTL2, 0x00001100); + regmap_write(priv->map, HHI_PCIE_PLL_CNTL3, 0x10058e00); + regmap_write(priv->map, HHI_PCIE_PLL_CNTL4, 0x000100c0); + regmap_write(priv->map, HHI_PCIE_PLL_CNTL5, 0x68000048); + regmap_write(priv->map, HHI_PCIE_PLL_CNTL5, 0x68000068); + udelay(20); + regmap_write(priv->map, HHI_PCIE_PLL_CNTL4, 0x008100c0); + udelay(10); + regmap_write(priv->map, HHI_PCIE_PLL_CNTL0, 0x34090496); + regmap_write(priv->map, HHI_PCIE_PLL_CNTL0, 0x14090496); + udelay(10); + regmap_write(priv->map, HHI_PCIE_PLL_CNTL2, 0x00001000); + regmap_update_bits(priv->map, HHI_PCIE_PLL_CNTL0, + 0x1f << 16, 9 << 16); + + return 100000000; +} + +static ulong meson_clk_set_rate_by_id(struct clk *clk, unsigned long id, + ulong rate, ulong current_rate) +{ + if (current_rate == rate) + return 0; + + switch (id) { + /* Fixed clocks */ + case CLKID_PCIE_PLL: + return meson_pcie_pll_set_rate(clk, rate); + + default: + return -ENOENT; + } + + return -EINVAL; +} + + +static ulong meson_clk_set_rate(struct clk *clk, ulong rate) +{ + ulong current_rate = meson_clk_get_rate_by_id(clk, clk->id); + int ret; + + if (IS_ERR_VALUE(current_rate)) + return current_rate; + + debug("%s: setting rate of %ld from %ld to %ld\n", + __func__, clk->id, current_rate, rate); + + ret = meson_clk_set_rate_by_id(clk, clk->id, rate, current_rate); + if (IS_ERR_VALUE(ret)) + return ret; + + debug("clock %lu has new rate %lu\n", clk->id, + meson_clk_get_rate_by_id(clk, clk->id)); + + return 0; +} + static int meson_clk_probe(struct udevice *dev) { struct meson_clk *priv = dev_get_priv(dev); @@ -298,6 +400,7 @@ static struct clk_ops meson_clk_ops = { .disable = meson_clk_disable, .enable = meson_clk_enable, .get_rate = meson_clk_get_rate, + .set_rate = meson_clk_set_rate, };
static const struct udevice_id meson_clk_ids[] = {
The following DT nodes in the process on review for Linux 5.3, until Linux 5.3 is tagged, add the missing DT nodes in u-boot specific DTSI files that will be dropped when the v5.3-rc1 DT is synced again.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/dts/meson-g12a-u-boot.dtsi | 216 +++++++++++++++++++++++ arch/arm/dts/meson-g12a-u200-u-boot.dtsi | 63 +++++++ 2 files changed, 279 insertions(+) create mode 100644 arch/arm/dts/meson-g12a-u-boot.dtsi create mode 100644 arch/arm/dts/meson-g12a-u200-u-boot.dtsi
diff --git a/arch/arm/dts/meson-g12a-u-boot.dtsi b/arch/arm/dts/meson-g12a-u-boot.dtsi new file mode 100644 index 0000000000..5065d8b65a --- /dev/null +++ b/arch/arm/dts/meson-g12a-u-boot.dtsi @@ -0,0 +1,216 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS. + * Author: Maxime Jourdan mjourdan@baylibre.com + */ + +/ { + soc { + ethmac: ethernet@ff3f0000 { + compatible = "amlogic,meson-axg-dwmac", "snps,dwmac-3.710", + "snps,dwmac"; + reg = <0x0 0xff3f0000 0x0 0x10000 + 0x0 0xff634540 0x0 0x8>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + clocks = <&clkc CLKID_ETH>, + <&clkc CLKID_FCLK_DIV2>, + <&clkc CLKID_MPLL2>; + clock-names = "stmmaceth", "clkin0", "clkin1"; + status = "disabled"; + + mdio0: mdio { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + }; + }; + + sd_emmc_a: sd@ffe03000 { + compatible = "amlogic,meson-axg-mmc"; + reg = <0x0 0xffe03000 0x0 0x800>; + interrupts = <GIC_SPI 189 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + clocks = <&clkc CLKID_SD_EMMC_A>, + <&clkc CLKID_SD_EMMC_A_CLK0>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; + resets = <&reset RESET_SD_EMMC_A>; + }; + + sd_emmc_b: sd@ffe05000 { + compatible = "amlogic,meson-axg-mmc"; + reg = <0x0 0xffe05000 0x0 0x800>; + interrupts = <GIC_SPI 190 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + clocks = <&clkc CLKID_SD_EMMC_B>, + <&clkc CLKID_SD_EMMC_B_CLK0>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; + resets = <&reset RESET_SD_EMMC_B>; + }; + + sd_emmc_c: mmc@ffe07000 { + compatible = "amlogic,meson-axg-mmc"; + reg = <0x0 0xffe07000 0x0 0x800>; + interrupts = <GIC_SPI 191 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + clocks = <&clkc CLKID_SD_EMMC_C>, + <&clkc CLKID_SD_EMMC_C_CLK0>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; + resets = <&reset RESET_SD_EMMC_C>; + }; + }; +}; + +&periphs_pinctrl { + emmc_pins: emmc { + mux { + groups = "emmc_nand_d0", + "emmc_nand_d1", + "emmc_nand_d2", + "emmc_nand_d3", + "emmc_nand_d4", + "emmc_nand_d5", + "emmc_nand_d6", + "emmc_nand_d7", + "emmc_clk", + "emmc_cmd"; + function = "emmc"; + bias-pull-up; + }; + }; + + emmc_ds_pins: emmc-ds { + mux { + groups = "emmc_nand_ds"; + function = "emmc"; + bias-pull-down; + }; + }; + + emmc_clk_gate_pins: emmc_clk_gate { + mux { + groups = "BOOT_8"; + function = "gpio_periphs"; + bias-pull-down; + }; + }; + + eth_leds_pins: eth-leds { + mux { + groups = "eth_link_led", + "eth_act_led"; + function = "eth"; + bias-disable; + }; + }; + + eth_rmii_pins: eth-rmii { + mux { + groups = "eth_mdio", + "eth_mdc", + "eth_rgmii_rx_clk", + "eth_rx_dv", + "eth_rxd0", + "eth_rxd1", + "eth_txen", + "eth_txd0", + "eth_txd1"; + function = "eth"; + bias-disable; + }; + }; + + eth_rgmii_pins: eth-rgmii { + mux { + groups = "eth_rxd2_rgmii", + "eth_rxd3_rgmii", + "eth_rgmii_tx_clk", + "eth_txd2_rgmii", + "eth_txd3_rgmii"; + function = "eth"; + bias-disable; + }; + }; + + sdcard_c_pins: sdcard_c { + mux { + groups = "sdcard_d0_c", + "sdcard_d1_c", + "sdcard_d2_c", + "sdcard_d3_c", + "sdcard_cmd_c", + "sdcard_clk_c"; + function = "sdcard"; + bias-pull-up; + }; + }; + + sdcard_clk_gate_c_pins: sdcard_clk_gate_c { + mux { + groups = "GPIOC_4"; + function = "gpio_periphs"; + bias-pull-down; + }; + }; + + sdcard_z_pins: sdcard_z { + mux { + groups = "sdcard_d0_z", + "sdcard_d1_z", + "sdcard_d2_z", + "sdcard_d3_z", + "sdcard_cmd_z", + "sdcard_clk_z"; + function = "sdcard"; + bias-pull-up; + }; + }; + + sdcard_clk_gate_z_pins: sdcard_clk_gate_z { + mux { + groups = "GPIOZ_6"; + function = "gpio_periphs"; + bias-pull-down; + }; + }; +}; + +&periphs { + eth_phy: mdio-multiplexer@4c000 { + compatible = "amlogic,g12a-mdio-mux"; + reg = <0x0 0x4c000 0x0 0xa4>; + clocks = <&clkc CLKID_ETH_PHY>, + <&xtal>, + <&clkc CLKID_MPLL_5OM>; + clock-names = "pclk", "clkin0", "clkin1"; + mdio-parent-bus = <&mdio0>; + #address-cells = <1>; + #size-cells = <0>; + + ext_mdio: mdio@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + }; + + int_mdio: mdio@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + internal_ephy: ethernet_phy@8 { + compatible = "ethernet-phy-id0180.3300", + "ethernet-phy-ieee802.3-c22"; + reg = <8>; + max-speed = <100>; + + /* FIXME: Add irq support */ + }; + }; + }; +}; + + diff --git a/arch/arm/dts/meson-g12a-u200-u-boot.dtsi b/arch/arm/dts/meson-g12a-u200-u-boot.dtsi new file mode 100644 index 0000000000..9486ab0c47 --- /dev/null +++ b/arch/arm/dts/meson-g12a-u200-u-boot.dtsi @@ -0,0 +1,63 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS. + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include "meson-g12a-u-boot.dtsi" + + / { + aliases { + ethernet0 = ðmac; + }; + + emmc_pwrseq: emmc-pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&gpio BOOT_12 GPIO_ACTIVE_LOW>; + }; +}; + +ðmac { + status = "okay"; + pinctrl-0 = <ð_leds_pins>; + pinctrl-names = "default"; + phy-handle = <&internal_ephy>; + phy-mode = "rmii"; +}; + + +/* SD card */ +&sd_emmc_b { + status = "okay"; + pinctrl-0 = <&sdcard_c_pins>; + pinctrl-1 = <&sdcard_clk_gate_c_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <4>; + cap-sd-highspeed; + max-frequency = <50000000>; + disable-wp; + + cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>; + vmmc-supply = <&vddao_3v3>; + vqmmc-supply = <&vddao_3v3>; +}; + +/* eMMC */ +&sd_emmc_c { + status = "okay"; + pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <8>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + max-frequency = <200000000>; + disable-wp; + + mmc-pwrseq = <&emmc_pwrseq>; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&flash_1v8>; +};
- Copyright (c) 2019 BayLibre, SAS.
- Author: Maxime Jourdan mjourdan@baylibre.com
Oops wrong author, will fix while applying
- soc {
"snps,dwmac";
mdio0: mdio {
#size-cells = <0>;
+&periphs_pinctrl {
- emmc_pins: emmc {
mux {
"emmc_nand_d1",
"emmc_nand_d2",
"emmc_nand_d3",
"emmc_nand_d4",
"emmc_nand_d5",
"emmc_nand_d6",
"emmc_nand_d7",
"emmc_clk",
"emmc_cmd";
function = "emmc";
bias-pull-up;
- emmc_ds_pins: emmc-ds {
mux {
function = "emmc";
bias-pull-down;
- emmc_clk_gate_pins: emmc_clk_gate {
mux {
groups = "BOOT_8";
bias-pull-down;
- eth_leds_pins: eth-leds {
mux {
"eth_act_led";
function = "eth";
bias-disable;
- eth_rmii_pins: eth-rmii {
mux {
"eth_mdc",
"eth_rgmii_rx_clk",
"eth_rx_dv",
"eth_rxd0",
"eth_rxd1",
"eth_txen",
"eth_txd0",
"eth_txd1";
function = "eth";
bias-disable;
- eth_rgmii_pins: eth-rgmii {
mux {
"eth_rxd3_rgmii",
"eth_rgmii_tx_clk",
"eth_txd2_rgmii",
"eth_txd3_rgmii";
function = "eth";
bias-disable;
- sdcard_c_pins: sdcard_c {
mux {
"sdcard_d1_c",
"sdcard_d2_c",
"sdcard_d3_c",
"sdcard_cmd_c",
"sdcard_clk_c";
bias-pull-up;
- sdcard_clk_gate_c_pins: sdcard_clk_gate_c {
mux {
groups = "GPIOC_4";
bias-pull-down;
- sdcard_z_pins: sdcard_z {
mux {
"sdcard_d1_z",
"sdcard_d2_z",
"sdcard_d3_z",
"sdcard_cmd_z",
"sdcard_clk_z";
bias-pull-up;
- sdcard_clk_gate_z_pins: sdcard_clk_gate_z {
mux {
groups = "GPIOZ_6";
bias-pull-down;
+&periphs {
- eth_phy: mdio-multiplexer@4c000 {
<&xtal>,
#size-cells = <0>;
ext_mdio: mdio@0 {
reg = <0>;
#size-cells = <0>;
int_mdio: mdio@1 {
reg = <1>;
#size-cells = <0>;
reg = <8>;
max-speed = <100>;
- Author: Neil Armstrong narmstrong@baylibre.com
- aliases {
ethernet0 = ðmac;
- emmc_pwrseq: emmc-pwrseq {
+ðmac {
- status = "okay";
- pinctrl-0 = <ð_leds_pins>;
- pinctrl-names = "default";
- phy-handle = <&internal_ephy>;
- phy-mode = "rmii";
- status = "okay";
- pinctrl-0 = <&sdcard_c_pins>;
- pinctrl-1 = <&sdcard_clk_gate_c_pins>;
- pinctrl-names = "default", "clk-gate";
- bus-width = <4>;
- cap-sd-highspeed;
- max-frequency = <50000000>;
- disable-wp;
- cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>;
- vmmc-supply = <&vddao_3v3>;
- vqmmc-supply = <&vddao_3v3>;
- status = "okay";
- pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>;
- pinctrl-1 = <&emmc_clk_gate_pins>;
- bus-width = <8>;
- cap-mmc-highspeed;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- max-frequency = <200000000>;
- disable-wp;
- mmc-pwrseq = <&emmc_pwrseq>;
- vmmc-supply = <&vcc_3v3>;
- vqmmc-supply = <&flash_1v8>;
This patchset :
Applied to u-boot-amlogic
Neil Armstrong
