[U-Boot] [PATCH] ARM: da850-evm: Remove repeated pinmuxing calls
arch_cpu_init() initializes the pinmuxing which is called fairly early in the start sequences, so the board_init function doesn't need to do it again. This patch removes the call from board_init.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index c5404e6063..fb1f5750fa 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -344,10 +344,6 @@ int board_init(void) DAVINCI_SYSCFG_SUSPSRC_UART2), &davinci_syscfg_regs->suspsrc);
- /* configure pinmux settings */ - if (davinci_configure_pin_mux_items(pinmuxes, ARRAY_SIZE(pinmuxes))) - return 1; - #ifdef CONFIG_USE_NOR /* Set the GPIO direction as output */ clrbits_le32((u32 *)GPIO_BANK0_REG_DIR_ADDR, (0x01 << 11));
Adam Ford
