[U-Boot] [PATCH] rtc: pcf8563: Make century compatible with Linux
This driver uses the century bit of this RTC in the opposite way Linux does.
From Linux's rtc-pcf8563.c:
/* * The meaning of MO_C bit varies by the chip type. * From PCF8563 datasheet: this bit is toggled when the years * register overflows from 99 to 00 * 0 indicates the century is 20xx * 1 indicates the century is 19xx * From RTC8564 datasheet: this bit indicates change of * century. When the year digit data overflows from 99 to 00, * this bit is set. By presetting it to 0 while still in the * 20th century, it will be set in year 2000, ... * There seems no reliable way to know how the system use this * bit. So let's do it heuristically, assuming we are live in * 1970...2069. */
As U-Boot's PCF8563 driver does not say it is supposed to support the RTC8564, make this driver compatible with Linux's by giving the opposite meaning to the century bit.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Wolfgang Denk wd@denx.de --- .../drivers/rtc/pcf8563.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git u-boot-66714b1.orig/drivers/rtc/pcf8563.c u-boot-66714b1/drivers/rtc/pcf8563.c index 339e5f6..a028533 100644 --- u-boot-66714b1.orig/drivers/rtc/pcf8563.c +++ u-boot-66714b1/drivers/rtc/pcf8563.c @@ -72,7 +72,7 @@ int rtc_get (struct rtc_time *tmp) tmp->tm_hour = bcd2bin (hour & 0x3F); tmp->tm_mday = bcd2bin (mday & 0x3F); tmp->tm_mon = bcd2bin (mon_cent & 0x1F); - tmp->tm_year = bcd2bin (year) + ((mon_cent & 0x80) ? 2000 : 1900); + tmp->tm_year = bcd2bin (year) + ((mon_cent & 0x80) ? 1900 : 2000); tmp->tm_wday = bcd2bin (wday & 0x07); tmp->tm_yday = 0; tmp->tm_isdst= 0; @@ -94,7 +94,7 @@ int rtc_set (struct rtc_time *tmp)
rtc_write (0x08, bin2bcd(tmp->tm_year % 100));
- century = (tmp->tm_year >= 2000) ? 0x80 : 0; + century = (tmp->tm_year >= 2000) ? 0 : 0x80; rtc_write (0x07, bin2bcd(tmp->tm_mon) | century);
rtc_write (0x06, bin2bcd(tmp->tm_wday));
On Fri, Jul 20, 2012 at 04:05:36 PM, Benoît Thébaudeau wrote:
This driver uses the century bit of this RTC in the opposite way Linux does. From Linux's rtc-pcf8563.c: /* * The meaning of MO_C bit varies by the chip type. * From PCF8563 datasheet: this bit is toggled when the years * register overflows from 99 to 00 * 0 indicates the century is 20xx * 1 indicates the century is 19xx * From RTC8564 datasheet: this bit indicates change of * century. When the year digit data overflows from 99 to 00, * this bit is set. By presetting it to 0 while still in the * 20th century, it will be set in year 2000, ... * There seems no reliable way to know how the system use this * bit. So let's do it heuristically, assuming we are live in * 1970...2069. */
- tmp->tm_year = bcd2bin (year) + ((mon_cent & 0x80) ? 1900 : 2000); tmp->tm_wday = bcd2bin (wday & 0x07); tmp->tm_yday = 0; tmp->tm_isdst= 0;
Ping?
Benoît
1900);
Ping?
Can someone answer, please?
Best regards, Benoît
Dear Benoît Thébaudeau,
In message 2136837803.335794.1342793136811.JavaMail.root@advansee.com you wrote:
This driver uses the century bit of this RTC in the opposite way Linux does> . From Linux's rtc-pcf8563.c: /* * The meaning of MO_C bit varies by the chip type. * From PCF8563 datasheet: this bit is toggled when the years * register overflows from 99 to 00 * 0 indicates the century is 20xx * 1 indicates the century is 19xx * From RTC8564 datasheet: this bit indicates change of * century. When the year digit data overflows from 99 to 00, * this bit is set. By presetting it to 0 while still in the * 20th century, it will be set in year 2000, ... * There seems no reliable way to know how the system use this * bit. So let's do it heuristically, assuming we are live in * 1970...2069. */
As U-Boot's PCF8563 driver does not say it is supposed to support the RTC85> 64, make this driver compatible with Linux's by giving the opposite meaning to > the century bit.
Applied, thanks.
Benoît Thébaudeau
