[U-Boot] [PATCH] ARM: atmel: add at91sam9g20ek_2mmc nand boot support
Add at91sam9g20_2mmc nand boot support. on this board, there is no dataflash, so disable it
change one commet for at91sam9g20ek board
Signed-off-by: Bo Shen voice.shen@atmel.com --- board/atmel/at91sam9260ek/at91sam9260ek.c | 7 ++++++- boards.cfg | 1 + include/configs/at91sam9260ek.h | 2 ++ 3 files changed, 9 insertions(+), 1 deletion(-)
diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index 2555672..3aa394a 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -157,13 +157,18 @@ int board_early_init_f(void)
int board_init(void) { +#ifdef CONFIG_AT91SAM9G20EK_2MMC + /* arch number of AT91SAM9G20EK_2MMC-Board */ + gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9G20EK_2MMC; +#else #ifdef CONFIG_AT91SAM9G20EK - /* arch number of AT91SAM9260EK-Board */ + /* arch number of AT91SAM9G20EK-Board */ gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9G20EK; #else /* arch number of AT91SAM9260EK-Board */ gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9260EK; #endif +#endif /* adress of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
diff --git a/boards.cfg b/boards.cfg index e4b0d44..fa863dc 100644 --- a/boards.cfg +++ b/boards.cfg @@ -95,6 +95,7 @@ at91sam9g10ek_nandflash arm arm926ejs at91sam9261ek atmel at91sam9g20ek_dataflash_cs0 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,SYS_USE_DATAFLASH_CS0 at91sam9g20ek_dataflash_cs1 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,SYS_USE_DATAFLASH_CS1 at91sam9g20ek_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,SYS_USE_NANDFLASH +at91sam9g20ek_2mmc_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH at91sam9m10g45ek_nandflash arm arm926ejs at91sam9m10g45ek atmel at91 at91sam9m10g45ek:AT91SAM9M10G45,SYS_USE_NANDFLASH at91sam9rlek_dataflash arm arm926ejs at91sam9rlek atmel at91 at91sam9rlek:AT91SAM9RL,SYS_USE_DATAFLASH at91sam9rlek_nandflash arm arm926ejs at91sam9rlek atmel at91 at91sam9rlek:AT91SAM9RL,SYS_USE_NANDFLASH diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index f921fac..02696b3 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -126,6 +126,7 @@ #endif
/* DataFlash */ +#ifndef CONFIG_AT91SAM9G20EK_2MMC #define CONFIG_ATMEL_DATAFLASH_SPI #define CONFIG_HAS_DATAFLASH 1 #define CONFIG_SYS_SPI_WRITE_TOUT (5*CONFIG_SYS_HZ) @@ -133,6 +134,7 @@ #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 0xD0000000 /* CS1 */ #define AT91_SPI_CLK 15000000 +#endif
#ifdef CONFIG_AT91SAM9G20EK #define DATAFLASH_TCSS (0x22 << 16)
Hi Andreas,
Signed-off-by: Bo Shenvoice.shen@atmel.com
ping?
- /* arch number of AT91SAM9G20EK_2MMC-Board */
- gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9G20EK_2MMC;
- /* arch number of AT91SAM9G20EK-Board */ gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9G20EK; #else /* arch number of AT91SAM9260EK-Board */ gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9260EK; #endif
#ifdef CONFIG_AT91SAM9G20EK #define DATAFLASH_TCSS (0x22<< 16)
Dear Bo Shen,
applied to u-boot-atmel/master, thanks!
Best regards
Andreas Bießmann
andreas.devel@googlemail.com
Bo Shen
